Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleLogicalTransactionStatus Class
The OracleLogicalTransactionStatus class provides information on the status of a logical transaction.
Class Inheritance
System.Object
  System.MarshalByRefObject
    Oracle.DataAccess.Client.OracleLogicalTransactionStatus
Declaration
// C#
public sealed class OracleLogicalTransactionStatus
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
OracleLogicalTransactionStatus Properties
OracleLoigcalTransactionStatus properties are listed in Table 5-74
Table 5-74 OracleLogicalTransactionStatus Properties
Property Description
Committed
Specifies if a transaction was committed
UserCallCompleted
Specifies if the application expects additional data such as PL/SQL out binds or DML to be returned with the COMMIT or if the COMMIT is part way through a PL/SQL
Committed
This property returns true if the transaction was committed.
Declaration
// C#
public bool Committed {get; set;}
Property Value
bool
Remarks
Table 5-75 describes the possible outcomes of the Committed and UserCallCompleted properties.
Table 5-75 Outcome of OracleLogicalTransactionStatus Properties
Committed Value UserCallCompleted Value Outcome
false
false
The call did not execute the commit.
true
true
The call did execute the commit and there was no additional information to return and no more work to do if that call was a PL/SQL procedure.
true
false
The transaction is committed, but the information returned may be incomplete and/or not all expected work was completed. Examples of incomplete information or incomplete work done include: the number of rows modified when using autocommit or commit on success, parameter and function results when calling PL/SQL procedures, or PL/SQL procedures with more work to do after the commit. In order to function correctly, .NET applications that use data returned from the commit must check the UserCallCompleted value.
UserCallCompleted
This property returns true if the application expects additional data such as PL/SQL out binds or DML to be returned with the commit or if the commit is part way through a PL/SQL procedure.
Declaration
// C#
public bool UserCallCompleted {get; set;}
Property Value
bool
Remarks
