Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleNotificationSource Enumeration
OracleNotificationSource enumerated values specify the different sources that cause notification.
Table 9-29 lists all the OracleNotificationSource enumeration values with a description of each enumerated value.
Table 9-29 OracleNotificationSource Members
Member Name Description
Data
The data in a table has changed.
Database
A database event such as a database startup or shutdown occurs.
Object
A database object is altered or dropped.
Subscription
The subscription is changed.
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
