Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleParameterCollection Class
An OracleParameterCollection class represents a collection of all parameters relevant to an OracleCommand object and their mappings to DataSet columns.
Class Inheritance
System.Object
  System.MarshalByRefObject
    System.Data.Common.DbParameterCollection
      Oracle.DataAccess.Client.OracleParameterCollection
Declaration
// C#
public sealed class OracleParameterCollection : DbParameterCollection,
    IDataParameterCollection, IList, ICollection, IEnumerable
Requirements
Provider ODP.NET, Unmanaged Driver ODP.NET, Managed Driver
Assembly Oracle.DataAccess.dll Oracle.ManagedDataAccess.dll
Namespace Oracle.DataAccess.Client Oracle.ManagedDataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
The position of an OracleParameter added into the OracleParameterCollection is the binding position in the SQL statement. Position is 0-based and is used only for positional binding. If named binding is used, the position of an OracleParameter in the OracleParameterCollection is ignored.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleParameterCollectionSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    OracleParameter[] prm = new OracleParameter[3];
    // Create OracleParameter objects through OracleParameterCollection
    OracleCommand cmd = con.CreateCommand();
    cmd.CommandText = "select max(empno) from emp";
    int maxno = int.Parse(cmd.ExecuteScalar().ToString());
    prm[0] = cmd.Parameters.Add("paramEmpno", OracleDbType.Decimal,
      maxno + 10, ParameterDirection.Input);
    prm[1] = cmd.Parameters.Add("paramEname", OracleDbType.Varchar2,
      "Client", ParameterDirection.Input);
    prm[2] = cmd.Parameters.Add("paramDeptNo", OracleDbType.Decimal,
    cmd.CommandText =
      "insert into emp(empno, ename, deptno) values(:1, :2, :3)";
    cmd.ExecuteNonQuery();
    Console.WriteLine("Record for employee id {0} has been inserted.",
      maxno + 10);
    // Remove all parameters from OracleParameterCollection
    cmd.Parameters.Clear();
    prm[0].Dispose();
    prm[1].Dispose();
    prm[2].Dispose();
    cmd.Dispose();
    con.Close();
    con.Dispose();
OracleParameterCollection Members
OracleParameterCollection members are listed in the following tables.
OracleParameterCollection Static Methods
OracleParameterCollection static methods are listed in Table 5-83.
Table 5-83 OracleParameterCollection Static Methods
Method Description
Equals
Inherited from System.Object (Overloaded)
OracleParameterCollection Properties
OracleParameterCollection properties are listed in Table 5-84.
Table 5-84 OracleParameterCollection Properties
Property Description
Count
Specifies the number of OracleParameters in the collection
Item
Gets and sets the OracleParameter object (Overloaded)
OracleParameterCollection Public Methods
OracleParameterCollection public methods are listed in Table 5-85.
Table 5-85 OracleParameterCollection Public Methods
Public Method Description
Add
Adds objects to the collection (Overloaded)
AddRange
Adds elements to the end of the OracleParameterCollection
Clear
Removes all the OracleParameter objects from the collection
Contains
Indicates whether or not objects exist in the collection (Overloaded)
CopyTo
Copies OracleParameter objects from the collection, starting with the supplied index to the supplied array
CreateObjRef
Inherited from System.MarshalByRefObject
Equals
GetHashCode
GetLifetimeService
GetType
InitializeLifetimeService
IndexOf
Returns the index of the objects in the collection (Overloaded)
Insert
Inserts the supplied OracleParameter to the collection at the specified index
Remove
Removes objects from the collection
RemoveAt
Removes objects from the collection by location (Overloaded)
ToString
The OracleParameterCollection static method is listed in Table 5-86.
Table 5-86 OracleParameterCollection Static Method
Method Description
Equals
OracleParameterCollection properties are listed in Table 5-87.
Table 5-87 OracleParameterCollection Properties
Count
Item
Count
This property specifies the number of OracleParameter objects in the collection.
Declaration
// C#
public override int Count {get;}
Property Value
The number of OracleParameter objects.
Implements
ICollection
Remarks
Default = 0
Item
Item gets and sets the OracleParameter object.
Overload List:
  • Item[int]
    This property gets and sets the OracleParameter object at the index specified by the supplied parameterIndex.
  • Item[string]
    This property gets and sets the OracleParameter object using the parameter name specified by the supplied parameterName.
Item[int]
Declaration
// C#
public object Item[int parameterIndex] {get; set;}
Property Value
An object.
Implements
IList
Exceptions
IndexOutOfRangeException - The supplied index does not exist.
Remarks
The OracleParameterCollection class is a zero-based index.
Item[string]
Declaration
// C#
public OracleParameter Item[string parameterName] {get; set;};
Property Value
An OracleParameter.
Implements
Exceptions
IndexOutOfRangeException - The supplied parameter name does not exist.
OracleParameterCollection public methods are listed in Table 5-88.
Table 5-88 OracleParameterCollection Public Methods
Add
AddRange
Clear
Contains
CopyTo
CreateObjRef
Equals
GetHashCode
GetLifetimeService
GetType
IndexOf
Insert
Remove
RemoveAt
ToString
Add
Add adds objects to the collection.
Overload List:
Add(object)
This method adds the supplied object to the collection.
Declaration
// C#
public override int Add(object obj);
Parameters
  • obj
    The supplied object.
Return Value
The index at which the new OracleParameter is added.
Implements
IList
Remarks
InvalidCastException - The supplied obj cannot be cast to an OracleParameter object.
Add(OracleParameter)
This method adds the supplied OracleParameter object to the collection.
Declaration
// C#
public OracleParameter Add(OracleParameter paramObj);
Parameters
  • paramObj
    The supplied OracleParameter object.
Return Value
The newly created OracleParameter object which was added to the collection.
Add(string, object)
This method adds an OracleParameter object to the collection using the supplied name and object value
Declaration
// C#
public OracleParameter Add(string name, object val);
Parameters
  • name
    The parameter name.
  • val
    The OracleParameter value.
Return Value
Add(string, OracleDbType)
This method adds an OracleParameter object to the collection using the supplied name and database type.
Declaration
// C#
public OracleParameter Add(string name, OracleDbType dbType);
Parameters
  • name
    The parameter name.
  • dbType
    The data type of the OracleParameter.
Return Value
Add(string, OracleDbType, ParameterDirection)
This method adds an OracleParameter object to the collection using the supplied name, database type, and direction.
Declaration
// C#
public OracleParameter Add(string name, OracleDbType dbType,
   ParameterDirection direction);
Parameters
  • name
    The parameter name.
  • dbType
  • direction
    The OracleParameter direction.
Return Value
Add(string, OracleDbType, object, ParameterDirection)
This method adds an OracleParameter object to the collection using the supplied name, database type, parameter value, and direction.
Declaration
// C#
public OracleParameter Add(string name, OracleDbType dbType, object val,
    ParameterDirection dir);
Parameters
  • name
    The parameter name.
  • dbType
  • val
  • dir
    The ParameterDirection value.
Return Value
Example
// C#
using System;
using System.Data;
class AddSample
  static void Main()
    OracleCommand cmd = new OracleCommand();
    // Add parameter to the OracleParameterCollection
    OracleParameter prm = cmd.Parameters.Add(
      "MyParam", OracleDbType.Decimal, 1, ParameterDirection.Input);
    // Prints "cmd.Parameters.Count = 1"
    Console.WriteLine("cmd.Parameters.Count = " + cmd.Parameters.Count);
    prm.Dispose();
    cmd.Dispose();
Add(string, OracleDbType, int, object, ParameterDirection)
This method adds an OracleParameter object to the collection using the supplied name, database type, size, parameter value, and direction.
Declaration
// C#
public OracleParameter Add(string name, OracleDbType dbType, int size,
    object val, ParameterDirection dir;
Parameters
  • name
    The parameter name.
  • dbType
  • size
    The size of OracleParameter.
  • val
  • dir
Return Value
Add(string, OracleDbType, int)
This method adds an OracleParameter object to the collection using the supplied name, database type, and size.
Declaration
// C#
public OracleParameter Add(string name, OracleDbType dbType, int size);
Parameters
  • name
    The parameter name.
  • dbType
  • size
Return Value
Example
// C#
using System;
class AddSample
  static void Main()
      "MyParam", OracleDbType.Varchar2, 10);
    prm.Dispose();
    cmd.Dispose();
Add (string, OracleDbType, int, string)
This method adds an OracleParameter object to the collection using the supplied name, database type, size, and source column.
Declaration
// C#
    string srcColumn);
Parameters
  • name
    The parameter name.
  • dbType
  • size
  • srcColumn
    The name of the source column.
Return Value
An OracleParameter.
Add(string, OracleDbType, int, ParameterDirection, bool, byte, byte, string, DataRowVersion, object)
This method adds an OracleParameter object to the collection using the supplied name, database type, size, direction, null indicator, precision, scale, source column, source version, and parameter value.
Declaration
// C#
    ParameterDirection dir, bool isNullable, byte precision,
    byte scale, string srcColumn, DataRowVersion version, object val);
Parameters
  • name
    The parameter name.
  • dbType
  • size
  • dir
  • isNullable
    An indicator that specifies if the parameter value can be null.
  • precision
    The precision of the parameter value.
  • scale
    The scale of the parameter value.
  • srcColumn
  • version
    The DataRowVersion value.
  • val
    The parameter value.
Return Value
Exceptions
ArgumentException - The type of supplied val does not belong to the type of Value property in any of the ODP.NET Types.
AddRange
This method adds elements to the end of the OracleParameterCollection.
Declaration
// C#
public override void AddRange(Array paramArray );
Parameters
paramArray
An array of OracleParameter objects.
Exceptions
ArgumentNullException - The input parameter is null.
Clear
This method removes all the OracleParameter objects from the collection.
Declaration
// C#
public override void Clear();
Implements
IList
Example
// C#
using System;
class ClearSample
  static void Main()
    OracleParameter prm = cmd.Parameters.Add("MyParam", OracleDbType.Decimal);
    // Clear all parameters in the OracleParameterCollection
    // Prints "cmd.Parameters.Count = 0"
    prm.Dispose();
    cmd.Dispose();
Contains
Contains indicates whether or not the supplied object exists in the collection.
Overload List:
  • Contains(object)
    This method indicates whether or not the supplied object exists in the collection.
  • Contains(string)
    This method indicates whether or not an OracleParameter object exists in the collection using the supplied string.
Contains(object)
Declaration
// C#
public override bool Contains(object obj)
Parameters
  • obj
    The object.
Return Value
A bool that indicates whether or not the OracleParameter specified is inside the collection.
Implements
IList
Exceptions
InvalidCastException - The supplied obj is not an OracleParameter object.
Remarks
Returns true if the collection contains the OracleParameter object; otherwise, returns false.
Example
// C#
using System;
class ContainsSample
  static void Main()
    OracleParameter prm1 = cmd.Parameters.Add("MyParam", OracleDbType.Decimal);
    // Check if the OracleParameterCollection contains prm1
    bool bContains = cmd.Parameters.Contains(prm1);
    // Prints "bContains = True"
    Console.WriteLine("bContains = " + bContains);
    OracleParameter prm2 = new OracleParameter();
    // Check if the OracleParameterCollection contains prm2
    bContains = cmd.Parameters.Contains(prm2);
    // Prints "bContains = False"
    prm1.Dispose();
    prm2.Dispose();
    cmd.Dispose();
Contains(string)
Declaration
// C#
public override bool Contains(string name);
Parameters
  • name
    The name of OracleParameter object.
Return Value
Returns true if the collection contains the OracleParameter object with the specified parameter name; otherwise, returns false.
Implements
Example
// C#
using System;
  static void Main()
    // Check if the OracleParameterCollection contains "MyParam"
    bool bContains = cmd.Parameters.Contains("MyParam");
    // Check if the OracleParameterCollection contains "NoParam"
    bContains = cmd.Parameters.Contains("NoParam");
    prm.Dispose();
    cmd.Dispose();
CopyTo
This method copies OracleParameter objects from the collection, starting with the supplied index to the supplied array.
Declaration
// C#
public override void CopyTo(Array array, int index);
Parameters
  • array
    The specified array.
  • index
    The array index.
Implements
ICollection
IndexOf
IndexOf returns the index of the OracleParameter object in the collection.
Overload List:
  • IndexOf(object)
    This method returns the index of the OracleParameter object in the collection.
  • IndexOf(String)
    This method returns the index of the OracleParameter object with the specified name in the collection.
IndexOf(object)
Declaration
// C#
public override int IndexOf(object obj);
Parameters
  • obj
    The specified object.
Return Value
Returns the index of the OracleParameter object in the collection.
Implements
IList
Exceptions
Remarks
Returns the index of the supplied OracleParameter obj in the collection.
IndexOf(String)
Declaration
// C#
public override int IndexOf(String name);
Parameters
  • name
    The name of parameter.
Return Value
Returns the index of the supplied OracleParameter in the collection.
Implements
Insert
This method inserts the supplied OracleParameter object to the collection at the specified index.
Declaration
// C#
public override void Insert(int index, object obj);
Parameters
  • index
    The specified index.
  • obj
    The OracleParameter object.
Implements
IList
Remarks
An InvalidCastException is thrown if the supplied obj cannot be cast to an OracleParameter object.
Remove
This method removes the supplied OracleParameter from the collection.
Declaration
// C#
public override void Remove(object obj);
Parameters
  • obj
    The specified object to remove.
Implements
IList
Exceptions
Example
// C#
using System;
class RemoveSample
  static void Main()
    // Add 2 parameters to the OracleParameterCollection
    OracleParameter prm1 = cmd.Parameters.Add("MyParam1", OracleDbType.Decimal);
    OracleParameter prm2 = cmd.Parameters.Add("MyParam2", OracleDbType.Decimal);
    // Prints "cmd.Parameters.Count = 2"
    // Remove the 1st parameter from the OracleParameterCollection
    cmd.Parameters.Remove(prm1);
    // Prints "cmd.Parameters[0].ParameterName = MyParam2"
    Console.WriteLine("cmd.Parameters[0].ParameterName = " +
      cmd.Parameters[0].ParameterName);
    prm1.Dispose();
    prm2.Dispose();
    cmd.Dispose();
RemoveAt
RemoveAt removes the OracleParameter object from the collection by location.
Overload List:
  • RemoveAt(int)
    This method removes from the collection the OracleParameter object located at the index specified by the supplied index.
  • RemoveAt(String)
    This method removes from the collection the OracleParameter object specified by the supplied name.
RemoveAt(int)
Declaration
// C#
public override void RemoveAt(int index);
Parameters
  • index
    The specified index from which the OracleParameter is to be removed.
Implements
IList
RemoveAt(String)
Declaration
// C#
public override void RemoveAt(String name);
Parameters
  • name
    The name of the OracleParameter object to be removed from the collection.
Implements
