| Oracle® Data Provider for .NET Developer's Guide 12c Release 1 (12.1.0.1.0) E41125-02 |
![]() Previous |
![]() Next |
An OracleTransaction object represents a local transaction.
Class Inheritance
System.Object
System.MarshalByRefObject
System.Data.Common.DbTransaction
Oracle.DataAccess.Client.OracleTransaction
Declaration
// C# public sealed class OracleTransaction : DbTransaction
// C# public sealed class OracleTransaction : MarshalByRefObject, IDbTransaction, IDisposable
Requirements
| Provider | ODP.NET, Unmanaged Driver | ODP.NET, Managed Driver |
| Assembly | Oracle.DataAccess.dll |
Oracle.ManagedDataAccess.dll |
| Namespace | Oracle.DataAccess.Client |
Oracle.ManagedDataAccess.Client |
| .NET Framework | 2.0, 3.0, 3.5, 4.0, 4.5 | 4.0, 4.5 |
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
The application calls BeginTransaction on the OracleConnection object to create an OracleTransaction object. The OracleTransaction object can be created in Read Committed mode only. Any other mode results in an exception.
The execution of a DDL statement in the context of a transaction is not recommended since it results in an implicit commit that is not reflected in the state of the OracleTransaction object.
All operations related to savepoints pertain to the current local transaction. Operations like commit and rollback performed on the transaction have no effect on data in any existing DataSet.
Example
// Database Setup, if you have not done so yet.
connect scott/tiger@oracle
DROP TABLE MyTable;
CREATE TABLE MyTable (MyColumn NUMBER);
--CREATE TABLE MyTable (MyColumn NUMBER PRIMARY KEY);
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleTransactionSample
static void Main()
// Drop & Create MyTable as indicated Database Setup, at beginning
// This sample starts a transaction and inserts two records with the same
// value for MyColumn into MyTable.
// If MyColumn is not a primary key, the transaction will commit.
// If MyColumn is a primary key, the second insert will violate the
// unique constraint and the transaction will rollback.
string constr = "User Id=scott;Password=tiger;Data Source=oracle";
OracleConnection con = new OracleConnection(constr);
con.Open();
OracleCommand cmd = con.CreateCommand();
// Check the number of rows in MyTable before transaction
cmd.CommandText = "SELECT COUNT(*) FROM MyTable";
int myTableCount = int.Parse(cmd.ExecuteScalar().ToString());
// Print the number of rows in MyTable
Console.WriteLine("myTableCount = " + myTableCount);
// Start a transaction
OracleTransaction txn = con.BeginTransaction(
IsolationLevel.ReadCommitted);
try
// Insert the same row twice into MyTable
cmd.CommandText = "INSERT INTO MyTable VALUES (1)";
cmd.ExecuteNonQuery();
cmd.ExecuteNonQuery(); // This may throw an exception
txn.Commit();
catch (Exception e)
// Print the exception message
Console.WriteLine("e.Message = " + e.Message);
// Rollback the transaction
txn.Rollback();
// Check the number of rows in MyTable after transaction
// Prints the number of rows
// If MyColumn is not a PRIMARY KEY, the value should increase by two.
// If MyColumn is a PRIMARY KEY, the value should remain same.
txn.Dispose();
cmd.Dispose();
con.Close();
con.Dispose();
Not supported in a .NET stored procedure
OracleTransaction members are listed in the following tables.
OracleTransaction Static Methods
The OracleTransaction static method is listed in Table 5-117.
Table 5-117 OracleTransaction Static Method
| Method | Description |
Inherited from |
OracleTransaction Properties
OracleTransaction properties are listed in Table 5-118.
Table 5-118 OracleTransaction Properties
| Property | Description |
Specifies the isolation level for the transaction |
Specifies the connection that is associated with the transaction |
OracleTransaction Public Methods
OracleTransaction public methods are listed in Table 5-119.
Table 5-119 OracleTransaction Public Methods
| Public Method | Description |
Commits the database transaction |
Inherited from |
Frees the resources used by the |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Rolls back a database transaction (Overloaded) |
Creates a savepoint within the current transaction |
Inherited from |
The OracleTransaction static method is listed in Table 5-120.
OracleTransaction properties are listed in Table 5-121.
Table 5-121 OracleTransaction Properties
This property specifies the isolation level for the transaction.
Declaration
// C#
public override IsolationLevel IsolationLevel {get;}
Property Value
IsolationLevel
Implements
IDbTransaction
Exceptions
InvalidOperationException - The transaction has already completed.
Remarks
Default = IsolationLevel.ReadCommitted
This property specifies the connection that is associated with the transaction.
Declaration
// C#
public OracleConnection Connection {get;}
Property Value
Connection
Implements
IDbTransaction
Remarks
This property indicates the OracleConnection object that is associated with the transaction.
OracleTransaction public methods are listed in Table 5-122.
Table 5-122 OracleTransaction Public Methods
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
Inherited from |
This method commits the database transaction.
Declaration
// C# public override void Commit();
Implements
IDbTransaction
Exceptions
InvalidOperationException - The transaction has already been completed successfully, has been rolled back, or the associated connection is closed.
Remarks
Upon a successful commit, the transaction enters a completed state.
Example
DROP TABLE MyTable;
// C#
using System;
using System.Data;
class CommitSample
static void Main()
// Drop & Create MyTable as indicated in Database Setup, at beginning
con.Open();
try
txn.Commit();
catch (Exception e)
txn.Rollback();
txn.Dispose();
cmd.Dispose();
con.Close();
con.Dispose();
This method frees the resources used by the OracleTransaction object.
Declaration
// C# public void Dispose();
Implements
IDisposable
Remarks
This method releases both the managed and unmanaged resources held by the OracleTransaction object. If the transaction is not in a completed state, an attempt to rollback the transaction is made.
Rollback rolls back a database transaction.
Overload List:
This method rolls back a database transaction.
This method rolls back a database transaction to a savepoint within the current transaction.
Declaration
// C# public override void Rollback();
Implements
IDbTransaction
Exceptions
Remarks
After a Rollback(), the OracleTransaction object can no longer be used because the Rollback ends the transaction.
Example
DROP TABLE MyTable;
// C#
using System;
using System.Data;
class RollbackSample
static void Main()
// Drop & Create MyTable as indicated previously in Database Setup
// This sample starts a transaction and inserts one record into MyTable.
// It then rollsback the transaction, the number of rows remains the same
con.Open();
// Insert a row into MyTable
txn.Rollback();
// Prints the number of rows, should remain the same
txn.Dispose();
cmd.Dispose();
con.Close();
con.Dispose();
Declaration
// C#
public override void Rollback(string savepointName);
Parameters
savepointName
The name of the savepoint to rollback to, in the current transaction.
Exceptions
Remarks
After a rollback to a savepoint, the current transaction remains active and can be used for further operations.
The savepointName specified does not have to match the case of the savepointName created using the Save method, since savepoints are created in the database in a case-insensitive manner.
This method creates a savepoint within the current transaction.
Declaration
// C#
public void Save(string savepointName);
Parameters
savepointName
The name of the savepoint being created in the current transaction.
Exceptions
InvalidOperationException - The transaction has already been completed.
Remarks
After creating a savepoint, the transaction does not enter a completed state and can be used for further operations.
The savepointName specified is created in the database in a case-insensitive manner. Calling the Rollback method rolls back to savepointName. This allows portions of a transaction to be rolled back, instead of the entire transaction.
Example
DROP TABLE MyTable;
// C#
using System;
using System.Data;
class SaveSample
static void Main()
// This sample starts a transaction and creates a savepoint after
// inserting one record into MyTable.
// After inserting the second record it rollsback to the savepoint
// and commits the transaction. Only the first record will be inserted
con.Open();
// Create a savepoint
txn.Save("MySavePoint");
// Insert another row into MyTable
cmd.CommandText = "insert into mytable values (2)";
// Rollback to the savepoint
txn.Rollback("MySavePoint");
// Commit the transaction
txn.Commit();
// Prints the number of rows, should have increased by 1
txn.Dispose();
cmd.Dispose();
con.Close();
con.Dispose();
