Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleXmlCommandType Enumeration
The OracleXmlCommandType enumeration specifies the values that are allowed for the XmlCommandType property of the OracleCommand class. It is used to specify the type of XML operation.
Table 6-1 lists all the OracleXmlCommandType enumeration values with a description of each enumerated value.
Table 6-1 OracleXmlCommandType Members
Member Name Description
None
No XML operation is desired
Query
The command text is a SQL query and the result of the query is an XML document. The SQL query needs to be a select statement
Insert
The command text is an XML document containing rows to insert.
Update
The command text is an XML document containing rows to update.
Delete
The command text is an XML document containing rows to delete.
