Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
OracleXmlSaveProperties Class
An OracleXmlSaveProperties object represents the XML properties used by the OracleCommand class when the XmlCommandType property is Insert, Update, or Delete.
Class Inheritance
System.Object
  System.OracleXmlSaveProperties
Declaration
public sealed class OracleXmlSaveProperties : ICloneable
Requirements
Provider ODP.NET, Unmanaged Driver
Assembly Oracle.DataAccess.dll
Namespace Oracle.DataAccess.Client
.NET Framework 2.0, 3.0, 3.5, 4.0, 4.5
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Remarks
OracleXmlSaveProperties can be accessed and modified using the XmlSaveProperties property of the OracleCommand class. Each OracleCommand object has its own instance of the OracleXmlSaveProperties class in the XmlSaveProperties property.
Use the default constructor to get a new instance of OracleXmlSaveProperties. Use the OracleXmlSaveProperties.Clone() method to get a copy of an OracleXmlSaveProperties instance.
Example
This sample demonstrates how to do inserts, updates, and deletes to a relational table or view using an XML document.
// C#
/* -- If HR account is being locked, you need to log on as a DBA
   -- to unlock the account first. Unlock a locked users account:
   ALTER USER hr ACCOUNT UNLOCK;
using System;
using Oracle.DataAccess.Client;
class OracleXmlSavePropertiesSample
  static void Main()
    string[] KeyColumnsList = null;
    string[] UpdateColumnsList = null;
    int rows = 0;
    // Create the connection.
    string constr = "User Id=hr;Password=hr;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Create the command.
    OracleCommand cmd = new OracleCommand("", con);
    // Set the XML command type to insert.
    cmd.XmlCommandType = OracleXmlCommandType.Insert;
    // Set the XML document.
    cmd.CommandText = "<?xml version=\"1.0\"?>\n" +
      "<ROWSET>\n" +
      " <MYROW num = \"1\">\n" +
      " <EMPLOYEE_ID>1234</EMPLOYEE_ID>\n" +
      " <LAST_NAME>Smith</LAST_NAME>\n" +
      " <EMAIL>Smith@Oracle.com</EMAIL>\n" +
      " <HIRE_DATE>1982-01-23T00:00:00.000</HIRE_DATE>\n" +
      " <JOB_ID>IT_PROG</JOB_ID>\n" +
      " </MYROW>\n" +
      " <MYROW num = \"2\">\n" +
      " <EMPLOYEE_ID>1235</EMPLOYEE_ID>\n" +
      " <LAST_NAME>Barney</LAST_NAME>\n" +
      " <EMAIL>Barney@Oracle.com</EMAIL>\n" +
      " </MYROW>\n" +
      "</ROWSET>\n";
    // Set the XML save properties.
    KeyColumnsList = new string[1];
    KeyColumnsList[0] = "EMPLOYEE_ID";
    UpdateColumnsList = new string[5];
    UpdateColumnsList[0] = "EMPLOYEE_ID";
    UpdateColumnsList[1] = "LAST_NAME";
    UpdateColumnsList[2] = "EMAIL";
    UpdateColumnsList[3] = "HIRE_DATE";
    UpdateColumnsList[4] = "JOB_ID";
    cmd.XmlSaveProperties.KeyColumnsList = KeyColumnsList;
    cmd.XmlSaveProperties.RowTag = "MYROW";
    cmd.XmlSaveProperties.Table = "employees";
    cmd.XmlSaveProperties.UpdateColumnsList = UpdateColumnsList;
    cmd.XmlSaveProperties.Xslt = null;
    cmd.XmlSaveProperties.XsltParams = null;
    // Do the inserts.
    rows = cmd.ExecuteNonQuery();
    Console.WriteLine("rows: " + rows);
    // Set the XML command type to update.
    cmd.XmlCommandType = OracleXmlCommandType.Update;
      "<ROWSET>\n" +
      " <LAST_NAME>Adams</LAST_NAME>\n" +
      " </MYROW>\n" +
      "</ROWSET>\n";
    UpdateColumnsList = new string[1];
    UpdateColumnsList[0] = "LAST_NAME";
    // Set the XML command type to delete.
    cmd.XmlCommandType = OracleXmlCommandType.Delete;
      "<ROWSET>\n" +
      " </MYROW>\n" +
      " </MYROW>\n" +
      "</ROWSET>\n";
    cmd.XmlSaveProperties.UpdateColumnsList = null;
    // Do the deletes.
    // Clean up.
    cmd.Dispose();
    con.Close();
    con.Dispose();
OracleXmlSaveProperties Members
OracleXmlSaveProperties members are listed in the following tables.
OracleXmlSaveProperties Constructor
OracleXmlSaveProperties constructors are listed in Table 6-7
Table 6-7 OracleXmlSaveProperties Constructor
Constructor Description
Instantiates a new instance of the OracleXmlSaveProperties class
OracleXmlSaveProperties Properties
The OracleXmlSaveProperties properties are listed in Table 6-8.
Table 6-8 OracleXmlSaveProperties Properties
Name Description
KeyColumnsList
Specifies the list of columns used as a key to locate existing rows for update or delete using an XML document
RowTag
Specifies the value for the XML element that identifies a row of data in an XML document
Table
Specifies the name of the table or view to which changes are saved
UpdateColumnsList
Specifies the list of columns to update or insert
Xslt
Specifies the XSL document used for XML transformation using XSLT
XsltParams
Specifies the parameters for the XSLT document specified in the Xslt property
OracleXmlSaveProperties Public Methods
The OracleXmlSaveProperties public methods are listed in Table 6-9.
Table 6-9 OracleXmlSaveProperties Public Methods
Name Description
Clone
Creates a copy of an OracleXmlSaveProperties object
The OracleXmlSaveProperties constructor instantiates a new instance of OracleXmlSaveProperties class.
Declaration
// C#
public OracleXmlSaveProperties;
The OracleXmlSaveProperties properties are listed in Table 6-10.
Table 6-10 OracleXmlSaveProperties Properties
Name Description
KeyColumnsList
RowTag
Table
UpdateColumnsList
Xslt
XsltParams
KeyColumnsList
This property specifies the list of columns used as a key to locate existing rows for update or delete using an XML document.
Declaration
// C#
public string[] KeyColumnsList {get; set;}
Property Value
The list of columns.
Remarks
Default value is null.
The first null value (if any) terminates the list.
KeyColumnsList usage with XMLCommandType property values:
  • Insert - KeyColumnsList is ignored and can be null.
  • Update - KeyColumnsList must be specified; it identifies the columns to use to find the rows to be updated.
  • Delete - If KeyColumnsList is null, all the column values in each row element in the XML document are used to locate the rows to delete. Otherwise, KeyColumnsList specifies the columns used to identify the rows to delete.
RowTag
This property specifies the value for the XML element that identifies a row of data in an XML document.
Declaration
// C#
public string RowTag {get; set;}
Property Value
An XML element name.
Remarks
The default value is ROW.
Each element in the XML document identifies one row in a table or view.
If RowTag is set to "" or null, no row tag is used in the XML document. In this case, the XML document is assumed to contain only one row.
Table
This property specifies the name of the table or view to which changes are saved.
Declaration
// C#
public string Table {get; set;}
Property Value
A table name.
Remarks
The property must be set to a valid table or view name.
UpdateColumnsList
This property specifies the list of columns to update or insert.
Declaration
// C#
public string[] UpdateColumnsList {get; set;}
Property Value
A list of columns.
Remarks
UpdateColumnList usage with XMLCommandType property values:
  • Insert - UpdateColumnList indicates which columns are assigned values when a new row is created. If UpdateColumnList is null, then all columns are assigned values. If a column is on the UpdateColumnList, but no value is specified for the row in the XML file, then NULL is used. If a column is not on the UpdateColumnList, then the default value for that column is used.
  • Update - UpdateColumnList specifies columns to modify for each row of data in the XML document. If UpdateColumnList is null, all the values in each XML element in the XML document are used to modify the columns.
  • Delete - UpdateColumnsList is ignored and can be null.
Xslt
This property specifies the XSL document used for XML transformation using XSLT.
Declaration
// C#
public string Xslt {get; set;}
Property Value
The XSL document used for XML transformation.
Remarks
Default = null.
The XSL document is used for XSLT transformation of a given XML document. The transformed XML document is used to save changes to the table or view.
XsltParams
This property specifies the parameters for the XSLT document specified in the Xslt property.
Declaration
// C#
public string XsltParams {get; set;}
Property Value
The parameters for the XSLT document.
Remarks
Default is null.
This property is a string delimited by semicolons in "name=value" pairs of the form "param1=value1; param2=value2; …".
The OracleXmlSaveProperties public methods are listed in Table 6-11.
Table 6-11 OracleXmlSaveProperties Public Methods
Name Description
Clone
Clone
This method creates a copy of an OracleXmlSaveProperties object.
Declaration
// C#
public object Clone();
Return Value
Implements
ICloneable
