Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
B Mapping LINQ Canonical Functions and Oracle Functions
This appendix lists the Entity Framework canonical functions and the corresponding ODP.NET provider functions to which they map.
Aggregate Canonical Functions
Canonical Function Oracle Function
Avg ( expression ) AVG(expression)
BigCount ( expression ) COUNT(expression)
Max ( expression ) MAX(expression)
Min ( expression ) MIN(expression)
StDev ( expression ) STDDEV(expression)
StDevP( expression) STDEVP(expression)
Sum ( expression ) SUM (expression)
Var(expression) VAR(expression)
VarP(expression) VARP(expression)
Math Canonical Functions
Abs ( value ) ABS (value)
Ceiling ( value ) CEIL(value)
Floor ( value ) FLOOR(value)
Power(value, exponent) POWER(value, exponent)
Round ( value ) ROUND(value)
Round ( value, digits ) ROUND(value, digits)
Truncate(value, digits) TRUNC(value, digits)
String Canonical Functions
Concat ( string1, string2) CONCAT(string1, string2)
or
( (string1) || (string2))
Contains(string, target) INSTR(string, target)
EndsWith(string, target) INSTR(REVERSE(string), REVERSE(target))
Comparison operators
IndexOf( target, string) INSTR(string2, target)
Left ( string1, length) SUBSTR(string1, length)
Length ( string ) LENGTH(string)
LTrim( string ) LTRIM(string)
Replace ( string1, string2, string3) REPLACE(string1, string2, string3)
Reverse ( string ) REVERSE(string)
Right ( string, length) (CASE WHEN LENGTH(string) >= (length) THEN SUBSTR (string) ,-(length), length ) ELSE string END)
RTrim( string ) RTRIM(string)
Substring ( string, start, length) SUBSTR(( string, start, length)
StartsWith(string, target) INSTR(string, target)
ToLower ( string ) LOWER(string)
ToUpper( string ) UPPER
Trim ( string ) LTRIM(RTRIM(string))
Date And Time Canonical Functions
AddNanoseconds(expression, number) (expression) + INTERVAL
AddMicroseconds(expression, number) (expression) + INTERVAL
AddMilliseconds(expression, number) (expression) + INTERVAL
AddSeconds(expression, number) (expression) + INTERVAL
AddMinutes(expression, number) (expression) + INTERVAL
AddHours(expression, number) (expression) + INTERVAL
AddDays(expression, number) (expression) + INTERVAL
AddMonths(expression, number) (expression) + INTERVAL
AddYears(expression, number) (expression) + INTERVAL
CreateDateTime(year, month, day, hour, minute, second) TO_TIMESTAMP
CreateDateTimeOffset(year, month, day, hour, minute, second, tzoffset) TO_TIMESTAMP_TZ
CreateTime(hour, minute, second) Time literals are not supported in Oracle
CurrentDateTime() LOCALTIMESTAMP
CurrentDateTimeOffset() SYSTIMESTAMP
CurrentUtcDateTime() SYS_EXTRACT_UTC
(LOCALTIMESTAMP)
Day(expression) EXTRACT(DAY FROM expression)
DayOfYear(expression) TO_NUMBER(TO_CHAR(CAST(expression AS TIMESTAMP), 'DDD'))
DiffNanoseconds(startExpression, endExpression) EXTRACT and arithmetic operations
DiffMilliseconds(startExpression, endExpression) EXTRACT and arithmetic operations
DiffMicroseconds(startExpression, endExpression) EXTRACT and arithmetic operations
DiffSeconds(startExpression, endExpression) EXTRACT and arithmetic operations
DiffMinutes(startExpression, endExpression) EXTRACT and arithmetic operations
DiffHours(startExpression, endExpression) EXTRACT and arithmetic operations
DiffDays(startExpression, endExpression) EXTRACT and arithmetic operations
DiffMonths(startExpression, endExpression) EXTRACT and arithmetic operations
DiffYears(startExpression, endExpression
<, <=, >, >=, <>, != operators
GetTotalOffsetMinutes ( datetimeoffset ) (EXTRACT(TIMEZONE_HOUR FROM (expression))) * 60 + EXTRACT (TIMEZONE_MINUTE FROM(expression))
(Require multiple operations.)
Hour (expression) EXTRACT(HOUR FROM expression)
Millisecond(expression) NVL(TO_NUMBER(SUBSTR(TO_CHAR(CAST(expression AS TIMESTAMP), 'DD-
MON-RR HH24:MI:SSXFF'), 20, 3)), 0)
Minute(expression) EXTRACT(MINUTE FROM expression)
Month (expression) EXTRACT(MONTH FROM expression)
Second(expression) EXTRACT (SECOND FROM expression)
TruncateDate(expression) TRUNC(expression)
Year(expression) EXTRACT(YEAR FROM expression)
Bitwise Canonical Functions
BitWiseAnd ( value1 , value2 ) BITAND(value1, value2)
BitWiseNot ( value ) ( 0 - value) - 1
BitWiseOr ( value1 , value2 ) Value1 - BITAND(value1, value2) + value2
BitWiseXor ( value1 , value2 ) Value1 - 2 * BITAND(value1, value2) + value2
Other Canonical Functions
NewGuid() SYS_GUID
