Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
15 CLSRSC-00001 to CLSRSC-04015
CLSRSC-00001: Insufficient privileges to execute this script
Cause: The script was invoked by a non-root or a non-administrator user.
Action: Run the script as the root or administrative user.
CLSRSC-00003: No value set for the required parameter 'string'
Cause: The required parameter file is missing, or no value is set for the parameter yet.
Action: Use the correct parameter file and provide each paramter with a valid value.
CLSRSC-00004: No value passed as Oracle CRS home
Cause: No value was passed as Oracle CRS home.
Action: None
CLSRSC-00005: The Oracle CRS home 'string' does not exist
Cause: The Oracle CRS home does not exist.
Action: Make sure that the Oracle Grid Infrastructure software is properly installed.
CLSRSC-00006: No value passed as Oracle Clusterware name
Cause: No value was passed as Oracle Clusterware name.
Action: None
CLSRSC-00007: The OCR location file '/etc/oracle/ocr.loc' is corrupted
Cause: The OCR location file '/etc/oracle/ocr.loc' is corrupted.
Action: Make sure that the '/etc/oracle' directory is empty if this is a fresh install.
CLSRSC-00008: No value passed as OCR locations
Cause: No value was passed as OCR locations.
Action: None
CLSRSC-00009: No value passed as OLR locations
Cause: No value was passed as OLR locations.
Action: None
CLSRSC-00010: The VIP resource was not created due to VIP address not available.
Cause: There was an error in obtaining a VIP address from the DHCP server.
Action: Run the command 'cluvfy comp dhcp' to check the DHCP server.
CLSRSC-00011: No value passed for OLR locations
Action: None
CLSRSC-00012: The ASM resource ora.asm did not start
Cause: There was an error in starting the ASM resource.
Action: Check the accompanying messages and contact Oracle Support Services.
CLSRSC-00013: The file 'string' does not exist
Cause: The specified file does not exist.
Action: None
CLSRSC-00014: CSS is configured for single instance Oracle databases
Cause: The current configuraiton is for previous installation.
Action: Delete this configuration using the command 'localconfig delete' before proceeding with Oracle RAC configuration.
CLSRSC-00015: No value passed for host name
Cause: No value was passed as the host name.
Action: None
CLSRSC-00016: No value passed for Oracle CRS user
Cause: No value was passed as Oracle crs user.
Action: None
CLSRSC-00017: Invalid GPnP setup
Cause: GPnP directories do not exist.
Action: Make sure that GPnP directories must exist.
CLSRSC-00018: The GPnP peer wallet file 'string' does not exist or is not readable
Cause: The GPnP peer wallet file does not exist or is not readable.
Action: None
CLSRSC-00019: 9i GSD is running on the Cluster nodes (string)
Cause: 9i GSD is running on the Cluster nodes.
Action: Stop the GSD and re-run 'root.sh' on UNIX platforms or 'gridconfig.bat' on Windows.
CLSRSC-00020: Invalid network type in the network specification string 'string'. Only 'public' and 'cluster_interconnect' are allowed
Cause: Internal error.
Action: If the problem persists, contact Oracle Support Services.
CLSRSC-00021: No value passed for the directory name
CLSRSC-00022: The directory 'string' does not exist
Cause: The specified directory does not exist.
CLSRSC-00023: No value passed for the file name
CLSRSC-00024: No value passed for the host name.
CLSRSC-00025: Unable to find the command 'string' to stop Clusterware
Cause: Cannot stop Clusterware because the required executable file does not exist.
CLSRSC-00026: The file system of 'string' is invalid
Cause: The root is not able to perform any operations on this file system.
Action: Check export options on NAS filer and make sure that the file system is not corrupted.
CLSRSC-00027: The GPnP configuration reader wallet in given directory 'string' is missing
Cause: The setup in GPnP configuration directory is incomplete.
CLSRSC-00028: The GPnP configuration reader wallet in given directory 'string' is invalid
Cause: The setup in GPnP configuration directory is invalid.
CLSRSC-00029: Invalid GPnP configuration directories. The cluster-wide 'string' and node-specific 'string' must be different
Cause: Invalid configuration was found while verifying the GPnP local and cluster-wide setup.
Action: None
CLSRSC-00030: No parameters specified to query from GPnP profile 'string'
Cause: The required parameters were not supplied while querying from GPnP profile.
Action: None
CLSRSC-00031: GPnP profile signature verification failed
Cause: The signature status string was not found in the output of 'gpnptool' execution.
Action: If error persists, contact Oracle Support Services.
CLSRSC-00032: The 'string' file is not readable
Cause: No read access to the specified file.
Action: Check the permissons on this file and make sure it is readable.
CLSRSC-00033: The OLR from version 'string' is missing or unusable for upgrade
Cause: Invalid OLR file was found during upgrade.
CLSRSC-00034: IPv6 is currently not supported
Cause: Attempt was made to use IPv6.
Action: None
CLSRSC-00035: The value set for the parameter 'CRS_NODEVIPS' is null
Cause: No value set for the parameter 'CRS_NODEVIPS'.
Action: Set 'CRS_NODEVIPS' parameter in 'crsconfig_params' and re-run 'rootupgrade.sh'. The format is as follows: CRS_NODEVIPS='node1-vip/node1-netmask/node1-interface,node2-vip/node2-netmask/node2-interface'.
CLSRSC-00036: The file 'string' does not exist to proceed with deconfiguration
Cause: Some files are missing in the Grid Infrastructure Home.
Action: Contact Oracle Support Services.
CLSRSC-00037: Run the deconfiguration script with a -force option.
Cause: The deconfiguration failed due to a missing file.
Action: Perform the deconfiguration using the -force option and manually stop any processes running from the GI home.
CLSRSC-00038: Oracle Clusterware stack is not active on this node
Cause: Oracle Clusterware is not running on this node.
Action: Restart the Clusterware stack using 'crsctl start crs' and retry.
CLSRSC-00039: Oracle Restart stack is not active on this node
Cause: Oracle SIHA stack is not running on this node.
Action: Restart the SIHA stack using 'crsctl start has' and retry.
CLSRSC-00040: No value passed for owner name
CLSRSC-00041: No value passed for group name
CLSRSC-00042: No value passed for the file or directory name
CLSRSC-00043: No value passed for permissions
CLSRSC-00044: The init script file name passed is null
CLSRSC-00045: The init script file 'string' does not exist
CLSRSC-00046: Error: 'string' does not exist
Cause: The specified file or directory does not exist.
Action: None
CLSRSC-00101: Could not copy OCR locations
CLSRSC-00102: Could not delete the OLR file 'string' (error: string)
CLSRSC-00103: An error occured while accessing the file 'string'
Cause: The specified file does not exist or is not readable.
Action: Make sure the file exists and it has read and execute access.
CLSRSC-00104: Could not execute 'string -g' and read output (error: string)
Cause: Unable to execute the specified command.
CLSRSC-00105: Failed to copy 'string' to 'string' (error: string)
Cause: An error occurred while copying the specified file.
CLSRSC-00106: Copy of older local-only OCR failed
Cause: An error occurred while copying over older local-only OCR to SIHA home.
Action: None
CLSRSC-00107: Start of GNS failed
Cause: This is a status message.
Action: None
CLSRSC-00108: Failed to start VIP on node 'string'
Action: None
CLSRSC-00109: Start of ASM diskgroup failed
Action: None
CLSRSC-00110: Failed to start the specified SCAN VIP
Action: None
CLSRSC-00111: Failed to start the specified SCAN listener
Action: None
CLSRSC-00112: Start of the CVU resource failed
Action: None
CLSRSC-00113: Start of ASM instance failed
Action: None
CLSRSC-00114: Force stop of ASM instance failed
Action: None
CLSRSC-00115: Start of resource 'string' failed
Action: None
CLSRSC-00116: Stop of resource 'string' failed
Action: None
CLSRSC-00117: Failed to start Oracle Clusterware stack
Cause: An error occurred while starting Oracle Clusterware stack.
CLSRSC-00119: Start of the exclusive mode cluster failed
Action: If the problem persists, Contact Oracle Support Services
CLSRSC-00120: Timed out waiting for the CRS stack to start
Action: If the problem persists,contact Oracle Support Services.
CLSRSC-00121: Timed out waiting for the GPNPD to start
CLSRSC-00122: Failed to create a root wallet for Oracle Cluster GPnP (error code string)
Action: Check accompanying messages and contact Oracle Support Services.
CLSRSC-00123: Failed to create a root certificate for Oracle Cluster GPnP (error code string)
CLSRSC-00124: Failed to export root certificate for Oracle Cluster GPnP (error code string)
CLSRSC-00125: Failed to create a peer wallet for Oracle Cluster GPnP (error code string)
CLSRSC-00126: Failed to create a profile reader wallet for Oracle Cluster GPnP (error code string)
CLSRSC-00127: Failed to create a provisioning authority wallet for Oracle Cluster GPnP (error code string)
CLSRSC-00128: Failed to make a peer wallet for Oracle Cluster GPnP (error code string). Could not add private key to a wallet
CLSRSC-00129: Failed to make a provisioning authority wallet for Oracle Cluster GPnP (error code string). Could not add private key to a wallet.
CLSRSC-00130: Failed to make a peer wallet for Oracle Cluster GPnP (error code string). Could not export a certificate request from a wallet.
CLSRSC-00131: Failed to make a provisioning authority wallet for Oracle Cluster GPnP (error code string). Could not export a certificate request from a wallet.
CLSRSC-00132: Failed to make a peer wallet for Oracle Cluster GPnP (error code string). Could not create a peer certificate.
CLSRSC-00133: Failed to make a provisioning authority wallet for Oracle Cluster GPnP (error code string). Could not create a PA certificate.
CLSRSC-00134: Failed to make a peer wallet for Oracle Cluster GPnP (error code string). Could not add a root TP certificate.
CLSRSC-00135: Failed to make a profile reader wallet for Oracle Cluster GPnP (error code string). Could not add a root TP certificate.
CLSRSC-00136: Failed to make a provisioning authority wallet for Oracle Cluster GPnP (error code string). Could not add a root TP certificate.
CLSRSC-00137: Failed to make a peer wallet for Oracle Cluster GPnP (error code string). Could not add a PA TP certificate.
Cause: Internal Error.
CLSRSC-00138: Failed to make a provisioning authority wallet for Oracle Cluster GPnP (error code string). Could not add a peer TP certificate.
CLSRSC-00139: Failed to make a profile reader wallet for Oracle Cluster GPnP (error code string). Could not add a PA TP certificate.
CLSRSC-00140: Failed to make a profile reader wallet for Oracle Cluster GPnP (error code string). Could not add a peer TP certificate.
CLSRSC-00141: Failed to make a peer wallet for Oracle Cluster GPnP (error code string). Could not add a PA TP certificate.
CLSRSC-00142: Failed to make a provisioning authority wallet for Oracle Cluster GPnP (error code string). Could not add a peer TP certificate.
CLSRSC-00143: Failed to string a peer profile for Oracle Cluster GPnP using 'gpnptool' (error code string)
CLSRSC-00144: Failed to sign a peer profile for Oracle Cluster GPnP using 'gpnptool' (error code string)
CLSRSC-00145: Failed to verify a peer profile 'string' with WRL='string' using 'gpnptool' (error code string)
CLSRSC-00146: Failed to take cluster-wide GPnP setup as local
CLSRSC-00147: Failed to get parameter values from GPnP profile 'string'
CLSRSC-00148: Errors occurred while setting GPnP wallets ownership/permissions
Cause: Failed to set GPnP wallets ownership/permissions.
Action: None
CLSRSC-00149: Creation of Oracle GPnP wallets failed for host 'string'
Cause: Failed to create Oracle GPnP wallets for the specified host.
CLSRSC-00150: Creation of Oracle GPnP peer profile failed for host 'string'
Cause: Failed to create Oracle GPnP peer profile for the specified host.
CLSRSC-00151: Failed to promote local GPnP setup to other cluster nodes
CLSRSC-00152: Could not set ownership on 'string'
Cause: Failed to set ownership on the specified file or directory.
Action: None
CLSRSC-00153: Could not set permissions on 'string'
Cause: Failed to set permissions on the specified file or directory.
Action: None
CLSRSC-00154: Check of resource "string" failed
CLSRSC-00155: Replace of older local-only OCR failed
CLSRSC-00156: Error creating local-only OCR
CLSRSC-00157: Failed to create Oracle Cluster Registry configuration
CLSRSC-00158: Failed to reset the OCR location in 'srvconfig.loc' file
CLSRSC-00159: Failed to initialize Oracle Cluster Registry for cluster
CLSRSC-00160: Failed to create local-only OCR using the command 'string'
CLSRSC-00161: Pin node using the command 'string' failed
CLSRSC-00162: Upgrade of ASM Windows Service failed
CLSRSC-00163: ASM rolling upgrade action failed
CLSRSC-00164: ASM upgrade failed
CLSRSC-00165: Backup of file 'string' failed
Cause: The copy of the file to a backup file failed.
CLSRSC-00166: Failed to stop or deconfigure older version Cluster Support Services daemon.
Cause: There was an error during the operation.
CLSRSC-00167: Restore of file 'string' failed
Cause: The copy of the file from a backup file failed.
CLSRSC-00168: Could not delete the file 'string' (error: string)
Cause: Unable to delete the specified file.
Action: None
CLSRSC-00169: Failed to create or upgrade OLR
Cause: The 'ocrconfig -local -upgrade' command failed.
CLSRSC-00170: Failed to deconfigure Oracle ASM (error code string)
CLSRSC-00171: Failed to get a list of CSS nodes from OCR
CLSRSC-00172: Failed to get a list of interfaces from OCR
CLSRSC-00173: Error: string \nError getting networks interface information using 'oifcfg'
CLSRSC-00174: Error: string \nAn error occurred while executing the command 'olsnodes'
CLSRSC-00175: Failed to write the checkpoint 'string' with status 'string' (error code string)
CLSRSC-00176: Failed to write contents of pfile 'string' for checkpoint 'string' (error code string)
CLSRSC-00177: Failed to add (property/value):('string'/'string') for checkpoint 'string' (error code string)
CLSRSC-00178: Failed to get property value for property 'string' for checkpoint 'string' (error code string)
CLSRSC-00179: Failed to get value of 'string' for checkpoint 'string' (error code string)
CLSRSC-00180: An error occurred while executing the command 'string' (error code string)
Cause: Failed to execute the specified command.
Action: Correct the problem indicated in the accompanying messages and retry.
CLSRSC-00181: Failed to find earlier version database home
CLSRSC-00182: Failed to add the resource for ASM diskgroup 'string'
Cause: An internal error occurred while creating the ASM diskgroup resource.
CLSRSC-00183: OCR manual backup operation failed (error code string)
CLSRSC-00184: Configuration of ASM failed
Cause: Errors occurred while configuring ASM via 'asmca'.
Action: See 'asmca' logs for details. If the problem persists, contact Oracle Support Services.
CLSRSC-00185: Could not open file string (error: string)
Cause: An error occured while attempting to open a specified file.
CLSRSC-00186: Failed to copy file from local path 'string' to remote path 'string' for given list of nodes 'string' (error code string)
CLSRSC-00187: Failure with signal 'string' from command 'string'
CLSRSC-00188: Failed to create keys in Oracle Local Registry
CLSRSC-00189: Failed to add type 'ora.registry.acfs.type'
CLSRSC-00190: Failed to add resource 'ora.registry.acfs'
CLSRSC-00191: Failed to stop Oracle Clusterware stack
Cause: An error occurred while stopping Oracle Clusterware stack.
CLSRSC-00192: Unable to stop Oracle Restart
CLSRSC-00193: Platform-specific setup failed
CLSRSC-00195: Failed to create OHASD resources for cluster and ASM
Cause: An error occurred while adding OHASD resource types and resources.
CLSRSC-00196: ACFS driver install actions failed
Cause: An error occurred while installing ACFS drivers using the 'acfsroot install' command.
Action: Examine the accompanying messages from the 'acfsroot install' command, correct the problem and retry.
CLSRSC-00197: Cluster configuration upgrade failed
CLSRSC-00198: Initial cluster configuration failed
CLSRSC-00199: Timed out waiting for OHASD to start
CLSRSC-00200: Failed to create HA resources for HAS daemon and ASM
CLSRSC-00201: Failed to start CSS daemon
CLSRSC-00202: Failed to start EVM daemon
CLSRSC-00203: Failed to stop resources from database home 'string'
CLSRSC-00204: Failed to downgrade OCR to version 'string'
CLSRSC-00205: Failed to uninstall ADVM/ACFS
CLSRSC-00206: Could not open file string for reading (error: string)
Cause: An error occurred while attempting to open a specified file for reading.
Action: Check that the file exists and has the proper permissions.
CLSRSC-00207: Could not open file string for writing (error: string)
Cause: An error occurred while attempting to open a specified file for writing.
CLSRSC-00208: Could not open file string for appending (error: string)
Cause: An error occurred while attempting to open a specified file for appending.
CLSRSC-00209: Could not move 'string' to 'string' (error: string)
Cause: An error occurred while moving the specified file.
CLSRSC-00210: Current Oracle Cluster Registry location 'string' in file 'string' and file 'string' do not match
CLSRSC-00211: Current Oracle Cluster Registry mirror location 'string' in file 'string' and file 'string' do not match
CLSRSC-00212: Update either file 'string' to use location 'string' or variable OCR_LOCATIONS property set in file 'string' with location 'string' then re-run this script
CLSRSC-00213: Failure in reading file 'string' (error: string)
CLSRSC-00214: Failed to start the resource 'string'
CLSRSC-00215: Could not open file 'string' to read permisisons (error: string)
CLSRSC-00216: Insufficient free space available in Cluster Health Monitor repository 'string'
Cause: The available space was less than the minimum space required (1024 MB).
Action: Run the command 'oclumon manage -repos reploc <new_path>' to change Cluster Health Monitor repository and make sure its free space meets the minimum requirement.
CLSRSC-00217: Could not open file 'string' to write permisisons (error: string)
CLSRSC-00218: Failed to install the OHASD startup script (error: string)
CLSRSC-00219: Unable to get Oracle owner for the home 'string'
CLSRSC-00220: Unable to retrieve database home information
CLSRSC-00221: The patch 'string' apply failed for home 'string'
CLSRSC-00222: The patch 'string' apply successful for home 'string'
Action: None
CLSRSC-00223: The patch 'string' rollback failed for home 'string'
CLSRSC-00224: The patch 'string' rollback successful for home 'string'
Action: None
CLSRSC-00225: The prepatch execution for database home failed
CLSRSC-00226: The postpatch execution for database home failed
CLSRSC-00227: Patch information file 'string' does not exist. Not a valid GI Bundle patch.
CLSRSC-00228: Timed out waiting for server assignments
CLSRSC-00242: Failed to start Oracle Grid Plug and Play (GPnP) component
CLSRSC-00243: Failed to upgrade the voting disks for Cluster Synchronization Service
CLSRSC-00244: Failed to start Cluster Synchronization Service in clustered mode
CLSRSC-00245: Failed to start Cluster Time Synchronization Service (CTSS)
CLSRSC-00246: HAIP startup failure considered fatal, terminating ...
CLSRSC-00247: Failed to start ASM
CLSRSC-00248: Failed to upgrade Oracle Clusterware Repository
CLSRSC-00249: Failed to start Cluster Ready Services
CLSRSC-00250: Failed to start Event Manager
CLSRSC-00251: Oracle Clusterware stack start initiated but failed to complete
CLSRSC-00252: Old CRS Home directory is invalid
CLSRSC-00253: Failed to call 'gethostbyname' with the argument 'string' (error: string)
CLSRSC-00254: Could not create the directory 'string' (error: string)
CLSRSC-00255: Could not create the file 'string' (error: string)
CLSRSC-00256: Could not eval string: string
CLSRSC-00257: Cluster Time Synchronization Service start in exclusive mode failed
CLSRSC-00258: Failed to configure and start ASM
CLSRSC-00259: Oracle Clusterware Repository configuration failed
CLSRSC-00260: Clusterware exclusive mode start of Cluster Ready Services failed
CLSRSC-00261: Failed to add voting disks
Cause: An attempt to add voting disks failed.
CLSRSC-00262: Failed to promote local GPnP setup to other cluster nodes
CLSRSC-00267: CSS could not exit exclusive mode
Cause: An attempt to stop running OHASD resources failed.
CLSRSC-00268: ORACLE_HOME is not set in the environment
CLSRSC-00269: Failed to add base type cluster_resource
CLSRSC-00270: Failed to register Clusterware type 'string'
CLSRSC-00271: Failed to add resource 'string'
CLSRSC-00272: Could not close file 'string' (error: string)
CLSRSC-00273: Failed to register the resource 'string' with the OHASD
CLSRSC-00274: Mismatching host to VIP IPs specified
CLSRSC-00275: No more elements in crs_nodevip_list
CLSRSC-00276: Unable to get VIP info for new node
CLSRSC-00277: Failed to perform new node configuration
CLSRSC-00278: Failed to perform last node configuration for upgrade
CLSRSC-00279: Failed to perform first node non rolling asm upgrade tasks for cluster
CLSRSC-00280: Failed to perform first node tasks for cluster modeling upgrade
CLSRSC-00281: Failed to set active version of Oracle Clusterware
Cause: An error occurred while executing the 'crsctl set crs activeversion' command.
Action: Correct the problem indicated in the accompanying messages, and then retry.
CLSRSC-00284: Failed to perform last node tasks for cluster modeling upgrade
CLSRSC-00285: Failed to perform upgrade configuration from old 11.2 install
CLSRSC-00286: Failed to add Grid Infrastructure node applications
CLSRSC-00287: FirstNode configuration failed
CLSRSC-00288: Failed to start Grid Infrastructure node applications
CLSRSC-00289: Could not get existing VIP information
CLSRSC-00290: Error: validation of Single Instance CSS failed
CLSRSC-00291: Error: validation of 9i GSD failed
CLSRSC-00292: Error: validation of OLR config failed
CLSRSC-00293: Error: validation of OCR location 'string' failed
CLSRSC-00294: CSS cannot be run in realtime mode
CLSRSC-00296: No configuration parameter file was specified
CLSRSC-00297: Configuration parameter file 'string' could not be found
CLSRSC-00298: The Oracle CRS home path not found in the configuration parameters
CLSRSC-00299: The configuration parameter file 'string' is not valid
CLSRSC-00300: Parameter 'string' not defined
CLSRSC-00301: Error in validate_ocrconfig
CLSRSC-00302: Unable to delete old services
CLSRSC-00303: Cannot complete the upgrade without the voting file list
CLSRSC-00304: Failed to upgrade ASM for Oracle Restart configuration
CLSRSC-00305: Failed to upgrade ASM in a rolling fashion for Oracle Clusterware configuration
CLSRSC-00306: Failed to upgrade ASM in a nonrolling fashion for Oracle Clusterware configuration
CLSRSC-00307: Failed to upgrade ASM service a rolling fashion for Oracle clusterware configuration
CLSRSC-00308: Failed to get non-FQDN host name
CLSRSC-00309: Failed to get node network interfaces, error: (string)
CLSRSC-00310: Could not open log file string for append (error: string)
CLSRSC-00311: Failed to verify resources
CLSRSC-00312: Failed to verify HA resources
CLSRSC-00313: Error: 'string' is an unknown Operating System
CLSRSC-00314: Failed to call 'tolower_host' (error: string)
CLSRSC-00315: Clusterware configuration check failed
CLSRSC-00316: OLR configuration failed
CLSRSC-00317: Failed to register Oracle OHASD service
CLSRSC-00318: Failed to start Oracle OHASD service
CLSRSC-00319: Unable to stop running CSS
CLSRSC-00320: Migration of older version local_only to SIHA failed
CLSRSC-00323: Error: readlink failed (error: string)
CLSRSC-00324: Could not open old init.cssd
CLSRSC-00325: Configure Oracle Grid Infrastructure for a Cluster ... succeeded
Action: None
CLSRSC-00326: Configure Oracle Grid Infrastructure for a Cluster ... failed
CLSRSC-00327: Successfully configured Oracle Restart for a standalone server
Action: None
CLSRSC-00328: Removing Clusterware entries in file 'string'
Action: None
CLSRSC-00329: Replacing Clusterware entries in file 'string'
Action: None
CLSRSC-00330: Adding Clusterware entries to file 'string'
Action: None
CLSRSC-00331: Failure initializing entries in file 'string'
CLSRSC-00332: CRS resources for listeners are still configured
CLSRSC-00333: Failed to remove database listener
CLSRSC-00334: Failed to remove database listener, but continuing to deconfigure with force option
CLSRSC-00335: Successfully downgraded Oracle Clusterware stack on this node
Action: None
CLSRSC-00336: Successfully deconfigured Oracle Clusterware stack on this node
Action: None
CLSRSC-00337: Successfully deconfigured Oracle Restart stack
Action: None
CLSRSC-00338: Successfully downgraded OCR to version string
Action: None
CLSRSC-00348: The Oracle Restart stack failed to stop
Cause: There was a failure in stopping the Oracle Restart stack.
Action: Stop the stack with 'crsctl stop has -f' and rerun the root script.
CLSRSC-00349: The Oracle Clusterware stack failed to stop
Cause: There was a failure in stopping the Oracle Clusterware stack.
Action: Stop the stack with 'crsctl stop crs -f' and rerun the root script.
CLSRSC-00350: Cannot configure two CRS instances on the same cluster
Cause: CRS is already configured on this node.
Action: Must deconfigure before proceeding with the configuration of new home.
CLSRSC-00351: Improper Oracle Clusterware configuration found on this host
Cause: There was an existing configuration found.
Action: Deconfigure the existing cluster configuration before starting to configure a new Clusterware.
CLSRSC-00352: CRS is already configured on this node for the CRS home location string
Cause: There was an attempt to configure the cluster when the cluster is already configured.
Action: None
CLSRSC-00353: Run 'string/crs/install/string -deconfig' to deconfigure existing failed configuration and then re-run 'string'
Cause: There was an attempt to configure the cluster when a prior failed configuration was not cleaned up.
Action: Perform the action specified in the message.
CLSRSC-00354: Error: invalid interface
CLSRSC-00355: Error: Cannot change directory to 'string', invalid Berkeley Database path
CLSRSC-00356: Error in opening directory 'string'
CLSRSC-00357: Failed to stop current Oracle Clusterware stack during upgrade
Cause: An error occurred while executing the 'crsctl stop crs -f' command from the current CRS home.
Action: Either manually stop the current Oracle Clusterware stack or reboot the local node to properly clean up the processes started by Oracle Clusterware, and then rerun rootupgrade.sh.
CLSRSC-00359: Unable to get owner information for the executable string
Cause: This is an internal error.
CLSRSC-00360: Owner 'string' of the old CRS home differs from owner 'string' of the new CRS home
Cause: The new CRS home was installed as the wrong OS user.
Action: Install the new CRS home as the owner of the old CRS home.
CLSRSC-00361: The Oracle Cluster Repository (OCR) check failed
CLSRSC-00362: The pre-upgrade checks failed, aborting the upgrade
Cause: One or more pre-upgrade checks failed. This message is accompanied by others providing details of the error.
Action: Correct the problem indicated by the accompanying messages and retry.
CLSRSC-00363: User ignored prerequisites during installation
Cause: Informational message.
Action: None
CLSRSC-00364: Failed to propagate ASM credentials to the other nodes
Cause: An attempt to copy the ASM credentials to all remote cluster nodes failed
CLSRSC-00365: Failed to create credentials for ASM on the local node
CLSRSC-00366: Failed to import credentials for ASM
CLSRSC-00367: The value set for the parameter 'GNS_ADDR_LIST' is null
Cause: No GNS address was found while configuring the big cluster discovery address.
CLSRSC-00368: Failed to set the node role 'string' for the local node
Cause: An error occurred while executing the 'crsctl set node role' command.
Action: Examine the accompanying messages from the 'crsctl set node role' command, correct the problem and retry.
CLSRSC-00369: Failed to set maximum number of Hub nodes to string
Cause: An error occurred while executing the 'crsctl set cluster hubsize' command.
Action: Examine the accompanying messages from the 'crsctl set cluster hubmax' command, correct the problem and retry.
CLSRSC-00370: Cloud Cluster requires Cloud ASM Server
Cause: Cloud ASM Server was not configured in the cluster.
CLSRSC-00371: Failed to add ASM remote configuration
Cause: An error occurred while executing the 'srvctl add asm -remote' command.
CLSRSC-00372: Failed to add ASM proxy configuration
Cause: An error occurred while executing the 'srvctl add asm -proxy' command.
CLSRSC-00375: Failed to copy ASM credentials to the GPnP directory
Cause: An error occurred while processing a copy operation.
CLSRSC-00376: Failed to get the configured node role for the node string
Cause: An error occurred while executing the 'crsctl get node role config -node nodename' command.
Action: Examine the accompanying messages from the 'crsctl get node role config -node nodename' command, correct the problem and retry.
CLSRSC-00377: Failed to create ASM credential domains
Cause: An error occurred while executing the 'crsctl add credmaint -path -ASM [-local]' command.
CLSRSC-00378: Failed to get the configured node role for the local node
Cause: An error occurred while executing the 'crsctl get node role config' command.
Action: Examine the accompanying messages from the 'crsctl get node role config' command, correct the problem and retry.
CLSRSC-00379: Invalid path for the password file used by ASM
Cause: The path for the password file used by ASM was not properly set in ASM configuration.
CLSRSC-00380: Failed to create the Rapid Home Provisioning Server credential domain
Cause: An error occurred while executing the 'crsctl add credmaint -path GRIDHOME' command.
CLSRSC-00398: Failed to retrieve old Grid Infrastructure home location during upgrade
Cause: An attempt to locate the previous version Oracle Clusterware home location failed during upgrade, possibly because its configuration was corrupt or removed.
CLSRSC-00399: Failed to retrieve the network configuration during upgrade
Cause: Private interconnect configuration could not be retrieved from the previous version Oracle Clusterware, possibly because its configuration was corrupt or removed.
CLSRSC-00400: A system reboot is required to continue installing.
Cause: The installation of new drivers requires a node reboot to continue the install.
Action: Reboot the node and rerun the install or patch configuration step.
CLSRSC-00404: Failed to upgrade Cluster Health Monitor service in rolling fashion for Oracle Clusterware configuration.
CLSRSC-00405: Unable to access old configuration file string of Cluster Health Monitor.
Cause: Old Cluster Health Monitor configuration file was absent.
Action: None
CLSRSC-00406: Failed to find new administrative directory string of Cluster Health Monitor.
CLSRSC-00408: Failed to create new configuration file string of Cluster Health Monitor.
Cause: New configuration file of Cluster Health Monitor could not be created.
Action: Ensure that you have the required OS authority or permissions for creating the indicated file.
CLSRSC-00409: Failed to patch Cluster Health Monitor service for Oracle Clusterware configuration.
CLSRSC-00410: Cannot change directory to 'string'.
Cause: During OCFS upgrade, an attempt to change to the indicated file system directory failed.
Action: Ensure that the directory ORACLE_HOME\cfs exists
CLSRSC-00411: A system reboot is required before using OCFS.
Cause: The existing OCFS driver could not be unloaded.
Action: Reboot the local node.
CLSRSC-00412: Failed to enable CRS after successfully installing the ACFS drivers.
Cause: After successfully configuring ACFS during an install, upgrade, or patch, the root script failed to enable CRS again, using the command 'crsctl enable crs'.
Action: Correct the errors accompanying the failure of the enable command and rerun the install configuration step.
CLSRSC-00413: Failed to disable CRS in preparation for a node reboot.
Cause: After a failure to install ACFS drivers, CRS is disabled. This allows the user to reboot and install the drivers for the new version successfully.
Action: Correct the errors accompanying the failure of the disable command, run 'crsctl disable crs', reboot, and continue the install configuration step.
CLSRSC-00414: The OCR backup 'string' was not found on this node to perform the last node downgrade
Cause: The node where the downgrade command was issued with the '-lastnode' option was not the first node that was upgraded. The OCR backup is located on that node.
Action: If this is the last node to be downgraded, copy the OCR backup to the location mentioned in the error and downgrade with the '-lastnode' option. If this is not the last node, re-run the downgrade command without the '-lastnode' option on this node.
CLSRSC-00415: Failed to delete voting disks
Cause: An attempt to delete voting disks failed.
CLSRSC-00416: Failed to retrieve old Grid Infrastructure configuration data during downgrade
Cause: An attempt to collect the older version Oracle Clusterware configuration data failed during downgrade, possibly because its configuration was corrupt or removed.
CLSRSC-00417: Backup of olr.loc not found for downgrade
Cause: This cluster was not one successfully upgraded from an old version.
Action: Ensure that this is an upgraded cluster; then re-run the downgrade command.
CLSRSC-00418: Failed to create the ADVM volume resource for device string.
Cause: An error occurred while executing the 'srvctl add volume' command.
CLSRSC-00419: An error occurred attempting to query the volume resource.
Cause: An error occurred while executing the 'srvctl status volume' command.
CLSRSC-00420: The ACFS registration for device 'string' on mount path 'string' could not be registered with CRS.
Cause: An error occurred while executing the 'acfsutil registry -a' command.
CLSRSC-00421: An error occurred attempting to query the file system resource.
Cause: An error occurred while executing the 'srvctl status // filesystem' command.
CLSRSC-00422: Failed to perform ACFS registry upgrade.
Cause: An error occurred while performing the ACFS registry upgrade.
CLSRSC-00423: Failed to stop database listener
Cause: An error occured while stopping the database listener.
Action: Try to stop the database listener manually using 'srvctl stop listener' command.
CLSRSC-00424: Failed to stop database listener, but continuing to deconfigure with force option
Action: None
CLSRSC-00425: Failed to create the ACFS drivers resource but continuing with the installation
Cause: An error occured while creating the ACFS drivers resource.
Action: Check if your OS kernel is supported and run 'acfsroot enable' to create and start the ACFS drivers resource.
CLSRSC-00426: Failed to create and start the ACFS drivers resource but continuing with the patching
Cause: An error occured while creating and starting the ACFS drivers resource.
CLSRSC-00427: Failed to remove OCR file string on ASM using command string ... output: string
Cause: Command failed.
CLSRSC-00428: Existing OCR configuration found, aborting the configuration. Rerun configuration setup after deinstall.
Cause: While configuring a new cluster, OCR was found to be already configured.
Action: Deinstall and rerun configuration setup.
CLSRSC-00429: The Oracle Clusterware force upgrade was aborted
Action: Address the issues reported by accompanying messages and follow the suggested action.
CLSRSC-00430: Failed to start rolling patch mode
Cause: An error occurred while executing the 'crsctl start rollingpatch' command.
Action: Examine the accompanying messages, correct the problem and retry.
CLSRSC-00431: Failed to stop rolling patch mode
Cause: An error occurred while executing the 'crsctl stop rollingpatch' command.
CLSRSC-00432: Invalid destination CRS home
Cause: The CRS home specified by '-dstcrshome' was identical to the current CRS home.
Action: Remove '-dstcrshome path to CRS home' from the command line or specify a different CRS home.
CLSRSC-00433: This command is deprecated and has been replaced by 'rootcrs.pl -postpatch'
Cause: A deprecated command was issued.
Action: Use 'rootcrs.pl -postpatch'. See usage for complete command line options.
CLSRSC-00434: An operating system reboot is required to continue the deconfiguration.
Cause: The uninstall of the ACFS drivers failed. An operating system reboot is required to continue the deconfiguration.
Action: Reboot the node and restart the deconfiguration step.
CLSRSC-00435: Failed to enable CRS after successfully uninstalling the ACFS drivers.
Cause: After successfully deconfiguring ACFS during an downgrade, the root script failed to re-enable CRS using the command 'crsctl enable crs'.
Action: Correct the errors accompanying the failure of the enable command and rerun the deconfiguration step.
CLSRSC-00436: Failed to disable CRS in preparation for a node reboot.
Cause: An attempt to disable CRS in preparation for a system reboot failed. The reboot is associated with a failed removal of ACFS drivers.
Action: Correct the errors accompanying the failure of the disable command, run 'crsctl disable crs', reboot, and continue the deconfiguration step.
CLSRSC-00437: Failed to add the management database listener
Cause: An error occurred while adding the management database listener.
Action: Rerun the root.sh script after resolving the problem indicated by the accompanying messages.
CLSRSC-00438: There is a mismatch between the node list and node role list in 'string/crs/install/crsconfig_addparams'
CLSRSC-00439: Unable to configure a Leaf node first. Run root.sh on a Hub node first.
Cause: root.sh was run on a Leaf node first.
Action: Run root.sh in a Hub node first.
CLSRSC-00440: Failed to copy GPnP setup from a remote node string that belongs to an upgraded cluster
Cause: The remote node was unreachable or has not completed upgrade processing.
Action: Make sure the given node can be reached and it has been successfully upgraded, and then rerun the 'rootupgrade.sh -join -existingNode node name' command.
CLSRSC-00442: Failed to copy Oracle Clusterware configuration files from existing nodes
Cause: During the operation of adding nodes, an attempt to copy configuration files from an existing node failed because no node was unreachable or user equivalence did not work.
Action: Ensure that at least one node can be reached and user equivalence is properly configured between the local node and existing nodes, and then rerun the 'root.sh' command. Contact Oracle Support Services if the problem persists.
CLSRSC-00443: An active CSS daemon was found during CSS exclusive mode startup
CLSRSC-00444: The 'root.sh' command must first be run on node 'string' where the OUI session was invoked
Cause: The node where the 'root.sh' command was running was not the node on which the OUI session was invoked.
Action: Run the 'root.sh' command on the node where the OUI was invoked.
CLSRSC-00445: The Oracle Grid Infrastructure has already been upgraded to [string]
Cause: The rootupgrade.sh was successfully executed on all cluster nodes.
Action: No further action is required.
CLSRSC-00446: The upgrade has not yet been performed on this node
Cause: The rootupgrade.sh was not yet executed on the local node, and the force option was specified.
Action: Rerun rootupgrade.sh without the force option on the local node.
CLSRSC-00447: The upgrade has not yet been performed on node string
Cause: The force option was supplied when some nodes in the cluster have not yet been upgraded. The upgrade cannot be forced to complete while some nodes running Oracle Clusterware have not yet been upgraded.
Action: Rerun rootupgrade.sh without force option on the specified node.
CLSRSC-00448: Cluster-wide Grid Plug and Play profile not found on this node
Cause: The Grid Plug and Play profile was not found on this node. The node may have been unreachable when the profile was created and distributed during an earlier upgrade operation.
Action: First, force completion of the earlier upgrade on the other nodes using 'rootupgrade.sh -force'. Then issue 'rootupgrade.sh -join -existingNode <node_name>' on the local node to rejoin this node to the cluster. Alternatively, remove this node from the cluster and then add it back.
CLSRSC-00449: Failed to retrieve the value of attribute 'check_interval' for CVU resource during upgrade
Cause: An attempt to retrieve the value of attribute 'check_interval' for CVU resource failed during upgrade, possibly because its configuration was corrupt or removed.
CLSRSC-00450: Failed to determine if the CVU resource was configured
Cause: During upgrade, an attempt to determine if CVU resource was configured failed, possibly because its configuration was corrupt or removed.
CLSRSC-00451: The last Hub node cannot be deconfigured while the Flex Cluster still has Leaf nodes
Cause: An attempt to deconfigure the last Hub node in the cluster found one or more Leaf nodes still active.
Action: Deconfigure all other nodes before deconfiguring the local node.
CLSRSC-00452: Failed to upgrade ASM on the current node during attempt to join an upgraded cluster
Cause: The ASM upgrade invoked during node join failed.
Action: Examine the accompanying messages, correct the problem and rerun the 'rootupgrade.sh -join -existingNode node name' command.
CLSRSC-00453: An operating system reboot is required to continue the downgrade
Cause: The reinstall of the older version of Oracle ASM Cluster file system (ACFS) drivers failed. An operating system reboot is required to continue the downgrade.
Action: Reboot the node before running 'crsctl start crs' from the older version of CRS home.
CLSRSC-00454: Failed to initiate the upgrade of Oracle Clusterware
Cause: An error occurred while executing the 'crsctl startupgrade' command.
Action: Rerun the rootupgrade.sh script and contact Oracle Support Services if the problem persists.
CLSRSC-00455: Failed attempt to initiate patch on a Leaf node
Cause: Pre-patch failed because of an attempt to execute 'rootcrs.pl -prepatch' on a Leaf node before any Hub node being patched.
Action: Run the 'rootcrs.pl -prepatch' command on a Hub node first, before running it on the current node.
CLSRSC-00456: The Oracle Grid Infrastructure has already been configured.
Cause: An attempt to run the configuration script was aborted because it had already been successfully executed on this node.
CLSRSC-00457: Oracle Restart is currently configured and cannot be deconfigured using this Oracle Clusterware deconfiguration command.
Cause: A request to deconfigure Oracle Clusterware was rejected because the existing configuration was Oracle Restart.
Action: Run the command 'roothas.pl -deconfig' to deconfigure Oracle Restart.
CLSRSC-00458: Failed to restore the ASM diagnostic destination during downgrade
Cause: An attempt to downgrade using the 'asmca -downgrade' command failed, because the ASM diagnostic destination could not be restored.
Action: Correct the problem indicated in the accompanying messages.
CLSRSC-00459: The '-lastnode' option is not specified on the downgrade command.
Cause: An attempt to downgrade the last node failed because the '-lastnode' option was missing from the downgrade command line.
Action: Reissue the downgrade command on this node with the '-lastnode' option specified after downgrading all other nodes.
CLSRSC-00460: failed to start Oracle Restart stack
Cause: An error occurred when the Oracle Restart stack was automatically restarted during installation or configuration processing.
Action: Retry the configuration script root.sh. If the problem persists, contact Oracle Support Services
CLSRSC-00461: Failed to retrieve OCR locations
Cause: An error occurred while executing the 'ocrcheck -config -details' command.
CLSRSC-00462: Failed to copy OCR location configuration file to remote nodes
Cause: An attempt to copy configuration file to remote nodes failed because the target node was unreachable or user equivalence did not work.
Action: Ensure that the remote nodes can be reached and user equivalence is properly configured across the cluster nodes, and then rerun the 'root.sh' command. Contact Oracle Support Services if the problem persists.
CLSRSC-00463: The deconfiguration or downgrade script could not stop current Oracle Clusterware stack.
Action: After deconfiguration or downgrade completes, either manually stop the current Oracle Clusterware stack or reboot the local node to properly clean up the processes started by Oracle Clusterware.
CLSRSC-00464: Starting retrieval of the cluster configuration data
Cause: Retrieval of the cluster configuration data from the older version of Oracle Grid Infrastructure stack has started.
Action: None
CLSRSC-00465: Retrieval of the cluster configuration data has successfully completed.
Cause: Retrieval of the cluster configuration data from the older version of Oracle Grid Infrastructure stack has successfully completed.
Action: None
CLSRSC-00466: Starting shutdown of the current Oracle Grid Infrastructure stack
Cause: Shutdown of the older version of Oracle Grid Infrastructure stack has started.
Action: None
CLSRSC-00467: Shutdown of the current Oracle Grid Infrastructure stack has successfully completed.
Cause: Shutdown of the older version of Oracle Grid Infrastructure stack has successfully completed.
Action: None
CLSRSC-00468: Setting Oracle Clusterware and ASM to rolling migration mode
Cause: An attempt has been made to set Oracle Clusterware and ASM to rolling migration mode.
Action: None
CLSRSC-00469: Successfully set Oracle Clusterware and ASM to rolling migration mode
Cause: An operation to set Oracle ASM to rolling migration mode has successfully completed.
Action: None
CLSRSC-00470: Starting non-rolling migration of Oracle ASM
Cause: An attempt has been made to initiate non-rolling migration of Oracle ASM.
Action: None
CLSRSC-00471: Successfully initiated non-rolling migration of Oracle ASM
Cause: An operation to initiate non-rolling migration of Oracle ASM has successfully completed.
Action: None
CLSRSC-00472: Attempting to export the OCR
Cause: An attempt has been made to export the OCR.
Action: None
CLSRSC-00473: Successfully exported the OCR
Cause: The OCR has successfully been exported.
Action: None
CLSRSC-00474: Initiating upgrade of resource types
Cause: An attempt has been made to initiate upgrade of resource types.
Action: None
CLSRSC-00475: Upgrade of resource types successfully initiated.
Cause: Upgrade of resource types has successfully started.
Action: None
CLSRSC-00476: Finishing upgrade of resource types
Cause: An attempt has been made to finish upgrade of resource types.
Action: None
CLSRSC-00477: Successfully completed upgrade of resource types
Cause: Upgrade of resource types has successfully completed.
Action: None
CLSRSC-00478: Setting Oracle Clusterware active version on the last node to be upgraded
Cause: An attempt has been made on the last node to be upgraded to set the Oracle Clusterware active version.
Action: None
CLSRSC-00479: Successfully set Oracle Clusterware active version
Cause: An operation initiated on the last node to be upgraded to set Oracle Clusterware active version has successfully completed.
Action: None
CLSRSC-00480: Starting the process of upgrading local listeners
Cause: The process of upgrading local listeners has started.
Action: None
CLSRSC-00481: Successfully completed the process of upgrading local listeners
Cause: The process of upgrading local listeners has successfully completed.
Action: None
CLSRSC-00482: Running command: 'string'
Cause: An attempt has been made to run the command mentioned in the message.
Action: None
CLSRSC-00483: unable to run 'rootcrs.pl -prepatch' to perform rolling, in-place patching for shared Grid Infrastructure home
Cause: In the course of patching a shared Grid Infrastructure home, an attempt to execute the 'rootcrs.pl -prepatch' command failed because rolling in-place patching of a shared home is not allowed.
Action: Reissue the 'rootcrs.pl -prepatch' command with the '-nonrolling' or '-dstcrshome' option specified .
CLSRSC-00484: error querying CRS software version on node 'string'
Cause: An error occurred while executing the 'crsctl query crs softwareversion' command.
Action: Correct the problem indicated in the accompanying messages and then rerun rootupgrade.sh. Contact Oracle Support Services if the problem persists.
CLSRSC-00485: Local port=string and remote port=string should not be same.
Cause: The rootupgrade script was aborted because the specified local and remote ports were the same.
Action: Rerun the rootupgrade.sh script after changing the port numbers.
CLSRSC-00487: Check for ASM compatibility version failed during downgrade.
Cause: An attempt to downgrade the current node failed because the ASM compatibility version was already advanced after upgrade.
Action: Downgrade is not allowed in this case. Contact Oracle Support Services for further action.
CLSRSC-00488: Patching the Grid Infrastructure Management Repository database failed.
Cause: An error occured when executing the 'sqlpatch -db -MGMTDB' command' to patch the Grid Infrastructure Management Repository database.
Action: Address the issues reported by accompanying messages and rerun the 'rootcrs.pl -postpatch' command. If the problem persists, contact Oracle Support Services.
CLSRSC-00489: Stopping the Grid Infrastructure Management Repository database failed.
Cause: An error occurred while executing the 'srvctl stop mgmtdb' command.
Action: Examine the accompanying messages, correct the problem and rerun the 'rootcrs.pl -postpatch' command.
CLSRSC-00490: Starting the Grid Infrastructure Management Repository database failed.
Cause: An error occurred while executing the 'srvctl start mgmtdb' command.
CLSRSC-00491: Failed to disable the Grid Infrastructure Management Repository database
Cause: An error occurred while executing the 'srvctl disable mgmtdb' command.
CLSRSC-00492: Failed to enable the Grid Infrastructure Management Repository database
Cause: An error occurred while executing the 'srvctl enable mgmtdb' command.
CLSRSC-00493: failed to initiate rolling patch on the current node because there is only one active HUB node
Cause: An attempt to execute the 'rootcrs.pl -prepatch' command failed because there was only one active HUB node.
Action: Reissue the 'rootcrs.pl -prepatch' command with the '-nonrolling' option specified or configure more than one active HUB node in the cluster.
CLSRSC-00494: Failed to execute this command. Current directory is under an ACFS mount point.
Cause: An attempt to execute a command that would result in a forced / shutdown of ACFS was rejected because the current directory is on an ACFS file system. Consequently, the forced shutdown of ACFS would terminate the execution of the attempted command.
Action: Ensure that the current shell has no dependencies on ACFS file systems (i.e. current directory not on ACFS and not a sub-shell of a process whose working directory is on ACFS) and retry the command.
CLSRSC-00495: failed to get active role for the node string
Cause: An error occurred while executing the command 'crsctl get node role status -node nodename'.
CLSRSC-00496: failed to get active role for the local node
Cause: An error occurred while executing the command 'crsctl get node role status'.
CLSRSC-00497: failed to retrieve the configured cluster mode
Cause: An error occurred while executing the command 'crsctl get cluster mode config'.
CLSRSC-00498: invalid cluster mode
Cause: An internal error. The cluster mode returned by the command 'crsctl get cluster mode config' was neither 'standard' nor 'flex'.
CLSRSC-00499: Stopping the Grid Infrastructure Management Repository database failed.
Action: Examine the accompanying messages, correct the problem and rerun rootupgrade.sh.
CLSRSC-00500: Starting the Grid Infrastructure Management Repository database failed.
CLSRSC-00501: failed to disable the Grid Infrastructure Management Repository database
CLSRSC-00502: failed to enable the Grid Infrastructure Management Repository database
CLSRSC-00503: Deleting the Grid Infrastructure Management Repository database failed.
Cause: An attempt to connect to the GI Management Repository database failed or an error occurred while executing the SQL statement 'drop database'.
CLSRSC-00504: The root script cannot proceed on this node string until the current first-node operations have finished on the first node string.
Cause: An attempt to run the root script on this node failed because the root script was still running on the first node and had not yet completed.
Action: Allow the root script to complete execution on the first node and then restart the root script on this node.
CLSRSC-00505: The root script cannot proceed on this node string because the root script encountered errors during execution on the first node string.
Cause: An attempt to run the root script on this node failed because the root script encountered errors during execution on the first node.
Action: Correct the problems indicated by the root script on the first node and rerun the script on that node. Following successful completion on the first node, restart the root script on this node.
CLSRSC-00506: The root script cannot proceed on this node string because the first-node operations have not completed and the first node string has crashed or gone offline.
Cause: An attempt to run the root script on this node failed because the root script did not completed successfully on the first node, and the first node has crashed or gone offline.
Action: Rerun the root script on any of the remaining nodes supplying the -force option to cause it to act as the first node.
CLSRSC-00507: The root script cannot proceed on this node string because either the first-node operations have not completed on node string or there was an error in obtaining the status of the first-node operations.
Cause: An attempt to run the root script on this node failed because the root script has not completed and may not yet have started on the first node or there was an error in obtaining the status of the first node.
Action: Start the root script on the first node if necessary, and after it has completed successfully on the first node, restart the root script on this node.
CLSRSC-00508: The root script cannot be started with the -first -force option on this node string, while the original first node string is still online.
Cause: An attempt to run the root script supplying the -first -force option on this node failed because the first node was still online.
Action: Run the root script on the first node. Following successful completion on the first node, restart the root script on this node.
CLSRSC-00509: invalid ASM mode
Cause: This is an internal error. The ASM mode was an undefined value at this point.
CLSRSC-00510: failed to delete the voting file on diskgroup 'string' during deconfiguration
Cause: The attempt to remove a voting file failed because an error occurred while executing the command 'crsctl delete css votedisk +diskgroup'.
Action: Retry the above command manually. If the problem persists, contact Oracle Support Services.
CLSRSC-00511: failed to set Oracle Clusterware and ASM to rolling migration mode
Cause: An error occurred while executing the command 'crsctl start rollingupgrade'.
Action: Correct the problem indicated in the accompanying messages and rerun rootupgrade.sh.
CLSRSC-00512: failed to force node string as the first node because it is not a hub node
Cause: An attempt to run the root script supplying the -force option on this node has failed because it is not a hub node.
Action: Run the root script with the -force option on a hub node.
CLSRSC-00514: failed to reset cardinality of Flex ASM to original value
Cause: An error occurred while attempting to reset Flex ASM cardinality, either in retrieving the previously stored value using 'crsctl status resource' or in restoring the previous value using 'srvctl modify asm'.
CLSRSC-00515: Starting OCR manual backup.
Cause: An attempt has been made to generate OCR manual backup.
Action: None
CLSRSC-00516: OCR manual backup successful.
Cause: OCR manual backup completed normally.
Action: None
CLSRSC-00517: The root script cannot run with the '-lastnode' option on this node string because the OCR backup file is on node string.
Cause: An attempt to run the root script supplying the '-lastnode' option on this node has failed because the OCR backup file is not on this node.
Action: Run the root script on this node without '-lastnode' option.
CLSRSC-00518: cannot open directory 'string'
Cause: An attempt to open the specified directory has failed.
Action: Ensure that the user running root script has read permission on the directory.
CLSRSC-00519: cannot move directory string to directory string
Cause: An attempt to move the source directory has failed.
Action: Ensure that the user running root script has read permission on the source directory and write permission on destination directory.
CLSRSC-00520: Clusterware version on this node too old to join target cluster
Cause: An attempt to join the current node to an upgraded cluster failed because the join is not supported for nodes with Oracle Clusterware older than version 11.2.0.1.
Action: Delete this node and then add this node back into Clusterware using the 'add node' operation.
CLSRSC-00522: The root script cannot downgrade this node string with the '-lastnode' option because there is at least one other node that has not finished downgrade.
Cause: An attempt to run the root script with the '-lastnode' option on this node failed because there was at least one other node that had not finished downgrade.
Action: Run the root script on this node with the '-lastnode' option after all other nodes have completed downgrade.
CLSRSC-00523: The root script cannot downgrade this node string because there is at least one other node that has not finished downgrade and this node should downgrade with the '-lastnode' option.
Cause: An attempt to run the root script on this node failed because there was at least one other node that had not finished downgrade and this node should downgrade with the '-lastnode' option.
CLSRSC-00524: Setting Oracle Clusterware to rolling migration mode
Cause: The command 'crsctl start rollingupgrade version' to initiate rolling migration of Oracle Clusterware was issued.
Action: None
CLSRSC-00525: Successfully set Oracle Clusterware to rolling migration mode
Cause: The command 'crsctl start rollingupgrade version' to initiate a rolling migration of Oracle Clusterware completed successfully.
Action: None
CLSRSC-00526: The root script cannot run with the '-first -force' options to force current node string as the first node.
Cause: An attempt to run the root script with options '-first -force' on this node failed because first-node operations had already been done.
Action: Run the root script on this node without the options '-first -force'.
CLSRSC-00527: The root script cannot run with the '-force' option to force current node string as the last node during fresh install (case: first-node operations complete).
Cause: An attempt to run the root script with option '-force' on this node failed because there are no last-node operations for a fresh install, and the first-node operations had been done.
Action: Run the root script on this node without the option '-force'.
CLSRSC-00528: The root script cannot run with the '-force' options to force current node string which is the installer node as the last node during upgrade before first-node operations have been done.
Cause: An attempt to run the root script with option '-force' on installer node failed because the first-node operations had not been done.
CLSRSC-00529: The root script cannot run with the '-force' option to force current node string as the last node during fresh install (case: first-node operations not complete).
Cause: An attempt to run the root script with option '-force' on this node failed because there are no last-node operations for a fresh install, and the first-node operations had not been done.
Action: Run the root script on this node with the options '-first -force'.
CLSRSC-00530: The root script cannot run with the '-force' option to force current node string which is a non-installer node as the last node during upgrade before first-node operations have been done.
Cause: An attempt to run the root script with option '-force' on a non- installer node failed because the first-node operations had not been done.
CLSRSC-00531: The root script does not need the '-first -force' options to force current node string as the first node.
Cause: An attempt to run the root script with options '-first -force' on this node failed because the '-first -force' options were not needed on installer node.
CLSRSC-00532: Clusterware version string does not support downgrade for nodes that have not been upgraded.
Cause: An attempt to downgrade this node failed because Oracle Clusterware versions older than 11.2.0.3 do not support downgrade for nodes that have not been upgraded.
Action: Leave this node unupgraded as it is.
CLSRSC-00533: failed to get the OCR backup information: string
Cause: An attempt to downgrade this node failed because the 'ocrdump' command failed to retrieve the OCR backup information.
Action: Correct the problem indicated in the accompanying messages and then retry downgrade.
CLSRSC-00534: Current node string cannot be the last node to downgrade because the OCR backup file is on node string.
Cause: An attempt to downgrade this node supplying the '-lastnode' option failed because the OCR backup file was not on this node.
Action: Supply the '-downgrade -lastnode' option on the node where the OCR backup file is located.
CLSRSC-00535: There is nothing to be downgraded on this node.
Cause: An attempt to downgrade this node failed because this node has never been upgraded.
CLSRSC-00537: The root script failed to copy the OCR backup file from node string to shared storage.
Cause: An error occurred while copying the OCR backup file to shared storage.
Action: Examine the accompanying messages, correct the problem indicated and rerun rootupgrade.sh.
CLSRSC-00538: The root script failed to get the name of the OCR backup file on the ASM diskgroup, and local node string does not have the OCR backup file on local storage.
Cause: An error occurred while getting the OMF name of the OCR backup file using the 'asmcmd find' command.
Action: Examine the accompanying messages from the 'asmcmd find' command, and correct the problem indicated.
CLSRSC-00539: There is at least one expired OCR backup on the ASM diskgroup, and the root script failed to remove it from the ASM diskgroup.
Cause: An error occurred while removing the expired OCR backup file using the 'asmcmd rm' command.
Action: Examine the accompanying messages from the 'asmcmd rm' command, and correct the problem indicated.
CLSRSC-00540: The root script failed to get a unique name of the OCR backup file on the ASM diskgroup using string, and local node string does not have the OCR backup file on local storage.
Cause: There are more than one OMF names corresponding to the given OCR backup file name.
Action: Remove the expired OCR backup file from the ASM diskgroup using 'asmcmd rm' command.
CLSRSC-00544: If the cluster is downgraded after a partial upgrade, the downgrade command must be run on the node string with the '-lastnode' option to restore global configuration data.
Cause: The OCR backup is located on that node.
Action: The downgrade command must be run on the specified node with the '-lastnode' option.
CLSRSC-00545: Voting files are not found.
Cause: The voting files are either removed by an earlier operation or the query for the voting files failed.
Action: Run 'crsctl query css votedisk' to check if the voting files are configured.
CLSRSC-00546: The Grid Infrastructure processes identified by the following PIDs (string) are still active.
Cause: There were still some of Grid Infrastructure processes running after shutting down the Grid Infrastructure stack.
Action: Run the 'crsctl stop crs -force' command again, or 'rootcrs.pl -prepatch -cleanpids' to terminate active processes before continuing the patch process.
CLSRSC-00549: The root script cannot downgrade this node string with the '-lastnode' option because the Grid Infrastructure stack is up on at least one other cluster node.
Cause: An attempt to run the root script with the '-lastnode' option on this node failed because there was at least one other cluster node with its Grid Infrastructure stack up.
Action: Run the root script on this node with the '-lastnode' option after the Grid Infrastructure stack on all other cluster nodes is down.
CLSRSC-00550: Local node string failed to check the status of the Grid Infrastructure stack of other cluster nodes.
Cause: An attempt to downgrade this node with the '-lastnode' option failed because the root script failed to check the status of the Grid Infrastructure stack of other cluster nodes by starting CSS in exclusive mode.
CLSRSC-00551: unable to start rolling mode upgrade due to nodes running or to prior non-rolling upgrade
Cause: The cluster was either previously upgraded in non-rolling mode or the Oracle Grid Infrastructure stack has been started on some nodes after the non-rolling upgrade installer interview.
Action: Shutdown the Oracle Grid Infrastructure stack on all other nodes and then rerun rootupgrade.sh.
CLSRSC-00552: unable to proceed with downgrade due to missing option '-lastnode' or '-online'
Cause: An attempt to downgrade a node failed because a required option was missing from the downgrade command line. Either '-lastnode' or '-online' must be specified.
Action: To perform a downgrade offline, shutdown the Oracle Grid Infrastructure stack on all other nodes and then reissue the downgrade command on this node specifying the '-lastnode' option. Otherwise, reissue the downgrade command on this node specifying the '-online' option.
CLSRSC-00553: unable to proceed with downgrade because both '-lastnode' and '-online' were specified
Cause: An attempt to downgrade a node failed because both '-lastnode' and '-online' were specified in the downgrade command line.
CLSRSC-00554: unable to perform an online downgrade after the cluster was upgraded completely
Cause: An attempt to downgrade a node failed because the option '-online' was specified in the downgrade command after the cluster had been upgraded completely.
Action: Reissue the downgrade command on this node without '-online' option.
CLSRSC-00555: unable to downgrade node string with '-lastnode' option because OCR backup information was not available
Cause: An error occurred while downgrading this node with '-lastnode' option because the OCR backup information was not available.
CLSRSC-00556: Oracle Clusterware stack on this node has been successfully downgraded. There were some errors which can be ignored.
Cause: The downgrade was successful, but stopping the Oracle Clusterware afterwards failed.
Action: Retry the stop operation by running 'crsctl stop crs -f' from the higher version home.
CLSRSC-00557: Oracle Clusterware stack on this node has been successfully deconfigured. There were some errors which can be ignored.
Cause: The deconfiguration was successful, but stopping the Oracle Clusterware afterwards failed.
CLSRSC-00558: failed to deconfigure ASM
Cause: There was an error in deconfiguring ASM.
Action: Examine the accompanying messages and correct the problem.
CLSRSC-01001: Failed to add resource OC4J
Cause: An error occurred while executing the 'srvctl add oc4j' command.
CLSRSC-01002: Failed to create or update the wallet APPQOSADMIN
Cause: An error occurred while creating the wallet.
CLSRSC-01003: Failed to start resource OC4J
Cause: An error occurred while executing the 'srvctl start oc4j' command.
CLSRSC-01004: Failed to enable resource OC4J
Cause: An error occurred while executing the 'srvctl enable oc4j' command.
CLSRSC-01005: Failed to disable resource OC4J
Cause: An error occurred while executing the 'srvctl disable oc4j' command.
CLSRSC-01006: Failed to create the wallet APPQOSADMIN or associated users during upgrade.
Cause: An error occurred while creating the wallet APPQOSADMIN or the users oc4jamin and qosadmin during the upgrade.
Action: Respond as follows: 1 - Correct the problem indicated in the accompanying messages. 2 - Rerun rootupgrade.sh.
CLSRSC-01007: Failed to start OC4J resource
CLSRSC-01008: The script string either does not exist or is not executable.
Cause: The specified script did not exist or was not executable.
Action: Make sure the script exists and it has execute access.
CLSRSC-01009: failed to stop resource OC4J
Cause: An error occurred while executing the 'srvctl stop oc4j' command.
Action: Correct the problems indicated in the accompanying messages and rerun rootupgrade.sh
CLSRSC-02000: Failed to enable CRS after successfully installing the OKA drivers.
Cause: After successfully configuring OKA during an install, upgrade, or patch, the root script failed to enable CRS again, using the command 'crsctl enable crs'.
CLSRSC-02001: Failed to disable CRS in preparation for a node reboot.
Cause: After failure to install OKA drivers, an attemmpt to disable CRS in preparation for a node reboot was unsuccessful.
Action: Correct the errors accompanying the failure of the disable command, run 'crsctl disable crs', reboot, and resume the install configuration step.
CLSRSC-02002: Failed to enable CRS after successfully uninstalling the OKA drivers.
Cause: After successfully deconfiguring OKA during a downgrade, the root script failed to re-enable CRS using the command 'crsctl enable crs'.
CLSRSC-02003: An operating system reboot is required to continue the deconfiguration.
Cause: The uninstall of the OKA drivers failed. An operating system reboot is required to continue the deconfiguration.
CLSRSC-02004: Failed to disable CRS in preparation for a node reboot.
Cause: An attempt to disable CRS in preparation for a system reboot failed. The reboot is associated with a failed removal of OKA drivers.
CLSRSC-02006: Failed to create the OKA drivers resource but continuing with the installation
Cause: An error occured while creating the OKA drivers resource.
Action: Contact Oracle Support Services.
CLSRSC-02007: OKA driver install actions failed
Cause: An error occurred while installing OKA drivers using the 'okaroot install' command.
Action: Examine the accompanying messages from the 'okaroot install' command, correct the problem and retry.
CLSRSC-02008: A system reboot is required to continue installing.
Cause: The installation of new OKA drivers requires a node reboot to continue the install.
Action: Reboot the node and rerun the install configuration step.
CLSRSC-02009: Failed to create and start the OKA drivers resource but continuing with patching
Cause: An error occured while creating and starting the OKA drivers resource.
Action: Check if your OS kernel is supported and run 'okaroot enable' to create and start the OKA drivers resource.
CLSRSC-02501: The AFD driver install actions failed.
Cause: An error occurred while installing the AFD driver using the 'afdroot install' command.
Action: Examine the accompanying messages from the 'afdroot install' command, correct the problem and retry.
CLSRSC-02502: A system reboot is required to continue installing.
Cause: Installation of the new AFD driver requires a reboot to continue.
CLSRSC-02503: Failed to add resource 'string'
Cause: An error occurred while attempting to add AFD resource.
Action: Correct the problem indicated in the accompanying messages and retry the command.
CLSRSC-02504: Failed to rescan devices with 'afdtool -rescan'
Cause: An error occurred while executing the 'afdtool -rescan' command.
CLSRSC-02505: An operating system reboot is required to continue the operation.
Cause: The uninstall of the AFD driver failed. An operating system reboot is required to continue the upgrade or deconfiguration.
Action: Reboot the node and restart the operation.
CLSRSC-02506: An operating system reboot is required at the end of the deinstall.
Cause: The uninstall of the AFD driver failed. An operating system reboot is required to complete the deinstall.
Action: Reboot the node after deinstall.
CLSRSC-02601: Failed to add Oracle Cluster Health Analysis resource
Cause: An error occurred while executing the 'srvctl add cha' command.
CLSRSC-02602: Failed to forcibly add Oracle Cluster Health Analysis resource
Cause: An error occurred while executing the 'srvctl add cha -force' command.
CLSRSC-02603: Failed to start Oracle Cluster Health Analysis resource
Cause: An error occurred while executing the 'srvctl start cha' command.
CLSRSC-02604: Failed to set the TARGET to ONLINE for Oracle Cluster Health Analysis resource
CLSRSC-03000: Invalid object 'string' specified on command line.
Cause: The object specified on the command line was not recognized.
Action: Use appcluster.pl with the --help option to display valid options. Ensure that a valid option is specified.
CLSRSC-03002: Oracle Clusterware has already been configured for non-database applications.
Cause: A request to configure Oracle Clusterware for non-database applications was rejected because Clusterware is already configured for non-database applications.
Action: If this is the expected state then this is not an error. If it is not then Oracle Clusterware can be de-configured and configured.
CLSRSC-03003: Cannot configure Oracle Restart for non-database applications (Clusterware is only for clusters).
Cause: A request configure Oracle Clusterware for non-database applications was rejected because Oracle Grid Infrastructure for a stand-alone server (Oracle Restart) was configured.
Action: De-configure Oracle Restart and configure Oracle Clusterware.
CLSRSC-03004: Failed to gather the configuration information for the node applications.
Cause: An error occurred while gathering the configuration information for the node applications.
CLSRSC-04000: Oracle Trace File Analyzer (TFA) Collector is not supported on this platform.
Action: None
CLSRSC-04001: Installing Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04002: Successfully installed Oracle Trace File Analyzer (TFA) Collector.
Cause: This is a status message.
Action: None
CLSRSC-04003: Successfully patched Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04004: Failed to install Oracle Trace File Analyzer (TFA) Collector. Grid Infrastructure operations will continue.
Cause: The Installation of Oracle Trace File Analyzer (TFA) Collector failed with the accompanying errors.
Action: The Oracle Trace File Analyzer (TFA) Collector will not be available, but Grid Infrastructure operation is unaffected. Address the issues reported by accompanying messages and retry using the command '<GI_Home>/crs/install/tfa_setup -crshome <GI_Home>'. If the problem persists, contact Oracle Support Services for further action.
CLSRSC-04005: Failed to patch Oracle Trace File Analyzer (TFA) Collector. Grid Infrastructure operations will continue.
Cause: An attempt to patch Oracle Trace File Analyzer (TFA) Collector failed with the accompanying errors.
Action: The Oracle Trace File Analyzer (TFA) Collector may not be available, but Grid Infrastructure operation is unaffected. Address the issues reported by accompanying messages and retry using the command '<GI_Home>/crs/install/tfa_setup -crshome <GI_Home>'. If the problem persists, contact Oracle Support Services for further action.
CLSRSC-04006: Removing Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04007: Successfully removed Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04008: Failed to remove Oracle Trace File Analyzer (TFA) Collector from home location 'string'. Grid Infrastructure operations will continue.
Cause: The accompanying errors occurred while running the Oracle Trace File Analyzer (TFA) Collector uninstall script.
Action: The Oracle Trace File Analyzer (TFA) Collector may not be available, but Grid Infrastructure operation is unaffected. Address the issues reported by accompanying messages and retry using the command '<GI_Home>/tfa/bin/tfactl uninstall'. If the problem persists, contact Oracle Support Services for further action.
CLSRSC-04009: Starting Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04010: Successfully started Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04011: Failed to start Oracle Trace File Analyzer (TFA) Collector. Grid Infrastructure operations will continue.
Cause: The Oracle Trace File Analyzer (TFA) Collector failed to start with the accompanying errors.
Action: The Oracle Trace File Analyzer (TFA) Collector failing to start, but Grid Infrastructure operation is unaffected. Address the issues reported by accompanying messages and retry using the command '<GI_Home>/tfa/bin/tfactl start'. If the problem persists, contact Oracle Support Services for further action.
CLSRSC-04012: Shutting down Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04013: Successfully shut down Oracle Trace File Analyzer (TFA) Collector.
Action: None
CLSRSC-04014: Failed to shut down Oracle Trace File Analyzer (TFA) Collector. Grid Infrastructure operations will continue.
Cause: The Oracle Trace File Analyzer (TFA) Collector did not shut down for patching with the accompanying errors.
Action: A forcible stop will be issued so that patching can proceed, so no action is required.
CLSRSC-04015: Performing install or upgrade action for Oracle Trace File Analyzer (TFA) Collector.
Action: None
