Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
19 CLSW-00001 to CLSW-01000
CLSW-00001: Cluster Wallet operation failed
Cause: This is generic internal error for Cluster Wallet.
Action: Contact Oracle Customer Support.
CLSW-00002: Out of heap memory.
Cause: The program ran out of heap memory.
Action: Retry the operation when more memory is available.
CLSW-00003: Error in the cluster registry (OCR) layer. [number] [string]
Cause: An error occurred in the cluster registry layer while performing a cluster wallet operation.
Action: Ensure correct operation of cluster registry by inspecting ocr error (oerr proc ocrerror), by using ocrcheck and ocrdump, and retry the operation.
CLSW-00004: Error in the network security layer. [number] [string]
Cause: An error occurred in the network security layer while performing a cluster wallet operation.
Action: Inspect the network security error (oerr ora nzerr), and take corrective action to ensure correct operation.
CLSW-00005: Cannot perform cluster wallet operation because one of the parameters is NULL.
Cause: Program tried a cluster wallet operation using a NULL parameter.
Action: Check the parameters, and retry the operation.
CLSW-00006: Cannot perform cluster wallet operation because the context is invalid.
Cause: The cluster wallet context passed was invalid.
Action: Intialize the cluster wallet and retry the operation.
CLSW-00007: Cannot perform cluster wallet operation because one of the parameters is invalid. [number] [string]
Cause: Program tried a cluster wallet operation using an invalid parameter.
CLSW-00008: The cluster wallet to be created already exists.
Cause: The program tried to create a cluster wallet that already exists.
Action: Retry the operation after unsetting the CLSW_FLAGS_WALLET_CREATE
CLSW-00009: The cluster wallet to be operated on does not exist.
Cause: Program tried to access a cluster wallet which does not exist.
Action: Check to see if the cluster wallet exists and try the operation
CLSW-00010: Error in the NLS services.
Cause: An error occurred in the NLS services while performing a cluster wallet operation.
Action: Check to see if the message file exists in $ORACLE_HOME/has/mesg/clsw*.msb
CLSW-00011: Cannot perform cluster wallet operation because data stored in the registry is invalid.
Cause: The data stored in the registry cannot be converted to a wallet.
Action: Delete the registry key associated with the wallet and recreate the wallet.
CLSW-00012: User is not authorized to perform the cluster wallet operation. [number] [string]
Cause: Program tried an operation on a cluster wallet for which it does not have permission.
Action: Check to see if program is run as the correct user.
CLSW-00013: Error in the clusterware operating system (SCLS) services. [string]
Cause: An error occurred in the SCLS services while performing a cluster wallet operation.
Action: Check to see if NIS/LDAP on Unix and Active Directory Service on Windows has been correctly configured.
CLSW-00014: Wallet type 'string' is not supported on this operating system.
Cause: The program tried a cluster wallet operation using a wallet type that is not supported on current operating system.
Action: This is an internal error. Contact oracle support services.
CLSW-00015: Alias 'string' already exists in wallet type 'string'.
Cause: A request to add the specified alias to the wallet failed because the alias already existed in the wallet.
Action: Add an alias that does not already exist in the wallet. The password for an alias that already exists can be modified using the command 'crsctl modify wallet'.
CLSW-00016: Alias 'string' was not found in wallet type 'string'.
Cause: A request to modify the specified alias in the wallet failed because the alias did not exist in the wallet.
Action: Ensure that the alias exists in the wallet type specified. A new alias can be added to a wallet type using the command 'crsctl add wallet'.
CLSW-01000: Enter Password:
Cause: This is a prompt to user to enter password.
Action: Enter password.
