IMG-00001: unable to initialize Oracle Multimedia environment
Cause:
The image processing external procedure initialization process failed.
Action:
Contact Oracle Support Services.
IMG-00002: unrecoverable error
Cause:
This is an internal error.
Action:
IMG-00003: exhausted memory while processing image
Cause:
Oracle Multimedia exhausted available Java memory during processing.
Action:
Increase the JAVA_POOL_SIZE initialization parameter setting.
IMG-00201: unsupported metadata type
Cause:
The requested metadata type could not be read from or written to this image format.
Action:
Refer to the Oracle Multimedia documentation to select the proper metadata type for this image.
IMG-00202: unsupported character encoding
Cause:
The character encoding was not supported for this image format.
Action:
Refer to the Oracle Multimedia documentation to select the proper encoding for this image.
IMG-00203: xmlData is invalid
Cause:
The XML document was NULL or not schema valid.
Action:
Create a schema valid document for input.
IMG-00204: input metadata too long
Cause:
The metadata was too long to embed in this image format.
Action:
Trim the metadata, or use a different image format.
IMG-00205: cannot add a TIFF directory entry
Cause:
No new entries could be added to this directory.
Action:
Use a different image format.
IMG-00206: unsupported image format for putMetadata
Cause:
Metadata could not be written to this image format.
Action:
IMG-00207: input parameter is not valid
Cause:
The input parameter value contained an invalid value.
Action:
Correct the input parameter value.
IMG-00208: metadata format parse error
Cause:
The parser detected an error in the embedded metadata.
Action:
Verify that the metadata conforms to proper standards.
IMG-00209: error parsing metadata
Cause:
There was an internal error while parsing the metadata.
Action:
IMG-00210: unable to get metadata from an empty image
Cause:
There was no data in the input image.
Action:
Refer to the Oracle Multimedia documentation for information on how to populate image data into the image object.
IMG-00211: metadataType value "string" is invalid
Cause:
The metadataType parameter value was NULL or invalid.
Action:
Correct the metadataType parameter value.
IMG-00212: encoding value "string" is invalid
Cause:
The encoding parameter value was NULL or invalid.
Action:
Correct the encoding parameter value.
IMG-00213: xmlData does not contain an RDF element
Cause:
The XML document did not contain an RDF element as a child of xmpMetadata.
Action:
Create a schema valid document with an RDF element.
IMG-00502: invalid scale value
Cause:
An invalid scale value was found while parsing the parameters for the image process function.
Action:
Correct the statement by using a valid scale value. Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the image processing command string.
IMG-00505: missing value in CUT rectangle
Cause:
An incorrect number of values was used to specify a rectangle.
Action:
Use exactly four integer values for the lower-left and upper- right vertices.
IMG-00506: extra value in CUT rectangle
Cause:
Action:
Use exactly four integer values for the lower left and upper right vertices.
IMG-00510: string
Cause:
A syntax error was found while parsing the parameters for the image process function.
Action:
Correct the statement by using valid parameter values. Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the image processing command string.
IMG-00511: string
Cause:
An error was found while accessing image data.
Action:
IMG-00512: multiple incompatible scaling parameters found
Cause:
Multiple incompatible scaling parameters were found in the image process command string. With the exception of XSCALE and YSCALE, which can be used together in a process command string, scaling functions are mutually exclusive and cannot be combined.
Action:
Remove scaling functions until only one remains (or two, if they are XSCALE and YSCALE).
IMG-00513: missing value in scaling operation
Cause:
An incorrect number of values was used to specify image dimensions. fixedScale and maxScale require exactly two integer values for the X and Y dimensions of the desired image.
Action:
Use two values for fixedScale and maxScale.
IMG-00514: extra value in scaling operation
Cause:
Action:
IMG-00515: incorrect number of input channels
Cause:
An incorrect number of values was used to specify input channels. InputChannels requires either one or three channels numbers for the gray or red, green, and blue channel assignments.
Action:
Use either one or three values to specify the input channels.
IMG-00516: default channel out of range
Cause:
An incorrect value was used to specify the default channel selection.
Action:
Use a channel number which is less than or equal to the number of bands and greater than zero.
IMG-00517: height or width not present in parameter string
Cause:
Height and/or width were not specified in the setProperties parameter string.
Action:
Specify both the height and width.
IMG-00518: invalid value for height or width
Cause:
Height and/or width were not positive integers"
Action:
Specify both the height and width as positive integers"
IMG-00519: illegal combination of parameters
Cause:
Other than height, width, dataOffset, and userString no other parameters may be specified in the setProperties parameter string when CCITTG3 or CCITTG4 is used as the compressionFormat.
Action:
Supply only the height and width when compessionFormat is either CCITTG3 or CCITTG4. The dataOffset and userString may optionally be supplied as well.
IMG-00520: invalid value for numberOfBands
Cause:
NumberOfBands was not a positive integer"
Action:
Specify numberOfBands as a positive integer"
IMG-00521: invalid value for dataOffset
Cause:
DataOffset was not a positive integer"
Action:
Specify dataOffset as a positive integer"
IMG-00522: invalid format for parameter value
Cause:
A floating point value was specified where an integer is required, or a character value was specified where a numeric value is required.
Action:
Specify the correct type of values for process parameters.
IMG-00523: invalid process verb
Cause:
A process verb was specified that is not understood by Oracle Multimedia.
Action:
Refer to the Oracle Multimedia documentation for a description of valid process verbs.
IMG-00524: mismatched quotes
Cause:
Quotation marks used within a process command string were not matched.
Action:
Ensure that quotation marks occur in pairs.
IMG-00525: locale error
Cause:
Action:
IMG-00526: error parsing foreign image description
Cause:
An internal error occurred while processing a foreign image.
Action:
IMG-00527: invalid deletePages specified
Cause:
The specified value for the deletePages parameter was not valid.
Action:
See the Oracle Multimedia documentation for reference information about valid values for deletePages parameter.
IMG-00528: invalid movePages specified
Cause:
The specified value for the movePages parameter was not valid.
Action:
See the Oracle Multimedia documentation for reference information about valid values for movePages parameter.
IMG-00529: invalid combination of TIFF page operations
Cause:
The specified TIFF page operations were not valid.
Action:
See the Oracle Multimedia documentation for reference information about valid values for TIFF page operations.
IMG-00530: internal error while parsing command
Cause:
An internal error occurred while parsing the command passed to the image processing function or the foreign image setProperties function.
Action:
Check the command passed to the function. Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the image processing command string or the foreign image setproperties function. If you are certain that your command is correct, then contact Oracle Support Services.
IMG-00531: empty or null image processing command
Cause:
An empty or null image processing command was passed to the image process function.
Action:
IMG-00540: contentFormat and interleave conflict
Cause:
Interleave values were specified using both the contentformat and interleave verbs.
Action:
Specify interleave using either contentformat or interleave, but not both.
IMG-00541: invalid contentFormat specified
Cause:
The specified contentFormat was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid contentFormat specifications.
IMG-00542: contentFormat includes invalid extra information
Cause:
The specified contentFormat included invalid characters at the end of the parameter string.
Action:
IMG-00543: invalid compressionFormat specified
Cause:
The specified compressionFormat was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid compressionFormat specifications.
IMG-00544: invalid compressionQuality specified
Cause:
The specified compressionQuality was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid compressionQuality specifications.
IMG-00545: invalid cut values specified
Cause:
An invalid value was found while parsing the parameters for the cut operation.
Action:
Correct the statement by specifying values for the cut operation that are not negative. Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the image processing command string.
IMG-00546: invalid page number specified
Cause:
An invalid page number was specified.
Action:
Specify page numbers that are not negative.
IMG-00547: invalid channelOrder specified
Cause:
The specified channelOrder was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid channelOrder specifications.
IMG-00548: invalid interleave specified
Cause:
The specified interleave was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid interleave specifications.
IMG-00549: invalid pixelOrder specfied
Cause:
The specified pixelOrder was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid pixelOrder specifications.
IMG-00550: invalid scanlineOrder specified
Cause:
The specified scanline order was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid scanlineOrder specifications.
IMG-00551: invalid quantize method specified
Cause:
The specified quantization method was not valid.
Action:
Refer to the Oracle Multimedia documentation for a description of valid quantization method specifications.
IMG-00552: invalid inputChannels specified
Cause:
An invalid value was specified for the inputChannels verb.
Action:
Specify non-negative values for inputChannels. Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the image processing command string.
IMG-00553: invalid rotate value
Cause:
An invalid value was specified for image rotation. Rotation values must be a floating point number.
Action:
Correct the statement by providing a valid rotation value.
IMG-00554: extra value in rotate operation
Cause:
Multiple arguments were used to specify image rotation. The rotate operation accepts only a single value.
Action:
Provide a single value for the rotate operation.
IMG-00555: invalid value for gamma correction
Cause:
An invalid value was specified for gamma correction. Gamma values must be positive.
Action:
Correct the statement by providing a positive gamma value.
IMG-00556: incorrect number of gamma values
Cause:
An incorrect number of values were used to specify gamma correction. Gamma correction requires either one or three gamma values.
Action:
Provide either one or three values to specify the gamma correction.
IMG-00557: invalid value for contrast enhancement
Cause:
An invalid value was used to specify contrast enhancement.
Action:
To specify contrast enhancement using percentages, provide values between 0 and 100. To specify contrast enhancement using bounds, provide values greater than 0.
IMG-00558: incorrect number of contrast values
Cause:
An incorrect number of values were used to specify contrast enhancement. Contrast enhancement requires one, two, three, or six contrast values.
Action:
Provide one or three values to specify contrast enhancement using percentages; provide two or six values to specify contrast enhancement using contrast bounds.
IMG-00559: invalid frame number
Cause:
An incorrect number was used to specify frame in Dicom image. The number should be greater than 0 and less than total frames in Dicom image.
Action:
Provide one number greater than 0 and less than total frames in Dicom image.
IMG-00560: input format does not support page selection
Cause:
The page verb was specified for an input format that does not support selecting pages.
Action:
Remove the page selection verb. Refer to the Oracle Multimedia documentation for a description of which image formats support page selection.
IMG-00561: input format does not support channel selection
Cause:
The inputChannels verb was specified for an input format that does not support selecting channels.
Action:
Remove the inputChannels verb. Refer to the Oracle Multimedia documentation for a description of which image formats support input channel selection.
IMG-00577: invalid quantize argument
Cause:
A quantize value was specified that accepts an argument, but the argument provided was not valid.
Action:
Provide a valid, non-negative argument for the quantize value.
IMG-00578: missing quantize argument
Cause:
A quantize value was specified that requires an argument, but no argument was provided.
Action:
Provide an argument for the quantize value.
IMG-00579: extra quantize argument
Cause:
An extra argument was provided for a quantize value. Some quantize values accept no arguments, while others accept a single argument.
Action:
Provide an argument only for quantize values that accept an argument.
IMG-00580: specified format does not support output
Cause:
The output format specified by fileFormat does support output.
Action:
Change the specified fileFormat to one that supports output. Refer to the Oracle Multimedia documentation for a description of which formats support output.
IMG-00581: output format does not support the specified contentFormat
Cause:
The specified contentFormat is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which contentFormat values are supported for each output format.
IMG-00582: output format does not support the specified interleave
Cause:
The specified interleave is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which interleave values are supported for each output format.
IMG-00583: output format does not support the specified compressionFormat
Cause:
The specified compressionFormat is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which compressionFormat values are supported for each output format.
IMG-00584: output format does not support the specified compressionQuality
Cause:
The specified compressionQuality is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which compressionQuality values are supported for each output format.
IMG-00585: output format does not support the specified channelOrder
Cause:
The specified channelOrder is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which channelOrder values are supported for each output format.
IMG-00586: output format does not support the specified pixelOrder
Cause:
The specified pixelOrder is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which pixelOrder values are supported for each output format.
IMG-00587: output format does not support the specified scanlineOrder
Cause:
The specified scanlineOrder is not supported by the explicitly or implicitly specified output format.
Action:
Refer to the Oracle Multimedia documentation for a description of which scanlineOrder values are supported for each output format.
IMG-00599: internal error
Cause:
An internal error has occurred.
Action:
IMG-00601: out of memory while copying image
Cause:
Operating system process memory has been exhausted while copying the image.
Action:
See the database administrator or operating system administrator to increase process memory quota.
IMG-00602: unable to access image data
Cause:
An error occurred while reading or writing image data.
Action:
Ensure that the source image can be read from and the destination can be written to.
IMG-00603: unable to access source image data
Cause:
The source image SOURCE attribute is invalid.
Action:
Ensure that the SOURCE attribute of the source image is populated with image data.
IMG-00604: unable to access destination image data
Cause:
The destination image SOURCE attribute is invalid.
Action:
Ensure that the SOURCE attribute of the destination image is populated with image data.
IMG-00606: unable to access image data
Cause:
An attempt was made to access an invalid image.
Action:
Ensure that the SOURCE attribute of the image is populated with image data.
IMG-00607: unable to write to destination image
Cause:
Action:
Ensure that the SOURCE attribute of the destination image is initialized correctly and that you have sufficient tablespace.
IMG-00609: unable to read image stored in a BFILE
Cause:
The image stored in a BFILE cannot be opened for reading.
Action:
Ensure that the access privileges of the image file and the image file's directory allow read access.
IMG-00611: unable to access the BLOB for reading
Cause:
The BLOB could not be opened for reading.
Action:
IMG-00612: unable to open export destination file
Cause:
The file could not be created or opened.
Action:
Check that the file does not refer to an existing directory. Check that the file is not locked by another application.
IMG-00613: export destination access denied
Cause:
Permission to write to destination file was denied.
Action:
Refer to the Oracle Multimedia documentation for information on granting privileges for the export() method.
IMG-00614: I/O error during export
Cause:
The export operation failed because of an I/O error.
Action:
Check OS logs and contact Oracle Support Services.
IMG-00701: unable to set the properties of an empty image
Cause:
There is no data in the image object.
Action:
IMG-00702: unable to initialize image processing environment
Cause:
Action:
IMG-00703: unable to read image data
Cause:
There is no image data in the image object.
Action:
IMG-00704: unable to read image data
Cause:
Action:
IMG-00705: unsupported or corrupted input format
Cause:
Action:
IMG-00706: unsupported or corrupted output format
Cause:
Action:
IMG-00707: unable to access image data
Cause:
Action:
Contact your system administrator.
IMG-00710: unable to write to destination image
Cause:
The destination image is invalid.
Action:
Ensure that the SOURCE attribute of the destination image is initialized and that you have sufficient tablespace.
IMG-00711: unable to set properties of destination image
Cause:
Action:
IMG-00712: unable to write to destination image
Cause:
Action:
Ensure that the SOURCE attribute of the destination image is initialized and that you have sufficient tablespace. Ensure the row containing the destination image has been locked (this does not apply to temporary BLOBs).
IMG-00713: unsupported destination image format
Cause:
A request was made to convert an image to a format that is not supported.
Action:
Refer to the Oracle Multimedia Documentation for supported formats.
IMG-00714: internal error
Cause:
Action:
IMG-00715: unable to open image stored in a BFILE
Cause:
The image stored in a BFILE could not be opened for reading.
Action:
IMG-00716: source image format does not support process options
Cause:
A request was made to apply a processing option not supported by the source image format.
Action:
Refer to the Oracle Multimedia Documentation for a discussion of supported processing options.
IMG-00717: destination image format does not support process options
Cause:
A request was made to apply a processing option not supported by the destination image format.
Action:
IMG-00718: the same Temporary LOB cannot be used as both source and destination
Cause:
A call was made to processCopy with the same Temporary LOB being specified as both the source and destination.
Action:
Specify a different LOB for parameter "dest".
IMG-00719: image processing internal error
Cause:
Action:
IMG-00720: image processing internal error
Cause:
Action:
IMG-00721: unable to find source plug-in package ORDPLUGINS.ORDX_string_SOURCE
Cause:
Custom source plug-in for user-specified source type was not found.
Action:
Ensure correct source type is specified or proper custom source plug-in package is installed.
IMG-00722: incorrect value of bitsAllocated, bitsStored or highBit for output Dicom image
Cause:
incorrect value of bitsAllocated, bitsStored or highBit for output Dicom image.
Action:
Ensure correct value of bitsAllocated, bitsStored or highBit for output Dicom image.
IMG-00723: missing value in SHARPEN operation
Cause:
An incorrect number of values was used to specify the sharpen parameters.
Action:
Use one integer value to specify the kernel type and one float value to specify the gain factor.
IMG-00724: extra value in SHARPEN operation
Cause:
Action:
IMG-00725: output image will be empty
Cause:
The processing commands resulted in an empty output image.
Action:
Ensure the resulting output image will not be empty.
IMG-00726: invalid value for the AVI framerate
Cause:
An invalid value was used to specify the AVI framerate parameter.
Action:
Use a floating-point value to specify the AVI framerate parameter.
IMG-00727: invalid value for the AVI frametime
Cause:
An invalid value was used to specify the AVI frametime parameter.
Action:
Use a floating-point value to specify the AVI frametime parameter.
IMG-00728: multiple incompatible AVI frame parameters found
Cause:
Multiple incompatible AVI frame parameters were found.
Action:
Use only one AVI frame parameter.
IMG-00729: output format does not support the specified frame parameters
Cause:
The specified frame parameter is not supported by the explicitly or implicitly specified output format.
Action:
Specify AVI as the output format in the process command string.
IMG-00730: unable to process empty image
Cause:
There is no data in the input image object.
Action:
Refer to the Oracle Multimedia documentation for information on how to put image data into the image object.
IMG-00731: specified page could be found in input image
Cause:
The specified page does not exist in the input image.
Action:
Restrict the value of the page parameter to values specifying pages that exist within the input image object.
IMG-00732: specified inputChannels could not be found in input image
Cause:
The specified inputChannel parameter does not exist in the input image.
Action:
Restrict the value of the inputChannels parameter to values specifying channels that exist within the input image object.
IMG-00733: invalid watermark property setting
Cause:
The specified watermark property setting is not supported by Oracle Multimedia.
Action:
See the Oracle Multimedia documentation for a description of valid watermark property settings.
IMG-00734: invalid deflateLevel value
Cause:
The specified value for the deflateLevel parameter was not supported by Oracle Multimedia.
Action:
See the Oracle Multimedia documentation for a description of the valid values for the deflateLevel parameter.
IMG-00735: incorrect transparencyFillColor values
Cause:
The specified value for the transparencyFillColor parameter was not supported by Oracle Multimedia.
Action:
See the Oracle Multimedia documentation for a description of the valid values for the transparencyFillColor parameter.
IMG-00800: internal error while parsing attribute string
Cause:
An internal error occurred while parsing the attribute string containing the weights of the attributes.
Action:
Check the command passed to the function. Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the attributes string for image matching. If you are certain that your command is correct, then contact Oracle Support Services.
IMG-00801: cannot extract height and width
Cause:
Height and width are not set in the image object.
Action:
Set the properties of the image object by calling setProperties and then generate signature.
IMG-00802: empty or null attribute string
Cause:
An empty or null attributes string was passed to the image matching operators.
Action:
Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax of the attributes string.
IMG-00803: invalid attribute value
Cause:
An invalid value was found while parsing the attribute string for the image matching operators.
Action:
Refer to the Oracle Multimedia documentation for a description of the correct usage and syntax for the attributes string. The weight values should be between 0.0 and 1.0.
IMG-00804: Syntax error in attribute string
Cause:
A syntax error was found while parsing the attribute string for the image matching operators.
Action:
IMG-00805: SIGNATURE data has been corrupted or is invalid
Cause:
The data in the signature is not a valid signature.
Action:
Re-create the signature using the generateSignature method.
IMG-00806: invalid input image
Cause:
The image data is either corrupt or is in an unsupported format.
Action:
Repopulate the image object, set properties of the image, and generate the signature.
IMG-00807: no weights specified in weight string
Cause:
All weights passed were zero. At least one attribute must be weighted.
Action:
Specify a non-zero weight for at least one attribute
IMG-00808: unable to read an empty image
Cause:
Action:
Refer to the Oracle Multimedia documentation for information on how to populate the image object with image data.
IMG-00809: usage of IMGSimilar is incorrect
Cause:
Syntax error while using IMGSimilar
Action:
Refer to the Oracle Multimedia documentation for information on how to use the IMGSimilar operator. Check whether the value returned by IMGSimilar is compared to the value 1.
IMG-00810: boundary queue initialization failed
Cause:
Operating system process memory has been exhausted while initializing the boundary queue.
Action:
IMG-00811: fail queue initialization failed
Cause:
Operating system process memory has been exhausted while initializin the fail queue.
Action:
IMG-00812: merged area queue initialization failed
Cause:
Operating system process memory has been exhausted while initializing the merged area queue.
Action:
IMG-00813: boundary queue free failed
Cause:
An internal error has occured.
Action:
Contact Oracle Support Services with the error number.
IMG-00814: fail queue free failed
Cause:
Action:
IMG-00815: merged area queue free failed
Cause:
Action:
IMG-00820: area 0 queue clear failed
Cause:
Action:
IMG-00821: area N queue clear failed
Cause:
Action:
IMG-00822: area queue reset failed
Cause:
Action:
IMG-00823: boundary queue pop failed
Cause:
Action:
IMG-00824: fail queue pop failed
Cause:
Action:
IMG-00825: merged area queue pop failed
Cause:
Action:
IMG-00830: boundary queue is full
Cause:
Action:
Contact Oracle Support Services with the error number and the image causing this problem.
IMG-00831: boundary queue size exceeds expected size
Cause:
Action:
IMG-00832: fail queue is full
Cause:
Action:
IMG-00833: boundary queue size exceeds expected size
Cause:
Action:
IMG-00834: merged area queue is full
Cause:
Action:
IMG-00835: merged area queue size exceeds expected size
Cause:
Action:
IMG-00836: area queue merge failed
Cause:
Action:
IMG-00840: image structure allocation failed
Cause:
Operating system process memory has been exhausted while initializing the image structure.
Action:
IMG-00841: image data allocation failed
Cause:
Operating system process memory has been exhausted while initializing the image data.
Action:
IMG-00842: image index allocation failed
Cause:
Operating system process memory has been exhausted while initializing the image index.
Action:
IMG-00843: internal image structure allocation failed
Cause:
Operating system process memory has been exhausted while initializing the internal image structure.
Action:
IMG-00844: internal image data allocation failed
Cause:
Operating system process memory has been exhausted while initializing the internal image data.
Action:
IMG-00845: internal image index allocation failed
Cause:
Operating system process memory has been exhausted while initializing the internal image index.
Action:
IMG-00846: adjacency matrix allocation failed
Cause:
Operating system process memory has been exhausted while initializing the adjacency matrix.
Action:
IMG-00847: area list allocation failed
Cause:
Operating system process memory has been exhausted while initializing the area list.
Action:
IMG-00850: image structure free failed
Cause:
Action:
IMG-00851: image data free failed
Cause:
Action:
IMG-00852: image index free failed
Cause:
Action:
IMG-00853: internal image structure free failed
Cause:
Action:
IMG-00854: internal image data free failed
Cause:
Action:
IMG-00855: internal image index free failed
Cause:
Action:
IMG-00856: adjacency matrix free failed
Cause:
Action:
IMG-00857: area list free failed
Cause:
Action:
IMG-00860: assert failure, number of region exceeds allocated
Cause:
Action:
IMG-00861: assert failure, inconsistency in area merge operation
Cause:
Action:
IMG-00862: assert failure, inconsistency in merged area labels
Cause:
Action:
IMG-00870: unsupported aspect ratio or image size
Cause:
Signature generation was attempted on an image smaller than the supported size.
Action:
Try scaling the image up to have a larger height and width, the suggested size is greater than 21 pixels each. If signature generation still fails, contact Oracle Support Services with the error number and the image causing this problem.
IMG-00871: unexpected number of seeds
Cause:
Action:
IMG-00872: unsupported image model
Cause:
Signature generation was attempted on an image with an image model that Oracle Multimedia is unable to support.
Action:
Try scaling the image down. If signature generation still fails, contact Oracle Support Services with the error number and the image causing this problem.
IMG-00899: signature cannot be generated
Cause:
generateSignature could not generate the signature.
Action:
Verify that the input image is a format supported by Oracle Multimedia.
IMG-00901: VIR signature version mismatch
Cause:
Two signatures to be compared have different versions.
Action:
Recompute signatures on the same platform and repeat signature comparison.
IMG-00902: VIR signature free failed
Cause:
Action:
IMG-00910: allocation of basic data structure failed
Cause:
Action:
IMG-00911: free basic data structure failed
Cause:
Action:
IMG-00921: threshold out of range
Cause:
Threshold is not between 0 and 100
Action:
Use a threshold between 0 and 100 and retry query.
IMG-00922: location specified without feature
Cause:
only location was specified.
Action:
Specify at least one other parameter (color, texture or shape) along with location. Refer to the Oracle Multimedia documentation for more details.
IMG-00923: signature is empty
Cause:
Signature has not been generated.
Action:
Generate the signature for the image by calling the generateSignature method.
IMG-00924: Incorrect parameter specification during CREATE INDEX
Cause:
There is a spelling error, or duplicate parameter specification, or incorrect specification of parameters while creating an index of type ORDIMAGEINDEX.
Action:
Refer to the Oracle Multimedia documentation for correct specification of CREATE INDEX parameters.
IMG-00925: unable to write to the ORDImageSignature object
Cause:
The signature object was not valid and therefore the write operation failed. This problem is commonly caused by an attempt to invoke the generateSignature method on an uninitialized ORDImageSignature object.
Action:
Ensure that the ORDImageSignature object has been initialized and inserted into a table. Also ensure that the row containing the signature object is locked. (The two previous actions do not apply to signature objects created using temporary BLOBs). Ensure that there is sufficient tablespace to contain the signature.
IMG-00926: tablespace specified during CREATE INDEX is not valid
Cause:
A tablespace specified in the parameter string of a CREATE INDEX operation did not exist or the current user did not have sufficient privileges on the tablespace.
Action:
Create the tablespace, grant appropriate privileges on the tablespace to the current user, or choose a different tablespace.
IMG-01000: unsupported option string
Cause:
The function was invoked with an invalid option string.
Action:
Ensure that correct option string is passed to the PL/SQL function. Refer to the Oracle Multimedia documentation for more information.
IMG-01001: not a DICOM object
Cause:
The input was not a valid DICOM standalone object.
Action:
Use an object that conforms to the DICOM standard. Refer to the Oracle Multimedia documentation for more information.
IMG-01002: unsupported DICOM version
Cause:
The object header could not be parsed, possibly because the object header did not conform to the DICOM standard release 2003.
Action:
Use an object that conforms to the DICOM standard release 2003. Refer to the Oracle Multimedia documentation for more information.
IMG-01003: unsupported DICOM object type
Cause:
The category of DICOM objects is not supported by Oracle Multimedia.
Action:
Use a DICOM image is supported by Oracle Multimedia. Oracle Multimedia supports image types defined in the DICOM standard release 2003. Refer to the Oracle Multimedia documentation for more details.
IMG-01004: input DICOM object is not an image
Cause:
The DICOM object was not a DICOM image. DICOM object types such as structured reporting are not allowed by this function.
Action:
Invoke this function with a DICOM image. Refer to the Oracle Multimedia documentation for more details.
IMG-01005: unsupported DICOM transfer syntax
Cause:
The operation failed because the transfer syntax in the DICOM object, which describes the binary encoding of the DICOM object, was not supported by Oracle Multimedia.
Action:
Use a DICOM object with a transfer syntax supported by Oracle Multimedia. Refer to the Oracle Multimedia documentation for more details.
IMG-01006: DICOM object cannot be parsed
Cause:
The DICOM object could not be parsed by Oracle Multimedia, possibly due to an incorrect format or corrupted object.
Action:
Verify that the DICOM object is not corrupted. If the DICOM object is valid, contact Oracle Support Services.
IMG-02001: 2FF01 - incorrect image format
Cause:
There was a SQL/MM Still Image exception. Either the supplied image BLOB format did not match the image format or the image format is unsupported.
Action:
For supported image formats, specify an input BLOB that has the same format as the image. For unsupported image formats, this method is not supported. Refer to the Oracle Multimedia documentation for more information.
IMG-02002: 2FF02 - incorrect average color feature specification
Cause:
There was a SQL/MM Still Image exception. The specified average color value was not a valid SI_Color value.
Action:
Specify an average color value that is not null and contains valid SI_Color values. SI_Color attribute values must be integers from 0 to 255. Refer to the Oracle Multimedia documentation for more information on constructing valid SI_Color objects.
IMG-02003: 2FF03 - incorrect color histogram feature specification
Cause:
There was a SQL/MM Still Image exception. This exception was caused by one of the following.
- The specified color value was null or invalid.
- The specified frequency value was null or invalid.
- The input color and frequency arrays were not equal in size.
- The SI_ColorList array attribute had reached the maximum size.
Action:
Ensure that the following are true(as applicable to your case):
- The color and frequency values are not null.
- The SI_Color attribute values are integers from 0 to 255.
- The frequency value is a double precision number from 0 to 100.
- The color and frequency arrays are equal in size and the size of the arrays is less than the SI_MaxHistogramLength value listed in the SI_VALUES view in the SI_INFORMTN_SCHEMA. Refer to the Oracle Multimedia documentation for more information on constructing SI_ColorHistogram objects.
IMG-02004: 2FF04 - incorrect feature list specification
Cause:
There was a SQL/MM Still Image exception. Either the specified feature values were invalid or the specified feature weights were invalid.
Action:
Check the values of feature and featureweight pairs. For a non null feature value, the corresponding feature weight value must be a double precision number greater than 0.0. Refer to the Oracle Multimedia documentation for more information on the SI_FeatureList object type and its methods.
IMG-02005: 2FF05 - incorrect color specification
Cause:
There was a SQL/MM Still Image exception. The specified red/green/blue value was null or invalid.
Action:
Specify red, green and blue values as integers from 0 to 255.
IMG-02006: 2FF06 - average color feature cannot be determined
Cause:
There was a SQL/MM Still Image exception. Either the specified image was null, the image data in the specified image was null, or the average color feature was not supported by the specified image format
Action:
Specify an image with non null image data and a supported format. Refer to the SI_INFORMTN_SCHEMA views and the Oracle Multimedia documentation for a list of supported image formats and image features.
IMG-02007: 2FF07 - positional color feature cannot be determined
Cause:
There was a SQL/MM Still Image exception. Either the specified image was null, the image data in the specified image was null, or the positional color feature was not supported by the specified image format.
Action:
Specify an image with non null image data and a supported format. Refer to the SI_INFORMTN_SCHEMA views and the Oracle Multimedia documentation for a list of supported image features and formats.
IMG-02008: 2FF08 - color histogram feature cannot be determined
Cause:
There was a SQL/MM Still Image exception. Either the specified image was null, the image data in the specified image was null, or the color histogram feature was not supported by the specified image format.
Action:
Specify an image with non null image data and a supported format Refer to the SI_INFORMTN_SCHEMA views and the Oracle Multimedia documentation for a list of supported image features and formats.
IMG-02009: 2FF09 - texture feature cannot be determined
Cause:
There was a SQL/MM Still Image exception. Either the specified image was null, the image data in the specified image was null, or the texture feature was not supported by the specified image format.
Action:
IMG-02010: 2FF10 - illegal image format specification
Cause:
There was a SQL/MM Still Image exception. The specified format name was null or invalid.
Action:
Specify a format name that is not null. For supported image formats, specify a format name that matches the image BLOB format. For unsupported image formats, specify a format name that is not listed as supported image format. Refer to the SI_INFORMTN_SCHEMA views and the Oracle Multimedia documentation for a list of supported image formats.
IMG-02011: 2FF11 - unsupported image format conversion specified
Cause:
There was a SQL/MM Still Image exception. Either the specified target format value was null, the specified image had a null format value, or the conversion from the specified image format to the specified target format was not supported.
Action:
Specify an image with a supported image format and specify a target format value that is supported for conversion. Refer to the SI_INFORMTN_SCHEMA views and the Oracle Multimedia documentation for a list of supported image format conversions.
IMG-02012: 2FF12 - illegal specification for thumbnail generation
Cause:
There was a SQL/MM Still Image exception. Either the specified image format did not support thumbnail generation, the specified thumbnail height or width was greater than the image height or width respectively, or the default thumbnail size 80 X 80 was greater than the image height or width respectively.
Action:
Specify an image for which thumbnail generation is supported and specify thumbnail height and width values that are less than the image height and width values. Refer to the SI_INFORMTN_SCHEMA views and the Oracle Multimedia documentation for a list of supported thumbnail formats.
IMG-02014: 2202D Data exception - Null image value
Cause:
There was a SQL/MM Still Image exception. The function was invoked using a null image value.
Action:
Specify an image whose image data is not null. Refer to the Oracle Multimedia documentation for more information on constructing SI_StillImage objects.
