- INS-00001: Unknown irrecoverable error
Cause: No additional information available.
Action: Refer to the logs or contact Oracle Support Services
- INS-00002: Unhandled exception
- INS-00003: Application startup failed
Cause: An unexpected error occured while loading the application configuration or other startup resources.
- INS-00004: Unable to load help
Cause: One or more help configuration files were not readable or not in the correct format.
Action: Contact Oracle Support Services or refer to the software manual.
- INS-00005: Invalid application configuration
Cause: The given application configuration is not compliant to the expected schema.
- INS-00006: No resource bundle is associated to the Resource instance
Cause: Specified resource bundle string is not found in the classpath.
Action: Ensure that the required libraries are in the classpath.
- INS-00007: Help not available for this application
Action: Contact Oracle Support Services support or refer software manual.
- INS-00008: Help topic not found
Cause: The current user interface do not have help content associated with it.
- INS-01001: Failed to create parent directories while copying string to string
Cause: Unexpected error occured while creating the nonexistent parent directories of the destination file string
Action: Manually verify whether the destination directory is possible to be created.
- INS-01002: Copy failed as the source file string do not exist
Action: Ensure that the source file exist.
- INS-01003: Copy failed as the source path string do not correspond to a file.
Cause: Copy routine expects a source path, which represents a file.
Action: Ensure that the source is a file and destination is a file or a directory. Note: if the destination is a directory, then the source file will be copied in the same name, under the destination directory.
- INS-01004: string is not directory.
Cause: The archive extraction routine expects the destination to be a directory.
Action: Ensure that destination is a directory
- INS-01005: Failed to copy file from string to string
Cause: Unexpected error occured while copying the file.
Action: Refer to the logs for more details.
- INS-01006: The file string cannot be copied onto itself.
Cause: The source file and destination file are same.
Action: Ensure that the destination file is different from the source file.
- INS-01007: The directory string cannot be copied onto itself
Cause: The source directory and destination directory are same.
Action: Ensure that the destination directory is different from the source directory.
- INS-01008: Copy failed as the destination file string already exists.
Action: Ensure that the destination file do not exist or use overwrite option to overwrite the destination file.
- INS-01009: string is not valid archive.
Cause: The given archive path, either do not correspond to a file or do not exist.
Action: Ensure that the given source path correspond to a valid archive location.
- INS-01010: Unable to save file to the specified location.
Cause: The specified location may not be writable.
Action: Specify a location that is writable.
- INS-04001: Invalid command line arguments xml file (string). Either application could not detect command line arguments xml file or contains syntactically incorrect information.
Cause: n/a
Action: n/a
- INS-04002: Application could not parse command line arguments xml file (string). Either XPathExpressionException or IOException occurred while parsing command line arguments xml file.
Cause: n/a
Action: n/a
- INS-04003: Invalid argument passed from command line. Specified argument (string) is not a supported argument for this application.
Cause: n/a
Action: n/a
- INS-04004: Value is not specified for comamnd line argument: string. Specify valid value for the mentioned argument. Refer application help for more details.
Cause: n/a
Action: n/a
- INS-04005: Invalid argument passed from command line: string. Specified argument is not a supported for the current operating system.
Cause: n/a
Action: n/a
- INS-04006: Invalid combination of arguments passed from command line. Arguments [string,string] cannot be passed together in the same application session.
Cause: n/a
Action: n/a
- INS-04007: Invalid argument passed from command line: string
Cause: n/a
Action: n/a
- INS-04008: Invalid combination of arguments passed from command line. One or more mandatory dependent arguments are not passed for the arugment: string
Cause: n/a
Action: n/a
- INS-04009: The argument [string] passed is not supported for the current context string
Cause: n/a
Action: n/a
- INS-06001: Failed to perform operation due to internal driver error.
- INS-06002: Authentication failed.
Cause: Failed to login into the selected nodes.
Action: Check shared unix password. Locked accounts or accounts with no password are not supported. Contact Administrator or refer logs for more details.
- INS-06003: Failed to setup passwordless SSH connectivity with the following node(s): string
Cause: It is possible that the failed nodes are running different Operating System or not reachable. If they are reachable and running the same Operating System as the local machine, it is possible that the SSH daemon is not configured on the selected nodes.
Action: Ensure that the failed nodes are reachable, running the same Operating System and have support for SSH connectivity.
- INS-06004: File operation on user's .ssh directory is not permitted.
Cause: Write permission not set for either user's home directory or .ssh directory under user's home directory.
Action: Ensure that .ssh directory is either allowed to be created under user's home directory or .ssh directory allows files to be written into it.
- INS-06005: Unable to get SSH connectivity details.
Cause: An unexpected error occured while getting SSH connectivity details across the selected nodes.
Action: Refer to the logs for more details or contact Oracle Support Services.
- INS-06006: Passwordless SSH connectivity not set up between the following node(s): string.
Cause: Either passwordless SSH connectivity is not setup between specified node(s) or they are not reachable. Refer to the logs for more details.
- INS-06007: SSH connectivity check operation disabled
Cause: Either the property named 'oracle.install.ssh.setupCheckEnabled' is set to true in Java system properties or the internal driver had disabled this operation.
Action: Try setting 'oracle.install.ssh.setupCheckEnabled=true' as Java system property or contact Oracle Support Services.
- INS-06008: SSH connectivity setup operation disabled
Cause: Either the property named 'oracle.install.ssh.setupEnabled' is set to true in Java system properties or the internal driver had disabled this operation.
Action: Try setting 'oracle.install.ssh.setupEnabled=true' as Java system property or contact Oracle Support Services.
- INS-06101: IP address of localhost could not be determined
Cause: The localhost is not mapped to a valid IP address in Hosts file (Eg. /etc/hosts in Unix).
Action: Assign a valid IP address for the localhost or set it to loopback IP address (127.0.0.1 in IPv4 or ::1 in IPv6).
- INS-07001: Value for property 'string' not found in the bean store.
Action: It is not mandatory that all properties are to be in a given bean store. This error can be ignored if the given property is not expected to be in the bean store.
- INS-07002: Unable to get the type definition for property named 'string' of bean type 'string'
Action: Ensure that the properties in the bean type are correctly defined.
- INS-07003: Unexpected error occured while accessing the bean store
Action: Refers logs or contact Oracle Support Services
- INS-07004: Invalid bean store
Cause: Either the bean store is corrupt or it does not have access to the underlying data source.
- INS-07005: The given beans cannot be written because there is no bean store assigned to the bean store writer.
- INS-07006: Unabled to save the bean store to the given target.
Cause: Either the target is not accessible or an unexpected error occured while saving the bean store.
- INS-07007: Failed to open or create a bean store reader.
- INS-07008: The format of the bean store is not specified
- INS-07009: Unable to load bean store
Cause: Unexpected error while loading the bean store.
- INS-07010: Invalid argument string
Cause: The argument for a given property did not comply with either the specification, schema, or rules.
Action: Ensure that given arguments are of the expected data type or schema
- INS-08001: Flow configuration is syntactically incorrect
- INS-08005: View class may not exist or a fully qualified View class name is not given.
- INS-08007: Fully qualified Action class name is not given.
- INS-08011: Route identifier 'string' mentioned in the transition may not exist.
- INS-08012: Unknown View Identifier 'string' associated to a state.
- INS-08013: Unknown Validator class 'string' associated to a state.
- INS-08014: Fully qualified Condition class name is not given.
- INS-08015: No transition specified for condition defined at state 'string'.
- INS-08101: Unexpected error while executing the action at state: 'string'
- INS-08102: Unexpected error occurred while transitioning from state 'string'
- INS-08103: Null route returned by state 'string'.
Cause: The route was not chosen from the current state in order to proceed further.
Action: No additional information available.
- INS-08104: Route 'string' returned by state 'string' is not found in the flow configuration.
- INS-08106: Unexpected error occurred while loading the view 'string' associated to state 'string'.
- INS-08107: Failed while processing user inputs at state 'string'.
Cause: Unexpected error occurred while processing the inputs from view 'string' associated to state 'string'.
- INS-08108: Failed while localizing the view
Cause: Unexpected error occurred while localizing the view 'string' associated to state 'string'.
- INS-08109: Unexpected error occurred while validating inputs at state 'string'.
- INS-08110: Invalid checkpoint file 'string'.
Cause: Session restoration failed since the given checkpoint file may have been syntactically incorrect or did not exist.
- INS-08801: View class referred by view ID 'string' not found.
Cause: The given View class was not found in the classpath.
- INS-08802: Unable to instantiate the View class referred by View ID 'string'.
Cause: The given class do not represent a valid View class or an unexpected error occured while instantiating it.
- INS-10002: Inventory initialization failed
Cause: Inventory exist, but an unexpected error occured while initializing it.
Action: Ensure that the inventory is not corrupt. Otherwise contact Oracle Support Services or refer logs.
- INS-10006: Scratch path 'string' is not valid.
Cause: The specified scratch path is either not accessible or do not exist.
Action: Contact Oracle Support Services or refer logs
- INS-10008: Session initialization failed
Cause: An unexpected error occured while initializing the session.
- INS-10010: Scratch path not defined or set
Cause: Not additional information available
- INS-10012: Setup driver initialization failed.
Cause: An unexpected error occured while initializing the underlying setup driver.
- INS-10013: The installer has detected that current home is not registered in the central inventory on this system.
Cause: This can happen for the following reasons - either string has not been run or script failed to update the inventory.
Action: Run the script as a root user.
- INS-10014: The installer has detected that current home is not registered in the central inventory on the node(s): string.
- INS-10015: Argument (string) passed from the command line is invalid.
Cause: n/a
Action: n/a
- INS-10016: Installer failed to update the cluster related details, for this Oracle home, in the inventory on all/some of the nodes
Cause: n/a
Action: n/a
- INS-10101: The given response file string is not found.
Cause: The given response file is either not accessible or do not exist.
Action: Give a correct response file location. (Note: relative path is not supported)
- INS-10102: Installer initialization failed.
Cause: An unexpected error occured while initializing the Installer.
- INS-10103: Response file is not specified for this session.
Cause: Response file was not specified for this session. A silent session requires input from a response file or from the command line.
Action: Specify the response file and rerun the installer.
- INS-10104: The given response file is not accessible.
Cause: Current user may not have read permission.
Action: Ensure that the current user have permission to read the given response file.
- INS-10105: The given response file string is not valid.
Cause: Syntactically incorrect response file. Either unexpected variables are specified or expected variables are not specified in the response file.
Action: Refer the latest product specific response file template
- INS-10106: The format of the given response file is not supported.
Cause: The response file format was incorrect or not supported.
Action: Use response files of type string.
- INS-10107: Argument \"string\" is not supported for this session.
Cause: Argument \"string\" is specified for this session. This option is supported only in case of silent installation.
Action: Ensure that you have specified correct arguments to the installer.
- INS-10108: The given response file name is not valid.
Cause: It contains special characters.
Action: Specify the response file name which does not have special characters.
- INS-13001: Environment does not meet minimum requirements.
Cause: Minimum requirements were not met for this environment
Action: Either check the logs for more information or check the supported configurations for this product.
- INS-13010: Automatic prerequisite fix up is not supported
Action: Refer logs and fix up all prerequisites manually.
- INS-13011: No automatic prerequisite fix up routine available.
Cause: Automatic fix up is not supported, hence no fix up routine generated.
- INS-13012: Automatic prerequisite fix up is not performed or is incomplete.
Cause: User has either cancelled the operation or did not execute the automatic prerequisite fix up routines.
Action: Run the automatic fix up routines or refer logs and fix up all prerequisites manually.
- INS-13013: Target environment does not meet some mandatory requirements.
Cause: Some of the mandatory prerequisites are not met. See logs for details. string
Action: Identify the list of failed prerequisite checks from the log: string. Then either from the log file or from installation manual find the appropriate configuration to meet the prerequisites and fix it manually.
- INS-13014: Target environment does not meet some optional requirements.
Cause: Some of the optional prerequisites are not met. See logs for details. string
- INS-13015: The path string provided for cvu_prereq.xml is invalid.
Cause: The path string provided for cvu_prereq.xml is invalid.
Action: Provide a valid path of cvu_prereq.xml. It must be specified as an absolute pathname.
- INS-13016: You have chosen to ignore some of the prerequisites for this installation. This may impact product configuration.
Cause: You have chosen to ignore failed prerequisites and proceed with the installation.
Action: Ensure that the failed prerequistes are fixed before proceeding.
- INS-13017: Installer is unable to run the fixup script.
Cause: This might be because of the incorrect credentials provided for configuration script execution.
Action: Ensure that the correct credentials provided for configuration script execution. Also refer log files for more details.
- INS-13018: Installer is unable to run the fixup script.
Cause: An exception occurred while running the fixup script or during fixup script result collection.
Action: Refer log files for more details.
- INS-20701: Unexpected internal driver error
Cause: A call to internal Oracle cluster API failed.
Action: Refer to the logs or contact Oracle Support Services. Note for advanced users: Launch the installer by passing the following flag '-ignoreInternalDriverError'.
- INS-20702: Unexpected internal driver error
Cause: A call to cluster verification utility failed.
- INS-20801: Configuration Assistant 'string' failed.
Cause: Refer to the logs for additional information.
- INS-20802: string failed.
Cause: The plug-in failed in its perform method
- INS-20803: The optional tool named 'string' failed.
Action: Refer to the logs or contact Oracle Support Services. As 'string' is an optional tool, it is safe to ignore this failure and proceed with the installation.
- INS-20804: string aborted.
- INS-20805: string is not activated
- INS-20806: string not executed.
Cause: The plug-in was not executed or unavailable
- INS-20807: string is not valid.
Cause: The action of the specfied type could not be found in the referred aggregate
- INS-20808: Action already referenced.
Cause: The action was already referred to by a previous micro step
- INS-20809: Execution of 'string' not enabled
Cause: The invocation of plug-in string is not active
- INS-20810: Target or command for 'string' not valid.
Cause: The specified external command or internal plug-in could not be executed
- INS-20811: string parameters are not initialized
Cause: An argument of plug-in 'string' referenced an uninitialized Parameter
- INS-20812: Unexpected error while executing 'string'
Cause: An unspecified error occurred while attempting to perform the micro step.
- INS-20813: string not found
Cause: The referred aggregate could not be found
- INS-20814: The aggregate of 'string' is not activated
Cause: The reference to the referred aggregate is set inactive
- INS-21001: ORACLE_HOME was not specified for clone.
Cause: n/a
Action: n/a
- INS-21002: ORACLE_BASE was not specified for clone.
Cause: n/a
Action: n/a
- INS-21003: Installer has detected that an invalid inventory pointer location file was specified.
Cause: Installer has failed to detect the inventory group owner from the inventory pointer location file.
Action: Ensure the Inventory location file oraInst.loc is corrected or specify a valid Inventory Pointer Location file
