JMS-00400: Destination name must be specified
Cause:
A null Destination name was specified
Action:
Specify a non-null destination name
JMS-00402: Class not found: {0}
Cause:
The specified class was not found
Action:
Make sure your CLASSPATH contains the class
JMS-00403: IO Exception {0}
Cause:
IO exception
Action:
See message is AQxmlException for details
JMS-00404: XML Parse Exception
Cause:
An error occured in the XML Parser layer
Action:
See the message inside the linked AQxmlException for more information
JMS-00405: XML SAX Exception
Cause:
An error occured in the XML SAX layer
Action:
JMS-00406: JMS Exception {0}
Cause:
An error occured in the JMS layer
Action:
See the message inside the linked JMSException for more information
JMS-00407: Operation not allowed on {0}
Cause:
The specified operation is not allowed on this object
Action:
n/a
JMS-00408: Conversion failed - invalid property type
Cause:
An error occured while converting the property to the requested type
Action:
Use the method corresponding to the property data type to retrieve it
JMS-00409: No such element
Cause:
Element with specified name was not found in the map message
Action:
n/a
JMS-00410: XML SQL Exception
Cause:
An error occured in the JDBC SQL layer
Action:
See the message inside the linked SQLException for more information
JMS-00411: Payload body cannot be null
Cause:
An invalid body string or document was specified
Action:
Specify a non-null body string or document
JMS-00412: Byte conversion failed
Cause:
An invalid username/password was specified
Action:
Specify a non-null username and password
JMS-00413: Autocommit not allowed for operation
Cause:
The autocommit flag cannot be set for this operation
Action:
Do not set the autocommit flag
JMS-00414: Destination owner must be specified
Cause:
A null Destination owner was specified
Action:
JMS-00415: Invalid Visibility value
Cause:
Visibility value specified is invalid
Action:
Valid values are AQxmlConstants.VISIBILITY_ONCOMMIT, AQxmlConstants.VISIBILITY_IMMEDIATE
JMS-00416: Invalid Dequeue mode
Cause:
Invalid dequeue mode was specified
Action:
Valid Dequeue modes are AQxmlConstants.DEQUEUE_BROWSE, AQxmlConstants.DEQUEUE_REMOVE, AQxmlConstants.DEQUEUE_LOCKED, AQxmlConstants.DEQUEUE_REMOVE_NODATA
JMS-00417: Invalid Navigation mode
Cause:
An invalid navigation mode was specified
Action:
The valid navigation modes are AQxmlConstants.NAVIGATION_FIRST_MESSAGE, AQxmlConstants.NAVIGATION_NEXT_MESSAGE, AQxmlConstants.NAVIGATION_NEXT_TRANSACTION
JMS-00418: Invalid value for wait_time
Cause:
Invalid value for wait type
Action:
Wait time can be AQDequeueOption.WAIT_FOREVER, AQDequeueOption.WAIT_NONE or any value greater than 0
JMS-00419: invalid ConnectionPoolDataSource
Cause:
A null or invalid ConnectionPoolDataSource was specified
Action:
Specify a valid OracleConnectionPoolDataSource object with the correct url and user/password
JMS-00420: Invalid value for cache_size
Cause:
An invalid cache_size was specified
Action:
Cache size must be greater than 0
JMS-00421: Invalid value for cache_scheme
Cause:
An invalid cache scheme was specified
Action:
The valid cache schemes are OracleConnectionCacheImpl.DYNAMIC_SCHEME OracleConnectionCacheImpl.FIXED_WAIT_SCHEME
JMS-00422: Invalid tag - {0}
Cause:
An invalid tag was encountered in the XML document
Action:
Verify that the XML document conforms to the AQ schema
JMS-00423: Invalid value
Cause:
An invalid value was specified
Action:
Verify that the value specified in the XML document conforms to those specifid in the AQ schema
JMS-00424: Invalid message header
Cause:
The message header specified is null or invalid
Action:
Specify a valid message header
JMS-00425: Property name must be specified
Cause:
Property name was null
Action:
Specify a non-null property name
JMS-00426: Property does not exist
Cause:
Invalid property name specified. The property does not exist
Action:
JMS-00427: Subscriber name must be specified
Cause:
Subscriber name was null
Action:
Specify a non-null subscription name
JMS-00428: Valid message must be specified
Cause:
message was null
Action:
Specify a non-null message
JMS-00429: Register Option must be specified
Cause:
Register option is null
Action:
Specify a non-null Register Option
JMS-00430: Database Link must be specified
Cause:
DB Link is null
Action:
JMS-00431: Sequence Number must be specified
Cause:
Action:
JMS-00432: Status must be specified
Cause:
status option is null
Action:
JMS-00433: User not authenticated
Cause:
User is not authenticated
Action:
Specify an authenticated user
JMS-00434: Invalid data source
Cause:
Data source is null or invalid
Action:
Specify a valid data source
JMS-00435: Invalid schema location
Cause:
Schema location is null or invalid
Action:
Specify a valid URL for the schema
JMS-00436: AQ Exception
Cause:
An error occured in the AQ java layer
Action:
See the message inside the AQxmlException and the linked exception for more information
JMS-00437: Invalid Destination
Cause:
An invalid destination object was specified
Action:
Specify a valid destination (Queue/Topic) object
JMS-00438: AQ agent {0} not mapped to a valid database user
Cause:
The AQ agent specified does not map to a database user which has privileges to perform the requested operation
Action:
Use dbms_aqadm.enable_db_access to map the agent to a database user with the required queue privileges
JMS-00439: Invalid schema document
Cause:
The schema document specified is not valid
Action:
Specify a valid URL for the schema document
JMS-00440: Invalid operations - agent {0} maps to more than one database user
Cause:
The aq agent mapped to more than one database user in the the same session
Action:
Map the aq agent to only one database user Check the aq$internet_users view for database users that map to this agent
JMS-00441: {0} cannot be null
Cause:
The specified parameter was null
Action:
Specify a non-null value
JMS-00442: Name and Address for Agent cannot be null
Cause:
Both the name and address parameters were specified as null
Action:
Specify a non-null value for the name or address
JMS-00443: IMMEDIATE visibility mode not supported for this queue/topic
Cause:
IMMEDIATE visibility mode not supported for JMS type queue/topic
Action:
Use ON_COMMIT or the default visibility mode for JMS type queue/topic
JMS-00444: This feature is not supported yet
Cause:
The requested feature is not yet supported
Action:
wait for future releases that support the feature.
JMS-00445: Destination alias must be specified
Cause:
A null Destination alias was specified
Action:
Specify a non-null destination alias
JMS-00446: Agent alias must be specified
Cause:
A null Agent alias was specified
Action:
Specify a non-null agent alias
JMS-00447: error in accessing LDAP server
Cause:
error in accessing the LDAP server
Action:
check the LDAP server is up and the environment parameters provided to the servlet are correct
JMS-00448: Invalid Content-Type
Cause:
Action:
Content-Type must be "text/xml" or "application/x-www-form-urlencoded" with parameter name "aqxmldoc"
