KFNDG-00200: invalid syntax
Cause:
Invalid syntax for renamedg was specified.
Action:
Try renamedg -help for more information.
KFNDG-00201: invalid arguments
Cause:
Invalid key or value was specified for renamedg.
Action:
KFNDG-00202: invalid value (string) for parameter phase
Cause:
Incorrect value for parameter PHASE was specified.
Action:
Valid values for parameter PHASE are ONE, TWO, BOTH. Retry with correct values.
KFNDG-00203: disk group name (string) exceeds maximum allowed length number
Cause:
Invalid disk group name was specified.
Action:
Disk group name can be a maximum of 32 characters.
KFNDG-00204: disk group name string has invalid characters
Cause:
Action:
Disk group name can only contain alphabetic, numeric and the underscore (_) characters.
KFNDG-00205: failed to interpret configuration file name
Cause:
Invalid configuration file name was specified.
Action:
Verify configuration file name and folder permissions and retry renamedg.
KFNDG-00301: new disk group (string) already exists, ignorning renamedg
Cause:
disk group specified in NEWDGNAME already exists.
Action:
None
KFNDG-00302: disk (string:string) does not contain a valid header
Cause:
Device header could not be located or corrupt.
Action:
Verify if the device mentioned is an ASM disk device.
KFNDG-00303: failed to update disk group name for string
Cause:
Insufficient privileges or write error in disk.
Action:
Verify disk permissions and retry renamedg. Also, see log for additional information.
KFNDG-00304: unable to access heartbeat block of the device string:string
Cause:
Heartbeat block of the disk was corrupt.
Action:
Verify disk header with ASM utilities, retry renamedg.
KFNDG-00305: failed to create configuration file
Cause:
Insufficient privileges or invalid path.
Action:
Verify folder permissions and retry the command.
KFNDG-00306: unable to write to configuration file
Cause:
Insufficient privileges.
Action:
Check file permissions and retry renamedg.
KFNDG-00307: unable to read configuration file
Cause:
Insufficient privileges or disk read error.
Action:
KFNDG-00308: failed to process configuration file entry: string
Cause:
Configuration file was corrupt.
Action:
Check file information and retry renamedg.
KFNDG-00401: allocation unit size conflict (number, number)
Cause:
Allocation unit size of disk group and the disk did not match.
Action:
Verify that the device is not corrupt and retry renamedg.
KFNDG-00402: ASM metadata block size conflict (number, number)
Cause:
Metadata block size of the disk group and disk did not match.
Action:
Verify if the device is not corrupt and retry renamedg.
KFNDG-00403: not all disks of disk group string were discovered
Cause:
Offine disks were present in the specified disk group.
Action:
Refer to Oracle Database Storage Administator's Guide for more details.
KFNDG-00404: disk group string contains offline disks, ignoring renamedg
Cause:
Disk group with offline disks could not be renamed.
Action:
KFNDG-00405: specified disk group string appears to be mounted
Cause:
Disk group was mounted.
Action:
Unmount the disk group and retry renamedg.
KFNDG-00406: disk group (string) is in use by CSS
Cause:
Cluster Synchronization Service(CSS) was using the disk group to be renamed.
Action:
Refer to crsctl command to relocate voting disks from disk group.
KFNDG-00407: Could not find disks for disk group string
Cause:
No disks were discovered for disk group.
Action:
Try renamedg with a different discovery string.
KFNDG-00408: disk (string:string) could not be discovered
Cause:
Disk was either deleted or moved.
Action:
None
KFNDG-00409: disk (string) doesn't belong to disk group (string)
Cause:
Disk is not part of the specified disk group.
Action:
None
KFNDG-00410: failed to discover devices in folder string
Cause:
Insufficient privileges or invalid discovery string.
Action:
See log for additional details.
KFNDG-00600: internal error string
Cause:
An internal error occured while executing renamedg.
Action:
Contact Oracle Support Services.
KFNDG-00601: fatal error string
Cause:
A fatal error occurred while executing renamedg.
Action:
KFNDG-00603: failed to initialize device discovery
Cause:
Error occurred while communicating with generic services layer.
Action:
KFNDG-00700: system dependent error (number, string, string, string) occurred
Cause:
Internal system error occurred.
Action:
KFNDG-00701: Error number while performing I/O
Cause:
I/O failure.
Action:
