LCD-00100: internal error, argument [number]
Cause:
An internal error has occurred
Action:
Report it to your System Administrator immediately
LCD-00111: value not in legal range [string]
Cause:
The value of the parameter is outside bounds
Action:
Refer to the manual for the bounds on the parameter
LCD-00112: illegal integer radix specification [string]
Cause:
Self Explanatory
Action:
valid characters are 'd', 'h', 'D' and 'H'
LCD-00113: integer conversion error or negative integer [string]
Cause:
A bad or negative integer was assigned to an integer parameter
Action:
Self explanatory
LCD-00114: illegal boolean response [string]
Cause:
You a value than TRUE or FALSE to a boolean parameter
Action:
Boolean parameters only take TRUE or FALSE
LCD-00122: unrecognized keyword [string]
Cause:
You have misspelled the parameter name
Action:
Spell the parameter name correctly
LCD-00128: invalid positional parameter value [string]
Cause:
An invalid positional parameter value has been entered
Action:
Remove the invalid positional parameter
LCD-00161: ORACLE error (possible syntax error) parameter [string]
Cause:
Possible syntax error. Additional messages follow.
Action:
Correct the parameter in error.
LCD-00201: could not open specified filename [string]
Cause:
The file specified does not exist
Action:
Create an appropriate parameter file
LCD-00203: missing keyword [string]
Cause:
A keyword is expected but none was found
Action:
Add a keyword followed by an '=' sign and a parameter value
LCD-00204: left parenth and no parameter specified [string]
Cause:
A parameter list was started but no parameter was specified
Action:
Add an appropriate list of values and close the parameter list
LCD-00205: unbalanced parentheses [string]
Cause:
Self explanatory
Action:
Balance the parentheses
LCD-00206: positional parameter entered after keyword [string]
Cause:
An '=' sign is missing
Action:
All keywords must be followed by '=' signs
LCD-00207: nested parentheses encountered [string]
Cause:
Only one set of parentheses is permitted
Action:
Remove the nested parentheses
LCD-00208: unexpected keyword in value list [string]
Cause:
A keyword was found instead of a value
Action:
Insert an appropriate value for the given parameter
LCD-00209: missing value for keyword at end of string [string]
Cause:
A keyword is specified with no value
Action:
Specify a valid value for the keyword
LCD-00210: illegal assignment operator [string]
Cause:
You used a sign other than '=' to assign a keyword a value
Action:
Use only the '=' sign
LCD-00211: unexpected delimiter [string]
Cause:
An invalid delimiter was found between values
Action:
A comma or a space is a valid delimiter
LCD-00212: runaway quoted string [string]
Cause:
The parameter value was quoted on the left side but not on the right
Action:
Quote the parameter value on both sides
LCD-00215: parameter files nested too deep [string]
Cause:
Too many levels of indirection of file parameters. Maximum is 3.
Action:
Reduce the level of indirection to less than 3
LCD-00217: failure while processing file parameter [string]
Cause:
An error occurred while processing the specified file parameter
Action:
Specific details will appear in other messges
LCD-00218: error in file [string]
Cause:
An error occurred in the particular file.
Action:
Refer to the other messages for the specific error.
LCD-00219: nested include file [string] is too large
Cause:
There is a limit on the size of a parameter file, and it was exceeded. This limit is now 8192 bytes.
Action:
Remove characters from the file to make it smaller, or use another level of nesting.
