Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
52 NZE-43000 to NZE-43021
NZE-43000: pkcs11 library not found
Cause: The PKCS11 library could not be found.
Action: Make sure that the pkcs11 library is at the location specified in the wallet.
NZE-43001: pkcs11 token not found
Cause: The PKCS11 token could not be found.
Action: Make sure that a token with correct label is present in slot.
NZE-43002: pkcs11 passphrase is wrong
Cause: The PKCS11 passphrase is wrong.
Action: Make sure that the token passphrase specified is correct.
NZE-43005: pkcs11: No tokens present
Cause: a token is not present in the slot
Action: Place a pkcs11 token in the slot
NZE-43011: pkcs11: Token login failed
Cause: To login to the pkcs11 token a correct passphrase is needed
Action: Check the token passphrase.
NZE-43014: pkcs11: finding private key on token error
Cause: error occurred while finding private key on token
Action: Make sure the private key corresponding to the certificate in wallet is on the token. Check trace message
NZE-43015: pkcs11: key pair gen error
Cause: error occurred while generating key pair using HSM
Action: Check trace message
NZE-43017: pkcs11: No certificate found on the smart card/HSM
Cause: No certificate was found on the smart card/HSM.
Action: Follow smart card/HSM vendor documentation to populate the smart card/HSM with certificate.
NZE-43018: pkcs11: No user certificate found on the smart card/HSM
Cause: No user certificate was found on the smart card/HSM.
Action: Follow smart card/HSM vendor documentation to populate the smart card/HSM with certificate and private key.
NZE-43019: pkcs11: No certificate found on smart card/HSM label with given cert label
Cause: There were no certificate labels on the smart card/HSM that matched the certificate label specified in the wallet.
Action: Follow smart card/HSM vendor documentation to set certificate label in smart card/HSM.
NZE-43020: pkcs11: Multiple certificates found on smart card/HSM with given cert label
Cause: Certificates with identical labels were found in the smart card/HSM.
Action: Follow smart card/HSM vendor documentation to assign unique certificate labels to certificates.
NZE-43021: pkcs11: Certificate with given cert label is not a user cert
Cause: The certificate with the specified certificate label did not have a matching private key in the smart card/HSM.
Action: Follow smart card/HSM vendor instructions to create credentials (certificate/private key) in smart card/HSM.
