OKSK-00000: %2 %3
Cause:
Informational.
Action:
None
OKSK-00001: %2 %3
Cause:
Informational.
Action:
None
OKSK-00002: %2 %3
Cause:
Informational.
Action:
None
OKSK-00003: %2 %3
Cause:
Informational.
Action:
None
OKSK-00004: Module load succeeded. Build information: %2 %3 %4
Cause:
Informational.
Action:
None
OKSK-00005: Module failed to load and start with status %2. Build information: %3 %4 %5
Cause:
Informational.
Action:
None
OKSK-00006: Module unloaded.
Cause:
Informational.
Action:
None
OKSK-00007: Information has been saved in the file %2 . Include the contents of this file if reporting a problem to Oracle.
Cause:
Informational.
Action:
None
OKSK-00008: Cluster Membership Change starting - Incarnation %2.
Cause:
Informational.
Action:
None
OKSK-00009: Cluster Membership Change complete.
Cause:
Informational.
Action:
n/a
OKSK-00010: Persistent OKS log opened at %2.
Cause:
Informational.
Action:
None
OKSK-00011: Failed to allocate kernel memory for %2.
Cause:
Unable to allocate memory for a required function.
Action:
Contact Oracle Support Services.
OKSK-00012: Failed to open %2.
Cause:
Unable to open a persistent OKS log file. Likely an invalid file path was specified or there was an internal error.
Action:
Ensure that the file or directory exists else. If it does, contact Oracle Support Services.
OKSK-00013: Terminating Persistent OKS log.
Cause:
Persistent OKS logging terminated due to the previous message.
Action:
Informational.
OKSK-00014: Unable to generate an persistent OKS log file name.
Cause:
Failed to generate an persistent OKS log fime name.
Action:
Internal error.
OKSK-00015: Persistent log thread creation failed.
Cause:
Failed to create a kernel thread.
Action:
Internal error.
OKSK-00016: Configuration error: buffer size %2 bytes is out of range.
Cause:
The user selected an invalid buffer size.
Action:
Select a different buffer size.
OKSK-00017: Configuration error: interval timer of %2 ms is out of range.
Cause:
The user selected an invalid timer interval.
Action:
Select a different timer value.
OKSK-00018: Configuration error: low water level of %2 bytes isout of range.
Cause:
The user selected an invalid low water value.
Action:
Select a different low water value.
OKSK-00019: Configuration error: high water level of %2 bytes is out of range.
Cause:
The user selected an invalid high water value.
Action:
Select a different high water value.
OKSK-00020: Configuration error: maximum number of log files (%2) is out of range.
Cause:
The user selected an invalid maximum file number value.
Action:
Select a different file number value.
OKSK-00021: Configuration error: The maximum file size of %2 bytes is out of range.
Cause:
The user selected an invalid maximum log file size value.
Action:
Select a different maximum log file size value.
OKSK-00022: File write error: File name 'string'.
Cause:
A write to the persistent OKS log file failed - possibly due to a full file system. Otherwise, it is an internal error. The in-memory OKS log will contain details regarding the error.
Action:
Free up file systems space and restart the OKS persistent log ('acfsutil plogconfig -d dir'). If freeing up file system space does not resolve the problem, contact Oracle Support Services.
OKSK-00023: Cluster membership node list:
Cause:
Informational.
Action:
None
OKSK-00024: Node %2 (Interconnect address: %3.%4.%5.%6)
Cause:
Informational.
Action:
None
OKSK-00025: Cluster membership node count: %2, Local Node Number: %3.
Cause:
Informational.
Action:
None
OKSK-00026: Cluster membership rebuild manager failed to initialize.
Cause:
Informational.
Action:
Contact Oracle Support.
OKSK-00027: Oracle kernel distributed lock manager hash size is %2
Cause:
Informational.
Action:
None
OKSK-00028: In memory kernel log buffer address: %2, size: %3
Cause:
Informational.
Action:
None
OKSK-00029: Unable to %2 the log buffer.
Cause:
Informational.
Action:
None
