ORA-12400: invalid argument to facility error handling
Cause:
An argument to a facility error handling function exceeded a maximum limit or referred to an invalid product/facility.
Action:
Specify a valid facility error handling parameter value.
ORA-12401: invalid label string: string
Cause:
The policy could not convert the label string to a valid internal label.
Action:
Correct the syntax of the label string.
ORA-12402: invalid format string: string
Cause:
The format string is not supported by the policy.
Action:
Correct the syntax of the format string.
ORA-12403: invalid internal label
Cause:
An internal label could not be converted to a valid label for the policy.
Action:
Analyze any additional messages on the error stack and consult the policy documentation.
ORA-12404: invalid privilege string: string
Cause:
The policy could not interpret the privilege string.
Action:
Specify a privilege string that is supported by the policy.
ORA-12405: invalid label list
Cause:
The policy determined that the label list was invalid for its intended use.
Action:
Check the policy constraints on the specific list of labels.
ORA-12406: unauthorized SQL statement for policy string
Cause:
The policy did not authorize the database session to perform the requested SQL statement.
Action:
Grant the user or program unit the necessary policy privilege or additional authorizations.
ORA-12407: unauthorized operation for policy string
Cause:
The policy did not authorize the database session to perform the requested operation.
Action:
ORA-12408: unsupported operation: string
Cause:
The specified policy does not support the requested operation.
Action:
Consult the policy documentation to determine the supported access mediation operations.
ORA-12409: policy startup failure for string policy
Cause:
The policy encountered an error during startup processing; access to the data protected by the policy is prohibited.
Action:
Check the alert log for additional information, correct the policy error, and restart the instance.
ORA-12410: internal policy error for policy: string\n Error: string
Cause:
The policy enforcement encountered an internal error.
Action:
Consult the policy documentation for details.
ORA-12411: invalid label value
Cause:
The specified label value does not exist.
Action:
Check the data dictionary views for the policy to identify valid labels.
ORA-12412: policy package string is not installed
Cause:
The policy package does not exist in the database.
Action:
Check that the policy package name is correct or install the required policy package.
ORA-12413: labels do not belong to the same policy
Cause:
The labels being compared belong to different policies.
Action:
Only compare labels that belong to the same policy.
ORA-12414: internal LBAC error: string\n Error: string
Cause:
An internal label policy framework error occurred.
Action:
Contact Oracle Customer Support.
ORA-12415: A column of another datatype exists on the specified table
Cause:
The datatype of the column present in the table is different from the datatype set for the policy column.
Action:
Drop the column on the table or change the datatype for policy column.
ORA-12416: policy string not found
Cause:
The specified policy does not exist in the database.
Action:
Enter the correct policy name or create the policy.
ORA-12417: database object "string" not found
Cause:
The specified object was not in the database.
Action:
Enter the correct name for the database object.
ORA-12418: user string not found
Cause:
The specified user does not exist in the database.
Action:
Correct the user name or create the user.
ORA-12419: null binary label value
Cause:
A null value was provided for a binary label operation.
Action:
Provide a valid binary label for the operation.
ORA-12420: required procedures and functions not in policy package "string"
Cause:
The policy package did not contain all of the procedures and functions necessary to enforce the policy.
Action:
Consult the label framework documentation for a list of required procedures and functions for a policy package.
ORA-12421: different size binary labels
Cause:
The label sizes for the binary label operation were not equal.
Action:
Provide binary labels with the same lengths for the operation.
ORA-12422: max policies exceeded
Cause:
You tried to create a new policy, but the maximum number of policies for the instance had already been created.
Action:
Increase the size of the MAX_LABEL_POLICIES initialization parameter and restart the server.
ORA-12423: invalid position specified
Cause:
The position specified for a binary label operation was invalid.
Action:
Provide a position that is within the label size limits.
ORA-12424: length exceeds binary label size
Cause:
The length specified for a binary label operation exceeded the the size of the binary label.
Action:
Provide a bit or byte length that is within the label size limits.
ORA-12425: cannot apply policies or set authorizations for system schemas
Cause:
You tried to either apply a policy to the SYS, SYSTEM, or LBACSYS schema or to set user labels/privileges for the SYS, SYSTEM, or LBACSYS user.
Action:
Apply policies and set authorizations only for non-system users.
ORA-12426: invalid audit option
Cause:
The option specified was not a valid audit option for the specified policy.
Action:
Enter a correct audit option.
ORA-12427: invalid input value for string parameter
Cause:
An input parameter was specified incorrectly.
Action:
Correct the parameter value.
ORA-12428:
ORA-12429: label list range exceeded
Cause:
The specified index value was not between 1 and 6.
Action:
Correct the index value for the label list operation.
ORA-12430: invalid privilege number
Cause:
The specified privilege number was not between 1 and 32.
Action:
Correct the privilege number.
ORA-12431: invalid audit action
Cause:
The specified audit action was not a valid audit action.
Action:
Correct the audit action number.
ORA-12432: LBAC error: string
Cause:
LBAC enforcement resulted in an error.
Action:
Correct the problem identified in the error message.
ORA-12433: create trigger failed, policy not applied
Cause:
The policy could not be applied due to errors during the creation of a DML trigger.
Action:
Correct the SQL syntax of the label function specification.
ORA-12434: invalid audit type: string
Cause:
The audit type must be BY ACCESS or BY SESSION.
Action:
Correct the audit type value.
ORA-12435: invalid audit success: string
Cause:
The audit success parameter must be SUCCESSFUL or NOT SUCCESSFUL.
Action:
Correct the audit success value.
ORA-12436: no policy options specified
Cause:
A NULL option string was specified, but no default schema or policy option string was found.
Action:
Enter a valid option string, or alter the schema or policy to have a valid default option string.
ORA-12437: invalid policy option: string
Cause:
A value that was not a valid policy option was entered.
Action:
Correct the policy option value.
ORA-12438: repeated policy option: string
Cause:
A policy option was entered more than once in the option string.
Action:
Remove the duplicate policy option value.
ORA-12439: invalid combination of policy options
Cause:
A set of contradictory policy options was entered.
Action:
Provide a set of compatible policy options.
ORA-12440: insufficient authorization for the SYSDBA package
Cause:
The use of the SYSDBA package requires the LBAC_DBA role.
Action:
Grant the LBAC_DBA role to the database user.
ORA-12441: policy string already exists
Cause:
You tried to create a policy with the same name as an existing one.
Action:
Use a different name or drop the existing policy.
ORA-12442: policy column "string" already used by an existing policy
Cause:
You tried to create a policy with the same policy column name as an existing policy.
Action:
Use a different name for the policy column or drop the existing policy.
ORA-12443: policy not applied to some tables in schema
Cause:
You applied a policy to a schema, and some of the tables in the schema already had the policy applied.
Action:
No action necessary; the policy was applied to the remaining tables.
ORA-12444: policy already applied to table
Cause:
You tried to apply a policy to a table that was already protected by the policy.
Action:
To change the policy options, predicate, or label function, remove the policy from the table and re-apply it.
ORA-12445: cannot change HIDDEN property of column
Cause:
You tried to specify a different HIDE option for a table with an existing policy column.
Action:
Drop the column from the table and reapply the policy with the new HIDE option.
ORA-12446: Insufficient authorization for administration of policy string
Cause:
You tried to perform an administrative function for a policy, but you have not been granted the policy_DBA role.
Action:
Grant the user the policy_DBA role for the specified policy.
ORA-12447: policy role already exists for policy string
Cause:
The role named policy_DBA already exists.
Action:
Correct the policy name or delete the existing policy.
ORA-12448: policy string not applied to schema string
Cause:
You tried to alter a schema policy that was not applied.
Action:
Correct the policy name or schema name.
ORA-12449: Labels specified for user must be of type USER
Cause:
You tried to set labels for a user, but the labels in the list were not all designated as USER labels.
Action:
Alter the labels to be USER labels.
ORA-12450: LOB datatype disabled in LBAC initialization file
Cause:
You tried to specify a LOB datatype for a column or attribute, but the use of the LOB datatype has been disabled.
Action:
Change the LBAC initialization file to allow the creation of LOB columns and attributes.
ORA-12451: label not designated as USER or DATA
Cause:
A label is either a DATA label, a USER label, or both DATA and USER.
Action:
Enter TRUE for at least DATA or USER.
ORA-12452: label tag string already exists
Cause:
The label tag value you entered is already in use for another label.
Action:
Enter a different value for the label tag.
ORA-12453: label string already exists
Cause:
The label value you entered already exists.
Action:
No action necessary; alter the label to change its tag or type.
ORA-12454: label string does not exist for policy string
Cause:
The label tag or value you entered did not identify a label for the policy.
Action:
Enter a label value or tag that is in use by the policy.
ORA-12455: internal error in Label Security MMON cleanup task
Cause:
An internal error occurred in the Label Security MMON cleanup task.
Action:
ORA-12456: label security startup in progress
Cause:
You attempted to connect to the database before the Oracle Label Security component was fully initialized.
Action:
Wait until the database is fully open before attempting to connect.
ORA-12457: security label exceeded maximum allowable length
Cause:
An operation attempted to materialize a security label greater than 4000 bytes in length.
Action:
Consult the Oracle Label Security documentation for information on how the length of a security label is calculated. Re-submit the operation once the problem has been corrected.
ORA-12458: Oracle Label Security not enabled
Cause:
A Label Security operation was attempted without enabling Oracle Label Security.
Action:
Consult the Oracle Label Security documentation for information on how to enable Oracle Label Security.
ORA-12459: Oracle Label Security not configured
Cause:
An administrative operation was attempted without configuring Oracle Label Security.
Action:
Consult the Oracle Label Security documentation for information on how to configure Oracle Label Security.
ORA-12460: cannot disable Oracle Label Security when Database Vault is enabled
Cause:
An attempt was made to disable Oracle Label Security when Database Vault was enabled.
Action:
Disable Database Vault and bounce the database before attempting to disable Oracle Label Security.
ORA-12461: undefined level string for policy string
Cause:
The specified level is not defined for the policy.
Action:
Correct the level identifier value.
ORA-12462: undefined compartment string for policy string
Cause:
The specified compartment is not defined for the policy.
Action:
Correct the compartment identifier value.
ORA-12463: undefined group string for policy string
Cause:
The specified group is not defined for the policy.
Action:
Correct the group identifier value.
ORA-12464: invalid characters in label component string
Cause:
Label components can contain only alphanumeric characters, blanks, and underscores.
Action:
Correct syntax of the label component.
ORA-12465: not authorized for read or write on specified groups or compartments
Cause:
Groups or compartments were included that were not in the user's list of groups and compartments authorized for read or write access.
Action:
Include groups or compartments authorized for read or write access in the user's list of groups and compartments.
ORA-12466: default level is greater than the user's maximum
Cause:
The default level cannot be greater than the user's maximum.
Action:
Enter an authorized level.
ORA-12467: minimum label can contain a level only
Cause:
You included compartments or groups in the minimum label.
Action:
Enter only an authorized minimum level as the label.
ORA-12468: max write level does not equal max read level
Cause:
The level in the max write label must equal the level in the max read label.
Action:
Enter max read and max write labels with the same level component.
ORA-12469: no user levels found for user string and policy string
Cause:
No levels have been specified for the user.
Action:
Enter the maximum and minimum labels for the user.
ORA-12470: NULL or invalid user label: string
Cause:
The label entered is NULL or not within the user's authorizations.
Action:
Enter the authorized labels for the user.
ORA-12471: Specified compartment or group is not authorized for user
Cause:
The specified compartment or group is not in user's authorizations or the user does not have read on compartment or group specified for write.
Action:
Enter an authorized compartment or group.
ORA-12472: policy string is being used
Cause:
The policy which was being dropped due to event propagation from OID was applied to some table or schema.
Action:
Drop a policy in OID only if it is not used in any of the databases using the policy.
ORA-12473: The procedure is disabled when Label Security is used with OID.
Cause:
Using Label Security with OID disabled this procedure.
Action:
Do not use OID with Label Security if this procedure is required to function.
ORA-12474: cannot change column name for a policy in use
Cause:
An attempt was made to change a column name for a policy that was applied on user schemas or tables.
Action:
Disable the policy for all user schemas and tables before changing the column name.
ORA-12475: incompatible Oracle Label Security configuration
Cause:
An attempt was made to configure Oracle Label Security with OID in a pluggable database when Oracle Label Security without OID is configured in another pluggable database or vice-versa.
Action:
Use similar configurations of Oracle Label Security in all pluggable databases.
ORA-12476: least upper bound resulted in an invalid OS label
Cause:
You tried to do an operation that generated a least upper bound (LUB) label which is not a valid label on your operating system.
Action:
Consult your OS label management documentation for information on invalid label generation.
ORA-12477: greatest lower bound resulted in an invalid OS label
Cause:
You tried to do an operation that generated a greatest lower bound (GLB) label which is not a valid label on your operating system.
Action:
ORA-12479: file label string must equal DBHIGH string
Cause:
A database file had an OS label that did not match DBHIGH. Either DBHIGH was altered or the OS file was relabeled.
Action:
Relabel the file so that its label matches DBHIGH, or alter DBHIGH so that it matches the label on the file.
ORA-12480: specified clearance labels not within the effective clearance
Cause:
You specified a clearance range that was not within your authorized clearance; you can only specify clearance ranges that are within your clearance.
Action:
Specify clearance labels that are within your own clearance range.
ORA-12481: effective label not within program unit clearance range
Cause:
The effective label when the program unit was invoked was not within the range authorized for the program unit.
Action:
Modify the program unit clearance range or invoke the program unit from a session with an authorized effective clearance.
ORA-12482: internal MLS error: string\n Error: string
Cause:
An internal MLS policy error occurred.
Action:
ORA-12483: label not in OS system accreditation range
Cause:
The specified label is above the OS maximum label or below the OS minimum label.
Action:
Use a label that is within the accreditation range for the host OS.
ORA-12484: invalid OS label
Cause:
The specified label does not exist in the OS host's label definition file.
Action:
Use the OS label management tools to define the label.
ORA-12485: new effective label not within effective clearance
Cause:
You attempted to enter a value for an effective label that did not dominate the effective min label or was not dominated by the effective max label.
Action:
Enter a value between the min and the max labels.
ORA-12486: effective max labels and min labels cannot be changed
Cause:
You attempted to enter a value for an effective min label or effective max label, but these labels cannot be changed.
Action:
Enter NULL values for the effective minimum and maximum labels.
ORA-12487: clearance labels not between DBHIGH and DBLOW
Cause:
You attempted to enter a value for a clearance label that was not dominated by DBHIGH or did not dominate DBLOW.
Action:
Enter clearance label values between DBHIGH and DBLOW.
ORA-12488: maximum label does not dominate minimum label
Cause:
You attempted to enter a value for a clearance label that did not preserve the dominance relationship between the minimum and maximum labels.
Action:
Enter label values that preserves the dominance relationship between the minimum and maximum.
ORA-12489: default label not within clearance range
Cause:
You attempted to enter a value for a default label that did not dominate the minimum clearance or was not dominated by the maximum clearance.
Action:
Enter a default label value within the clearance range.
ORA-12490: DBHIGH cannot be lowered
Cause:
You attempted to enter a value for DBHIGH that did not dominate the existing value of DBHIGH.
Action:
Enter a value for DBHIGH that dominates the old value.
ORA-12491: DBHIGH value does not dominate DBLOW
Cause:
You attempted to enter a value for DBHIGH that did not dominate DBLOW.
Action:
Enter a value for DBHIGH that dominates DBLOW.
ORA-12492: DBLOW cannot be changed
Cause:
You attempted to change the value of DBLOW after it had been set to any initial value. DBLOW can only be set once after initial database creation.
Action:
To change DBLOW, you have to create a new database, set DBLOW to the new value, and import your data into the new database.
ORA-12493: invalid MLS binary label
Cause:
The MLS binary label contained an invalid value, was not the correct size, or contained a level, category, or release category that was not enabled.
Action:
Check the DBA_MLS_LABELS view for the valid MLS labels.
ORA-12494: cannot insert or delete a level, category, or release category
Cause:
You attempted to insert or delete a level, category, or release category definition.
Action:
If the label definition is no longer valid, change its name to one that identifies it as invalid. When any labels are converted to character strings, the new label definition will be used.
ORA-12495: cannot disable an enabled level, category, or release category
Cause:
You attempted to disable a level, category, or release category that had previously been enabled. An enabled label definition may be exist in some database label, so cannot be disabled.
Action:
ORA-12496: cannot change existing level, category, or release numbers
Cause:
You attempted to change the number assigned to level, category or releasability category.
Action:
Change the character string representations, not the numbers.
ORA-12497: maximum combined categories exceeds string
Cause:
The maximum number of descriptive categories plus release categories supported by the MLS policy was exceeded.
Action:
Enter numbers that do not add up to more than the maximum.
ORA-12498:
