ORA-12700: invalid NLS parameter value (string)
Cause:
An invalid or unknown NLS configuration parameter was specified.
Action:
n/a
ORA-12701: CREATE DATABASE character set is not known
Cause:
The character set specified when creating the database is unknown.
Action:
n/a
ORA-12702: invalid NLS parameter string used in SQL function
Cause:
An unknown parameter name or invalid value is specified in a NLS parameter string.
Action:
n/a
ORA-12703: this character set conversion is not supported
Cause:
The requested conversion between two character sets in the CONVERT function is not implemented
Action:
n/a
ORA-12704: character set mismatch
Cause:
One of the following:
- The string operands(other than an nlsparams argument) to an operator or built-in function do not have the same character set.
- An nlsparams operand is not in the database character set.
- String data with character set other than the database character set is passed to a built-in function not expecting it.
- The second argument to CHR() or CSCONVERT() is not CHAR_CS or NCHAR_CS.
- A string expression in the VALUES clause of an INSERT statement, or the SET clause of an UPDATE statement, does not have the same character set as the column into which the value would be inserted.
- A value provided in a DEFAULT clause when creating a table does not have the same character set as declared for the column.
- An argument to a PL/SQL function does not conform to the character set requirements of the corresponding parameter.
Action:
n/a
ORA-12705: Cannot access NLS data files or invalid environment specified
Cause:
Either an attempt was made to issue an ALTER SESSION command with an invalid NLS parameter or value; or the environment variable(s) NLS_LANG, ORA_NLSxx, or ORACLE_HOME was incorrectly specified, therefore the NLS data files cannot be located.
Action:
Check the syntax of the ALTER SESSION command and the NLS parameter, correct the syntax and retry the statement, or specify the correct directory path/values in the environment variables.
ORA-12706: this CREATE DATABASE character set is not allowed
Cause:
It is not allowed to create a database on a native ASCII-based machine using an EBCDIC-based character set, and vice versa.
Action:
n/a
ORA-12707: error while getting create database NLS parameter string
Cause:
Internal error
Action:
n/a
ORA-12708: error while loading create database NLS parameter string
Cause:
Internal error
Action:
n/a
ORA-12709: error while loading create database character set
Cause:
Internal error
Action:
n/a
ORA-12710: CREATE CONTROLFILE character set is not known
Cause:
The character set specified when creating the control file is unknown.
Action:
n/a
ORA-12711: this CREATE CONTROLFILE character set is not allowed
Cause:
It is not allowed to create a control file on a native ASCII-based machine using an EBCDIC-based character set, and vice versa.
Action:
n/a
ORA-12712: new character set must be a superset of old character set
Cause:
When you ALTER DATABASE ... CHARACTER SET, the new character set must be a superset of the old character set. For example, WE8ISO8859P1 is not a superset of the WE8DEC.
Action:
Specify a superset character set.
ORA-12713: Character data loss in NCHAR/CHAR conversion
Cause:
When character set conversion happens between CHAR and NCHAR either implicitly or explicitly, some characters are lost due to no mapping characters in the destination character set.
Action:
Make sure all the characters can be mapped to destination character set or set NLS_NCHAR_CONV_EXCP to be FALSE.
ORA-12714: invalid national character set specified
Cause:
Only UTF8 and AL16UTF16 are allowed to be used as the national character set
Action:
Ensure that the specified national character set is valid
ORA-12715: invalid character set specified
Cause:
The character set specified is not allowed for this operation or is invalid
Action:
Ensure that the specified character set is valid
ORA-12716: Cannot ALTER DATABASE CHARACTER SET when CLOB data exists
Cause:
CLOB data changes representation to Unicode when converting to a multibyte character set and must be migrated
Action:
Remove CLOB data as listed in the alert file. CLOB data can be migrated by methods such as import/export
ORA-12717: Cannot issue ALTER DATABASE NATIONAL CHARACTER SET when NCLOB, NCHAR or NVARCHAR2 data exists
Cause:
NCLOB, NCHAR or NVARCHAR2 data changed the representation to Unicode when converting to a multibyte character set and must be migrated.
Action:
Remove NCLOB, NCHAR or NVARCHAR2 data as listed in the alert file. The above type data can be migrated by methods such as import/export.
ORA-12718: operation requires connection as SYS
Cause:
This command can only be run when connecting as SYS
Action:
Connect as SYS to run this command
ORA-12719: operation requires database is in RESTRICTED mode
Cause:
This command can only be run when the database is in RESTRICTED mode
Action:
Ensure that the system is in RESTRICTED mode
ORA-12720: operation requires database is in EXCLUSIVE mode
Cause:
This command can only be run when the database is in EXCLUSIVE mode
Action:
Ensure that the system is in EXCLUSIVE mode
ORA-12721: operation cannot execute when other sessions are active
Cause:
This command can only be run when there are no other sessions active
Action:
Ensure there are no other connections to the database
ORA-12722: regular expression internal error
Cause:
A regular expression internal error occurred.
Action:
This is an internal error. Contact Oracle Support Services.
ORA-12723: regular expression too complex
Cause:
The regular expression was too complex and could not be parsed.
Action:
ORA-12724: regular expression corrupt
Cause:
The regular expression contained an incorrect sequence of metacharacters.
Action:
Ensure the metacharacters are correctly positioned.
ORA-12725: unmatched parentheses in regular expression
Cause:
The regular expression did not have balanced parentheses.
Action:
Ensure the parentheses are correctly balanced.
ORA-12726: unmatched bracket in regular expression
Cause:
The regular expression did not have balanced brackets.
Action:
Ensure the brackets are correctly balanced.
ORA-12727: invalid back reference in regular expression
Cause:
A back references was found before a sub-expression.
Action:
Ensure a valid sub-expression is being referenced.
ORA-12728: invalid range in regular expression
Cause:
An invalid range was found in the regular expression.
Action:
Ensure a valid range is being used.
ORA-12729: invalid character class in regular expression
Cause:
An unknown character class was found in the regular expression.
Action:
Ensure a valid characters class is being used.
ORA-12730: invalid equivalence class in regular expression
Cause:
An unknown equivalence class was found in the regular expression.
Action:
Ensure a valid equivalence class is being used.
ORA-12731: invalid collation class in regular expression
Cause:
An unknown collation class was found in the regular expression.
Action:
Ensure a valid collation class is being used.
ORA-12732: invalid interval value in regular expression
Cause:
An invalid interval value was found in the regular expression.
Action:
Ensure a valid interval value is being used.
ORA-12733: regular expression too long
Cause:
The operation failed because the regular expression it used exceeds the maximum supported size.
Action:
Use a shorter regular expression.
ORA-12734: Instant Client Light: unsupported client national character set string
Cause:
Only UTF8 and AL16UTF16 are allowed to be used as the national character set. Instant Client Light has only minimal character sets.
Action:
Do not use Instant Client Light for this character set
ORA-12735: Instant Client Light: unsupported client character set string
Cause:
The character set specified is not allowed for this operation or is invalid. Instant Client Light has only minimal character sets.
Action:
ORA-12736: Instant Client Light: unsupported server national character set string
Cause:
Action:
ORA-12737: Instant Client Light: unsupported server character set string
Cause:
Action:
ORA-12738: Express Instant Client: unsupported client national character set string
Cause:
Only UTF8 and AL16UTF16 are allowed to be used as the national character set. Instant Client has only minimal character sets.
Action:
Do not use Express Instant Client for this character set
ORA-12739: Express Instant Client: unsupported client character set string
Cause:
The character set specified is not allowed for this operation or is invalid. Express Instant Client has only minimal character sets.
Action:
ORA-12740: Express Instant Client: unsupported server national character set string
Cause:
Action:
ORA-12741: Express Instant Client: unsupported server character set string
Cause:
Action:
Do not use Express Instant Light for this character set
ORA-12742: unable to create the collation key
Cause:
The character argument of a collation-sensitive operator was too long or it had too many decomposable characters to create a collation key for it in the available buffer space.
Action:
Shorten the argument value or, if using a UCA-based collation, increase the ratio of characters with short or no Unicode decomposition to characters with long Unicode decomposition in the value.
ORA-12743: internal LX error code, arguments: [string], [string], [string]
Cause:
This is an internal error in a globalization support function.
Action:
ORA-12744: Character set string is not allowed as a database character set.
Cause:
An attempt was made to create or alter a database using a client-only or conversion-only character set.
Action:
Specify a supported database character set.
ORA-12752: An instance-critical process has terminated.
Cause:
An unexpected error was encountered by an instance-critical process.
Action:
ORA-12753: The Oracle home user ID does not match the effective user ID of the local client which connected to the Oracle instance.
Cause:
The user ID that is the owner of the Oracle home directory was not the same as the effective user ID of the local client that connected to the Oracle instance.
Action:
Run the local client that connects to Oracle instance with the same user ID as the owner of the Oracle home.
ORA-12800: system appears too busy for parallel query execution
Cause:
load on system is too high to perform parallel queries.
Action:
re-execute serially or wait until system load is reduced.
ORA-12801: error signaled in parallel query server string
Cause:
A parallel query server reached an exception condition.
Action:
Check the following error message for the cause, and consult your error manual for the appropriate action.
ORA-12802: parallel query server lost contact with coordinator
Cause:
A parallel query server lost contact with the foreground (coordinator) process/thread.
Action:
Check your system for anomalies and reissue the statement. If this error persists, contact Oracle Support Services.
ORA-12803: parallel query server lost contact with another server
Cause:
A parallel query server lost contact with another server.
Action:
ORA-12804: parallel query server appears to have died
Cause:
Cannot find process information for a parallel query server thread.
Action:
ORA-12805: parallel query server died unexpectedly
Cause:
A parallel query server died unexpectedly, PMON cleaning up the process.
Action:
Check your system for anomalies and reissue the statement. If this error persists, contact Oracle Support Services. See trace file for more details.
ORA-12806: could not get background process to hold enqueue
Cause:
Internal error.
Action:
This error should not normally occur. If it persists, contact Oracle Support Services.
ORA-12807: process queue could not receive parallel query message
Cause:
Internal error.
Action:
ORA-12808: cannot set string_INSTANCES greater than number of instances string
Cause:
An attempt was made to set SCAN_INSTANCES or CACHE_INSTANCES using the ALTER SYSTEM command to a value larger than the number of available instances.
Action:
See the accompanying message for the current allowable maximum value, or set SCAN_INSTANCES / CACHE_INSTANCES to ALL.
ORA-12809: cannot set string_INSTANCES when mounted in exclusive mode
Cause:
An attempt was made to set SCAN_INSTANCES or CACHE_INSTANCES using the ALTER SYSTEM command while the database was mounted in exclusive mode.
Action:
SCAN_INSTANCES / CACHE_INSTANCES may not be set unless running Oracle Real Application Clusters mounted in CLUSTER_DATABASE mode.
ORA-12810: PARALLEL_MAX_SERVERS must be less than or equal to string
Cause:
An attempt was made to set the PARALLEL_MAX_SERVERS parameter to a value higher than the maximum allowed by the system.
Action:
Set PARALLEL_MAX_SERVERS to a value less than or equal to the maximum specified in the accompanying message and retry.
ORA-12811: PARALLEL_MIN_SERVERS must be less than or equal to PARALLEL_MAX_SERVERS, string
Cause:
An attempt was made to set the PARALLEL_MIN_SERVERS parameter to a value higher than PARALLEL_MAX_SERVERS.
Action:
Set PARALLEL_MIN_SERVERS to a value less than or equal to PARALLEL_MAX_SERVERS (indicated in the accompanying message) and retry.
ORA-12812: only one PARALLEL or NOPARALLEL clause may be specified
Cause:
PARALLEL was specified more than once, NOPARALLEL was specified more than once, or both PARALLEL and NOPARALLEL were specified in a CREATE TABLE, CLUSTER, or INDEX or in an ALTER TABLE or CLUSTER statement, or in a RECOVER command.
Action:
Remove all but one of the PARALLEL or NOPARALLEL clauses and reissue the statement.
ORA-12813: value for PARALLEL or DEGREE must be greater than 0
Cause:
PARALLEL 0 or DEGREE 0 was specified in a CREATE TABLE, CLUSTER, or INDEX or in an ALTER TABLE or CLUSTER statement.
Action:
Specify a degree of parallelism greater than 0 or specify default parallelism using PARALLEL with no degree or using DEGREE DEFAULT within a PARALLEL clause.
ORA-12814: only one CACHE or NOCACHE clause may be specified
Cause:
CACHE was specified more than once, NOCACHE was specified more than once, or both CACHE and NOCACHE were specified in a CREATE TABLE or CLUSTER, or in an ALTER TABLE or CLUSTER statement.
Action:
Remove all but one of the CACHE or NOCACHE clauses and reissue the statement.
ORA-12815: value for INSTANCES must be greater than 0
Cause:
PARALLEL parameter specifying number of instances must be a positive integer or DEFAULT
Action:
specify a positive integer or DEFAULT for INSTANCES if parallelism across instances is desired.
ORA-12816: parallel create index fastpath operation
ORA-12817: parallel query option must be enabled
Cause:
A parallel query option feature has been invoked but this option has not been enabled.
Action:
Enable the parallel query option.
ORA-12818: invalid option in PARALLEL clause
Cause:
an unrecognized option was used within a PARALLEL clause.
Action:
specify any combination of DEGREE { n | DEFAULT } and INSTANCES { n | DEFAULT } within the PARALLEL clause.
ORA-12819: missing options in PARALLEL clause
Cause:
PARALLEL clause cannot be empty.
Action:
ORA-12820: invalid value for DEGREE
Cause:
invalid value for DEGREE was specified within a PARALLEL clause.
Action:
specify a positive integer or DEFAULT for the DEGREE option within a PARALLEL clause.
ORA-12821: invalid value for INSTANCES
Cause:
invalid value for INSTANCES was specified within a PARALLEL clause.
Action:
specify a positive integer or DEFAULT for the INSTANCES option within a PARALLEL clause.
ORA-12822: duplicate option in PARALLEL clause
Cause:
DEGREE or INSTANCES was specified more than once within a PARALLEL clause.
Action:
specify each desired PARALLEL clause option only once.
ORA-12823: default degree of parallelism may not be specified here
Cause:
the PARALLEL keyword was used alone or DEGREE DEFAULT was specified in the PARALLEL clause of an ALTER DATABASE RECOVER command.
Action:
respecify with an explicit degree of parallelism.
ORA-12824: INSTANCES DEFAULT may not be specified here
Cause:
INSTANCES DEFAULT was specified in the PARALLEL clause of an ALTER DATABASE RECOVER command
Action:
respecify with an explicit value for INSTANCES or omit the INSTANCES option if single instance recovery is desired.
ORA-12825: explicit degree of parallelism must be specified here
Cause:
the DEGREE option was omitted from an ALTER DATABASE RECOVER command.
Action:
ORA-12826: hung parallel query server was killed
Cause:
parallel query server was hung and subsequently killed.
Action:
re-execute query and report suspicious events in trace file to Oracle Support Services if error persists.
ORA-12827: insufficient parallel query slaves (requested string, available string, parallel_min_percent string)
Cause:
PARALLEL_MIN_PERCENT parameter was specified and fewer than the minimum number of slaves were acquired
Action:
Either reexecute the query with a lower PARALLEL_MIN_PERCENT or wait until some running queries are completed, thus freeing up slaves
ORA-12828: Can't start parallel transaction at a remote site
Cause:
PDML transaction cannot be started because we are not in the coordinator site of the distributed transaction.
Action:
Do not use PDML at remote sites.
ORA-12829: Deadlock - itls occupied by siblings at block string of file string
Cause:
parallel statement failed because all itls in the current block are occupied by siblings of the same transaction.
Action:
increase MAXTRANS of the block or reduce the degree of parallelism for the statement. Reexecute the statement. Report suspicious events in trace file to Oracle Support Services if error persists.
ORA-12830: Must COMMIT or ROLLBACK after executing parallel INSERT/UPDATE/DELETE
Cause:
After executing a parallel INSERT/UPDATE/DELETE statement, a command other than COMMIT or ROLLBACK was issued.
Action:
Execute COMMIT or ROLLBACK before issuing another SQL command.
ORA-12831: Must COMMIT or ROLLBACK after executing INSERT with APPEND hint
Cause:
After executing an INSERT statement with an APPEND hint, a command other than COMMIT or ROLLBACK was issued.
Action:
ORA-12832: Could not allocate slaves on all specified instances
Cause:
After executing a query on a global v$ fixed view, one or more instances failed to allocate a slave to process query
Action:
To allow results to be returned by sucessfully allocated slaves, execute ALTER SESSION SET ALLOW_PARTIAL_SN_RESULTS=TRUE statement, or check parameters of instances
ORA-12833: Coordinator's instance not a member of parallel_instance_group
Cause:
The coordinator's instance must be a member of the parallel_instance_group in which this operation will be run.
Action:
Either add the coordinator's instance to the current parallel_instance_group or change parallel_instance_group.
ORA-12834: Instance group name, 'string', too long, must be less than string characters
Cause:
The instance group name is too long.
Action:
Either shorten the name or get rid of the instance group.
ORA-12835: No instances are active in the GLOBAL_VIEW_ADMIN_GROUP
Cause:
There must be at least one instance in the GLOBAL_VIEW_ADMIN_GROUP in order to execute a query on global views
Action:
Change the value of GLOBAL_VIEW_ADMIN_GROUP
ORA-12838: cannot read/modify an object after modifying it in parallel
Cause:
Within the same transaction, an attempt was made to add read or modification statements on a table after it had been modified in parallel or with direct load. This is not permitted.
Action:
Rewrite the transaction, or break it up into two transactions: one containing the initial modification and the second containing the parallel modification operation.
ORA-12839: cannot modify an object in parallel after modifying it
Cause:
Within the same transaction, an attempt was made to perform parallel modification operations on a table after it had been modified. This is not permitted.
Action:
Rewrite the transaction or break it up into two transactions: one containing the parallel modification and the second containing the initial modification operation.
ORA-12840: cannot access a remote table after parallel/insert direct load txn
Cause:
Within a transaction, an attempt was made to perform distributed access after a PDML or insert direct statement had been issued.
Action:
Commit/rollback the PDML transaction first, and then perform the distributed access, or perform the distributed access before the first PDML statement in the transaction.
ORA-12841: Cannot alter the session parallel DML state within a transaction
Cause:
Transaction in progress
Action:
Commit or rollback transaction and then re-execute
ORA-12842: Cursor invalidated during parallel execution
Cause:
The cursor was invalidated during the parse phase of deferred parallel processing, e.g. when set operands are parallelized.
Action:
Depends on why the cursor was invalidated. Possible causes include DDL on a schema object and shared pool being flushed.
ORA-12843: pdml lock not held properly on the table
Cause:
The coodinator crashed or released the lock on the partition which the slave is trying to aquire currently.
Action:
Check if the coordinator or some of the other slaves died. Also check that the lock has not been corrupted. Issue the pdml again.
ORA-12845: failed to receive interinstance parallel execution message
Cause:
OS or interconnect problem receiving interinstance message
Action:
Check OS specific diagnostics
ORA-12850: Could not allocate slaves on all specified instances: string needed, string allocated
Cause:
When executing a query on a gv$ fixed view, one or more instances failed to allocate a slave to process query.
Action:
Check trace output for instances on which slaves failed to start. GV$ query can only proceed if slaves can be allocated on all instances.
ORA-12851: PARALLEL_MAX_SERVERS must be greater than or equal to PARALLEL_MIN_SERVERS, string
Cause:
An attempt was made to set the PARALLEL_MAX_SERVERS parameter to a value less than PARALLEL_MIN_SERVERS.
Action:
Set PARALLEL_MAX_SERVERS to a value greater than or equal to PARALLEL_MIN_SERVERS value specified in the accompanying message and retry.
ORA-12852: PARALLEL_MIN_SERVERS must be less than PROCESSES, string
Cause:
An attempt was made to set the PARALLEL_MIN_SERVERS parameter to a value higher than PROCESSES.
Action:
Set PARALLEL_MIN_SERVERS to a value less than PROCESSES value specified in the accompanying message and retry.
ORA-12853: insufficient memory for PX buffers: current stringK, max needed stringK
Cause:
Insufficient SGA memory for PX buffers
Action:
Reconfigure sga to include at least (max - current) bytes of additional memory
ORA-12854: Parallel query is not supported on temporary LOBs
Cause:
The parallel query statement produced a temporary LOB.
Action:
Turn off parallelism for the query or underlying table
ORA-12855: cannot run parallel or insert direct load in a loopback
Cause:
A loopback was created in the transaction before this operation.
Action:
Do not use loopback when using pdml or insert direct load.
ORA-12856: cannot run parallel query on a loopback connection
Cause:
A table or index in a parallel query is referenced via a loopback connection.
Action:
Do not use loopback connection when running a query in parallel.
ORA-12872: First slave parse gave different plan
Cause:
First hard parse on slave given QC-supplied environment and parameters gave different plan from QC. Try again with outline.
Action:
No external action. Internally used for outline-based reparse.
ORA-12874: parallel execution monitor terminated with error
Cause:
The parallel execution monitor process died.
Action:
Wait for the process to restart.
ORA-12899: value too large for column string (actual: string, maximum: string)
Cause:
An attempt was made to insert or update a column with a value which is too wide for the width of the destination column. The name of the column is given, along with the actual width of the value, and the maximum allowed width of the column. Note that widths are reported in characters if character length semantics are in effect for the column, otherwise widths are reported in bytes.
Action:
Examine the SQL statement for correctness. Check source and destination column data types. Either make the destination column wider, or use a subset of the source column (i.e. use substring).
ORA-12900: must specify a default temporary tablespace for a locally managed database
Cause:
a locally managed database must have a temporary tablespace other than SYSTEM tablespace
Action:
specify the default temporary tablespace when creating a locally managed database
ORA-12901: default temporary tablespace must be of TEMPORARY type
Cause:
in a locally managed database, default temporary tablespace must be TEMPORARY type
Action:
n/a
ORA-12902: default temporary tablespace must be SYSTEM or of TEMPORARY type
Cause:
in a dictionary managed database, default temporary tablespace must be SYSTEM or TEMPORARY type
Action:
n/a
ORA-12903: default temporary tablespace must be an ONLINE tablespace
ORA-12904: default temporary tablespace cannot be altered to PERMANENT type
ORA-12905: default temporary tablespace cannot be brought OFFLINE
ORA-12906: cannot drop default temporary tablespace
ORA-12907: tablespace string is already the default temporary tablespace
ORA-12908: cannot specify SYSTEM as default temporary tablespace when creating database
ORA-12909: TEMPORARY keyword expected
ORA-12910: cannot specify temporary tablespace as default tablespace
Cause:
attempt to assign a temporary tablespace to be a user's default tablespace
Action:
assign a permanent tablespace to be the default tablespace
ORA-12911: permanent tablespace cannot be temporary tablespace
Cause:
attempt to assign a permanent tablespace to be a user's temporary tablespace
Action:
assign a temporary tablespace to be user's temporary tablespace
ORA-12912: Dictionary managed tablespace specified as temporary tablespace
Cause:
attempt to assign a dictionary managed tablespace to be a user's temporary tablespace
Action:
Assign a locally managed temporary tablespace to be user's temporary tablespace
ORA-12913: Cannot create dictionary managed tablespace
Cause:
Attemp to create dictionary managed tablespace in database which has system tablespace as locally managed
Action:
Create a locally managed tablespace.
ORA-12914: Cannot migrate tablespace to dictionary managed type
Cause:
Attemp to migrate locally managed tablespace to dictionary managed type when the database has locally managed system tablespace.
Action:
Command cannot be issued.
ORA-12915: Cannot alter dictionary managed tablespace to read write
Cause:
Attemp to alter dictionary managed tablespace to read write in database which has system tablespace as locally managed. This tablespace can only be dropped.
Action:
ORA-12916: cannot shrink permanent or dictionary managed tablespace
Cause:
An attempt was made to shrink a permanent tablespace or a dictionary managed tablespace.
Action:
Check the tablespace type and issue the statement only on locally managed temporary tablespaces.
ORA-12917: Invalid option specified for default permanent tablespace
ORA-12918: Invalid tablespace type for default permanent tablespace
Cause:
The tablespace is either dropped, temporary or undo
Action:
Check the tablespace type and reissue the statement
ORA-12919: Can not drop the default permanent tablespace
Cause:
An attemp was made to drop the default permanent tablespace
Action:
Make a different tablespace as the default permanent tablespace and reissue the drop
ORA-12920: database is already in force logging mode
Cause:
ALTER DATABASE FORCE LOGGING command failed because the database is already in force logging mode.
Action:
n/a
ORA-12921: database is not in force logging mode
Cause:
ALTER DATABASE NO FORCE LOGGING command failed because the database is not in force logging mode.
Action:
n/a
ORA-12922: concurrent ALTER DATABASE [NO] FORCE LOGGING command is running
Cause:
There is a concurrent ALTER DATABASE FORCE LOGGING or ALTER DATABASE NO FORCE LOGGING command running in the system.
Action:
Contact the database administrator who is responsible for the concurrent command.
ORA-12923: tablespace string is in force logging mode
Cause:
An attempt to alter the specified tablespace temporary failed because the tablespace is in force logging mode.
Action:
Put the tablespace out of force logging mode by ALTER TABLESPACE NO FORCE LOGGING command.
ORA-12924: tablespace string is already in force logging mode
Cause:
An attempt to alter the specified tablespace into force logging mode failed because it is already in force logging mode.
Action:
n/a
ORA-12925: tablespace string is not in force logging mode
Cause:
An attempt to alter the specified tablespace out of force logging mode failed because it is not in force logging mode.
Action:
n/a
ORA-12926: FORCE LOGGING option already specified
Cause:
In CREATE TABLESPACE, the FORCE LOGGING option was specified more than once.
Action:
Remove all but one of the FORCE LOGGING options.
ORA-12927: RETENTION option already specified
Cause:
In CREATE TABLESPACE, the RETENTION option was specified more than once.
Action:
Remove all but one of the RETENTION options.
ORA-12928: ENCRYPTION option already specified
Cause:
In CREATE TABLESPACE, the ENCRYPTION option was specified more than once.
Action:
Remove all but one of the ENCRYPTION options.
ORA-12931: FORCE LOGGING or SET STANDBY NOLOGGING already specified
Cause:
FORCE LOGGING or SET STANDBY NOLOGGING options were specified more than once.
Action:
Remove all but one of the FORCE LOGGING or SET STANDBY NOLOGGING options.
ORA-12940: Not enough space in DBVerify text buffer
Cause:
DBVerify ran out of text buffer. The error was trapped internally by the system. DBVerify would return the result in text buffer and then resume checking.
Action:
None
ORA-12941: DBVerify exception
Cause:
DBVerify encountered run-time error. The error signal was trapped internally by the system.
Action:
None
ORA-12950: SYSTEM tablespace specified as default permanent tablespace
Cause:
SYSTEM tablespace was specified as the default permanent during database creation.
Action:
If default permanent tablespace is not specified,then SYSTEM will implicitly become the default permanent tablespace. Specify an alternate tablespace or omit the default tablespace clause and reissue the CREATE DATABASE statement
ORA-12951: Attempt to change default permanent tablespace to temporary
Cause:
It is incorrect to alter the default permanent tablespace of a database to temporary type
Action:
n/a
ORA-12952: Control space growth in ASSM segment under concurrency
ORA-12980: checkpoint option not allowed with SET UNUSED
Cause:
An attempt was made to specify checkpoint option with SET UNUSED.
Action:
Remove checkpoint option.
ORA-12981: cannot drop column from an object type table
Cause:
An attempt was made to drop a column from an object type table.
Action:
This action is not allowed.
ORA-12982: cannot drop column from a nested table
Cause:
An attempt was made to drop a column from a nested table.
Action:
ORA-12983: cannot drop all columns in a table
Cause:
An attempt was made to drop all columns in a table.
Action:
Make sure at least one column remains in the table after the drop column operation.
ORA-12984: cannot drop partitioning column
Cause:
An attempt was made to drop a column used as the partitioning key.
Action:
ORA-12985: tablespace 'string' is read only, cannot drop column
Cause:
An attempt was made to drop column from a partition/subpartition on a read only tablespace.
Action:
Set the tablespace to read write and resubmit statement.
ORA-12986: columns in partially dropped state. Submit ALTER TABLE DROP COLUMNS CONTINUE
Cause:
An attempt was made to access a table with columns in partially dropped state (i.e., drop column operation was interrupted).
Action:
Submit ALTER TABLE DROP COLUMNS CONTINUE to complete the drop column operation before accessing the table.
ORA-12987: cannot combine drop column with other operations
Cause:
An attempt was made to combine drop column with other ALTER TABLE operations.
Action:
Ensure that drop column is the sole operation specified in ALTER TABLE.
ORA-12988: cannot drop column from table owned by SYS
Cause:
An attempt was made to drop a column from a system table.
Action:
ORA-12989: invalid value for checkpoint interval
Cause:
An invalid checkpoint interval specified in statement. Checkpoint interval must be between 0 and (2^31-1).
Action:
Correct checkpoint interval and resubmit statement
ORA-12990: duplicate option specified
Cause:
Duplicate option specified in statement.
Action:
Remove the duplicate option and resubmit statement.
ORA-12991: column is referenced in a multi-column constraint
Cause:
An attempt was made to drop a column referenced by some constraints.
Action:
Drop all constraints referencing the dropped column or specify CASCADE CONSTRAINTS in statement.
ORA-12992: cannot drop parent key column
Cause:
An attempt was made to drop a parent key column.
Action:
Drop all constraints referencing the parent key column, or specify CASCADE CONSTRAINTS in statement.
ORA-12993: tablespace 'string' is offline, cannot drop column
Cause:
An attempt was made to drop a column from a partition/subpartition on an offline tablespace.
Action:
Bring the tablespace online and resubmit statement.
ORA-12994: drop column option only allowed once in statement
Cause:
An attempt was made to repeat the drop column option in a single statement.
Action:
Separate drop column options into different statements and resubmit statements.
ORA-12995: no columns in partially dropped state
Cause:
An attempt was made to submit DROP COLUMNS CONTINUE statement while there are no partially dropped columns.
Action:
Cannot submit this statement.
ORA-12996: cannot drop system-generated virtual column
Cause:
An attempt was made to drop a virtual column generated by the system.
Action:
n/a
ORA-12997: cannot drop primary key column from an index-organized table
Cause:
An attempt was made to drop a primary key column from an index- organized table.
Action:
ORA-12998: Ignore errors during drop column from atb.c
ORA-12999: cannot DROP or SET UNUSED a column that has been set unused
Cause:
An attempt was made to DROP or SET UNUSED a column that has already been 'set unused'.
Action:
Use the DROP UNUSED COLUMNS option to remove the column.
ORA-13000: dimension number is out of range
Cause:
The specified dimension is either smaller than 1 or greater than the number of dimensions encoded in the HHCODE.
Action:
Make sure that the dimension number is between 1 and the maximum number of dimensions encoded in the HHCODE.
ORA-13001: dimensions mismatch error
Cause:
The number of dimensions in two HHCODEs involved in a binary HHCODE operation do not match.
Action:
Make sure that the number of dimensions in the HHCODEs match.
ORA-13002: specified level is out of range
Cause:
The specified level is either smaller than 1 or greater than the maximum level encoded in an HHCODE.
Action:
Verify that all levels are between 1 and the maximum number of levels encoded in the HHCODE.
ORA-13003: the specified range for a dimension is invalid
Cause:
The specified range for a dimension is invalid.
Action:
Make sure that the lower bound (lb) is less than the upper bound (ub).
ORA-13004: the specified buffer size is invalid
Cause:
The buffer size for a function is not valid.
Action:
ORA-13005: recursive HHCODE function error
Cause:
An error occurred in a recursively called HHCODE function.
Action:
ORA-13006: the specified cell number is invalid
Cause:
The cell identifier is either less than 0 or greater than (2^ndim - 1).
Action:
Make sure that the cell identifier is between 0 and (2^ndim - 1).
ORA-13007: an invalid HEX character was detected
Cause:
A character that is not in the range [0-9] or [A-F a-f] was detected.
Action:
Verify that all characters in a string are in [0-9] or [A-F a-f].
ORA-13008: the specified date format has an invalid component
Cause:
Part of specified date format is invalid.
Action:
Verify that the date format is valid.
ORA-13009: the specified date string is invalid
Cause:
The specified date string has a bad component or does not match the specified format string.
Action:
Make sure that the components of the date string are valid and that the date and format strings match.
ORA-13010: an invalid number of arguments has been specified
Cause:
An invalid number of arguments was specified for an SDO function.
Action:
Verify the syntax of the function call.
ORA-13011: value is out of range
Cause:
A specified dimension value is outside the range defined for that dimension.
Action:
Make sure that all values to be encoded are within the defined dimension range.
ORA-13012: an invalid window type was specified
Cause:
An invalid window type was specified.
Action:
Valid window types are RANGE, PROXIMITY, POLYGON.
ORA-13013: the specified topology was not INTERIOR or BOUNDARY
Cause:
A topology was specified that was not INTERIOR or BOUNDARY.
Action:
Make sure that INTERIOR or BOUNDARY is used to describe an HHCODE's topology.
ORA-13014: a topology identifier outside the range of 1 to 8 was specified
Cause:
A topology identifier outside the range of 1 to 8 was specified.
Action:
Specify a topology in the range of 1 to 8.
ORA-13015: the window definition is not valid
Cause:
The number of values used to define the window does not correspond to the window type.
Action:
Verify that the number of values used to defined the window is correct for the window type and number of dimensions.
ORA-13016: specified topology [string] is invalid
Cause:
The specified topology did not exist in the database, or some components of the topology were missing from the database.
Action:
Check the specified topology by executing the SDO_TOPO.validate_topology function.
ORA-13017: unrecognized line partition shape
Cause:
The shape of a 2-D line partition could not be determined.
Action:
ORA-13018: bad distance type
Cause:
The specified distance type is invalid.
Action:
The only supported distance functions are EUCLID and MANHATTAN.
ORA-13019: coordinates out of bounds
Cause:
Vertex coordinates lie outside the valid range for specified dimension.
Action:
Redefine vertex coordinates within specified boundaries.
ORA-13020: coordinate is NULL
Cause:
A vertex coordinate has a NULL value.
Action:
Redefine vertex coordinate to have non-NULL value.
ORA-13021: element not continuous
Cause:
The coordinates defining a geometric element are not connected.
Action:
Redefine coordinates for the geometric element.
ORA-13022: polygon crosses itself
Cause:
The coordinates defining a polygonal geometric element represent crossing segments.
Action:
Redefine coordinates for the polygon.
ORA-13023: interior element interacts with exterior element
Cause:
An interior element of a geometric object interacts with the exterior element of that object.
Action:
Redefine coordinates for the geometric elements.
ORA-13024: polygon has less than three segments
Cause:
The coordinates defining a polygonal geometric element represent less than three segments.
Action:
Redefine the coordinates for the polygon.
ORA-13025: polygon does not close
Cause:
The coordinates defining a polygonal geometric element represent an open polygon.
Action:
Redefine the coordinates of the polygon.
ORA-13026: unknown element type for element string.string.string
Cause:
The SDO_ETYPE column in the layer_SDOGEOM table contains an invalid geometric element type value.
Action:
Redefine the geometric element type in the layer_SDOGEOM table for the specified geometric element using one of the supported SDO_ETYPE values. See the Oracle Spatial documentation for an explanation of SDO_ETYPE and its possible values.
ORA-13027: unable to read dimension definition from string
Cause:
There was a problem reading the dimension definition from the layer_SDODIM table.
Action:
Verify that the layer_SDODIM table exists and that the appropriate privileges exist on the table. Address any other errors that might appear with the message.
ORA-13028: Invalid Gtype in the SDO_GEOMETRY object
Cause:
There is an invalid SDO_GTYPE in the SDO_GEOMETRY object.
Action:
Verify that the geometries have valid gtypes.
ORA-13029: Invalid SRID in the SDO_GEOMETRY object
Cause:
There is an invalid SDO_SRID in the SDO_GEOMETRY object. The specified SRID may be outside the valid SRID range.
Action:
Verify that the geometries have valid SRIDs.
ORA-13030: Invalid dimension for the SDO_GEOMETRY object
Cause:
There is a mismatch between the dimension in the SDO_GTYPE and dimension in the SDO_GEOM_METADATA for the SDO_GEOMETRY object.
Action:
Verify that the geometries have valid dimensionality.
ORA-13031: Invalid Gtype in the SDO_GEOMETRY object for point object
Cause:
There is an invalid SDO_GTYPE in the SDO_GEOMETRY object where the VARRAYs are NULL but the SDO_GTYPE is not of type POINT.
Action:
ORA-13032: Invalid NULL SDO_GEOMETRY object
Cause:
There are invalid SDO_POINT_TYPE or SDO_ELEM_INFO_ARRAY or SDO_ORDINATE_ARRAY fields in the SDO_GEOMETRY object.
Action:
Verify that the geometries have valid fields. To specify a NULL geometry, specify the whole SDO_GEOMETRY as NULL instead of setting each field to NULL.
ORA-13033: Invalid data in the SDO_ELEM_INFO_ARRAY in SDO_GEOMETRY object
Cause:
There is invalid data in the SDO_ELEM_INFO_ARRAY field of the SDO_GEOMETRY object. The triplets in this field do not make up a valid geometry.
Action:
Verify that the geometries have valid data.
ORA-13034: Invalid data in the SDO_ORDINATE_ARRAY in SDO_GEOMETRY object
Cause:
There is invalid data in the SDO_ORDINATE_ARRAY field of the SDO_GEOMETRY object. The coordinates in this field do not make up a valid geometry. There may be NULL values for X or Y or both.
Action:
ORA-13035: Invalid data (arcs in geodetic data) in the SDO_GEOMETRY object
Cause:
There is invalid data in the SDO_ELEM_INFO_ARRAY field of the SDO_GEOMETRY object. There are arcs in a geometry that has geodetic coordinates.
Action:
ORA-13036: Operation [string] not supported for Point Data
Cause:
The specified geometry function is not supported for point data.
Action:
Make sure that the specified geometry function is not called on point data.
ORA-13037: SRIDs do not match for the two geometries
Cause:
A Spatial operation is invoked with two geometries where one geometry has an SRID and the other geometry does not have an SRID.
Action:
Make sure that the spatial operations are invoked between two geometries with compatible SRIDs.
ORA-13039: failed to update spatial index for element string.string.string
Cause:
Another error will accompany this message that will indicate the problem.
Action:
Correct any accompanying errors. If no accompanying error message appears, contact Oracle Support Services.
ORA-13040: failed to subdivide tile
Cause:
Action:
Note any accompanying errors and contact Oracle Support Services.
ORA-13041: failed to compare tile with element string.string.string
Cause:
The spatial relationship between a generated tile and the specified element could not be determined.
Action:
This is an internal error. Verify the geometry using the VALIDATE_GEOMETRY_WITH_CONTEXT procedure. If the procedure does not return any errors, note any errors that accompany ORA-13041 and contact Oracle Support Services.
ORA-13042: invalid SDO_LEVEL and SDO_NUMTILES combination
Cause:
An invalid combination of SDO_LEVEL and SDO_NUMTILES values was read from the layer_SDOLAYER table. The most likely cause is that the columns are NULL.
Action:
Verify the that SDO_LEVEL and SDO_NUMTILES columns contain valid integer values as described in the Oracle Spatial documentation. Then retry the operation.
ORA-13043: failed to read metadata from the layer_SDOLAYER table
Cause:
An error was encountered reading the layer metadata from the layer_SDOLAYER table.
Action:
This error is usually the result of an earlier error which should also have been reported. Address this accompanying error and retry the current operation. If no accompanying error was reported, contact Oracle Support Services.
ORA-13044: the specified tile size is smaller than the tolerance
Cause:
The tile size specified for fixed size tessellation is smaller than the tolerance as specified in the layer metadata.
Action:
See the Oracle Spatial documentation for an explanation of tiling levels, tile size, and tiling resolution. Ensure that the tiling parameters are set such that any generated tile is always larger than or equal to a tile at the maximum level of resolution. This can be achieved by using a fewer number of tiles per geometric object or specifying a smaller tile size value than the current one.
ORA-13045: invalid compatibility flag
Cause:
Action:
ORA-13046: invalid number of arguments
Cause:
An invalid number of arguments were specified for an SDO_GEOM function.
Action:
See the Oracle Spatial documentation for a description of the syntax and semantics of the relevant SDO_GEOM function.
ORA-13047: unable to determine ordinate count from table layer_SDOLAYER
Cause:
An SDO_GEOM function was unable to determine the number of ordinates for the SDO layer layer.
Action:
Verify that the layer_SDOLAYER table has a valid value for the column SDO_ORDCNT. Then retry the operation.
ORA-13048: recursive SQL fetch error
Cause:
Action:
ORA-13049: unable to determine tolerance value from table layer_SDODIM
Cause:
An SDO_GEOM function was unable to determine the tolerance value for the SDO layer layer.
Action:
Verify that the layer_SDODIM table has a valid value for the column SDO_TOLERANCE.
ORA-13050: unable to construct spatial object
Cause:
Action:
ORA-13051: failed to initialize spatial object
Cause:
Action:
ORA-13052: unsupported geometric type for geometry string.string
Cause:
The geometry type for a specific instance in a layer_SDOGEOM table is not among the set of geometry types supported by Oracle Spatial.
Action:
Check the Oracle Spatial documentation for the list of supported geometry types and workarounds that permit the storage and retrieval of non-supported geometric types with the SDO schema.
ORA-13053: maximum number of geometric elements in argument list exceeded
Cause:
The maximum number of geometric elements that can be specified in the argument list for an SDO_GEOM function was exceeded.
Action:
Check the Oracle Spatial documentation for the syntax of the SDO_GEOM function and use fewer arguments to describe the geometry, or check the description of the SDO_WINDOW package for a workaround that permits storing the object in a table and then using it in as an argument in a call to the SDO_GEOM function.
ORA-13054: recursive SQL parse error
Cause:
Action:
ORA-13055: Oracle object string does not exist in specified table
Cause:
The requested object is not present in the specified table.
Action:
Verify the syntax of the function or procedure that reported this error and verify that the object does indeed exist in the specified table. Then retry the operation.
ORA-13060: topology with the name string already exists
Cause:
The specified topology name was not unique in the database.
Action:
Verify that the CREATE_TOPOLOGY call specifies the correct topology name and that the procedure is invoked from the correct schema.
ORA-13061: topology with the name string does not exist
Cause:
The specified topology did not exist in the database.
Action:
Verify that the current procedure/function call specifies the correct schema and topology name.
ORA-13062: topology IDs do not match in the feature table and the topology
Cause:
The specified topology ID in the feature table did not match the topology ID stored in the topology metadata.
Action:
Verify that the specified topology ID matches the topology ID stored in the topology metadata.
ORA-13063: relationship information table is missing data for feature table [string]
Cause:
The topology relationship information table (xxx_RELATION$) did not have the matching partition corresponding to the feature table.
Action:
Make sure the correct topology IDs and names are specified in the call to register the feature table with the topology.
ORA-13064: relationship information table has inconsistent data for feature table [string]
Cause:
The topology_id, tg_layer_id values stored in the feature table did not match the values stored in the topology relationship information table (xxx_RELATION$).
Action:
Make sure that the correct feature tables are specified in the call to register the feature table with the topology.
ORA-13065: cannot delete a child layer with a parent layer
Cause:
A call was made to delete a feature layer which has a dependent layer defined on it.
Action:
Make sure that all dependent feature layers are deleted before deleting the current feature layer.
ORA-13066: wrong feature geometry or element type
Cause:
The SDO_TOPO_GEOMETRY object had the wrong geometry and/or element type.
Action:
Correct the geometry and/or element type in the SDO_TOPO_GEOMETRY object.
ORA-13067: operator requires both parameters from the same topology
Cause:
Both SDO_TOPO_GEOMETRY parameters did not come from the same topology.
Action:
Make sure both the parameters to the operator are from the same topology. If this is not possible, consider using a signature of the operator that does not use two SDO_TOPO_GEOMETRY parameters.
ORA-13068: wrong table or column name in SDO_TOPO_GEOMETRY constructor
Cause:
An SDO_TOPO_GEOMETRY constructor was invoked with incorrect parameters for table name and/or column name.
Action:
Fix the parameters in the call and try again.
ORA-13069: incorrect degree value for SDO_GEOMETRY object
Cause:
An incorrect degree value <=1 was passed for a Non-Uniform Rational B-Spline curve.
Action:
Correct the degree value for the Non-Uniform Rational B-Spline curve.
ORA-13070: incorrect number of control points for SDO_GEOMETRY object
Cause:
An incorrect number of control points was passed for a Non-Uniform Rational B-Spline curve.
Action:
Correct the number of control points for the Non-Uniform Rational B-Spline curve.
ORA-13071: incorrect control points, degree for SDO_GEOMETRY object
Cause:
An incorrect number of control points and degree was passed for a Non-Uniform Rational B-Spline curve.
Action:
Ensure that the number of control points is greater than the degree for a Non-Uniform Rational B-Spline curve.
ORA-13072: incorrect number of knots for SDO_GEOMETRY object
Cause:
An incorrect number of knot values was passed for a Non-Uniform Rational B-Spline curve.
Action:
Correct the number of knot values passed for the Non-Uniform Rational B-Spline curve.
ORA-13073: incorrect control point weight value for a SDO_GEOMETRY object
Cause:
An incorrect value was passed for the weight of a control point of a Non-Uniform Rational B-Spline curve.
Action:
Ensure all weight values for control points are positive.
ORA-13074: incorrect knot value for SDO_GEOMETRY object
Cause:
An incorrect knot value was passed for a Non-Uniform Rational B-Spline curve.
Action:
Ensure the knot values passed for the Non-Uniform Rational B-Spline curve are in non-decreasing order.
ORA-13075: incorrect knot value sequence for SDO_GEOMETRY object
Cause:
An incorrect knot value sequence was passed for a Non-Uniform Rational B-Spline curve.
Action:
Ensure the knot values passed for the Non-Uniform Rational B-Spline curve have no more than a sequence of 'k' consecutive identical values or no more than 'k + 1' consecutive same values at the beginning or end of Non-Uniform Rational B-Spline curve.
ORA-13076: incorrect knot value sequence for SDO_GEOMETRY object
Cause:
Action:
Ensure the knot value sequence passed for the Non-Uniform Rational B-Spline curve is a normalized vector beginning at zero and ending at one.
ORA-13077: incorrect start or end point for subelement of a compound curve
Cause:
The end point of a subelement for a compound curve was not equal to the start point of the next subelement, or the start point of a subelement was not equal to the end point of the previous subelement and one of the subelements was a NURBS curve.
Action:
Ensure that the end point of each subelement is equal to the start point of the next subelement and that the start point of each subelement is equal to the end point of the previous subelement when one of the subelements is a NURBS curve.
ORA-13107: operation not supported for Non-Uniform Rational B-Spline type
Cause:
This operation cannot be executed for Non-Uniform Rational B-Spline curves.
Action:
Specify a geometry that does not contain a Non-Uniform Rational B-Spline curve type.
ORA-13108: spatial table string not found
Cause:
The specified spatial table does not exist.
Action:
Check the Spatial data dictionary to make sure that the table is registered.
ORA-13109: spatial table string exists
Cause:
The specified spatial table is registered in the Spatial data dictionary.
Action:
Remove the existing table from the Spatial data dictionary or use a different name.
ORA-13110: cannot drop topology with associated topo_geometry tables
Cause:
The drop_topology procedure was invoked for a topology that has assocated topo_geometry layers with it.
Action:
Delete the topo_geometry layers from the topology before dropping the topology. Use SDO_TOPO.delete_topo_geometry_layer to delete topo_geometry layers from the topology.
ORA-13111: cannot add topo_geometry layer [string] to topology
Cause:
It was not possible to add the specified topo_geometry layer to the topology.
Action:
Make sure the topo_geometry layer table exists in the database.
ORA-13112: cannot delete topo_geometry layer [string] from topology
Cause:
It was not possible to delete the specified topo_geometry layer from the topology.
Action:
Check USER_SDO_TOPO_METADATA to see if the specified topo_geometry layer is part of the topology. Only those topo_geometry layers which are part of the topology can be deleted from it.
ORA-13113: invalid tg_layer_id in sdo_topo_geometry constructor
Cause:
An invalid layer_id was passed to the SDO_TOPO_GEOMETRY constructor.
Action:
Valid layer_ids are obtained by adding a topo_geometry layer to the topology. Check USER_SDO_TOPO_METADATA to find out the layer_id for an existing topo_geometry layer.
ORA-13114: [string]_NODE$ table does not exist
Cause:
The NODE$ table for the topology did not exist in the database.
Action:
There is a severe corruption of the topology. Call Oracle Support Services with the error number.
ORA-13115: [string]_EDGE$ table does not exist
Cause:
The EDGE$ table for the topology did not exist in the database.
Action:
ORA-13116: [string]_FACE$ table does not exist
Cause:
The FACE$ table for the topology did not exist in the database.
Action:
ORA-13117: [string]_RELATION$ table does not exist
Cause:
The RELATION$ table for the topology did not exist in the database.
Action:
ORA-13118: invalid node_id [string]
Cause:
A topology node operation was invoked with an invalid node_id.
Action:
Check the topology node$ table to see if the specified node_id exists in the topology.
ORA-13119: invalid edge_id [string]
Cause:
A topology edge operation was invoked with an invalid edge_id.
Action:
Check the topology edge$ table to see if the specified edge_id exists in the topology.
ORA-13120: invalid face_id [string]
Cause:
A topology face operation was invoked with an invalid face_id.
Action:
Check the topology face$ table to see if the specified face_id exists in the topology.
ORA-13121: layer type type mismatch with topo_geometry layer type
Cause:
The tg_type in SDO_TOPO_GEOMETRY constructor did not match the type specified for the layer.
Action:
Check the USER_SDO_TOPO_METADATA view to see the layer type for the layer and use it in the constructor.
ORA-13122: invalid topo_geometry specified
Cause:
The SDO_TOPO_GEOMETRY object passed into the function/operator was not valid.
Action:
Check the SDO_TOPO_GEOMETRY object and verify that it is a valid topo_geometry object.
ORA-13123: invalid TOPOLOGY name specified
Cause:
The create_topo operation requires a unique TOPOLOGY name, that already does not exist in the database.
Action:
Check to see if there is already an entry in the USER_SDO_TOPO_METADATA (or the MDSYS.SDO_TOPO_METADATA_TABLE) with this topology name.
ORA-13124: unable to determine column id for column string
Cause:
Action:
ORA-13125: partition key is already set
Cause:
A partition key is already set for the spatial table.
Action:
Only one partition key can be specified per spatial table.
ORA-13126: unable to determine class for spatial table string
Cause:
Action:
ORA-13127: failed to generate target partition
Cause:
Action:
ORA-13128: current tiling level exceeds user specified tiling level
Cause:
Action:
ORA-13129: HHCODE column string not found
Cause:
The specified spatial column does not exist.
Action:
Verify that the specified column is a spatial column by checking the Spatial data dictionary.
ORA-13135: failed to alter spatial table
Cause:
Action:
ORA-13136: null common code generated
Cause:
Action:
ORA-13137: failed to generate tablespace sequence number
Cause:
Action:
ORA-13138: could not determine name of object string
Cause:
Action:
ORA-13139: could not obtain column definition for string
Cause:
Action:
ORA-13140: invalid target type
Cause:
The specified target type is not valid.
Action:
Substitute a valid target type. Valid target types are TABLE and VIEW.
ORA-13141: invalid RANGE window definition
Cause:
The RANGE window specified is not correctly defined.
Action:
A RANGE window is defined by specifying the lower and upper boundary of each dimension as a pair of values (e.g.: lower_bound1,upper_bound1,lower_bound2,upper_bound2,...). There should be an even number of values.
ORA-13142: invalid PROXIMITY window definition
Cause:
The PROXIMITY window specified is not correctly defined.
Action:
A PROXIMITY window is defined by specifying a center point and a radius. The center point is defined by ND values. There should be ND+1 values.
ORA-13143: invalid POLYGON window definition
Cause:
The POLYGON window specified is not correctly defined.
Action:
A POLYGON window is defined by specifying N pairs of values that represent the vertices of the polygon. There should be an even number of values.
ORA-13144: target table string not found
Cause:
Action:
ORA-13145: failed to generate range list
Cause:
Action:
ORA-13146: could not find table substitution variable string
Cause:
The partition name substitution variable %s was not found in the SQL filter.
Action:
The substitution variable %s must be in the SQL filter to indicate where that partition name should be placed.
ORA-13147: failed to generate MBR
Cause:
Action:
ORA-13148: failed to generate SQL filter
Cause:
Action:
ORA-13149: failed to generate next sequence number for spatial table string
Cause:
Action:
ORA-13150: failed to insert exception record
Cause:
Operation failed to insert a record into the exception table.
Action:
Fix any other errors reported.
ORA-13151: failed to remove exception record
Cause:
Operation failed to remove a record from the exception table.
Action:
ORA-13152: invalid HHCODE type
Cause:
Specified HHCODE type is not valid.
Action:
Substitute a valid HHCODE type. Valid HHCODE types are POINT and LINE.
ORA-13153: invalid high water mark specified
Cause:
The high water mark must be greater than or equal to zero.
Action:
Make sure that the high water mark is an integer greater than or equal to zero.
ORA-13154: invalid precision specified
Cause:
The precision specified is out of range.
Action:
The precision must be an integer greater than or equal to zero.
ORA-13155: invalid number of dimensions specified
Cause:
The number of dimensions specified is out of range.
Action:
The number of dimension must be between 1 and 32.
ORA-13156: table to be registered string.string is not empty
Cause:
The specified table has rows in it.
Action:
Make sure that the table to be registered is empty.
ORA-13157: Oracle error ORAstring encountered while string
Cause:
The specified Oracle error was encountered.
Action:
Correct the Oracle error.
ORA-13158: Oracle object string does not exist
Cause:
The specified object does not exist.
Action:
Verify that the specified object exists.
ORA-13159: Oracle table string already exists
Cause:
The specified table already exists.
Action:
Drop the specified table.
ORA-13181: unable to determine length of column string_SDOINDEX.SDO_CODE
Cause:
The length of the SDO_CODE column in the layer_SDOINDEX table could not be determined.
Action:
Make sure that the layer_SDOINDEX table exists with the SDO_CODE column. Verify that the appropriate privileges exist on the table. Then retry the operation.
ORA-13182: failed to read element string.string.string
Cause:
The specified element could not be read from the layer_SDOGEOM table.
Action:
Verify that the specified element exists in the table. Then retry the operation.
ORA-13183: unsupported geometric type for geometry string.string
Cause:
The geometry type in the layer_SDOGEOM table is unsupported.
Action:
Modify the geometry type to be one of the supported types.
ORA-13184: failed to initialize tessellation package
Cause:
Initialization of the tessellation package failed.
Action:
Record the error messages that are returned and contact Oracle Support Services.
ORA-13185: failed to generate initial HHCODE
Cause:
Action:
ORA-13186: fixed tile size tessellation failed
Cause:
Action:
ORA-13187: subdivision failed
Cause:
Action:
ORA-13188: cell decode failed
Cause:
Action:
ORA-13189: recursive SQL parse failed
Cause:
Action:
ORA-13190: recursive SQL fetch failed
Cause:
Action:
ORA-13191: failed to read SDO_ORDCNT value
Cause:
Action:
ORA-13192: failed to read number of element rows
Cause:
Action:
ORA-13193: failed to allocate space for geometry
Cause:
There was insufficient memory to read the geometry from the database.
Action:
Validate the geometry. Record the error messages that are returned and contact Oracle Support Services.
ORA-13194: failed to decode supercell
Cause:
Action:
ORA-13195: failed to generate maximum tile value
Cause:
Action:
ORA-13196: failed to compute supercell for element string.string.string
Cause:
The system was unable to compute the minimum bounding HHCODE or supercell for the geometry.
Action:
Another error might accompany this error. Correct the accompanying error. Also, validate the geometry for correctness.
ORA-13197: element string.string.string is out of range
Cause:
Tessellation did not generate any tiles for this element. This error could be caused if the geometry definition puts the geometry outside the domain defined in the layer_SDODIM table.
Action:
Verify that the geometry is valid and within the defined domain.
ORA-13198: Spatial error: string
Cause:
Internal error in some Oracle Spatial stored procedure.
Action:
Record the sequence of procedure calls or events that preceded this error, and contact Oracle Support Services if the error message text does not clearly specify the cause of the error.
ORA-13199: string
Cause:
Action:
ORA-13200: internal error [string] in spatial indexing.
Cause:
Action:
Contact Oracle Support Services with the exact error text.
ORA-13201: invalid parameters supplied in CREATE INDEX statement
Cause:
An error was encountered while trying to parse the parameters clause for the spatial CREATE INDEX statement.
Action:
Check the Oracle Spatial documentation for the number, syntax, and semantics of expected parameters for spatial index creation.
ORA-13202: failed to create or insert into the SDO_INDEX_METADATA table
Cause:
An error was encountered while trying to create the SDO_INDEX_METADATA table or insert data into it.
Action:
Verify that the current user has CREATE TABLE privilege and that the user has sufficient quota in the default or specified tablespace.
ORA-13203: failed to read USER_SDO_GEOM_METADATA view
Cause:
An error encountered while trying to read the USER_SDO_GEOM_METADATA view.
Action:
Check that USER_SDO_GEOM_METADATA has an entry for the current geometry table.
ORA-13204: failed to create spatial index table
Cause:
An error was encountered while trying to create the index table.
Action:
Check that user has CREATE TABLE privilege in the current schema and that the user has sufficient quota in the default or specified tablespace.
ORA-13205: internal error while parsing spatial parameters
Cause:
An internal error was encountered while parsing the spatial parameters.
Action:
Check that the parameters passed in the parameter string are all valid.
ORA-13206: internal error [string] while creating the spatial index
Cause:
An internal error was encountered while creating the spatial index.
Action:
ORA-13207: incorrect use of the [string] operator
Cause:
An error was encountered while evaluating the specified operator.
Action:
Check the parameters and the return type of the specified operator.
ORA-13208: internal error while evaluating [string] operator
Cause:
An internal error was encountered.
Action:
ORA-13209: internal error while reading SDO_INDEX_METADATA table
Cause:
An internal error was encountered while trying to read the SDO_INDEX_METADATA table.
Action:
Contact Oracle Support Services. Note this and accompanying error numbers.
ORA-13210: error inserting data into the index table
Cause:
An error was encountered while trying to insert data into the index table. Likely causes are:
- Insufficient quota in the current tablespace
- User does not appropriate privileges
Action:
Check the accompanying error messages.
ORA-13211: failed to tessellate the window object
Cause:
An internal error was encountered while trying to tessellate the window object.
Action:
Verify the geometric integrity of the window object using the VALIDATE_GEOMETRY_WITH_CONTEXT procedure.
ORA-13212: failed to compare tile with the window object
Cause:
The spatial relationship between a generated tile and the specified window object could not be determined.
Action:
This is an internal error. Verify the geometry using the VALIDATE_GEOMETRY_WITH_CONTEXT procedure. If the procedure does not return any errors, note any accompanying errors and contact Oracle Support Services.
ORA-13213: failed to generate spatial index for window object
Cause:
Another error, indicating the real cause of the problem, should accompany this error.
Action:
ORA-13214: failed to compute supercell for window object
Cause:
The system was unable to compute the minimum bounding tile or supercell for the geometry.
Action:
ORA-13215: window object is out of range
Cause:
Tessellation did not generate any tiles for this geometry. This error could be caused if the geometry definition puts the geometry outside the domain defined in the USER_SDO_GEOM_METADATA view.
Action:
ORA-13216: failed to update spatial index
Cause:
Action:
ORA-13217: invalid parameters supplied in ALTER INDEX statement
Cause:
An error was encountered while trying to parse the parameters clause for the spatial ALTER INDEX statement.
Action:
Check the Oracle Spatial documentation for the number, syntax, and semantics of expected parameters for the spatial ALTER INDEX statement.
ORA-13218: max number of supported index tables reached for [string] index
Cause:
An add_index parameter was passed to ALTER INDEX when the number of existing index tables is already at maximum.
Action:
Delete one of the index tables before adding another index table.
ORA-13219: failed to create spatial index table [string]
Cause:
Action:
There is a table in the index's schema with the specified name. The CREATE INDEX statement will try to create an index table with this name. Either rename this table or change the name of the index.
ORA-13220: failed to compare tile with the geometry
Cause:
The spatial relationship between a generated tile and the specified geometry could not be determined.
Action:
This is an internal error. Validate the geometry using the VALIDATE_GEOMETRY_WITH_CONTEXT procedure. If the procedure does not return any errors, note any errors that accompany ORA-13220 and contact Oracle Support Services.
ORA-13221: unknown geometry type in the geometry object
Cause:
The SDO_GTYPE attribute in the geometry object contains an invalid value
Action:
Redefine the geometric type in the geometry table using one of the supported SDO_GTYPE values. See the Oracle Spatial documentation for an explanation of SDO_GTYPE and its possible values.
ORA-13222: failed to compute supercell for geometry in string
Cause:
The system was unable to compute the minimum bounding tile or supercell for a geometry in the specified table.
Action:
ORA-13223: duplicate entry for string in SDO_GEOM_METADATA
Cause:
There are duplicate entries for the given table and column value pair in the USER_SDO_GEOM_METADATA view.
Action:
Check that the specified table and geometry column names are correct. There should be only one entry per table, geometry column pair in the USER_SDO_GEOM_METADATA view.
ORA-13224: zero tolerance specified for layer in USER_SDO_GEOM_METADATA
Cause:
A tolerance of zero or NULL is supplied for a layer in USER_SDO_GEOM_METADATA view.
Action:
Check the tolerance specified to make sure it is a positive value.
ORA-13225: specified index table name is too long for a spatial index
Cause:
An index table name is specified which is longer than the supported length of the spatial index table name.
Action:
Check the supported size of the index table name and reduce the size of the index name.
ORA-13226: interface not supported without a spatial index
Cause:
The geometry table does not have a spatial index.
Action:
Verify that the geometry table referenced in the spatial operator has a spatial index on it.
ORA-13227: SDO_LEVEL values for the two index tables do not match
Cause:
The SDO_LEVEL values for the two index tables used in the spatial join operator do not match.
Action:
Verify that two compatible indexes are used for the spatial join operator. Quadtree indexes are compatible if they have the same SDO_LEVEL and SDO_NUMTILES values
ORA-13228: spatial index create failed due to invalid type
Cause:
An Attempt was made to create a spatial index on a column of type other than SDO_GEOMETRY.
Action:
Make sure that the index is created on a column of type SDO_GEOMETRY.
ORA-13230: failed to create temporary table [string] during R-tree creation
Cause:
The specified temporary table either already exists or there is not enough tablespace.
Action:
Delete the table if it already exists and verify if the current user has CREATE TABLE privileges and has sufficient space in the default or specified tablespace.
ORA-13231: failed to create index table [string] during R-tree creation
Cause:
The specified index table either already exists or there is not enough tablespace.
Action:
Delete the table if it already exists and verify if the current user has CREATE TABLE privileges and has sufficient space in the default or specified tablespace. If that fails to correct the problem, contact Oracle Support Services.
ORA-13232: failed to allocate memory during R-tree creation
Cause:
This feature assumes a minimum of 64K memory for bulk creation.
Action:
Create the index for a small subset of the data. Then, use transactional insert operations for the rest of the data.
ORA-13233: failed to create sequence number [string] for R-tree
Cause:
The specified sequence number exists.
Action:
Delete the sequence object, or contact Oracle Support Services.
ORA-13234: failed to access R-tree-index table [string]
Cause:
The index table is either deleted or corrupted.
Action:
Rebuild the index or contact Oracle Support Services with accompanying error messages.
ORA-13236: internal error in R-tree processing: [string]
Cause:
An internal error occurred in R-tree processing.
Action:
Contact Oracle Support Services with the message text.
ORA-13237: internal error during R-tree concurrent updates: [string]
Cause:
An inconsistency is encountered during concurrent updates, possibly due to the use of serializable isolation level.
Action:
Change the isolation level to "read committed" using the ALTER SESSION statement, or contact Oracle Support Services with the message text.
ORA-13239: sdo_dimensionality not specified during n-d R-tree creation
Cause:
An error occurred in reading the dimensionality parameter
Action:
Check the documentation for a valid range, and specify the dimensionality as a parameter.
ORA-13240: specified dimensionality greater than that of the query mbr
Cause:
An error occurred because of too few values in the query minimum bounding rectangle (MBR).
Action:
Omit the dimensionality, or use the dimensionality of the query.
ORA-13241: specified dimensionality does not match that of the data
Cause:
An error occurred because the dimensionality specified in the CREATE INDEX statement does not match that of the data.
Action:
Change the statement to reflect the data dimensionality.
ORA-13243: specified operator is not supported for 3- or higher-dimensional R-tree
Cause:
Currently, an R-tree index with three or more index dimensions can be used only with the SDO_FILTER operator.
Action:
Use the SDO_FILTER operator, and check the documentation for the querytype parameter for SDO_FILTER; or contact Oracle Support Services.
ORA-13249: string
Cause:
An internal error was encountered in the extensible spatial index component. The text of the message is obtained from some other server component.
Action:
ORA-13250: insufficient privileges to modify metadata table entries
Cause:
The user requesting the operation does not have the appropriate privileges on the referenced tables.
Action:
Check that the specified feature and geometry table names are correct, and then verify that the current user has at least SELECT privilege on those tables.
ORA-13251: duplicate entry string in metadata table
Cause:
The specified entry already exists in the metadata table.
Action:
Check that the specified feature and geometry table names are correct. A feature-geometry table association should be registered only once.
ORA-13260: layer table string does not exist
Cause:
Data migration source table layer_SDOGEOM does not exist.
Action:
Ensure that the specified layer name is correct and that the corresponding spatial layer tables exist in the current schema.
ORA-13261: geometry table string does not exist
Cause:
The specified geometry table does not exist in the current schema.
Action:
Create a table containing a column of type SDO_GEOMETRY and a column of type NUMBER for the GID values.
ORA-13262: geometry column string does not exist in table string
Cause:
The specified table does not have a column of type SDO_GEOMETRY.
Action:
Alter or re-create the table such that it includes a column of type SDO_GEOMETRY and a column of type NUMBER.
ORA-13263: column string in table string is not of type SDO_GEOMETRY
Cause:
The column intended for storing the geometry is not of type SDO_GEOMETRY.
Action:
Alter the column definition to be of type SDO_GEOMETRY.
ORA-13264: geometry identifier column string does not exist in table string
Cause:
The specified table does not contain a GID column.
Action:
Confirm that the GID column name was correctly specified and that it exists in the specified table.
ORA-13265: geometry identifier column string in table string is not of type NUMBER
Cause:
GID column is not of type NUMBER.
Action:
Alter the table definition such that the column containing the geometry identifier (GID) is of type NUMBER.
ORA-13266: error inserting data into table string
Cause:
An OCI error occurred, or the user has insufficient quota in the active tablespace, or the rollback segments are too small.
Action:
There should be an accompanying error message that indicates the cause of the problem. Take appropriate action to correct the indicated problem.
ORA-13267: error reading data from layer table string
Cause:
There was an error reading the geometry data from the layer_SDOGEOM table.
Action:
Verify that layer_SDOGEOM and layer_SDODIM exist. If they do exist, run VALIDATE_LAYER_WITH_CONTEXT on the specified layer.
ORA-13268: error obtaining dimension from USER_SDO_GEOM_METADATA
Cause:
There is no entry in the USER_SDO_GEOM_METADATA view for the specified geometry table.
Action:
Insert an entry for the destination geometry table with the correct dimension information.
ORA-13269: internal error [string] encountered when processing geometry table
Cause:
An internal error occurred.
Action:
Contact Oracle Support Services with the exact error message text.
ORA-13270: OCI error \nstring
Cause:
An OCI error occurred while processing the layer or geometry tables.
Action:
Take the appropriate steps to correct the OCI-specific error.
ORA-13271: error allocating memory for geometry object
Cause:
Insufficient memory.
Action:
Make more memory available to the current session/process.
ORA-13272: geometric object string in table string is invalid
Cause:
The specified object failed the geometric integrity checks performed by the validation function.
Action:
Check the Oracle Spatial documentation for information about the geometric integrity checks performed by VALIDATE_GEOMETRY_WITH_CONTEXT and correct the geometry definition if required.
ORA-13273: dimension metadata table string does not exist
Cause:
The layer_SDODIM table does not exist.
Action:
Verify that the specified layer name is correct and that the layer_SDODIM table exists in the current schema.
ORA-13274: operator invoked with non-compatible SRIDs
Cause:
A Spatial operator was invoked with a window geometry with an SRID but the layer has no SRID; or the window has no SRID but the layer has an SRID.
Action:
Make sure that the layer and window both have an SRID or that they both do not have an SRID.
ORA-13275: spatial index creation failure on unsupported type
Cause:
An attempt was made to create a spatial index create on a column that is not of type SDO_GEOMETRY.
Action:
A spatial index can only be created on a column of type SDO_GEOMETRY. Make sure the indexed column is of type SDO_GEOMETRY.
ORA-13276: internal error [string] in coordinate transformation
Cause:
OCI internal error.
Action:
ORA-13278: failure to convert SRID to native format
Cause:
OCI internal error.
Action:
ORA-13281: failure in execution of SQL statement to retrieve WKT
Cause:
OCI internal error, or SRID does not match a table entry.
Action:
Check that a valid SRID is being used.
ORA-13282: failure on initialization of coordinate transformation
Cause:
Parsing error on source or destination coordinate system WKT, or incompatible coordinate systems.
Action:
Check the validity of the WKT for table entries, and check if the requested transformation is valid.
ORA-13283: failure to get new geometry object for conversion in place
Cause:
OCI internal error.
Action:
ORA-13284: failure to copy geometry object for conversion in place
Cause:
OCI internal error.
Action:
ORA-13285: Geometry coordinate transformation error
Cause:
A coordinate pair was out of valid range for a conversion/projection.
Action:
Check that data to be transformed is consistent with the desired conversion/projection.
ORA-13287: can't transform unknown gtype
Cause:
A geometry with a gtype of <= 0 was specified for transformation. Only a gtype >= 1 is allowed.
Action:
Check the Oracle Spatial documentation for SDO_GTYPE values, and specify a value whose last digit is 1 or higher.
ORA-13288: point coordinate transformation error
Cause:
An internal error occurred while transforming points.
Action:
ORA-13290: the specified unit is not supported
Cause:
An Oracle Spatial function was called with an unknown UNIT value.
Action:
Check Spatial documentation for the supported units, and call the function with the correct UNIT parameter.
ORA-13291: conversion error between the specified unit and standard unit
Cause:
Cannot convert the specified unit from/to standard unit for linear distance, angle, or area.
Action:
Check the unit specification and respecify it.
ORA-13292: incorrect ARC_TOLERANCE specification
Cause:
When a SDO_BUFFER or SDO_AGGR_BUFFER function is called on a geodetic geometry, or SDO_ARC_DENSIFY is called, ARC_TOLERANCE must be specified, and it should not be less than the tolerance specified for the geometry.
Action:
Check ARC_TOLERANCE specification and make sure it is correct.
ORA-13293: cannot specify unit for geometry without a georeferenced SRID
Cause:
An Oracle Spatial function with a UNIT parameter was called on a geometry without a georeferenced SRID.
Action:
Make sure that spatial functions with UNIT parameters are only called on geometries with georeferenced SRIDs.
ORA-13294: cannot transform geometry containing circular arcs
Cause:
It is impossible to transform a 3-point representation of a circular arc without distortion.
Action:
Make sure a geometry does not contain circular arcs.
ORA-13295: geometry objects are in different coordinate systems
Cause:
An Oracle Spatial function was called with two geometries that have different SRIDs.
Action:
Transform geometry objects to be in the same coordinate system and call the spatial function.
ORA-13296: incorrect coordinate system specification
Cause:
Wrong numbers in WKT for Earth radius or flattening for the current SRID.
Action:
Check WKT in the MDSYS.CS_SRS table for Earth radius and inverse flattening.
ORA-13300: single point transform error
Cause:
Low-level coordinate transformation error trap.
Action:
ORA-13303: failure to retrieve a geometry object from a table
Cause:
OCI internal error.
Action:
ORA-13304: failure to insert a transformed geometry object in a table
Cause:
OCI internal error.
Action:
ORA-13330: invalid MASK
Cause:
The MASK passed to the RELATE function is not valid.
Action:
Verify that the mask is not NULL. See the Oracle Spatial documentation for a list of supported masks.
ORA-13331: invalid LRS segment
Cause:
The given LRS segment was not a valid line string.
Action:
A valid LRS geometric segment is a line string geometry in Oracle Spatial. It could be a simple or compound line string (made of lines or arcs, or both). The dimension information must include the measure dimension as the last element in the Oracle Spatial metadata. Currently, the number of dimensions for an LRS segment must be greater than 2 (x/y or longitude/latitude, plus measure)
ORA-13332: invalid LRS point
Cause:
The specified LRS point was not a point geometry with measure information.
Action:
Check the given point geometry. A valid LRS point is a point geometry in Oracle Spatial with an additional dimension for measure.
ORA-13333: invalid LRS measure
Cause:
The given measure for linear referencing was out of range.
Action:
Redefine the measure.
ORA-13334: LRS segments not connected
Cause:
The specified geometric segments are not connected.
Action:
Check the start/end points of the given geometric segments.
ORA-13335: LRS measure information not defined
Cause:
The measure information of a geometric segment was not assigned (IS NULL).
Action:
Assign/define the measure information. An LRS geometric segment is defined if its start and end measure are assigned (non-null).
ORA-13336: failure in converting standard diminfo/geometry to LRS dim/geom
Cause:
There is no room for the measure dimension in the given diminfo, or the specified standard geometry is not a point a line string.
Action:
Check if the diminfo dimensions are less than 3 or if the geometry type is point or line string.
ORA-13337: failure in concatenating LRS polygons
Cause:
LRS concatenation involving LRS polygons is not supported.
Action:
Check the geometry and element types to make sure the concatenate operation is not called with a polygon type.
ORA-13338: failure in reversing LRS polygon/collection geometry
Cause:
Reversing an LRS polygon/collection geometry produces an invalid geometry.
Action:
Check the geometry type to make sure this operation is called on non-polygon geometries.
ORA-13339: LRS polygon clipping across multiple rings
Cause:
Clipping (dynseg) a polygon across multiple rings is not allowed.
Action:
Polygon clipping is allowed only for a single ring.
ORA-13340: a point geometry has more than one coordinate
Cause:
A geometry, specified as being a point, has more than one coordinate in its definition.
Action:
A point has only one coordinate. If this geometry is intended to represent a point cluster, line, or polygon, set the appropriate SDO_GTYPE or SDO_ETYPE value. If this is a single point object, remove the extraneous coordinates from its definition.
ORA-13341: a line geometry has fewer than two coordinates
Cause:
A geometry, specified as being a line, has fewer than two coordinates in its definition.
Action:
A line must consist of at least two distinct coordinates. Correct the geometric definition, or set the appropriate SDO_GTYPE or SDO_ETYPE attribute for this geometry.
ORA-13342: an arc geometry has fewer than three coordinates
Cause:
A geometry, specified as being an arc, has fewer than three coordinates in its definition.
Action:
An arc must consist of at least three distinct coordinates. Correct the geometric definition, or set the appropriate SDO_GTYPE or SDO_ETYPE attribute for this geometry.
ORA-13343: a polygon geometry has fewer than four coordinates
Cause:
A geometry, specified as being a polygon, has fewer than four coordinates in its definition.
Action:
A polygon must consist of at least four distinct coordinates. Correct the geometric definition, or set the appropriate SDO_GTYPE or SDO_ETYPE attribute for this geometry.
ORA-13344: an arcpolygon geometry has fewer than five coordinates
Cause:
A geometry, specified as being an arcpolygon, has fewer than five coordinates in its definition.
Action:
An arcpolygon must consist of at least five coordinates. An arcpolygon consists of an ordered sequence of arcs, each of which must be described using three coordinates. Since arcs are connected the end-point of the first is the start of the second and does not have to be repeated. Correct the geometric definition, or set the appropriate SDO_GTYPE or SDO_ETYPE attribute for this geometry.
ORA-13345: a compound polygon geometry has fewer than five coordinates
Cause:
A geometry, specified as being a compound polygon, has fewer than five coordinates in its definition.
Action:
A compound polygon must contain at least five coordinates. A compound polygon consists of at least one arc and one line, each of which must be described using three and at least two distinct coordinates respectively. Correct the geometric definition, or set the appropriate SDO_GTYPE or SDO_ETYPE attribute for this geometry.
ORA-13346: the coordinates defining an arc are collinear
Cause:
Invalid definition of an arc. An arc is defined using three non-collinear coordinates.
Action:
Alter the definition of the arc, or set the SDO_ETYPE or SDO_GTYPE to the line type.
ORA-13347: the coordinates defining an arc are not distinct
Cause:
Two or more of the three points defining an arc are the same.
Action:
Alter the definition of the arc to ensure that three distinct coordinate values are used.
ORA-13348: polygon boundary is not closed
Cause:
The boundary of a polygon does not close.
Action:
Alter the coordinate values or the definition of the SDO_GTYPE or SDO_ETYPE attribute of the geometry.
ORA-13349: polygon boundary crosses itself
Cause:
The boundary of a polygon intersects itself.
Action:
Correct the geometric definition of the object.
ORA-13350: two or more rings of a complex polygon touch
Cause:
The inner or outer rings of a complex polygon touch.
Action:
All rings of a complex polygon must be disjoint. Correct the geometric definition of the object.
ORA-13351: two or more rings of a complex polygon overlap
Cause:
The inner or outer rings of a complex polygon overlap.
Action:
ORA-13352: the coordinates do not describe a circle
Cause:
The set of coordinates used to describe a circle are incorrect.
Action:
Confirm that the set of coordinates actually represent points on the circumference of a circle.
ORA-13353: ELEM_INFO_ARRAY not grouped in threes
Cause:
The ELEM_INFO_ARRAY in an SDO_GEOMETRY definition has more or fewer elements than expected.
Action:
Confirm that the number of elements in ELEM_INFO_ARRAY is divisible by 3.
ORA-13354: incorrect offset in ELEM_INFO_ARRAY
Cause:
The offset field in ELEM_INFO_ARRAY of an SDO_GEOMETRY definition references an invalid array subscript in SDO_ORDINATE_ARRAY.
Action:
Confirm that the offset is a valid array subscript in SDO_ORDINATE_ARRAY.
ORA-13355: SDO_ORDINATE_ARRAY not grouped by number of dimensions specified
Cause:
The number of elements in SDO_ORDINATE_ARRAY is not a multiple of the number of dimensions supplied by the user.
Action:
Confirm that the number of dimensions is consistent with data representation in SDO_ORDINATE_ARRAY.
ORA-13356: adjacent points in a geometry are redundant
Cause:
There are repeated points in the sequence of coordinates.
Action:
Remove the redundant point.
ORA-13357: extent type does not contain 2 points
Cause:
Extent type should be represented by two points: lower left and upper right.
Action:
Confirm that there are only two points for an extent type.
ORA-13358: circle type does not contain 3 points
Cause:
Circle type should be represented by three distinct points on the circumference.
Action:
Confirm that there are only three points for a circle type.
ORA-13359: extent does not have an area
Cause:
The two points representing the extent are identical.
Action:
Confirm that the two points describing the extent type are distinct.
ORA-13360: invalid subtype in a compound type
Cause:
This subtype is not allowed within the ETYPE specified.
Action:
Check the Oracle Spatial documentation for type definitions.
ORA-13361: not enough sub-elements within a compound ETYPE
Cause:
The compound type declare more sub-elements than actually defined.
Action:
Confirm that the number of sub-elements is consistent with the compound type declaration.
ORA-13362: disjoint sub-element in a compound polygon
Cause:
Compound polygon must describe an enclosed area.
Action:
Confirm that all sub-elements are connected.
ORA-13363: no valid ETYPE in the geometry
Cause:
None of the ETYPEs within the geometry is supported.
Action:
Confirm that there is at least one valid ETYPE.
ORA-13364: layer dimensionality does not match geometry dimensions
Cause:
The spatial layer has a geometry with a different dimensions than the dimensions specified for the layer.
Action:
Make sure that all geometries in a layer have the same dimensions and that they match the dimensions in the SDO_DIM_ARRAY object for the layer in the USER_SDO_GEOM_METADATA view.
ORA-13365: layer SRID does not match geometry SRID
Cause:
The spatial layer has a geometry with a different SRID than the SRID specified for the layer.
Action:
Make sure that all geometries in a layer have the same SRID and that the SRIDs match the SRID for the layer in the USER_SDO_GEOM_METADATA view.
ORA-13366: invalid combination of interior exterior rings
Cause:
In an Oracle Spatial geometry, interior and exterior rings are not used consistently.
Action:
Make sure that the interior rings corresponding to an exterior ring follow the exterior ring in the ordinate array.
ORA-13367: wrong orientation for interior/exterior rings
Cause:
In an Oracle Spatial geometry, the exterior and/or interior rings are not oriented correctly.
Action:
Be sure that the exterior rings are oriented counterclockwise and the interior rings are oriented clockwise.
ORA-13368: simple polygon type has more than one exterior ring
Cause:
In a polygon geometry there is more than one exterior ring.
Action:
Set the type to be multipolygon if more than one exterior ring is present in the geometry.
ORA-13369: invalid value for etype in the 4-digit format
Cause:
A 4-digit etype for a non-polygon type element is used, or the orientation is not a valid orientation for interior/exterior rings of the polygon.
Action:
Correct the geometry definition.
ORA-13370: failure in applying 3D LRS functions
Cause:
Only non-geodetic 3D line string geometries (made of line segments) are supported for 3D LRS functions.
Action:
Check the geometry and element types and the SRID values.
ORA-13371: invalid position of measure dimension
Cause:
LRS measure dimension has to be after spatial dimensions. The position has to be either 3rd or 4th in the dim_info_array.
Action:
Check the geometry's gtype and its position in the dim_info_array.
ORA-13372: failure in modifying metadata for a table with spatial index
Cause:
Modifying the metadata after the index is created will cause an inconsistency between the geometry's gtype and diminfo.
Action:
Modify (or Prepare) metadata before creating an index on the SDO_GEOMETRY column.
ORA-13373: invalid line segment in geodetic data
Cause:
A geodetic line segment was not less than half of a great circle.
Action:
Densify the line by adding points.
ORA-13374: SDO_MBR not supported for geodetic data
Cause:
The SDO_MBR functionality is not supported for geodetic data.
Action:
Find an alternative function that can be used in this context.
ORA-13375: the layer is of type [string] while geometry inserted has type [string]
Cause:
The layer has a type that is different or inconsistent with the type of the current geometry.
Action:
Change the geometry type to agree with the layer type, or change the layer type to agree with the geometry type.
ORA-13376: invalid type name specified for layer_gtype parameter
Cause:
An invalid type name is specified for the layer_gtype constraint.
Action:
See the Spatial documentation for of valid keywords that can be used in defining a layer_gtype constraint.
ORA-13377: invalid combination of elements with orientation
Cause:
An element of the geometry has orientation specified while some other element has no orientation specified (4-digit etype).
Action:
Make sure all the polygon elements have orientation specified using the 4-digit etype notation.
ORA-13378: invalid index for element to be extracted
Cause:
An invalid (or out of bounds) index was specified for extracting an element from a geometry.
Action:
Make sure the parameters to the extract function are in the valid range for the geometry.
ORA-13379: invalid index for sub-element to be extracted
Cause:
An invalid (or out of bounds) index was specified for extracting a sub-element from a geometry.
Action:
ORA-13380: network not found
Cause:
The specified network was not found in the network metadata.
Action:
Insert the network information in the USER_SDO_NETWORK_METADATA view.
ORA-13381: table:string not found in network:string
Cause:
The specified table was not found in the network metadata.
Action:
Insert the table information in the USER_SDO_NETWORK_METADATA view.
ORA-13382: geometry metadata (table:string column:string) not found in spatial network:string
Cause:
The specified geometry metadata was not found in the spatial network metadata.
Action:
Insert the spatial metadata information in the USER_SDO_NETWORK_METADATA view.
ORA-13383: inconsistent network metadata: string
Cause:
There was an inconsistency between the network metadata and the node/link information.
Action:
Check the network metadata and the node/link information.
ORA-13384: error in network schema: string
Cause:
The network table(s) did not have required column(s)
Action:
Check the network schema.
ORA-13385: error in network manager: [string]
Cause:
There was an internal error in network manager.
Action:
Contact Oracle Customer Support for more help.
ORA-13386: commit/rollback operation error: [string]
Cause:
The index-level changes were not fully incorporated as part of the commit or rollback operation.
Action:
Correct the specified error and use the following statement: ALTER INDEX index-name PARAMETERS ('index_status=synchronize');
ORA-13387: sdo_batch_size for array inserts should be in the range [number,number]
Cause:
The specified value for sdo_batch_size was too high or too low.
Action:
Change the value to be in the specified range.
ORA-13388: invalid value for dst_spec parameter
Cause:
The dst_spec parameter was specified in the wrong format.
Action:
Check the documentation for this parameter.
ORA-13389: unable to compute buffers or intersections in analysis function
Cause:
There was an internal error in computing the buffers or intersections in the specified spatial analysis function.
Action:
Modify the tolerance value in the USER_SDO_GEOM_METADATA view before invoking the spatial analysis function.
ORA-13390: error in spatial analysis and mining function: [string]
Cause:
There was an internal error in the specified analysis function.
Action:
ORA-13391: string
Cause:
An attempt was made to violate GeoRaster management restrictions.
Action:
Check the documentation for more detailed information.
ORA-13392: status report error: string
Cause:
There was an error on status report related operation.
Action:
Check the error message for details.
ORA-13393: null or invalid string parameter
Cause:
The operation failed because the input parameter was null or invalid.
Action:
Correct the parameter and try again.
ORA-13397: different dimension sizes in the input GeoRaster objects
Cause:
The two input GeoRaster objects had different dimension sizes.
Action:
Check the documentation and make sure the dimension size is same for both input GeoRaster objects.
ORA-13398: invalid expression parameter: string
Cause:
The expression parameter was not a valid math expression.
Action:
Check the documentation and make sure the expression parameter is correct.
ORA-13399: invalid condition parameter: string
Cause:
The condition parameter was not a valid boolean expression.
Action:
Check the documentation and make sure the condition parameter is correct.
ORA-13400: duplicate entry for string in USER_SDO_GEOR_SYSDATA view
Cause:
The current operation caused a duplicate RASTER_DATA_TABLE and RASTER_ID combination to be inserted into the USER_SDO_GEOR_SYSDATA view.
Action:
Ensure that the RASTER_DATA_TABLE and RASTER_ID combination to be inserted into the USER_SDO_GEOR_SYSDATA view is unique.
ORA-13401: duplicate entry for string in USER_SDO_GEOR_SYSDATA view
Cause:
The RASTER_DATA_TABLE and RASTER_ID columns contained the same information in two or more rows in the USER_SDO_GEOR_SYSDATA view.
Action:
Ensure that the RASTER_DATA_TABLE and RASTER_ID columns in the USER_SDO_GEOR_SYSDATA view contain the correct information, and that the value pair is unique for each row.
ORA-13402: the rasterType is null or not supported
Cause:
The specified rasterType was null or not supported.
Action:
Check the documentation for the rasterType number and/or formats supported by GeoRaster.
ORA-13403: invalid rasterDataTable specification: string
Cause:
Each GeoRaster object must have an associated raster data table whose name is unique among raster data table names in the database. If the GeoRaster object is not empty and not blank, the raster data table must exist, be visible in the current schema, be defined in the same schema as the GeoRaster data table, and be an object table of SDO_RASTER type. However, one or more of these requirements were not met.
Action:
Check the rasterDataTable specification and ensure that all relevant raster data table requirements are met.
ORA-13404: invalid ultCoordinate parameter
Cause:
The ultCoordinate array parameter had the wrong length or contained an invalid value.
Action:
Check the documentation, and make sure the ultCoordinate parameter is correct.
ORA-13405: null or invalid dimensionSize parameter
Cause:
The dimensionSize array parameter was null, had the wrong length, or contained an invalid value.
Action:
Check the documentation, and make sure the dimensionSize parameter is correct.
ORA-13406: null or invalid GeoRaster object for output
Cause:
The GeoRaster object for output was null or invalid.
Action:
Make sure the GeoRaster object for output has been initialized properly.
ORA-13407: invalid storage parameterstring
Cause:
The storage parameter contained an invalid specification.
Action:
Check the documentation, and make sure the storage parameter is correct.
ORA-13408: invalid blockSize storage parameter
Cause:
The blockSize storage parameter had the wrong length or contained invalid value.
Action:
Check the documentation, and make sure the blockSize storage parameter is correct.
ORA-13409: null or invalid pyramidLevel parameter
Cause:
The specified pyramidLevel parameter was null or invalid.
Action:
Make sure the pyramidLevel parameter specifies a valid pyramid level value for the GeoRaster object.
ORA-13410: invalid layerNumbers or bandNumbers parameter
Cause:
The layerNumbers or bandNumbers parameter was invalid.
Action:
Check the documentation and make sure the layerNumbers or bandNumbers parameter is valid.
ORA-13411: subset results in null data set
Cause:
The intersection of cropArea and source GeoRaster object was null.
Action:
Check the documentation, and make sure the cropArea parameter is correct.
ORA-13412: invalid scale parameterstring
Cause:
The scale parameter contained an invalid specification.
Action:
Check the documentation, and make sure the scale parameter is correct.
ORA-13413: null or invalid resampling parameter
Cause:
The resampling parameter was null or invalid.
Action:
Check the documentation, and make sure the resampling parameter is correct.
ORA-13414: invalid pyramid parameter
Cause:
The pyramid parameter was invalid.
Action:
Check the documentation, and make sure the pyramid parameter is correct.
ORA-13415: invalid or out of scope point specification
Cause:
The point position specified by the <ptGeom, layerNumber> or <rowNumber, colNumber, bandNumber> parameter combination was invalid or out of scope.
Action:
Make sure the parameter(s) specify a valid point that is or can be translated into a cell position inside the cell space of the GeoRaster object.
ORA-13416: invalid geometry parameter
Cause:
The geometry parameter did not specify a valid single-point geometry.
Action:
Specify a valid single-point geometry.
ORA-13417: null or invalid layerNumber parameter
Cause:
The layerNumber parameter was null or out of scope.
Action:
Specify a valid layerNumber parameter.
ORA-13418: null or invalid parameter(s) for set functions
Cause:
A parameter for set metadata operations was null or invalid.
Action:
Check the documentation for information about the parameters.
ORA-13419: cannot perform mosaic operation: string
Cause:
An attempt to perform a mosaic operation failed.
Action:
ORA-13420: the SRID of the geometry parameter was not null
Cause:
The input geometry must be in the GeoRaster cell space, which has a null SRID value.
Action:
Make sure the geometry parameter has a null SRID.
ORA-13421: NULL or invalid cell value
Cause:
The cell value was NULL or out-of-scope.
Action:
Make sure the cell value is not NULL and is in the range as designated by the cellDepth definition of the specified GeoRaster object.
ORA-13422: invalid model coordinate parameter
Cause:
The model coordinate array parameter had the wrong length or had null ordinate element(s).
Action:
Make sure the model coordinate parameter is valid.
ORA-13423: invalid cell coordinate parameter
Cause:
The cell coordinate array parameter had the wrong length or had null ordinate element(s).
Action:
Make sure the cell coordinate parameter is valid.
ORA-13424: the GeoRaster object is not spatially referenced
Cause:
The GeoRaster object was not spatially referenced.
Action:
Make sure the GeoRaster object is spatially referenced.
ORA-13425: invalid background filling value parameter
Cause:
The background filling value parameter was invalid either because the array had the wrong size or because some of the element values were invalid.
Action:
Make sure the parameter that specifies the background filling value is valid. The size of the array must equal to either 1 (the value is for all bands) or the exact band dimension size. The element values must be valid cell values as determined by the cell depth.
ORA-13426: invalid window parameter
Cause:
The specified window parameter was invalid.
Action:
Specify a valid window parameter. Check the documentation for details.
ORA-13427: invalid bitmap mask
Cause:
The bitmap mask was not a valid 1BIT GeoRaster object, or it had the wrong dimension sizes.
Action:
Make sure the bitmap mask is a valid 1BIT GeoRaster object with only one band, and the row and column dimension sizes of the bitmap mask are the same as those of the target GeoRaster object.
ORA-13428: invalid modelCoordinateLocation
Cause:
The program [or user] specified a modelCoordinateLocation that is not supported, or the modelCoordinateLocation of the GeoRaster object was wrong.
Action:
Set or specify the modelCoordinateLocation to be CENTER (0) or UPPERLEFT (1).
ORA-13429: invalid xCoefficients or yCoefficients parameter(s)
Cause:
An attempt to perform a georeference operation failed. Possible reasons include xCoefficients or yCoefficients having the wrong number of coefficients or invalid coefficients.
Action:
Check the documentation for supported coefficient specifications.
ORA-13430: the GeoRaster object has null attribute(s)
Cause:
The metadata or rasterType of the GeoRaster object was null.
Action:
This object may only be used as an output parameter of procedures or functions. It is not valid for other purposes.
ORA-13431: GeoRaster metadata rasterType error
Cause:
The rasterType in the metadata of the GeoRaster object was inconsistent with the GeoRaster rasterType attribute.
Action:
Make sure the rasterType in the metadata of the GeoRaster object and the GeoRaster rasterType attribute have the same value.
ORA-13432: NULL or invalid blankCellValue
Cause:
The blankCellValue element could not be found in the metadata of a blank GeoRaster object, or the specified blankCellValue element value was NULL or invalid.
Action:
Call SDO_GEOR.setBlankCellValue to add blankCellValue to the metadata whenever the isBlank element value is TRUE, and make sure that the specified blankCellValue element value is not NULL and is in the range as designated by the cellDepth definition of the GeoRaster object.
ORA-13433: GeoRaster metadata default RGB error
Cause:
At least one of the defaultRed, defaultGreen, and defaultBlue values (logical layer numbers) was zero, negative, or out of range.
Action:
ORA-13434: GeoRaster metadata cellRepresentation error
Cause:
The cellRepresentation type was not supported.
Action:
Check the documentation for supported cellRepresentation types.
ORA-13435: GeoRaster metadata dimension inconsistent
Cause:
The specification of dimensions or totalDimensions was inconsistent with rasterType, or vice versa.
Action:
Make sure dimension specifications are consistent.
ORA-13436: GeoRaster metadata dimensionSize error
Cause:
Either the dimensionSize for each dimension was not specified, or an extraneous dimensionSize was specified.
Action:
Add a dimsenionSize for each dimension of the GeoRaster object and delete extra dimensionSize elements.
ORA-13437: GeoRaster metadata blocking error
Cause:
Either the wrong block number(s) or block size(s) along dimensions were specified, or the block numbers and sizes when taken together were not consistent.
Action:
ORA-13438: GeoRaster metadata pyramid type error
Cause:
The specified pyramid type was not supported.
Action:
Check the documentation for supported pyramid types.
ORA-13439: GeoRaster metadata pyramid maxLevel error
Cause:
The specified maxLevel exceeded the maximum level allowed by the specified pyramid type.
Action:
Check the documentation for supported pyramid types and their total level limitations.
ORA-13440: GeoRaster metadata compression type error
Cause:
The specified compression type was not supported.
Action:
Check the documentation for supported compression types.
ORA-13441: GeoRaster metadata SRS error: string
Cause:
The specified error relates to the polynomialModel element in the Spatial Reference System (SRS) metadata.
Action:
Check the documentation and make sure that a valid polynomial model is specified.
ORA-13442: GeoRaster object not registered: string
Cause:
There was no sysdata entry for the specified GeoRaster object.
Action:
Make sure that a sysdata entry has been inserted for the specified GeoRaster object.
ORA-13443: null or invalid values in string
Cause:
There were null or invalid component values in the specified metadata.
Action:
Check the documentation and make sure that all the component values are valid.
ORA-13444: cannot perform mergeLayers operation
Cause:
The two GeoRaster objects whose layers are to be combined together either had different row or column dimension sizes, or their georeferencing information did not match.
Action:
Make sure the objects have the same row and column dimension sizes. If neither is georeferenced, their ULTCoordinate values must be the same. Otherwise, they must be both georeferenced and cover the same area in the model space.
ORA-13445: NULL or invalid NODATA value or value range
Cause:
There was invalid NODATA value or value range in the metadata, or the specified NODATA value or value range was invalid.
Action:
Make sure the NODATA value or value range is not NULL and is completely contained in the range as designated by the cellDepth definition of the specified GeoRaster object.
ORA-13446: GeoRaster metadata TRS error
Cause:
The GeoRaster Temporal Reference System was not supported.
Action:
Set isReferenced to FALSE.
ORA-13447: GeoRaster metadata BRS error
Cause:
The GeoRaster Band Reference System was not supported.
Action:
ORA-13448: GeoRaster metadata BRS error
Cause:
The GeoRaster spectral extent specification was incorrect.
Action:
The MIN value must be less than the MAX value in the spectralExtent element.
ORA-13449: GeoRaster metadata ULTCoordinate error
Cause:
The GeoRaster rasterInfo ULTCoordinate was not correct.
Action:
Check the documentation for restrictions.
ORA-13450: GeoRaster metadata layerInfo error
Cause:
The GeoRaster had more than one layerInfo element, or the layerDimension value was not supported.
Action:
The current release only supports one layerInfo element; layer can only be defined along one dimension, and this dimension must be BAND.
ORA-13451: GeoRaster metadata scaling function error
Cause:
The scaling function had a zero denominator.
Action:
Make sure the scaling function denominator is not zero.
ORA-13452: GeoRaster metadata BIN function error
Cause:
The bin function data did not match its type.
Action:
For EXPLICIT type, provide a binTableName element; otherwise, provide a binFunctionData element.
ORA-13453: GeoRaster metadata layer error
Cause:
Too many subLayers were defined for the GeoRaster object, or layerNumber or layerDimensionOrdinate was not assigned correctly.
Action:
The total number of logical layers cannot exceed the total number of physical layers, and each logical layer must be assigned a valid physical layer number following the same order. Check the documentation for more details.
ORA-13454: GeoRaster metadata is invalid
Cause:
The GeoRaster metadata was invalid against its XML Schema.
Action:
Run the schemaValidate routine to find the errors.
ORA-13455: GeoRaster metadata TRS error
Cause:
The beginDateTime value was later than the endDateTime value.
Action:
Make sure that the beginDateTime value is not later than the endDateTime value.
ORA-13456: GeoRaster cell data error: string
Cause:
There was an error in the original GeoRaster cell data or in the cell data of the pyramids.
Action:
If the error is related to the original GeoRaster cell data, the GeoRaster object is invalid and has to be deleted or manually repaired. If the error is related to pyramids, delete the pyramids and regenerate them.
ORA-13457: bitmap mask cell data error: string
Cause:
There was an error in the cell data of an original bitmap mask or in the cell data of the pyramids of a bitmap mask.
Action:
If the error is related to an original bitmap mask, remove the bitmap mask. If the error is related to the pyramids of a bitmap mask, delete the pyramids and regenerate them.
ORA-13458: GeoRaster metadata SRS error
Cause:
The polynomial model did not match the requirements of a rectified GeoRaster object.
Action:
Check the documentation for the requirements of the polynomial model for a rectified GeoRaster object, or set isRectified to be false.
ORA-13459: GeoRaster metadata SRS error
Cause:
The polynomial model was not an six-parameter transformation, or the six-parameter transformation was not valid.
Action:
Check the documentation and make sure the polynomial model is a valid six-parameter affine transformation.
ORA-13460: GeoRaster metadata SRS error
Cause:
The referenced GeoRaster object had a zero model space SRID or the specified model space SRID was zero.
Action:
Set or specify the model space SRID to be a nonzero number.
ORA-13461: the interleaving type is not supported
Cause:
The interleaving type of the GeoRaster object was not supported.
Action:
Check the documentation for the interleaving types supported by GeoRaster. Use SDO_GEOR.changeFormatCopy to transform the image to a supported interleaving type.
ORA-13462: invalid blocking specification
Cause:
The specified blocking configuration was invalid.
Action:
Check the documentation for the blocking specification supported by GeoRaster.
ORA-13463: error retrieving GeoRaster data: string
Cause:
An internal error occurred while retrieving GeoRaster data from the database.
Action:
ORA-13464: error loading GeoRaster data: string
Cause:
An internal error occurred while loading GeoRaster data into the database.
Action:
ORA-13465: null or invalid table or column specification
Cause:
The specified table or column did not exist, or the column was not a GeoRaster column.
Action:
Make sure the specified table exists and the specified column is a GeoRaster column.
ORA-13466: format not appropriate for specified compression method: string
Cause:
The operation failed because the GeoRaster object had an inappropriate type or format for the specified compression method. The GeoRaster type or format is not supported for the specified compression.
Action:
Check the error message for details. Check the documentation for the appropriate GeoRaster types and formats for each compression method. Use SDO_GEOR.changeFormatCopy to transform the GeoRaster object to an appropriate format, or apply another compression method.
ORA-13467: unsupported GeoRaster metadata specification: string
Cause:
The GeoRaster metadata specification is not supported.
Action:
Check the documentation for the supported GeoRaster metadata specifications.
ORA-13468: invalid blockMBR
Cause:
Invalid blockMBR geometries were stored in the raster data table.
Action:
Make sure the blockMBR geometries stored in the raster data table are valid, or call SDO_GEOR.generateBlockMBR() to regenerate the blockMBR geometries.
ORA-13469: cannot perform updateRaster operation
Cause:
The data of the source GeoRaster object could not be used to update that of the target GeoRaster object.
Action:
Make sure the source and the target GeoRaster objects have the same cell depth, and that both objects are either georeferenced or not georeferenced at all. If both are georeferenced, they should be in the same coordinate system and have the same spatial resolutions.
ORA-13470: target and source layers or bands mismatched
Cause:
The number of specified target layers or bands and source layers or bands did not match.
Action:
When updating layers or bands of a target GeoRaster object to reflect the associated layers or bands of the source GeoRaster object, specify the same number of layers or bands for both the source and the target objects. Check the documentation for details.
ORA-13471: unable to determine the owner of string
Cause:
The owner of the specified raster data table could not be determined.
Action:
Make sure the GeoRaster object that refers to the raster data table has been registered by inserting the object into a GeoRaster table.
ORA-13472: invalid geometry parameter
Cause:
The geometry parameter did not specify a valid geometry.
Action:
Specify a valid 2D or 3D geometry. If the model SRID is null or indicates a 2D coordinate system, the geometry must be 2D. If the model SRID indicates a 3D coordinate system, the geometry must either be a 3D geometry or a 2D geometry that can be converted to 3D with the specified vertical axis (or vertical SRID) and ellipsoidal parameters.
ORA-13473: invalid rasterSpec parameter
Cause:
The rasterSpec parameter contained an invalid specification.
Action:
Check the documentation and make sure the rasterSpec parameter contains only valid keywords and values.
ORA-13474: invalid rasterDataTable name: string
Cause:
The rasterDataTable name was not a valid nonquoted identifier, it contained a period separator, or not all of the alphanumeric characters were uppercase.
Action:
Ensure that the table name is a valid nonquoted identifier without any period separators, and that all the alphanumeric characters are uppercase.
ORA-13475: invalid GeoRaster object for output
Cause:
The output GeoRaster object had the same RASTER_DATA_TABLE and RASTER_ID combination as that of an input GeoRaster object.
Action:
Ensure that the output GeoRaster object is different from any of the input GeoRaster objects.
ORA-13476: invalid or out of scope point specification
Cause:
The point position specified by the point geometry parameter or the rowNumber/colNumber parameter combination was null or out of scope.
Action:
Ensure that the parameters specify a valid point that translates or can be translated into a cell position inside the cell space of the GeoRaster object.
ORA-13477: invalid GCP georeferencing specification: string
Cause:
The specified functional fitting method was not supported, the number of GCPs was insufficient, some GCPs were invalid, or the distribution of the GCPs led to no solution or an unstable solution.
Action:
Check the GeoRaster documentation for the supported functional fitting methods and the requirements of GCPs.
ORA-13478: the target SRID is the same as the source GeoRaster object's SRID
Cause:
The target SRID was not different from the source GeoRaster object's SRID.
Action:
Specify a different valid SRID for the target GeoRaster object.
ORA-13479: cannot reproject
Cause:
Reprojection from source to destination projection produced a large distortion.
Action:
Check the destination projection and make sure it is suitable for the area covered by the source GeoRaster object. Check the GeoRaster documentation for more information about reprojection.
ORA-13480: the Source Type is not supported
Cause:
The specified source type was not supported.
Action:
Check the documentation for the source types (such as FILE and HTTP) supported by GeoRaster.
ORA-13481: the destination type is not supported
Cause:
The specified destination type was not supported.
Action:
Check the documentation for the destination types (such as FILE) supported by GeoRaster.
ORA-13482: GeoRaster object is not initialized for the image
Cause:
No GeoRaster object has been initialized for the specified image.
Action:
Initialize a GeoRaster object to hold this image before loading it into the database. Check the documentation for details.
ORA-13483: insufficient memory for the specified GeoRaster data
Cause:
There was insufficient memory to hold the specified GeoRaster data for this operation.
Action:
Use SDO_GEOR.subset to isolate a subset of the GeoRaster data, or reblock the GeoRaster data into smaller sized blocks. Check the documentation for details.
ORA-13484: the file format or compression type is not supported: string
Cause:
The file format or compression type was not supported.
Action:
Check the documentation for formats that are currently supported by GeoRaster.
ORA-13485: error occurred during compression or decompression: string
Cause:
The operation could not be completed because an error occurred during compression or decompression. Check the error message for details.
Action:
Check that the GeoRaster object is valid, that its metadata is valid for the specified compression format, and that valid parameters are passed into the compression or decompression operation.
ORA-13486: invalid or insufficient GeoTIFF metadata to georeference the GeoRaster object: string
Cause:
The GeoTIFF metadata of the specified input image contained invalid or insufficient information to georeference the GeoRaster object.
Action:
ORA-13487: SRID not found for source coordinate system metadata
Cause:
No SRID was found in the Oracle Spatial CS_SRS table to match the source coordinate system metadata.
Action:
Add a user-defined coordinate reference system for this coordinate system, as explained in the Oracle Spatial documentation.
ORA-13488: cannot perform transformation: string
Cause:
An attempt to perform a transformation operation failed.
Action:
ORA-13497: string
Cause:
This is an internal GeoRaster error.
Action:
Contact Oracle Support Services. You may want to make sure the GeoRaster object is valid before you do so.
ORA-13498: string
Cause:
An error related to an external plugin was encountered in the GeoRaster component.
Action:
Check the documentation for the external plugin, or contact the plugin provider and supply the exact error text.
ORA-13499: string
Cause:
This is an internal Spatial error.
Action:
ORA-13500: SYSAUX DATAFILE clause specified more than once
Cause:
The CREATE DATABASE command contains more than one SYSAUX DATAFILE clause.
Action:
Specify at most one SYSAUX DATAFILE clause.
ORA-13501: Cannot drop SYSAUX tablespace
Cause:
Tried to drop SYSAUX tablespace
Action:
None
ORA-13502: Cannot rename SYSAUX tablespace
Cause:
An attempt to rename the SYSAUX tablespace failed.
Action:
No action required.
ORA-13503: Creating SYSAUX tablespace with invalid attributes
Cause:
An attempt to create the SYSAUX tablespace with invalid attributes.
Action:
Create SYSAUX tablespace with ONLINE, PERMANENT, EXTENT MANAGEMENT LOCAL, SEGMENT SPACE MANAGEMENT AUTO attributes.
ORA-13504: No SYSAUX datafile clause specified
Cause:
If Create Database has the datafile clause, then SYSAUX datafile clause has to be specified, unless using OMF.
Action:
Specify the SYSAUX datafile clause.
ORA-13505: SYSAUX tablespace can not be made read only
Cause:
Attempting to set the SYSAUX tablespace to read only. The SYSAUX tablespace must remain read write for database operation.
Action:
Leave SYSAUX tablespace read write.
ORA-13506: operation failed due to invalid snapshot range (string, string)
Cause:
An attempt was made to perform operation with an invalid Start/End Snapshot Pair.
Action:
Choose a valid Start/End Snapshot Pair.
ORA-13509: error encountered during updates to a AWR table
Cause:
An update error occurred during OCI operation due to an underlying error.
Action:
Check associated OCI error. Correct problem and retry the operation.
ORA-13510: invalid RETENTION string, must be in the range (string, string)
Cause:
The user has specified a RETENTION setting that is not in the supported range of (MIN, MAX).
Action:
Choose a valid RETENTION setting and retry the operation.
ORA-13511: invalid INTERVAL string, must be in the range (string, string)
Cause:
The user has specified a INTERVAL setting that is not in the supported range of (MIN, MAX).
Action:
Choose a valid INTERVAL setting and retry the operation.
ORA-13514: Metric Capture too close to last capture, group string
Cause:
The metric capture cannot be executed because it is too close to the last capture (within 1 centi-second).
Action:
add some delay and reissue command to retry.
ORA-13515: Error encountered during Database Usage Statistics capture
Cause:
Error occurred during OCI operation due to underlying error.
Action:
ORA-13516: AWR Operation failed: string
Cause:
The operation failed because AWR is not available. The possible causes are: AWR schema not yet created; AWR not enabled; AWR schema not initialized; or database not open or is running in READONLY or STANDBY mode.
Action:
check the above conditions and retry the operation.
ORA-13517: Baseline (id = string) does not exist
Cause:
The operation failed because the specified baseline ID does not exist in the Workload Repository.
Action:
check the baseline id and retry the operation.
ORA-13518: Invalid database id (string)
Cause:
The operation failed because the specified database ID does not exist in the Workload Repository.
Action:
check the database id and retry the operation.
ORA-13519: Database id (string) exists in the workload repository
Cause:
The operation failed because the specified database ID already exists in the Workload Repository.
Action:
ORA-13520: Database id (string) not registered, Status = string
Cause:
The operation failed because the specified database ID was not registered in the Workload Repository properly.
Action:
check the status of database id and retry the operation.
ORA-13521: Unregister operation on local Database id (string) not allowed
Cause:
The operation failed because the local database ID cannot be unregistered from the Workload Repository.
Action:
ORA-13523: unable to allocate required space for return type
Cause:
Out of memory to allocate the space for the return variable for an external procedure.
Action:
Try operation again.
ORA-13524: error encountered while retrieving baseline information
Cause:
A read error occurred during the OCI operation to retrieve the baseline information
Action:
Check associated error. Correct problem and retry the operation.
ORA-13525: error with computing space usage for sysaux occupant
Cause:
Action:
ORA-13526: baseline (string) does not exist
Cause:
The operation failed because the specified baseline name does not exist in the Workload Repository.
Action:
check the baseline name and retry the operation.
ORA-13527: invalid baseline name
Cause:
The operation failed because the specified baseline name is invalid.
Action:
ORA-13528: name (string) is already used by an existing baseline
Cause:
The operation failed because the specified baseline name already exists in the Workload Repository.
Action:
ORA-13529: Error occurred when flushing AWR table group
Cause:
An error occurred during the flushing of a table group. Because of the error in the group, we are unable to flush this table.
Action:
Check the error associated with the table group.
ORA-13530: invalid TOPNSQL string, must be in the range (string, string)
Cause:
The user has specified a TOPNSQL setting that is not in the supported range of (MIN, MAX).
Action:
Choose a valid TOPNSQL setting and retry the operation.
ORA-13531: SQL Text was purged from AWR before the operation completed
Cause:
A SQL was purged from AWR before the operation completed.
Action:
Retry the operation.
ORA-13532: SQL ID [string] already exists
Cause:
The operation failed because the specified SQL ID already existed in the repository.
Action:
Check the SQL ID and retry the operation.
ORA-13533: invalid SQL ID
Cause:
The operation failed because the specified SQL ID was invalid.
Action:
ORA-13534: Current SQL count(string) reached maximum allowed (string)
Cause:
The operation failed because the maximum allowed colored SQL was exceeded.
Action:
Check the count for colored SQL.
ORA-13535: name (string) is already used by an existing baseline template
Cause:
The operation failed because the specified baseline template name already existed in the Workload Repository.
Action:
Check the baseline template name and retry the operation.
ORA-13536: baseline template (string) does not exist
Cause:
The operation failed because the specified baseline template name did not exist in the Workload Repository.
Action:
ORA-13537: invalid input for create baseline template (string, string)
Cause:
Invalid input was specified for the create baseline template routine.
Action:
Check the argument displayed in the error message text.
ORA-13538: invalid value for baseline expiration (string)
Cause:
An invalid value was specified for the expiration of a baseline. The expiration is specified in number of days, and the expiration must be at least one day.
Action:
Check the value for expiration.
ORA-13539: invalid input for modify baseline window size (string, string)
Cause:
Invalid input was specified for the modify baseline window size routine.
Action:
ORA-13540: operation not allowed on system moving window baseline (string)
Cause:
The requested operation was not allowed on the system moving window baseline.
Action:
Retry the operation with another baseline name.
ORA-13541: system moving window baseline size (string) greater than retention (string)
Cause:
The system moving window baseline size must be less than the retention setting. The specified window size or retention violate this.
Action:
Check the moving window baseline size or retention.
ORA-13542: baseline ID (string) does not exist
Cause:
The operation failed because the specified baseline ID did not exist in the Workload Repository.
Action:
Check the baseline ID and retry the operation.
ORA-13543: error encountered while retrieving baseline template information
Cause:
A read error occurred during the OCI operation to retrieve the baseline template information.
Action:
ORA-13544: error encountered while automatically generating a baseline
Cause:
An error occurred while automatically generating a baseline based on the template information.
Action:
Look in the trace file for more error information.
ORA-13545: invalid baseline template name
Cause:
The operation failed because the specified baseline template name was an invalid identifier.
Action:
ORA-13546: Error encountered during maintenance of Adaptive Thresholds
Cause:
Action:
ORA-13547: Unable to drop baseline since it is in use by string
Cause:
The system is not able to drop the baseline since the baseline is in use by a functionality that depends on its existence.
Action:
Note the name of the functionality using the baseline, and check if the functionality still needs the baseline.
ORA-13548: Unable to find valid snapshot IDs for the inputted baseline time range
Cause:
The system is not able to find valid snapshot IDs for the inputted time range while attempting to create a baseline.
Action:
Check that the inputted time range has at least two valid snapshots. The dba_hist_snapshot displays the snapshot id and time information.
ORA-13549: invalid input for create baseline with time range (string)
Cause:
Invalid time input was specified for the create baseline routine.
Action:
ORA-13550: value "string" of length (string) exceeded maximum length (string) for parameter [string]
Cause:
An invalid parameter was specified for the Automatic Workload Repository (AWR) registration routine.
Action:
ORA-13551: source database same [string] not found in AWR
Cause:
An invalid parameter was specified for the Automatic Workload Repository (AWR) operation.
Action:
ORA-13552: parameter [string] of value [string] mismatched with AWR registered value [string]
Cause:
Action:
ORA-13553: operation failed - missing parameter [string]
Cause:
The required parameter was missing for the Automatic Workload Repository (AWR) operation.
Action:
Check the parameter name displayed in the error message text.
ORA-13554: failed to stop report capture on all instances
Cause:
The API 'finish_report_capture' ran successfully on %d instances only.
Action:
Check if all instances are active and running.
ORA-13600: error encountered in Advisor\nstring
Cause:
An error occurred in the Advisor. This message will be followed by a second message giving more details about the nature of the error.
Action:
See the Advisor documentation for an explanation of the second error message.
ORA-13601: The specified Advisor string does not exist.
Cause:
The user specified an advisor name that has not be defined in the advisor repository.
Action:
Correct the advisor name and retry the operation.
ORA-13602: The specified parameter string is not valid for task or object string.
Cause:
The user attempted to access a task parameter that does not exist for the specified advisor object. The parameter may be misspelled or the user has selected a parameter that is not supported by the particular advisor.
Action:
Validate the parameter name and retry the operation.
ORA-13603: The specified parameter string cannot be fetched as a numeric value for task or object string.
Cause:
The user attempted to retrieve a string parameter as a numeric value.
Action:
Check the datatype for the task parameter and retry the operation.
ORA-13604: The specified parameter string cannot be fetched as a SQL table.
Cause:
The user attempted to retrieve a non-table parameter as a table name.
Action:
ORA-13605: The specified task or object string does not exist for the current user.
Cause:
The user attempted to reference an advisor task or object using a name that does not exist in the Advisor repository.
Action:
Adjust the name and retry the operation.
ORA-13606: the specified task parameter element string is out of range for parameter string.
Cause:
The user attempted to reference an invalid parameter element.
Action:
Adjust the element offset and retry the operation.
ORA-13607: The specified task or object string already exists
Cause:
The user attempted to create the specified task or object using a name that already exists in the Advisor repository. Task names must be unique to the database user.
Action:
ORA-13608: The specified name string is invalid.
Cause:
An attempt was made to specify a name for a task, object, execution or directive instance, which contained invalid characters or an invalid wildcard specifier.
Action:
ORA-13609: The specified task string must be executing to be cancelled or interrupted.
Cause:
The user attempted to cancel or interrupt a task that is not currently executing.
Action:
Check the status of the task and retry the operation.
ORA-13610: The directive string does not exist for task string.
Cause:
The user attempted to access a task directive that does not exist.
Action:
Validate the directive and retry the operation.
ORA-13611: The command string is not a valid advisor command.
Cause:
The user attempted to specify a command that does not exist.
Action:
Validate the command and retry the operation.
ORA-13612: The recommendation action string,string is not valid for task string.
Cause:
The user attempted to access a recommendation action that does not exist in the task.
Action:
Validate the recommendation-action and retry the operation.
ORA-13613: The requested operation is not supported for this advisor object.
Cause:
The user attempted to perform an operation that is not supported for the particular advisor or task type.
Action:
Validate the task or object and retry the operation.
ORA-13614: The template string is not compatible with the current advisor.
Cause:
The user attempted to create a new task or object using an existing task or object that was not created by the same advisor.
Action:
Validate the template and retry the operation.
ORA-13615: The task or object string is greater than the maximum allowable length of 30 characters.
Cause:
The user attempted to create a new task or object using a name that is too long.
Action:
Shorten the name and retry the operation.
ORA-13616: The current user string has not been granted the ADVISOR privilege.
Cause:
The user attempted an advisor operation that requires privilege.
Action:
Adjust the user's privileges and retry the operation.
ORA-13617: The specified task string already executing
Cause:
The user attempted to execute a task that is currently executing.
Action:
Wait for the task to finish before attempting any further task activities.
ORA-13618: The specified value is not a valid value for procedure argument string.
Cause:
The user executed a procedure but failed to provide correct values for the argument.
Action:
Correct the procedure arguments and retry the operation.
ORA-13619: The procedure argument string is greater than the maximum allowable length of string characters.
Cause:
The user attempted to pass a character argument that is too long.
Action:
Shorten the specified character argument and retry the operation.
ORA-13620: The task or object string is read-only and cannot be deleted or modified.
Cause:
The user attempted to perform an operation that will update or delete a read-only task or object.
Action:
Adjust the READ_ONLY property for the object and retry the operation.
ORA-13621: The task_or object string is marked as a template and cannot perform the requested operation.
Cause:
The user attempted perform an unsupported operation on a task or object that is identified as a template.
Action:
Choose a different object and retry the operation.
ORA-13622: invalid recommendation annotation
Cause:
The user attempted to mark a recommendation using an invalid annotation. Valid annotation actions are ACCEPT, REJECT and IGNORE.
Action:
Correct the action and retry the operation.
ORA-13623: The recommendation string is not valid for task string.
Cause:
The user attempted to access a recommendation that does not exist in the task.
Action:
Validate the recommendation and retry the operation.
ORA-13624: The task string is executing and cannot be deleted or modified.
Cause:
The user attempted to access a task that currently executing.
Action:
Wait for the task to complete and retry the operation.
ORA-13625: string is an invalid advisor object type.
Cause:
The user has specified an invlaid object type.
Action:
Refre to dba_advisor_object_types for all valid object types
ORA-13626: The specified object string is not valid for task string.
Cause:
The user specified an non-existent object for the task
Action:
ORA-13627: Setting of parameter string is disallowed until the task is reset.
Cause:
The user attempted to set the value of a parameter before the task was reset. This parameter cannot be changed until the task is reset.
Action:
Reset the task and retry the operation.
ORA-13628: Insufficient privileges to access the task belonging to the specified user
Cause:
The user could not access dba_* views.
Action:
Retry operation as owner of the task or after granting new privileges.
ORA-13629: The task or object string is being used by another operation.
Cause:
The user attempted to access a task or object that is locked by another session.
Action:
Wait for the task or object activity to complete and retry the operation.
ORA-13630: The task string contains execution results and cannot be executed.
Cause:
The user attempted to execute a task that already contains execution results.
Action:
Reset the task to its initial state and retry the operation.
ORA-13631: The most recent execution of task string contains no results.
Cause:
The user attempted to create a report or script from a task that has not successfully completed an execution.
Action:
Execute the task and then retry the operation
ORA-13632: The user cancelled the current operation.
Cause:
The user signaled a cancel during a task or object operation.
Action:
None
ORA-13633: The task string was interrupted and needs to be resumed.
Cause:
The user attempted to execute a task that was interrupted.
Action:
Resume the execution of the task via the RESUME_TASK API.
ORA-13634: The task string needs to be reset before being re-executed.
Cause:
The task must be in an inital state to be executed.
Action:
ORA-13635: The value provided for parameter string cannot be converted to a number.
Cause:
A numeric parameter was incorrectly supplied in string form.
Action:
Retry by supplying valid numeric value.
ORA-13636: The specified value provided for parameter string is not valid for this advisor.
Cause:
The user supplied an invalid parameter value.
Action:
Retry by supplying valid value.
ORA-13637: Executing or modifying task string is disallowed until the task is reset to its initial state.
Cause:
The user attempted to execute or modify the task that is in not in its INITIAL state.
Action:
ORA-13638: The user interrupted the current operation.
Cause:
The user signaled an interrupt during a task or object operation.
Action:
None
ORA-13639: The current operation was interrupted because it timed out.
Cause:
The task or object operation timed out.
Action:
None
ORA-13640: The current operation was cancelled because it timed out, and was not in interruptible mode.
Cause:
Action:
None
ORA-13641: Task cannot be interrupted yet. You may cancel it instead.
Cause:
The user attempted to interrupt a task that has not reached interruptible mode.
Action:
Wait until the task reaches interruptible mode, or cancel the task execution.
ORA-13642: The specified string string provided for string cannot be converted to a date. The acceptable date format is string.
Cause:
The user supplied a date value in an incorrect format.
Action:
ORA-13643: The task can not be interrupted or cancelled.
Cause:
Request to interrupt or cancel task execution can not be granted because the task has not reached the appropriate mode.
Action:
User should wait for a few seconds and try again.
ORA-13644: The user "string" is invalid.
Cause:
Invalid user name specified to advisor framework
Action:
User should specify a correct, case-sensitive, name
ORA-13645: The specified execution string does not exist for this task.
Cause:
You attempted to reference an advisor task execution using a name that did not exist.
Action:
ORA-13646: The specified execution string already exists
Cause:
You attempted to perform a new execution using a name that already exists for the specified task. Execution names must be unique within the same task.
Action:
ORA-13647: Setting of parameter string is disallowed during task execution.
Cause:
You attempted to set the value of a parameter while the task was being executed. This parameter cannot be changed until the task finishes its execution.
Action:
Verify the status of the task and retry the operation.
ORA-13648: The specified execution type does not exist for this advisor.
Cause:
You attempted to use an advisor task execution type using a name that did not exist.
Action:
ORA-13649: The type of execution is not specified for this advisor or task.
Cause:
You attempted to execute a task for a multi-execution task advisor without specifying the type of execution to perform.
Action:
Set the execution type and retry the operation.
ORA-13650: The specified object does not exist for this execution.
Cause:
You attempted to associate an object to a task execution that id not contain the object.
Action:
Adjust the execution name and object ID, and then retry the operation.
ORA-13651: The specified list of execution parameters is invalid.
Cause:
The list did not include pairs of (parameter_name, parameter_value) where every parameter is a valide task parameter. Duplicates are not allowed.
Action:
Adjust the content of the list, and then retry the operation.
ORA-13652: Cannot set execution parameters for this advisor
Cause:
You attempted to set execution parameters for an advisor that did not support multiple executions of its tasks.
Action:
Adjust the property of the advisor, and then retry the operation.
ORA-13653: The directive with definition id string was not found.
Cause:
An invalid directive identifier was specified to advisor framework.
Action:
User should specify a correct identifier number and retry the operation.
ORA-13654: The directive with instance id of string was not found.
Cause:
An invalid instance identifier was specified to advisor framework.
Action:
User should specify a correct instance identifier number and retry the operation.
ORA-13655: The directive document contains a syntax error and cannot be loaded.
Cause:
An attempt was made to load an XML-based directive that does not conform to the documented DTD.
Action:
Reformat the directive according the documented DTD.
ORA-13656: The parameter was not found in directive string.
Cause:
The specified parameter name could not be located within the directive XML document.
Action:
Verify the existence of the parameter in the specified directive.
ORA-13657: The filter Xpath specification has invalid syntax.
Cause:
The specified filter could not be compiled within the directive XML document.
Action:
Verify the syntax of the filter and retry the operation.
ORA-13658: The specified directive already has an instance
Cause:
An attempt was made to create multiple instances of a directive when not permitted
Action:
Verify the parent directive identifier and the instance name.
ORA-13659: A directive with domain "string" and name "string" already exists for advisor string.
Cause:
The specified directive is not unique among the directives.
Action:
Choose a directive name and domain that is distinct for the associated advisor.
ORA-13660: A directive instance with the name "string" already exists.
Cause:
The specified directive instance is not unique among instances for this directive.
Action:
Choose an instance name that is distinct for the associated directive.
ORA-13661: A directive instance with the name "string" was not found.
Cause:
An attempt was made to update or delete a non-existent directive instance.
Action:
ORA-13662: The specified value provided for parameter string is not valid for this task.
Cause:
The supplied parameter value was not valid for the current task configuration.
Action:
Retry by supplying valid value. Check the current task configuration.
ORA-13663: The task string contains no results for execution string.
Cause:
An attempt was made to create a report or script from an execution that had not been successfully completed.
Action:
Run a new execution and then retry the operation.
ORA-13664: A task-managed "SQL Tuning Set" already exists for task "string".
Cause:
An attempt was made to create a task-managed SQL Tuning Set for a task that already had one.
Action:
Create a new task to use a different SQL Tuning Set.
ORA-13665: Execution names are not correctly ordered.
Cause:
The supplied execution names were not properly ordered by execution start date.
Action:
Retry by supplying a valid order.
ORA-13666: Task ID string does not exist.
Cause:
The supplied task ID was invalid.
Action:
Check the task ID and try again.
ORA-13667: Execution ID string does not exist.
Cause:
The supplied execution ID was invalid.
Action:
Check the execution ID and try again.
ORA-13668: The current operation was aborted because it was blocking another session.
Cause:
The task or object operation interrupted itself when it detected that it was blocking some other session.
Action:
Retry the operation when the conflicting operations are not running.
ORA-13669: Execution provided has type "string", expected "string".
Cause:
An execution was provided whose type did not match the one expected by the API.
Action:
Check the execution name, and try again.
ORA-13670: No execution of type string exists for task provided.
Cause:
No execution of the required type existed for the given advisor task.
Action:
Check the task, and try again.
ORA-13699: Advisor feature is not currently implemented.
Cause:
An attempt was made to execute an unsupported advisor operation.
Action:
Verify the availability of the operation.
ORA-13700: Reserved for ADDM tracing.
ORA-13701: Snapshot pair [string, string] seems to be specified in reverse order.
Cause:
The start snapshot id was greater than the end snapshot id.
Action:
Swap the start and end snapshot ids.
ORA-13702: Snapshot IDs specified by the range [string, string] are equal.
Cause:
The start snapshot id and end snapshot id were identical.
Action:
Provide different start and end snapshot ids.
ORA-13703: The snapshot pair [string, string] for database_id string and instance_id string are not found in the current repository.
Cause:
The snapshot ids or the database id or the instance id was invalid or the specified snapshots have already been purged.
Action:
Set valid snapshot ids and retry.
ORA-13704: Invalid value "string" specified for parameter "string".
Cause:
The parameter was not set before executing the ADDM.
Action:
Set the parameter to a valid value and retry.
ORA-13705: There was a instance shutdown/startup between the snapshots in the range [string, string].
Cause:
Instance was shut down and restarted between the two specified snapshots.
Action:
Specify start and end snapshot ids that does not have a shutdown/startup in between them.
ORA-13706: Invalid value "string" specified for parameter "string" in "string" analysis mode.
Cause:
The parameter was not set to an acceptable value for this particular mode of analysis.
Action:
ORA-13707: Either the start snapshot string or the end snapshot string is incomplete or missing key statistics.
Cause:
Either the start or the end snaphots was missing or purged or had encountered errors while creating them.
Action:
Verify that AWR is done taking these two snapshots, or Look in DBA_HIST_SNAP_ERROR to find what tables are missing in the start/end snapshots. Use the ERROR_NUMBER column in that view together with the alert log to identify the reason for failure and take necessary action to prevent such failures in the future. Try running ADDM on a different snapshot range that has valid start and end snapshots.
ORA-13708: Some snapshots in the range [string, string] were purged before the analysis was complete.
Cause:
One or both of the snapshots have been purged from AWR.
Action:
Verify that the AWR auto purging is not trying to purge these snapshots and re-run ADDM.
ORA-13709: Required parameter "string" must be set before execution.
Cause:
The parameter needs to be set before running the ADDM
Action:
ORA-13710: Parameter "string" must have a higher value than parameter "string". The values supplied were "string" and "string" respectively.
Cause:
Invalid interaction between two parameter values.
Action:
Set at least one of the values so the value of the first parameter is higher than the value of the second parameter.
ORA-13711: Some snapshots in the range [string, string] are missing key statistics.
Cause:
Some AWR tables encountered errors while creating one or more snapshots in the given range. The data present in one or more of these missing tables is necessary to perform an ADDM analysis.
Action:
Look in DBA_HIST_SNAP_ERROR to find what tables are missing in the given snapshot range. Use the ERROR_NUMBER column in that view together with the alert log to identify the reason for failure and take necessary action to prevent such failures in the future. Try running ADDM on a different snapshot range that does not include any incomplete snapshots.
ORA-13712: Cannot perform ADDM analysis on AWR snapshots from previous releases. Snapshot version "string" do not match the database version "string".
Cause:
ADDM analysis can only be performed on AWR snapshots taken in the current release.
Action:
One can still generate AWR and ASH reports using ?/rdbms/admin/awrrpt and ?/rdbms/admin/ashrpt on these snapshots to analyze the data in them.
ORA-13713: Finding name "string" does not exist. Look in DBA_ADVISOR_FINDING_NAMES for all valid values
Cause:
Attempt to refer to an advisor's finding name that does not exist.
Action:
Specify a valid value. The list of all valid values is in DBA_ADVISOR_FINDING_NAMES
ORA-13714: "string" is not a valid SQL_ID value
Cause:
The specified value of SQL_ID was not properly formatted.
Action:
Specify a valid value consisting of a 13 character string with characters from '0' to '9' and from 'a' to 'z'.
ORA-13715: "string" is not recognized by ADDM as a parameter name
Cause:
The specified value for a system parameter was not recognized by ADDM.
Action:
Specify a value that appears in the NAME column of V$PARAMETER.
ORA-13716: Diagnostic Package License is needed for using this feature.
Cause:
The specified value for system parameter CONTROL_MANAGEMENT_PACK_ACCESS indicated that the Diagnostic Package was disabled.
Action:
Modify the parameter value if the Diagnostic Package License was purchased.
ORA-13717: Tuning Package License is needed for using this feature.
Cause:
The specified value for system parameter CONTROL_MANAGEMENT_PACK_ACCESS indicated that the Tuning Package was disabled.
Action:
Modify the parameter value if the Tuning Package License was purchased.
ORA-13718: Tuning Package License or Real Application Testing Option is needed for using this feature.
Cause:
The specified package license and option were not installed.
Action:
Consider purchasing and installing either the missing package licence or option. If the tuning package license was purchased, then check the value of system parameter CONTROL_MANAGEMENT_PACK_ACCESS.
ORA-13719: Imported AWR snapshots are from a database with an incompatible character set.
Cause:
ADDM analysis was attempted on imported Automatic Workload Repository (AWR) snapshots with incompatible character set.
Action:
Perform ADDM analysis using a database with the same version and character set as the original database.
ORA-13720: dimension name provided is too long
Cause:
Active Session History (ASH) dimension name provided was longer than the limit of 30 characters.
Action:
Correct the dimension name and retry the operation.
ORA-13721: dimension name provided is invalid
Cause:
Active Session History (ASH) dimension name provided was invalid.
Action:
ORA-13750: User "string" has not been granted the "ADMINISTER SQL TUNING SET" privilege.
Cause:
The user attempted an SQL Tuning Set operation that requires a specific privilege.
Action:
ORA-13751: "SQL Tuning Set" "string" does not exist for owner "string" or user "string" does not have permission to access the "SQL Tuning Set".
Cause:
The user attempted to access a SQL Tuning Set that does not exist or the user does have permission to access the SQL Tuning Set
Action:
Check the existence of the "SQL Tuning Set" or adjust the user's privileges and retry the operation.
ORA-13752: User "string" must be SYS or must have the "ADMINISTER ANY SQL TUNING SET" privilege.
Cause:
The attempted to create a SQL Tuning Set in another schema without having the right privilege.
Action:
Connect as SYS or adjust the user's privilege and retry the operation.
ORA-13753: "SQL Tuning Set" "string" already exists for user "string".
Cause:
The user attempted to create a "\SQL Tuning"\ Set using a name that already exists for that owner.
Action:
Change the name of the SQL Tuning Set and retry the operation.
ORA-13754: "SQL Tuning Set" "string" does not exist for user "string".
Cause:
The user attempted to access a SQL Tuning Set that does not exist.
Action:
Check the speelling of the SQL Tuning Set name and retry the operation.
ORA-13755: invalid "SQL Tuning Set" name
Cause:
The user attempted to specify a SQL Tuning Set name that is invalid. A name must not contain wildcards and its length must be less than 30 characters.
Action:
ORA-13756: Cannot update attribute "string".
Cause:
The user attempted to update an attribute element that cannot be modified. The only string attributes that can be updated are MODULE, ACTION, PARSING_SCHEMA_NAME, PRIORITY, and OTHER.
Action:
Adjust the attribute name and retry the operation.
ORA-13757: "SQL Tuning Set" "string" owned by user "string" is active.
Cause:
The user attempted to update an active SQL Tuning Set.
Action:
Remove all reference to the SQL Tuning Set and retry the operation.
ORA-13758: "SQL Tuning Set" "string" owned by user "string" is in use.
Cause:
The user attempted to modify a SQL Tuning Set or to add a reference to a SQL Tuning Set which is in use.
Action:
Wait until the end of the previous operation and retry.
ORA-13759: User "string" cannot remove reference "string".
Cause:
The user attempted to remove a SQL Tuning Set reference that does not exist. The user might not own the reference.
Action:
Check the reference ID and the reference owner and retry the operation.
ORA-13761: invalid filter
Cause:
The user attempted to select data from a data source using an invalid filter. A filter is a WHERE clause on data source content.
Action:
Correct the filter and retry the operation.
ORA-13762: The string ranking measure is invalid.
Cause:
The user attempted to select data from a data source using an invlaid ranking measure. A ranking measure must represent a valid numerical expression.
Action:
Correct the ranking measure and retry the operation.
ORA-13763: illegal ranking attribute "string"
Cause:
The user attempted to use an attribute element that is not allowed in a ranking measure.
Action:
Check the attribute in the ranking measure and retry the operation.
ORA-13764: Value "string" is illegal as a result percentage.
Cause:
The user attempted to select data from a SQL Tuning Set using an invalid result percentage. The result percentage must be between 0 and 1.
Action:
Correct the result percentage value and retry the operation.
ORA-13765: Value "string" is illegal for a result limit.
Cause:
The user attempted to select data from a SQL Tuning Set using an invalid result limit. A result limit must be a positive interger.
Action:
Correct the result limit value and retry the operation.
ORA-13766: A ranking measure is required.
Cause:
The user attempted to select data from a SQL Tuning Set using a percentage argument without specifying a ranking measure.
Action:
Add a ranking measure or remove the percentage argument and retry the operation.
ORA-13767: End snapshot ID must be greater than begin snapshot ID.
Cause:
The user attempted to select data from the workload repository using an invalid snaphot ID range.
Action:
Adjust the snapshot ID range and retry the operation.
ORA-13768: Snapshot ID must be between string and string.
Cause:
The user attempted to select data from the workload repository using a snaphot ID which does not exist.
Action:
Adjust the snapshot ID and retry the operation.
ORA-13769: Snapshots string and string do not exist.
Cause:
The user attempted to select data from the workload repository using snapshots that do not exist.
Action:
Check the snapshot identifiers and retry the operation.
ORA-13770: Baseline "string" does not exist.
Cause:
The user attempted to access a baseline that does not exsit.
Action:
Check the speelling of the baseline name and retry the operation.
ORA-13771: cannot obtain exclusive lock string on "SQL Tuning Set" "string" owned by user "string"
Cause:
Unexpected error from DBMS_LOCK.REQUEST.
Action:
This error should not normally occur. Check your system for anomalies and retry the operation. If this error persists, contact Oracle Support Services.
ORA-13772: unexpected deadlock on "SQL Tuning Set" "string" owned by user "string"
Cause:
Action:
ORA-13773: insufficient privileges to select data from the cursor cache
Cause:
The user attempted to perform an operation without having the appropriate privileges on V$SQL and V$SQL_BIND_CAPTURE.
Action:
ORA-13774: insufficient privileges to select data from the workload repository
Cause:
The user attempted to perform an operation without having the appropriate privileges on views DBA_HIST_BASELINE, DBA_HIST_SQLTEXT, DBA_HIST_SQLSTAT, DBA_HIST_SQLBIND, DBA_HIST_OPTIMIZER_ENV, and DBA_HIST_SNAPSHOT.
Action:
ORA-13775: inconsistent datatype in input cursor
Cause:
The user attempted to load a SQL Tuning Set using an invalid input cursor. All rows in the cursor must match type SQLSET_ROW.
Action:
Check the rows type in the cursor and retry the operation.
ORA-13776: User "string" has not been granted the "SELECT" privilege on the "SQL tuning set" DBA views.
Cause:
The user attempted to read a SQL tuning set belonging to someone else without having SELECT privilege on the DBA views
Action:
User should be granted the privilege or only access his own STS
ORA-13777: invalid list of attribute names
Cause:
The user specified an attribute element that is not valid. The only attributes that can be selected are NULL, BASIC, TYPICAL, ALL or a comma separated list of the names including EXECUTION_STATISTICS, OBJECT_LIST, BIND_LIST and SQL_PLAN.
Action:
Adjust the attribute list and retry the operation.
ORA-13778: no new name or owner specified for "SQL Tuning Set"
Cause:
The user attempted to call remap_stgtab_sqlset without specifying either a new SQL tuning set name or a new SQL tuning set owner
Action:
Specify at least one or the other argument as non-NULL
ORA-13779: invalid load option
Cause:
The user attempted to call load_sqlset with a load option that is different than INSERT, UPDATE and MERGE.
Action:
Adjust the load option and retry the operation.
ORA-13780: SQL statement does not exist.
Cause:
The user attempted to tune a SQL statement that does not exist.
Action:
Verify the sql_id and the plan hash value of the statement and retry the operation.
ORA-13781: cannot perform test-execute and explain plan operations on the automatic SQL tuning task
Cause:
The user attempted to test-execute or generate explain plans for a SQL workload using the automatic SQL tuning task.
Action:
Verify the name of the tuning task and retry the operation.
ORA-13783: invalid tuning scope
Cause:
The user attempted to specify a tuning task scope that is invalid. The possible values are LIMITED or COMPREHENSIVE.
Action:
Check the scope value and retry the operation.
ORA-13784: cannot accept SQL profiles for all statements in the "string"
Cause:
An attempt was made to accept SQL profiles for all statements in the input workload.
Action:
Provide the object identifier corresponding to a statement in the workload and retry the operation.
ORA-13785: missing target object for tuning task "string"
Cause:
The user attempted to perform an operation on a task without specifying a target object or by using an invalid object identifier.
Action:
Check the identifier of the object and retry the operation.
ORA-13786: missing SQL text of statement object "string" for tuning task "string"
Cause:
The user attempted to accept SQL profile for an object that has not a SQL text associated to it.
Action:
ORA-13787: missing SQL profile for statement object "string" for tuning task "string"
Cause:
The user attempted to accept a SQL profile for an object that has not a SQL profile associated to it.
Action:
ORA-13788: invalid recommendation type
Cause:
The user passed an invalid recommendation type in the rec_type argument to script_tuning_task. Possible values are ALL or any subset of a comma-separated list of PROFILES, STATISTICS and INDEXES.
Action:
Check the rec_type arg and retry the operation.
ORA-13789: invalid process action
Cause:
The user passed an invalid action to process a SQL statement. Possible value is any subset of a comma-seperated list of EXECUTE and EXPLAIN_PLAN.
Action:
Check the action argument and retry the operation.
ORA-13790: invalid value for time limit
Cause:
The user passed an invalid value for the time limit argument.
Action:
Check the argument specified value and retry the operation.
ORA-13791: cannot resume a task created to process a single statement
Cause:
An attempt was made to resume a task that was created for a single SQL statement. A task can be resumed only if it is used for a SQL Tuning Set.
Action:
No action required.
ORA-13793: invalid comparison metric
Cause:
An invalid metric to compare SQL performance was specified.
Action:
Use execution statistics to compare the result of two executions and optimizer_cost to analyze performance of two explain plan actions.
ORA-13794: execution type mismatch
Cause:
An attempt was made to analyze the performance of a SQL workload using two executions that were generated using two different actions.
Action:
check the name and type of task executions to analyze and retry the operation.
ORA-13795: missing task execution
Cause:
An insufficient number of valid task executions to analyze the performance of a SQL workload were specified.
Action:
run the task to generate two executions of the same type and retry the operation.
ORA-13796: invalid value string specified for problem type
Cause:
An invalid problem type was specified to the SQL diagnosis advisor. Problem type should be one of the PROBLEM_TYPE_* defined in 'admin/dbmsdiag.sql'.
Action:
Specify valid problem type.
ORA-13797: invalid SQL Id specified, string
Cause:
Invalid SQL Id specified for conversion.
Action:
Specify valid SQL Id.
ORA-13798: Parameter string cannot be NULL.
Cause:
A call to GET_THRESHOLD procedure was made without a required parameter.
Action:
Specify a valid value for this parameter.
ORA-13799: threshold not found
Cause:
No threshold was found with the specified threshold key.
Action:
No action required.
ORA-13800: concurrent DDL failure on SQL repository objects
Cause:
A SQL repository object was the target of two concurrent DDL operations.
Action:
Check the current state of the object and retry the operation that failed.
ORA-13801: invalid value for SQLTUNE_CATEGORY parameter
Cause:
An invalid Oracle identifier was used as the value of the parameter.
Action:
Specify the parameter conforming to the rules for Oracle identifiers.
ORA-13802: failed to purge SQL Tuning Base entry from sql$
Cause:
An error occured while try to delete a SQL Tuning Base object.
Action:
Look at the underlying error(s) on the error stack.
ORA-13810: FORCE_TRACKING parameter can only be values of NO_FORCE_TRACKING or FORCE_TRACKING
Cause:
The wrong value was passed in for the parameter.
Action:
Check the value and input the correct value.
ORA-13811: error encountered during the start of the operation
Cause:
An internal error was encountered.
Action:
Check the alert log and report to Oracle Support Services.
ORA-13812: current session does not have database operation monitored
Cause:
An attempt was made to end a database operation that did not exist.
Action:
Check if the database operation is being monitored.
ORA-13813: database operation name or execution ID does not match
Cause:
The database operation name or execution ID did not match.
Action:
Call the interface with the right database operation name and execution ID.
ORA-13825: missing SQL statement text
Cause:
No SQL text was provided to the create SQL profile or patch operation.
Action:
Retry with properly specified SQL text.
ORA-13826: empty SQL profile or patch not allowed
Cause:
No attributes were specified to the create SQL profile or patch operation.
Action:
Retry with at least one hint specified.
ORA-13827: null or zero length attribute not allowed
Cause:
One of the attributes within the SQL profile or patch was not properly specified.
Action:
Retry with a fully specified SQL profile or patch.
ORA-13828: generated SQL profile or patch name string already exists
Cause:
A SQL profile or patch already exists with the name generated by the system.
Action:
Retry the operation as the generated name is time sensitive.
ORA-13829: SQL profile or patch named string already exists
Cause:
A SQL profile or patch already exists with the name specified.
Action:
Specify a different name or drop the existing SQL profile or patch.
ORA-13830: SQL profile or patch with category string already exists for this SQL statement
Cause:
A SQL profile or patch already exists for the given SQL statement and category.
Action:
Drop or update the existing SQL profile or patch.
ORA-13831: SQL profile or patch name specified is invalid
Cause:
An invalid SQL profile or patch name was specified.
Action:
Look for the underlying error on the error message stack.
ORA-13832: category name specified is invalid
Cause:
An invalid category name swas pecified.
Action:
ORA-13833: SQL profile or patch named string doesn't exist
Cause:
A SQL profile or patch name was specified that doesn't exist.
Action:
Verify the name of the SQL profile or patch.
ORA-13834: name of SQL profile or patch to be cloned must be provided
Cause:
A SQL profile or patch name was not provided as the from target of a clone SQL profile or patch operation.
Action:
Provide the name of the SQL profile or patch being cloned.
ORA-13835: invalid attribute name specified
Cause:
An invalid attribute name was specified for an alter SQL profile or patch operation.
Action:
Verify the name of the attribute.
ORA-13836: invalid attribute value specified
Cause:
An invalid attribute value was specified for an alter SQL profile or patch operation.
Action:
Verify the attribute value.
ORA-13837: invalid HASH_VALUE
Cause:
An invalid HASH_VALUE was passed to a create SQL profile operation
Action:
Verify the HASH_VALUE.
ORA-13838: invalid ADDRESS value
Cause:
An invalid ADDRESS value was passed to a create SQL profile operation.
Action:
Verify the ADDRESS value.
ORA-13839: V$SQL row doesn't exist with given HASH_VALUE and ADDRESS.
Cause:
A HASH_VALUE and ADDRESS combination passed to the create SQL profile operation doesn't coorespond to an existing V$SQL entry.
Action:
Verify the HASH_VALUE and ADDRESS in V$SQL.
ORA-13840: Concurrent DDL Error in create SQL profile operation.
Cause:
A concurrent DDL operation was performed during a create or replace sql profile operation.
Action:
Try operation again
ORA-13841: SQL profile named string already exists for a different signature/category pair
Cause:
A SQL profile already exists with the name specified under a different signature/category pair so it cannot be replaced, even with FORCE specified.
Action:
Specify a different name or drop the existing SQL profile.
ORA-13842: no SELECT privilege on DBA_SQL_PROFILES
Cause:
A user has tried to perform an operation that requires SELECT privileges on the DBA_SQL_PROFILES view.
Action:
Either perform the operation as another user or get the privilege
ORA-13843: no SQL profile with name like "string" exists for category like "string"
Cause:
A user tried to perform an operation by specifying a profile name/ category filter that did not target any profiles
Action:
Try a different filter after checking the profile name/category
ORA-13844: no new SQL profile name or category specified.
Cause:
A user called remap_stgtab_sqlprof without specifying new values for the sql profile name or category. At least one is required.
Action:
Specify either a new profile name, or a new category, or both
ORA-13845: invalid SQL profile XML specification provided
Cause:
The supplied XML specification for the SQL profile did not adhere to the proper schema.
Action:
Check the syntax and try again.
ORA-13846: Cannot create SQL plan baseline on the given plan
Cause:
There are either multiple plans exist for the given value or the plan is not reproducible.
Action:
Call Oracle Support.
ORA-13847: The plan with plan hash value string does not exist
Cause:
The give plan does not exist.
Action:
Check the available plans.
ORA-13850: Tracing for client identifier string is not enabled
Cause:
Attempt to disable a client identifier tracing which was never enabled
Action:
Supply correct client identifier
ORA-13851: Tracing for client identifier string is already enabled
Cause:
Attempt to enable a client identifier tracing which has been already enabled
Action:
Supply correct client identifier, or disable and re-enable tracing with different bind/wait options
ORA-13852: Tracing for service(module/action) string is not enabled
Cause:
Attempt to disable a service-level tracing which was never enabled
Action:
Supply correct service(module/action) name
ORA-13853: Tracing for service (module/action) string is already enabled
Cause:
Attempt to enable a service-level tracing which has been already enabled
Action:
Supply correct service(module/action), or disable and re-enable tracing with different bind/wait options
ORA-13854: Tracing for service(module/action) string on instance string is not enabled
Cause:
Attempt to disable a service-level tracing which was never explicitly enabled on a specific instance
Action:
ORA-13855: Tracing for service (module/action) string on instance string is already enabled
Cause:
Attempt to enable a service-level tracing which has been already enabled on a specific instance
Action:
ORA-13856: Service name must be specified
Cause:
Omitting service name while enabling/disabling tracing or aggregation
Action:
Supply the service name
ORA-13857: Invalid module name
Cause:
Module name is too long (exceeding 48 characters)
Action:
Supply correct name
ORA-13858: Invalid action name
Cause:
Action name is too long (exceeding 32 characters)
Action:
Supply correct name
ORA-13859: Action cannot be specified without the module specification
Cause:
Action name is specified, but the module name is not
Action:
Supply the module name
ORA-13860: Invalid service name
Cause:
Service name is too long (exceeding 64 characters)
Action:
Supply correct name
ORA-13861: Statistics aggregation for client identifier string is already enabled
Cause:
Attempt to enable a client identifier aggregation which has been already enabled
Action:
ORA-13862: Statistics aggregation for client identifier string is not enabled
Cause:
Attempt to disable a client identifier statistics aggregation which was never enabled
Action:
ORA-13863: Statistics aggregation for service(module/action) string is not enabled
Cause:
Attempt to disable a service-level statistics aggregation which was never enabled
Action:
ORA-13864: Statistics aggregation for service (module/action) string is already enabled
Cause:
Attempt to enable a service-level statistics aggregation which has been already enabled
Action:
ORA-13865: Module name must be specified
Cause:
Attempt to enable/disable a service-level statistics aggregation without a module specification
Action:
Supply module name
ORA-13866: Client identifier must be specified
Cause:
Omitting client identifier while enabling/disabling tracing or aggregation
Action:
Supply the client identifier
ORA-13867: Database-wide SQL tracing is already enabled
Cause:
Attempt to enable a database-level tracing which has been already enabled
Action:
Disable and re-enable tracing with different bind/wait options
ORA-13868: Instance-wide SQL tracing on instance string is not enabled
Cause:
Action:
No action required
ORA-13869: Instance-wide SQL tracing on instance string is already enabled
Cause:
Attempt to enable an instance-level tracing which has been already enabled on a specific instance
Action:
ORA-13870: Database-wide SQL tracing is not enabled
Cause:
Attempt to disable a database-level tracing which was never enabled
Action:
No action required
ORA-13871: Invalid instance name
Cause:
Instance name is too long (exceeding 16 characters)
Action:
Supply correct name
ORA-13900: missing or invalid parameter string
Cause:
A call to SET_THRESHOLD procedure was either missing a parameter, or the parameter was invalid.
Action:
ORA-13901: Object string was not found.
Cause:
An object name was passed to SET_THRESHOLD procedure that did not map to a valid object.
Action:
Specify a valid object name.
ORA-13902: The specified file string is not a data file.
Cause:
The object name was passed to a SET_THRESHOLD procedure that did not map to a valid data file.
Action:
Specify a valid data file name.
ORA-13903: Invalid combination of string threshold value and operator.
Cause:
A non-positive number was used for "Blocked User Session Count" metrics while operator contains equal.
Action:
Use a positive number for the threshold value or use "greater than" operator.
ORA-13904: The file has been dropped and recreated during the procedure call.
Cause:
The file on which threshold is specified was dropped and recreated during the procedure call.
Action:
Retry this operation.
ORA-13905: Critical or warning threshold have incorrect values
Cause:
The tablespace threshold values can be in the range 0 to 100 only.
Action:
Check the threshold values
ORA-13906: The tablespace is not of the right type.
Cause:
An attempt was made to set a threshold on dictionary-managed tablespaces.
Action:
Check the tablespace type and reissue the command.
ORA-13907: Threshold value is invalid.
Cause:
An attempt was made to specify an invalid value for critical or warning thresholds.
Action:
Use non-negative integers only for threshold values.
ORA-13908: Invalid combination of metrics id and object type parameters.
Cause:
An attempt was made to specify an invalid combination of metrics id // and object type parameters.
Action:
Specify a valid combination of metrics id and object type parameters.
ORA-13909: Invalid combination of threshold value and operator.
Cause:
An attempt was made to specify an invalid combination of threshold value and operator.
Action:
Check the operator and threshold values and reissue statement.
ORA-13910: Parameter string cannot be NULL.
Cause:
An attempt was made to call GET_THRESHOLD procedure without a required parameter.
Action:
ORA-13911: Threshold not found
Cause:
The threshold did not exist with the specified threshold key.
Action:
No action required.
ORA-13912: Critical threshold value is less than warning threshold value.
Cause:
An attempt was made to call SET_THRESHOLD procedure with the critical threshold value less than the warning threshold value.
Action:
Check the threshold values and reissue the statement.
ORA-13913: The threshold cannot be set when SYSAUX is offline.
Cause:
SET_THRESHOLD procedure was called when SYSAUX tablespace was offline.
Action:
Call SET_THRESHOLD procedure when SYSAUX is online.
ORA-13914: Threshold notification failed.
Cause:
An error occurred when sending notification for this threshold.
Action:
Make sure you have enough space on SYSAUX tablespace and retry this operation.
ORA-13915: Critical byte based free space threshold value is greater than warning threshold value.
Cause:
An attempt was made to call SET_THRESHOLD procedure with the bytes based critical threshold value greater than the warning threshold value.
Action:
ORA-13916: Invalid value "string" specified for parameter "string"
Cause:
An invalid value was specified for the the given parameter.
Action:
Correct the value being specified for the parameter.
ORA-13917: Posting system alert with reason_id string failed with code [string] [string]
Cause:
Connection to the database is dead, or invalid parameter to alert routine.
Action:
If this condition repeats, please contact Oracle Support.
ORA-13918: Updating system alert with reason_id string failed; previous alert not found
Cause:
System Error: An attempt to update a system alert failed. The alert was improperly cleared from WRI$_ALERT_OUTSTANDING.
Action:
Do not delete from WRI$_ALERT_OUTSTANDING. If this condition repeats, please contact Oracle Support.
ORA-13919: Cannot specify values for parameter "string" and for parameter "string"
Cause:
Can only specify a value for one or the other.
Action:
Pass just one of the parameters.
ORA-13920: Threshold cannot be set when database is in read-only mode.
Cause:
SET_THRESHOLD procedure was called when database was open in read-only mode.
Action:
Call SET_THRESHOLD procedure when database is open in read/write mode.
ORA-13951: MMON sub-action time limit exceeded
Cause:
MMON sub-action did not complete within the system specified time frame.
Action:
None
ORA-13970: Invalid name of "string" given
Cause:
Passed an invalid component, report, or transformation name to the framework. Names must be alphanumeric and can contain the underscore (_) character.
Action:
Try again with a valid name
ORA-13971: string "string" unknown
Cause:
Passed an unknown component, report, or transformation to the framework.
Action:
Give a different name
ORA-13972: string "string" unknown for string "string"
Cause:
An object with the first name is unknown within the naming scope of the second name
Action:
Change the parameters passed in or register the proper object
ORA-13973: string unknown for string "string"
Cause:
An object is unknown within the given naming scope
Action:
ORA-13974: string with name "string" already exists
Cause:
An object with the given name already exists
Action:
ORA-13975: string with name "string" already exists for string "string"
Cause:
An object with the first name already exists within the naming scope of the second name
Action:
ORA-13976: Improperly-formed report tag
Cause:
The top-level report tag was not built properly
Action:
Make sure that the report tag is built using the common tag library function
ORA-13977: Invalid content type
Cause:
An invalid content type was passed to the register format API
Action:
Correct your code to use the values in dbmsrep.sql
ORA-13978: Invalid reference string parameter or value
Cause:
An invalid parameter/value was passed to a dbms_report API
Action:
Ensure that the parameter names and values are alphanumeric.
ORA-13979: Filename too long
Cause:
An invalid file name was passed to STORE_FILE
Action:
Ensure that the filename is less than 500 bytes
ORA-13980: Invalid file URL
Cause:
A URL with invalid syntax was provided, either directly to the function or via an XML IMPORT or INCLUDE.
Action:
Check the URL.
ORA-13981: Invalid file URL or path prefix
Cause:
Either a URL or path prefix with invalid syntax was provided.
Action:
Check the URL
ORA-13982: Could not find file at URL provided
Cause:
The file requested could not be found in the given location.
Action:
Check the URL provided.
ORA-13983: Missing body tag from HTML
Cause:
An HTML document was passed to the function missing its body tag.
Action:
Check the HTML source.
ORA-13984: Invalid reference string
Cause:
The given reference string could not be parsed.
Action:
Check the reference string syntax.
ORA-13985: Invalid URL provided to servlet
Cause:
An invalid URL was provided to the servlet.
Action:
Check the URL.
ORA-13986: Error \string received from XPath engine
Cause:
An error was received from the xpath library during an xpath operation.
Action:
Check xmlerr.h to understand the cause of the error.
ORA-13987: Invalid input to build common <string> tag
Cause:
Invalid input was given when attempting to build a common tag.
Action:
Check the function input to make sure all necessary information is given.
ORA-13988: Invalid input given to variable argument list report function.
Cause:
An invalid parameter was provided to one of the report framework variable argument list functions.
Action:
Check the function input and try again.
ORA-13989: Invalid input given to structured argument list report function.
Cause:
An invalid parameter was provided to one of the report framework structured argument list functions.
Action:
ORA-13990: Invalid tag name given to common tag callout function.
Cause:
This is an internal Server Manageability Error
Action:
Contact Oracle Support Services
ORA-14000: only one LOCAL clause may be specified
Cause:
CREATE INDEX statement contained more than one LOCAL clause
Action:
Specify LOCAL option at most once
ORA-14001: LOCAL clause contradicts previosly specified GLOBAL clause
Cause:
CREATE INDEX statement contained a GLOBAL clause and a LOCAL clause
Action:
Specify LOCAL or GLOBAL clause, but not both
ORA-14002: only one GLOBAL clause may be specified
Cause:
CREATE INDEX statement contained more than one GLOBAL clause
Action:
Specify GLOBAL option at most once
ORA-14003: GLOBAL clause contradicts previosly specified LOCAL clause
Cause:
CREATE INDEX statement contained a LOCAL clause and a GLOBAL clause
Action:
Specify GLOBAL or LOCAL clause, but not both
ORA-14004: missing PARTITION keyword
Cause:
keyword PARTITION missing
Action:
supply missing keyword
ORA-14005: missing RANGE keyword
Cause:
keyword RANGE missing
Action:
ORA-14006: invalid partition name
Cause:
a partition name of the form identifier is expected but not present.
Action:
enter an appropriate partition name.
ORA-14007: missing LESS keyword
Cause:
keyword LESS missing
Action:
ORA-14008: missing THAN keyword
Cause:
keyword THAN missing
Action:
ORA-14009: partition bound may not be specified for a LOCAL index partition
Cause:
while parsing a CREATE INDEX statement to create a LOCAL partitioned index, partition-description of one of partitions was found to contain VALUES LESS THAN clause which is illegal since a LOCAL index inherits partition bounds from its base table
Action:
remove all VALUES LESS THAN clauses from descriptions of LOCAL index partitions
ORA-14010: this physical attribute may not be specified for an index partition
Cause:
unexpected option was encountered while parsing physical attributes of an index partition; valid options for Range or Composite Range partitions are INITRANS, MAXTRANS, TABLESPACE, STORAGE, PCTFREE; only TABLESPACE may be specified for Hash partitions
Action:
remove invalid option(s) from the list of physical attributes of an index partition
ORA-14011: names assigned to resulting partitions must be distinct
Cause:
Names of partitions resulting from splitting of an existing table or index partition are not distinct
Action:
rename resulting partition(s) to ensure that their names are distinct and different from those of any other partition of the table or index
ORA-14012: resulting partition name conflicts with that of an existing partition
Cause:
Name of a partition resulting from splitting of an existing table or index partition is identical to that of some other existing partition of that table or index
Action:
ORA-14013: duplicate partition name
Cause:
Name of a partition of a table or index being created is not unique
Action:
rename partition(s) to ensure that their names are unique among partitions of the table or index being created
ORA-14014: maximum number of partitioning columns is 16
Cause:
number of columns in a partitioning column list exceeded the legal limit of 16
Action:
modify partitioning column list so that it consists of at most 16 columns
ORA-14015: too many partition descriptions
Cause:
CREATE TABLE or CREATE INDEX contained too many partition descriptions; maximum number of partitions is 1048575 (1024K-1).
Action:
Reduce number of partitions to not exceed 1048575 (1024K -1).
ORA-14016: underlying table of a LOCAL partitioned index must be partitioned
Cause:
User attempted to create a LOCAL partitioned index on a non-partitioned table which is illegal. Only GLOBAL indices (partitioned or otherwise) may be created on a non-partitioned table.
Action:
Correct the statement and reenter
ORA-14017: partition bound list contains too many elements
Cause:
Partition bound list contained more elements than there are partitioning columns
Action:
Ensure that the number of elements in partition bound list is equal to the number of partitioning columns of the table or index
ORA-14018: partition bound list contains too few elements
Cause:
Partition bound list contained fewer elements than there are partitioning columns
Action:
ORA-14019: partition bound element must be one of: string, datetime or interval literal, number, or MAXVALUE
Cause:
Partition bound list contained an element of invalid type (i.e. not a number, non-empty string, datetime or interval literal, or MAXVALUE)
Action:
Ensure that all elements of partition bound list are of valid type
ORA-14020: this physical attribute may not be specified for a table partition
Cause:
unexpected option was encountered while parsing physical attributes of a table partition; valid options for Range or Composite Range partitions are INITRANS, MAXTRANS, TABLESPACE, STORAGE, PCTFREE, and PCTUSED; only TABLESPACE may be specified for Hash partitions
Action:
remove invalid option(s) from the list of physical attributes of a table partition
ORA-14021: MAXVALUE must be specified for all columns
Cause:
In the VALUES LESS THAN clause for the highest (last) partition of a GLOBAL index, MAXVALUE must be specified for all columns
Action:
Ensure that VALUES LESS THAN clause for the last partition of a GLOBAL index has MAXVALUE specified for all columns
ORA-14022: creation of LOCAL partitioned cluster indices is not supported
Cause:
An attempt was made to create a LOCAL partitioned cluster index, which is currently illegal
Action:
Remove LOCAL along with partition descriptions, if any, from the CREATE INDEX statement.
ORA-14023: creation of GLOBAL partitioned cluster indices is not supported
Cause:
An attempt was made to create a GLOBAL partitioned cluster index, which is currently illegal
Action:
Remove PARTITION BY RANGE clause along with partition descriptions from the CREATE INDEX statement.
ORA-14024: number of partitions of LOCAL index must equal that of the underlying table
Cause:
User attempted to create a LOCAL partitioned index with a number of partitions which is different from that of the underlying table.
Action:
Correct the CREATE INDEX statement to specify a correct number of partitions
ORA-14025: PARTITION may not be specified for a materialized view or a materialized view log
Cause:
PARTITION option was encountered while parsing a definition of a materialized view or a materialized view log
Action:
Ensure that a definition of a MATERIALIZED VIEW does not include invalid options
ORA-14026: PARTITION and CLUSTER clauses are mutually exclusive
Cause:
definition of a table contained both PARTITION and CLUSTER clauses which is illegal
Action:
Remove one of the conflicting clauses
ORA-14027: only one PARTITION clause may be specified
Cause:
CREATE TABLE statement contained more than one PARTITION clause
Action:
Specify PARTITION option at most once
ORA-14028: missing AT or VALUES keyword
Cause:
keyword AT or VALUES missing
Action:
ORA-14029: GLOBAL partitioned index must be prefixed
Cause:
partitioning columns of a global partitioned index must form a prefix of the index' key columns
Action:
Ensure that the GLOBAL partitioned index being created is prefixed
ORA-14030: non-existent partitioning column in CREATE TABLE statement
Cause:
Partitioning column specified in CREATE TABLE statement is not one of columns of the table being created.
Action:
Ensure that all columns in the partitioning column list are columns of the table being created.
ORA-14031: partitioning column may not be of type LONG or LONG RAW
Cause:
Partitioning column specified by the user was of type LONG or LONG RAW, which is illegal.
Action:
Ensure that no partitioning column is of type LONG or LONG RAW.
ORA-14032: partition bound of partition number string is too high
Cause:
High bound of the partition whose number (partitions are numbered starting with 1) is displayed in this message did not collate lower than that of the following partition, which is illegal.
Action:
Ensure that high bound of every partition (except for the last one) collates lower than that of a following partition.
ORA-14036: partition bound value too large for column
Cause:
Length of partition bound value is longer than that of the corresponding partitioning column.
Action:
Ensure that lengths of high bound values do not exceed those of corresponding partitioning columns
ORA-14037: partition bound of partition "string" is too high
Cause:
High bound of the partition whose name (explicitly specified by the user) is displayed in this message did not collate lower than that of the following partition, which is illegal.
Action:
ORA-14038: GLOBAL partitioned index must be prefixed
Cause:
User attempted to create a GLOBAL non-prefixed partitioned index which is illegal
Action:
If the user, indeed, desired to create a non-prefixed index, it must be created as LOCAL; otherwise, correct the list of key and/or partitioning columns to ensure that the index is prefixed
ORA-14039: partitioning columns must form a subset of key columns of a UNIQUE index
Cause:
User attempted to create a UNIQUE partitioned index whose partitioning columns do not form a subset of its key columns which is illegal
Action:
If the user, indeed, desired to create an index whose partitioning columns do not form a subset of its key columns, it must be created as non-UNIQUE; otherwise, correct the list of key and/or partitioning columns to ensure that the index' partitioning columns form a subset of its key columns
ORA-14041: partition bound may not be specified for resulting partitions
Cause:
while parsing an ALTER {TABLE|INDEX} SPLIT PARTITION statement, partition-description of a resulting partition was found to contain VALUES LESS THAN clause which is illegal
Action:
remove VALUES LESS THAN clause from the description(s) of partitions resulting from splitting an existing table or index partition
ORA-14042: partition bound may not be specified for a partition being moved, modified or rebuilt
Cause:
while parsing an ALTER {TABLE|INDEX} MODIFY PARTITION, ALTER TABLE MOVE PARTITION, or ALTER INDEX REBUILD PARTITION statement, description of new physical attributes of the partition being moved, modified, or rebuilt was found to contain VALUES LESS THAN clause which is illegal
Action:
remove VALUES LESS THAN clause from the description of new attributes of the partition being moved, modified, or rebuilt
ORA-14043: only one partition may be added
Cause:
ALTER TABLE ADD PARTITION contained descriptions of more than one partition to be added
Action:
Ensure that the statement contains exactly one partition definition and that it does not contain any commas
ORA-14044: only one partition may be moved
Cause:
ALTER TABLE MOVE PARTITION contained descriptions of more than one partition to be moved
Action:
Ensure that the statement describes exactly one partition to be moved and that it does not contain any commas
ORA-14045: only one partition may be modified
Cause:
ALTER TABLE|INDEX MODIFY PARTITION contained descriptions of more than one partition to be modified
Action:
Ensure that the statement describes exactly one partition to be modified and that it does not contain any commas
ORA-14046: a partition may be split into exactly two new partitions
Cause:
ALTER TABLE|INDEX SPLIT PARTITION did not contain descriptions of exactly two new partitions into which an existing table or index partition was to be split
Action:
Ensure that the statement describes exactly two partition into which an existing partition is to be split
ORA-14047: ALTER TABLE|INDEX RENAME may not be combined with other operations
Cause:
ALTER TABLE or ALTER INDEX statement attempted to combine a RENAME operation with some other operation which is illegal
Action:
Ensure that RENAME operation is the sole operation specified in ALTER TABLE or ALTER INDEX statement;
ORA-14048: a partition maintenance operation may not be combined with other operations
Cause:
ALTER TABLE or ALTER INDEX statement attempted to combine a partition maintenance operation (e.g. MOVE PARTITION) with some other operation (e.g. ADD PARTITION or PCTFREE which is illegal
Action:
Ensure that a partition maintenance operation is the sole operation specified in ALTER TABLE or ALTER INDEX statement; operations other than those dealing with partitions, default attributes of partitioned tables/indices or specifying that a table be renamed (ALTER TABLE RENAME) may be combined at will
ORA-14049: invalid ALTER TABLE MODIFY PARTITION option
Cause:
An option other than PCTFREE, PCTUSED, INITRANS, MAXTRANS, STORAGE, BACKUP, ALLOCATE EXTENT, or DEALLOCATE UNUSED was specified in an ALTER TABLE MODIFY PARTITION statement for a Range or Composite Range partition.
Action:
Specify only legal options.
ORA-14050: invalid ALTER INDEX MODIFY PARTITION option
Cause:
An option other than INITRANS, MAXTRANS, STORAGE, or DEALLOCATE UNUSED was specified in an ALTER INDEX MODIFY PARTITION statement.
Action:
ORA-14051: invalid ALTER MATERIALIZED VIEW option
Cause:
An option other than PCTFREE, PCTUSED, INITRANS, MAXTRANS, STORAGE, or BACKUP was specified in an ALTER MATERIALIZED VIEW statement.
Action:
ORA-14052: partition-extended table name syntax is disallowed in this context
Cause:
User attempted to use partition-extended table name syntax in illegal context (i.e. not in FROM-clause or INSERT, DELETE, or UPDATE statement)
Action:
Avoid use of partition-extended table name in contexts other those mentioned above.
ORA-14053: illegal attempt to modify string in string statement
Cause:
Certain attributes of objects (e.g. tables) may be specified at creation time, but may not be modified using ALTER statement. Unfortunately, user specified one of such attributes.
Action:
Ensure that ALTER statement specifies new values only for attributes which may be changed once an object has been created
ORA-14054: invalid ALTER TABLE TRUNCATE PARTITION option
Cause:
Name of the partition to be truncated may be followed by DROP STORAGE or REUSE STORAGE
Action:
Ensure that no options besides DROP STORAGE or REUSE STORAGE are specified with ALTER TABLE TRUNCATE PARTITION
ORA-14055: keyword REBUILD in ALTER INDEX REBUILD must immediately follow index name
Cause:
ALTER INDEX statement contained REBUILD keyword following some index attributes (e.g. INITRANS.)
Action:
Ensure that keyword REBUILD immediately follows the name of the index being altered
ORA-14056: partition number string: sum of PCTUSED and PCTFREE may not exceed 100
Cause:
the sum of PCTUSED and PCTFREE for a partition whose number (partitions are numbered starting with 1) is displayed in this message exceeds 100. Note that if PCTUSED and/or PCTFREE values for this partition were not specified explicitly, default values for the partitioned table or index would be used. If, in turn, default PCTUSED and/or PCTFREE values for the partitioned table or index were not specified, system defaults would be used.
Action:
ensure that a sum of PCTUSED and PCTFREE for the partition does not exceed 100
ORA-14057: partition "string": sum of PCTUSED and PCTFREE may not exceed 100
Cause:
the sum of PCTUSED and PCTFREE for a partition whose name (explicitly specified by the user) is displayed in this message exceeds 100. Note that if PCTUSED and/or PCTFREE values for this partition were not specified explicitly, default values for the partitioned table or index would be used. If, in turn, default PCTUSED and/or PCTFREE values for the partitioned table or index were not specified, system defaults would be used.
Action:
ORA-14058: partition number string: INITRANS value must be less than MAXTRANS value
Cause:
Value of INITRANS was found to be greater than that of MAXTRANS for a partition whose number (partitions are numbered starting with 1) is displayed in this message. Note that if INITRANS and/or MAXTRANS values for this partition were not specified explicitly, default values for the partitioned table or index would be used. If, in turn, default INITRANS and/or MAXTRANS values for the partitioned table or index were not specified, system defaults would be used.
Action:
ensure that value of INITRANS (whether specified explcitly or derived from the default value for the partitioned table or index) is no greater than that of MAXTRANS
ORA-14059: partition "string": INITRANS value must be less than MAXTRANS value
Cause:
Value of INITRANS was found to be greater than that of MAXTRANS for a partition whose name (explicitly specified by the user) is displayed in this message. Note that if INITRANS and/or MAXTRANS values for this partition were not specified explicitly, default values for the partitioned table or index would be used. If, in turn, default INITRANS and/or MAXTRANS values for the partitioned table or index were not specified, system defaults would be used.
Action:
ORA-14060: data type or length of a table partitioning column may not be changed
Cause:
User issued ALTER TABLE statement attempting to modify data type and/or length of a column used to partition the table named in ALTER TABLE statement, which is illegal
Action:
Avoid modifying data type and/or length of table partitioning column(s)
ORA-14061: data type or length of an index partitioning column may not be changed
Cause:
User issued ALTER TABLE statement attempting to modify data type and/or length of a column used to partition some index defined on the table named in ALTER TABLE statement, which is illegal
Action:
Avoid modifying data type and/or length of index partitioning column(s)
ORA-14062: one or more of table's partitions reside in a read-only tablespace
Cause:
User issued ALTER TABLE statement attempting to modify an existing VARCHAR2 (or VARCHAR) column to be of type CHAR (or CHARACTER), increase length of an existing CHAR (or CHARACTER) column, or add a column with user-specified default for a table one or more partitions of which reside in read-only tablespaces, which is illegal
Action:
Avoid performing aformentioned operations on a partitioned table one or more partitions of which reside in read-only tablespaces
ORA-14063: Unusable index exists on unique/primary constraint key
Cause:
User attempted to add or enable a primary key/unique constraint on column(s) of a table on which there exists an index marked Index Unusable.
Action:
Drop the existing index or rebuild it using ALTER INDEX REBUILD
ORA-14064: Index with Unusable partition exists on unique/primary constraint key
Cause:
User attempted to add or enable a primary key/unique constraint on column(s) of a table on which there exists an index one or more partitions of which are marked Index Unusable.
Action:
Drop the existing index or rebuild unusable partitions it using ALTER INDEX REBUILD PARTITION
ORA-14065: ALLOCATE STORAGE may not be specified for a partitioned table
Cause:
User specified ALLOCATE STORAGE clause in ALTER TABLE statement issued against a partitioned table which is illegal.
Action:
Remove the illegal option. If it is desired to add storage to individual partitions, ALLOCATE STORAGE clause may be specified with ALTER TABLE MODIFY PARTITION statement.
ORA-14066: illegal option for a non-partitioned index-organized table
Cause:
An attempt was made to issue a CREATE or ALTER TABLE command on a non-partitioned IOT, but the command contains an option that is legal only for partitioned index-organized tables. Such options are: ENABLE ROW MOVEMENT and DISABLE ROW MOVEMENT.
Action:
Remove the illegal option(s) from the command.
ORA-14067: duplicate TABLESPACE_NUMBER specification
Cause:
TABLESPACE_NUMBER clause was specified more than once for an table, index or an index partition
Action:
Correct the code generating text of CREATE INDEX statement sent to the slaves
ORA-14068: TABLESPACE and TABLESPACE_NUMBER may not be both specified
Cause:
Both TABLESPACE and TABLESPACE_NUMBER clauses were specified for a table, index or an index partition
Action:
ORA-14069: invalid TABLESPACE_NUMBER value
Cause:
The TABLESPACE_NUMBER value is not an integer between 0 and 0x7FFFFFFF
Action:
ORA-14070: option may be specified only for partitioned indices or with REBUILD
Cause:
User issued ALTER INDEX statament containing an option which is legal only for partitioned indices or in conjunction with REBUILD against a non-partitioned index. Such options are: PCTFREE, TABLESPACE, [NO]PARALLEL and INITIAL, FREELISTS, and FREELIST GROUPS inside STORAGE clause
Action:
Remove illegal option(s).
ORA-14071: invalid option for an index used to enforce a constraint
Cause:
An option other than COMPRESS, NOCOMPRESS, PCTFREE, INITRANS, MAXTRANS, STORAGE, TABLESPACE, PARALLEL, NOPARALLEL, RECOVERABLE, UNRECOVERABLE, LOGGING, NOLOGGING, LOCAL, or GLOBAL was specified for an index used to enforce a constraint.
Action:
Choose one of the valid index options.
ORA-14072: fixed table may not be truncated
Cause:
User attempted to truncate a fixed table which is illegal.
Action:
Ensure that the table being truncated is not a fixed table.
ORA-14073: bootstrap table or cluster may not be truncated
Cause:
User attempted to truncate a bootstrap table or cluster which is illegal
Action:
Ensure that the table (or cluster) being truncated is not a bootstrap table (or cluster)
ORA-14074: partition bound must collate higher than that of the last partition
Cause:
Partition bound specified in ALTER TABLE ADD PARTITION statement did not collate higher than that of the table's last partition, which is illegal.
Action:
Ensure that the partition bound of the partition to be added collates higher than that of the table's last partition.
ORA-14075: partition maintenance operations may only be performed on partitioned indices
Cause:
Index named in ALTER INDEX partition maintenance operation is not partitioned, making a partition maintenance operation, at best, meaningless
Action:
Ensure that the index named in ALTER INDEX statement specifying a partition maintenance operation is, indeed, partitioned
ORA-14076: submitted alter index partition/subpartition operation is not valid for local partitioned index
Cause:
User attempted to either drop, split, add or coalesce a partition or a subpartition of a local index which is illegal.
Action:
Ensure that the index named in such statement is a global partitioned index.
ORA-14078: you may not drop the highest partition of a GLOBAL index
Cause:
User attempted to drop highest partition of a GLOBAL index, which is illegal.
Action:
Ensure that the partition specified in ALTER INDEX DROP PARTITION statement is not the highest partition of the index.
ORA-14079: illegal option for a partition marked Index Unusable
Cause:
ALTER INDEX MODIFY PARTITION statement against an index partition marked Index Unusable contained STORAGE and/or DEALLOCATE SPACE clauses which is illegal
Action:
Ensure that only valid optins are specified
ORA-14080: partition cannot be split along the specified high bound
Cause:
User attempted to split a partition along a bound which either collates higher than that of the partition to be split or lower than that of a partition immediately preceding the one to be split
Action:
Ensure that the bound along which a partition is to be split collates lower than that of the partition to be split and higher that that of a partition immediately preceding the one to be split
ORA-14081: new partition name must differ from the old partition name
Cause:
User entered ALTER TABLE/INDEX RENAME PARTITION specifying new-partition-name which is identical to the name of the partition being renamed
Action:
Ensure that the new partition name is different from the name of any (including the one being renamed) existing partition of a given table or index
ORA-14082: new partition name must differ from that of any other partition of the object
Cause:
User entered ALTER TABLE/INDEX RENAME PARTITION specifying new-partition-name which is identical to the name of some existing partition of the object
Action:
ORA-14083: cannot drop the only partition of a partitioned table
Cause:
A drop partition command is being executed when there is only one partition in the table
Action:
Ensure that there is at least one partition. Drop table to remove all partitions
ORA-14084: you may specify TABLESPACE DEFAULT only for a LOCAL index
Cause:
User attempted to specify TABLESPACE DEFAULT for an object other than a LOCAL index, which is illegal.
Action:
Reenter the statement without TABLESPACE DEFAULT clause.
ORA-14085: partitioned table cannot have column with LONG datatype
Cause:
User tried to create a partitioned table with a LONG datatype or tried to add a LONG datatype column to a partitioned table.
Action:
LONG data types are not supported with partitioned tables. Create table without LONG column or change table to not partitioned. If adding column, do not use LONG datatype. If modifying attributes of a column to change data type to LONG, it has to be a non partitioned table.
ORA-14086: a partitioned index may not be rebuilt as a whole
Cause:
User attempted to rebuild a partitioned index using ALTER INDEX REBUILD statement, which is illegal
Action:
Rebuild the index a partition at a time (using ALTER INDEX REBUILD PARTITION) or drop and recreate the entire index
ORA-14094: invalid ALTER TABLE EXCHANGE PARTITION option
Cause:
Name of the table to be EXCHANGED has to be followed by [{INCLUDING|EXCLUDING} INDEX][{WITH|WITHOUT} VALIDATION]
Action:
Ensure that no options besides INCLDING INDEX or EXCLUDING INDEX are specified with ALTER TABLE EXCHANGE PARTITION
ORA-14095: ALTER TABLE EXCHANGE requires a non-partitioned, non-clustered table
Cause:
The table in the EXCHANGE operation is either clustered or partitioned
Action:
Ensure that the table with which the partition is being exchanged for is not partitioned or clustered.
ORA-14096: tables in ALTER TABLE EXCHANGE PARTITION must have the same number of columns
Cause:
The two tables specified in the EXCHANGE have different number of columns
Action:
Ensure that the two tables have the same number of columns with the same type and size.
ORA-14097: column type or size mismatch in ALTER TABLE EXCHANGE PARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE PARTITION are of different type or size
Action:
ORA-14098: index mismatch for tables in ALTER TABLE EXCHANGE PARTITION
Cause:
The two tables specified in the EXCHANGE have indexes which are not equivalent
Action:
Ensure that the indexes for the two tables have indexes which follow this rule For every non partitioned index for the non partitioned table, there has to be an identical LOCAL index on the partitioned table and vice versa. By identical, the column position, type and size have to be the same.
ORA-14099: all rows in table do not qualify for specified partition
Cause:
There is at least one row in the non partitioned table which does not qualify for the partition specified in the ALTER TABLE EXCHANGE PARTITION
Action:
Ensure that all the rows in the segment qualify for the partition. Perform the alter table operation with the NO CHECKING option. Run ANALYZE table VALIDATE on that partition to find out the invalid rows and delete them.
ORA-14100: partition extended table name cannot refer to a remote object
Cause:
User attempted to use partition-extended table name syntax in conjunction with remote object name which is illegal
Action:
ORA-14101: partition extended table name cannot refer to a synonym
Cause:
User attempted to use partition-extended table name syntax in conjunction with synonym name which is illegal
Action:
ORA-14102: only one LOGGING or NOLOGGING clause may be specified
Cause:
LOGGING was specified more than once, NOLOGGING was specified more than once, or both LOGGING and NOLOGGING were specified.
Action:
Remove all but one of the LOGGING or NOLOGGING clauses and reissue the statement.
ORA-14103: LOGGING/NOLOGGING may not be combined with RECOVERABLE/UNRECOVERABLE
Cause:
A statement contained both [NO]LOGGING and [UN]RECOVERABLE clauses which is disallowed.
Action:
Remove one of the offending clauses. [UN]RECOVERABLE is being deprecated in V8 and will be obsoleted in V9. To duplicate semantics of UNRECOVERABLE clause, create an object with NOLOGGING option and then ALTER it specifying LOGGING. To duplicate semantics of RECOVERABLE clause, create an object with LOGGING option.
ORA-14104: RECOVERABLE/UNRECOVERABLE may not be specified for partitioned tables/indices
Cause:
CREATE TABLE/INDEX statement used to create a partitioned table/index contained RECOVERABLE or UNRECOVERABLE clause which is illegal
Action:
Remove offending clause. [UN]RECOVERABLE is being deprecated in V8 and will be obsoleted in V9. To duplicate semantics of UNRECOVERABLE clause, create an object with NOLOGGING option and then ALTER it specifying LOGGING. To duplicate semantics of RECOVERABLE clause, create an object with LOGGING option.
ORA-14105: RECOVERABLE/UNRECOVERABLE may not be specified in this context
Cause:
RECOVERABLE/UNRECOVERABLE clause is not allowed in this context.
Action:
Remove offending clause. RECOVERABLE/UNRECOVERABLE may only be specified in CREATE TABLE/INDEX statement describing a non-partitioned table or index and ALTER INDEX REBUILD statement. [UN]RECOVERABLE is being deprecated in V8 and will be obsoleted in V9. To duplicate semantics of UNRECOVERABLE clause, create an object with NOLOGGING option and then ALTER it specifying LOGGING. To duplicate semantics of RECOVERABLE clause, create an object with LOGGING option.
ORA-14106: LOGGING/NOLOGGING may not be specified for a clustered table
Cause:
User attempted to specify LOGGING or NOLOGGING clausein CREATE TABLE or ALTER TABLE statement involving a clustered table
Action:
ORA-14107: partition specification is required for a partitioned object
Cause:
parameter which supplies partition name is missing. This parameter is optional for non-partitioned objects, but is required for partitioned objects.
Action:
supply missing parameter
ORA-14108: illegal partition-extended table name syntax
Cause:
Partition to be accessed may only be specified using its name. User attempted to use a partition number or a bind variable.
Action:
Modify statement to refer to a partition using its name
ORA-14109: partition-extended object names may only be used with tables and editioning views
Cause:
An attempt was made to use a partition-extended object name with an object which was not a table or an editioning view.
Action:
Avoid using partition-extended name syntax with objects which are not tables or editioning views
ORA-14110: partitioning column may not be of type ROWID
Cause:
Partitioning column specified by the user was of type ROWID, which is illegal.
Action:
Ensure that no partitioning column is of type ROWID.
ORA-14111: creation of a GLOBAL partitioned index on clustered tables is not supported
Cause:
An attempt was made to create a GLOBAL partitioned index on a clustered table which is currently illegal.
Action:
Remove PARTITION BY RANGE/HASH clause along with any partition descriptions to create a GLOBAL non-partitioned index on a clustered table
ORA-14112: RECOVERABLE/UNRECOVERABLE may not be specified for a partition or subpartition
Cause:
Description of a partition or subpartition found in CREATE TABLE/INDEX statement contained RECOVERABLE or UNRECOVERABLE clause which is illegal
Action:
Remove offending clause. Use LOGGING or NOLOGGING instead.
ORA-14113: partitioned table cannot have column with LOB datatype
Cause:
User tried to create a partitioned table with a LOB datatype or tried to add a LOB datatype column to a partitioned table.
Action:
LOB data types are not supported with partitioned tables. Create table without LOB column or change table to not partitioned. If adding column, do not use LOB datatype. If modifying attributes of a column to change data type to LOB, it has to be a non partitioned table.
ORA-14114: partitioned table cannot have column with object, REF, nested table, array datatype
Cause:
User tried to create a partitioned table with a object datatype (object, REF, nested table, array) or tried to add a object datatype column to a partitioned table.
Action:
object data types are not supported with partitioned tables. Create table without object column or change table to not partitioned. If adding column, do not use object datatypes. If modifying attributes of a column to change data type to object, it has to be a non partitioned table.
ORA-14115: partition bound of partition number string is too long
Cause:
Length of linear key representation of a high bound of the partition whose number (partitions are numbered starting with 1) is displayed in this message exceeded the legal limit (4K).
Action:
Change representation of a partition high bound to bring its length within legal limit.
ORA-14116: partition bound of partition "string" is too long
Cause:
Length of linear key representation of a high bound of the partition whose name (explicitly specified by the user) is displayed in this message exceeded the legal limit (4K).
Action:
ORA-14117: partition resides in offlined tablespace
Cause:
User attempted an operation requiring that we access data in a partition which resides in a tablespace which was taken offline. Such operations include trying to drop a tablespace of a table which has indices defined on it or is referenced by a constraint.
Action:
Bring tablespace online before attempting the operation.
ORA-14118: CHECK constraint mismatch in ALTER TABLE EXCHANGE PARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE PARTITION statement have CHECK constraint defined on them.
Action:
Ensure that the two tables do not have CHECK constraint defined on any column
ORA-14119: specified partition bound is too long
Cause:
Length of a linear key representation of a high bound of a table partition being added or along which an existing table or index partition is being split exceeded the legal limit (4K).
Action:
ORA-14120: incompletely specified partition bound for a DATE column
Cause:
An attempt was made to use a date expression whose format does not fully (i.e. day, month, and year (including century)) specify a date as a partition bound for a DATE column. The format may have been specified explicitly (using TO_DATE() function) or implicitly (NLS_DATE_FORMAT).
Action:
Ensure that date format used in a partition bound for a DATE column supports complete specification of a date (i.e. day, month, and year (including century)). If NLS_DATE_FORMAT does not support complete (i.e. including the century) specification of the year, use TO_DATE() (e.g. TO_DATE('01-01-1999', 'MM-DD-YYYY') to fully express the desired date.
ORA-14121: MODIFY DEFAULT ATTRIBUTES may not be combined with other operations
Cause:
ALTER TABLE or ALTER INDEX statement attempted to combine MODIFY DEFAULT ATTRIBUTES with some other operation (e.g. ADD PARTITION or PCTFREE) which is illegal
Action:
Ensure that MODIFY DEFAULT ATTRIBUTES is the sole operation specified in ALTER TABLE or ALTER INDEX statement; operations other than those dealing with partitions, default attributes of partitioned tables/indices or specifying that a table be renamed (ALTER TABLE RENAME) may be combined at will
ORA-14122: only one REVERSE or NOREVERSE clause may be specified
Cause:
Both REVERSE and NOREVERSE were specified in CREATE INDEX statement.
Action:
Remove all but one of the REVERSE or NOREVERSE clauses and reissue the statement.
ORA-14123: duplicate NOREVERSE clause
Cause:
NOREVERSE was specified more than once in ALTER INDEX statement.
Action:
Remove all but one of the NOREVERSE clauses and reissue the statement.
ORA-14124: duplicate REVERSE clause
Cause:
REVERSE was specified more than once in ALTER INDEX or CREATE INDEX statements.
Action:
Remove all but one of the REVERSE clauses and reissue the statement.
ORA-14125: REVERSE/NOREVERSE may not be specified in this context
Cause:
REVERSE/NOREVERSE clause is not allowed in this context.
Action:
Remove offending clause. REVERSE may be specified as an attribute of an index (not of an individual partition, if creating a partitioned index) in CREATE INDEX statement and ALTER INDEX REBUILD statement. NOREVERSE may be specified only in ALTER INDEX REBUILD statement.
ORA-14126: only a parallel clause may follow description(s) of resulting partitions
Cause:
Descriptions of partition(s) resulting from splitting of a table or index partition may be followed by an optional parallel clause which applies to the entire statement and which, in turn, may not be followed by any other clause.
Action:
Ensure that all partition attributes appear within the parenthesized list of descriptions of resulting partitions in ALTER TABLE/INDEX SPLIT PARTITION statement.
ORA-14128: FOREIGN KEY constraint mismatch in ALTER TABLE EXCHANGE PARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE PARTITION statement have different FOREIGN KEY constraints.
Action:
Ensure that the two tables do not have FOREIGN KEY constraints defined on any column or disable all FOREIGN KEY constraints on both tables. Then retry the operation.
ORA-14129: INCLUDING INDEXES must be specified as tables have enabled UNIQUE constraints
Cause:
Matching UNIQUE constraints in both table are enabled and validated but INCLUDING INDEXES is not specified in ALTER TABLE EXCHANGE PARTITION|SUBPARTITION command.
Action:
Disable currently enabled matching UNIQUE constraints on both tables or ensure that INCLUDING INDEXES option is used.
ORA-14130: UNIQUE constraints mismatch in ALTER TABLE EXCHANGE PARTITION
Cause:
One of the tables named in the ALTER TABLE EXCHANGE PARTITION command has a UNIQUE constraint for which no matching (vis-a-vis key columns) constraint is defined on the other table or a matching constraint is defined on the other table, but it differs from that defined on the first table vis-a-vis being enabled and/or validated.
Action:
Ensure that for every UNIQUE constraint defined on one of the tables named in the ALTER TABLE EXCHANGE PARTITION statement there is a matching (vis-a-vis key columns and being enabled and/or validated) UNIQUE constraint defined on the other table. If UNIQUE constrains are enabled, UNIQUE constraints on the partitioned table should be enforced using local indexes.
ORA-14131: enabled UNIQUE constraint exists on one of the tables
Cause:
One of the tables referenced in the ALTER TABLE EXCHANGE PARTITION|SUBPARTITION statement has enabled UNIQUE constraint(s) defined on it, which prevents EXCHANGE from proceeding.
Action:
Disable constraints defined on tables referenced in the ALTER TABLE EXCHANGE PARTITION|SUBPARTITION statement and retry the statement.
ORA-14132: table cannot be used in EXCHANGE
Cause:
An attempt was made to issue an ALTER TABLE EXCHANGE PARTITION | SUBPARTITION command, but the non-partitioned table cannot be used in the EXCHANGE because one or more of the following apply:
- it is a typed table
- it is a temporary table
- it contains ADT columns
- it contains nested-table columns
- it contains REF columns
- it contains array columns
- it is an index-organized table
- it contains LOB columns
- it is a nested table
- it is created with row dependency and the partitioned table is not
- it is created without row dependency and the partitioned table is
Action:
Make sure the non-partitioned table does not violate any of the above restrictions for the ALTER TABLE EXCHANGE PARTITION | SUBPARTITION command.
ORA-14133: ALTER TABLE MOVE cannot be combined with other operations
Cause:
An attempt was made to combine an ALTER TABLE MOVE statement with another operation, such as MODIFY.
Action:
Make sure that MOVE is the only operation specified in ALTER TABLE statement;
ORA-14134: indexes cannot use both DESC and REVERSE
Cause:
An attempt was made to make a reverse index with some index columns marked DESC.
Action:
Do not use DESC in reverse indexes. The rule-based optimizer can scan indexes backwards, which allows a normal reverse index to simulate a reverse index with columns marked DESC.
ORA-14135: a LOB column cannot serve as a partitioning column
Cause:
An attempt was made to specify a column of type BLOB or CLOB as a partitioning or subpartitioning column.
Action:
Ensure that no partitioning or subpartitioning column is of type BLOB or CLOB.
ORA-14136: ALTER TABLE EXCHANGE restricted by fine-grained security
Cause:
User doing exchange does not have full table access due to VPD policies.
Action:
Grant exempt priviliges to this user.
ORA-14137: Table in partially dropped state, submit DROP TABLE PURGE
Cause:
An attempt was made to access a partitioned table in a partially dropped state.
Action:
Submit DROP TABLE table PURGE to drop the table.
ORA-14138: An unexpected error encountered during drop table operation
Cause:
Drop table encountered an unexpected error.
Action:
a. Submit drop table table purge, or b. If the situation described in the next error on the stack can be corrected, do so. c. Contact Oracle Support.
ORA-14139: table string.string is already in read-only mode
Cause:
an attempt was made to set a read-only table in read-only mode
Action:
this DDL can only be executed on a read/write table
ORA-14140: table string.string is already in read/write mode
Cause:
an attempt was made to set a read/write table in read/write mode
Action:
this DDL can only be executed on a read-only table
ORA-14141: ALTER INDEX VISIBLE|INVISIBLE may not be combined with other operations
Cause:
ALTER INDEX statement attempted to combine a VISIBLE|INVISIBLE operation with some other operation which is illegal
Action:
Ensure that VISIBLE|INVISIBLE operation is the sole operation specified in ALTER INDEX statement
ORA-14142: ALTER INDEX VISIBLE|INVISIBLE may not be used with certain types of index
Cause:
Using the ALTER INDEX VISIBLE|INVISIBLE statement on certain types of indexes (IOT-TOP, Cluster indexes) is illegal.
Action:
Remove the option VISIBLE|INVISIBLE.
ORA-14143: CREATE INDEX INVISIBLE may not be used with this type of index
Cause:
Certain types of indexes (IOT-TOP, Cluster indexes) cannot be created invisible.
Action:
Remove the option INVISIBLE
ORA-14145: only one UNUSABLE clause may be specified
Cause:
UNUSABLE was specified more than once.
Action:
Remove all but one of the UNUSABLE clauses and reissue the statement.
ORA-14146: Old CONNECT BY does not support partitioned tables
Cause:
The query used the old CONNECT BY clause on a partitioned object.
Action:
Disable old CONNECT BY by disabling the _old_connect_by_enabled parameter.
ORA-14147: There is an existing VISIBLE index defined on the same set of columns.
Cause:
An attempt was made to define more than one VISIBLE index on the same set of columns. There can be only one VISIBLE index on the same set of columns. Hence ALTER INDEX VISIBLE was not supported on this index.
Action:
Make all the indexes defined on the same set of columns as INVISIBLE and then reexecute this DDL.
ORA-14148: DML and DDL operations are not directly allowed on the guard-column.
Cause:
An attempt was made to execute a DML or a DDL directly on the guard-column.
Action:
This is not supported.
ORA-14150: missing SUBPARTITION keyword
Cause:
keyword SUBPARTITION missing
Action:
ORA-14151: invalid table partitioning method
Cause:
Invalid partitioning method was specified in CREATE TABLE statement. A table may be partitioned by RANGE, HASH, LIST, SYSTEM, or Composite Range-Hash/List/Range (R+H/L/R).
Action:
Specify one of valid partitioning methods
ORA-14152: invalid number of partitions specified in PARTITIONS clause
Cause:
number-of-partitions clause contained in CREATE TABLE or CREATE INDEX statement specified a number of partitions outside of legal range (1-1048575)
Action:
Specify a number between 1 and 1024K-1 in the number-of-partitions clause
ORA-14153: only one of STORE IN or partition-description clause may be specified
Cause:
both STORE IN and partition-description clauses were specified in a CREATE TABLE|INDEX command
Action:
Remove one of offending clauses
ORA-14154: only one of STORE IN or subpartition-description clause may be specified
Cause:
both STORE IN and subpartition-description clauses were specified in a CREATE TABLE|INDEX, or ALTER TABLE ADD|SPLIT PARTITION or ALTER TABLE MERGE PARTITIONS command for a Composite Range partitioned object
Action:
ORA-14155: missing PARTITION, PARTITIONS, SUBPARTITION, or SUBPARTITIONS keyword
Cause:
The keyword PARTITION,PARTITIONS, SUBPARTITION, or SUBPARTITIONS was expected but none were supplied.
Action:
Supply the missing keyword.
ORA-14156: invalid number of subpartitions specified in [SUBPARTITIONS | SUBPARTITION TEMPLATE] clause
Cause:
number-of-subpartitions clause contained in CREATE TABLE or CREATE INDEX statement specified a number of subpartitions outside of legal range (1-1048575)
Action:
Specify a number between 1 and 1024K-1 in the number-of-subpartitions clause
ORA-14157: invalid subpartition name
Cause:
a subpartition name of the form identifier is expected but not present.
Action:
enter an appropriate subpartition name.
ORA-14158: too many subpartition descriptions
Cause:
CREATE TABLE or CREATE INDEX contained too many subpartition descriptions; maximum number of subpartitions is 1048575.
Action:
Reduce number of subpartitions to not exceed 1024K-1.
ORA-14159: duplicate subpartition name
Cause:
Name of a subpartition of a table or index being created is not unique
Action:
rename subpartition(s) to ensure that their names are unique among subpartitions of the table or index being created
ORA-14160: this physical attribute may not be specified for a table subpartition
Cause:
unexpected option was encountered while parsing physical attributes of a table subpartition; TABLESPACE is the only valid option
Action:
ORA-14161: subpartition number string: sum of PCTUSED and PCTFREE may not exceed 100
Cause:
the sum of PCTUSED and PCTFREE for a subpartition whose number (subpartitions are numbered starting with 1) is displayed in this message exceeds 100. Note that if PCTUSED and/or PCTFREE values for this subpartition were not specified explicitly, default values at partition-level would be used. If, in turn, default PCTUSED and/or PCTFREE values at partition-level were not specified, default values for the partitioned table or index would be used. If those values were also not specified explicitly, system defaults would be used.
Action:
ensure that a sum of PCTUSED and PCTFREE for the subpartition does not exceed 100
ORA-14162: subpartition "string": sum of PCTUSED and PCTFREE may not exceed 100
Cause:
the sum of PCTUSED and PCTFREE for a subpartition whose name (explicitly specified by the user) is displayed in this message exceeds 100. Note that if PCTUSED and/or PCTFREE values for this subpartition were not specified explicitly, default values at partition-level would be used. If, in turn, default PCTUSED and/or PCTFREE values at partition-level were not specified, default values for the partitioned table or index would be used. If those values were also not specified explicitly, system defaults would be used.
Action:
ORA-14163: subpartition number string: INITRANS value must be less than MAXTRANS value
Cause:
Value of INITRANS was found to be greater than that of MAXTRANS for a subpartition whose number (subpartitions are numbered starting with 1) is displayed in this message. Note that if INITRANS and/or MAXTRANS values for this subpartition were not specified explicitly, default values at partition-level would be used. If, in turn, default INITRANS and/or MAXTRANS values at partition-level were not specified, default values for the partitioned table or index would be used. If those values were also not specified explicitly, system defaults would be used.
Action:
ensure that value of INITRANS (whether specified explicitly or derived from the default value at partition-level, table-level or index-level) is no greater than that of MAXTRANS
ORA-14164: subpartition "string": INITRANS value must be less than MAXTRANS value
Cause:
Value of INITRANS was found to be greater than that of MAXTRANS for a subpartition whose name (explicitly specified by the user) is displayed in this message. Note that if INITRANS and/or MAXTRANS values for this subpartition were not specified explicitly, default values at partition-level would be used. If, in turn, default INITRANS and/or MAXTRANS values at partition-level were not specified, default values for the partitioned table or index would be used. If those values were also not specified explicitly, system defaults would be used.
Action:
ORA-14165: MODIFY DEFAULT ATTRIBUTES FOR PARTITION may not be combined with other operations
Cause:
ALTER TABLE or ALTER INDEX statement attempted to combine MODIFY DEFAULT ATTRIBUTES OF PARTITION with some other operation (e.g. ADD PARTITION or PCTFREE) which is illegal
Action:
ORA-14166: missing INTO keyword
Cause:
keyword INTO missing
Action:
ORA-14167: only one subpartition may be moved
Cause:
ALTER TABLE MOVE SUBPARTITION contained descriptions of more than one subpartition to be moved
Action:
Ensure that the statement describes exactly one subpartition to be moved and that it does not contain any commas
ORA-14168: only one subpartition may be modified
Cause:
ALTER TABLE|INDEX MODIFY SUBPARTITION contained descriptions of more than one subpartition to be modified
Action:
Ensure that the statement describes exactly one subpartition to be modified and that it does not contain any commas
ORA-14169: invalid ALTER TABLE MODIFY SUBPARTITION option
Cause:
An option other than PCTFREE, PCTUSED, INITRANS, MAXTRANS, STORAGE, was specified in an ALTER TABLE MODIFY SUBPARTITION statement.
Action:
ORA-14170: cannot specify <(sub)partition-description> clause in CREATE TABLE or CREATE INDEX
Cause:
A request was made to generate default partition description(s) (possibly via PARTITIONS number-of-partitions) while at the same time specified <(sub)partition-description> clause which is illegal.
Action:
Remove one of offending clauses.
ORA-14171: cannot specify subpartition-description clause in CREATE|ALTER TABLE
Cause:
User requested to generate default subpartition description(s) (possibly via SUBPARTITIONS) while at the same time specified subpartition-description clause which is illegal
Action:
ORA-14172: invalid ALTER TABLE EXCHANGE SUBPARTITION option
Cause:
Action:
Ensure that no options besides INCLDING INDEX or EXCLUDING INDEX are specified with ALTER TABLE EXCHANGE SUBPARTITION
ORA-14173: illegal subpartition-extended table name syntax
Cause:
Subpartition to be accessed may only be specified using its name. User attempted to use a subpartition number or a bind variable.
Action:
Modify statement to refer to a subpartition using its name
ORA-14174: only a parallel clause may follow COALESCE PARTITION|SUBPARTITION
Cause:
ALTER TABLE COALESCE PARTITION|SUBPARTITION may be followed by an optional parallel clause. No partition/subpartition attributes may be specified
Action:
Ensure that no partition/subpartition attribute was specified.
ORA-14175: a subpartition maintenance operation may not be combined with other operations
Cause:
ALTER TABLE or ALTER INDEX statement attempted to combine a subpartition maintenance operation (e.g. MOVE SUBPARTITION) with some other operation (e.g. MODIFY PARTITION ADD SUBPARTITION or PCTFREE) which is illegal
Action:
Ensure that a subpartition maintenance operation is the sole operation specified in ALTER TABLE or ALTER INDEX statement; operations other than those dealing with subpartitions, default attributes of partitioned tables/indices or specifying that a table be renamed (ALTER TABLE RENAME) may be combined at will
ORA-14176: this attribute may not be specified for a hash partition
Cause:
An invalid option was encountered while parsing physical attributes of a partition of an object partitioned using the HASH method. The TABLESPACE option is the only valid option for such partitions.
Action:
Remove the invalid option(s).
ORA-14177: STORE-IN (Tablespace list) can only be specified for a LOCAL index on a Hash or Composite Range Hash table
Cause:
STORE-IN (Tablespace list) clause was used while creating a local index on a range/list/composite range list partitioned table
Action:
Do not use the STORE_IN (Tablespace list) clause while creating a local index on range/list/composite range list partitioned table
ORA-14178: STORE IN (DEFAULT) clause is not supported for hash partitioned global indexes
Cause:
STORE IN (DEFAULT) is valid only for local indexes.
Action:
a) Specify a tablespace list in place of DEFAULT, or b) Remove STORE IN clause and specify tablespaces individually for each index partition.
ORA-14179: An unsupported partitioning method was specified in this context.
Cause:
An attempt was made to specify an unsupported partitioning method in this context.
Action:
Remove the invalid option.
ORA-14183: TABLESPACE DEFAULT can be specified only for Composite LOCAL index
Cause:
User attempted to specify TABLESPACE DEFAULT for a partition of a Range/System/Hash partitioned LOCAL index object, which is illegal.
Action:
Replace TABLESPACE DEFAULT with TABLESPACE <ts_name> or remove it.
ORA-14185: incorrect physical attribute specified for this index partition
Cause:
unexpected option was encountered while parsing physical attributes of a local index partition; valid options for Range or Composite Range partitions are INITRANS, MAXTRANS, TABLESPACE, STORAGE, PCTFREE, PCTUSED, LOGGING and TABLESPACE; but only TABLESPACE may be specified for Hash partitions STORE IN () is also disallowed for all but Composite Range partitions
Action:
ORA-14186: number of sub-partitions of LOCAL index must equal that of the underlying table
Cause:
User attempted to create a LOCAL partitioned index with a number of sub-partitions which is different from that of the underlying table.
Action:
Correct the CREATE INDEX statement to specify a correct number of sub-partitions
ORA-14187: partitioning method for LOCAL index is inconsistent with that of the underlying table
Cause:
User attempted to create a LOCAL partitioned index that is not equi-partitioned with the underlying table. The partitioning types are mismatched.
Action:
Correct the CREATE INDEX statement to ensure that the index partitionining method is consistent with that of the base table
ORA-14188: sub-partitioning columns must form a subset of key columns of a UNIQUE index
Cause:
User attempted to create a UNIQUE partitioned index whose sub-partitioning columns do not form a subset of its key columns which is illegal
Action:
If the user, indeed, desired to create an index whose subpartitioning columns do not form a subset of its key columns, it must be created as non-UNIQUE; otherwise, correct the list of key and/or subpartitioning columns to ensure that the index' subpartitioning columns form a subset of its key columns
ORA-14189: this physical attribute may not be specified for an index subpartition
Cause:
unexpected option was encountered while parsing physical attributes of an index subpartition; TABLESPACE is the only valid option
Action:
ORA-14190: only one ENABLE/DISABLE ROW MOVEMENT clause can be specified
Cause:
One of three possible actions caused the error: 1) ENABLE ROW MOVEMENT was specified more than once. 2) DISABLE ROW MOVEMENT was specified more than once. 3) Both ENABLE ROW MOVEMENT and DISABLE ROW MOVEMENT were specified.
Action:
Remove all but one of the ENABLE ROW MOVEMENT or DISABLE ROW MOVEMENT clauses; then, reissue the command.
ORA-14191: ALLOCATE EXTENT may not be specified for composite partitioned object
Cause:
User specified ALLOCATE STORAGE clause in ALTER TABLE/ALTER INDEX statement issued against a composite partitioned index which is illegal.
Action:
Remove the illegal option. If you want to add storage to individual [sub]partitions,the ALLOCATE EXTENT clause may be specified with ALTER TABLE OR INDEX MODIFY [SUB]PARTITION statement.
ORA-14192: cannot modify physical index attributes of a Hash index partition
Cause:
User attempted to modify one of INITRANS/MAXTRANS/LOGGING/STORAGE clause for an index partition of a Hash partitioned index
Action:
Remove the physical attributes one is trying to modify
ORA-14193: invalid ALTER INDEX MODIFY SUBPARTITION option
Cause:
An option other than UNUSABLE, ALLOCATE EXTENT, DEALLOCATE UNUSED was specified in an ALTER INDEX MODIFY SUBPARTITION statement.
Action:
ORA-14194: only one subpartition may be rebuilt
Cause:
ALTER INDEX REBUILD SUBPARTITION contained descriptions of more than one subpartition to be rebuilt
Action:
Ensure that the statement describes exactly one subpartition to be rebuilt and that it does not contain any commas
ORA-14195: ALLOCATE STORAGE may not be specified for RANGE or LIST partitioned object
Cause:
User specified ALLOCATE STORAGE clause in ALTER TABLE/ALTER INDEX statement issued against a range-partitioned index which is illegal.
Action:
Remove the illegal option. If it is desired to add storage to individual partitions, ALLOCATE STORAGE clause may be specified with ALTER TABLE/INDEX MODIFY PARTITION statement.
ORA-14196: Specified index cannot be used to enforce the constraint.
Cause:
The index specified to enforce the constraint is unsuitable for the purpose.
Action:
Specify a suitable index or allow one to be built automatically.
ORA-14201: specified subpartition bound is too long
Cause:
Length of a linear key representation of a high bound of a table subpartition being added or along which an existing table or index subpartition is being split exceeded the legal limit (4K).
Action:
Change the representation of a subpartition high bound to bring its length within legal limit.
ORA-14202: subpartition bound of subpartition "string" is too high
Cause:
High bound of the specified subpartition displayed in this message did not collate lower than that of the subsequent subpartition.
Action:
Ensure that high bound of every subpartition (except for the last one) collates lower than that of a subsequent subpartition.
ORA-14203: subpartition bound of subpartition "string" is too long
Cause:
Length of linear key representation of a high bound of the specified subpartition displayed in this message exceeded the legal limit (4K).
Action:
ORA-14204: subpartition bound of subpartition number string is too high
Cause:
Action:
ORA-14205: subpartition bound of subpartition number string is too long
Cause:
Action:
ORA-14206: table is not subpartitioned by List or Range methods
Cause:
A subpartition maintenance operation such as ALTER TABLE DROP|SPLIT|MERGE SUBPARTITION can only be performed on List or Range subpartitioned objects
Action:
Issue the command only against a List or Range subpartitioned object.
ORA-14207: maximum number of subpartitioning columns is 16
Cause:
number of columns in a subpartitioning column list exceeded the legal limit of 16
Action:
modify subpartitioning column list so that it consists of at most 16 columns
ORA-14208: lower-bound subpartition must be specified first
Cause:
A higher-bound subpartition was specified before the lower-bound subpartition in ALTER TABLE MERGE SUBPARTITIONS statement.
Action:
Specify lower-bound subpartition first and then higher-bound subpartition
ORA-14209: subpartitions being merged are not adjacent
Cause:
Attempted to merge two subpartitions that are not adjacent to each other.
Action:
Specify two subpartitions that are adjacent
ORA-14210: cannot reuse lower-bound subpartition as resulting subpartition
Cause:
Attempted to reuse the lower-bound subpartition of the subpartitions being merged.
Action:
Specify new resulting subpartition name or reuse the higher-bound subpartition only
ORA-14211: subpartition bound must collate higher than that of the last subpartition
Cause:
Subpartition bound specified in ALTER TABLE MODIFY PARTITION ADD SUBPARTITION statement did not collate higher than that of the partition's last subpartition.
Action:
Ensure that the subpartition bound of the subpartition to be added collates higher than that of the table partition's last subpartition.
ORA-14212: subpartition cannot be split along the specified high bound
Cause:
Attempted to split a subpartition along a bound which either collates higher than that of the subpartition to be split or lower than that of a subpartition immediately preceding the one to be split
Action:
Ensure that the bound along which a subpartition is to be split collates lower than that of the subpartition to be split and higher than that of a subpartition immediately preceding the one to be split
ORA-14213: VALUES LESS THAN or AT clause cannot be used for List subpartitioned tables
Cause:
VALUES LESS THAN or AT clause was used for List subpartitioned tables
Action:
Use VALUES (value list) clause for List subpartitioned tables
ORA-14214: VALUES (value list) cannot be used for Range subpartitioned tables
Cause:
VALUES (value list) clause was used for Range subpartitioned tables
Action:
Use VALUES LESS THAN or AT clause with Range subpartitioned tables
ORA-14215: subpartition bound list contains too many elements
Cause:
Subpartition bound list contained more elements than there are subpartitioning columns
Action:
Ensure that the number of elements in subpartition bound list is equal to the number of subpartitioning columns of the table or index
ORA-14216: subpartition bound list contains too few elements
Cause:
Subpartition bound list contained fewer elements than there are subpartitioning columns
Action:
ORA-14217: VALUES (value list) clause expected
Cause:
VALUES (value list) clause was not specified for the list subpartition being added
Action:
Specify a VALUES (value list) clause
ORA-14218: Invalid operation for object without a segment
Cause:
The object (table or index or lob) did not have a segment.
Action:
Create segments for the object with the ALTER TABLE ALLOCATE EXTENT command.
ORA-14220: Invalid operation for object without a segment
Cause:
Attempted to modify storage or allocate an extent for an object (table or LOB or index) without a segment.
Action:
ORA-14221: Dictionary managed tablespace cannot be used for this operation
Cause:
Attempted to create an index or add a LOB column in a dictionary managed tablespace to a table without a segment.
Action:
Specify a locally managed tablespace OR create segments for the table with the ALTER TABLE ALLOCATE EXTENT command.
ORA-14223: Deferred segment creation is not supported for this table
Cause:
The SEGMENT CREATION DEFERRED clause was specified in the CREATE TABLE statement.
Action:
Remove the SEGMENT CREATION DEFERRED clause.
ORA-14224: Deferred segment creation is not supported for this schema
Cause:
Action:
ORA-14225: The INDEXING clause is not supported for this table.
Cause:
The INDEXING clause was specified for an unsupported table type.
Action:
Remove the INDEXING clause from the statement.
ORA-14226: unique index may not be PARTIAL
Cause:
INDEXING PARTIAL was specified during creation or modification of a unique index.
Action:
Remove the INDEXING PARTIAL clause from the statement.
ORA-14227: INDEXING may be specified only when the underlying table is partitioned
Cause:
INDEXING FULL or INDEXING PARTIAL was specified during CREATE INDEX or ALTER INDEX when the base table was not partitioned.
Action:
ORA-14228: INDEXING may not be specified for this index
Cause:
INDEXING FULL or INDEXING PARTIAL was specified during CREATE INDEX or ALTER INDEX for an unsupported index type.
Action:
ORA-14229: cannot modify the indexing attribute of a composite partition
Cause:
An attempt was made to perform ALTER TABLE MODIFY PARTITION INDEXING [ON|OFF] on a composite table partition.
Action:
Run ALTER TABLE MODIFY SUBPARTITION INDEXING [ON|OFF] on each subpartition individually.
ORA-14251: Specified subpartition does not exist
Cause:
Subpartition not found for the object.
Action:
Retry with correct subpartition name.
ORA-14252: invalid ALTER TABLE MODIFY PARTITION option for a Hash partition
Cause:
Only ALLOCATE EXTENT and DEALLOCATE UNUSED may be specified in ALTER TABLE MODIFY PARTITION for a Hash partition.
Action:
ORA-14253: table is not partitioned by Composite Range method
Cause:
The table in a subpartition maintenance operation (ALTER TABLE EXCHANGE/MODIFY/MOVE/TRUNCATE SUBPARTITION, or ALTER TABLE MODIFY PARTITION ADD/COALESCE SUBPARTITION command must be partitioned by Composite Range method
Action:
Ensure that the table is partitioned by Composite Range method
ORA-14254: cannot specify ALLOCATE STORAGE for a (Composite) Range or List partitioned table
Cause:
User specified ALLOCATE STORAGE clause in ALTER TABLE statement issued against a Range or Composite Range partitioned table which is illegal.
Action:
Remove the illegal option. If it is desired to add storage to individual partitions/subpartitions, ALLOCATE STORAGE clause may be specified with ALTER TABLE MODIFY PARTITION/SUBPARTITION statement. If it is desired to add storage to all subpartitions of a Composite partition, ALLOCATE STORAGE clause may be specified with ALTER TABLE MODIFY PARTITION.
ORA-14255: table is not partitioned by Range, List, Composite Range or Composite List method
Cause:
The table was not partitioned by Range, List, Composite Range or Composite List method.
Action:
ALTER TABLE SPLIT/DROP PARTITION or ALTER TABLE MERGE PARTITIONS command is only valid for table partitioned by Range, List, Composite Range or Composite List methods. Ensure that the table is partitioned appropriately.
ORA-14256: invalid resulting partition description(s)
Cause:
User specified STORE-IN clause, SUBPARTITIONS clause, and/or subpartition-description clause in partition description(s) in ALTER TABLE SPLIT PARTITION or ALTER TABLE MERGE PARTITIONS statement but the table in the maintenance operation is not a Composite Range partitioned table which is illegal
Action:
Remove invalid clause(s), or ensure that the table is partitioned by Composite Range method
ORA-14257: cannot move partition other than a Range, List, System, or Hash partition
Cause:
User attempt to move a partition that is not a Range,List,System, or Hash partition which is illegal
Action:
Specify MOVE PARTITION for a Range,List,System, or Hash partition only
ORA-14258: invalid partition description
Cause:
User specified STORE-IN clause, SUBPARTITIONS clause, and/or subpartition-description clause in ALTER TABLE ADD PARTITION statement but the table in the maintenance operation is not a Composite Range/Hash partitioned table which is illegal
Action:
Remove invalid clause(s), or ensure that the table is partitioned by Composite Range/Hash method
ORA-14259: table is not partitioned by Hash method
Cause:
ALTER TABLE COALESCE PARTITION is only valid for table partitioned by Hash method
Action:
Specify valid ALTER TABLE option for the table, or ensure that the table is partitioned by Hash method
ORA-14260: incorrect physical attribute specified for this partition
Cause:
User specified INITRANS, MAXTRANS, STORAGE, PCTFREE, PCTUSED, and/or [NO]LOGGING option to a Hash partition via ALTER TABLE ADD/MOVE PARTITION command which is illegal. Only TABLESPACE may be specified.
Action:
Remove invalid option(s)
ORA-14261: partition bound may not be specified when adding this Hash partition
Cause:
User specified VALUES LESS THAN clause when adding a partition (via ALTER TABLE ADD PARTITION) to a Hash partitioned table which is illegal
Action:
Remove VALUES LESS THAN clause from the description of partition being added
ORA-14262: new subpartition name must differ from the old subpartition name
Cause:
User entered ALTER TABLE/INDEX RENAME SUBPARTITION specifying new-subpartition-name which is identical to the name of the subpartition being renamed
Action:
Ensure that the new subpartition name is different from the name of any (including the one being renamed) existing subpartition of a given table or index
ORA-14263: new subpartition name must differ from that of any other subpartition of the object
Cause:
User entered ALTER TABLE/INDEX RENAME SUBPARTITION specifying new-subpartition-name which is identical to the name of some existing subpartition of the object
Action:
ORA-14264: table is not partitioned by Composite Range method
Cause:
The table in the MODIFY DEFAULT ATTRIBUTES FOR PARTITION operation is partitioned by method other than Composite method
Action:
Ensure that the table is partitioned by Composite method
ORA-14265: data type or length of a table subpartitioning column may not be changed
Cause:
User issued ALTER TABLE statement attempting to modify data type and/or length of a column used to subpartition the table named in ALTER TABLE statement, which is illegal
Action:
Avoid modifying data type and/or length of table subpartitioning column(s)
ORA-14266: data type or length of an index subpartitioning column may not be changed
Cause:
User issued ALTER TABLE statement attempting to modify data type and/or length of a column used to subpartition some index defined on the table named in ALTER TABLE statement, which is illegal
Action:
Avoid modifying data type and/or length of index subpartitioning column(s)
ORA-14267: cannot specify PARALLEL clause when adding a (Composite) Range partition
Cause:
User issued ALTER TABLE ADD PARTITION statement with PARALLEL clause for a Range or Composite Range partition which is illegal
Action:
Remove the PARALLEL clause.
ORA-14268: subpartition 'string' of the partition resides in offlined tablespace
Cause:
User attempted an operation requiring that we access data in a subpartition which resides in a tablespace which was taken offline. Such operations include trying to drop a tablespace of a table which has indices defined on it or is referenced by a constraint.
Action:
ORA-14269: cannot exchange partition other than a Range,List,System, or Hash partition
Cause:
User attempt to exchange a partition with a non-partitioned table but the specified partition is not a Range,List,System, or Hash partition which is illegal
Action:
Specify EXCHANGE PARTITION for a Range,List,System, or Hash partition only
ORA-14270: table is not partitioned by Range, System, Hash or List method
Cause:
The table in ALTER TABLE MODIFY PARTITION { UNUSABLE LOCAL INDEXES | REBUILD UNUSABLE LOCAL INDEXES } statement is not partitioned by Range,List,System, or Hash method which is illegal.
Action:
Ensure that the table is partitioned by Range,List,System, or Hash method
ORA-14271: table is not partitioned by Composite Range method
Cause:
The table in ALTER TABLE MODIFY SUBPARTITION { UNUSABLE LOCAL INDEXES | REBUILD UNUSABLE LOCAL INDEXES } statement is not partitioned by Composite Range method which is illegal.
Action:
ORA-14272: only a partition with higher bound can be reused
Cause:
User attempt to reuse a lower-bound partition in ALTER TABLE MERGE PARTITIONS statement as the resulting partition which is illegal.
Action:
Use the higher-bound partition to be the resulting partition or specify a new partition name
ORA-14273: lower-bound partition must be specified first
Cause:
User specified higher-bound partition before lower-bound partition in ALTER TABLE MERGE PARTITIONS statement which is illegal
Action:
Specify lower-bound partition then higher-bound partition
ORA-14274: partitions being merged are not adjacent
Cause:
User attempt to merge two partitions that are not adjacent to each other which is illegal
Action:
Specify two partitions that are adjacent
ORA-14275: cannot reuse lower-bound partition as resulting partition
Cause:
User attempt to reuse lower-bound partition of the partitions being merged which is illegal
Action:
Specify new resulting partition name or reuse the higher-bound partition only
ORA-14276: EXCHANGE SUBPARTITION requires a non-partitioned, non-clustered table
Cause:
The table in the ALTER TABLE EXCHANGE SUBPARTITION operation is either clustered or partitioned
Action:
Ensure that the table with which the subpartition is being exchanged for is not partitioned or clustered.
ORA-14277: tables in EXCHANGE SUBPARTITION must have the same number of columns
Cause:
The two tables specified in the ALTER TABLE EXCHANGE SUBPARTITION have different number of columns
Action:
ORA-14278: column type or size mismatch in EXCHANGE SUBPARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE SUBPARTITION are of different type or size
Action:
ORA-14279: index mismatch for tables in ALTER TABLE EXCHANGE SUBPARTITION
Cause:
The two tables specified in the ALTER TABLE EXCHANGE SUBPARTITION have indexes which are not equivalent
Action:
ORA-14280: all rows in table do not qualify for specified subpartition
Cause:
There is at least one row in the non partitioned table which does not qualify for the subpartition specified in the ALTER TABLE EXCHANGE SUBPARTITION
Action:
Ensure that all the rows in the segment qualify for the subpartition. Perform the alter table operation with the NO CHECKING option. Run ANALYZE table VALIDATE on that subpartition to find out the invalid rows and delete them.
ORA-14281: CHECK constraint mismatch in ALTER TABLE EXCHANGE SUBPARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE SUBPARTITION statement have CHECK constraint defined on them.
Action:
ORA-14282: FOREIGN KEY constraint mismatch in ALTER TABLE EXCHANGE SUBPARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE SUBPARTITION statement have different FOREIGN KEY constraints.
Action:
ORA-14283: UNIQUE constraints mismatch in ALTER TABLE EXCHANGE SUBPARTITION
Cause:
One of the tables named in the ALTER TABLE EXCHANGE SUBPARTITION command has a UNIQUE constraint for which no matching (vis-a-vis key columns) constraint is defined on the other table or a matching constraint is defined on the other table, but it differs from that defined on the first table vis-a-vis being enabled and/or validated.
Action:
Ensure that for every UNIQUE constraint defined on one of the tables named in the ALTER TABLE EXCHANGE SUBPARTITION statement there is a matching (vis-a-vis key columns and being enabled and/or validated) UNIQUE constraint defined on the other table. If UNIQUE constrains are enabled, UNIQUE constraints on the partitioned table should be enforced using local indexes.
ORA-14284: one or more of table's subpartitions reside in a read-only tablespace
Cause:
User issued ALTER TABLE statement attempting to modify an existing VARCHAR2 (or VARCHAR) column to be of type CHAR (or CHARACTER), increase length of an existing CHAR (or CHARACTER) column, or add a column with user-specified default for a table one or more subpartitions of which reside in read-only tablespaces, which is illegal
Action:
Avoid performing aformentioned operations on a partitioned table one or more subpartitions of which reside in read-only tablespaces
ORA-14285: cannot COALESCE the only partition of this hash partitioned table or index
Cause:
A COALESCE PARTITION command was issued when there is only one partition in the table or index, which is illegal
Action:
Ensure that there is at least one partition. Drop the table or index to remove all partitions.
ORA-14286: cannot COALESCE the only subpartition of this table partition
Cause:
A COALESCE SUBPARTITION command was issued when there is only one subpartition in the partition which is illegal
Action:
Ensure that there is at least one subpartition. Drop partition to remove all subpartitions.
ORA-14287: cannot REBUILD a partition of a Composite Range partitioned index
Cause:
User attempted to rebuild a partition of a Composite Range partitioned index which is illegal
Action:
REBUILD the index partition, a subpartition at a time
ORA-14288: index is not partitioned by Composite Range method
Cause:
The index in a partition or subpartition maintenance operation (ALTER INDEX MODIFY [SUBPARTITION|DEFAULT ATTRIBUTES FOR PARTITION] or ALTER INDEX REBUILD SUBPARTITION command must be partitioned by Composite Range method
Action:
n/a
ORA-14289: cannot make local index partition of Composite Range partitioned table unusable
Cause:
Action:
n/a
ORA-14290: PRIMARY KEY constraint mismatch in ALTER TABLE EXCHANGE [SUB]PARTITION
Cause:
The corresponding columns in the tables specified in the ALTER TABLE EXCHANGE [SUB]PARTITION statement have different PRIMARY KEY constraints.
Action:
Ensure that the two tables do not have PRIMARY KEY constraints defined on any column or disable all PRIMARY KEY constraints on both tables. Then retry the operation.
ORA-14291: cannot EXCHANGE a composite partition with a non-partitioned table
Cause:
A composite partition can only be exchanged with a partitioned table.
Action:
Ensure that the table being exchanged is partitioned or that that the partition being exchanged is non-composite.
ORA-14292: Partitioning type of table must match subpartitioning type of composite partition
Cause:
When exchanging a partitioned table with a composite partition the partitioning type of the table must match the subpartitioning type of the composite partition.
Action:
Ensure that the partitioning type of partitioned table is the same as the subpartitioning type of the composite partition.
ORA-14293: Number of partitioning columns does not match number of subpartitioning columns
Cause:
When exchanging a partitioned table with a composite partition the number of partitioning columns of the table must match the number of subpartitioning columns of the composite partition.
Action:
Ensure that the number of partitioning columns in the partitioned table is the same as the number of subpartitioning columns in the the composite partition.
ORA-14294: Number of partitions does not match number of subpartitions
Cause:
When exchanging a partitioned table with a composite partition the number of partitions of the table must match the number of subpartitions of the composite partition.
Action:
Ensure that the number of partitions in the partitioned table is the same as the number of subpartitions in the the composite partition.
ORA-14295: column type or size mismatch between partitioning columns and subpartitioning columns
Cause:
When exchanging a partitioned table with a composite partition the type and size of the partitioning columns of the table must match the type and size of the subpartitioning columns of the composite partition.
Action:
Ensure that the type and size of the partitioning columns of the partitioned is the same as the type and size of the subpartitioning columns of the composite partition.
ORA-14296: Table block size mismatch in ALTER TABLE EXCHANGE [SUB]PARTITION
Cause:
The block sizes of the two tables specified in the ALTER TABLE EXCHANGE [SUB]PARTITION statement are different. For index organized tables, either the block sizes of the index or the overflow (or both) do not match.
Action:
Ensure that the block sizes of the tables involved in the ALTER TABLE EXCHANGE [SUB]PARTITION statement are the same. For index organized tables, ensure that the block sizes of both the index and the overflow of the two tables match.
ORA-14297: Index block size mismatch in ALTER TABLE EXCHANGE [SUB]PARTITION
Cause:
The block sizes of a pair of indexes being exchanged in the ALTER TABLE EXCHANGE [SUB]PARTITION statement are different.
Action:
Ensure that the block sizes of the corresponding pairs of indexes that need to be exchanged in the ALTER TABLE EXCHANGE [SUB]PARTITION statement are the same.
ORA-14298: LOB column block size mismatch in ALTER TABLE EXCHANGE [SUB]PARTITION
Cause:
The block sizes of a pair of corresponding LOB columns of the two tables specified in the ALTER TABLE EXCHANGE [SUB]PARTITION statement are different.
Action:
Ensure that the block sizes of corresponding pairs of LOB columns of the tables involved in the ALTER TABLE EXCHANGE [SUB]PARTITION statement are the same.
ORA-14299: total number of partitions/subpartitions exceeds the maximum limit
Cause:
The total number of combined fragments specified in partitions /subpartitions exceeds 1048575.
Action:
Reissue the statement with fewer number of fragments
ORA-14300: partitioning key maps to a partition outside maximum permitted number of partitions
Cause:
The row inserted had a partitioning key that maps to a partition number greater than 1048575
Action:
Ensure that the partitioning key falls within 1048575 partitions or subpartitions.
ORA-14301: table-level attributes must be specified before partition-level attributes
Cause:
While processing an ALTER TABLE ADD COLUMN statement, table-level attributes of LOB columns were encountered after processing partition-level attributes of LOB columns or while processing CREATE TABLE statement, table-level attributes of LOB columns were encountered after processing partition descriptions.
Action:
Modify the SQL statement to specify table-level attributes prior to partition-level attributes or partition descriptions; then retry the statement.
ORA-14302: only one list of added-LOB-storage-clauses can be specified in a statement
Cause:
While parsing an ALTER TABLE ADD COLUMN statement, one list of added-LOB-storage-clauses was parsed when another list of added-LOB-storage-clauses was encountered. There cannot be more than one list of added-LOB-storage-clauses in a statement; all added-LOB-storage-clauses must be combined into one list.
Action:
Combine all of the lists of added-LOB-storage-clauses into one list and retry the statement.
ORA-14303: partitions or subpartitions are not in the right order
Cause:
Action:
Re-order the partitions or subpartitions in the added LOB storage clause by partition or subpartition DDL order, and retry the statement.
ORA-14304: List partitioning method expects a single partitioning column
Cause:
number of columns in a partitioning column list exceeded the legal limit of 1 for List partitioned objects
Action:
modify partitioning column list so that it consists of at most 1 column
ORA-14305: List value 'string' specified twice in partition 'string'
Cause:
A list value cannot be specified more that once
Action:
Remove one of the specifications of the value
ORA-14306: List value 'string' specified twice in partitions 'string', 'string'
Cause:
Action:
ORA-14307: partition contains too many list values
Cause:
Partition list contains more than 524288 list values
Action:
Reduce the number of values to not exceed 524288 values
ORA-14308: partition bound element must be one of: string, datetime or interval literal, number, or NULL
Cause:
Partition bound list contained an element of invalid type (i.e. not a number, non-empty string, datetime or interval literal, or NULL)
Action:
Ensure that all elements of partition bound list are of valid type
ORA-14309: Total count of list values exceeds maximum allowed
Cause:
Partitioned object contains more than 524288 list values
Action:
Reduce number of values to less than 524288.
ORA-14310: VALUES LESS THAN or AT clause cannot be used with List partitioned tables
Cause:
VALUES LESS THAN or AT clause can be used only with Range partitioned tables
Action:
Use VALUES (value list) clause with List partitioned tables
ORA-14311: Expecting VALUES LESS THAN or AT clause
Cause:
VALUES (value list) clause can be used only with List partitioned tables
Action:
Use VALUES LESS THAN clause with Range partitioned tables
ORA-14312: Value string already exists in partition string
Cause:
One of the list values in the ADD PARTITION or ADD VALUES statement already exists in another partition
Action:
Remove the duplicate value from the statement and try again
ORA-14313: Value string does not exist in partition string
Cause:
One of the list values in the SPLIT PARTITION or DROP VALUES statement does not exist in the partition
Action:
Remove the value from the statement and try again
ORA-14314: resulting List partition(s) must contain atleast 1 value
Cause:
After a SPLIT/DROP VALUE of a list partition, each resulting partition(as applicable) must contain at least 1 value
Action:
Ensure that each of the resulting partitions contains atleast 1 value
ORA-14315: cannot merge a partition with itself
Cause:
The same partition name was specified twice for the merge operation
Action:
Re-submit operation with 2 distinct partition names
ORA-14316: table is not partitioned by List method
Cause:
ALTER TABLE ADD|DROP VALUES can only be performed on List partitioned objects
Action:
Re-issue the command against a List partitioned object.
ORA-14317: cannot drop the last value of partition
Cause:
ALTER TABLE DROP VALUES tried to drop the last value of the partition
Action:
Cannot execute the command, unless two or more values exist for partition
ORA-14318: DEFAULT partition must be last partition specified
Cause:
A partition description follows the one describing the default partition
Action:
Ensure that the DEFAULT partition is the last partition description
ORA-14319: DEFAULT cannot be specified with other values
Cause:
DEFAULT keyword has been specified along with other values when specifying the values for a list partition
Action:
Ensure that if DEFAULT is specified, it is the only value specified
ORA-14320: DEFAULT cannot be specified for ADD/DROP VALUES or SPLIT
Cause:
DEFAULT keyword has been specified when doing a ADD VALUES or DROP VALUES or SPLIT partition or subpartition.
Action:
Ensure that DEFAULT is not specified for ADD/DROP VALUES or SPLIT partition/subpartition operation.
ORA-14321: cannot add/drop values to DEFAULT partition
Cause:
A ADD/DROP VALUES operation is being done on the default partition
Action:
Ensure that ADD/DROP VALUES is not done on the DEFAULT partition
ORA-14322: DEFAULT partition already exists
Cause:
A partition already exists with DEFAULT value
Action:
n/a
ORA-14323: cannot add partition when DEFAULT partition exists
Cause:
An ADD PARTITION operation cannot be executed when a partition with DEFAULT values exists
Action:
Issue a SPLIT of the DEFAULT partition instead
ORA-14324: values being added already exist in DEFAULT partition
Cause:
An ADD VALUE operation cannot be executed because the values being added exist in the DEFAULT partition
Action:
Issue a SPLIT of the DEFAULT partition and then MERGE the split partition into the partition to which values need to be added
ORA-14325: only LOCAL indexes may be specified in this clause
Cause:
A global index has been specified in the UPDATE INDEXES (..) clause
Action:
Only specify local indexes when using this clause
ORA-14326: Primary index on an IOT, DOMAIN and LOB indexes may not be specified in the UPDATE INDEXES clause
Cause:
A Primary index on an IOT, DOMAIN or LOB index has been specified in the UPDATE INDEXES (..) clause
Action:
Do not specify any of these indexes when using this clause
ORA-14327: Some index [sub]partitions could not be rebuilt
Cause:
The first phase (partition DDL and index [sub]partition placement) completed successfully. During the second phase, some of the index [sub]partitions could not be rebuilt.
Action:
Search the alert log for the string DBMS_INDEX_UTL. Check the error associated with each of the [sub]partitions that could not be rebuilt and take the appropriate corrective action.
ORA-14329: domain index [sub]partitions cannot be renamed in this clause
Cause:
The user tried to rename a domain index [sub]partition in the UPDATE INDEXES clause of a ALTER TABLE MOVE [SUB]PARTITION operation. This is not allowed.
Action:
Leave the name blank or use the same name.
ORA-14330: Cannot drop a partition of a global hash-partitioned index
Cause:
An attempt was made to drop a partition of a hash-partitioned global index.
Action:
Try COALESCE PARTITION instead.
ORA-14331: cannot drop all [sub]partitions of a partitioned table
Cause:
An attempt was made to drop all partitions of a partitioned table.
Action:
Try DROP TABLE instead.
ORA-14332: duplicate partition or subpartition names specified
Cause:
The list of partitions contained duplicate partition or subpartition names.
Action:
Ensure that list of partition or subpartition names are distinct.
ORA-14333: subpartition names specified are across multiple partitions
Cause:
The specified subpartitions did not belong to the same partition.
Action:
Ensure that all subpartitions specified belong to the same partition.
ORA-14334: guard column expected
Cause:
There was no guard column or the NOT NULL constraint was not specified for this column.
Action:
Add a guard column or NOT NULL constraint for column.
ORA-14335: number of new fragments for adding partitions exceeds the maximum limit
Cause:
The total number of new fragments for adding partitions exceeded 125000.
Action:
Reissue the statement with a fewer number of new fragments.
ORA-14400: inserted partition key does not map to any partition
Cause:
An attempt was made to insert a record into, a Range or Composite Range object, with a concatenated partition key that is beyond the concatenated partition bound list of the last partition -OR- An attempt was made to insert a record into a List object with a partition key that did not match the literal values specified for any of the partitions.
Action:
Do not insert the key. Or, add a partition capable of accepting the key, Or add values matching the key to a partition specification
ORA-14401: inserted partition key is outside specified partition
Cause:
the concatenated partition key of an inserted record is outside the ranges of the two concatenated partition bound lists that delimit the partition named in the INSERT statement
Action:
do not insert the key or insert it in another partition
ORA-14402: updating partition key column would cause a partition change
Cause:
An UPDATE statement attempted to change the value of a partition key column causing migration of the row to another partition
Action:
Do not attempt to update a partition key column or make sure that the new partition key is within the range containing the old partition key.
ORA-14403: cursor invalidation detected after getting DML partition lock
Cause:
cursor invalidation was detected after acquiring a partition lock during an INSERT, UPDATE, DELETE statement. This error is never returned to user, because is caught in opiexe() and the DML statement is retried.
Action:
nothing to be done, error should never be returned to user
ORA-14404: partitioned table contains partitions in a different tablespace
Cause:
An attempt was made to drop a tablespace which contains tables whose partitions are not completely contained in this tablespace
Action:
find tables with partitions which span the tablespace being dropped and some other tablespace(s). Drop these tables or move partitions to a different tablespace
ORA-14405: partitioned index contains partitions in a different tablespace
Cause:
An attempt was made to drop a tablespace which contains indexes whose partitions are not completely contained in this tablespace, and which are defined on the tables which are completely contained in this tablespace.
Action:
find indexes with partitions which span the tablespace being dropped and some other tablespace(s). Drop these indexes, or move the index partitions to a different tablespace, or find the tables on which the indexes are defined, and drop (or move) them.
ORA-14406: updated partition key is beyond highest legal partition key
Cause:
At attempt was made to update a record with a concatenated partition key that is beyond the concatenated partition bound list of the last partition.
Action:
Do not update the key. Or, add a partition capable of accepting the key.
ORA-14407: partitioned table contains subpartitions in a different tablespace
Cause:
An attempt was made to drop a tablespace which contains tables whose subpartitions are not completely contained in this tablespace
Action:
find tables with subpartitions which span the tablespace being dropped and some other tablespace(s). Drop these tables or move subpartitions to a different tablespace
ORA-14408: partitioned index contains subpartitions in a different tablespace
Cause:
An attempt was made to drop a tablespace which contains indexes whose subpartitions are not completely contained in this tablespace, and which are defined on the tables which are completely contained in this tablespace.
Action:
find indexes with subpartitions which span the tablespace being dropped and some other tablespace(s). Drop these indexes, or move the index partitions to a different tablespace, or find the tables on which the indexes are defined, and drop (or move) them.
ORA-14409: inserted partition key is outside specified subpartition
Cause:
the concatenated partition key of an inserted record is outside the ranges of the two concatenated subpartition bound lists that delimit the subpartition named in the INSERT statement
Action:
do not insert the key or insert it in another subpartition
ORA-14411: The DDL cannot be run concurrently with other DDLs
Cause:
Another conflicting DDL was already running.
Action:
Retry after the conflicting DDL has finished.
ORA-14413: ALTER INDEX UNUSABLE ONLINE cannot be used with certain types of indexes.
Cause:
An attempt was made to use the ALTER INDEX UNUSABLE ONLINE statement on an index type (for example, indexed-organized table (IOT), cluster, LOB, domain indexes) that was not allowed.
Action:
Using the ALTER INDEX UNUSABLE ONLINE statement on certain types of indexes (for example, indexed-organized table (IOT), cluster, LOB, domain indexes) is illegal. Remove the ONLINE keyword from the statement.
ORA-14414: DROP INDEX ONLINE cannot be used with certain types of indexes.
Cause:
An attempt was made to use the DROP INDEX ONLINE statement on an index type (for example, indexed-organized table (IOT), cluster, LOB, domain indexes) that was not allowed.
Action:
Using the DROP INDEX ONLINE statement on certain types of indexes (for example, indexed-organized table (IOT), cluster, LOB, domain indexes) is illegal. Remove the ONLINE keyword from the statement.
ORA-14415: index in partially dropped state, submit DROP INDEX
Cause:
An attempt was made to access an index in a partially dropped state.
Action:
Submit the DROP INDEX index statement to drop the index.
ORA-14416: Online DDL's cannot be used with certain types of tables.
Cause:
An attempt was made to use the DROP INDEX ONLINE, ALTER TABLE DROP CONSTRAINT ONLINE, or ALTER TABLE SET UNUSED COLUMN ONLINE statement on an table type (for example, cluster, temporary, index-organized table (IOT), external tables) that was not allowed.
Action:
Using online DDL's like DROP INDEX ONLINE, ALTER TABLE DROP CONSTRAINT ONLINE, or ALTER TABLE SET UNUSED COLUMN ONLINE statement on certain types of tables (for example, cluster, temporary, indexed-organized table (IOT), external tables) is illegal. Remove the ONLINE keyword from the statement.
ORA-14417: Online DDL's cannot be used with deferrable constraints.
Cause:
An attempt was made to use the DROP CONSTRAINT ONLINE or SET UNUSED COLUMN ONLINE statement on constraint states (for example, deferrable, deferred) that was not allowed.
Action:
Using DROP CONSTRAINT ONLINE or SET UNUSED COLUMN ONLINE statement on constraints that are deferrable or deferred is illegal. Remove the ONLINE keyword from the statement.
ORA-14418: Online DDL's cannot be used with this constraint type.
Cause:
An attempt was made to use the DROP CONSTRAINT ONLINE or SET UNUSED COLUMN ONLINE statement on a constraint type other than check, primary key, unique, referential, or not null constraint.
Action:
Using DROP CONSTRAINT ONLINE or SET UNUSED COLUMN ONLINE statement on any other constraint types excluding check, primary key, unique, referential, or not null constraints is illegal. Remove the ONLINE keyword from the DDL.
ORA-14419: DROP CONSTRAINT ONLINE does not support the CASCADE option.
Cause:
An attempt was made to use the CASCADE option with DROP CONSTRAINT ONLINE statement.
Action:
Using the CASCADE option with the DROP CONSTRAINT ONLINE statement is illegal. Remove the CASCADE keyword from the statement. Drop the child key constraint in a separate DROP CONSTRAINT ONLINE statement on the child table.
ORA-14450: attempt to access a transactional temp table already in use
Cause:
An attempt was made to access a transactional temporary table that has been already populated by a concurrent transaction of the same session.
Action:
do not attempt to access the temporary table until the concurrent transaction has committed or aborted.
ORA-14451: unsupported feature with temporary table
Cause:
An attempt was made to create an IOT, specify physical attributes, specify partition or parallel clause.
Action:
do not do that.
ORA-14452: attempt to create, alter or drop an index on temporary table already in use
Cause:
An attempt was made to create, alter or drop an index on temporary table which is already in use.
Action:
All the sessions using the session-specific temporary table have to truncate table and all the transactions using transaction specific temporary table have to end their transactions.
ORA-14453: attempt to use a LOB of a temporary table, whose data has alreadybeen purged
Cause:
An attempt was made to use LOB from a temporary table whose data has been dropped either because table was transaction-specific and transaction has commited or aborted, table was truncated or session which created this LOB has ended.
Action:
This LOB locator is invalid and cannot be used.
ORA-14454: attempt to reference temporary table in a referential integrity constraint
Cause:
An attempt was made to reference temporary table in a referencial integrity constraint. This is not supported.
Action:
Use triggers.
ORA-14455: attempt to create referential integrity constraint on temporary table
Cause:
An attempt was made to create a referential integrity constraint on a temporary table. This is not supported.
Action:
Use triggers.
ORA-14456: cannot rebuild index on a temporary table
Cause:
An attempt was made to rebuild an index on a temp table.
Action:
The index data is anyway lost at end of session/transaction.
ORA-14457: disallowed Nested Table column in a Temporary table
Cause:
An attempt made to create a Nested Table column in a temporary table. This is not supported.
Action:
Do not specify these datatypes for temporary tables.
ORA-14458: attempt was made to create a temporary table with INDEX organization
Cause:
An attempt was made to create an Index Organized Temporary table. This is not supported.
Action:
Create the table with HEAP organization and the primary key.
ORA-14459: missing GLOBAL keyword
Cause:
keyword GLOBAL is missing while creating temporary table.
Action:
supply keyword.
ORA-14460: only one COMPRESS or NOCOMPRESS clause may be specified
Cause:
COMPRESS was specified more than once, NOCOMPRESS was specified more than once, or both COMPRESS and NOCOMPRESS were specified.
Action:
specify each desired COMPRESS or NOCOMPRESS clause option only once.
ORA-14461: cannot REUSE STORAGE on a temporary table TRUNCATE
Cause:
REUSE STORAGE was specified with TRUNCATE on a temporary table. This is unsupported as it is meaningless.
Action:
Specify DROP STORAGE instead (which is the default).
ORA-14462: cannot TRUNCATE temporary table in an autonomous transaction which is already in use by the parent transaction
Cause:
An attempt was made to TRUNCATE a temporary table in an autonomous transaction which is already in use by the parent transaction.
Action:
Make sure the temporary table is not being used by the parent transaction before trying to TRUNCATE in an autonomous transaction.
ORA-14463: OPERATIONS keyword not specified
Cause:
OPERATIONS keyword was not specified in the Compression Clause.
Action:
specify OPERATIONS in the Compression Clause.
ORA-14464: Compression Type not specified
Cause:
Compression Type was not specified in the Compression Clause.
Action:
specify Compression Type in the Compression Clause.
ORA-14465: Fast-Split is not possible on these partitions
Cause:
The Fast-Split event was forced in this session.
Action:
Disable the event that forces Fast-Split.
ORA-14500: LOCAL option not valid without partition name
Cause:
Incorrect syntax specified
Action:
Retry the command
ORA-14501: object is not partitioned
Cause:
Table or index is not partitioned. Invalid syntax.
Action:
Retry the command with correct syntax.
ORA-14503: only one partition name can be specified
Cause:
More than one partition name has been specified for analyze
Action:
Specify one partition name.
ORA-14504: syntax not supported for analyze
Cause:
A partition/subpartition number or bind variable has been used
Action:
Specify a valid partition/subpartition name.
ORA-14505: LOCAL option valid only for partitioned indexes
Cause:
Action:
Retry the command
ORA-14506: LOCAL option required for partitioned indexes
Cause:
Action:
Retry the command
ORA-14507: partition corrupt. all rows do not fall within partition bounds
Cause:
The partition contains rows which should really be in some other partition. Possibly due to an exchange partition without validation
Action:
Delete rows in partition which do not qualify
ORA-14508: specified VALIDATE INTO table not found
Cause:
The specified table either does not exist or user does not have the proper privleges.
Action:
Specify the correct table to use.
ORA-14509: specified VALIDATE INTO table form incorrect
Cause:
The specified table does not have the proper field definitions.
Action:
Specify the correct table to use. See utlvalid.sql for more information.
ORA-14510: can specify VALIDATE INTO clause only for partitioned tables
Cause:
The VALIDATE INTO has been specified for a non partitioned table or cluster or index.
Action:
Use syntax correctly
ORA-14511: cannot perform operation on a partitioned object
Cause:
An attempt was made to perform an operation that is not allowed on partitioned tables or indexes.
Action:
ORA-14512: cannot perform operation on a clustered object
Cause:
An attempt was made to perform an operation that is not allowed on clustered tables or indexes.
Action:
ORA-14513: partitioning column may not be of object datatype
Cause:
Partitioning column specified by the user was an object datatype (object, REF, nested table, array) which is illegal.
Action:
Ensure that no partitioning column is an object datatype.
ORA-14514: LOCAL option not valid without subpartition name
Cause:
Action:
Retry the command
ORA-14515: only one aubpartition name can be specified
Cause:
More than one subpartition name has been specified for analyze
Action:
Specify one subpartition name.
ORA-14516: subpartition corrupt. all rows do not fall within subpartition bounds
Cause:
The subpartition contains rows which should really be in some other subpartition. Possibly due to an exchange subpartition without validation
Action:
Delete rows in subpartition which do not qualify
ORA-14517: subpartition of index 'string.string' is in unusable state
Cause:
An attempt has been made to access an index subpartition that has been marked unusable by a direct load or by a DDL operation
Action:
REBUILD the unusable index subpartition
ORA-14518: partition contains rows corresponding to values being dropped
Cause:
table partition contains rows for the values being dropped.
Action:
DELETE all rows for the values being dropped and reissue statement
ORA-14519: Conflicting tablespace blocksizes for string string: Tablespace string block size string [string] conflicts with previously specified/implied tablespace string block size string [string]
Cause:
An attempt has been made to create a partitioned object in a manner that would require the partitioned object to span tablespaces of more than one block size.
Action:
Ensure that all tablespaces specified in the DDL command for the given object as well as any tablespaces implicitly assigned to partitions or subpartitions of the object being created are all of the same block size.
ORA-14520: Tablespace string block size [string] does not match existing object block size [string]
Cause:
A DDL statement was issued that would require a tablespace of a block size different from the block size of the specified partitioned object to be assigned either: (1) As the object's default tablespace (or one of the object's partition-level default tablespaces, if composite partitioning is being used) OR (2) To one of the object's partitions/subpartitions.
Action:
Specify a tablespace of the same block size as the partitioned object.
ORA-14521: Default tablespace string block size [string] for string string does not match existing string block size [string]
Cause:
A DDL statement was issued that would require creation of a new partition/subpartition in the object-level default tablespace of an existing partitioned object. However, the object-level default tablespace block size does not match the block size of the partitioned object.
Action:
Either (1) Modify the default tablespace of the partitioned object to a tablespace of the same block size as the object and then retry the DDL command, OR (2) Ensure that tablespaces of the correct block size are specified for all new partitions/subpartitions being created.
ORA-14522: Partition-level default tablespace string block size [string] for string string does not match existing string block size [string]
Cause:
A DDL statement was issued that would require creation of a new subpartition in one of the partition-level default tablespaces of an existing composite partitioned object. However, the partition-level default tablespace block size does not match the block size of the partitioned object.
Action:
Either (1) Modify the partition-level default tablespace of the appropriate partition of the partitioned object to a tablespace of the same block size as the object and then retry the DDL command, OR (2) Ensure that tablespaces of the correct block size are specified for all new subpartitions being created.
ORA-14523: Cannot co-locate [sub]partition of string string with table [sub]partition because string block size [string] does not match table block size [string]
Cause:
A DDL statement was issued that would require a partition/subpartition of a local index/LOB column to be co-located with the corresponding partition/subpartition of the base table. However, this is not possible because the block sizes of the table and the LOB column/local index are different.
Action:
Either (1) Specify an object-level default tablespace (or partition-level default tablespace for the appropriate partition, if composite partitioning is used) for the partitioned local index/LOB column and then retry the DDL command, OR (2) Ensure that tablespaces of the correct block size are specified for all new partitions/subpartitions being created. Also ensure that neither of TABLESPACE DEFAULT and STORE IN (DEFAULT) is specified for a local index whose block size does not match that of the base table.
ORA-14530: row mismatches found in table string.string and index string.string
Cause:
rows in table and index inconsistent
Action:
run complete analyze to determine corrupt rows
ORA-14551: cannot perform a DML operation inside a query
Cause:
DML operation like insert, update, delete or select-for-update cannot be performed inside a query or under a PDML slave.
Action:
Ensure that the offending DML operation is not performed or use an autonomous transaction to perform the DML operation within the query or PDML slave.
ORA-14552: cannot perform a DDL, commit or rollback inside a query or DML
Cause:
DDL operations like creation tables, views etc. and transaction control statements such as commit/rollback cannot be performed inside a query or a DML statement.
Action:
Ensure that the offending operation is not performed or use autonomous transactions to perform the operation within the query/DML operation.
ORA-14553: cannot perform a lob write operation inside a query
Cause:
A lob write operation cannot be performed inside a query or a PDML slave.
Action:
Ensure that the offending lob write operation is not performed or use an autonomous transaction to perform the operation within the query or PDML slave.
ORA-14554: cannot perform requested operation during database startup
Cause:
Requested operation requires the Cost Based Optimizer(CBO) which is not available during database startup. Features like partitioning, IOTs, grouping sets, and flashback cursor require the CBO.
Action:
Retry the query after the database is open.
ORA-14601: Illegal to specify SUBPARTITIONS or STORE-IN while specifying a subpartition template
Cause:
Cannot specify these clauses while specifying a template
Action:
Correct the subpartition template clause.
ORA-14602: SUBPARTITION TEMPLATE is legal only for a composite partitioned table
Cause:
SUBPARTITION TEMPLATE can be specified only for composite partitioned tables
Action:
Do not use SUBPARTITION TEMPLATE on non-partitioned or non-composite partitioned tables.
ORA-14603: [SUBPARTITIONS | SUBPARTITION TEMPLATE] subpartition_count syntax is valid only for range-hash tables
Cause:
This syntax is valid only if subpartitioning dimension is hash
Action:
n/a
ORA-14604: During CREATE TABLE time it is illegal to specify SUBPARTITIONS or STORE IN once a SUBPARTITION TEMPLATE has been specified
Cause:
Once a subpartition template has been specified during a CREATE TABLE it is illegal to specify SUBPARTITIONS or STORE IN anywhere else
Action:
Remove either the SUBPARTITIONS | STORE IN or remove the SUBPARTITION TEMPLATE clause
ORA-14605: Name missing for subpartition / lob segment in template
Cause:
A subpartition / lob segment was not specified a name in the template descriptions
Action:
All subpartitions / lob segments must have names specified in the template
ORA-14607: Tablespace was not specified for previous subpartitions in template but is specified for string
Cause:
Tablespaces may either be specified for all subpartitions or must not be specified for any subpartitions
Action:
Either specify tablespaces for all or for none of the subpartitions
ORA-14610: Lob attributes not specified for lob column string for subpartition string
Cause:
Lob attributes of a column must be specified for all subpartitions or must not be specified at all
Action:
Ensure lob attributes of a column are specified for all subpartitions or not specified at all
ORA-14611: Duplicate subpartition name string in template
Cause:
A subpartition name cannot be duplicated within the template
Action:
Rename one of the subpartitions.
ORA-14612: Duplicate lob segment name string for lob column string in template
Cause:
Two lob segments of the same column were given the same name in the template
Action:
Rename one of the lob segments
ORA-14613: Attempt to generate name from parent name string and template name string failed as the combine named would have been longer than allowed
Cause:
Any name generated from a partition name and template name must be less than the maximum permissible name for an identifier
Action:
Shorten either partition or template name.
ORA-14614: List value 'string' specified twice in subpartition 'string'
Cause:
Action:
ORA-14615: List value 'string' specified twice in subpartitions 'string', 'string'
Cause:
Action:
ORA-14616: table is not subpartitioned by List method
Cause:
A subpartition maintenance operation, such as ALTER TABLE MODIFY SUBPARTITION ADD|DROP VALUES, was performed on a non-List subpartitioned object.
Action:
Reissue the command against a List subpartitioned object.
ORA-14617: cannot add/drop values to DEFAULT subpartition
Cause:
A ADD/DROP VALUES operation is being done on the default subpartition
Action:
Ensure that ADD/DROP VALUES is not done on the DEFAULT subpartition
ORA-14618: cannot drop the last value of subpartition
Cause:
ALTER TABLE DROP VALUES tried to drop the last value of the subpartition
Action:
Cannot execute the command, unless two or more values exist for subpartition
ORA-14619: resulting List subpartition(s) must contain at least 1 value
Cause:
After a SPLIT/DROP VALUE of a list subpartition, each resulting subpartition(as applicable) must contain at least 1 value
Action:
Ensure that each of the resulting subpartitions contains atleast 1 value
ORA-14620: DEFAULT subpartition already exists
Cause:
A subpartition already exists with DEFAULT value
Action:
Remove the DEFAULT value from the list specified
ORA-14621: cannot add subpartition when DEFAULT subpartition exists
Cause:
An ADD SUBPARTITION operation cannot be executed when a subpartition with DEFAULT values exists
Action:
Issue a SPLIT of the DEFAULT subpartition instead
ORA-14622: Value string already exists in subpartition string
Cause:
One of the list values in the ADD SUBPARTITION or ADD VALUES statement already exists in another subpartition
Action:
ORA-14623: Value string does not exist in subpartition string
Cause:
One of the list values in the SPLIT PARTITION or DROP VALUES statement does not exist in the subpartition
Action:
ORA-14624: DEFAULT subpartition must be last subpartition specified
Cause:
A subpartition description follows the one describing the default subpartition
Action:
Ensure that the DEFAULT subpartition is the last subpartition description
ORA-14625: subpartition contains rows corresponding to values being dropped
Cause:
table subpartition contains rows for the values being dropped.
Action:
ORA-14626: values being added already exist in DEFAULT subpartition
Cause:
An ADD VALUE operation cannot be executed because the values being added exist in the DEFAULT subpartition
Action:
Issue a SPLIT of the DEFAULT subpartition and then MERGE the split subpartition into the subpartition to which values need to be added
ORA-14627: Invalid operation was specified on a GLOBAL partitioned index
Cause:
An invalid operation such as ALTER INDEX DROP|SPLIT SUBPARTITION was specified on the global index
Action:
Ensure that subpartition level operations are not specified on a GLOBAL index, since these are only RANGE partitioned
ORA-14628: specification of bounds is inconsistent with LIST method
Cause:
An operation such as ALTER TABLE SPLIT|ADD SUBPARTITION specified bounds that were inconsistent with List subpartitioning method
Action:
Specify VALUES/subpartition descriptions correctly for SPLIT/ADD of List subpartitions
ORA-14629: cannot drop the only subpartition of a partition
Cause:
A drop subpartition command is being executed when there is only one subpartition in the partition
Action:
n/a
ORA-14630: subpartition resides in offlined tablespace
Cause:
Action:
Bring tablespace online before attempting the operation.
ORA-14631: the partition bounds do not match the subpartition bounds of the partition
Cause:
When exchanging a partitioned table with a composite partition the bounds that describe the partitions of the table must match the bounds that describe the subpartitions of the composite partition.
Action:
Ensure that the bounds describing partitions in the partitioned table is the same as the bounds of the subpartitions in the the composite partition.
ORA-14632: cannot specify PARALLEL clause when adding a List subpartition
Cause:
User issued ALTER TABLE ADD SUBPARTITION statement with PARALLEL clause for a List subpartition of a Range/List partitioned object which is illegal
Action:
ORA-14633: Index maintainence clause not allowed for ADD list subpartition to a Composite partitioned table
Cause:
The clause INVALIDATE or UPDATE GLOBAL INDEXES is allowed only for ADD hash subpartition to a composite partitioned table.
Action:
Remove clause and reissue operation
ORA-14634: Subpartition descriptions cannot be specified during the SPLIT/MERGE of a partition of a Range-List partitioned table
Cause:
During a split or a merge of a partition of a range list partitioned table you cannot specify any subpartitioning information for the resulting partition (s)
Action:
Remove all subpartitioning information from the DDL.
ORA-14635: only one resulting subpartition can be specified for MERGE SUBPARTITIONS
Cause:
ALTER TABLE MERGE SUBPARTITIONS contained more than one resulting subpartition for the MERGE
Action:
Ensure that the statement describes exactly one subpartition as the target that need to be MERGEd
ORA-14636: only 2 resulting subpartition can be specified for SPLIT SUBPARTITION
Cause:
ALTER TABLE SPLIT SUBPARTITION contained more than 2 resulting subpartition for the SPLIT
Action:
Ensure that the statement describes exactly 2 subpartitions as the target of the SPLIT operation
ORA-14637: cannot merge a subpartition with itself
Cause:
The same subpartition name was specified twice for the merge operation
Action:
Re-submit operation with 2 distinct subpartition names within the same composite partition
ORA-14638: cannot MERGE subpartitions in different Range Composite partitions
Cause:
Attempted to MERGE subpartitions in different Range Composite partitions
Action:
Reissue the command after ensuring that the 2 subpartitions being merged lie in the same composite partition
ORA-14639: SUBPARTITIONS clause can be specfied only for Hash, Composite Range Hash table/partition
Cause:
Attempted to specify SUBPARTITIONS clause on table that is not partitioned by the Composite Range-Hash method
Action:
Reissue the command after ensuring that the SUBPARTITIONS clause is not specified, to specify a template for a Composite Range List object use the SUBPARTITION TEMPLATE clause
ORA-14640: add/coalesce index partition operation is valid only for hash partitioned global indexes
Cause:
User attempted to add or coalesce an index partition of a global index not partitioned by hash method.
Action:
Issue the statement on a global index partitioned by hash method. or if the index is partitioned by range method consider using split/drop instead of add/coalesce.
ORA-14641: STORE-IN clause can be specified only for a Hash, Composite Range Hash table/partition
Cause:
Specifying a STORE-IN clause during CREATE/ALTER of a Range, Composite Range List partitioned table which is not allowed"
Action:
Re-issue the stament after removing the STORE-IN clause
ORA-14642: Bitmap index mismatch for tables in ALTER TABLE EXCHANGE PARTITION
Cause:
The two tables in the EXCHANGE have usable bitmap indexes, and the INCLUDING INDEXES option has been specified and the tables have different hakan factors.
Action:
Perform the exchange with the EXCLUDING INDEXES option or alter the bitmap indexes to be unusable.
ORA-14643: Hakan factor mismatch for tables in ALTER TABLE EXCHANGE PARTITION
Cause:
Either records_per_block has been minimized for one of the tables to be exchanged, but not the other, or the hakan factors for the tables to be exchanged are not equal.
Action:
If records_per_block has been minimized for one of the tables, but not the other, either perform alter table with the NOMINIMIZE RECORDS_PER_BLOCK option for both tables, or perform alter table with the MINIMIZE RECORDS_PER_BLOCK for both tables. If the hakan factors do not match perform alter table with the NOMINIMIZE RECORDS_PER_BLOCK option for both tables.
ORA-14644: table is not subpartitioned by Hash method
Cause:
A subpartition maintenance operation such as ALTER TABLE MODIFY PARTITION COALESCE SUBPARTITION can only be performed on Hash subpartitioned objects
Action:
Re-issue the command against a Hash subpartitioned object.
ORA-14645: STORE IN clause cannot be specified for Range List objects
Cause:
A STORE IN clause was specified for Range List partitioned object
Action:
Re-issue the command after removng the STORE IN clause
ORA-14646: Specified alter table operation involving compression cannot be performed in the presence of usable bitmap indexes
Cause:
The first time a table is altered to include compression, it cannot have a usable bitmap index (partition). Subsequent alter table statements involving compression do not have this same restriction.
Action:
A) Drop any bitmap indexes defined on the table, and re-create them once the operation is complete or, B) Mark all index fragments of all bitmap indexes defined on the table UNUSABLE and rebuild them once the operation is complete.
ORA-14647: cannot MERGE subpartitions in different list composite partitions
Cause:
An attempt was made to MERGE subpartitions in different list composite partitions.
Action:
Reissue the command after ensuring that the two subpartitions being merged lie in the same composite partition.
ORA-14650: operation not supported for reference-partitioned tables
Cause:
Attempted to perform an operation on a reference-partitioned table that was not supported.
Action:
Do not perform the unsupported operation.
ORA-14651: reference partitioning constraint is not supported
Cause:
The specified partitioning constraint was not supported for reference-partitioned tables. The partitioning constraint must be enabled, validated, and not deferrable. The partitioning constraint must not have ON DELETE SET NULL semantics.
Action:
Correct the statement to specify a supported partitioning constraint.
ORA-14652: reference partitioning foreign key is not supported
Cause:
The specified partitioning foreign key was not supported for reference-partitioned tables. All columns of the partitioning foreign key must be constrained NOT NULL with enabled, validated, and not deferrable constraints. Furthermore, a virtual column cannot be part of the partitioning foreign key.
Action:
Correct the statement to specify a supported partitioning foreign key.
ORA-14653: parent table of a reference-partitioned table must be partitioned
Cause:
Attempted to create a reference-partitioned table with a non-partitioned parent table.
Action:
Correct the statement and reenter.
ORA-14654: number of partitions of reference-partitioned table must equal that of the parent table
Cause:
Attempted to create a reference-partitioned table with a number of partitions which was different from that of the parent table.
Action:
Correct the CREATE TABLE statement to specify a correct number of partitions.
ORA-14655: reference partitioning constraint not found
Cause:
Partitioning constraint specified in CREATE TABLE ... PARTITION BY REFERENCE was not one of the referential constraints on the table being created.
Action:
Ensure that the specified partitioning constraint is one of the referential constraints on the table being created.
ORA-14656: cannot drop the parent of a reference-partitioned table
Cause:
Attempted to drop the parent of a reference-partitioned table.
Action:
Drop all reference-partitioned child tables before dropping the parent table.
ORA-14657: cannot cascade row migration to reference-partitioned child table
Cause:
Update of a parent key may require migration of rows in reference-partitioned child tables, however this is not supported because the parent key was not suitably indexed.
Action:
Replace the existing index on the parent key with a unique index that does not contain any columns in addition to the parent key.
ORA-14658: specified dependent table is not affected by this operation
Cause:
A table has been specified in the DEPENDENT TABLES clause that is not a reference-partitioned table affected by the operation.
Action:
ORA-14659: Partitioning method of the parent table is not supported
Cause:
An attempt was made to create a reference-partitioned table with an interval partitioned parent table.
Action:
Do not create a reference-partitioned table with an interval partitioned parent table.
ORA-14660: parent table of a reference-partitioned table cannot be index-organized
Cause:
Attempted to create a reference-partitioned table with a index-organized parent table.
Action:
ORA-14661: row movement must be enabled
Cause:
Attempted to disable row movement for a reference-partitioned table, although row movement was enabled for its parent table.
Action:
Disable row movement for parent table before disabling row movement for the reference-partitioned table.
ORA-14662: row movement cannot be enabled
Cause:
Attempted to enable row movement for a partitioned table, although row movement was disabled for a reference-partitioned child table.
Action:
Enable row movement for reference-partitioned child tables before enabling row movement for the parent table.
ORA-14663: reference partitioning parent key is not supported
Cause:
Parent key of the reference-partitioned table's partitioning constraint contained virtual columns.
Action:
Correct the statement to specify a partitioning constraint with supported parent key and reenter.
ORA-14664: Cannot use PL/SQL expressions in reference partitioning parent key
Cause:
Parent key of the reference partitioned table's partitioning constraint contained a virtual column that referenced a PL/SQL expression.
Action:
ORA-14665: Cannot use expressions involving ROWID data type in reference partitioning parent key
Cause:
Parent key of the reference partitioned table's partitioning constraint contained a virtual column that involved the ROWID data type.
Action:
ORA-14666: Cannot use expressions involving BLOB or CLOB data types in reference partitioning parent key
Cause:
Parent key of the reference partitioned table's partitioning constraint contained a virtual column that involved a BLOB or CLOB data type.
Action:
ORA-14667: Cannot use expressions involving object data types in reference partitioning parent key
Cause:
Parent key of the reference partitioned table's partitioning constraint contained a virtual column that involved an object data type (object, REF, nested table, array).
Action:
ORA-14668: Cannot drop a unique or primary key referenced by the partitioning constraint of a reference-partitioned table.
Cause:
An attempt was made to drop a unique or primary key referenced by the partitioning constraint of a reference-partitioned table.
Action:
Drop all reference-partitioned child tables before dropping the unique or primary key of the parent table.
ORA-14669: interval partition of reference-partitioned table must correspond to interval partition of the parent table
Cause:
An attempt was made to create a reference-partitioned table with an interval partiton that does not pair with an interval partition in the parent table.
Action:
ORA-14670: there is no usable index on the reference partitioning parent key
Cause:
An attempt was made to run an operation on a reference partitioned table that requires a usable index on the reference partitioning parent key, but no such index exists.
Action:
Create a usable index on the reference partitioning parent key, or rebuild the existing unusable index on the reference partitioning parent key.
ORA-14690: value too long for MIN or MAX aggregate
Cause:
An attempt was made to use a MIN or MAX aggregate with a value that was too long.
Action:
Limit the size of MIN and MAX aggregate inputs to 32763 bytes.
ORA-14691: Extended character types are not allowed in this table.
Cause:
An attempt was made to create VARCHAR2 or NVARCHAR2 columns larger than 4000 bytes, or a RAW column larger than 2000 bytes, in a cluster, clustered table or index-organized table.
Action:
ORA-14692: STORE AS clause is not allowed for extended character type column
Cause:
An attempt was made to use the STORE AS clause to specify storage attributes for an extended character type column.
Action:
ORA-14693: The MAX_STRING_SIZE parameter must be EXTENDED.
Cause:
An attempt was made to set the MAX_STRING_SIZE parameter to STANDARD in a database that has been created with, or migrated to, the EXTENDED setting.
Action:
Set MAX_STRING_SIZE to EXTENDED and retry.
ORA-14694: database must in UPGRADE mode to begin MAX_STRING_SIZE migration
Cause:
An attempt was made to update the MAX_STRING_SIZE parameter to EXTENDED when the database was not in UPGRADE mode.
Action:
Restart the database in UPGRADE mode, modify the parameter, run the utl32k.sql script in $ORACLE_HOME/rdbms/admin, and restart the database in normal mode.
ORA-14695: MAX_STRING_SIZE migration is incomplete
Cause:
An attempt was made to open the database in normal mode before the MAX_STRING_SIZE migration process completed.
Action:
Restart the database in UPGRADE mode, run the utl32k.sql script in $ORACLE_HOME/rdbms/admin, and restart the database in normal mode.
ORA-14696: MAX_STRING_SIZE migration is incomplete for pluggable database string
Cause:
An attempt was made to open the database in normal mode before the MAX_STRING_SIZE migration process completed for the specified pluggable database.
Action:
Restart the database in UPGRADE mode, run the utl32k.sql script in $ORACLE_HOME/rdbms/admin in the specified pluggable database, and restart the database in normal mode.
ORA-14697: This connection does not support bind variables larger than 4000 bytes for SQL statements.
Cause:
An attempt was made to use a bind variable larger than 4000 bytes for a SQL statement when the client initially connected to a container with STANDARD MAX_STRING_SIZE, and then within the same session switched to a container with EXTENDED MAX_STRING_SIZE.
Action:
Initialize a new connection for the container with EXTENDED MAX_STRING_SIZE and retry.
ORA-14700: Object(s) owned by SYS cannot be locked by non-SYS user
Cause:
Attempt to issue a LOCK TABLE statement on SYS owned object(s) by a non-SYS user, user should minimally have DML privileges
Action:
Re-issue LOCK TABLE statement for non-SYS user after granting DML privileges on object, or non-SYS user should connect as SYS
ORA-14701: partition-extended name or bind variable must be used for DMLs on tables partitioned by the System method
Cause:
User attempted not to use partition-extended syntax for a table partitioned by the System method
Action:
Must use of partition-extended syntax in contexts mentioned above.
ORA-14702: The partition number is invalid or out-of-range
Cause:
Attempted to use nonnumerical value or the number was out of range of the partitions.
Action:
Use a valid partition number.
ORA-14703: The AFTER clause can be used to ADD PARTITION only to a System Partitioned table.
Cause:
The table is not partitioned by the System method
Action:
Skip the AFTER clause.
ORA-14704: Create table as select disallowed for SYSTEM patitioned tables
Cause:
User attempted to create a SYSTEM partitioned table by doing a create table as select.
Action:
Do a create table followed by an insert as select into each partition.
ORA-14705: unique or primary keys referenced by enabled foreign keys in table "string"."string"
Cause:
An attempt was made to truncate a table with unique or primary keys referenced by enabled foreign keys in another table.
Action:
Before performing the TRUNCATE operation on the table, disable the foreign key constraints in other tables. You can see what constraints exist in a table by issuing the following command: SELECT * FROM USER_CONSTRAINTS WHERE TABLE_NAME = :1;
ORA-14706: multiple child tables reference constraint "string" in table "string"." string"
Cause:
An ALTER TABLE EXCHANGE [SUB]PARTITION CASCADE command found that the specified parent key in the specified table was referenced by partitioning constraints in multiple reference partitioned child tables.
Action:
Perform EXCHANGE [SUB]PARTITION without the CASCADE option. The CASCADE option is not supported if a parent key in the reference partitioned table hierarchy is referened by multiple partitioning constraints.
ORA-14707: no match found for table "string"." string" for EXCHANGE CASCADE
Cause:
There was no table matching the specified table in the ALTER TABLE EXCHANGE [SUB]PARTITION CASCADE command.
Action:
Perform EXCHANGE [SUB]PARTITION without the CASCADE option or ensure that exactly one table matches the specified table.
ORA-14708: multiple matches found for table "string"." string" for EXCHANGE CASCADE
Cause:
There were multiple tables matching the specified table in the ALTER TABLE EXCHANGE [SUB]PARTITION CASCADE command.
Action:
ORA-14709: index mismatch for table "string"."string" in ALTER TABLE EXCHANGE [SUB]PARTITION
Cause:
An ALTER TABLE EXCHANGE [SUB]PARTITION command was attempted for the specified table, however, the exchange table did not have equivalent indexes.
Action:
Ensure that the indexes for the two tables have indexes which follow this rule: For every nonpartitioned index for the nonpartitioned table, there has to be an identical LOCAL index on the partitioned table and vice versa. To be identical, the column position type and size have to be the same.
ORA-14750: Range partitioned table with INTERVAL clause has more than one column
Cause:
You attempted to create an interval partitioned table with more than one partitioning column.
Action:
Use a single partitioning column.
ORA-14751: Invalid data type for partitioning column of an interval partitioned table
Cause:
You attempted to use interval partitioning on a table partitioned on a column of data type other than number or date/time.
Action:
Use only number or date/time columns as partitioning columns for interval partitioned tables.
ORA-14752: Interval expression is not a constant of the correct type
Cause:
You attempted to use either a nonconstant interval or an interval whose data type does not correspond to the partitioning column
Action:
Use only constant expressions for the interval. If the data type of partitioning column is numeric, the interval must be a numeric constant. If the data type is of type date/time, the interval must be a constant of interval type
ORA-14753: Interval cannot be zero
Cause:
The interval mapped to zero.
Action:
You must use a nonzero interval.
ORA-14754: Interval string is too long
Cause:
The interval string was too long
Action:
Specify interval using a shorter string
ORA-14755: Invalid partition specification for FOR VALUES clause.
Cause:
The [SUB]PARTITION FOR VALUES (...) clause can only take constants. In addition it takes as many arguments as there are partitioning columns and the values must be coercible to the partitioning columns.
Action:
Specify a valid FOR VALUES clause.
ORA-14756: Table is not partitioned by Interval method.
Cause:
The table was not partitioned by Interval method.
Action:
ALTER TABLE SET STORE IN is only valid for Interval partitioned tables. Ensure that the table by Interval.
ORA-14757: Table is already a range partitioned table
Cause:
SET INTERVAL () is used to convert an interval partitioned table to a range partitioned table. It is not legal on a range partitioned table
Action:
Use SET INTERVAL () only on an interval partitioned table.
ORA-14758: Last partition in the range section cannot be dropped
Cause:
An attempt was made to drop the last range partition of an interval partitioned table.
Action:
Do not attempt to drop this partition.
ORA-14759: SET INTERVAL is not legal on this table.
Cause:
SET INTERVAL clause was specified. ALTER TABLE SET INTERVAL is only legal on a range partitioned table with a single partitioning column. Additionally, this table cannot have a maxvalue partition and cannot be the parent table for any reference partitioned tables.
Action:
Use SET INTERVAL only on a valid table.
ORA-14760: ADD PARTITION is not permitted on Interval partitioned objects
Cause:
ALTER TABLE ADD PARTITION was attempted on an Interval partitioned object.
Action:
Do not perform the operation on an Interval partitioned object. Insert a row to create the new partition.
ORA-14761: MAXVALUE partition cannot be specified for Interval partitioned objects
Cause:
An attempt was made to create a partition with a MAXVALUE highbound on an Interval partitioned object.
Action:
Do not create a partition with a MAXVALUE highbound.
ORA-14762: Domain index creation on interval partitioned tables is not permitted
Cause:
An attempt was made to create a domain index on an interval partitioned table.
Action:
Do not create a domain index on an interval partitioned table.
ORA-14763: Unable to resolve FOR VALUES clause to a partition number
Cause:
Could not determine the partition corresponding to the FOR VALUES clause.
Action:
Remove bind variables and dependencies on session parameters from the values specified in the FOR VALUES clause.
ORA-14764: FOR VALUES clause cannot be specified for only one partition
Cause:
An attempt was made to specify the FOR VALUES clause for only one of the two partitions being merged.
Action:
Specify a FOR VALUES clause for each of the two partitions being merged or do not specify the FOR VALUES clause for either.
ORA-14765: Cannot create a partition while doing a create index
Cause:
An attempt was made to create a partition concurrently with index creation.
Action:
Retry the statement after the index build is finished.
ORA-14766: Unable to obtain a stable metadata snapshot
Cause:
This operation was not able to obtain a stable snapshot of the interval partitioning metadata.
Action:
Retry the statement.
ORA-14767: Cannot specify this interval with existing high bounds
Cause:
The interval specified conflicts with the existing high bound for the last partition. The combination might lead to invalid dates for high bounds in the future.
Action:
If this is a CREATE TABLE, try specifying a different high bound value for the last partition, or a different interval. If this is an ALTER TABLE SET INTERVAL, please choose either a different interval, or, modify the table to change the high bound for the last partition.
ORA-14769: cannot interval partition nested table or XMLType with object-relational storage
Cause:
Interval partition was not supported for nested table and XMLType with object-relational storage.
Action:
Use a list or range partition instead.
ORA-14801: Hash composite partitioning is not supported
Cause:
An attempt was made to partition a table using a Hash composite method.
Action:
Do not partition the table by a Hash composite method.
ORA-14802: Specified operation is not permitted on Hash composite partitioned objects
Cause:
An unsupported operation was attempted on a Hash composite partitioned object.
Action:
Do not perform the operation on a Hash composite partitioned object.
ORA-14803: partition bound may not be specified for hash subpartitioned tables
Cause:
A VALUES LESS THAN or VALUES clause was specified with a subpartition description.
Action:
Remove the VALUES LESS THAN or VALUES clause from the subpartition description.
ORA-14804: A partition must be split into two or more partitions
Cause:
An ALTER TABLE SPLIT PARTITION contained a description for only one resulting partition.
Action:
Specify at least 2 resulting partitions.
ORA-14805: last resulting partition cannot contain bounds
Cause:
An ALTER TABLE SPLIT PARTITION contained a description for the last partition which included the bounds.
Action:
Do not specify bounds for the last resulting partition.
ORA-14806: merging more than two partitions or subpartitions is only supported for heap tables
Cause:
An ALTER TABLE MERGE PARTITIONS or MERGE SUBPARTITIONS with more than two source partitions or subpartitions was issued. Merging more than two partitions or subpartitions is only supported for heap tables.
Action:
Specify exactly two partitions or subpartitions to merge.
ORA-14807: merging partitions or subpartitions using name TO name syntax is only supported for range partitioned tables
Cause:
An ALTER TABLE MERGE PARTITIONS pname TO pname or an ALTER TABLE MERGE SUBPARTITIONS subpname TO subpname was issued. This is only supported for range partitions or subpartitions.
Action:
Specify all the partitions or subpartitions to be merged.
ORA-14808: ONLINE MOVE PARTITION is not supported for this table
Cause:
An ALTER TABLE MOVE PARTITION ONLINE statement was issued on a table that was either not a heap table or had an object type, domain index or bitmap join index defined on it. This operation is only supported for heap tables.
Action:
Do not use the ONLINE keyword.
ORA-14809: ONLINE MOVE PARTITION not supported for this schema
Cause:
An ALTER TABLE MOVE PARTITION ONLINE statement was issued on a table owned by SYS, SYSTEM, PUBLIC, OUTLN or XDB.
Action:
ORA-14810: ONLINE MOVE PARTITION not supported while database is not open or in migrate mode
Cause:
An ALTER TABLE MOVE PARTITION ONLINE statement was issued on a table while the database was not open or was in migrate mode.
Action:
ORA-14811: ONLINE MOVE PARTITION not supported under supplemental logging
Cause:
An ALTER TABLE MOVE PARTITION ONLINE statement was issued on a table while supplemental logging was enabled.
Action:
ORA-14812: DBMS_LOB operations not allowed on partition while it is being moved online
Cause:
A DBMS_LOB operation was issued on a LOB while an ALTER TABLE MOVE PARTITION ONLINE was concurrently executing on the partition containing the LOB.
Action:
Reissue DBMS_LOB operation after MOVE PARTITION ONLINE has completed.
ORA-14900: The logical transaction ID is no longer valid.
Cause:
The logical transaction ID has been purged and the commit failed.
Action:
Reconnect and re-run the transaction.
ORA-14901: Commits during replay are not permitted.
Cause:
The transaction tried to commit during replay.
Action:
Contact Oracle Support Services.
ORA-14902: Instance has not been configured for application continuity.
Cause:
The partition of the transaction history table had not been created.
Action:
ORA-14903: Corrupt logical transaction detected.
Cause:
The logical transaction was corrupt. The size was incorrect.
Action:
Verify your network configuration.
ORA-14904: Corrupt logical transaction ID detected.
Cause:
The logical transaction was corrupt. The database ID was incorrect.
Action:
ORA-14905: Serializable transactions cannot be replayed.
Cause:
The transaction tried to replay a serializable transaction.
Action:
ORA-14906: Get LTXID outcome operation is not permitted on the current session.
Cause:
The transaction tried to execute get LTXID outcome on the current session.
Action:
Check the parameters used to invoke get LTXID outcome.
ORA-14907: Cannot execute get LTXID outcome for the transaction of another user.
Cause:
The transaction tried to execute get LTXID outcome for a different user session.
Action:
ORA-14908: Cannot invoke get LTXID outcome while a transaction is open.
Cause:
Get LTXID outcome could not be executed because a transaction was open.
Action:
Invoke get LTXID outcome after the transaction has been completed.
ORA-14909: Current session has been blocked by another user with the same user name using GET_LTXID_OUTCOME.
Cause:
Could not commit after GET_LTXID_OUTCOME was invoked.
Action:
ORA-14910: Sessions with SYSDBA privilege are not allowed to connect to a service that has commit outcome enabled.
Cause:
A session with SYSDBA privilege tried to connect to a service that has commit outcome enabled.
Action:
Connect without the SYSDBA privilege.
ORA-14911: XA transactions are not supported by Transaction Guard.
Cause:
The transaction tried to commit an XA transaction.
Action:
ORA-14912: Transactions by DRCP clients are not supported by Transaction Guard.
Cause:
The Database Resident Connection Pooling (DRCP) client tried to commit a transaction while Transaction Guard was enabled.
Action:
ORA-14950: Force outcome failed. Client transaction is too old.
Cause:
The client transaction had been commited or forced earlier.
Action:
None
ORA-14951: Force outcome failed. Client transaction is ahead of server logical transaction ID.
Cause:
The client transaction had not been seen by the server and could not be forced. This can happen if the server is restored or a flashback operation has been executed.
Action:
None
ORA-14952: Force outcome failed. General error occurred.
Cause:
The force outcome operation failed. See previous error for the reason.
Action:
None
ORA-14953: Invalid partition ID specified.
Cause:
The partition IDs of the transaction history table were not consecutive.
Action:
Specify the next higer partition ID.
ORA-14954: Invalid tablespace name specified.
Cause:
The tablespace did not exist.
Action:
Specify an existing tablespace.
ORA-15000: command disallowed by current instance type
Cause:
The user has issued a command to a conventional RDBMS instance that is only appropriate for an ASM instance. Alternatively, the user has issued a command to an ASM instance that is only appropriate for an RDBMS instance.
Action:
Connect to the correct instance type and re-issue the command.
ORA-15001: diskgroup "string" does not exist or is not mounted
Cause:
An operation failed because the diskgroup specified does not exist or is not mounted by the current ASM instance.
Action:
Verify that the diskgroup name used is valid, that the diskgroup exists, and that the diskgroup is mounted by the current ASM instance.
ORA-15002: parameter LOCK_NAME_SPACE exceeds limit of string characters
Cause:
The LOCK_NAME_SPACE initialization parameter contained a value that is too long.
Action:
Correct the LOCK_NAME_SPACE initialization parameter.
ORA-15003: diskgroup "string" already mounted in another lock name space
Cause:
The diskgroup could not be mounted by the ASM instance because it was operating in a lockspace different than another existing ASM instance which had already mounted the diskgroup.
Action:
Check the LOCK_NAME_SPACE initialization parameter value, or dismount the diskgroup from the other ASM instances.
ORA-15004: alias "string" does not exist
Cause:
The specified alias did not exist within the diskgroup.
Action:
Check the alias name and diskgroup name.
ORA-15005: name "string" is already used by an existing alias
Cause:
An existing alias in the diskgroup used the same name.
Action:
Select another alias name, or drop the existing alias.
ORA-15006: template "string" does not exist
Cause:
The specified template did not exist within the diskgroup.
Action:
Check the template name and diskgroup name.
ORA-15007: name is already used by an existing template
Cause:
A template with the same name already exists.
Action:
Select another template name, or drop the existing template.
ORA-15008: cannot drop system template
Cause:
The specified template was created by the system and must always exist for proper operation.
Action:
Select another template name.
ORA-15009: ASM disk "string" does not exist
Cause:
The specified ASM disk was not found.
Action:
Check the ASM disk name.
ORA-15010: name 'string' is already used by an existing ASM disk
Cause:
The specified name was already used in this diskgroup.
Action:
Specify a different ASM disk name.
ORA-15011: failure group "string" does not exist in diskgroup "string"
Cause:
The specified name did not match the failure group of any disks in the diskgroup. This usually indicates that the failure group name was specified incorrectly.
Action:
Check the failure group name.
ORA-15012: ASM file 'string' does not exist
Cause:
The ASM file was not found.
Action:
Check the ASM file name.
ORA-15013: diskgroup "string" is already mounted
Cause:
An ALTER DISKGROUP MOUNT command specified the name of a diskgroup which is already mounted by the current ASM instance.
Action:
Check the name of the diskgroup.
ORA-15014: path 'string' is not in the discovery set
Cause:
The operating system path specified was outside the set of disks that are discovered by the instance.
Action:
Specify a operating system path within the set of disks that are discovered based upon the ASM_DISKSTRING parameter. Alternatively, check the setting of the ASM_DISKSTRING parameter.
ORA-15015: Specified path 'string' conflicts with path 'string'
Cause:
The ASM instance previously discovered specified disk with an ASM library using a different path.
Action:
Use the discovery string of the ASM library to add the disk.
ORA-15016: inconsistent respecification of path 'string'
Cause:
The specified path was provided more than once with different properties.
Action:
Do not provide a path more than once. Alternatively, provide consistent properties.
ORA-15017: diskgroup "string" cannot be mounted
Cause:
The disk group could not be mounted by the ASM instance either of an IO error or due to other reasons explained in alert log or trace files.
Action:
Check for additional errors reported. Correct the error and retry the operation.
ORA-15018: diskgroup cannot be created
Cause:
The specified diskgroup could not be created.
Action:
ORA-15019: discovered duplicate path 'string' for 'string'
Cause:
The discovery encountered multiple paths to the same disk.
Action:
Check that the ASM_DISKSTRING parameter specifies only a single path for each disk.
ORA-15020: discovered duplicate ASM disk "string"
Cause:
The discovery encountered two disks claiming to be the same named ASM disk.
Action:
ORA-15021: parameter "string" is not valid in string instance
Cause:
The specified parameter was not supported when starting an instance of this type.
Action:
Delete the specified parameter from the INIT.ORA file.
ORA-15022: unable to load an Oracle ASM library
Cause:
An Oracle instance attempted to load an Oracle ASM library which could not be discovered.
Action:
Check other error messages to determine why Oracle is unable to retrieve the library path from the Oracle ASM instance.
ORA-15023: reached maximum allowable number of disks string
Cause:
An attempt was made to add another disk to a diskgroup which already contains the maximum number of disks allowed.
Action:
Consider dropping existing disks from the diskgroup before adding additional ones, or create a new diskgroup.
ORA-15024: discovered duplicately numbered ASM disk string
Cause:
ASM discovered two disks claiming to have the same ASM disk number in the same disk group.
Action:
ORA-15025: could not open disk "string"
Cause:
The specified disk could not be opened. If the database instance is running as an Operating System (OS) user different from that of the ASM instance, then the permissions on the database oracle binary may be incorrect.
Action:
Check the additional error messages, if any. If the database instance is running as an OS user different from that of the ASM instance, use the "srvctl" command to stop and restart the database to fix the permissions.
ORA-15026: disk 'string' is not an ASM disk
Cause:
The disk did not contain a valid ASM disk header.
Action:
Check to see if the data on the disk has been changed by some system administrator action.
ORA-15027: active use of diskgroup "string" precludes its dismount
Cause:
An ALTER DISKGROUP ... DISMOUNT command specified a diskgroup which had clients with open files in the diskgroup. Diskgroups cannot be dismounted until all open files in the diskgroup are closed.
Action:
Stop all clients that are using this diskgroup and retry the ALTER DISKGROUP ... DISMOUNT command. Query the V$ASM_CLIENT fixed view in an ASM instance or use ASMCMD LSOF to list active clients.
ORA-15028: ASM file 'string' not dropped; currently being accessed
Cause:
An attempt was made to drop an ASM file, but the file was being accessed by one or more clients and therefore could not be dropped.
Action:
Stop all clients that are using this file and retry the drop command. Query the V$ASM_CLIENT fixed view in an ASM instance or use ASMCMD LSOF to list active clients.
ORA-15029: disk 'string' is already mounted by this instance
Cause:
An attempt was made to add to a diskgroup a disk that was already mounted by the current instance as part of some (possibly other) diskgroup.
Action:
Specify a different disk in the command. Note that not even the FORCE option can be used to correct the situation until the diskgroup containing the disk becomes dismounted by this instance.
ORA-15030: diskgroup name "string" is in use by another diskgroup
Cause:
A CREATE DISKGROUP command specfied a diskgroup name that was already assigned to another diskgroup.
Action:
Select a different name for the diskgroup.
ORA-15031: disk specification 'string' matches no disks
Cause:
The device specification string to a CREATE DISKGROUP command did not match any devices which could be discovered.
Action:
Check the device specification string matches a disk on the system.
ORA-15032: not all alterations performed
Cause:
At least one ALTER DISKGROUP action failed.
Action:
Check the other messages issued along with this summary error.
ORA-15033: disk 'string' belongs to diskgroup "string"
Cause:
An attempt was made to ADD to a diskgroup (or REPLACE with) a disk that was already part of another diskgroup, or an attempt was made to DROP / OFFLINE / ONLINE / CHECK a disk that was not part of the specified diskgroup.
Action:
For ADD and REPLACE, check the path specifier for the disk. If it is certain that the disk is not in use by another diskgroup, the FORCE option may be used to override this check. For the other commands, check the name of the specified disk.
ORA-15034: disk 'string' does not require the FORCE option
Cause:
An attempt was made to add the disk to the diskgroup using the FORCE option. The disk was not found to be in use at the present time, so the FORCE option was not permitted.
Action:
Avoid gratuitous use of the FORCE option.
ORA-15035: no disks belong to diskgroup "string"
Cause:
An attempt was made to mount a diskgroup for which no member disks were discovered.
Action:
Specify a valid diskgroup name that contains disks.
ORA-15036: disk 'string' is truncated
Cause:
The size of the disk, as reported by the operating system, was smaller than the size of the disk as recorded in the disk header block on the disk.
Action:
Check if the system configuration has changed.
ORA-15037: disk 'string' is smaller than mimimum of string MBs
Cause:
The size of the disk, as reported by the operating system, was too small to allow the disk to become part of the diskgroup.
Action:
Check if the system configuration is correct.
ORA-15038: disk 'string' mismatch on 'string' with target disk group [string] [string]
Cause:
An attempt was made to mount into a disk group a disk whose recorded allocation unit size, metadata block size, physical sector size, or creation time stamp was inconsistent with the other disk group members.
Action:
Check if the system configuration has changed. Verify disk discovery string.
ORA-15039: diskgroup not dropped
Cause:
An attempt to drop a diskgroup failed.
Action:
See the associated messages for details about why the drop was not successful.
ORA-15040: diskgroup is incomplete
Cause:
Some of the disks comprising a diskgroup were not present.
Action:
Check the hardware to ensure that all disks are functional. Also check that the setting of the ASM_DISKSTRING initialization parameter has not changed. Alternatively, for normal or high redundancy diskgroups, use MOUNT FORCE to offline missing disks as part of mounting the diskgroup.
ORA-15041: diskgroup "string" space exhausted
Cause:
At least one disk in the diskgroup is out of space.
Action:
If all disks are evenly balanced, add more disks to the diskgroup,
ORA-15042: ASM disk "string" is missing from group number "string"
Cause:
The specified disk, which is a necessary part of a diskgroup, could not be found on the system.
Action:
Check the hardware configuration.
ORA-15043: ASM disk "string" is not a diskgroup member
Cause:
The specified disk has been removed from the diskgroup, but a disk matching its name was found.
Action:
ORA-15044: ASM disk 'string' is incorrectly named
Cause:
Either the specified disk had its contents changed such that it no longer contained an ASM disk name in its header that matches the diskgroup information or its FAILGROUP information may have become inconsistent.
Action:
Drop the disk from the diskgroup.
ORA-15045: ASM file name 'string' is not in reference form
Cause:
The ASM file name was not in a form that can be used to reference an existing file because a file/incarnation number or an alias name was not present or a template name was included.
Action:
Correct the specified ASM file name.
ORA-15046: ASM file name 'string' is not in single-file creation form
Cause:
The ASM file name was not in a form that can be used to create an single file because a file/incarnation number was present.
Action:
ORA-15047: ASM file name 'string' is not in multiple-file creation form
Cause:
The ASM file name was not in a form that can be used to create multiple files because either a fully-qualified file name or an alias name was present.
Action:
ORA-15048: ASM internal files cannot be deleted
Cause:
An attempt was made to delete a metadata file used by ASM to manage the diskgroup.
Action:
Check the specified ASM file name.
ORA-15049: diskgroup "string" contains string error(s)
Cause:
Errors were discovered by the ALTER DISKGROUP CHECK command.
Action:
See the alert log for details of the errors.
ORA-15050: disk "string" contains string error(s)
Cause:
Errors were discovered by the ALTER DISKGROUP CHECK DISK command.
Action:
ORA-15051: file 'string' contains string error(s)
Cause:
Errors were discovered by the ALTER DISKGROUP CHECK FILE command.
Action:
ORA-15052: ASM file name 'string' is not in diskgroup "string"
Cause:
The ASM file name did not contain a diskgroup name that specified the correct diskgroup as implied by the other arguments to the command.
Action:
Correct the specified ASM file name or diskgroup name.
ORA-15053: diskgroup "string" contains existing files
Cause:
An attempt was made to drop a diskgroup that still contains existing files.
Action:
Specify the INCLUDING CONTENTS option to drop the diskgroup and all of its existing files.
ORA-15054: disk "string" does not exist in diskgroup "string"
Cause:
An attempt was made to alter a disk that is not part of the specified diskgroup.
Action:
Check the name of the specified disk and the specified diskgroup.
ORA-15055: unable to connect to ASM instance
Cause:
The RDBMS instance was unable to connect to the required ASM instance when accessing a disk group.
Action:
Check the additional error messages. May need to configure correct ASM sid or make sure the RDBMS instance has OS privileges for ASM SYSDBA.
ORA-15056: additional error message
Cause:
An operating system error occured.
Action:
Correct the operating system error and retry the operation.
ORA-15057: specified size of string MB is larger than actual size of string MB
Cause:
A disk size expression exceeded the amount of storage actually available, as reported by the operating system.
Action:
Specify a valid size.
ORA-15058: disk 'string' belongs to an incompatible diskgroup
Cause:
An attempt was made to ADD to a diskgroup a disk which was already part of another diskgroup. The other diskgroup was written by a more recent software release.
Action:
Check the path specifier for the disk. If it is certain that the disk is not in use by another diskgroup, the FORCE option may be used to override this check.
ORA-15059: invalid device type for ASM disk
Cause:
The device type of the discovered disk was not valid for use as an ASM disk.
Action:
Check the file path and retry or exclude it from the discovery set. See the accompanying operating system error for additional information.
ORA-15060: template "string" does not exist
Cause:
A command specified a template name, either directly or as part of an ASM file name, which did not exist.
Action:
Check the template specifier in the command.
ORA-15061: ASM operation not supported [string]
Cause:
An ASM operation was attempted that is invalid or not supported by this version of the ASM instance.
Action:
This is an internal error code that is used for maintaining compatibility between software versions and should never be visible to the user; contact Oracle support Services.
ORA-15062: ASM disk is globally closed
Cause:
The disk to which the I/O request was issued has gone offline or has been globally closed by the background process. Check other messages in the trace files for more information.
Action:
Bring the disk online for I/Os to get through.
ORA-15063: ASM discovered an insufficient number of disks for diskgroup "string"
Cause:
ASM was unable to find a sufficient number of disks belonging to the diskgroup to continue the operation.
Action:
Check that the disks in the diskgroup are present and functioning, that the owner of the ORACLE binary has read/write permission to the disks, and that the ASM_DISKSTRING initialization parameter has been set correctly. Verify that ASM discovers the appropriate disks by querying V$ASM_DISK from the ASM instance.
ORA-15064: communication failure with ASM instance
Cause:
There was a failure to communicate with the ASM instance, most likely because the connection went down.
Action:
Check the accompanying error messages for more information on the reason for the failure. Note that database instances will always return this error when the ASM instance is terminated abnormally.
ORA-15065: hash collision for diskgroup names 'string' and 'string'
Cause:
There was a collision in the group name used for the diskgroup. The diskgroup(s) cannot be mounted using colliding names.
Action:
Use a different diskgroup name and also report to Oracle Support Services the two diskgroup names which collided.
ORA-15066: offlining disk "string" in group "string" may result in a data loss
Cause:
Following I/O failures, the disks holding all copies of a data block were attempted to be taken offline.
Action:
Check the accompanying error messages for more information on the reason for the disk I/O failures.
ORA-15067: command or option incompatible with diskgroup redundancy
Cause:
An attempt was made to use a feature which is not permitted by the diskgroup's redundancy policy. Common examples are forcibly dropping a disk from an EXTERNAL REDUNDANCY diskgroup, using the FAILGROUP clauses with an EXTERNAL REDUNDANCY diskgroup, or using invalid template attributes.
Action:
Omit the option from the command.
ORA-15068: maximum number of diskgroups string already mounted
Cause:
An attempt was made to mount more diskgroups than the instance is capable of mounting at one time.
Action:
Dismount a mounted diskgroup and retry the command.
ORA-15069: ASM file 'string' not accessible; timed out waiting for lock
Cause:
An attempt was made to access an ASM file, but the file is currently being created, resized, or deleted and therefore cannot be accessed.
Action:
No action required, or try again later, after the create or resize has completed.
ORA-15070: maximum number of files string exceeded in diskgroup "string"
Cause:
The diskgroup ran out of space.
Action:
Delete some existing ASM files or create files in a new diskgroup.
ORA-15071: ASM disk "string" is already being dropped
Cause:
An attempt was made to drop or replace a disk that was already in the process of being dropped from the diskgroup. Alternatively, an attempt was made to forcibly drop a disk from a diskgroup using the FORCE option that was already being forcibly dropped from the diskgroup.
Action:
Check the ASM disk name and FORCE option as specified in the command.
ORA-15072: command requires at least string regular failure groups, discovered only string
Cause:
An attempt was made to create either a normal redundancy diskgroup for which fewer than two regular failure groups were both specified and discovered, or a high redundancy diskgroup for which fewer than three regular failure groups were both specified and discovered, or an external redundancy diskgroup for which only quorum disks were both specified and discovered.
Action:
Check the that the command does specify the required number of failure groups, and that all of the specified disks are discovered by ASM. A query of the V$ASM_DISK fixed view will show which disks are discovered by ASM. Note that a quorum failure group will not be used as a regular failure group. An external redundancy diskgroup requires at least one regular disk.
ORA-15073: diskgroup string is mounted by another ASM instance
Cause:
An attempt was made to drop a diskgroup that is still mounted somewhere in the cluster by another instance.
Action:
dismount the diskgroup from all nodes except the one performing the drop diskgroup command.
ORA-15074: diskgroup string requires rebalance completion
Cause:
An attempt was made to repeatedly add or drop disks from a diskgroup. ASM could not perform the operation given the current state of the diskgroup.
Action:
Manually invoke the ALTER DISKGROUP REBALANCE command and allow the rebalance to run to completion. Alternatively, invoke the ALTER DISKGROUP UNDROP DISKS command and allow the rebalance to run to completion. After the rebalance has completed, retry the operation.
ORA-15075: disk string is not visible on instance number string
Cause:
An ALTER DISKGROUP ADD DISK command specified a disk that could not be discovered.
Action:
Check operating system permissions for the device and the storage subsystem configuration on the specified node.
ORA-15076: Emulating I/O errors on the OSM disk
Cause:
The disk to which the I/O request was issued is in an error emulation mode.
Action:
ORA-15077: could not locate ASM instance serving a required diskgroup
Cause:
The instance failed to perform the specified operation because it could not locate a required ASM instance.
Action:
If you want to start a database instance, start an ASM instance and mount the required diskgroup. If you want to start an ASM instance, relink the ORACLE binary with ASM_ON or explicitly set INSTANCE_TYPE initialization parameter to ASM.
ORA-15078: ASM diskgroup was forcibly dismounted
Cause:
The diskgroup to which the I/O request was issued was forcibly dismounted (with the ALTER DISKGROUP DISMOUNT FORCE command) so that it could not be accessed.
Action:
Mount the diskgroup to allow access again.
ORA-15079: ASM file is closed
Cause:
The file to which the I/O request was issued was closed. This could have been a consequence of the diskgroup being dismounted.
Action:
Make sure the diskgroup is mounted and the file is open.
ORA-15080: synchronous I/O operation failed to string block string of disk string in disk group string
Cause:
A synchronous I/O operation invoked on a disk has failed.
Action:
Make sure that all of the disks are operational.
ORA-15081: failed to submit an I/O operation to a disk
Cause:
A submission of an I/O operation to a disk has failed.
Action:
Make sure that all the disks are operational.
ORA-15082: ASM failed to communicate with client
Cause:
There was a failure or time out when ASM tried to communicate with a connected RDBMS or Oracle ASM Dynamic Volume Manager (Oracle ADVM) client.
Action:
Check the accompanying error messages and alert logs for more information on the reason for the failure. Check system specific logs (/var/log/messages on Linux, Event Log on Windows) for Oracle ADVM messages.
ORA-15083: failed to communicate with ASMB background process
Cause:
A database instance failed to communicate with its ASMB background process when attempting to access an ASM file.
Action:
Check the alert log for more information on the reason for the failure.
ORA-15084: ASM disk "string" is offline and cannot be dropped.
Cause:
An attempt was made to drop a disk that is offline.
Action:
Check the ASM disk name as specified in the command; or, if needed, use the DROP DISK FORCE option.
ORA-15085: disk "string" has inconsistent sector size (expected string, actual string) with disk group "string"
Cause:
An attempt to mount a disk group failed because a disk reported inconsistent sector size value.
Action:
Use disks with sector size consistent with disk group sector size, or make sure the operating system can accurately report the disk sector size.
ORA-15086: Diskgroup sector size must be specified.
Cause:
The _disk_sector_size_override parameter was used but the sector disk value was not specified in the command.
Action:
Specify the sector size value, or do not set (or do not set to TRUE) the _disk_sector_size_override parameter.
ORA-15087: disk 'string' is formatted as an ext2/ext3 or OCFS2 file system.
Cause:
A signature was found on the specified disk indicating that it is in use by an existing ext2/ext3 or OCFS2 file system.
Action:
Adjust discovery string and device permissions to exclude previously formatted disks from discovery.
ORA-15088: diskgroup creation incomplete
Cause:
A previous failure during diskgroup creation left the diskgroup in an inconsistent state.
Action:
Issue DROP DISKGROUP ... FORCE INCLUDING CONTENTS to clean up the failed creation, then re-create the diskgroup.
ORA-15090: handle string is not a valid descriptor
Cause:
The file handle was not valid in this session.
Action:
Submit a handle obtained from a successful call to DBMS_DISKGROUP.OPEN().
ORA-15091: operation incompatible with open handle in this session
Cause:
The current session contained an open handle from the DBMS_DISKGROUP PL/SQL package which precluded performing the command.
Action:
Execute the command in a different session.
ORA-15092: I/O request size string is not a multiple of logical block size string
Cause:
The length of the request was not a multiple of logical block size.
Action:
ORA-15093: buffer only contains string bytes, I/O requested is string bytes
Cause:
The buffer supplied for write was too small to satisfy the request.
Action:
ORA-15094: attempted to write to file opened in read only mode
Cause:
The file handle passed to DBMS_DISKGROUP.WRITE() did not have write privileges.
Action:
Obtain a file handle in read-write mode and retry the write operation.
ORA-15095: reached maximum ASM file size (string GB) for this disk group\n
Cause:
An ASM file creation or file resize operation exceeded the maximum file size permitted by ASM for this disk group.
Action:
Use smaller files. Alternatively, set the disk group attribute compatible.rdbms >= 11.1 if not set already.
ORA-15096: lost disk write detected
Cause:
A failure either by disk hardware or disk software caused a disk write to to be lost, even though ASM received acknowledgement that the write completed. Alternatively, a clustering hardware failure or a clustering software failure resulted in an ASM instance believing that another ASM instance had crashed, when in fact it was still active.
Action:
The disk group is corrupt and cannot be recovered. The disk group must be recreated, and its contents restored from backups.
ORA-15097: cannot SHUTDOWN ASM instance with connected client (process string)
Cause:
A SHUTDOWN command was issued to an ASM instance that had one or more connected clients.
Action:
Stop all clients that are using this ASM instance and retry the SHUTDOWN command. Alternatively, use the SHUTDOWN ABORT command. Note that issuing the SHUTDOWN ABORT command to an ASM instance results in abormal termination of all RDBMS instances connected to that ASM instance. One of the active clients has been listed in the error message. Query the V$ASM_CLIENT fixed view in an ASM instance or use ASMCMD LSOF to list all active clients.
ORA-15098: file type not recognized by ASM instance
Cause:
An attempt was made by DB instance to create a file for a file type that is not recognized by current version of ASM instance.
Action:
Upgrade ASM to higher version that recognizes this file type.
ORA-15099: disk 'string' is larger than maximum size of string MBs
Cause:
The specified size of the disk was too big to allow the disk to become part of the diskgroup.
Action:
Specify a smaller disk size than the maximum allowed size.
ORA-15100: invalid or missing diskgroup name
Cause:
The command did not specify a valid diskgroup name.
Action:
Specify a valid diskgroup name.
ORA-15101: no action specified
Cause:
The ALTER DISKGROUP command did not specify any alterations.
Action:
Specify at least one operation clause.
ORA-15102: invalid POWER expression
Cause:
The syntax of the POWER expression was invalid.
Action:
Specify a valid POWER expression.
ORA-15103: conflicting or duplicate REPAIR options
Cause:
The command specified conflicting or duplicate REPAIR keywords.
Action:
Specify only one REPAIR action.
ORA-15104: conflicting CONTENTS options
Cause:
The command specified conflicting or duplicate INCLUDING CONTENTS or EXCLUDING CONTENTS options.
Action:
Specify only one option.
ORA-15105: missing or invalid FAILGROUP name
Cause:
The command did not specify a valid failure group name.
Action:
Specify a valid failure group name.
ORA-15106: missing or invalid operating system disk locator string
Cause:
The command did not specify a valid operating system path for the device as a string.
Action:
Specify a valid operating system path for the device.
ORA-15107: missing or invalid ASM disk name
Cause:
The command did not specify a valid ASM disk name identifier.
Action:
Specify a valid ASM disk name identifier.
ORA-15108: missing or invalid template name
Cause:
The command did not specify a valid template name identifier.
Action:
Specify a valid template name identifier.
ORA-15109: conflicting protection attributes specified
Cause:
The command contained an invalid combination of the UNPROTECTED, MIRROR, or PARITY keywords.
Action:
Specify only one keyword.
ORA-15110: no diskgroups mounted
Cause:
No diskgroups were specified in the ASM_DISKGROUPS parameter, so instance startup or the ALTER DISKGROUP ALL MOUNT command did not mount any diskgroups.
Action:
Specify valid diskgroups in the ASM_DISKGROUPS parameter or ignore the error.
ORA-15111: conflicting or duplicate STRIPE options
Cause:
The command contained both a FINE and COARSE keyword, or contained the FINE keyword more than once, or contained the COARSE keyword more than once.
Action:
ORA-15112: no diskgroups currently mounted
Cause:
An ALTER DISKGROUP ALL command did not find any mounted diskgroups upon which to operate. Either instance shutdown or an ALTER DISKGROUP ALL DISMOUNT command did not dismount any diskgroups, or an ALTER DISKGROUP ALL UNDROP DISKS command did not undrop any disks.
Action:
Mount the diskgroups on which you wish to operate or ignore the error.
ORA-15113: alias name 'string' refers to a directory
Cause:
The name specified referred to a directory in the alias directory and not a valid alias entry.
Action:
Check the alias name and retry.
ORA-15114: missing or invalid ASM file name
Cause:
The command did not specify a valid ASM file name identifier.
Action:
Specify a valid ASM file name identifier.
ORA-15115: missing or invalid ASM disk size specifier
Cause:
The command did not specify a valid ASM disk size.
Action:
Specify a valid ASM disk size.
ORA-15116: invalid combination of ALTER DISKGROUP options
Cause:
The ALTER DISKGROUP options may not be combined in this manner.
Action:
Issue separate ALTER DISKGROUP commands to accomplish the desired action.
ORA-15117: command only operates on one diskgroup
Cause:
An ALTER DISKGROUP, CREATE DISKGROUP, or DROP DISKGROUP command specified a list of diskgroups or the keyword ALL in a context where only a single diskgroup was permitted.
Action:
Issue separate ALTER DISKGROUP, CREATE DISKGROUP, or DROP DISKGROUP commands to accomplish the desired action.
ORA-15118: ASM diskgroup 'string' was forcibly dismounted.
Cause:
Action:
ORA-15119: too many disk groups (string); maximum allowed string
Cause:
An attempt was made to mount more than the maximum allowed number of disk groups.
Action:
Do not attempt to mount more than the maximum allowed number of disk groups. Check ASM instance parameters.
ORA-15120: ASM file name 'string' does not begin with the ASM prefix character
Cause:
A file name was specified to ASM which did not begin with the ASM prefix character (currently '+'). ASM uses the prefix to determine that a file specification is in fact an ASM file.
Action:
Correct the file name specification.
ORA-15121: ASM file name 'string' contains an invalid diskgroup name
Cause:
A file name was specified that did not contain a valid diskgroup name. The diskgroup name follows immediately after the ASM prefix character. It must start with an alphabetic character, and consist of up to 30 characters which are alphabetic, numeric, or the characters '$' and '_'.
Action:
ORA-15122: ASM file name 'string' contains an invalid file number
Cause:
A numeric file name was specified which did not contain a valid ASM file number. The ASM file number follows immediately after the diskgroup name. It must be preceeded by a '.' character, and contain only numeric characters.
Action:
ORA-15123: ASM file name 'string' contains an invalid incarnation number
Cause:
A numeric file name was specified which did not contain a valid ASM incarnation number. The ASM incarnation number follows immediately after the ASM file number. It must be preceeded by a '.' character, and contain only numeric characters.
Action:
ORA-15124: ASM file name 'string' contains an invalid alias name
Cause:
A file name was specified which did not contain a valid ASM alias name. The ASM alias name, if present, follows immediately after the diskgroup name, in place of the ASM file number. It must be preceeded by a slash, start with an alphabetic character, and consist of up to 48 characters which are alphabetic, numeric, or the characters '$', '_', '-', or '#". A space can separate two parts of an alias name.
Action:
ORA-15125: ASM file name 'string' contains an invalid template name
Cause:
A file name was specified to ASM which did not contain a valid template name. The template name, if present, follows immediately after the ASM incarnation number or the ASM alias name, if such is used in place of the ASM file number. It must be enclosed in parenthesis, start with an alphabetic character, and consist of up to 30 characters which are alphabetic, numeric, or the characters '$' and '_'.
Action:
ORA-15126: component within ASM file name 'string' exceeds maximum length
Cause:
The maximum identifier length of 48 characters was exceeded for the diskgroup name, template name, or alias name field within the ASM file name.
Action:
ORA-15127: ASM file name 'string' cannot use templates
Cause:
A fully qualified ASM file name was specified. Such a specification does not permit the inclusion of a template name in the ASM file name.
Action:
ORA-15128: ASM file name 'string' exceeds maximum length string
Cause:
The maximum ASM file name length of 256 characters was exceeded for the combination of diskgroup name, file number, template name, alias name plus punctuation within the ASM file name.
Action:
ORA-15129: entry 'string' does not refer to a valid directory
Cause:
The entry indicated did not refer to a directory. Attempt was made to access the contents of this directory.
Action:
Correct the error and try again.
ORA-15130: diskgroup "string" is being dismounted
Cause:
The diskgroup is being dismounted by request or because an I/O error was encountered that could not be handled by taking the disks offline. A disk cannot be offlined whenever doing so could result in all copies of a redundant extent being unavailable.
Action:
Repair the hardware problem and re-mount the diskgroup. Refer to the alert log to determine which disks have failed.
ORA-15131: block string of file string in diskgroup string could not be read
Cause:
A block could not be read because the disk containing the block is either offline or an I/O error occured while reading the block. If this is mirrored file, then all disks that contain a copy of the block are either offline or received errors.
Action:
Repair the affected disk and bring it back online. Refer to accompanying error messages to determine which disk has failed.
ORA-15132: block string of file string in diskgroup string could not be written
Cause:
A block could not be written because the disk containing the block is either offline or an I/O error occured while writing the block. If this is mirrored file, then insufficient disks which contain a copy of the block are either offline or received errors.
Action:
ORA-15133: instance recovery required for diskgroup string
Cause:
An instance in the cluster crashed making instance recovery necessary.
Action:
None. This error should not normally be seen by an ASM client. ASM will trap this error and retry the operation after doing instance recovery automatically.
ORA-15134: mirror resilvering not supported for string
Cause:
The specified device requires oracle to take mirror resilvering responsiblity. ASM does not resilver logical volume manager (lvm) based mirrors.
Action:
Disable lvm-based mirroring or set the parameter _asm_allow_lvm_resilvering to TRUE. One might experience performance degradation when lvm-based resilvering is enabled with ASM.
ORA-15135: The string cluster is not in rolling patch state. The patch level [string] of instance string is not the same as the current cluster patch level [string].
Cause:
During startup, this instance found one or more other instances running at a different patch level, and the cluster was not in rolling patch state. Startup of this instance failed.
Action:
The patch level of this instance differs from the cluster patch level. If the intention is to patch the cluster using the rolling option, then set the cluster in rolling patch state using the 'crsctl start rollingpatch' command from an active node, and restart Oracle Clusterware on this node. If the intention is to patch the cluster in a non-rolling manner, and the patch has been applied on the local node, then stop all of the active nodes in the cluster that have a patch level that does not match the patch level of the current node. Use the 'crsctl query crs softwarepatch host' command to retrieve the configured patch level of a node. If the intention is to patch the cluster in a non-rolling manner, and the patch has not been applied on the local node, then apply the requisite patch, and restart Oracle Clusterware on this node. Patches applied on a node can be obtained by issuing the the 'crsctl query crs releasepatch' command.
ORA-15136: cluster in rolling patch from patch level [string] to [string]
Cause:
The current patch level of the instance was incompatible with the rolling patch operation of the cluster.
Action:
The patch level of the new member instance must be one of the two patch levels involved in the rolling patch operation.
ORA-15137: The string cluster is in rolling patch state.
Cause:
The cluster was already in the middle of rolling patch.
Action:
Rolling patch needs to be stopped before attempting to start again.
ORA-15138: cluster rolling patch incomplete
Cause:
The cluster was still performing rolling patch.
Action:
Ensure that all of the instances in the cluster are patched before retrying the command.
ORA-15139: patch level of string instances differ in cluster
Cause:
Not all of the instances in the cluster had the same set of patches.
Action:
Ensure that all of the instances in the cluster have the same patches before retrying the command. Find the configured patch level on a node using the 'crsctl query crs softwarepatch' command.
ORA-15140: rolling patch prevented by string
Cause:
One or more instances were blocking the rolling patch.
Action:
Terminate or wait until the reported operation is complete before attempting the rolling patch to the cluster.
ORA-15141: The string cluster is not in either rolling upgrade or rolling patch state.
Cause:
The ALTER SYSTEM STOP ROLLING MIGRATION or ALTER SYSTEM STOP ROLLING PATCH command was executed when the cluster was not in either the rolling upgrade or rolling patch state.
Action:
The system has to be set to rolling upgrade or rolling patch state before attempting to execute the command.
ORA-15142: either MIGRATION or PATCH keyword expected
Cause:
The keyword was missing.
Action:
Supply the missing keyword.
ORA-15143: either APPLY or ROLLBACK keyword expected
Cause:
Action:
ORA-15144: disk 'string' is about to fail
Cause:
An attempt was made to ADD (or REPLACE) a failing disk to a disk group.
Action:
Specify a different disk in the command. Note that not even the FORCE option can be used to add the disk to the disk group.
ORA-15145: ASM disk 'string' is online and cannot be replaced.
Cause:
The REPLACE DISK operation specified a disk which is online.
Action:
Check to confirm that the ASM disk is offline. Online disks can be replaced while maintaining redundancy by issuing ADD and DROP disk commands in a single SQL statement.
ORA-15146: Rolling migration or patching operation failed
Cause:
Operation failed due to temporary issue.
Action:
Retry the command.
ORA-15147: failed to start the instance
Cause:
The instance could not be started during rolling upgrade from ASM instance versions prior to 12.1.0.0.0
Action:
Complete the rolling upgrade process and start the instance.
ORA-15148: Too many CRS users are created.
Cause:
The number of CRS users has reached its limit of 999. The situation is unexpected.
Action:
Check to see why so many CRS users are created.
ORA-15149: another ASM instance found running on the host
Cause:
Another ASM instance found on the host. Only one ASM instance is supported on a host.
Action:
Shut down the other instance before starting this ASM instance.
ORA-15150: instance lock mode 'string' conflicts with other ASM instance(s)
Cause:
Some other ASM instance used the lock name space in a conflicting mode.
Action:
Shut down the other instance or start up in compatible mode. Alternatively, set the DB_UNIQUE_NAME initialization parameter to avoid the conflict.
ORA-15151: missing or invalid version number for rolling migration
Cause:
The command did not specify a valid version number.
Action:
Correct the version number in the command. It should be of the form v#.#.#.#.# or other forms with fewer numbers delimited by a period. The version number must be different from the current software version of the instance.
ORA-15152: The string cluster is in rolling upgrade state.
Cause:
The cluster was already in the middle of rolling upgrade.
Action:
Rolling upgrade needs to be stopped before attempting to start again.
ORA-15153: The string cluster is not in rolling upgrade state. The version [string] of instance string is not the same as the current cluster version [string].
Cause:
During startup, this instance found one or more other instances running at a different version, and the cluster was not in rolling upgrade state. Startup of this instance failed.
Action:
The version of this instance differs from the cluster version. If the intention is to upgrade the cluster using the rolling option, then set the cluster in rolling upgrade state using the 'crsctl start rollingupgrade' command from an active node, and restart Oracle Clusterware on this node. If the intention is to upgrade the cluster in a non-rolling manner, and the local node has already been upgraded, then stop all of the active nodes in the cluster that have an older version than the current node. Use the 'crsctl query crs softwareversion host' command to retrieve the configured version of a node. If the intention is to upgrade the cluster in a non-rolling manner, and the local node has not been upgraded yet, then upgrade the node by running the rootupgrade.sh script.
ORA-15154: cluster rolling upgrade incomplete
Cause:
The cluster was still performing rolling upgrade.
Action:
Ensure that all the instances in the cluster are upgraded before retrying the command.
ORA-15155: version incompatible with the cluster
Cause:
The current software version of the instance was incompatible with the other members of the cluster.
Action:
Make sure that all the members of the cluster are at the same version. If you are attempting to perform rolling upgrade, execute ALTER SYSTEM START ROLLING command. Ensure that the version being upgraded to is compatible with the existing version of the cluster.
ORA-15156: cluster in rolling upgrade from version [string] to [string]
Cause:
The current software version of the instance was incompatible with the rolling upgrade operation of the cluster.
Action:
The version number of new member instance must be one of the two versions involved in the rolling upgrade.
ORA-15157: rolling migration is not allowed
Cause:
The cluster was not capable of handling ASM rolling migration.
Action:
The Oracle Cluster Services is using vendor clusterware. Oracle cannot perform rolling upgrade or downgrade using vendor cluster ware. Restart ASM instances using Oracle cluster ware and retry the operation.
ORA-15158: rolling upgrade prevented by string
Cause:
One or more instances were blocking the rolling upgrade.
Action:
Terminate or wait until the reported operation is complete before attempting the rolling upgrade to the cluster.
ORA-15160: rolling migration internal fatal error in module string,string
Cause:
Rolling migration experienced a fatal error.
Action:
Please contact Oracle support services.
ORA-15161: invalid SYS_CLUSTER_PROPERTIES parameter
Cause:
The parameter passed in for SYS_CLUSTER_PROPERTIES is invalid
Action:
Pass in the correct parameter, refer to user documentation for a list of allowed parameter values.
ORA-15162: cluster in rolling downgrade
Cause:
The cluster was already in the middle of rolling downgrade.
Action:
Rolling downgrade needs to be stopped before attempting to start again.
ORA-15163: cluster is not in the rolling downgrade to string
Cause:
The cluster was not in the rolling downgrade.
Action:
Start the rolling downgrade using the ALTER SYSTEM START ROLLING MIGRATION command from another ASM instance and restart this instance.
ORA-15164: cluster rolling downgrade incomplete
Cause:
The cluster was still performing rolling downgrade.
Action:
Ensure that all the instances in the cluster are downgraded before retrying the command.
ORA-15166: cluster in rolling downgrade from version [string] to [string]
Cause:
The current software version of the instance was incompatible with the rolling downgrade operation of the cluster.
Action:
The version number of new member instance must be one of the two versions involved in the rolling downgrade.
ORA-15168: rolling downgrade prevented by string
Cause:
One or more instances were blocking the rolling downgrade.
Action:
Terminate or wait until the reported operation is complete before attempting the rolling downgrade to the cluster.
ORA-15169: destination 'string' is a subdirectory of 'string'
Cause:
Attempt to rename directory failed because the new directory name was a subdirectory of the original directory.
Action:
Correct the path of the destination and try again.
ORA-15170: cannot add entry 'string' in directory 'string'
Cause:
Other errors prevented directory/alias creation.
Action:
Correct the errors and try again.
ORA-15171: invalid syntax in the alias path after 'string'
Cause:
An invalid alias/directory name syntax was specified.
Action:
Correct the alias path and try again.
ORA-15173: entry 'string' does not exist in directory 'string'
Cause:
The specified alias did not exist in the given directory.
Action:
ORA-15174: unable to create alias name
Cause:
An attempt to create an alias name for an ASM file failed.
Action:
Check the alert logs and trace files of the Oracle ASM instance for more information on the failure, as well as checking the accompanying error messages.
ORA-15175: cannot create alias for diskgroup metadata file 'string'
Cause:
An attempt was made to create an alias for a diskgroup metadata file.
Action:
ORA-15176: file 'string' already has an alias associated with it
Cause:
An attempt was made to create an alias for a file that already had an existing alias.
Action:
Correct the file name and try again or drop existing alias.
ORA-15177: cannot operate on system aliases
Cause:
An attempt was made to modify a system alias.
Action:
Correct the alias name and try again.
ORA-15178: directory 'string' is not empty; cannot drop this directory
Cause:
An attempt was made to drop a directory that contained valid entries.
Action:
Correct the directory path or specify the FORCE option to drop a directory that is not empty.
ORA-15179: missing or invalid alias name
Cause:
The command did not specify a valid alias identifier.
Action:
Specify a valid alias identifier.
ORA-15180: could not open dynamic library string, error [string]
Cause:
The library was not accessible
Action:
Correct the permissions of the library and try again.
ORA-15181: symbol [string] not found in library string, error [string]
Cause:
An error was encountered while loading the specified ASMLIB symbol.
Action:
Correct the error reported and try again.
ORA-15182: ASMLIB [string] version mismatch, ORACLE version [string]
Cause:
The ASMLIB version reported is not supported by the ORACLE binary.
Action:
Install the correct library and try again.
ORA-15183: ASMLIB initialization error [string]
Cause:
Unable to initialize the ASMLIB in ORACLE.
Action:
Check the configuration of ASMLIB or deinstall ASMLIB if not used.
ORA-15184: ASMLIB error could not be determined [string] [string]
Cause:
An error was encountered which cannot be diagnosed further.
Action:
Contact ASMLIB libary vendor for support.
ORA-15185: could not close dynamic library string, error [string]
Cause:
Could not close the dynamic library.
Action:
ORA-15186: ASMLIB error function = [string], error = [string], mesg = [string]
Cause:
An error occured during a call to function listed in the error.
Action:
The detailed message associated with the error is listed along with the error. Correct the error and try again or contact ASMLIB library vendor for support.
ORA-15187: Incompatible RDBMS operation [string] pushed to storage
Cause:
RDBMS to storage version mismatched with incompatibility operation.
Action:
Upgrade RDBMS to match storage version.
ORA-15188: process terminated due to an ASMLIB error
Cause:
A process was terminated as a result of an ASMLIB error.
Action:
See the alert log for more information. Reconnect to the database or the ASM instance. If the process termination resulted in instance termination, restart the instance.
ORA-15192: invalid ASM disk header [string] [string] [string] [string] [string]
Cause:
ASM encountered an invalid disk header.
Action:
ORA-15196: invalid ASM block header [string:string] [string] [string] [string] [string != string]
Cause:
ASM encountered an invalid metadata block.
Action:
ORA-15197: suppressing string additional ASM messages
Cause:
The ASM command generated so many erorrs that this summary message was reported in place of many individual messages.
Action:
If the command contained multiple actions, try separating each action into its own command and executing each command by itself. Otherwise, try not to generate so many errors.
ORA-15198: operation string is not yet available
Cause:
An unimplemented operation was attempted.
Action:
Consider upgrading to later releases as they become available.
ORA-15200: initialization parameter string (string) is not a power of two
Cause:
The value specified for this initialization parameter was not a power of two.
Action:
Correct the initialization parameter value and restart the instance.
ORA-15201: disk string contains a valid RDBMS file or foreign volume
Cause:
A disk specified in a CREATE DISKGROUP or ALTER DISKGROUP ... ADD DISK command appeared to contain a file from an existing database or a foreign volume. By default, as a safeguard against damaging an existing database or foreign volume, ASM does not allow a disk group to be created using this disk.
Action:
Check that the ASM disk specification is correct. Otherwise, when storage from a defunct database or unmounted foreign volume is reused as part of an ASM disk group, specify the FORCE option to the ASM SQL command. See the alert log for more information.
ORA-15202: cannot create additional ASM internal change segment
Cause:
The mount of a diskgroup by an additional instance in a RAC cluster required more space for internal use by ASM than was available in the diskgroup.
Action:
Delete unused files from the diskgroup or add additional disks to the diskgroup and retry the operation.
ORA-15203: diskgroup string contains disks from an incompatible version of ASM
Cause:
Diskgroup was created by an ASM instance with a higher compatibility setting.
Action:
Use an ASM instance with the appropriate software version to mount the diskgroup.
ORA-15204: database version string is incompatible with diskgroup string
Cause:
The COMPATIBLE parameter for the RDBMS instance is less than the value of the compatible.rdbms attribute for the disk group.
Action:
Update the COMPATIBLE parameter for RDBMS instance to a version greater than or equal to compatible.rdbms version. The compatible attributes for diskgroups cannot be lowered.
ORA-15205: requested mirror side unavailable
Cause:
The requested mirror side of a block is either unallocated or allocated on a disk that has been dropped from the diskgroup.
Action:
Resubmit the request or try another mirror side.
ORA-15206: duplicate diskgroup string specified
Cause:
A command specified the same diskgroup twice.
Action:
Specify each diskgroup only once.
ORA-15210: conflicting or duplicate PERMISSION options
Cause:
The PERMISSION clause contained the USER, GROUP, or OTHER keyword more than once.
Action:
Specify each keyword, at most, once.
ORA-15211: conflicting or duplicate OWNERSHIP options
Cause:
The OWNERSHIP clause contained either the OWNER or the GROUP keyword more than once.
Action:
ORA-15212: missing or invalid OWNER or GROUP name
Cause:
The command did not specify a valid name for either the OWNER or the GROUP keyword.
Action:
Specify a valid name for either the OWNER or the GROUP keyword.
ORA-15213: command operates on only one attribute
Cause:
More than one disk group attribute was specified in the ALTER DISKGROUP statement.
Action:
Specify only one disk group attribute per ALTER DISKGROUP statement.
ORA-15214: missing or invalid attribute specification
Cause:
The command did not specify a valid attribute name or a valid attribute value.
Action:
Specify a valid attribute name and value pair.
ORA-15215: missing or invalid user name
Cause:
The command did not specify a valid user name.
Action:
Specify a valid user name.
ORA-15216: missing or invalid user group name
Cause:
The command did not specify a valid user group name.
Action:
Specify a valid user group name.
ORA-15217: missing or invalid timeout value after DROP AFTER
Cause:
The command did not specify a valid timeout value after the DROP AFTER clause.
Action:
Specify a valid timeout value after the DROP AFTER clause.
ORA-15218: timeout value exceeded range
Cause:
The OFFLINE timeout value exceeded the range of 0-136 years, inclusive. 136 years are 49674 days, 1192176 hours, and 71530560 minutes.
Action:
Specify a timeout value within the range of 0-136 years, inclusive.
ORA-15219: conflicting or duplicate disk region options
Cause:
The command contained one or more of the following:
- both the HOT and the COLD keywords
- both the MIRRORHOT and the MIRRORCOLD keywords
- the HOT keyword more than once
- the COLD keyword more than once
- the MIRRORHOT keyword more than once
- the MIRRORCOLD keyword more than once
Action:
Specify either the HOT or the COLD keyword and either the MIRRORHOT or the MIRRORCOLD keyword, at most, once.
ORA-15220: invalid file attribute specification
Cause:
The keyword UNPROTECTED, MIRROR, HIGH, FINE, or COARSE was specified in a MODIFY FILE clause. These file attributes are immutable once a file is created.
Action:
Specify a disk region keyword; for example, HOT, COLD, MIRRORHOT, or MIRRORCOLD.
ORA-15221: ASM operation requires compatible.asm of string or higher
Cause:
The ASM operation specified requires a higher disk group attribute value for compatible.asm.
Action:
Set the disk group attribute compatible.asm to or above the requested version.
ORA-15222: ASM disk "string" is offline and cannot be renamed.
Cause:
An attempt was made to rename a disk that is offline.
Action:
Check the ASM disk name as specified in the command.
ORA-15223: conflicting disk operations for string
Cause:
An attempt was made to ADD and DROP the specified ASM disk in the same statement.
Action:
Revise the statement to specify distinct ASM disks in the ADD disk and DROP disk clauses.
ORA-15224: disk "string" is already provisioned for ASM
Cause:
An attempt was made to label a disk that is already provisioned for ASM.
Action:
ORA-15225: label name 'string' is already in use
Cause:
A LABEL SET command specified a label name that was already used by another ASM disk.
Action:
Select a different name for the label.
ORA-15226: label name 'string' is not used by ASM
Cause:
A LABEL CLEAR command specified a label name that was not used by ASM.
Action:
ORA-15227: could not perform label set/clear operation
Cause:
An error occurred while setting/clearing the ASM label.
Action:
Look at the underlying error(s) on the error stack. Check other messages in the trace files for more information.
ORA-15230: diskgroup 'string' does not require the FORCE option
Cause:
An attempt was made to MOUNT or DROP a disk group with the FORCE option.
Action:
MOUNT and DROP diskgroup with the FORCE option are only permitted if the diskgroup cannot be mounted normally.
ORA-15231: advancing diskgroup compatibility would exclude connected clients
Cause:
Disk group compatibility could not be advanced because connected clients were at a lower compatibility than the target value.
Action:
Make sure all connected clients are at target compatibility level or higher.
ORA-15232: cannot advance diskgroup compatibility due to offline disks
Cause:
Disk group compatibilty could not be advanced because some disks are offline.
Action:
Retry the command after offline disks are dropped.
ORA-15233: cannot advance diskgroup compatibility due to [string]
Cause:
Disk group compatibilty could not be advanced because of errors.
Action:
ORA-15234: target RDBMS compatibility (string) exceeds ASM compatibility (string)
Cause:
An attempt was made to advance RDBMS compatibility beyond the disk group's ASM compatibility.
Action:
Advance ASM compatibility before advancing RDBMS compatibility.
ORA-15235: diskgroup string mount mode conflicts with existing mount
Cause:
The mode specified in the diskgroup mount command conflicted with the mode in which it was mounted on some other instance.
Action:
Specify a compatible mode in the diskgroup mount command.
ORA-15236: diskgroup string mounted in restricted mode
Cause:
The specified diskgroup was mounted in restricted mode prohibiting client access.
Action:
Dismount the diskgroup and remount it in appropriate mode.
ORA-15237: invalid attribute string to CREATE DISKGROUP command
Cause:
An invalid attribute was specified with the CREATE DISKGROUP command.
Action:
Check the valid attributes for CREATE DISKGROUP command and specify a valid one.
ORA-15238: string is not a valid value for attribute string
Cause:
The specified value was not valid for the attribute.
Action:
Check the attribute name and value.
ORA-15239: allocation unit size higher than string requires RDBMS compatibility string
Cause:
The allocation unit size requested exceeded the limit imposed by the RDBMS compatibility setting.
Action:
Use a smaller allocation unit size or specify a higher RDBMS compatibility setting.
ORA-15240: attribute name string is invalid
Cause:
The attribute name was not valid or was not recognized.
Action:
Check the attribute name.
ORA-15241: attribute string is read only
Cause:
The attribute value is read-only and cannot be changed.
Action:
None. The attribute value cannot be changed.
ORA-15242: could not set attribute string
Cause:
An error occurred while setting the attribute.
Action:
ORA-15243: string is not a valid version number
Cause:
The given version number was invalid, or not valid in this context.
Action:
Verify that the version number is valid and is appropriate for this command. Check for additional errors reported.
ORA-15244: new compatibility setting less than current [string]
Cause:
The compatibility setting was invalid. The compatibility setting can only be advanced.
Action:
Check the version number.
ORA-15245: ASM disk string is already being brought online
Cause:
An attempt was made to bring online a disk that is already being brought online.
Action:
Change the ONLINE statement to exclude the disk.
ORA-15246: cannot bring ASM disk string both online and then offline in the same statement
Cause:
An attempt was made to bring the specified disk both online and offline in the same statement.
Action:
Revise the statement to either bring the disk online or take the disk offline.
ORA-15247: cannot specify both WAIT and NOWAIT options in the same statement
Cause:
An attempt was made to specify both WAIT and NOWAIT options in the same statement.
Action:
Revise the statement and include at most one option.
ORA-15248: ASM attributes feature not enabled
Cause:
The ASM attributes feature was not enabled.
Action:
Advance disk group ASM compatibility to version 11.1.0 or newer.
ORA-15249: could not locate ASM attribute string
Cause:
The specified attribute could not be accessed.
Action:
Check the attribute name and examine underlying error(s) on the error stack.
ORA-15250: insufficient diskgroup space for rebalance completion
Cause:
The command attempted to reduce the available diskgroup space below the current space used.
Action:
Consult V$ASM_DISK to determine the space requirements for the diskgroup contents, and repeat the command after making the required storage available.
ORA-15251: only restricted mount is allowed in the ASM instance
Cause:
The ASM instance was started in restricted mode, and an attempt was made to mount a diskgroup in non-restricted mode.
Action:
Start the ASM instance in non-restricted mode and mount the diskgroup again, or mount the diskgroup in restricted mode.
ORA-15252: user name 'string' does not exist in OS user dictionary
Cause:
The specified user name was not a valid operating system user.
Action:
Specify a valid operating system user.
ORA-15253: user group name 'string' exceeds limit of string characters
Cause:
The length of the specified user group name exceeded the maximum limit.
Action:
Reduce the length of the user group name to a value within the limit.
ORA-15254: user group 'string' already exists in disk group
Cause:
The specified user group name already existed in the disk group.
Action:
Specify a different user group name.
ORA-15255: user group 'string' does not exist in disk group 'string'
Cause:
The specified user group name did not exist in the disk group.
Action:
ORA-15256: user 'string' is already a member of user group 'string'
Cause:
The specified user was already a member of the specified user group.
Action:
Specify either an alternate user or an alternate user group.
ORA-15257: exceeded string number of members per user group
Cause:
The maximum number of members per user group was exceeded.
Action:
Delete existing members of the user group to create space.
ORA-15258: user group entry number must be between string and string, inclusive
Cause:
The specified user group entry number was beyond the acceptable range.
Action:
Specify a valid value for the user group entry number.
ORA-15259: user 'string' is not a member of user group 'string'
Cause:
The specified user was not a member of the specified user group.
Action:
ORA-15260: permission denied on ASM disk group
Cause:
An attempt was made to perform an operation on an ASM disk group without the appropriate privileges.
Action:
Ask the ASM administrator to perform the operation or grant the required privileges.
ORA-15261: user 'string' already exists in disk group 'string'
Cause:
The specified UID already existed in the disk group.
Action:
Specify a different UID.
ORA-15262: user 'string' does not exist in disk group 'string'
Cause:
The specified UID did not exist in the disk group.
Action:
Specify a user with a valid UID.
ORA-15263: user name 'string' exceeds limit of string characters
Cause:
The length of the specified user name exceeded the maximum limit.
Action:
Reduce the length of the user name to a value within the limit.
ORA-15264: Operating system function returned error string
Cause:
An operating system error occurred.
Action:
ORA-15265: user identification number not in range of [string,string]
Cause:
The operating system user identification number exceeded the maximum value.
Action:
Change the user identification number to a value within the accepted range.
ORA-15266: user identification number 'string' is not allowed
Cause:
This user identification number is used internally by ASM.
Action:
Please choose a different user identification number.
ORA-15268: internal Oracle file string already exists.
Cause:
File was already in existence.
Action:
This is an internal error. Contact Oracle Support Services.
ORA-15269: group identification number not in range of [string,string]
Cause:
The operating system group identification number exceeded the maximum value.
Action:
Change the group identification number to a value within the accepted range.
ORA-15270: disk string is not a quorum disk
Cause:
The specified disk was not a quorum disk.
Action:
Retry the operation without the quorum attribute for the disk.
ORA-15271: failgroup string is a quorum failgroup
Cause:
The specified failgroup was a quorum failgroup.
Action:
Retry the operation with the quorum attribute for the failgroup.
ORA-15272: failgroup string is not a quorum failgroup
Cause:
The specified failgroup was not a quorum failgroup.
Action:
Retry the operation without the quorum attribute for the failgroup.
ORA-15273: Could not create the required number of voting files.
Cause:
The required number of voting files could not be created. See accompanying messages for possible causes.
Action:
See accompanying messages for possible actions.
ORA-15274: Not enough failgroups (string) to create voting files
Cause:
The number of failgroups required for this redundancy were not present in the diskgroup to create voting files.
Action:
Retry the operation after creating new failgroup(s).
ORA-15275: Not enough contiguous space (string AUs) in disk string to allocate a voting file
Cause:
The specified disk did not have enough space to allocate a voting file on it.
Action:
Ensure that there is at least 1 disk with the required space in atleast the required number of failgroups for the diskgroup.
ORA-15276: ASM diskgroup string has cluster voting files
Cause:
An attempt was made to drop a diskgroup that contained cluster voting files.
Action:
Move the cluster voting files out of the diskgroup and retry the operation.
ORA-15277: disk string is a quorum disk
Cause:
The specified disk was a quorum disk.
Action:
Retry the operation with the quorum attribute for the disk.
ORA-15278: external redundancy diskgroup requires at least one regular disk
Cause:
An attempt was made to create an external redundancy diskgroup with only quorum disks.
Action:
Specify atleast one regular disk to create an external redundancy diskgroup.
ORA-15279: user 'string' is currently being deleted
Cause:
The specified user was in the process of being deleted and could not be used.
Action:
Either abandon this operation or specify a different user.
ORA-15280: user 'string' owns existing files
Cause:
An attempt was made to drop a user that still owns existing files.
Action:
Specify the CASCADE option to drop the user and all of the owned files.
ORA-15281: not all specified disks were brought ONLINE
Cause:
Some of the disks specified either experienced I/O errors while being brought ONLINE, or were simultaneously brought OFFLINE or dropped in another session, or were full.
Action:
Query V$ASM_DISK or use ASMCMD LSDSK to determine which disks were not brought ONLINE. Inspect any additional error messages and the alert log to determine the exact cause. If some of the disks failed, either fix the cause of the failures or drop the disks. If some of the disks are full, either free space in the disk group or add new disks to the diskgroup.
ORA-15283: ASM operation requires compatible.rdbms of string or higher
Cause:
The ASM operation specified requires a higher disk group attribute value for compatible.rdbms.
Action:
Set the disk group attribute compatible.rdbms to or above the requested version.
ORA-15284: ASM terminated ALTER DISKGROUP ONLINE
Cause:
None of the disks specified by ALTER DISKGROUP ONLINE could be brought ONLINE.
Action:
Inspect additional error messages and the alert log to determine why the specified disks cannot be brought ONLINE.
ORA-15285: disk 'string' violates disk group attribute string
Cause:
Including the specifed disk would violate a restriction imposed by the specified disk group attribute.
Action:
Retry the operation while omitting the offending disk or change the attribute.
ORA-15286: could not set disk group attribute string due to offline disks
Cause:
The specified disk group attribute could not be set because the disk group includes offline disks.
Action:
Retry the operation after the offline disks in this disk group are dropped or brought online.
ORA-15287: could not set disk group attribute string due to incompatible disks
Cause:
The specified disk group attribute could not be set because the disk group includes disks that conflict with the new value.
Action:
Retry the operation after dropping the conflicting disks in this disk group.
ORA-15288: disk(s) require disk group attribute string clause
Cause:
Some of the disks specified by the command also require the specified disk group attribute to be stated.
Action:
Retry the command including an ATTRIBUTE clause for the required disk group attribute. Alternatively, omit the disks that require setting the disk group attribue. See the alert log for additional information on the disks that require setting the disk group attribute.
ORA-15289: disk string is limited to string MB on instance string
Cause:
An ALTER DISKGROUP ADD DISK or RESIZE DISK command specified a disk with a size greater than the specified instance could use.
Action:
Check the storage subsystem configuration on the specified node.
ORA-15290: operation not permitted on offline disk string
Cause:
An attempt was made to specify an operation that is only permitted on disks that are online. The specified disk was not online.
Action:
Online the disk or wait for online to complete before retrying the operation.
ORA-15291: ASM could not add disk "string" to disk group "string"
Cause:
An attempt was made to add a disk to a disk group while the distribution of disks in failure groups was too uneven.
Action:
Add or drop disks to or from failure groups to balance their distribution in all failure groups and retry the operation.
ORA-15292: Disk name string is being used by another disk
Cause:
The specified disk name could not be reused because an 11.1.0.6.0 or earlier database instance had it cached in memory.
Action:
Do one of the following
- Specify a different name for the disk.
- Wait for the rebalance to complete successfully.
- Identify the database instance with the problem and shut it down before retrying the command.
ORA-15293: operation disallowed by ASM_POWER_LIMIT
Cause:
This operation required data movement in order to complete successfully. However, ASM_POWER_LIMIT was set to zero, thereby preventing this operation.
Action:
Repeat the operation after setting ASM_POWER_LIMIT to a non-zero value.
ORA-15294: SYSASM privilege not allowed on database instance
Cause:
The SYSASM privilege was not allowed on this database instance; it is allowed only on an ASM instance.
Action:
Use either the SYSDBA or the SYSOPER privilege.
ORA-15295: ASM instance software version string less than client version string
Cause:
The ASM instance software version was less than the client version.
Action:
Upgrade the ASM instance software. Check the alert log for more information on the reason for the failure.
ORA-15298: possible lost disk write detected during crash recovery
Cause:
ASM crash recovery read a block who's version was older than expected.
Action:
None. End users will not see this error. ASM automatically traps this error and attempts a fallback recovery.
ORA-15299: FINE striping not allowed for the Staleness Registry
Cause:
An SQL command attempted to set the striping attribute of the ASM_STALE template to FINE striping.
Action:
Do not modify the striping attribute of the ASM_STALE template.
ORA-15300: File string is incompatible with this operation
Cause:
The file type was incompatible with the operation.
Action:
Use another file of the correct type.
ORA-15301: cannot change string of the open file 'string'
Cause:
A SET OWNERSHIP or SET PERMISSION command was attempted on an open file.
Action:
Close the file and retry the SQL command.
ORA-15302: active use of files owned by user 'string' precludes its drop
Cause:
A DROP USER command specified a user owning files that were in use.
Action:
Close all files owned by this user.
ORA-15303: Voting files could not be created in diskgroup string due to small Allocation Unit size
Cause:
An attempt was made to create voting files in a diskgroup with a small Allocation Unit size.
Action:
Create voting files in a different diskgroup whose Allocation Unit size is at least 1 mega byte.
ORA-15304: operation requires ACCESS_CONTROL.ENABLED attribute to be TRUE
Cause:
An attempt was made to run an operation that required the ACCESS_CONTROL.ENABLED attribute to be set to TRUE, but its existing state was FALSE.
Action:
Set the ACCESS_CONTROL.ENABLED attribute to TRUE and retry the operation.
ORA-15305: cannot operate on ASM internal files
Cause:
An attempt was made to operate on Automatic Storage Management (ASM) metadata used to manage the diskgroup.
Action:
Check the specified ASM file name.
ORA-15306: ASM password file update failed on at least one node
Cause:
A CREATE USER, ALTER USER, DROP USER, GRANT, or REVOKE command failed on at least one node of the Automatic Storage Management (ASM) cluster.
Action:
Check the ASM alert logs for more information.
ORA-15307: disk string not discoverable by CSS; diskgroup string has CSS voting files
Cause:
An attempt was made to add a disk which cannot be discovered by Cluster Synchronization Services (CSS). CSS has voting files in the disk group and will not be able to use the new disk if CSS cannot discover the disks.
Action:
Update the Automatic Storage Management (ASM) disk string in the Grid Plug and Play (GPnP) profile to include the specified disk and retry the operation. Alternatively, migrate the CSS voting files out of the diskgroup and retry the operation
ORA-15308: could not access ASM SPFILE in RDBMS instance
Cause:
A relational database management system (RDBMS) instance attempted to access an Automatic Storage Management (ASM) SPFILE.
Action:
Connect to an ASM instance and reissue the command. Alternatively, specify an RDBMS SPFILE.
ORA-15309: could not access database SPFILE in ASM instance
Cause:
An Automatic Storage Management (ASM) instance attempted to access a relational database management system (RDBMS) SPFILE.
Action:
Connect to an RDBMS instance and reissue the command. Alternatively, specify an ASM SPFILE.
ORA-15310: process terminated due to signal
Cause:
A process was terminated as a result of a signal in the I/O path.
Action:
ORA-15311: process terminated due to fenced I/O
Cause:
A process was terminated because it was fenced from doing any more I/Os.
Action:
ORA-15312: invalid file type
Cause:
Automatic Storage Management (ASM) could not determine the type of file.
Action:
The file specified is not supported with Automatic Storage Management (ASM). Specify a supported file type for the operation.
ORA-15313: Oracle ASM disk string cannot be resized under string M
Cause:
An Oracle ASM disk resize command specified a size that was less than the size required to support the voting file present on the disk.
Action:
Increase the size specified for the disk.
ORA-15315: Write errors in disk group string could lead to inconsistent ASM metadata.
Cause:
One or more failures occurred while writing ASM metadata to disk.
Action:
Repair the hardware problem and remount the disk group. Check the accompanying errors and alert log for the disks which reported the error.
ORA-15316: Previous client instance string has not fully exited.
Cause:
One or more processes from a prior instantiation of this client were not fenced.
Action:
Make sure all processes belonging to the client instance exited. Check the client alert log and the trace file of the process that terminated the instance.
ORA-15317: user identification number 'string' does not exist in operating system user dictionary
Cause:
The specified user identification number did not belong to a valid operating system user.
Action:
ORA-15318: disks in disk group string cannot be resized
Cause:
Execution of ASM Storage Reclamation Utility script was incomplete on the specified disk group.
Action:
Execute ASM Storage Reclamation utility on the disk group to complete the operation.
ORA-15319: ownership assignment of files to user 'string' precludes its drop
Cause:
A DROP USER command specified a user currently being assigned as the owner of one or more files with a SET OWNERSHIP command.
Action:
Wait for the SET OWNERSHIP command to complete and then retry the DROP USER command
ORA-15320: cannot drop user 'string' that has been assigned as the owner of one or more open files
Cause:
A SET OWNERSHIP command assigned this user as the owner of one or more files which were open at the time of assignment, and hence this user cannot be dropped due to possible inconsistencies in file ownerships.
Action:
Restart all ASM client instances of the cluster in a rolling manner.
ORA-15321: cannot set attribute with connected clients
Cause:
The disk group attribute could not be set because there were connected clients.
Action:
Shut down connected clients and retry the command. Query the V$ASM_CLIENT fixed view in an ASM instance or use ASMCMD LSOF to list active clients.
ORA-15322: cannot drop the owner 'string' of user group 'string' in disk group 'string'
Cause:
An attempt was made to drop the owner of a user group from the group's member list.
Action:
Specify a user group member who is not the owner of the user group.
ORA-15323: ASM password update has failed on local node
Cause:
A CREATE USER, ALTER USER, DROP USER, GRANT, or REVOKE command failed on the local node of the Automatic Storage Management (ASM) cluster.
Action:
ORA-15324: requested operation is not allowed on the password file string
Cause:
An attempt was made to run an operation that is not supported on password files.
Action:
Specify a new file name or a file with the correct file type and retry the operation.
ORA-15325: file string is not a valid password file
Cause:
An attempt was made to open a file that had a type different from the password file.
Action:
Specify correct password file name and retry the operation.
ORA-15326: specified input string is a not an ASM file
Cause:
The attributes could not be obtained as the specified input is either a disk group or a directory.
Action:
Specify a valid Automatic Storage Management (ASM) file name.
ORA-15327: remote ASM is not enabled
Cause:
An operation was requested that requires remote ASM to be enabled.
Action:
Enable remote ASM.
ORA-15328: user identification string 'string' exceeds limit of string characters
Cause:
The user identification string provided for this operation exceeded the maximum number of characters allowed.
Action:
Provide a user identification string of shorter length.
ORA-15329: cluster identification string 'string' exceeds limit of string characters
Cause:
The cluster identification string provided for this operation exceeded the maximum number of characters allowed.
Action:
Provide a cluster identification string of shorter length.
ORA-15330: ASM user name format requires COMPATIBLE.ASM of string or higher
Cause:
The ASM user name format specified requires a higher disk group attribute value for COMPATIBLE.ASM.
Action:
Set the disk group attribute COMPATIBLE.ASM to or above the requested version.
ORA-15331: ASM proxy instance ORACLE_SID string does not start with string
Cause:
The ASM proxy instance was started with an invalid ORACLE_SID prefix.
Action:
Start the ASM proxy instance with an ORACLE_SID that begins with the correct prefix.
ORA-15332: ASM proxy instance cannot connect to an ASM server
Cause:
The ASM proxy instance could not find an ASM server to connect to during startup.
Action:
Verify that an ASM server instance is running and accessible in the cluster and restart the proxy instance.
ORA-15333: disk is not visible on client instance
Cause:
An ALTER DISKGROUP ADD DISK statement specified a disk that could not be discovered by all ASM client instances.
Action:
Check the ASM alert logs for more information. Check operating system permissions for the device and the storage subsystem configuration.
ORA-15334: VUBG process terminated with error
Cause:
The volume background process terminated with error.
Action:
Warm start instance.
ORA-15335: ASM metadata corruption detected in disk group 'string'
Cause:
A corruption was detected reading a block. It may be recoverable.
Action:
The corruption could be the result of a storage problem, a configuration issue, or a software bug. Check the alert log for the result of the recovery attempt. If unsuccessful, contact Oracle Support Services with the incident information.
ORA-15336: STRIPE_WIDTH cannot be set when STRIPE_COLUMNS equals 1
Cause:
An ADD VOLUME command specified a STRIPE_COLUMNS equal to 1 and specified the STRIPE_WIDTH argument.
Action:
If striping is required, set STRIPE_COLUMNS to greater than 1. If striping is not required, do not set STRIPE_WIDTH.
ORA-15337: invalid or missing database name
Cause:
You did not specify a valid database name for this command.
Action:
Specify a valid database name.
ORA-15338: ASM client instance string reconnection refused
Cause:
The client was not found as an orphaned client and hence is not a legitimate candidate to reconnect to Oracle ASM.
Action:
Shut down and restart the remote client to be considered as a new client in the cluster.
ORA-15339: ASM client instance string has been fenced by ASM
Cause:
Oracle ASM has already fenced this client.
Action:
ORA-15340: unable to create Client Cluster 'string'
Cause:
Creation of the Client Cluster failed.
Action:
Check the alert logs and trace files of the Oracle ASM instance for more information on the reason for the failure, as well as checking the accompanying error messages.
ORA-15341: unable to delete Client Cluster 'string'
Cause:
Deletion of the Client Cluster failed.
Action:
ORA-15343: Feature string ASM is not enabled
Cause:
An operation was requested that requires Oracle Flex ASM to be enabled.
Action:
Enable Oracle Flex ASM.
ORA-15344: client string not found
Cause:
The specified Oracle ASM client was not registered with this instance.
Action:
Check the alert logs and trace files of the client for more information on the reason for the failure, as well as the accompanying error messages.
ORA-15345: disconnected client instance(s) detected
Cause:
One or more ASM client instances were not connected to an ASM instance.
Action:
Check that all of the ASM client instances are connected to an ASM instance and retry the operation.
ORA-15346: process attempting to identify or create ASM file string was aborted
Cause:
The client process attempting to identify or create the ASM file terminated or was interrupted.
Action:
Correct the cause of the process interruption and retry the operation.
ORA-15347: logical block size string of ASM file 'string' is too small for disk group sector size string
Cause:
An attempt was made to create a file on ASM whose logical block size was less than the sector size for the disk group.
Action:
Check if the system configuration has changed. Correct the error and retry the operation.
ORA-15348: ASMLIB misconfiguration error [string]
Cause:
ASMLIB was found in more than one location.
Action:
Check the configuration of ASMLIB and ensure that only one library is configured.
ORA-15349: failed to set or get AFD_DISKSTRING parameter
Cause:
The operation failed because Oracle Local Repository (OLR) was not available.
Action:
Check that Oracle Clusterware is properly configured.
ORA-15350: invalid SYS_ASMFD_PROPERTIES parameter
Cause:
The parameter passed in for SYS_ASMFD_PROPERTIES was invalid.
Action:
Pass in the correct parameter. Refer to the product documentation for a list of allowed parameter values.
ORA-15351: I/O request issued to a sparse grid disk failed because the disk was out of space.
Cause:
The sparse grid disk was out of space.
Action:
Add more space to the disk group by adding more disks or add more space to existing disks by resizing them.
ORA-15352: invalid client name string specified
Cause:
The client name passed in was invalid.
Action:
Pass in a valid client name. The valid client name is of format instance name:dbunique name:cluster name or instance name:dbunique name
ORA-15353: disk 'string' cannot be added to disk group 'string'
Cause:
The disk type did not match the disk group sparse type.
Action:
Make sure the disk type matches the disk group sparse type.
ORA-15354: failed to format grid disk "string"
Cause:
The grid disk format command failed.
Action:
Check the grid disk logs and take corrective actions.
ORA-15357: Can not create file "string" on a sparse disk group
Cause:
An attempt was made to create fine-grained striping files on sparse disk groups. Fine-grained striping files cannot be created on sparse disk groups.
Action:
Create the file on a regular disk group, or create a coarse-grained striping file on a sparse disk group.
ORA-15358: query for materialized space to sparse grid disk "string" of disk group "string" has failed
Cause:
The query for materialized space to the cell server has failed.
Action:
Check the ASM and cell alert logs and take corrective actions.
ORA-15359: could not perform label scan operation
Cause:
An error occurred while scanning for ASM label.
Action:
Look at the underlying errors on the error stack. Check other messages in the trace files for more information.
ORA-15360: could not perform label filter operation
Cause:
An error occurred while setting AFD filter status.
Action:
ORA-15361: unable to find Client Cluster 'string'
Cause:
Looking up of the Client Cluster failed.
Action:
Execute the 'asmcmd lscc' command to list all of the configured Client Clusters. If the Client Cluster listed in the message is not present, it might have been forcibly deleted. Refer to the product documentation for more information. If the Client Cluster listed in the message was present, contact Oracle Support Services.
ORA-15362: invalid cluster name 'string' specified
Cause:
An invalid cluster name was supplied.
Action:
Specify a cluster name which is at least one character but no more than 15 characters in length. The cluster name must be alphanumeric, it cannot begin with a numeric character, and it may contain hyphen (-) characters. However, it cannot end with a hyphen (-) character.
ORA-15363: invalid version number 'string' specified
Cause:
Action:
ORA-15364: Client Cluster version string is incompatible with Storage Server version string
Cause:
The specified Client Cluster version was not supported by the Storage Server.
Action:
Upgrade or downgrade the Storage Server to a version that is compatible with Client Cluster and retry the operation. Install a Client Cluster using a supported version. Refer to product documentation for a complete list of supported releases.
ORA-15365: Client Cluster 'string' already configured
Cause:
The specified Client Cluster was already configured.
Action:
Execute the 'asmcmd lscc' command to list all of the configured Client Clusters. Reexecute the command with a Client Cluster name that has not already been configured.
ORA-15366: unable to delete configuration for Client Cluster 'string' because the directory 'string' was not empty
Cause:
Deleting the Client Cluster configuration failed because some files were present.
Action:
Deinstall the Client Cluster and rerun the command. If the command fails again, execute the 'asmcmd rmcc <client_cluster_name> -f' command to force deletion of the configuration for the Client Cluster.
ORA-15367: Client Cluster 'string' not configured
Cause:
The specified Client Cluster was not configured.
Action:
Execute the 'asmcmd lscc' command to list all of the configured Client Clusters. Reexecute the command with a Client Cluster name that is configured.
ORA-15368: Oracle Cluster Registry operation failed with error string.\nstring
Cause:
Action:
ORA-15369: OCI invalid handle string
Cause:
An Oracle Call Interface (OCI) call returned the OCI_INVALID_HANDLE return code and did not store the error on the stack.
Action:
ORA-15371: The command is not supported on a Client Cluster.
Cause:
An attempt was made to run a command that is not supported on a Client Cluster.
Action:
Rerun the command on the Storage Server.
ORA-15400: not running on supported ASM appliance
Cause:
An attempt was made to initialize the server code as an appliance when it was not running a supported appliance configuration.
Action:
Check the appliance configuration and retry the operation.
ORA-15401: command not supported on ASM appliance 'string'
Cause:
An attempt was made to run an operation that is not supported by the specified appliance.
Action:
Check the documentation to see which operations are allowed or disallowed for the specified appliance.
ORA-15402: insufficient number of disks to support ASM appliance 'string'
Cause:
An attempt was made to do an operation that resulted in insufficient number of disks required for the specified appliance.
Action:
Check the appliance configuration and retry the operation after inserting disks in the appropriate slots.
ORA-15403: unable to read an ASM appliance configuration file
Cause:
Oracle ASM was unable to read an appliance configuration file.
Action:
Check the operating system error messages to determine the identity of the configuration file. Then, fix the configuration file.
ORA-15404: Oracle ASM could not add disk "string" to disk group "string" on appliance string
Cause:
There were too many dropping or offline disks in the specified disk group.
Action:
Wait for the drop and rebalance operations to complete, or online the offline disks and wait for the online to complete. Then, retry the operation.
ORA-15405: Slot string in Oracle ASM appliance 'string' contains more than one disk
Cause:
An attempt was made to add a disk to a slot in the ASM appliance that already had a disk (possibly OFFLINE) associated with it.
Action:
Use FORCE to drop the disk that exists in the specified slot. Then, retry the operation.
ORA-15406: ASM disk string is being replaced.
Cause:
An attempt was made to either online or replace a disk that was already being replaced, probably by another instance.
Action:
ORA-15407: Disk specification 'string' matches multiple disks.
Cause:
More than one disk is discovered matching the specified disk string.
Action:
Change the disk string to specify one and only one disk.
ORA-15408: Replacement disk 'string' for 'string' must be at least string MB.
Cause:
The replacement disk must be at least of the same size of the old disk.
Action:
Use a larger physical disk to replace.
ORA-15409: All disks in disk group string are not of the same type.
Cause:
An attempt was made to add disks of a different type to the disk group under appliance mode.
Action:
Check if all the disks in the disk group are of the same type. Do not add flash and hard disks to the same disk group.
ORA-15410: Disks in disk group string do not have equal size.
Cause:
The disks in the disk group were not of equal size.
Action:
Ensure that all disks in the disk group are of equal size. If adding new disks to the disk group, their size must be equal to the size of the existing disks in the disk group. If resizing, all disks in the disk group must be resized to the same size.
ORA-15411: Failure groups in disk group string have different number of disks.
Cause:
An attempt was made to enable appliance mode with a different number of disks in each failure group.
Action:
Check if all failure groups have an equal number of disks and try again.
ORA-15412: Operation on disk group string is incompatible under appliance mode.
Cause:
An attempt was made to do an operation that resulted in dropping all disks in a failure group or creating a new failure group.
Action:
Disable appliance mode, perform the operation and reenable appliance mode. WARNING: To reenable appliance mode, ensure the following constraints are met:
* There are a sufficient number of disks in each failure group.
* All failure groups have an equal number of disks.
* There are no offline disks in the disk group.
* Every disk in the disk group is of the same type (flash or hard disk).
* All disks in the disk group have an equal size.
ORA-15413: Appliance mode is disabled.
Cause:
Appliance mode could not be set because it was explicitly disabled.
Action:
Enable appliance mode and appliance partnering parameters.
ORA-15414: Appliance mode requires at least string failure groups and either string or string disks in all failure groups.
Cause:
Appliance mode could not be enabled because it did not meet the minimum requirements.
Action:
Check if there are sufficient failure groups and a sufficient number of disks in each failure group.
ORA-15415: could not retrieve appliance properties for disk group string
Cause:
Some of the appliance properties were invalid. This could be due to a cell software downgrade after setting the 'appliance.mode' attribute.
Action:
Check the cell software on all of the cells or disable appliance mode.
ORA-15416: ASM disk string in disk group string is offline.
Cause:
An offline disk prevented the current ADD or DROP operation.
Action:
Drop the offline disk or online the offline disk or disable appliance mode.
ORA-15418: Appliance mode is not supported for compatible.asm string.
Cause:
Appliance mode could not be enabled for the current value of the compatible.asm attribute.
Action:
Disable appliance mode if it is enabled or advance compatible.asm to a version that supports appliance mode.
ORA-15419: disk group string is not mounted in restricted mode
Cause:
The specified disk group was not mounted in restricted mode prohibiting the requested operation.
Action:
Dismount the disk group, remount it in restricted mode and retry the operation.
ORA-15420: Operation on disk group string is disabled.
Cause:
The current operation could not be completed because the disk group is in the middle of an appliance migration.
Action:
Wait for the migration to complete and then retry the command.
ORA-15440: VIO0 process terminated with error
Cause:
A volume IO background process terminated with error.
Action:
Wait for the process to restart.
ORA-15450: invalid volume name specifier
Cause:
The volume name specified was invalid
Action:
Specify a valid volume name.
ORA-15451: missing or invalid volume size specifier
Cause:
The volume size specified was invalid.
Action:
Specify a valid volume size.
ORA-15452: missing or invalid stripe width specifier
Cause:
The volume stripe width specified was invalid.
Action:
Specify a valid volume stripe width.
ORA-15453: invalid STRIPE_COLUMNS specifier
Cause:
An ADD VOLUME command did not specify a valid number of stripe columns.
Action:
Specify a valid number of stripe columns.
ORA-15454: ALTER DISKGROUP ALL cannot use single volume names
Cause:
An ALTER DISKGROUP ALL command specified a single volume or a list of volumes
Action:
Use the ALL keyword when specifying volumes on multiple diskgroups.
ORA-15455: FORCE option cannot be used when specifying ALL volumes
Cause:
The FORCE option was used to disable ALL volumes.
Action:
Use FORCE option to disable one volume at a time.
ORA-15456: missing or invalid volume usage specifier
Cause:
The command did not specify a valid volume usage string.
Action:
Specify a valid volume usage string with alphanumeric characters.
ORA-15457: first letter of the volume name is not alphabetic
Cause:
A volume name was specified with a nonalphabetic first character.
Action:
Set the first character of the volume name to be alphabetic.
ORA-15458: invalid character in volume name
Cause:
A volume name was specified with an invalid character.
Action:
Use a volume name with only alphanumeric characters.
ORA-15459: STRIPE_WIDTH of string is not a power of two
Cause:
An ADD VOLUME command specified a STRIPE_WIDTH that was not a power of two.
Action:
Select a STRIPE_WIDTH that is a power of two; for example, 4K, 8K, etc.
ORA-15460: volume name 'string' is already in use
Cause:
An ADD VOLUME command specified a volume name that was already used by another volume.
Action:
Select a different name for the volume.
ORA-15461: STRIPE_WIDTH of string bytes is less than the minimum of string bytes
Cause:
An ADD VOLUME command specified a STRIPE_WIDTH that was too small.
Action:
Select a larger STRIPE_WIDTH.
ORA-15462: STRIPE_WIDTH of string bytes is greater than the maximum of string bytes
Cause:
An ADD VOLUME command specified a STRIPE_WIDTH that was too large.
Action:
Select a smaller STRIPE_WIDTH.
ORA-15463: volume size of stringK is less than the minimum of stringM
Cause:
The volume size specified was too small.
Action:
Select a larger volume size.
ORA-15464: STRIPE_COLUMNS of string is greater than the maximum of string
Cause:
An ADD VOLUME command specified a STRIPE_COLUMNS that was that was too large.
Action:
Select a smaller STRIPE_COLUMNS value.
ORA-15465: STRIPE_COLUMNS of string is less than the minimum of string
Cause:
An ADD VOLUME command specified a STRIPE_COLUMNS that was too small.
Action:
Select a larger STRIPE_COLUMNS value.
ORA-15466: volume 'string' in disk group 'string' does not exist
Cause:
The command specified a volume name that does not exist.
Action:
Ensure a valid volume name is used.
ORA-15467: volume operation is already in progress
Cause:
Another command was currently operating on a volume.
Action:
Wait a short time before retrying the command.
ORA-15468: volume 'string' in diskgroup 'string' is currently being accessed
Cause:
An attempt was made to communicate with the volume driver. The volume was being accessed by another application and, therefore, could not be changed.
Action:
Shut down all applications that might be accessing this volume and then retry the command.
ORA-15469: VBG process terminated with error
Cause:
A volume background process terminated with error.
Action:
Wait for process to restart.
ORA-15470: VDBG process terminated with error
Cause:
The volume driver background process terminated with error.
Action:
ORA-15471: volume redundancy incompatible with disk group redundancy
Cause:
An ADD VOLUME command specified a volume redundancy that was incompatible with the redundancy of the disk group.
Action:
Specify a valid volume redundancy. An unprotected redundancy volume cannot be added to a normal or high redundancy disk group, and a mirror or high redundancy volume cannot be added to an external redundancy disk group.
ORA-15472: volume library cannot be loaded. Platform may not support volume creation.
Cause:
The volume library could not be loaded. Either the platform does not support volume operations, or there is a problem with the library.
Action:
Ensure that the platform supports volumes. If the platform does support volumes, check the alert log for library loading failure information.
ORA-15473: access to a volume's storage through an unsupported interface
Cause:
An attempt was made to access or modify a volume's storage through an unsupported interface.
Action:
Use supported interfaces for access to volume devices.
ORA-15474: volume name is greater than string characters
Cause:
An ADD VOLUME command specified a volume name that was too long.
Action:
Select a smaller volume name.
ORA-15475: usage string is greater than string characters
Cause:
The usage string specified was too long.
Action:
Select a smaller usage string.
ORA-15476: ACFS volumes must be resized with the 'acfsutil size' operating system command.
Cause:
An attempt was made using SQL to resize an ADVM volume that contains an ACFS file system.
Action:
Use the 'acfsutil size' operating system command to resize the volume.
ORA-15477: cannot communicate with the volume driver
Cause:
Action:
Check that the ASM volume driver is loaded. If so, check the alert log to identify the reason for failure and take necessary action to prevent such failures in the future.
ORA-15478: ACFS process terminated with error
Cause:
The ACFS background process terminated with error
Action:
Wait for process restart
ORA-15479: ASM diskgroup does not support volumes
Cause:
Volumes were not supported. A common example is having disks, such as NFS, in the diskgroup that are not supported by volumes.
Action:
Remove unsupported disks in the diskgroup.
ORA-15480: error reported in the ASM volume driver
Cause:
An error was reported in the ASM volume driver.
Action:
Check the operating system log files to identify the reason for the failure and take necessary action to prevent such failures in the future.
ORA-15481: missing or invalid volume mountpath specifier
Cause:
A invalid volume mountpath string was specified.
Action:
Specify a valid volume mountpath string with alphanumeric characters.
ORA-15482: failed to create/remove device file for volume string on diskgroup string
Cause:
Improper driver installation.
Action:
Check the alert log for device file creation failure information. Reload the driver using the supported installation method.
ORA-15483: volume driver version is not compatible with the ASM instance
Cause:
The version of the ASM volume driver was not supported by ASM.
Action:
Update the volume driver or the ASM instance.
ORA-15484: volume 'string' contains string error(s)
Cause:
Errors were returned by the ALTER DISKGROUP CHECK VOLUME command.
Action:
See the alert log for details of the errors.
ORA-15485: number of volumes in diskgroup exceeds the maximum of string
Cause:
A volume was added on a diskgroup that already contained the maximum number allowed.
Action:
Remove volumes on the diskgroup.
ORA-15486: internal error while altering volume
Cause:
An internal ASM error occurred while altering a volume.
Action:
See the alert log for details of the error.
ORA-15487: cannot shutdown the ASM instance with an open ASM volume
Cause:
One or more ASM volumes were found to be open during shutdown.
Action:
Close the ASM volume and retry the shutdown.
ORA-15488: volume string is open on instance string
Cause:
ASM volume was not closed prior to instance termination on node specified.
Action:
Close the ASM volume either via unmount or node restart and retry the operation
ORA-15489: conflicting volume already open on this node
Cause:
An ASM volume was not closed prior to instance shutdown on node specified. It is conflicting with the volume that is to be enabled.
Action:
Close the ASM volume either via unmount or node restart and retry the operation.
ORA-15490: not all instances could add/drop the volume
Cause:
The ASM volume cannot be added/dropped on all instances.
Action:
See the alert log for the reason the volume could not be added/droped.
ORA-15491: volume redundancy conflicts with disk region options
Cause:
Non-mirrored volumes erroneously contained the MIRRORHOT or MIRRORCOLD keyword.
Action:
Remove the MIRRORHOT or MIRRORCOLD keywords from non-mirrored volumes.
ORA-15492: command or option incompatible with ASM volumes
Cause:
An attempt was made to use a feature which is not compatible with existing ASM volumes. A common example is adding a disk to the diskgroup that is unsupported by ASM volumes.
Action:
Omit the option from the command.
ORA-15493: target ADVM compatibility (string) exceeds ASM compatibility (string)
Cause:
An attempt was made to advance ADVM compatibility beyond the disk group's ASM compatibility.
Action:
Advance ASM compatibility before advancing ADVM compatibility.
ORA-15494: compatible.advm must be string or higher
Cause:
An attempt was made to set the ADVM compatibility to a version that was lower than the minimum supported.
Action:
Set ADVM compatibility to at least the minimum supported version.
ORA-15495: ASM operation requires compatible.advm of string or higher
Cause:
The ASM operation specified required a higher disk group attribute value for compatible.advm.
Action:
Set the disk group attribute compatible.advm to or above the requested version.
ORA-15496: volume size is greater than the maximum of stringT
Cause:
The volume size specified was too large.
Action:
Select a smaller volume size.
ORA-15497: diskgroup uses a sector size that is incompatible with volumes
Cause:
The diskgroup used a sector size that was not 512 bytes.
Action:
Create the volume in a diskgroup with a sector size of 512 bytes.
ORA-15498: Volume name 'string' would collide with existing volume(s) 'string string'.
Cause:
A volume name was specified that would conflict with existing volume device(s). A volume '<vol_name>-<dg_num>' is the name of the block device. Additionally, a raw device named 'r<vol_name>-<dg_num>' is also created. Since that name already existed, a name collision occurred.
Action:
Choose another name for the volume (no leading 'r' is recommended).
ORA-15499: Volume Membership (VMB) process terminated with error
Cause:
Action:
Warm start the instance.
ORA-15501: cannot start workload capture on instance string
Cause:
Given instance encountered unexpected errors while trying to start the workload capture.
Action:
Check the alert log and other diagnostics in the given instance to diagnose the problem.
ORA-15502: cannot stop workload capture on instance string
Cause:
Given instance encountered unexpected errors while trying to stop the workload capture.
Action:
ORA-15503: cannot startup instance when procedures in "DBMS_WORKLOAD_CAPTURE" or "DBMS_WORKLOAD_REPLAY" are in the middle of their execution
Cause:
The new instance could not be started because the database was executing a procedure in either the DBMS_WORKLOAD_CAPTURE or DBMS_WORKLOAD_REPLAY package.
Action:
Start the new instance after such procedures in the given packages have finished execution.
ORA-15504: cannot start workload capture because instance string not present in RESTRICTED SESSION mode
Cause:
The NO_RESTART_MODE option in DBMS_WORKLOAD_CAPTURE.START_CAPTURE was FALSE, therefore all the active instances were expected to be in the RESTRICTED SESSION mode.
Action:
Start all instances using STARTUP RESTRICT or execute ALTER SYSTEM ENABLE RESTRICTED SESSION on all active instances before issuing DBMS_WORKLOAD_CAPTURE.START_CAPTURE.
ORA-15505: cannot start workload capture because instance string encountered errors while accessing directory "string"
Cause:
Given instance could not access the specified CAPTURE directory or the specified CAPTURE directory already had a workload capture in it.
Action:
Provide a directory object that is valid, empty and accessible from all the instances in the database cluster.
ORA-15506: cannot prepare instance string for replay
Cause:
Given instance encountered unexpected errors while trying to prepare for a workload replay.
Action:
ORA-15507: cannot start workload replay on instance string
Cause:
Given instance encountered unexpected errors while trying to start a workload replay.
Action:
ORA-15508: cannot cancel workload replay on instance string
Cause:
Given instance encountered unexpected errors while trying to cancel a workload replay.
Action:
ORA-15509: workload replay has been cancelled
Cause:
Workload replay was cancelled.
Action:
Restart the workload replay.
ORA-15510: cannot perform operation when "STATISTICS_LEVEL" is "BASIC"
Cause:
The STATISTICS_LEVEL initialization parameter was set to BASIC.
Action:
Change the STATISTICS_LEVEL initialization parameter setting to either TYPICAL or ALL.
ORA-15511: cannot process workload capture because no user sessions were recorded
Cause:
No user sessions were recorded in the given workload capture. Processing this capture failed because no user workload was captured.
Action:
Capture a workload in which at least one user session connects and performs some operations.
ORA-15512: directory "string" does not contain a valid processed workload capture
Cause:
One or more files created by DBMS_WORKLOAD_REPLAY.PROCESS_CAPTURE were missing.
Action:
Process the workload capture using DBMS_WORKLOAD_REPLAY.PROCESS_CAPTURE and then retry the command.
ORA-15513: cannot access the input directory
Cause:
Given input directory is either invalid or inaccessible.
Action:
Verify that the input directory is valid and accessible and then retry the command.
ORA-15514: cannot find a match for the remote procedure call during replay
Cause:
The corresponding PL/SQL program was either dropped or modified.
Action:
Verify that the corresponding PL/SQL program is defined the same way during replay as it was defined during workload capture.
ORA-15515: error while replaying remote procedure call: "string.string.string"
Cause:
Error encountered during the replay of a remote procedure call.
Action:
Correct the cause of the preceding error and restart workload replay.
ORA-15516: parallel preprocessing worker hit error ORA-string
Cause:
One of the parallel preprocessing workers died unexpectedly while processing the workload.
Action:
Find the root cause or simply preprocess the workload using only one process.
ORA-15517: cannot start parallel preprocessing worker
Cause:
One of the parallel preprocessing workers could not be started.
Action:
ORA-15518: parallel preprocessing encountered an unexpected error
Cause:
An unexpected error occured during parallel preprocessing.
Action:
ORA-15519: cannot access database link "string" because it is disabled
Cause:
For security considerations, access to external databases via database links were disabled during workload replay.
Action:
Use advanced parameter for Database Replay to enable database links during workload replay.
ORA-15520: Directory is corrupted. Two WMD files are found at "string" and "string"
Cause:
Two WMD files were found in the directory.
Action:
Check that the WMD files in capture directory were not modified, moved, duplicated or deleted.
ORA-15521: failed to create file "string" during workload processing
Cause:
An attempt was made to create a file during workload processing without the proper file permissions.
Action:
Correct the file permissions and try again.
ORA-15522: failed to generate a workload capture subset: "string"
Cause:
An attempt to generate a workload capture subset failed. Possible reasons are included in the error message.
Action:
Correct the issue and try again.
ORA-15551: workload replay client cannot connect to database server
Cause:
The server connection identifier was invalid.
Action:
Restart the client with correct server connection identifier.
ORA-15552: workload replay client cannot login to database server
Cause:
1) the replay client used an invalid username or password; 2) the replay user does not have the privilege to switch user; 3) the recorded username does not exist in the replay database.
Action:
1) restart replay client with correct username and password 2) grant user switching prvilege to the replay user 3) verify whether the replay database was restored properly
ORA-15553: workload replay client cannot execute the DBMS_WORKLOAD_REPLAY package
Cause:
Workload Replay Client's replay user did not have EXECUTE permission on the DBMS_WORKLOAD_REPLAY package.
Action:
Grant execute permission on the DBMS_WORKLOAD_REPLAY package to replay user and restart the Workload Replay Client.
ORA-15554: cannot start workload replay client because the database server is not in PREPARE mode
Cause:
The Workload Replay Client could not connect to the database server because the database server was not in the PREPARE mode.
Action:
Put the database in PREPARE mode by using DBMS_WORKLOAD_REPLAY.PREPARE_REPLAY, and restart the Workload Replay Client.
ORA-15555: workload replay client encountered unexpected error: "string"
Cause:
Workload Replay Client encountered an unexpected error.
Action:
Check the Workload Replay Client's log files and the database server alert log to diagnose the problem.
ORA-15556: invalid input specified to the workload replay client; type 'wrc HELP=Y' for help
Cause:
Invalid input was specified.
Action:
Use the Workload Replay Client's HELP=Y option to know more about valid input options.
ORA-15557: workload replay client cannot access the replay directory or the database version do not match the preprocessing one
Cause:
The Workload Replay Client could not access the directory that contained the workload to be replayed, or the workload was preprocessed by a different version of the database.
Action:
Restart the workload replay after specifying the correct replay directory, or preprocess it with the correct database.
ORA-15558: replay thread encountered unexpected error
Cause:
A single replay thread got disconnected from the server due to an unexpected error.
Action:
ORA-15559: workload replay client cannot open workload capture file
Cause:
The Workload Replay Client could not access one or more workload capture files from the replay directory.
Action:
Restart the workload replay after copying all the workload capture files to the replay directory.
ORA-15560: workload replay client cannot access the work directory
Cause:
The Workload Replay Client could not access the work directory to write log files for debug information.
Action:
Restart the Workload Replay Client after specifying the correct work directory.
ORA-15561: workload replay client cannot connect to the remapped connection with conn_id : string
Cause:
The specified connection is invalid or the specified host is inaccessible.
Action:
Test the specified connection using other methods and redefine the connection remapping, if necessary. Consult the view DBA_WORKLOAD_CONNECTION_MAP to inspect connection remappings.
ORA-15562: workload replay client cannot read the DBA_WORKLOAD_CONNECTION_MAP view
Cause:
The DBA_WORKLOAD_CONNECTION_MAP view did not exist or was not accessible.
Action:
Re-create the workload capture and replay views. For additional information, see the documentation.
ORA-15563: workload replay client cannot spawn new threads
Cause:
The Workload Replay Client does not have enough resource (CPU or memory) to spawn new threads.
Action:
Restart the workload replay after allocating more resource (CPU and memory) to the Workload Replay Client or use more hosts as replay clients to drive the workload.
ORA-15564: contents of the replay directory provided to the workload replay client do not match with the replay directory provided to the database server
Cause:
The processed workload capture files given to the workload replay client directory did not match the contents of the replay directory given as input to DBMS_WORKLOAD_REPLAY.INITIALIZE_REPLAY.
Action:
Provide the same processed workload capture files to both the database server and all the workload replay clients and restart the replay. If the same workload capture files were processed more than once, provide a copy of the latest processed workload capture files to all the workload replay clients and the database server.
ORA-15566: workload replay client cannot replay user call in the current version
Cause:
The workload replay client encountered a user call in the captured workload that was not supported for replay in the current version.
Action:
Look in the DBA_WORKLOAD_REPLAY_DIVERGENCE view for details about the call that encountered this error. Refer to the documentation for more details on the types of workload that are not supported in the current version.
ORA-15567: replay user string encountered an error during a sanity check
Cause:
The replay user encountered an error when accessing internal objects for Database Replay or switching user.
Action:
Set up the replay user appropriately at the replay database. Make sure the replay user can access SYS-owned objects and has BECOME USER privilege.
ORA-15568: login of user string during workload replay failed with ORA-string
Cause:
The recorded user did not exist in the replay database or encountered other problems during log in.
Action:
Check the returned error number and set up the recorded user appropriately at the replay database.
ORA-15569: timeout encountered during the replay of a recorded user call
Cause:
The replay of a recorded user call was terminated since it was significantly slower than the workload capture.
Action:
Find the root cause for the performance issue. Or, use DBMS_WORKLOAD_REPLAY API to disable the timeout check if the replay is expected to be slower.
ORA-15590: encountered incomplete workload capture files
Cause:
The captured workload contained one or more incomplete recording files. This can happen when the original workload capture's FINISH_CAPTURE command timed out while waiting for all the active sessions to close their workload capture files.
Action:
Incomplete capture files will not interfere with the processing and replaying of the captured workload. This is simply a warning message to point out that some database calls might not have been recorded due to FINISH_CAPTURE command timing out. For a list of the incomplete files, check the alert log for lines containing DBMS_WORKLOAD_REPLAY.PROCESS_CAPTURE after capture processing.
ORA-15591: encountered corrupt workload capture files
Cause:
The captured workload contained one or more corrupt recording files.
Action:
For a list of the incomplete files, check the alert log for lines containing DBMS_WORKLOAD_REPLAY.PROCESS_CAPTURE after capture processing. The corrupt files will be replayed up to the point of the corruption. Alternatively, it is possible to remove the corrupt files and run DBMS_WORKLOAD_REPLAY.PROCESS_CAPTURE again. In this case, no workload from the corrupt files will be replayed.
ORA-15601: Invalid value specified for parameter "string"
Cause:
An invalid value was specified for the given parameter.
Action:
Correct the value being specified for the parameter.
ORA-15602: Parameter "string" cannot be NULL.
Cause:
An attempt was made to call a procedure without a required parameter.
Action:
Specify a valid value for this parameter.
ORA-15603: Action cannot be performed when database is in read-only mode.
Cause:
A procedure in DBMS_AUTO_TASK_ADMIN package was invoked when database was open in read-only mode.
Action:
Retry when database is open in read/write mode.
ORA-15604: Initialization parameters prevent client from being enabled.
Cause:
An attempt was made to enable a client that was disabled for automatic execution by an initialization parameter.
Action:
Check the related client parameters and try again.
ORA-15605: "string" is not a Maintenance Window
Cause:
Window name passed to DBMS_AUTO_TASK_ADMIN.ENABLE procedure must be a member of the MAINTENANCE_WINDOW_GROUP.
Action:
Make the window a member of the MAINTENANCE_WINDOW_GROUP and retry the call.
ORA-15700: SQL limit already reached by prior task execution
Cause:
An attempt was made to resume the execution of a task when the prior execution already reached the SQL limit.
Action:
Task execution is complete. Examine the report to review Advisor's recommendations.
ORA-15701: All "SQL Tuning Set(s)" with name like "string" and owner like "string" are empty
Cause:
An attempt was made to pack one or more SQL Tuning Sets, none
* of which contained any statements.
Action:
Check the input and try again.
ORA-15702: duplicate values for plan line ID in input collection
Cause:
An invalid input was provided containing duplicate values for plan line IDs causing the load of the statement to fail.
Action:
ORA-15703: invalid version number "number" for SQL tuning set staging table
Cause:
An invalid version number was provided for a staging table used to pack a SQL tuning set.
Action:
ORA-15739: invalid name "string" for SQL Performance Analyzer task
Cause:
An invalid SQL Performance Analyzer task name was used.
Action:
Check the name of the SQL Performance Analyzer task to ensure that it is correct.
ORA-15740: parameter "string" not set for SQL Performance Analyzer task "string"
Cause:
Could not find the specified parameter name for the SQL Performance Analyzer task.
Action:
Check that the specified parameter exists for the SQL Performance Analyzer task so that the parameter is set.
ORA-15741: no COMPARE_PERFORMANCE execution exists for SQL Performance Analyzer task "string"
Cause:
Could not find an execution of type COMPARE_PERFORMANCE for specified SQL Performance Analyzer task.
Action:
Ensure that the given SQL Performance Analyzer task has at least one execution of type COMPARE_PERFORMANCE.
ORA-15742: specified execution name "string" is not a valid COMPARE_PERFORMANCE execution for SQL Performance Analyzer task "string".
Cause:
The specified execution name was not a valid execution of type COMPARE_PERFORMANCE for the SQL Performance Analyzer task.
Action:
Ensure that a valid COMPARE_PERFORMANCE execution name is used for the SQL Performance Analyzer task.
ORA-15743: need to specify the object ID if the tuning task is on a SQL set.
Cause:
There could be multiple objects in the SQL tuning task. Specify which one.
Action:
Add object ID to the interface.
ORA-15744: The directory name is null.
Cause:
The directory name for finding the SQL traces was null.
Action:
Create the directory.
ORA-15745: The plan type is not valid.
Cause:
The specified plan type was not valid
Action:
Check the existing plan types and specify the right one.
ORA-15746: Missing EXECUTE privilege on DBMS_AUTO_SQLTUNE.
Cause:
The current user was missing the necessary privileges to execute the API.
Action:
Grant the privilege and try again.
ORA-15747: The previous Oracle Data Masking job is unfinished. "string" table is not empty.
Cause:
The previously executed Oracle Data masking job was not successfully completed.
Action:
Execute Oracle Data masking cleanup.
ORA-16000: database or pluggable database open for read-only access
Cause:
The database or pluggable database was opened for read-only access. Attempts to modify the database using DML or DDL statements generate this error.
Action:
In order to modify the database or pluggable database, it must first be shut down and reopened for read/write access.
ORA-16001: database already open for read-only access by another instance
Cause:
The database has been opened for read-only access by another instance, and cannot be opened for read/write access by this instance.
Action:
This instance must be opened for read/write access, or all other instances must first be shut down and reopened for read-only access.
ORA-16002: database or pluggable database already open for read/write access by another instance
Cause:
The database or pluggable database has been opened for read/write access by another instance, and cannot be opened for read-only access by this instance.
Action:
This instance must be opened for read-only access, or all other instances must first be shut down and reopened for read/write access.
ORA-16003: standby database is restricted to read-only access
Cause:
An attempt was made to open a physical standby database in read/write mode.
Action:
Reissue the ALTER DATABASE OPEN specifying READ ONLY.
ORA-16004: backup database required recovery
Cause:
The database could not be opened for read-only access by this instance because it requires recovery.
Action:
Perform the necessary recovery and reopen for read-only access.
ORA-16005: database requires recovery
Cause:
The database requires recovery, and therefore cannot be opened for read-only access by this instance.
Action:
ORA-16006: A remote archival request was aborted due to database shutdown.
Cause:
When opening or closing a database instance, the database may wait for pending remote archival requests to complete before proceeding with the operation. This error was reported because a shutdown was detected.
Action:
This is an informational message so no action is required.
ORA-16007: invalid backup control file checkpoint
Cause:
The database could not be opened for read-only access because its control file did not contain a valid control file checkpoint.
Action:
Open the database for read/write access to create a valid control file checkpoint. The database can then be opened for read-only access.
ORA-16008: indeterminate control file checkpoint
Cause:
The control file for the database being opened for read-only access was created using the CREATE CONTROLFILE statement. Therefore, a control file checkpoint could not be calculated and the database could not be opened for read-only access.
Action:
First, open the database for read/write access. This creates a valid control file checkpoint. Then, reopen the database for read-only access.
ORA-16009: invalid redo transport destination
Cause:
The redo transport destination could not accept redo data because it was not a valid redo transport destination type.
Action:
Verify that all redo transport destinations are either standby databases or downstream capture databases.
ORA-16011: Remote File Server process is in Error state.
Cause:
The Remote File Server (RFS) process at the specified redo transport destination experienced an unrecoverable error and was unable to receive further redo data.
Action:
Correct the problem at the redo transport destination.
ORA-16012: database identifier mismatch
Cause:
The database identifier of a physical standby database did not match that of the primary database.
Action:
Ensure that the database identifier of each physical standby database matches that of the primary database.
ORA-16013: log string sequence# string does not need archiving
Cause:
An attempt was made to archive the named file manually, but the file did not require archiving. The file had previously been successfully archived.
Action:
No action is required.
ORA-16014: log string sequence# string not archived, no available destinations
Cause:
An attempt was made to archive the named log, but the archive was unsuccessful. The archival failed because there were no archive log destinations specified, or all destinations are in an error state.
Action:
Verify that archive log destinations are specified or take the necessary step to correct any errors that may have occurred.
ORA-16015: Log string sequence# string was not archived.
Cause:
An attempt was made to archive the named log to a destination, but the operation did not succeed because the destination was not in ARCHIVELOG mode.
Action:
Enable ARCHIVELOG mode at all destinations and retry.
ORA-16016: archived log for thread string sequence# string unavailable
Cause:
Redo apply timed out waiting for the requested archived log file.
Action:
Verify that the primary database is still archiving redo data to the standby database and reissue the RECOVER STANDBY DATABASE command.
ORA-16017: cannot use LOG_ARCHIVE_DUPLEX_DEST without a primary archive destination
Cause:
The parameter LOG_ARCHIVE_DUPLEX_DEST was set to a non-NULL value when the primary archive destination was set to NULL explicitly.
Action:
Set the primary archive destination to a valid non-NULL value.
ORA-16018: cannot use string with LOG_ARCHIVE_DEST_n or DB_RECOVERY_FILE_DEST
Cause:
One of the following events caused an incompatibility: 1) Parameter LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST was in use when a LOG_ARCHIVE_DEST_n (n = 1...31) parameter was encountered while fetching initialization parameters. 2) An ALTER SYSTEM ARCHIVE LOG START TO command was in effect when a LOG_ARCHIVE_DEST_n parameter was encountered while fetching initialization parameters. 3) A LOG_ARCHIVE_DEST_n parameter was in use when an ALTER SYSTEM command was used to define a value for either the LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST parameter. 4) Parameter DB_RECOVERY_FILE_DEST was in use when an attempt was made to use an ALTER SYSTEM or ALTER SESSION command to define a value for LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST.
Action:
Eliminate any incompatible parameter definitions.
ORA-16019: cannot use string with LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST
Cause:
One of the following events caused an incompatibility: 1) Parameter LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST was in use when the specified LOG_ARCHIVE_DEST_n (n = 1...31) or DB_RECOVERY_FILE_DEST parameter was encountered while fetching initialization parameters. 2) Parameter LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST was in use when an attempt was made to use an ALTER SYSTEM or ALTER SESSION command to define a value for the specified LOG_ARCHIVE_DEST_n or DB_RECOVERY_FILE_DEST parameter. 3) An ALTER SYSTEM ARCHIVE LOG START TO command was in effect when the specified LOG_ARCHIVE_DEST_n parameter was encountered while fetching initialization parameters. 4) An ALTER SYSTEM ARCHIVE LOG START TO command was in effect when an attempt was made to use an ALTER SYSTEM or ALTER SESSION command to define a value for the specified LOG_ARCHIVE_DEST_n parameter.
Action:
ORA-16020: fewer destinations available than specified by LOG_ARCHIVE_MIN_SUCCEED_DEST
Cause:
The number of archive log destinations that could be used was less than the LOG_ARCHIVE_MIN_SUCCEED_DEST parameter value.
Action:
Either adjust the log archive destination parameters, or lower the value of LOG_ARCHIVE_MIN_SUCCEED_DEST.
ORA-16021: session string destination cannot be the same as session string destination
Cause:
An attempt was made to change the first specified archive log parameter using ALTER SESSION to have a destination value that duplicates the session-level destination value of the second specified archive log parameter.
Action:
Specify a different session destination value for one of the LOG_ARCHIVE_DEST_n parameters.
ORA-16022: LOG_ARCHIVE_DEST cannot be NULL because LOG_ARCHIVE_DUPLEX_DEST is non-NULL
Cause:
An attempt was made to change parameter LOG_ARCHIVE_DEST to NULL when parameter LOG_ARCHIVE_DUPLEX_DEST is non-NULL.
Action:
Either set parameter LOG_ARCHIVE_DEST to a non-NULL value, or set parameter LOG_ARCHIVE_DUPLEX_DEST to a NULL value.
ORA-16023: system string destination cannot be the same as session string destination
Cause:
An attempt to change the first specified LOG_ARCHIVE_DEST_n (n = 1...31) parameter produced a destination that duplicates the session destination value of the second specified LOG_ARCHIVE_DEST_n parameter. This error can occur when setting a non-NULL value with the ALTER SYSTEM command. Or, this error can occur when setting a NULL value with ALTER SESSION command, because then the associated system destination value may appear as a duplicate.
Action:
Specify a different destination value for the first specified LOG_ARCHIVE_DEST_n parameter.
ORA-16024: parameter string cannot be parsed
Cause:
The value for the indicated LOG_ARCHIVE_DEST_n (n = 1...31) parameter could not be parsed. Common causes for this error are a misplaced equal sign, an unrecognized attribute, or an attribute that is missing a required value.
Action:
Correct the value for the indicated LOG_ARCHIVE_DEST_n parameter.
ORA-16025: parameter string contains repeated or conflicting attributes
Cause:
The value for the specified LOG_ARCHIVE_DEST_n (n = 1...31) parameter contained either repeated attributes or attributes that conflicted with each other.
Action:
ORA-16026: parameter string contains an invalid attribute value
Cause:
The value for the specified LOG_ARCHIVE_DEST_n (n = 1...31) parameter contained an attribute with an invalid value.
Action:
ORA-16027: parameter string is missing a destination option
Cause:
The value for the indicated LOG_ARCHIVE_DEST_n (n = 1...31) parameter failed to include a destination option. A destination option is specified using either the LOCATION or SERVICE attrbute.
Action:
ORA-16028: new string causes less destinations than LOG_ARCHIVE_MIN_SUCCEED_DEST requires
Cause:
An attempt was made to change the indicated LOG_ARCHIVE_DEST_n or LOG_ARCHIVE_DEST_STATE_n parameter (n = 1...31) to a value that reduces the number of archive log destinations to less than the specified LOG_ARCHIVE_MIN_SUCCEED_DEST value.
Action:
Either select different options for the LOG_ARCHIVE_DEST_n or LOG_ARCHIVE_DEST_STATE_n parameters, or reduce the value for parameter LOG_ARCHIVE_MIN_SUCCEED_DEST.
ORA-16029: cannot change LOG_ARCHIVE_MIN_SUCCEED_DEST, no archive log destinations
Cause:
An attempt was made to change the LOG_ARCHIVE_MIN_SUCCEED_DEST parameter when there are no archive log destinations.
Action:
Define one or more log archive destinations using parameters LOG_ARCHIVE_DEST, LOG_ARCHIVE_DUPLEX_DEST, or LOG_ARCHIVE_DEST_n (n = 1...31). Then, change the value of parameter LOG_ARCHIVE_MIN_SUCCEED_DEST.
ORA-16030: session specific change to the LOG_ARCHIVE_MIN_SUCCEED_DEST parameter requires a LOG_ARCHIVE_DEST_n destination
Cause:
The following event caused an incompatibility: Parameter LOG_ARCHIVE_DEST or LOG_ARCHIVE_DUPLEX_DEST was in use when an attempt was made to change the LOG_ARCHIVE_MIN_SUCCEED_DEST parameter with an ALTER SESSION command.
Action:
Replace any LOG_ARCHIVE_DEST and LOG_ARCHIVE_DUPLEX_DEST parameters with LOG_ARCHIVE_DEST_n (n = 1...31) parameters.
ORA-16031: parameter string destination string exceeds string character limit
Cause:
The value for the specified parameter contained a destination string that is too long.
Action:
Replace the destination value for the specified parameter with a character string that has a length below the limit specified in the error message.
ORA-16032: parameter string destination string cannot be translated
Cause:
The value for the specified parameter contained a destination string that could not be translated.
Action:
Use a valid destination string in the specified parameter.
ORA-16033: parameter string destination cannot be the same as parameter string destination
Cause:
An attempt was made to change the first specified archive log parameter to have a destination value that duplicates the system-level destination value of the second specified archive log parameter.
Action:
Specify a different value for one of the archive log parameters.
ORA-16034: Recovery could not be started.
Cause:
Database recovery could not be started because the FROM and MANAGED STANDBY DATABASE clauses were both specifed when attempting to start recovery.
Action:
Retry the command with either the FROM or MANAGED STANDBY DATABASE clause, but not both.
ORA-16035: missing required keyword string
Cause:
The indicated keyword is required but was not specified.
Action:
Correct the syntax and retry the command.
ORA-16036: invalid CANCEL option
Cause:
A mode other than IMMEDIATE followed the CANCEL keyword in RECOVER MANAGED STANDBY DATABASE statement.
Action:
Specify either nothing or IMMEDIATE following CANCEL.
ORA-16037: user requested cancel of managed recovery operation
Cause:
The managed standby database recovery operation has been canceled per user request.
Action:
ORA-16038: log string sequence# string cannot be archived
Cause:
An attempt was made to archive the named file, but the file could not be archived. Examine the secondary error messages to determine the cause of the error.
Action:
ORA-16039: RFS request version mismatch
Cause:
A request to archive a redo log to a redo transport destination failed because of an Oracle software version mismatch at the destination.
Action:
Verify that a compatible version of Oracle software is running at the redo transport destination.
ORA-16040: Destination archive log file is locked.
Cause:
The target archive log file was locked. This indicates that the file is being archived to another Remote File Server (RFS) process.
Action:
Ensure that each remote redo transport destination uses a unique network service name.
ORA-16041: Remote File Server fatal error
Cause:
The Remote File Server (RFS) process at a redo transport destination encountered a fatal error and was no longer available. Further redo transmission to this destination may not be possible.
Action:
Refer to the appropriate RFS trace file located at the redo transport destination for details regarding the error encountered and take corrective action.
ORA-16042: user requested cancel immediate of redo apply
Cause:
Redo apply was canceled immediately per user request. Processing of the current archive log file has been interrupted and, therefore, the database is in an inconsistent state.
Action:
ORA-16043: Redo apply has been canceled.
Cause:
Redo apply was canceled per user request or operation timeout.
Action:
More specific messages will accompany this message.
ORA-16044: Destination string attribute cannot be specified at session level.
Cause:
An attempt was made to modify a redo transport destination attribute using the ALTER SESSION command.
Action:
Use the ALTER SYSTEM command to modify the destination attribute.
ORA-16045: circular redo transport destination dependency chain
Cause:
An attempt was made to make a redo transport destination dependent on a redo transport destination that was dependent on it.
Action:
Ensure that no redo transport destination is dependent on any destination that is dependent on it.
ORA-16046: Redo transport destination failed due to failed dependent destination.
Cause:
The redo transport destination was dependent upon another destination, which failed. Therefore, this destination failed.
Action:
No action required.
ORA-16047: DGID mismatch between destination setting and target database
Cause:
The DB_UNIQUE_NAME specified for the destination did not match the DB_UNIQUE_NAME at the target database.
Action:
Make sure the DB_UNIQUE_NAME specified in the LOG_ARCHIVE_DEST_n parameter matches the DB_UNIQUE_NAME parameter defined at the destination.
ORA-16050: destination exceeded specified quota size
Cause:
An archive log was attempted to be created in a destination with a specified maximum quota size. The creation of the archive log exceeded the specified quota size. Therefore, the destination has been made inaccessible to future archival operations.
Action:
ORA-16051: parameter string contains an invalid delay time
Cause:
The value for the specified LOG_ARCHIVE_DEST_n (n = 1...31) parameter contained a DELAY attribute with an invalid numeric value. The valid range is 0-5760 (in minutes).
Action:
ORA-16052: DB_UNIQUE_NAME attribute is required.
Cause:
DB_UNIQUE_NAME attribute was not specified. The value of the LOG_ARCHIVE_DEST_n parameter for each remote redo transport destination must contain the DB_UNIQUE_NAME attribute if the LOG_ARCHIVE_CONFIG parameter value contains the DG_CONFIG attribute.
Action:
Use the DB_UNIQUE_NAME attribute to specify the DB_UNIQUE_NAME for the destination.
ORA-16053: DB_UNIQUE_NAME string is not in the Data Guard Configuration
Cause:
The specified DB_UNIQUE_NAME is not in the Data Guard Configuration.
Action:
If the DG_CONFIG attribute of the LOG_ARCHIVE_CONFIG parameter is enabled, you must specify a valid DB_UNIQUE_NAME. The list of valid DB_UNIQUE_NAMEs can be seen with the V$DATAGUARD_CONFIG view. This problem can also occur when specifying a non-standby destination with an DB_UNIQUE_NAME attribute that does not match the DB_UNIQUE_NAME initialization parameter for the current instance.
ORA-16055: FAL request rejected
Cause:
Fetch archive log (FAL) server rejected a redo gap fetch request from the client. This may have various causes.
Action:
Check the alert log on the primary database. Take the appropriate action to solve the problem.
ORA-16056: Backup control file archival requires proper syntax.
Cause:
An attempt was made to perform an online log file archival using a backup control file. However, the USING BACKUP CONTROLFILE syntax was not specified.
Action:
Use the USING BACKUP CONTROLFILE clause to perform an online log file archival using a backup control file.
ORA-16057: server not in Data Guard configuration
Cause:
The primary database or fetch archive log (FAL) server was not found in the Data Guard configuration of the standby database.
Action:
Add the database unique name of the primary database or FAL server to the DG_CONFIG attribute of the LOG_ARCHIVE_CONFIG database initialization parameter.
ORA-16058: standby database instance is not mounted
Cause:
The Remote File Server (RFS) process on the standby database received an internal error.
Action:
Check the standby alert log and RFS trace files for more information.
ORA-16059: empty log file or invalid next available block
Cause:
An attempt was made to archive an empty or invalid log file.
Action:
ORA-16060: Log file is current.
Cause:
An attempt was made to archive current log file.
Action:
ORA-16061: Log file status has changed.
Cause:
The online log file was reclaimed as a new log file either before archival started or during the archival operation.
Action:
ORA-16062: standby database not in Data Guard configuration
Cause:
The standby database was not found in the Data Guard configuration of the server.
Action:
Add the database unique name of the standby database to the DG_CONFIG attribute of the LOG_ARCHIVE_CONFIG database initialization parameter.
ORA-16065: remote archival disabled at standby destination
Cause:
Receipt of remote archived REDO log files has been disabled at the associated standby destination host database.
Action:
If appropriate change the associated archive log parameter to specify a local destination with the LOCATION keyword or defer the associated archive log destination. Or, if possible, set the standby REMOTE_ARCHIVE_ENABLE parameter to TRUE, or enable the RECEIVE attribute of the LOG_ARCHIVE_CONFIG parameterand restart the standby database instance before further REDO log file archivals occur.
ORA-16066: remote archival disabled
Cause:
An archive log destination parameter has specified a remote destination with the SERVICE keyword. Remote archival of REDO log files has been disabled for this database. The associated archive log destination has been disabled.
Action:
If appropriate change the archive log parameter to specify a local destination with the LOCATION keyword or (if appropriate) set the REMOTE_ARCHIVE_ENABLE parameter to TRUE, or enable the SEND attribute of the LOG_ARCHIVE_CONFIG parameter and restart the database instance before further REDO log file archivals occur.
ORA-16067: activation identifier mismatch in archive log string
Cause:
The activation identifier contained in the archive log file header does not match the activation identifier of the database being recovered. The indicated archive log cannot be applied to the database.
Action:
Locate the appropriate archive log for the database.
ORA-16068: redo log file activation identifier mismatch
Cause:
The activation identifier of the indicated redo log file does not match the activation identifier of the database.
Action:
n/a
ORA-16069: activation identifier mismatch
Cause:
Redo transport failed because the activation identifier of the primary and physical standby databases did not match. This can happen if the physical standby database was not created from a backup of the primary database.
Action:
Create a valid configuration and re-try the failed operation.
ORA-16070: parameter string contains an invalid REGISTER attribute value
Cause:
The value for the specified LOG_ARCHIVE_DEST_n (n = 1...31) parameter contained a REGISTER attribute that specified an invalid file name template string. If specified, the REGISTER file name template string must indicate an O/S-specific file path name including thread and log sequence number substitution directives (%t, %T, %s, %S).
Action:
Correct the value for the LOG_ARCHIVE_DEST_n parameter.
ORA-16071: Archived log file string was not found at dependency destination.
Cause:
The specified archived log file was not found at a redo tranpsort destination on which other destinations are dependent.
Action:
Verify that all redo transport destinations that are dependent upon another destination or upon which other destinations are dependent are configured correctly.
ORA-16072: a minimum of one standby database destination is required
Cause:
No standby database archive log destinations were specified.
Action:
Specify a standby archive log destination in the initialization parameter file.
ORA-16073: archiving must be enabled
Cause:
Online log file archiving is disabled.
Action:
Enable log file archiving.
ORA-16074: No ARCH processes are active.
Cause:
All ARCH processes have stopped.
Action:
Restart the instance.
ORA-16075: standby database destination mismatch
Cause:
Another instance had access to a standby database destination that this instance did not. If the initialization parameter LOG_ARCHIVE_CONFIG does not define a DG_CONFIG, this may be due to a standby database becoming unavailable recently.
Action:
Ensure that at each instance the set of standby databases referred to by LOG_ARCHIVE_DEST_n initialization parameters is the same and define a DG_CONFIG at each instance to identify those databases explicitly.
ORA-16076: unknown standby database destination
Cause:
A standby database destination was specified that was not accessed by another instance. If the initialization parameter LOG_ARCHIVE_CONFIG does not define a DG_CONFIG, this mismatch may be due to a standby database having been restarted recently.
Action:
ORA-16078: media recovery disabled
Cause:
The database is not in ARCHIVELOG mode.
Action:
Place the database in ARCHIVELOG mode.
ORA-16079: standby archival not enabled
Cause:
The standby database did not have archival enabled.
Action:
In order to allow the standby database to access the standby log files, the standby database must be in ARCHIVELOG mode.
ORA-16080: invalid LogMiner session string for APPLY
Cause:
Logical standby apply engine was started with an invalid LogMiner session identifier.
Action:
Fix the problem with the LogMiner session or create a new session.
ORA-16081: insufficient number of processes for APPLY
Cause:
Logical standby apply engine was started with fewer processes available than needed.
Action:
Increase the values of the initialization parameters PROCESSES and or the MAX_SERVERS parameter seen in the DBA_LOGSTDBY_PARAMETERS view.
ORA-16082: logical standby is not initialized correctly
Cause:
Logical standby apply engine was started but it found inconsistencies in its metadata.
Action:
Look in the trace file for more information.
ORA-16083: LogMiner session has not been created
Cause:
Logical standby apply engine was started without creating a LogMiner session.
Action:
Create a LogMiner session and restart the apply engine.
ORA-16084: an apply engine is already running
Cause:
A logical standby apply engine was running when another was created.
Action:
Shut down the previous apply engine before starting a new one.
ORA-16086: Redo data cannot be written to the standby redo log
Cause:
The primary database was in MAXIMUM PROTECTION or MAXIMUM AVAILABILITY mode, but redo data could not be written to the standby redo log at the standby database(s).
Action:
Check the Remote File Server (RFS) trace file for specific errors and reconfigure the standby redo log as appropriate.
ORA-16087: Switchover requires standby or current control file.
Cause:
An attempt was made to perform a switchover operation using a backup or clone control file.
Action:
Convert the backup control file into a current control file prior to attempting a switchover operation. A clone control file cannot be used for a switchover operation.
ORA-16088: archive log has not been completely archived
Cause:
An attempt was made to register an archive log that has not been completely archived. The specified archive log may be a "current" log file.
Action:
Specify a completed archive log.
ORA-16089: archive log has already been registered
Cause:
An attempt was made to register an archive log that already has a corresponding thread# and sequence# entry in the standby database control file. Duplicate information is not permitted.
Action:
Use the V$ARCHIVED_LOG fixed view to verify the archive log information.
ORA-16090: archive log to be replaced not created by managed standby process
Cause:
An attempt was made to replace an archive log entry that was not originally created by the managed standby operation.
Action:
No user action required.
ORA-16091: dependent archive log destination already archived
Cause:
An archive log destination contains a dependency to another archive log destination that has previously been archived.
Action:
The parent archive log destination cannot be dependent on another archive log destination. Use the ALTER SYSTEM command to remove one of the dependency attributes.
ORA-16092: dependent archive log destination is not active
Cause:
An archive log destination contains a dependency to another archive log destination that is not active"
Action:
The child archive log destination cannot be dependent on another invalid archive log destination. Use the ALTER SYSTEM command to remove one of the dependency attributes.
ORA-16093: dependent archive log destination is not LGWR-enabled
Cause:
An archive log destination contains a dependency to another archive log destination that is not enabled for the LGWR process"
Action:
The child archive log destination cannot be dependent on another archive log destination not archived by the LGWR. Use the ALTER SYSTEM command to change the parent archive log to specify the LGWR process.
ORA-16094: Database shut down during archival operation.
Cause:
The database was shut down while an online log file archival was active.
Action:
None required.
ORA-16095: Dependent destination removal for inactivation
Cause:
A dependent archive log destination was inactivated due to the parent archive log destination becoming inelligible for archival. This may be due to the parent destination being manually deferred by an application user.
Action:
None required.
ORA-16096: ALTER DATABASE COMMIT TO SWITCHOVER TO PHYSICAL STANDBY
Cause:
None
Action:
Specify this command to switch the primary database to the physical standby role.
ORA-16097: ALTER DATABASE COMMIT TO SWITCHOVER TO PRIMARY
Cause:
None
Action:
Specify this command to switch the physical standby database to the primary role.
ORA-16098: Primary database has been shut down to prevent data loss.
Cause:
The primary database was shut down because it was operating in maximum protection mode and no suitable standby databases were available to protect the primary database from data loss.
Action:
Diagnose and correct whatever errors exist in the configuration or configure the primary database for maximum availability or maximum performance mode.
ORA-16099: internal error ORA-00600 occurred at standby database
Cause:
The RFS process on the standby database received an internal error.
Action:
ORA-16100: not a valid Logical Standby database
Cause:
This database has not been completely configured as a Logical Standby database.
Action:
Verify that the database is the intended Logical Standby database. Ensure that you already started logical standby apply with the ALTER DATABASE START LOGICAL APPLY INITIAL statement. See the Oracle8i SQL Reference manual for the statement syntax.
ORA-16101: a valid start SCN could not be found
Cause:
An SCN from which to start could not be found.
Action:
Register the first log file following the backup from which this database was generated. Using the ALTER DATABASE REGISTER LOGILE statement to register the database is recommended. Alternatively, you can provide a starting SCN value with this startement.
ORA-16102: remote information is not available on the specified primary
Cause:
The new primary has not completed generating the necessary information for the standby to begin consuming its log stream.
Action:
Verify that the database link provided references a system that is about to become a new primary. Wait a short time before retrying the command to allow the primary some time to generate the necessary information.
ORA-16103: Logical Standby apply must be stopped to allow this operation
Cause:
Logical Standby is currently applying changes. The apply must complete or be stopped to allow the requested operation.
Action:
Execute the ALTER DATABASE STOP LOGICAL STANDBY APPLY statement, then re-enter or respecify the operation.
ORA-16104: Invalid Logical Standby parameter
Cause:
The specified parameter is not valid.
Action:
Check spelling or refer to the DBMS_LOGSTDBY PL/SQL package documentation for the correct statement syntax.
ORA-16105: Logical Standby is already running in background
Cause:
A Logical Standby apply operation is already running.
Action:
None
ORA-16106: loading previously applied transaction information
Cause:
Logical Standby coordinator was performing a scan to identify previously applied transactions.
Action:
No action necessary. This informational statement is provided to record the event for diagnostic purposes.
ORA-16107: all log data from primary has been processed
Cause:
On the primary system, the log stream has been ended by the ALTER DATABASE COMMIT TO SWITCHOVER TO LOGICAL STANDBY command.
Action:
Issue one of the following commands to make this standby a primary or resume applying changes from a new primary. ALTER DATABASE COMMIT TO SWITCHOVER TO LOGICAL PRIMARY; ALTER DATABASE START LOGICAL STANDBY APPLY NEW PRIMARY dblink;
ORA-16108: database is no longer a standby database
Cause:
The current database has already been made a primary database.
Action:
Issue the following commands to make this primary a standby. ALTER DATABASE COMMIT TO SWITCHOVER TO LOGICAL STANDBY; ALTER DATABASE START LOGICAL STANDBY APPLY NEW PRIMARY dblink;
ORA-16109: failed to apply log data from previous primary
Cause:
Log data from previous primary could not be completely applied.
Action:
Check DBA_LOGSTDBY_EVENTS for failures and take corrective action. Then, reissue command.
ORA-16110: user procedure processing of logical standby apply DDL
Cause:
A user provided stored procedure has been called to inspect a DDL statement prior to it being processed.
Action:
No action necessary, this informational statement is provided to record user involvement in the processing of a statement. Additional information can be found in the DBA_LOGSTDBY_EVENTS and the DBA_LOGSTDBY_SKIP views.
ORA-16111: log mining and apply setting up
Cause:
This logical standby process is setting up to begin processing changes.
Action:
No action necessary, this informational statement is provided to record the event for diagnostic purposes.
ORA-16112: log mining and apply stopping
Cause:
This logical standby process is cleaning up and stopping Logical Standby apply.
Action:
ORA-16113: applying change to table or sequence string
Cause:
The process is applying changes to a specific schema object.
Action:
ORA-16114: applying DDL transaction with commit SCN string
Cause:
The process is applying a DDL change that's committed at the given SCN.
Action:
ORA-16115: string\% of LogMiner dictionary loading is done
Cause:
The process is loading dictionary information from the redo stream. This activity may take a few minutes.
Action:
ORA-16116: no work available
Cause:
The process is idle waiting for additional changes to be made available.
Action:
ORA-16117: processing
Cause:
The process is performing its primary function and is not waiting on any significant event.
Action:
ORA-16119: building transaction at SCN string
Cause:
The transaction being committed at the given SCN is being prepared for apply.
Action:
ORA-16120: dependencies being computed for transaction at SCN string
Cause:
The transaction committed at the given SCN is being analyzed for dependencies.
Action:
ORA-16121: applying transaction with commit SCN string
Cause:
The transaction committed at the given SCN is being applied.
Action:
ORA-16122: applying large dml transaction at SCN string
Cause:
A large transaction is being applied before the commit has been seen. The current redo being applied ends as the given SCN.
Action:
ORA-16123: transaction string string string is waiting for commit approval
Cause:
The apply process is waiting for approval to commit a transaction. This transaction may depend on another or other synchronization activity may delay the committing of a transaction.
Action:
ORA-16124: transaction string string string is waiting on another transaction
Cause:
The apply process is waiting to apply additional changes. This transaction likely depends on another.
Action:
ORA-16125: large transaction string string string is waiting for more data
Cause:
The apply process is waiting until additional changes for a large transaction are retrieved from the log stream.
Action:
ORA-16126: loading table or sequence string
Cause:
Information on the given table or sequence is being loaded into an in memory cache for future use.
Action:
ORA-16127: stalled waiting for additional transactions to be applied
Cause:
This process is waiting for additional memory before continuing. Additional log information cannot be read into memory until more transactions have been applied to the database, thus freeing up additional memory.
Action:
No action necessary, this informational statement is provided to record the event for diagnostic purposes. If this message occurs often and changes are not being applied quickly, increase available SGA or the number of apply processes.
ORA-16128: User initiated stop apply successfully completed
Cause:
Logical standby was shutdown in an orderly fashion.
Action:
ORA-16129: unsupported DML encountered
Cause:
One or more DMLs to an unsupported table were encountered and skipped.
Action:
No action necessary. This informational statement is provided to record the event for diagnostic purposes. Optionally, check the DBA_LOGSTDBY_EVENTS view for more information including the impacted table owner and name.
ORA-16130: supplemental log information is missing from log stream
Cause:
Supplemental logging is not enabled at the primary database.
Action:
Issue the following command to enable supplemental logging. ALTER DATABASE ADD SUPPLEMENTAL LOG DATA (PRIMARY KEY, UNIQUE INDEX) COLUMNS;
ORA-16131: An error occurred during a Terminal Recovery of the standby.
Cause:
Action:
Check the standby alert log additional information.
ORA-16132: An error occurred during activation of the standby.
Cause:
An error occurred during activation of the standby database following a Terminal Recovery.
Action:
ORA-16133: Datafile string has incorrect terminal recovery stamp.
Cause:
After activation of a standby database following a terminal recovery (recovery of standby using current logs), recovery of a datafile from before the activation must have completed the same terminal recovery to avoid corruption.
Action:
A backup of the datafile taken after the terminal recovery and before activating the standby must be used for recovery.
ORA-16134: invalid MANAGED recovery FINISH option
Cause:
A mode other than NOWAIT follows the FINISH keyword in RECOVER MANAGED STANDBY DATABASE statement.
Action:
Specify either nothing or NOWAIT following FINISH.
ORA-16135: Invalid LOG_ARCHIVE_CONFIG modification while in protected mode
Cause:
The LOG_ARCHIVE_CONFIG parameter can not be modified while any RAC instance is open in either maximum protection or maximum availability mode. Also, the parameter can not be modified in such way that would cause all destinations to fail while in maximum protection mode.
Action:
Make the modification before the database is opened by any instance.
ORA-16136: Managed Standby Recovery not active
Cause:
An attempt was made to cancel a managed recovery session but no managed recovery session was active.
Action:
No action is necessary.
ORA-16138: end of log stream not received from primary
Cause:
The standby system has not received notification that the primary system log stream has been terminated. A graceful switchover is not possible.
Action:
Verify that the primary log stream has been terminated. Ensure that the standby has applied all necessary redo from the primary system and, if appropriate, reissue the graceful switchover command.
ORA-16139: media recovery required
Cause:
An error has occurred while performing a switchover.
Action:
If you were switching a primary database to the standby role, the conversion was successful, but one or more errors occurred after the conversion completed. See the alert log for more information. You can proceed with switching the target standby database to the primary role, but you must address the errors reported at the old primary database before it can protect the new primary database. If you encountered this error while switching a physical standby database to the primary role, the switchover did not succeed because additional redo must be applied. Verify that redo apply is active and wait until the SWITCHOVER_STATUS column of the V$DATABASE dynamic performance view reports TO_PRIMARY or SESSIONS_ACTIVE before retrying the switchover.
ORA-16140: standby online logs have not been recovered
Cause:
The standby database has online logs containing redo that has not been recovered. Activating the standby would lose redo contained in the online logs.
Action:
To recover the standby online logs issue the following command: ALTER DATABASE RECOVER MANAGED STANDBY DATABASE FINISH. Then reissue the ALTER DATABASE ACTIVATE STANDBY DATABASE command. To activate the standby without recovering the online logs, issue the following command: ALTER DATABASE ACTIVATE STANDBY DATABASE SKIP STANDBY LOGFILE.
ORA-16143: RFS connections not allowed during or after terminal recovery
Cause:
An attempt was made, by an RFS process, to access a standby online log file during or after a terminal recovery.
Action:
The primary must not attempt to archive to the standby after a terminal recovery.
ORA-16145: archival for thread# string sequence# string in progress
Cause:
The indicated archived log file is not available for recovery due to the fact that it is still being archived.
Action:
Verify that archival of the indicated log file has completed and reissue the RECOVER STANDBY DATABASE command.
ORA-16146: stringcontrol file enqueue unavailable
Cause:
The control file enqueue is currently unavailable.
Action:
No Action is required. We will try to re-fetch it at a later time.
ORA-16147: standby database referenced by multiple archive log destinations
Cause:
Multiple archive log destinations reference the same standby database, using different service names. This is not allowed.
Action:
Remove one of the duplicate archive log destinations.
ORA-16148: user requested expiration of managed recovery operation
Cause:
The managed standby database recovery operation has been canceled per user specified EXPIRE option of the RECOVER MANAGED STANDBY DATABASE statement.
Action:
ORA-16150: FINISH recovery performed on another, older standby database
Cause:
An archive log containing a FINISH recovery indicator was received by a standby database that has received archive logs in the future of the received archive log. Because of the possibility that these future archive logs have been applied to this standby database, the received archive log must be rejected.
Action:
ORA-16151: Managed Standby Recovery not available
Cause:
The attempted operation failed because of a pending CANCEL of the managed standby recovery operation.
Action:
Wait for the managed standby recovery session to end. Then retry the operation.
ORA-16152: standby database is in 'no-data-loss' protected mode
Cause:
The attempted database operation is not allowed while the standby database is in 'no-data-loss' protected mode.
Action:
Verify that the attempted database operation is warranted, ALTER DATABASE SET STANDBY DATABASE UNPROTECTED and reissue the statement.
ORA-16154: suspect attribute: string
Cause:
Use of the indicated attribute is illegal in the given context.
Action:
Make the appropriate changes and reissue the statement.
ORA-16156: LGWR archive log dependency not allowed if database is standby protected
Cause:
The use of a LGWR archive log dependency is not allowed when the primary is protected by a standby database, as this requires use of the standby redo log files.
Action:
Remove the LGWR archive log dependency and use normal LGWR archival instead.
ORA-16157: media recovery not allowed following successful FINISH recovery
Cause:
A RECOVER MANAGED STANDBY DATABASE FINISH command has previously completed successfully. Another media recovery is not allowed.
Action:
Issue one of these operations following a FINISH recocvery: ALTER DATABASE OPEN READ ONLY or ALTER DATABASE COMMIT TO SWITCHOVER TO PRIMARY.
ORA-16159: Cannot change protected standby destination attributes
Cause:
An attempt was made to change the LGWR/ARCH or SYNC/ASYNC attributes for a destination that is participating in the standby protection mode of the database.
Action:
ORA-16160: Cannot change protected standby database configuration
Cause:
An attempt was made to change the standby database configuration when the primary database is in standby protected mode.
Action:
The standby database must be added to the configuration before the primary database is opened.
ORA-16161: Cannot mix standby and online redo log file members for group string
Cause:
An attempt was made to add a log file member that did not match the other member types. This problem typically occurs when adding a standby log file member to an online redo log file group, or adding an online redo log file member to a standby redo log file group.
Action:
Verify the log file group type using the TYPE column of the V$LOG fixed view.
ORA-16162: Cannot add new standby databases to protected configuration
Cause:
An attempt was made to enable a new standby database destination when the primary database is in standby protected mode.
Action:
ORA-16163: LGWR network server host attach error
Cause:
The LGWR network server could not attach to remote host
Action:
The alert log contains more problem-specific information
ORA-16164: LGWR network server host detach error
Cause:
The LGWR network server could not detach from remote host
Action:
ORA-16165: LGWR failed to hear from network server
Cause:
The LGWR lost its connection to the network server
Action:
ORA-16166: LGWR network server failed to send remote message
Cause:
The LGWR network server could not communicate with the remote host
Action:
ORA-16167: LGWR network server could not switch to non-blocking mode
Cause:
The LGWR network server could not switch to non-blocking mode
Action:
ORA-16168: LGWR network server could not switch to blocking mode
Cause:
The LGWR network server could not switch to blocking mode
Action:
ORA-16169: LGWR network server invalid parameters
Cause:
Action:
ORA-16170: Terminal recovery may have left the database in an inconsistent state
Cause:
When terminal recovery is invoked in a standby database without synchronous log shipping, in the rare case of the recovery session being in an unrecoverable state, terminal recovery cannot bring the standby database to a consistent SCN boundary if the primary database continues to have redo thread(s) open.
Action:
Continue standby recovery with additional log shipping from primary.
ORA-16171: RECOVER...FINISH not allowed due to gap for thr string, seq string-string
Cause:
See alert log for more details
Action:
Copy missing archived logs from primary or another standby. Register the logs and reissue the RECOVER...FINISH command. If the logs are not available, issue the ALTER DATABASE RECOVER MANAGED STANDBY SKIP command to ignore the standby redo log files.
ORA-16172: archive logs detected beyond Terminal End-Of-Redo
Cause:
An attempt to archive a Terminal End-Of-Redo archive log to a remote destination failed due the existence, at the remote site, of archive logs containing REDO in the future of the Terminal EOR.
Action:
n/a
ORA-16173: incompatible archival network connections active
Cause:
One of two situations can cause this error: 1) An attempt to start a Terminal Incomplete Recovery operation failed due to an active Remote File Server process detected. 2) An attempt to archive a Terminal End-Of-Redo archive log to a remote destination failed due to an active Remote File Server process at the remote site. An active Remote File Server (RFS) process implies connectivity with the primary database which may indicate that a Terminal Incomplete Recovery operation is not warrented.
Action:
Verify the Managed Standby environment and re-evaluate the necessity of a Terminal Incomplete Recovery operation.
ORA-16174: user requested thread/sequence termination of managed recovery
Cause:
The managed standby database recovery operation has been terminated per user specified THROUGH THREAD/SEQUENCE option of the RECOVER MANAGED STANDBY DATABASE statement.
Action:
ORA-16175: cannot shut down database when media recovery is active
Cause:
An attempt was made to shut down a standby database while media recovery was active.
Action:
Cancel media recovery to proceed with the shutdown.
ORA-16176: background dictionary build cannot be running
Cause:
The background process dedicated to dictionary build is active.
Action:
wait and try it later.
ORA-16177: media recovery is not required
Cause:
The THROUGH LAST SWITCHOVER clause of the ALTER DATABASE RECOVER MANAGED STANDBY DATABASE was specified and the database has been recovered to the most recent End-Of-Redo marker. All known archived logs have been applied. Managed recovery is not required.
Action:
No action is necessary. The standby database may be activated as a new primary or may continue as a standby.
ORA-16178: Cannot specify remote destinations in manual archiving mode
Cause:
The database is operating in manual archiving mode. Remote archivelog destinations are not allowed in this mode.
Action:
Use the ALTER DATABASE ARCHIVELOG command to place the database in automatic ARCHIVELOG mode, or defer the archivelog destinations that specify the SERVICE= attribute.
ORA-16179: incremental changes to "string" not allowed with SPFILE
Cause:
Incremental changes to a log_archive_dest_n parameter cannot be made when using an SPFILE.
Action:
Specify either LOCATION or SERVICE plus all other attributes to be set in one ALTER SYSTEM/SESSION SET command.
ORA-16180: number of processes specified is too large
Cause:
The number of server processes available for Logical Standby is currently limited to 1024 LogMiner processes and 1024 apply processes or a total of 2048.
Action:
Retry with a lower value.
ORA-16181: SGA specified for Logical Standby is too large
Cause:
MAX_SGA is larger than 75% of the larger of initialization parameters SHARED_POOL_SIZE, MEMORY_TARGET, and SGA_TARGET.
Action:
Specify the value of MAX_SGA to be less than 75% of the maximum of SHARED_POOL_SIZE, MEMORY_TARGET, and SGA_TARGET.
ORA-16182: Internal error on internal channel during remote archival
Cause:
An internal error was encountered on the internal channel between LGWR and Network Server.
Action:
No action is required, as an attempt will be made to re-archive the file that had this failure during archival.
ORA-16184: DB_UNIQUE_NAME string hashes to the same value as DB_UNIQUE_NAME string
Cause:
The internal hash value generated for one DB_UNIQUE_NAME collided with the hash value of another DB_UNIQUE_NAME.
Action:
Slightly modify one of the DB_UNIQUE_NAMEs so it hashes to a different value.
ORA-16185: REMOTE_ARCHIVE_ENABLE and LOG_ARCHIVE_CONFIG mutually exclusive
Cause:
Both the REMOTE_ARCHIVE_ENABLE and LOG_ARCHIVE_CONFIG parameters are defined in the initialization file and they are mutually exclusive.
Action:
The REMOTE_ARCHIVE_ENABLE parameter has been made obsolete. Use only the LOG_ARCHIVE_CONFIG parameter.
ORA-16186: Modifying LOG_ARCHIVE_CONFIG requires SID='*' qualifier
Cause:
The setting for the LOG_ARCHIVE_CONFIG parameter must be exactly the same on all RAC instances so the SID='*' qualifier is required.
Action:
Re-enter the command using the SID='*' qualifier.
ORA-16187: LOG_ARCHIVE_CONFIG contains duplicate, conflicting or invalid attributes
Cause:
The LOG_ARCHIVE_CONFIG parameter was specified with duplicate, conflicting or invalid attributes.
Action:
Check the documentation regarding the correct specification of the LOG_ARCHIVE_CONFIG parameter.
ORA-16188: LOG_ARCHIVE_CONFIG settings inconsistent with previously started instance
Cause:
The settings for the LOG_ARCHIVE_CONFIG parameter are inconsistent with the settings of a previously started instance. The settings for this parameter must be exactly the same for all instances.
Action:
Make sure all instances use the exact same LOG_ARCHIVE_CONFIG settings.
ORA-16191: Primary log shipping client not logged on standby
Cause:
An attempt to ship redo to standby without logging on to standby or with invalid user credentials.
Action:
Check that primary and standby are using password files and that both primary and standby have the same SYS password. Restart primary and/or standby after ensuring that password file is accessible and REMOTE_LOGIN_PASSWORDFILE initialization parameter is set to SHARED or EXCLUSIVE.
ORA-16192: Primary and standby network integrity mismatch
Cause:
Standby wants sqlnet network integrity for redo shipment which is not configured properly at the primary.
Action:
Check sqlnet.ora documentation regarding how to setup network integrity and set it up identically on both primary and standby. Restart primary and/or standby.
ORA-16193: Primary and standby network encryption mismatch
Cause:
Standby wants sqlnet network encryption for redo shipment which is not configured properly at the primary.
Action:
Check sqlnet.ora documentation regarding how to setup network encryption and set it up identically on both primary and standby. Restart primary and/or standby.
ORA-16194: Modifying DB_UNIQUE_NAME requires SID='*' qualifier
Cause:
The setting for the DB_UNIQUE_NAME parameter must be exactly the same on all RAC instances so the SID='*' qualifier is required.
Action:
ORA-16195: DG_CONFIG requires DB_UNIQUE_NAME be explicitly defined
Cause:
The DG_CONFIG attribute of the LOG_ARCHIVE_CONFIG parameter can only be used if the DB_UNIQUE_NAME parameter has been explicitly defined.
Action:
Explicitly define a valid DB_UNIQUE_NAME.
ORA-16196: database has been previously opened and closed
Cause:
The instance has already opened and closed the database, which is allowed only once in its lifetime.
Action:
Shut down the instance.
ORA-16197: Invalid DB_UNIQUE_NAME parameter specification
Cause:
The DB_UNIQUE_NAME parameter has an invalid specification. The DB_UNIQUE_NAME parameter has a maximum length of 30 characters and the only characters allowed are alpha-numeric characters and "_", "$" and "#".
Action:
Check the documentation and re-enter the parameter.
ORA-16198: Timeout incurred on internal channel during remote archival
Cause:
A timeout was incurred during remote archival.
Action:
ORA-16199: Terminal recovery failed to recover to a consistent point
Cause:
Action:
Try to resolve the problem. Retry terminal recovery. If the problem occurs repeatedly and cannot be resolved, call Oracle support.
ORA-16200: Skip procedure requested to skip statement
Cause:
Logical standby called a skip procedure that requested for a particular statement not to be applied.
Action:
ORA-16201: Skip procedure requested to apply statement
Cause:
Logical standby called a skip procedure that requested for a particular statement to be applied.
Action:
ORA-16202: Skip procedure requested to replace statement
Cause:
Logical standby called a skip procedure that requested for a particular statement to be replaced with a new statement.
Action:
ORA-16203: Unable to interpret skip procedure return values
Cause:
The skip procedure returned conflicting or invalid values.
Action:
Ensure that the new_statement output parameter is non-NULL when returning DBMS_LOGSTDBY.SKIP_ACTION_REPLACE and NULL otherwise. Also ensure SKIP_ACTION is specified correctly.
ORA-16204: DDL successfully applied
Cause:
A DDL statement has successfully commited on the logical standby database.
Action:
ORA-16205: DDL skipped due to skip setting
Cause:
A setting in the logical standby skip table indicates that this type of DDL should always be skipped.
Action:
ORA-16206: database already configured as Logical Standby database
Cause:
This database has been previously configured as a Logical Standby database. A Logical Standby database is not capable of processing the requested operation.
Action:
Ensure that you entered the command on the correct database as this database is a Logical Standby and is not capable of servicing the request.
ORA-16207: Logical standby dictionary build not permitted.
Cause:
A dictionary build is currently in progress. Only one build can be active at a time.
Action:
Wait for the active build to complete before invoking a new build.
ORA-16208: Logical standby dictionary build failed to start.
Cause:
Failure to start the logical standby dictionary build process (LSP1)
Action:
Check the accompanying messages, and the background process trace file. Correct the problem mentioned in the messages. Then shut down and restart the instance. If the trace file mentions any other background process messages, check the trace file for the mentioned process until the root message is found.
ORA-16209: Logical standby dictionary build failed to complete.
Cause:
The logical standby dictionary build process terminated abnormally.
Action:
ORA-16210: Logical standby coordinator process terminated with error
Cause:
The logical standby coordinator process terminated abnormally.
Action:
ORA-16211: unsupported record found in the archived redo log
Cause:
Log apply services encountered a record in the archived redo log that could not be interpreted.
Action:
1. Use DBMS_LOGSTDBY.INSTANTIATE_TABLE to re-create the table on the standby database or simply drop the table if it's unimportant.
2. ALTER DATABASE START LOGICAL STANDBY APPLY;
3. Examine the current_scn column in the DBA_LOGSTDBY_EVENTS view to determine which log file contains the unsupported record.
4. Provide the log file to Oracle Support Services.
ORA-16212: number of processes specified for SQL Apply is too great
Cause:
Logical standby apply engine was started with more processes requested than are available.
Action:
Adjust the values of the initialization parameters PROCESSES or the MAX_SERVERS parameter seen in the DBA_LOGSTDBY_PARAMETERS view. If you did not specify MAX_SERVERS, but instead specified PREPARE_SERVERS and APPLY_SERVERS through the dbms_logstdby.apply_set procedure, you will need to decrease either one or both of them.
ORA-16213: ddl encountered, stopping apply engine
Cause:
stop_on_ddl callout specified and DDL was encountered.
Action:
Either disable stop_on_ddl callout or remove DDL.
ORA-16214: apply stalled for apply delay
Cause:
A delay has been specified on the primary database for this destination.
Action:
Either turn off the delay on the primary or use DBMS_LOGSTDBY.APPLY_UNSET('APPLY_DELAY'); to override.
ORA-16215: history metadata inconsistency
Cause:
internal error.
Action:
This is an internal error. Contact Oracle support.
ORA-16216: Log stream sequence error
Cause:
The log stream being processed did not follow the last processed stream.
Action:
If the database is in an active configuration, issue an ALTER DATABASE START LOGICAL STANDBY APPLY NEW PRIMARY command to synchronize log stream data with the current primary database. If the database is not in an active configuration, manually add the next dictionary-begin log file that followed the previous log stream.
ORA-16217: prepare to switchover has not completed
Cause:
An ALTER DATABASE PREPARE TO SWITCHOVER command was issued, but the prepare activity did not complete.
Action:
Verify that the standby was prepared properly. You may cancel the prepare and perform an unprepared switchover which requires a database link to complete. Or reissue the prepare operation on the standby.
ORA-16218: This database is already preparing to switch over.
Cause:
The database was already preparing to switch over and was not able to accomodate another prepare attempt.
Action:
Cancel the current prepare attempt with the ALTER DATABASE PREPARE TO SWITCHOVER CANCEL command, then reissue the prepare request.
ORA-16219: This database is not preparing to switch over.
Cause:
The database was not preparing to switch over. Therefore, it was not possible to cancel the SWITCHOVER command.
Action:
Preparing for the SWITCHOVER command can be accomplished with the ALTER DATABASE PREPARE TO SWITCHOVER command.
ORA-16220: no failed transaction found
Cause:
No failed transaction was found.
Action:
Retry the ALTER DATABASE START LOGICAL STANDBY APPLY command without the SKIP FAILED TRANSACTION option.
ORA-16221: history table synchronization error
Cause:
internal error.
Action:
ORA-16222: automatic Logical Standby retry of last action
Cause:
A failure occurred while running Logical Standby apply. A new attempt is automatically being made by Logical Standby apply.
Action:
No action is necessary. This informational statement is provided to record the event for diagnostic purposes.
ORA-16223: DDL skipped, unsupported in current version
Cause:
The given DDL statement was not supported in the current version of Logical Standby and was skipped.
Action:
ORA-16224: Database Guard is enabled
Cause:
Operation could not be performed because database guard is enabled
Action:
Verify operation is correct and disable database guard
ORA-16225: Missing LogMiner session name for Capture
Cause:
An attempt was made to register the log file for Capture without a specified LogMiner session name.
Action:
Specify a valid LogMiner session name to which the log file will be registered.
ORA-16226: DDL skipped due to lack of support
Cause:
Logical Standby does not support this type of DDL in this version, so the DDL is skipped.
Action:
The DBA may apply the DDL explicitly at a later time or a procedure to handle this type of DDL can be created. see DBMS_LOGSTDBY.SKIP procedure for details.
ORA-16227: DDL skipped due to missing object
Cause:
A table or other database object upon which this DDL depended was not defined on the Logical Standby database.
Action:
ORA-16228: Insufficient recovery for logical standby
Cause:
Insufficient amount of recovery was run for logical standby instantiation.
Action:
Continue to recover the database using ALTER DATABASE RECOVER MANAGED STANDBY DATABASE.
ORA-16229: PDML child string string string for parent string string string cannot be skipped.
Cause:
A request was made to skip a parallel DML child transaction id. This is not supported.
Action:
Using the DBMS_LOGSTDBY.UNSKIP_TRANSACTION procedure, remove the child transaction id, then specify the parent transaction id using DBMS_LOGSTDBY.SKIP_TRANSACTION if appropriate.
ORA-16230: committing transaction string string string
Cause:
Logical Standby apply was committing changes for the given transaction.
Action:
ORA-16232: adding Logical Standby skip entry for table string.string
Cause:
Table was previously unsupported due to datatype or storage attribute definitions. Table is now capable of being supported.
Action:
To have Logical Standby maintain the table, import that table directly from the primary.
ORA-16233: The table string.string is unsupported now
Cause:
Table was previously supported but now is unsupported due to altered datatype or storage attribute definitions.
Action:
None
ORA-16234: restarting to reset Logical Standby apply
Cause:
Logical Standby encountered a work load that required a restart to properly reschedule.
Action:
ORA-16235: DDL skipped because import has occurred
Cause:
An object was exported from the primary database and imported into the Logical Standby database. This DDL occurred before the export.
Action:
ORA-16236: Logical Standby metadata operation in progress
Cause:
The requested operation failed because an incompatible Logical Standby metadata operation such as DBMS_LOGSTDBY.SET_TABLESPACE, DBMS_LOGSTDBY.APPLY_SET or DBMS_LOGSTDBY.INSTANTIATE_TABLE was still running.
Action:
Wait for the incompatible Logical Standby metadata operation to finish, then reenter or respecify the operation.
ORA-16237: SGA specified for Logical Standby is too small
Cause:
MAX_SGA must be at least 10 Megabytes for proper functioning of Logical Standby.
Action:
Specify the value of MAX_SGA to be greater than or equal to 10Mb. Alternatively, increase the shared_pool_size/sga_target so that 1/4 of it will amount to 10 Megabytes.
ORA-16238: attempt to use version 9 log
Cause:
Version 9 log files are not supported.
Action:
Use log files of a supported version.
ORA-16239: IMMEDIATE option not available without standby redo logs
Cause:
The IMMEDIATE option cannot be used without standby redo logs.
Action:
Do not specify the IMMEDIATE option unless standby redo logs are being used.
ORA-16240: Waiting for log file (thread# string, sequence# string)
Cause:
Process is idle waiting for additional log file to be available.
Action:
ORA-16241: Waiting for gap log file (thread# string, sequence# string)
Cause:
Reader process was idle waiting for the log file to fill the log sequence gap.
Action:
ORA-16242: Processing log file (thread# string, sequence# string)
Cause:
Reader process was processing the log file.
Action:
ORA-16243: paging out string bytes of memory to disk
Cause:
Builder process is paging out momery to free up space in lcr cache.
Action:
ORA-16245: change db_name to string in the server-side parameter file (SPFILE)
Cause:
An ALTER DATABASE RECOVER TO LOGICAL STANDBY new-dbname command was successfully executed without a modifiable server parameter file (SPFILE).
Action:
The server-side parameter file must be modified so that db_name is set to the given name before mounting the database again. You must do this by executing CREATE PFILE FROM SPFILE, editing the resulting text parameter file, and then executing CREATE SPFILE FROM PFILE.
ORA-16246: User initiated abort apply successfully completed
Cause:
SQL Apply was stopped using the abort option.
Action:
ORA-16247: DDL skipped on internal schema
Cause:
Logical Standby ignores DDLs on internal schemas such as SYS and SYSTEM. For a complete list of internal schemas ignored by Logical Standby perform the following query: SELECT owner FROM dba_logstdby_skip WHERE statement_opt = 'INTERNAL SCHEMA'.
Action:
ORA-16248: RFS connections not permitted during Terminal Apply
Cause:
Writes by RFS are not permitted while Logical Standby is performing Terminal Apply.
Action:
Permit any outstanding Logical Standby operations to complete.
ORA-16249: Terminal apply failed to complete during failover
Cause:
The logical standby coordinator process terminated abnormally."
Action:
Examine the DBA_LOGSTDBY_EVENTS view for the reason behind the abnormal shutdown, and resolve accordingly. Once the problem has been rectified, reissue the ALTER DATABASE ACTIVATE LOGICAL STANDBY DATABASE command to complete the failover.
ORA-16250: Failed to acquire starting scn of new log stream
Cause:
The starting SCN for the new log stream could not be determined.
Action:
Please reissue the ACTIVATE LOGICAL STANDBY DATABASE command.
ORA-16251: LSP1 Background Build not permitted
Cause:
The LSP1 background process is not permitted to start because it had previously been attempted.
Action:
ORA-16252: Rebuild operation not permitted
Cause:
The REBUILD operation is not permitted.
Action:
Only on a primary database that has failed to complete the LogMiner dictionary build may the REBUILD operation take place. Reissue the ACTIVATE LOGICAL STANDBY DATABASE command if it previously failed to complete.
ORA-16253: Logical standby cannot start due to a prior, incomplete operation
Cause:
A failure during a prior failover or configuration-related operation left the logical standby in an inconsistent state.
Action:
Identify and reissue the operation before attempting to restart the logical standby apply engine.
ORA-16254: change db_name to string in the client-side parameter file (pfile)
Cause:
An ALTER DATABASE RECOVER TO LOGICAL STANDBY new-dbname command was successfully executed without a server parameter file (spfile).
Action:
The client-side parameter file must be edited so that db_name is set to the given name before mounting the database again.
ORA-16255: Log Auto Delete conflicts with another LogMiner session
Cause:
Log Auto Delete cannot be on while another LogMiner session is running on the same database.
Action:
Start Logical Standby without Log Auto Delete or destroy other LogMiner sessions first.
ORA-16256: Failure to complete standby redo log file archival after failover
Cause:
The standby redo log files processed during the failover of a logical standby were not archived.
Action:
Execute DBMS_LOGSTDBY.REBUILD to reattempt the archival.
ORA-16257: Switchover initiated stop apply successfully completed
Cause:
SQL Apply was stopped because of a switchover.
Action:
ORA-16258: marking index unusable due to a constraint violation
Cause:
A constraint violation occurred during the apply of a direct path load. The index will be marked unusable and the apply will be restarted.
Action:
No action necessary. See alert log for index schema and name.
ORA-16259: Switchover to logical standby requires a log archive destination
Cause:
A valid log archive destination was not found to which the local system could archive the end of redo (EOR) log file. A minimum of one destination is required.
Action:
Ensure all log archive destinations are properly configured and, if applicable, have network connectivity before reissuing the ALTER DATABASE COMMIT TO SWITCHOVER TO LOGICAL STANDBY DDL operation.
ORA-16260: Waiting to replace partial or corrupt log file (thread# string, sequence# string)
Cause:
LogMiner Reader process reached the end of a partial log file or encountered a corrupted block. It is now waiting for the log file to be recovered and reregistered.
Action:
No action necessary. Once the fetch archive log (FAL) archiver replaces the log file, standby will automatically restart to process the replaced file.
ORA-16261: Identification key mismatch for table "string"."string".
Cause:
Internal error in SQL Apply.
Action:
Contact Oracle Support Services.
ORA-16262: Invalid value specified for Logical Standby parameter
Cause:
The value specified in APPLY_SET is invalid for the parameter.
Action:
Specify correct parameter value. Please refer to documentation on DBMS_LOGSTDBY PL/SQL package for details.
ORA-16263: Dynamic parameters can only be set on SQL apply instance
Cause:
Attempt to set a Logical standby dynamic parameter on an instacne other than where SQL apply coordinator is running.
Action:
Connect to the instance where SQL apply coordinator is running and reissue the statement.
ORA-16264: invalid value for PREPARE_SERVERS parameter
Cause:
attempt to set PREPARE_SERVERS parameter to zero or to a value which would require MAX_SERVERS to be increased.
Action:
set PREPARE_SERVERS parameter to a non zero value and or increase MAX_SERVERS parameter accordingly.
ORA-16265: Unsupported PL/SQL procedure encountered
Cause:
Apply encountered an unsupported procedure from an Oracle supplied PL/SQL package that is otherwise supported
Action:
Either add a skip rule for this procedure or manually apply the procedure and restart apply skipping the failed transaction Please refer to documentation on the PL/SQL package for details.
ORA-16266: Cannot instantiate a Logical Standby from another Logical Standby
Cause:
An instantiation of a Logical Standby has been attempted for another database with the Logical Standby role, which is not supported.
Action:
Instantiate a Logical Standby database only from a Primary Database.
ORA-16267: Cannot instantiate a Logical Standby during a switchover
Cause:
An instantiation of a Logical Standby has been attempted for a primary database that is in the middle of a switchover.
Action:
Execute ALTER DATABASE PREPARE TO SWITCHOVER CANCEL to cancel the switchover, and attempt the instantiation again.
ORA-16268: user procedure processing of logical standby apply PL/SQL
Cause:
A user-provided stored procedure was called to inspect a PL/SQL statement prior to the statement being processed.
Action:
ORA-16269: PL/SQL procedure skipped due to failure on primary database
Cause:
Because the PL/SQL procedure failed when executed on the primary database, it could not be executed on the standby database.
Action:
This informational statement is provided to record the event for diagnostic purposes. The failed PL/SQL procedure needs to be investigated to ensure it did not commit interesting data before it failed.
ORA-16270: PL/SQL procedure skipped due to unmaintained standby objects
Cause:
Because the PL/SQL procedure manipulated objects not being maintained by the standby database, it was skipped.
Action:
ORA-16271: PL/SQL successfully applied
Cause:
A PL/SQL procedure was successfully applied on the logical standby database.
Action:
ORA-16272: PL/SQL procedure skipped due to skip setting
Cause:
A setting in the logical standby skip table indicated that this PL/SQL procedure should always be skipped.
Action:
ORA-16273: invalid value for APPLY_SERVERS parameter
Cause:
attempt to set APPLY_SERVERS parameter to zero or to a value which would require MAX_SERVERS to be increased.
Action:
set APPLY_SERVERS parameter to a non zero value or increase MAX_SERVERS parameter accordingly.
ORA-16274: failure to perform operation on all Oracle RAC instances
Cause:
One or more instances encountered an error while performing an operation.
Action:
Ensure every instance in the Oracle RAC meets the requirements for the operation, and retry the operation.
ORA-16275: prior failed CTAS detected and pre-existing table dropped
Cause:
During the processing of a CTAS operation, an existing empty table with the same name and attributes as the CTAS source table was found, and the table was dropped.
Action:
ORA-16276: specified database link does not correspond to primary database
Cause:
The database link specified to DBMS_LOGSTDBY.INSTANTIATE_TABLE did not link to the primary database for this logical standby database.
Action:
Specify a database link that corresponds to the primary database for this logical standby database. The link should have privileges to read and lock the table being instantiated, as well as the SELECT_CATALOG_ROLE.
ORA-16277: specified table is not supported by logical standby database
Cause:
A call was made to DBMS_LOGSTDBY.INSTANTIATE_TABLE to instantiate an unsupported table on the logical standby database. Tables with unsupported data types cannot be replicated to a logical standby database.
Action:
Specify a table which is not listed in the DBA_LOGSTDBY_UNSUPPORTED_TABLE view.
ORA-16278: specified table has a multi-object skip rule defined
Cause:
A table that is instantiated via DBMS_LOGSTDBY.INSTANTIATE_TABLE must not have any skip rules defined with wildcard characters.
Action:
Remove or rewrite any skip rules defined for the specified table so that they no longer contain wildcard characters, or no longer affect the specified table.
ORA-16279: supplied dblink does not have sufficient privileges
Cause:
A dblink was specified that lacked one or more of the CONNECT, RESOURCE, or SELECT_CATALOG_ROLE roles or that connects to a user with insufficient privileges to lock the table.
Action:
Grant the necessary privileges to the dblink and the user to which the dblink connects and retry the operation.
ORA-16280: cannot change master key on a logical standby database
Cause:
An attempt was made to change the master key for transparent data encryption on a logical standby database.
Action:
Set GUARD to NONE and reissue the command. This prevents you from replicating tables with encrypted columns from the primary database.
ORA-16281: missing identification key for table "string"."string".
Cause:
No identification key was created for specified table.
Action:
Create a primakey key or unique index for specified table.
ORA-16282: operation not permitted during rolling upgrade
Cause:
An operation was attempted that is not supported during a rolling upgrade.
Action:
Retry the operation upon completion of the upgrade.
ORA-16283: operation not permitted on non-apply instance
Cause:
An operation was attempted that is not supported since it requires a running logical apply on the local instance.
Action:
Retry the operation on the instance on which the apply engine is running.
ORA-16284: timed out waiting for an in-progress operation to complete
Cause:
An operation timed out waiting for another operation to complete.
Action:
Retry the operation when the in-progress operation has completed.
ORA-16285: operation not permitted due to inconsistent role state
Cause:
A prior attempt to change the role of this database has failed before the new role state could be fully committed.
Action:
Retry the previously attempted role-related operation before attempting the current operation.
ORA-16286: operation not permitted due to lack of synchronized destination
Cause:
A synchronized log archive destination was not found to which the end-of-redo log file could be archived.
Action:
Before re-attempting the operation, wait at least one minute for the Remote File Server to automatically recover any missing log files or manually recover and register any missing log files with logical standby.
ORA-16287: operation not permitted due to active apply state
Cause:
An operation was attempted that was not supported while the logical standby database had an active apply state.
Action:
Confirm the procedures used to configure the logical standby database. Procedures which attempt to reconfigure a logical standby database for a new primary database may encounter this error if an error in a preliminary step was encountered.
ORA-16288: DDL skipped due to missing edition "string"
Cause:
The edition in which the DDL was performed on the primary did not exist on the standby database.
Action:
ORA-16289: unable to access Pluggable Database "string"
Cause:
Logical standby attempted to access a Pluggable Database that did not exist.
Action:
Create or plug in the specified Pluggable Database or add an appropriate skip rule and then restart logical standby.
ORA-16290: cannot alter the session logical replication state within a transaction
Cause:
A transaction was already in progress.
Action:
Commit or rollback the transaction and then reexecute.
ORA-16300: LSBY architected tracing event
ORA-16302: extended data type support is not supported for specified table
Cause:
A call was made to DBMS_LOGSTDBY.EDS_ADD_TABLE for a table that was not supported for such an operation. The table either does not have a primary key or it has a data type not supported by this procedure.
Action:
Specify a table for which support exists in EDS_ADD_TABLE.
ORA-16303: specified table already has extended data type support
Cause:
A call was made to DBMS_LOGSTDBY.EDS_ADD_TABLE for a table that already had EDS added on the local database.
Action:
None
ORA-16304: procedure must first be called on primary database
Cause:
A call was made to DBMS_LOGSTDBY.EDS_ADD_TABLE on a logical standby database without having first called it on the primary database.
Action:
Call DBMS_LOGSTDBY.EDS_ADD_TABLE on the primary database and then retry on the standby.
ORA-16305: procedure not supported on a logical standby
Cause:
A call was made to DBMS_LOGSTDBY.EDS_EVOLVE_TABLE on a logical standby database which can only be called on a primary database
Action:
Call DBMS_LOGSTDBY.EDS_EVOLVE_TABLE on the primary database
ORA-16306: specified table does not have a primary key
Cause:
A call was made to DBMS_LOGSTDBY.EDS_ADD_TABLE for a table that did not have a primary key.
Action:
Add a primary key and retry the operation.
ORA-16307: TSE key string successfully applied
Cause:
An ALTER SYSTEM SET ENCRYPTION KEY statement was successfully committed on the logical standby database.
Action:
ORA-16308: specified table has extended data type support
Cause:
A call was made to DBMS_LOGSTDBY.INSTANTIATE_TABLE for a table that is being maintained by extended data type support.
Action:
Call DBMS_LOGSTDBY.EDS_REMOVE_TABLE followed by either DBMS_LOGSTDBY.EDS_ADD_TABLE or a retry of the operation.
ORA-16309: extended data type support evolve operation not yet started
Cause:
A call was made to finish an extended data type support evolve operation without having first started the operation.
Action:
Call DBMS_LOGSTDBY.EDS_EVOLVE_MANUAL with START option and then retry.
ORA-16310: extended data type support evolve operation in progress
Cause:
An extended data type support evolve operation was started but not yet completed.
Action:
Wait a few seconds and retry the command if automatic evolve has been enabled or call DBMS_LOGSTDBY.EDS_EVOLVE_MANUAL with the FINISH option and then retry.
ORA-16311: materialized view log already exists
Cause:
A call was made to DBMS_LOGSTDBY.EDS_ADD_TABLE for a table with a LOB that requires the creation of a specifically-defined materialized view log but one already exists.
Action:
Drop the existing materialized view log and retry the operation.
ORA-16330: error in container "string"
Cause:
An operation was attempted on a container and an error occurred.
Action:
Address the failure condition and then retry.
ORA-16331: container "string" is not open
Cause:
An operation was attempted on a container. However, the container was not open.
Action:
Open the container and then retry.
ORA-16332: logical standby encountered non-fatal error ORA-string during DDL execution
Cause:
Logical standby apply encountered a non-fatal error during DDL execution and continued to process subsequent transactions.
Action:
This error is informational only. No user action is required.
ORA-16333: _MAX_LOG_LOOKBACK parameter not sufficiently larger than MAX_SGA
Cause:
_MAX_LOG_LOOKBACK or MAX_SGA parameter was set to a value that will lead to decreased performance.
Action:
Reset parameters such that _MAX_LOG LOOKBACK is at least 5 times the value of MAX_SGA.
ORA-16334: skip procedure does not exist
Cause:
The specified skip procedure did not exist.
Action:
Ensure that the specified skip procedure exists and is accessible by the calling user.
ORA-16400: quota attributes are not allowed with DB_RECOVERY_FILE_DEST
Cause:
Quota attributes for the destination parameters are not allowed when the parameter DB_RECOVERY_FILE_DEST is defined.
Action:
No action is required.
ORA-16401: archive log rejected by Remote File Server (RFS)
Cause:
An attempt was made to re-archive an existing archive log.
Action:
See alert log and trace file for more details. No action is necessary. This is an informational statement provided to record the event for diagnostic purposes.
ORA-16402: TRANSPORT=ONDEMAND is unsupported.
Cause:
The ARCHIVELOG destination TRANSPORT=ONDEMAND attribute was specified on the primary database.
Action:
Use of the TRANSPORT=ONDEMAND is no longer supported. Remove this attribute from the LOG_ARCHIVE_DEST_n initialization parameter.
ORA-16403: shut down in progress - remote connection is not permitted
Cause:
A redo transport session could not be started because the database was shutting down.
Action:
Wait for the remote instance to be restarted, or contact your DBA.
ORA-16406: primary and standby database software version mismatch
Cause:
The primary and standby databases were not running compatible versions of Oracle server software.
Action:
Install the correct Oracle server software and try again.
ORA-16407: An archive log from an earlier redo branch has been rejected
Cause:
An archive log from a redo branch that is earlier than the one that the standby database is currently applying was rejected.
Action:
ORA-16408: An archive log from an incompatible redo branch has been rejected.
Cause:
An archive log from a redo branch that is incompatible with the one that the standby database is currently applying was rejected.
Action:
ORA-16409: archive log switchover reference number mismatch
Cause:
The archive log switchover reference numbers of the primary and standby database did not match. Remote archival of redo log files is not allowed to incompatible standby database instances.
Action:
ORA-16411: TRANSPORT=ONDEMAND is unsupported
Cause:
The archivelog destination TRANSPORT=ONDEMAND attribute was specified on the primary database.
Action:
ORA-16412: TRANSPORT=ONDEMAND is unsupported
Cause:
Action:
ORA-16413: TRANSPORT=ONDEMAND is unsupported
Cause:
Action:
ORA-16416: No viable stringswitchover targets available
Cause:
Switchover failed because no standby databases of the appropriate type were available.
Action:
Check the alert log for errors, correct the problem and retry the switchover.
ORA-16417: Activation occurred after recovery from standby redo log files; a full database backup is required
Cause:
Activation occurred after recovery from standby redo log files.
Action:
Take a full database backup.
ORA-16419: Snapshot standby must be converted to a physical standby database.
Cause:
The database was not a physical standby database.
Action:
Convert to physical standby database and retry the operation.
ORA-16420: fast-start failover target cannot be converted to snapshot standby
Cause:
The database chosen for conversion to a snapshot standby was the fast-start failover target standby database.
Action:
Choose another physical standby database and retry the operation.
ORA-16424: RECOVER FINISH cannot complete due to a redo gap.
Cause:
RECOVER FINISH failed because there was a redo gap on the standby database.
Action:
Resolve redo gap or issue ALTER DATABASE ACTIVATE STANDBY DATABASE to perform an immediate failover with some data loss.
ORA-16425: RECOVER FINISH cannot be issued when recovery branch string is not the target branch string.
Cause:
RECOVER FINISH failed because a new branch existed on the physical standby database.
Action:
Issue real-time apply recovery and see if recovery can proceed on the new branch by checking if logs on the new branch are applied by recovery. If so, issue another RECOVER FINISH. Otherwise, issue ALTER DATABASE ACTIVATE STANDBY DATABASE.
ORA-16426: Recovery requested an incorrect log from which to apply redo data.
Cause:
Media recovery selected an incorrect log.
Action:
Verify that the appropriate log has been properly registered and restart media recovery.
ORA-16427: Redo gap is too large to resolve.
Cause:
The redo transport lag at this database was too large for automatic redo gap detection to take place.
Action:
Re-create this standby database from a current backup copy of the primary database.
ORA-16431: cannot expand control file
Cause:
Additional redo log threads were added on the primary database after the standby control file was created.
Action:
Shut down the standby database and replace the control file with a new standby control file from the primary database or change the COMPATIBLE parameter to 10.2.0 or above and restart the standby database.
ORA-16432: inconsistent set of logs applied at a standby database
Cause:
Redo apply stopped because it detected an inconsistency in the progression of the SCNs. If this database is a bystander standby database, this is most likely due to a failover operation in which incompatible logs were applied from the old and new primary databases.
Action:
Determine the STANDBY_BECAME_PRIMARY_SCN by selecting it from V$DATABASE on the new primary database. Then, flashback the target database to this SCN and use RMAN to delete all archive logs at or beyond this SCN. Finally, fetch all terminal end of redo (EOR) logs corresponding to the failover operation from the new primary and register all these logs at the target database. Restart redo apply.
ORA-16433: The database or pluggable database must be opened in read/write mode.
Cause:
An attempt was made to open the database or pluggable database in read-only mode after an operation that requires the database or pluggable database be opened in read/write mode.
Action:
Open the database in read/write mode. The database can then be opened in read-only mode.
ORA-16434: archive log for branch string thread string sequence string cannot be queued
Cause:
An archive log needed by the standby database to resolve a redo gap was not found on the source database. This is a fatal situation during a switchover or far sync instance assisted failover because the source database waits for the target standby to be clear of all archive log gaps before allowing the operation to proceed. If a redo gap cannot be resolved during these operations, the operation cannot succeed so it must be failed.
Action:
If the specified log is listed in V$ARCHIVED_LOG for the DEST_ID of the local destination on the source database but no longer exists at that location on disk, the archived log can be copied back to that location to allow gap processing to automatically resolve the gap. If the specified log has been purged from V$ARCHIVED_LOG, the archived log can be copied to disk on either the source or destination database and registered using the ALTER DATABASE REGISTER OR REPLACE LOGFILE command.
ORA-16436: ALTER DATABASE ... RECOVER FINISH could not start
Cause:
ALTER DATABASE ... RECOVER FINISH failed to start because the standby database was missing redo changes below the checkpoint of data files.
Action:
Issue ALTER DATABASE ACTIVATE STANDBY DATABASE command instead.
ORA-16437: No active coordinator RFS for current operation
Cause:
The coordinator Remote File Server (RFS) for this parallel archival either abnormally terminated or ran down before this subordinate RFS could begin its leg of the operation.
Action:
No explicit user action is required.
ORA-16438: Switchover to primary cannot be executed at this time
Cause:
ALTER DATABASE COMMIT TO SWITCHOVER TO PRIMARY could not be executed because an incompatible operation such as RMAN restore or flashback was in progress. See the database alert log for details.
Action:
Wait for the incompatible operation to complete. The files that have been flashed back or restored need recovery before you can reissue ALTER DATABASE COMMIT TO SWITCHOVER TO PRIMARY statement. Start redo apply and verify that the SWITCHOVER_STATUS column of the V$DATABASE view reports TO_PRIMARY or SESSIONS_ACTIVE before retrying ALTER DATABASE COMMIT TO SWITCHOVER TO PRIMARY.
ORA-16439: Standby not ready to receive redo at this time
Cause:
A logical standby or down stream capture database was not in a state where it could accept a request to receive redo from another database. This was likely due to the database not being open.
Action:
See the database alert log at the receiving side of the transfer for details of why the database was not ready. If the database was mounted but not open, open it to clear the problem. The initialization parameter LOG_ARCHIVE_DEST_STATE_n at the sending site may need to be set to ENABLE.
ORA-16440: Control file is corrupt.
Cause:
ALTER SYSTEM FLUSH REDO TO STANDBY failed because the control file was corrupt.
Action:
Restore the current control file at the primary database and then reissue ALTER SYSTEM FLUSH REDO TO STANDBY from a mounted primary instance.
ORA-16441: Current log string for thread string sequence string is invalid.
Cause:
ALTER SYSTEM FLUSH REDO TO STANDBY failed because the current redo log file was corrupt.
Action:
Restore the current log at the primary database, and then reissue ALTER SYSTEM FLUSH REDO TO STANDBY from a mounted primary instance.
ORA-16442: ALTER SYSTEM FLUSH REDO TO STANDBY succeeded, but some redo has not been applied.
Cause:
The target standby database did not apply all received redo.
Action:
Allow the target standby database to apply all redo and then reissue the ALTER SYSTEM FLUSH REDO TO STANDBY statement.
ORA-16443: could not switch out of log string thread string
Cause:
ALTER SYSTEM FLUSH REDO TO STANDBY could not switch out of the current log.
Action:
This can happen if there are one or more errors during archival of the current log at the primary database. Reissue ALTER SYSTEM FLUSH REDO TO STANDBY after resolving the archiving errors.
ORA-16444: ALTER SYSTEM FLUSH REDO TO STANDBY failed due to a corrupted control file or online log file.
Cause:
A flush redo operation discovered SCNs greater than a previously failed flush redo operation.
Action:
This can happen if there are one or more errors that have corrupted the control file or online redo logs. In these cases, flush redo operation is not possible.
ORA-16445: Database has to be mounted and cannot be open
Cause:
ALTER SYSTEM FLUSH REDO TO STANDBY required that the database be mounted, but not opened.
Action:
Mount the database and then reissue the operation.
ORA-16446: Target database was not a standby database
Cause:
ALTER SYSTEM FLUSH REDO TO STANDBY failed because the target database is not a standby database.
Action:
Reissue the ALTER SYSTEM FLUSH REDO TO STANDBY statement and specify a standby database as the target database.
ORA-16447: Redo apply was not active at the target standby database
Cause:
ALTER SYSTEM FLUSH REDO TO STANDBY failed because redo apply is not active at the target database.
Action:
Start redo apply at the standby database and reissue the ALTER SYSTEM FLUSH REDO TO STANDBY statement, or reissue the ALTER SYSTEM FLUSH REDO TO STANDBY statement with the NO CONFIRM APPLY clause.
ORA-16448: Primary database corruption has been detected by standby database.
Cause:
The primary database became corrupted.
Action:
Identify the extent of the corruption on both the primary and standby database and take remedial action.
ORA-16449: incomplete redo thread enable operation
Cause:
The switchover operation could not continue because it failed to disable a thread that was left in an incomplete thread enable state.
Action:
Check alert log for more details.
ORA-16451: A remote archival request has timed out.
Cause:
When opening or closing a database instance, the database may wait for up to 1 minute for pending remote archival requests to be performed before proceeding with the operation. This error was reported because that time limit was exceeded.
Action:
This is an informational message so no action is required.
ORA-16455: switchover to standby failed
Cause:
An attempt to switchover to a physical standby database failed.
Action:
Check alert log for more details. Issue the SHUTDOWN ABORT command on the database before issuing another ALTER DATABASE COMMIT TO SWITCHOVER TO STANDBY command.
ORA-16456: switchover to standby in progress or completed
Cause:
The requested operation was not allowed because a switchover to standby operation was either in progress or had completed.
Action:
Issue the SHUTDOWN ABORT command on the database after switchover operation completes.
ORA-16459: recovery already beyond standby failover
Cause:
Redo Apply stopped because it detected that it had proceeded beyond a standby failover operation.
Action:
Determine the STANDBY_BECAME_PRIMARY_SCN by selecting it from V$DATABASE on the new primary database. Then, flashback the target database to this SCN and use RMAN to delete all archive logs at or beyond this SCN. Finally, fetch all terminal end-of-redo (EOR) logs corresponding to the failover operation from the new primary database and register all these logs at the target database. Restart Redo Apply.
ORA-16461: database not flashed back or recovered to a consistent point
Cause:
ALTER DATABASE CONVERT TO STANDBY command failed because either the database was not properly flashed back to STANDBY_BECAME_PRIMARY_SCN, or at least one of the online data files was not current.
Action:
Flashback database to STANDBY_BECAME_PRIMARY_SCN and retry the ALTER DATABASE CONVERT TO STANDBY command.
ORA-16463: invalid target database name
Cause:
ALTER DATABASE FAILOVER TO <target_db_name> or ALTER DATABASE SWITCHOVER TO <target_db_name> FORCE command failed because the target_db_name was invalid. The target_db_name must be the same as the name of the database on which the SQL command is issued.
Action:
Change the target database name and reissue the command.
ORA-16464: operation not allowed
Cause:
An attempt was made to issue the ALTER DATABASE FAILOVER TO <target_db_name> or the ALTER DATABASE SWITCHOVER TO <target_db_name> FORCE command on a database other than a physical standby database.
Action:
Issue the command on a physical standby database.
ORA-16465: operation not allowed
Cause:
An attempt was made to issue the ALTER DATABASE SWITCHOVER TO <target_db_name> [VERIFY] command on a database other than an open primary database.
Action:
Issue the command on an open primary database.
ORA-16466: invalid switchover target
Cause:
The switchover target was not a valid, enabled, or active standby database.
Action:
Fix the problem in the switchover target and reissue the command.
ORA-16467: switchover target is not synchronized
Cause:
The switchover target was not synchronized with the primary database.
Action:
Wait until the switchover target is synchronized with the primary database, then reissue the command.
ORA-16468: error connecting to switchover target string
Cause:
The primary database could not connect to the switchover target.
Action:
Check the alert log for detailed errors.
ORA-16469: switchover target version number is lower than 12
Cause:
The switchover target version number was lower than 12.
Action:
Upgrade the switchover target to a higher release.
ORA-16470: Redo Apply is not running on switchover target
Cause:
The switchover target was not running Redo Apply.
Action:
Start Redo Apply on the switchover target and reissue the command.
ORA-16471: cannot convert switchover target string to a primary database
Cause:
Switchover failed because the switchover target could not convert to a primary database.
Action:
Check the database role of the switchover target. If the switchover target database role is standby, do one of the following:
- Fix the problem shown in the alert log.
- Issue the remedial ALTER DATABASE SWITCHOVER TO <target_db_name> FORCE command to convert the switchover target to a primary database.
- If the problem in the switchover target cannot be fixed, issue the remedial ALTER DATABASE SWITCHOVER TO <target_db_name> FORCE command on the old primary database to convert the old primary database back to a primary database. If the switchover target database role is primary, the switchover has completed. Open the switchover target and startup the old primary database to finish the switchover process.
ORA-16472: failover failed due to data loss
Cause:
The database was in MaxAvailability or MaxProtection mode but terminal recovery finished with data loss.
Action:
For a data loss failover, issue ALTER DATABASE ACTIVATE STANDBY DATABASE command.
ORA-16473: database is not in limbo
Cause:
The ALTER DATABASE SWITCHOVER TO <target_db_name> FORCE command could not proceed because the database was not in limbo state.
Action:
Make sure the SWITCHOVER_STATUS column in V$DATABASE has the value TO PRIMARY or SESSIONS ACTIVE. If needed, start managed standby recovery and reissue the command after the SWITCHOVER_STATUS column value changes to one of the above values.
ORA-16474: target_db_name not found in the LOG_ARCHIVE_DEST_n parameter
Cause:
ALTER DATABASE SWITCHOVER TO <target_db_name> or ALTER SYSTEM FLUSH REDO TO <target_db_name> command failed because the target_db_name was not defined in the LOG_ARCHIVE_DEST_n parameter.
Action:
Make sure the target_db_name is defined in the LOG_ARCHIVE_DEST_n parameter.
ORA-16475: succeeded with warnings, check alert log for more details
Cause:
The ALTER DATABASE SWITCHOVER TO <target_db_name> VERIFY command succeeded but with warnings.
Action:
ORA-16476: far sync instance does not allow string operation
Cause:
The specified operation was invalid on a far sync instance.
Action:
Do not attempt the specified operation on a far sync instance.
ORA-16477: destination is being serviced by another viable source
Cause:
An attempt was made by a far sync instance to perform gap analysis with a remote destination that already had connectivity with a different viable source of live redo.
Action:
No action is required. This exception code is informational and is used by the far sync instance to remain idle with respect to this destination until it establishes connectivity with the primary database.
ORA-16478: cannot locate far sync instance connect string
Cause:
The connect string for the far sync instance that is flagged as the source of live redo for this database could not be located.
Action:
Define a LOG_ARCHIVE_DEST_n parameter for the far sync instance using the SERVICE attribute to define the connect string for the far sync instance destination. This destination should be set to DEFER using the corresponding LOG_ARCHIVE_DEST_STATE_n parameter. Once the connect string is defined, retry the failover operation. Using the FORCE option on the failover command allows the operation to proceed and bypass the far sync instance but bypassing the far sync instance increases the potential for data loss.
ORA-16479: cannot connect to the far sync instance
Cause:
An attempt was made to connect to the far sync instance to help facilitate the failover operation but the connection attempt failed.
Action:
Make sure the far sync instance is mounted. Check the alert log and trace files on both the current database and the far sync instance for further details. Retry the operation if a problem is identified and corrected. Using the FORCE option on the failover command allows the operation to proceed and bypass the far sync instance but bypassing the far sync instance increases the potential for data loss.
ORA-16480: operational error during far sync instance assisted failover
Cause:
After successfully connecting to the far sync instance, an error was encountered when polling the far sync instance for progress.
Action:
Check the alert log and traces of both the current database and the far sync instance for further details. Retry the operation if a problem is identified and corrected. Using the FORCE option on the failover command allows the operation to proceed and bypass the far sync instance but bypassing the far sync instance increases the potential for data loss.
ORA-16481: destination error during far sync instance assisted failover
Cause:
After successfully connecting to the far sync instance, an error was encountered when managing the failover target destination on the far sync instance.
Action:
ORA-16482: a role transition is in progress
Cause:
The operation failed because a role transition was in progress.
Action:
None
ORA-16483: unable to set a LOG_ARCHIVE_DEST_n parameter to the switchover target
Cause:
An attempt was made to set a LOG_ARCHIVE_DEST_n parameter to the switchover target failed.
Action:
Manually set a LOG_ARCHIVE_DEST_n parameter to the switchover target.
ORA-16484: compatibility setting is too low
Cause:
The compatibility setting in the redo log transported to this standby database exceeded the current compatibility setting.
Action:
Check the compatibility setting on the primary and standby database, and increase the compatibility setting in the initialization parameter file on the standby database accordingly.
ORA-16485: redo log is already received at destination
Cause:
A copy of this redo log was already received at the destination.
Action:
None
ORA-16486: redo log is rejected by the destination
Cause:
The destination was not allowed to receive this redo log.
Action:
Ensure the source database is registered at the destination, the destination is up and running, and storage is available.
ORA-16487: the destination database is not writable
Cause:
The destination database was in read-only mode.
Action:
Ensure the destination database is open for write.
ORA-16488: cannot create a bookkeeping entry in database
Cause:
The destination database failed to create an entry in the table used to track the redo log.
Action:
Examine the trace file of the Remote File Server (RFS) process. Check and make sure space is available in your database.
ORA-16489: cannot register the redo log at the destination database
Cause:
Registering the redo log to the destination database failed.
Action:
ORA-16491: operation not allowed due to insufficient online redo log files string
Cause:
A minimum of two online redo log files per active thread were not supplied.
Action:
Add the required redo log files and reissue the command.
ORA-16492: switchover target local destination has error
Cause:
The switchover target local destination either exceeded quota size or had an error.
Action:
ORA-16493: using SYSDBA, SYSOPER, SYSDG, or SYSBKUP user for redo shipping to Recovery Appliance is not supported
Cause:
An attempt was made to use a SYSDBA, SYSOPER, SYSDG, or SYSBKUP user to ship redo logs to a Recovery Appliance.
Action:
Use a user without the SYSDBA, SYSOPER, SYSDG, or SYSBKUP privilege to ship redo logs to a Recovery Appliance.
ORA-16494: process started from pluggable database (PDB)
Cause:
The Remote File Server (RFS) process or Remote Message Interface (RMI) process or Fetch Archive Log (FAL) process was started from the PDB.
Action:
Check the service name that the RFS or RMI or FAL client connected to. Ensure the service is not from PDB.
ORA-16495: Using fast recovery area to receive redo log files on Recovery Appliance is not supported.
Cause:
An attempt was made to use fast recovery area to receive redo log file on a Recovery Appliance.
Action:
Do not configure fast recovery area for receiving redo log files on a Recovery Appliance.
ORA-16501: The Oracle Data Guard broker operation failed.
Cause:
Action:
See accompanying messages for details.
ORA-16502: The Oracle Data Guard broker operation succeeded with warnings.
Cause:
Action:
ORA-16503: cannot exceed the maximum number of databases in this configuration
Cause:
The Oracle Data Guard broker configuration already contained the maximum number of databases that could be configured and managed by the broker.
Action:
Select and remove an existing database from the broker configuration, then reissue the command to add another database to the configuration. Note that when COMPATIBLE is set lower than 11.2.0.0.0, the broker can configure and manage up to 10 databases. When COMPATIBLE is set to 11.2.0.0.0 or higher, this limit is increased to 31.
ORA-16504: The Oracle Data Guard configuration already exists.
Cause:
A request to create an Oracle Data Guard configuration was made while connected to a database that is part of an existing configuration.
Action:
To create a new configuration, the existing configuration must be deleted.
ORA-16506: out of memory
Cause:
Process exceeded private or shared memory limits.
Action:
Check for memory leaks, increase system parameters and restart.
ORA-16509: request timed out
Cause:
The Oracle Data Guard broker timed out the request.
Action:
Check the Oracle Data Guard broker log file for more information. Ensure that the network connections between the databases are functioning properly and retry the request.
ORA-16513: maximum requests exceeded
Cause:
The maximum number of requests that the broker can service on the database instance was exceeded.
Action:
Wait for the broker to complete processing the requests before issuing more requests.
ORA-16516: current state is invalid for the attempted operation
Cause:
The broker may have returned this error for either switchover operations or for database state change operations. If this error was returned for a switchover operation, the broker determined that either:
- The databases changing roles are shut down.
- The primary database is not shipping redo data.
- The standby database that will become the primary database is not applying redo data. If this error was returned for database state change operations, the database state specified was invalid.
Action:
If this error is returned when attempting a switchover operation, make sure that:
- The databases changing roles are started.
- The primary database is shipping redo data.
- The standby database is applying redo data. If this error is returned when attempting a database state change operation, make sure a valid database state is specified.
ORA-16521: operation requires connection to the multitenant container database
Cause:
The command required the client to connect to the multitenant container database.
Action:
Connect to the multitenant container database and reissue the command.
ORA-16522: configuration is part of Global Data Services pool
Cause:
The attempted command was not allowed because the configuration was part of a Global Data Services pool.
Action:
Remove the configuration from the Global Data Services pool using GDSCTL. Then, retry the broker command. If the command was attempting to repair a database, disable or remove the individual database from the configuration and fix the issue. After the issue is resolved, reenable the database, or add the database back to the configuration if it had been removed.
ORA-16523: operation requires the client to connect to instance "string"
Cause:
The switchover or failover operation required the client to connect to the apply instance of the target database.
Action:
Connect to the indicated instance and reissue the SWITCHOVER or FAILOVER command.
ORA-16524: unsupported command, option, or argument
Cause:
A command, option, or fast-start failover condition argument was specified that is not supported in this release.
Action:
If trying to enable or disable a fast-start failover condition, try a different Oracle error number. Otherwise, contact Oracle Support Services.
ORA-16525: The Oracle Data Guard broker is not yet available.
Cause:
The Oracle Data Guard broker process was either not yet started, was initializing, or failed to start.
Action:
If the broker has not been started, set the DG_BROKER_START initialization parameter to true and allow the broker to finish initializing before making the request. If the broker failed to start, check the Oracle Data Guard log for possible errors. Otherwise, retry the operation.
ORA-16526: unable to allocate memory to process request
Cause:
The Oracle Data Guard broker was unable to allocate memory for a request.
Action:
Increase the size of the System Global Area (SGA).
ORA-16527: unable to allocate broker System Global Area (SGA) memory
Cause:
The Oracle Data Guard broker was unable to allocate memory within the System Global Area (SGA).
Action:
Increase the size of the System Global Area (SGA) memory.
ORA-16528: unable to allocate Program Global Area (PGA) memory
Cause:
There was insufficient space in Program Global Area (PGA) to allocate memory.
Action:
Increase process virtual memory.
ORA-16530: invalid buffer or length
Cause:
A NULL buffer or a length of zero was specified.
Action:
Correct the command parameters and retry the command.
ORA-16532: Oracle Data Guard broker configuration does not exist
Cause:
A broker operation was requested that required a broker configuration to already be created.
Action:
Create a Data Guard broker configuration prior to performing other broker operations. If only one instance of a RAC database is reporting this error, ensure that the DG_BROKER_CONFIG_FILE[1|2] initialization parameters are set to file locations that are shared by all instances of the RAC database.
ORA-16534: switchover, failover or convert operation in progress
Cause:
The Oracle Data Guard broker returned this status because a switchover, failover or convert operation was in progress. The broker could not accept new commands until the operation finished.
Action:
Wait until the operation is complete and reissue the command.
ORA-16535: Oracle Restart or Oracle Clusterware prevented completion of broker operation
Cause:
The broker could not complete the operation because Oracle Restart (for single instance databases) or Oracle Clusterware (for RAC databases) could not stop services or instances on this database.
Action:
Check the Oracle Data Guard broker log file for more information and stop the appropriate services or instances using SRVCTL. Then retry the broker operation.
ORA-16538: no match on requested item
Cause:
The Oracle Data Guard broker did not recognize the specified property or state name, or a fast-start failover condition was specified that is not enabled.
Action:
Verify the command parameters and reissue the command.
ORA-16540: invalid argument
Cause:
One of the arguments for the specified command was invalid.
Action:
Verify the arguments and then reissue the command.
ORA-16541: member is not enabled
Cause:
The member specified in the command was not enabled.
Action:
Select an enabled member and reissue the command.
ORA-16544: modifying DG_BROKER_START requires SID='*' qualifier
Cause:
The setting for the DG_BROKER_START parameter must be exactly the same on all RAC database instances. The SID='*' qualifier was required in the command.
Action:
Reenter the command using the SID='*' qualifier.
ORA-16547: cannot disable or remove the primary database
Cause:
An attempt was made to disable broker management of the primary database or remove the primary database from the broker configuration while the configuration was enabled.
Action:
If you wish to disable broker management of the primary database when the configuration is enabled, you must instead disable broker management of the entire broker configuration. If you wish to remove the primary database from the broker configuration while the configuration is enabled, you must instead remove the entire broker configuration.
ORA-16548: database not enabled
Cause:
An attempt was made to modify or query a disabled database. This error is also returned on an attempt to enable, modify, or query a database that the broker has disabled because of a switchover or failover operation. The broker disables its management of a database when it detects that the database needs to be re-created because of a failover or switchover operation.
Action:
If broker management of the database is disabled, enable it and reissue the command.
ORA-16549: invalid string
Cause:
An invalid or NULL string value was specified.
Action:
Correct command parameters and retry.
ORA-16550: truncated result
Cause:
A string property value was truncated due to insufficient buffer size.
Action:
Specify a larger receive buffer.
ORA-16551: short string copied
Cause:
A string property value that did not fill the receive buffer was placed in the receive buffer.
Action:
This is an informational message only.
ORA-16552: error occurred while generating directives for client
Cause:
The operation could not be completed because the broker required assistance from the client that it was unable to provide because of the accompanying error.
Action:
See the accompanying error message for more information and follow the directions provided in the Action section of that message. Then retry the operation.
ORA-16555: database is not active
Cause:
An operation was attempted on a database that was not active. not active.
Action:
Verify that the database is active and retry the operation.
ORA-16556: observer version mismatch
Cause:
This version of the observer was incompatible with the version of the specified Oracle database server to which the observer had been connected. This observer client cannot be used to observe the specified Oracle server.
Action:
Use a version of the observer that is compatible with the Oracle database server to be observed.
ORA-16557: database is already in use
Cause:
An attempt was made to create a duplicate database in the broker configuration, or to add a duplicate instance (sid) for an existing database in the broker configuration.
Action:
Check the database to be added to ensure there are no duplicates.
ORA-16558: database specified for switchover is not a standby database
Cause:
An attempt was made to switchover to a database that was not a standby database.
Action:
Locate an enabled standby database and select that database as the target of the switchover.
ORA-16561: cannot remove an active instance
Cause:
The instance to be removed was running.
Action:
Shut down the instance and reissue the REMOVE command.
ORA-16568: cannot set property string
Cause:
The specified property could not be modified because it was either a monitorable property or a property that did not exist.
Action:
Retry the command with a valid configurable property.
ORA-16569: Oracle Data Guard configuration is not enabled
Cause:
The requested operation required that broker management of the Data Guard configuration must be enabled.
Action:
Enable the Oracle Data Guard configuration and reissue the command.
ORA-16570: database needs restart
Cause:
The Oracle Data Guard broker operation required this database instance to be shut down and restarted.
Action:
If DGMGRL or Enterprise Manager has not already done so, shut down the Oracle instance and then restart it.
ORA-16571: Oracle Data Guard configuration file creation failure
Cause:
The Oracle Data Guard broker was unable to create the configuration file on permanent storage.
Action:
Verify space, permissions and file name as indicated by the DG_BROKER_CONFIG_FILE[1|2] initialization parameters and retry the operation.
ORA-16572: Oracle Data Guard configuration file not found
Cause:
The Oracle Data Guard broker configuration file was either unavailable or did not exist.
Action:
Verify that the configuration file was successfully created. If the DG_BROKER_CONFIG_FILE[1|2] initialization parameters were changed, ensure the file name on disk and the parameter value match, there is space on the device, and the proper permissions are granted. For a RAC database, ensure that these initialization parameters are set to file locations that are shared by all instances of the RAC database.
ORA-16573: attempt to change or access configuration file for an enabled broker configuration
Cause:
The operation was rejected because the Oracle Data Guard broker configuration file was in use. The attempted operation was unsafe while broker management of the configuration was enabled. For example:
- An attempt was made to alter the DG_BROKER_CONFIG_FILE[1|2] initialization parameters while the broker was running.
- Non-broker access (such as DBMS_FILE_TRANSFER) to the configuration files was attempted. See the alert log for additional information.
Action:
Disable the broker configuration and shut down the Oracle Data Guard broker, then retry the operation. If the operation includes altering the DG_BROKER_CONFIG_FILE[1|2] initialization parameters, be sure that the new parameter values correctly specify the files at their expected location before reenabling broker management of the configuration.
ORA-16574: switchover disallowed when required databases are shut down
Cause:
Switchover failed because either the primary database or the designated standby database were shut down.
Action:
Ensure that the primary and standby databases are running and that primary database is shipping redo data to the designated standby database. Also ensure that that the designated standby database is applying the redo data received from the primary database.
ORA-16575: request terminated because failover is in progress
Cause:
This error was returned when the broker terminated a request because it was processing a failover command.
Action:
Wait for failover to complete and then retry the request.
ORA-16576: failed to update Data Guard configuration file
Cause:
A failure was encountered while the broker was updating the Oracle Data Guard broker configuration file on permanent storage.
Action:
Verify space, permissions and file name as indicated by the DG_BROKER_CONFIG_FILE[1|2] initialization parameters.
ORA-16577: corruption detected in Data Guard configuration file
Cause:
The Oracle Data Guard broker detected errors while loading the configuration file.
Action:
Verify space, permissions and file name as indicated by the DG_BROKER_CONFIG_FILE[1|2] initialization parameters. Contact Oracle Support Services.
ORA-16578: failed to read Data Guard configuration file
Cause:
A failure was encountered while the broker was reading the configuration file on permanent storage.
Action:
ORA-16582: cannot change instance-specific property
Cause:
An attempt was made to change an instance-specific property for a database that had more than one instance.
Action:
Retry the command and identify a specific instance whose property value is to be changed.
ORA-16584: operation cannot be performed on a standby database
Cause:
The database specified for the operation was a standby database, or the operation was attempted on a standby database.
Action:
Check the database type and retry the operation. If the command must be executed on a primary database, connect to the primary database and retry the operation.
ORA-16585: operation cannot be performed on a primary database
Cause:
The database specified for the operation was a primary database, or the operation was attempted on a primary database.
Action:
Check the database type and retry the operation. If the command must be executed on a standby database, connect to a standby database and retry the operation.
ORA-16586: cannot change database property with EDIT INSTANCE command
Cause:
An attempt was made to change a database property using an EDIT INSTANCE command instead of an EDIT DATABASE command.
Action:
Use the EDIT DATABASE command to change database properties.
ORA-16587: ambiguous object specified to Data Guard broker
Cause:
An object was specified that the broker could not uniquely distinguish from other objects in the configuration.
Action:
Try to further distinguish the object specified for the operation and reissue the command.
ORA-16589: Oracle Data Guard broker detected network transfer error
Cause:
The Oracle Data Guard broker detected an error while transferring data from one database to another. This may happen when:
- The broker detects an inconsistency in the block count of configuration file when the file is transmitted between databases.
- The broker encountered an error when writing the configuration file.
Action:
ORA-16594: DMON background process is not running
Cause:
The Oracle Data Guard broker background process, DMON, was not running.
Action:
Check the Oracle Data Guard broker log file and DMON process trace file to determine why the DMON process is not running.
ORA-16595: process string failed to terminate
Cause:
The specified process did not terminate at the request of the Data Guard broker.
Action:
ORA-16596: database not part of the Oracle Data Guard broker configuration
Cause:
The specified database was not in the Oracle Data Guard broker configuration.
Action:
Retry the command with a database that is in the broker configuration.
ORA-16597: Oracle Data Guard broker detects two or more primary databases
Cause:
The Oracle Data Guard broker detected two or more primary databases in the broker configuration and could not continue.
Action:
ORA-16598: Oracle Data Guard broker detected a mismatch in configuration
Cause:
The Oracle Data Guard broker detected a significant mismatch while performing configuration membership validation between two or more databases in the broker configuration. This can occur when the primary database has stale broker configuration files.
Action:
ORA-16599: Oracle Data Guard broker detected a stale configuration
Cause:
The Oracle Data Guard broker detected a stale configuration during initialization for this database.
Action:
The broker will automatically resolve this situation once the primary database completes its initialization.
ORA-16600: not connected to target standby database for failover
Cause:
The failover command failed because the client was not connected to the target standby database.
Action:
Explicitly connect to the standby database to be failed over to and retry the failover command.
ORA-16602: database must be disabled to perform this operation
Cause:
An attempt was made to edit a database property while the database was enabled.
Action:
Disable the database and retry the command.
ORA-16603: database is part of another Data Guard broker configuration
Cause:
The database was part of another Data Guard broker configuration. This could occur if the original configuration was re-created while this database was disconnected from the network or the same database was added to two different Data Guard broker configurations.
Action:
Make sure the database belongs to only one broker configuration. Shut down the broker by setting the DG_BROKER_START initialization parameter to false. Then, remove the Oracle Data Guard broker configuration files. Finally, restart the broker by setting the DG_BROKER_START initialization parameter to true.
ORA-16604: operation not allowed on a database that ships redo data
Cause:
An attempt was made to delete, disable, or convert a database that ships redo data to another database.
Action:
Ensure that the name of the database to be deleted, disabled, or converted is not specified in another database's RedoSource property.
ORA-16606: unable to find property "string"
Cause:
The specified property did not exist.
Action:
Specify a valid property name and reissue the command.
ORA-16607: one or more databases have failed
Cause:
A failure was detected for one or more databases in the Data Guard broker configuration.
Action:
Locate the database(s) with a failure status and correct it.
ORA-16608: one or more databases have warnings
Cause:
A warning was detected for one or more databases in the Data Guard broker configuration.
Action:
Locate the database(s) with a warning status and correct it.
ORA-16609: database is being disabled
Cause:
A command was attempted on a database that was being disabled. For example, attempting to reinstate the old primary database, the database that was the primary database prior to the most recent failover, before it was ready to be reinstated.
Action:
Wait for the Oracle Data Guard broker to disable the database and then retry the command.
ORA-16610: command "string" in progress
Cause:
The specified broker command was already running and the command issued could not be completed.
Action:
Wait for the specified command to finish and then retry the command.
ORA-16611: command aborted at user request
Cause:
The command was aborted at the user's request.
Action:
No action required.
ORA-16612: string value too long for attribute "string"
Cause:
The string value for the named attribute was too long.
Action:
Specify a shorter string value.
ORA-16613: initialization in progress for database
Cause:
A request was made that required access to the Oracle Data Guard broker configuration before the Oracle Data Guard broker had completed initialization.
Action:
Wait until the Oracle Data Guard broker has completed initialization, then reissue the command.
ORA-16614: Oracle Data Guard broker configuration is disabled
Cause:
An attempt to enable a database failed because the Oracle Data Guard broker configuration was disabled.
Action:
Enable the Oracle Data Guard broker configuration and issue the DGMGRL CLI SHOW CONFIGURATION command to see if there are any databases that are still disabled. If the database you tried to enable is still disabled, issue the DGMGRL CLI SHOW DATABASE command to check the status of the database. If the database status indicates that the database needs to be reinstated, then issue the DGMGRL CLI REINSTATE DATABASE command to reinstate and enable the database. If the database does not require reinstatement, then issue the DGMGRL CLI ENABLE DATABASE command to enable the database.
ORA-16617: unknown object identifier specified in request
Cause:
Object identifier specified in the request was invalid or unknown.
Action:
Verify that a valid object identifier is specified and reissue the command.
ORA-16619: condition for fast-start failover is already enabled
Cause:
The condition specified for fast-start failover was already enabled.
Action:
No action is required. Use the DGMGRL CLI SHOW FAST_START FAILOVER command to see the conditions that are enabled.
ORA-16620: one or more databases could not be reached for a delete operation
Cause:
One or more standby databases could not be reached for either a DGMGRL CLI REMOVE DATABASE or a REMOVE CONFIGURATION command.
Action:
This typically indicates a network problem where the standby database is unable to respond to the primary database. In the event of this situation, examine the primary database Data Guard broker log file to determine which standby databases could not be reached. For each standby database not reached, connect to that database and shut down the broker by setting the initialization parameter, DG_BROKER_START, to false. After the broker has been shut down for the standby database, locate the Data Guard broker configuration files from the standby database DG_BROKER_CONFIG_FILE[1|2] initialization parameter values and delete them. Then restart the broker by setting DG_BROKER_START to true.
ORA-16621: database name for ADD DATABASE must be unique
Cause:
An attempt was made to add a database to the broker configuration that already included a database with the specified name. The database names must be unique.
Action:
Verify that a unique name is specified for the new database to be added. Also, the database name must match the DB_UNIQUE_NAME initialization parameter of the database.
ORA-16622: two or more broker database objects resolve to the same database
Cause:
Multiple database objects referred to the same database.
Action:
Examine the details of all databases in the broker configuration and verify that there are not two or more databases referring to the same database. If two or more database profiles in the broker configuration have the same value for the DGConnectIdentifier database property, either:
- Remove and re-add the erroneously defined database(s) to resolve the ambiguity.
- Ensure that the DGConnectIdentifier database property for each database allows the broker to properly connect to that database.
ORA-16623: database detected role change
Cause:
A successful switchover or failover operation had been completed and was detected during database startup or broker health check. If this database was unavailable during a switchover or failover operation, it may not be a viable standby database for the new primary database and was disabled by the Oracle Data Guard broker.
Action:
Connect to the new primary database and examine the broker configuration for databases that were disabled and that may require reinstatement or re-creation.
ORA-16624: broker protocol version mismatch detected
Cause:
A network protocol version number mismatch was detected. This could happen if the databases in the broker configuration were not running the same version of Oracle. The broker would disable standby databases that were not running the same version of Oracle as the primary database if this situation was detected.
Action:
Examine the version of Oracle installed on all databases in the broker configuration to ensure they are identical. Once all of the databases in the broker configuration are running the same version of Oracle, reenable the standby databases that were disabled.
ORA-16625: cannot reach database "string"
Cause:
The command could not be executed because the database noted in the error text was not reachable from the database where the command was issued.
Action:
See accompanying messages for more information. Check the network connections to the specified database. Alternatively, connect to a different database in the Oracle Data Guard broker configuration and retry the command.
ORA-16626: failed to enable specified database
Cause:
This status was returned when attempting to enable a standby database that:
- Could not locate itself in the broker configuration file.
- Failed to distinguish itself from two or more databases in the configuration file.
- Determined it missed a role change within the configuration.
Action:
To correct the problem, try one of these actions:
- Confirm that the host and SID names for the database exactly match the values in the HOST_NAME and INSTANCE_NAME columns of V$INSTANCE.
- Confirm that there are not two or more databases with the same connect identifier. That is, multiple databases in the broker configuration should not reach the same database.
- If a failover had been performed and the old primary database has been re-created (or a standby database has been re-created), make sure the Oracle Data Guard broker configuration files have been removed for that database. Do NOT remove the configuration files that are in use by the new primary database.
ORA-16627: operation disallowed since no standby databases would remain to support protection mode
Cause:
This status was returned because of one of the following:
- The broker rejected an attempt to change the overall configuration protection mode since it could not find any enabled standby databases that supported the proposed protection mode.
- The broker rejected an attempt to enable the configuration if it determined that there were no enabled standby databases that supported the overall protection mode.
- The broker rejected an attempt to disable or remove a database that, if disabled or deleted, would result in no remaining standby databases that could support the overall configuration protection mode.
- The broker rejected an attempt to switchover if doing so would violate the overall configuration protection mode.
- Performing automatic health check if the broker determined that no standby datbases supported the overall protection mode.
Action:
- If changing the overall protection mode, confirm that at least one standby database satisfies the new protection mode.
- For enable failures, confirm that at least one standby database has a LogXptMode configurable property setting that supports the current overall protection mode.
- For delete and disable failures, confirm that at least one other standby database has a LogXptMode configurable property setting that supports the overall protection mode.
- For switchover failures that occur when the configuration is operating in maximum protection or maximum availability mode, confirm that at least one other standby database has its LogXptMode configurable property set to the value "SYNC". If the configuration contains a primary database and a single standby database and is operating in either maximum protection or maximum availability mode, ensure that the LogXptMode configurable property of the primary database is set to the value "SYNC". Since the old primary database will become the standby database after switchover completes, its LogXptMode configurable property setting must support the configuration protection mode.
- For health check error, confirm that at least one standby database has a LogXptMode configurable property setting that supports the current overall protection mode.
ORA-16628: broker protection mode inconsistent with the database setting
Cause:
The Oracle Data Guard broker protection mode saved in the broker configuration file was inconsistent with the actual database setting.
Action:
Reset the protection mode through the Oracle Data Guard broker.
ORA-16629: database reports a different protection level from the protection mode
Cause:
The current database protection level was different from the configured protection mode. This typically was caused by redo transport problems, or the primary database was not open.
Action:
Check the database alert log files and Data Guard broker log files for more details. Also, check the redo transport status. Ensure that one standby database supports the configured protection mode and that the network to that standby database is working properly. Ensure the primary database is open.
ORA-16630: database property has been deprecated
Cause:
The property that was specified in the command was deprecated.
Action:
Check the broker documentation to identify a replacement property or SQL command for the deprecated property.
ORA-16631: operation requires shutdown of database or instance "string"
Cause:
The Oracle Data Guard broker operation required a shutdown of the database or instance.
Action:
If database or instance has not been shutdown by the DGMGRL CLI or Enterprise Manager, shutdown the database or instance manually.
ORA-16632: instance being added to database profile
Cause:
The Oracle Data Guard broker determined that an instance successfully found its database profile within the broker configuration file, but lacked an instance-specific profile. The broker automatically created an instance-specific profile and associated the instance with its database profile.
Action:
No user action is required. The broker will automatically associate the instance with its database profile and incorporate the instance into broker activity.
ORA-16633: the only instance of a member cannot be removed
Cause:
The instance to be removed was the only instance of the corresponding member that was known to the broker.
Action:
Remove the corresponding member from the broker configuration instead of the individual instance of the member.
ORA-16635: network connection failed during transmission
Cause:
The Oracle Data Guard broker detected a connection failure to a remote database in the broker configuration. This failure happened in the middle of a transmission session. A transmission session usually requires more than one send operation for sending a large amount of data (for example, the broker configuration file) to the remote database.
Action:
In most cases, no user action is required. The Oracle Data Guard broker always tries to resend the data. This error will be reported if the problem persists. This error indicates there are some problems with the network connection between broker managed databases. Further network troubleshooting should be done to identify and correct the actual problem.
ORA-16636: fast-start failover target standby in error state, cannot stop observer
Cause:
A STOP OBSERVER operation could not be completed when fast-start failover was enabled because the target standby database could not participate in the STOP OBSERVER operation.
Action:
Additional information about this failure is recorded in the Data Guard broker log file for the primary database. This information helps to identify the reason why the target standby database was unable to participate in the STOP OBSERVER operation. If the problem can be corrected by the information in the broker log file, retry the operation. Alternatively, fast-start failover may be forcibly disabled by connecting to the primary database and issuing the DISABLE FAST_START FAILOVER FORCE command from the DGMGRL CLI. Once fast-start failover has been forcibly disabled, the observer can be stopped regardless of the current state of the target standby database.
ORA-16637: maximum number of Oracle error numbers for fast-start failover already reached
Cause:
The broker could not enable any more Oracle error numbers for initiating a fast-start failover.
Action:
Use the DGMGRL CLI SHOW FAST_START FAILOVER command to help identify an Oracle error number that can be disabled before attempting to enable an additional error number for initiating a fast-start failover.
ORA-16638: could not obtain instance status
Cause:
The broker could not determine whether the specified instance was running.
Action:
See the next error message in the error stack for more detailed information. If the situation described in the next error in the stack can be corrected, do so; otherwise, contact Oracle Support Services.
ORA-16639: specified instance inactive or currently unavailable
Cause:
An attempt was made to perform an operation on an instance that was not running or was unavailable.
Action:
Ensure that the instance specified in the operation is running and then retry the operation.
ORA-16642: DB_UNIQUE_NAME mismatch
Cause:
The expected DB_UNIQUE_NAME value did not match the actual DB_UNIQUE_NAME value for the database that the broker contacted using the connect identifier that was associated with that database.
Action:
Verify that the connect identifier correctly connects to the intended database. Verify that the name of the database the broker expects to find by that connect identifier matches the actual DB_UNIQUE_NAME for that database.
ORA-16643: unable to determine location of broker configuration files
Cause:
The Oracle Data Guard broker was unable to determine the location of its configuration files from the DG_BROKER_CONFIG_FILE[1|2] initialization parameters.
Action:
Retry the operation and, if the error persists, contact Oracle Support Services.
ORA-16644: apply instance not available
Cause:
The broker operation could not finish, because it requires a running apply instance for the standby database, and either there was no such instance designated for the standby database or the designated apply instance was not currently available.
Action:
Start the designated apply instance or wait until the broker specifies an instance to be the apply instance and reissue the command.
ORA-16645: startup of an instance interrupted current operation
Cause:
The startup of an instance that is not part of the broker configuration prevented the operation from completing.
Action:
Reissue the operation after the new instance has joined the Data Guard configuration.
ORA-16646: fast-start failover is disabled
Cause:
The operation was not allowed because fast-start failover was disabled.
Action:
Enable fast-start failover and retry the operation.
ORA-16647: could not start more than one observer
Cause:
The observer could not start because there was another observer already observing the Oracle Data Guard configuration for which fast-start failover may have been enabled.
Action:
Stop the running observer. Retry the operation.
ORA-16648: a new observer registered with identifier string
Cause:
The observer was registered with the Oracle Data Guard broker and will begin observing the Oracle Data Guard configuration for conditions that warrant doing a fast-start failover.
Action:
None
ORA-16649: possible failover to another database prevents this database from being opened
Cause:
An attempt to open the primary database was made either after a failover occurred, or when it was likely to have occurred as the result of the primary being isolated from the fast-start failover target standby database and from the fast-start failover observer.
Action:
Check if a failover did occur. If fast-start failover is enabled, and a failover did not occur, ensure that connectivity exists between the primary database and either the observer or the target standby database. Then, try opening the database again.
ORA-16650: unrecognized object specified
Cause:
An unrecognized database or far sync instance was specified in the command.
Action:
Try the command again using a valid object name. Use the SHOW CONFIGURATION command to identify the members in the configuration.
ORA-16651: requirements not met for enabling fast-start failover
Cause:
The attempt to enable fast-start failover could not be completed because one or more requirements were not met:
- The Oracle Data Guard configuration must be in either MaxAvailability or MaxPerformance protection mode.
- The LogXptMode property for both the primary database and the fast-start failover target standby database must be set to either SYNC or FASTSYNC if the configuration protection mode is set to MaxAvailability mode.
- The LogXptMode property for both the primary database and the fast-start failover target standby database must be set to ASYNC if the configuration protection mode is set to MaxPerformance mode.
- The primary database and the fast-start failover target standby database must both have flashback enabled.
- No valid target standby database was specified in the primary database FastStartFailoverTarget property prior to the attempt to enable fast-start failover, and more than one standby database exists in the Oracle Data Guard configuration.
- fast-start failover target standby database did not receive redo data directly from the primary database or from a far sync instance.
Action:
Retry the command after correcting the issue:
- Set the Oracle Data Guard configuration to either MaxAvailability or MaxPerformance protection mode.
- Ensure that the LogXptMode property for both the primary database and the fast-start failover target standby database are set to either SYNC or FASTSYNC if the configuration protection mode is set to MaxAvailability.
- Ensure that the LogXptMode property for both the primary database and the fast-start failover target standby database are set to ASYNC if the configuration protection mode is set to MaxPerformance.
- Ensure that both the primary database and the fast-start failover target standby database have flashback enabled.
- Set the primary database FastStartFailoverTarget property to the DB_UNIQUE_NAME value of the desired target standby database and set the desired target standby database FastStartFailoverTarget property to the DB_UNIQUE_NAME value of the primary database.
- Ensure the RedoSource properties of both the primary and the target standby database are set to either the empty value or the name of a far sync instance.
ORA-16652: fast-start failover target standby database is disabled
Cause:
The command to enable or disable fast-start failover could not be completed because Data Guard broker management of the fast-start failover target standby database is currently disabled.
Action:
Enable broker management of the target standby database and reissue the command. If an attempt was made to disable fast-start failover when this error was reported, disable fast-start failover forcibly using the DGMGRL DISABLE FAST_START FAILOVER FORCE command. Consult the documentation for more information.
ORA-16653: failed to reinstate database
Cause:
The Oracle Data Guard broker failed to reinstate the specified database because the reinstatement could not be completed or the database was already enabled.
Action:
Additional information about this failure is recorded in the primary database or the specified database Data Guard broker log files. This information is helpful in determining how to proceed.
ORA-16654: fast-start failover is enabled
Cause:
The attempted command was not allowed while fast-start failover was enabled:
- The FastStartFailoverTarget property may not be modified.
- The LogXptMode property for either the primary database or the fast-start failover target standby database may not be modified.
- The configuration's protection mode may not be modified.
- Neither the broker configuration nor the fast-start failover target standby database may be disabled using the DGMGRL CLI DISABLE command.
- Neither the broker configuration nor the fast-start failover target standby database may be removed using the DGMGRL CLI REMOVE command.
- The FAILOVER IMMEDIATE command is not allowed.
- The DG_BROKER_START initialization parameter may not be set to FALSE.
Action:
Disable fast-start failover, using the FORCE option if required. Then retry the attempted command.
ORA-16655: specified target standby database invalid
Cause:
The attempted command was not allowed because fast-start failover was enabled for this Data Guard configuration and the target standby database specified in the command differs from the standby database that was indicated by the FastStartFailoverTarget property associated with the current primary database.
Action:
Retry the attempted command by specifying the standby database that is indicated by the FastStartFailoverTarget property that is associated with the current primary database. Alternatively, fast-start failover may be disabled. Then retry the command using the originally specified target standby database.
ORA-16656: Oracle Data Guard broker detected role change
Cause:
The Oracle Data Guard broker detected a role change during database startup or health check.
Action:
Additional information about this failure is recorded in the Oracle Data Guard broker log files, one for the primary database and one for each standby database in the Oracle Data Guard configuration. This information is helpful in determining how best to proceed from this failure.
ORA-16657: reinstatement of database in progress
Cause:
Reinstatement of this database was in progress.
Action:
None
ORA-16658: unobserved fast-start failover configuration
Cause:
The fast-start failover configuration was currently unobserved so failover was disallowed.
Action:
Make sure the observer is running and has connectivity to both the primary and the target standby databases. Otherwise, disable fast-start failover to perform a failover in the absence of the observer process.
ORA-16659: failover operation in progress
Cause:
A primary database that restarted contacted a standby database that is being failed over to.
Action:
Shut down the primary database and wait for failover to complete on the standby database. Once failover is complete, restart the old primary database. If the failover occurred due to fast-start failover, restarting the primary database after failover is complete allows it to be automatically reinstated as a standby database to the new primary database.
ORA-16660: fast-start failover operation attempted in absence of a broker configuration
Cause:
An attempt was made to enable or disable fast-start failover when connected to a standby database for which broker configuration details are currently unavailable. For instance, the standby database may currently require re-creation (or flashback reinstantiation) before it may respond to broker client commands.
Action:
1) An attempt to enable or disable (non-FORCE) fast-start failover at this standby database will be rejected until such time that the broker configuration details have been made available to that standby database from the primary database. This normally occurs when the standby database is successfully re-created or flashed back, and then reenabled at the primary database. 2) Use the FORCE option to override fast-start failover that has been enabled at the standby database even when the broker configuration details are currently unavailable to the standby database. In this case, this status message is only a warning. Note that fast-start failover is not formally disabled in the broker configuration. The effect of this command issued under these circumstances may or may not be permanent, depending upon when the primary and standby databases regain full communication between each other and if the state of fast-start failover has been altered at the primary database in the meantime.
ORA-16661: the standby database needs to be reinstated
Cause:
A role change has caused this database to require reinstatement.
Action:
Use the DGMGRL REINSTATE DATABASE command or Enterprise Manager to reinstate the database. Reinstate the database as soon as possible, because the database will have to be re-created if another role change occurs while it is in this state.
ORA-16662: network timeout when contacting a database
Cause:
In response to the issued command, the Oracle Data Guard broker attempted to contact a database in the Oracle Data Guard configuration. That attempt failed because there was no response from that database after the period of time specified by the CommunicationTimeout configuration property.
Action:
Check the Oracle Data Guard broker log file for the details of the failure. Fix the problem and try the command again.
ORA-16664: unable to receive the result from a database
Cause:
During execution of a command, a database in the Oracle Data Guard broker configuration failed to return a result.
Action:
Check Oracle Data Guard broker log files for the details of the failure. Ensure network communication is working properly amongst the members of the configuration. Fix any possible network problems and reissue the command.
ORA-16665: timeout waiting for the result from a database
Cause:
The Oracle Data Guard broker was forced to time out a network connection to a remote database because:
- The network call to the remote database did not complete in a timely manner.
- The remote database was unable to execute the command due to an instance failure.
Action:
Check Data Guard broker log files for the details of the failure. If the network call did not complete in a timely manner, increase the CommunicationTimeout configuration property value and reissue the command.
ORA-16666: unable to initiate fast-start failover on a bystander standby database
Cause:
The request to initiate a fast-start failover using DBMS_DG.INITIATE_FS_FAILOVER was made on a bystander standby database. DBMS_DG.INITIATE_FS_FAILOVER can only be called on either the primary or fast-start failover target standby database.
Action:
Call DBMS_DG.INITIATE_FS_FAILOVER on either the primary or fast-start failover target standby database.
ORA-16667: request Oracle Data Guard broker client to reissue command
Cause:
The Oracle Data Guard broker operation required the same command be issued again from the client.
Action:
If DGMGRL or Enterprise Manager has not already done so, reissue the same command to the Oracle Data Guard broker manually.
ORA-16668: operation cannot be performed on the fast-start failover target standby database
Cause:
The database specified for the operation was the fast-start failover target standby database.
Action:
Retry the operation on a different database. Alternatively, disable fast-start failover and retry the operation.
ORA-16671: instance-specific property must be set uniquely for instances of an Oracle RAC database
Cause:
An attempt was made to set an instance-specific property to the same value for all instances of an Oracle RAC database for a property whose value must be unique for each instance.
Action:
Use the EDIT INSTANCE command and specify the SID of each instance whose instance-specific property value is to be changed.
ORA-16672: some switchover databases need to be restarted manually
Cause:
An error occurred during the restart of either the old and the new primary databases or both in a switchover operation.
Action:
Manually restart both the old and new primary databases, including all their Oracle RAC instances if it is an Oracle RAC database.
ORA-16673: standby database running different Oracle version
Cause:
The standby database was running a different version of Oracle than the primary database.
Action:
Ensure the primary and standby databases are running the same versions of Oracle.
ORA-16674: standby database type has changed
Cause:
An attempt to enable a database whose standby type changed from physical or snapshot to logical (or vice versa) was disallowed.
Action:
If the intention is to retain the database conversion to the new type, the database must be removed and re-added to the configuration in order to obtain correct values for database properties specific to the new standby type.
ORA-16675: database instance restart required for property value modification to take effect
Cause:
One or more properties that correspond to static initialization parameters were modified, but the database instances were not restarted. Or, a static initialization parameter that corresponds to a broker property was modified using an ALTER SYSTEM SQL*Plus statement.
Action:
Restart the database instances for the modified property values to take effect. If the error persists after having restarted the instance, use the DGMGRL CLI or Enterprise Manager to modify the property the static initialization parameter corresponds to.
ORA-16676: RedoRoutes property for two or more databases contains a circular route
Cause:
The value of a RedoRoutes property for two or more databases was set such that a database that sends redo also receives redo data data in the same route. For example, A sends to B, B sends to C, and C sends to A.
Action:
Correct the setting of the RedoRoutes propety on one or more databases to eliminate the circular route.
ORA-16677: physical standby database cannot be an alternate destination
Cause:
A physical standby database was set as an alternate destination for another physical standby, or for a far sync instance and the FALLBACK keyword was not specified.
Action:
Check the Oracle Data Guard broker log file for the reason for the failure and reissue the command. Ensure that a physical standby database is not set to be an alternate destination for another physical standby. If the physical standby is to be an alternate destination for a far sync instance, be sure to specify the FALLBACK keyword.
ORA-16678: unrecognized or duplicate attribute specified
Cause:
The specified value contained an unrecognized or duplicated attribute.
Action:
Ensure the property string does not contain any undefined or duplicate attributes. See the Oracle Data Guard broker documentation for supported attributes.
ORA-16679: one or more illegal keywords found
Cause:
The specified value contained one or more illegal keywords.
Action:
See the Oracle Data Guard broker documentation for the supported keywords.
ORA-16680: value contains unbalanced set of parentheses
Cause:
The specified value contained an unbalanced set of parentheses or a missing set of parentheses.
Action:
Ensure the parentheses are correctly matched and specify parentheses when required. See the Oracle Data Guard broker documentation for more information.
ORA-16681: value does not contain a colon
Cause:
The specified value did not contain a colon (:).
Action:
Include the colon (:) in the value.
ORA-16682: value contains duplicate databases or far sync instances
Cause:
The specified value contained the same database or far sync instance multiple times.
Action:
Ensure that a database or far sync instance is specified only once.
ORA-16683: illegal, empty substring specified in property value
Cause:
The value specified contained an illegal, empty string or substring, e.g. "()".
Action:
Remove the illegal empty strings and retry the command.
ORA-16684: maximum number of destinations exceeded
Cause:
The value specified for the RedoRoutes property contained more than the 30 destinations.
Action:
Ensure that no more than 30 destinations are specified.
ORA-16685: database does not receive redo data
Cause:
The RedoRoutes property for all members of the configuration were set such that this database did not receive redo data. Or, the transport state of the database that sends redo data to this database is not valid.
Action:
Check the setting of the RedoRoutes property for all members of the configuration. Ensure that at least one member's RedoRoutes property value is set to ship redo data to this database. Also check the transport state of the database that sends redo data to this database.
ORA-16686: database may not receive redo data if redo source is an alternate destination
Cause:
This database may not receive redo data if the redo source is an alternate destination that does not ship redo to this database.
Action:
Ensure that any alternates for the redo source for this database includes this database in its send to list.
ORA-16687: database has multiple redo sources
Cause:
Using the RedoRoutes properties, multiple redo sources were shipping redo to the standby.
Action:
Using the RedoRoutes properties, ensure that only one redo source ships redo to the standby.
ORA-16688: illegal alternate destination specified for RedoRoutes property
Cause:
The specified value contained an alternate destination that was duplicated with a regular destination or another alternate destination.
Action:
Ensure that any database that's specified as an alternate is not also specified as a regular destination or as an alternate destination for another regular destination in the same rule.
ORA-16689: illegal sender specified for RedoRoutes property
Cause:
A far sync instance or a recovery appliance was specified as the redo source in a RedoRoutes property rule.
Action:
Check the setting of the RedoRoutes property and confirm that a far sync instance or a recovery appliance is not specified as the redo source in the RedoRoutes property rule.
ORA-16690: illegal destination specified for RedoRoutes
Cause:
A specified destination in a RedoRoutes rule either appears in the primary setting of the same rule or is the local database itself.
Action:
Ensure that any specfifed destination in a RedoRoutes rule neither appears in the primary setting of the same rule nor be the local database itself.
ORA-16691: cannot remove a configuration member that is specified in a RedoRoutes property
Cause:
An attempt was made to remove a database or far sync instance that is specified in another configuration member's RedoRoutes property.
Action:
First remove the database or far sync instance from all other member's RedoRoutes property values. Then retry the remove command.
ORA-16692: operation disallowed for a database or far sync instance that sends redo data
Cause:
An attempt was made to delete, disable, or convert a database that sends redo data to another database or far sync instance.
Action:
Reset the value of the RedoRoutes property to the empty string of the database or far sync instance to be deleted, disabled, or converted (physical standby database).
ORA-16693: requirements not met for enabling fast-start failover
Cause:
- fast-start failover target standby database did not receive redo data directly from the primary database when the protection mode was set to maximum performance mode.
- The primary database has multiple routes to the fast-start failover target standby database.
Action:
- Ensure the RedoRoutes property of the primary includes the name of the fast-start failover target standby database when the protection mode is set to maximum performance mode.
- Ensure the RedoRoutes property of the primary database has only one route to the fast-start failover target standby database.
ORA-16694: one or more databases involved for switchover need to be restarted
Cause:
Action:
ORA-16695: redo transport mode incompatible with RedoRoutes property value
Cause:
The standby database could not be set to receive redo data from another standby database or a far sync instance because either a RedoRoutes rule for that standby did not specify ASYNC or the database's LogXptMode property was not set to ASYNC.
Action:
A standby database or far sync instance can only send redo data in asynchronous mode. Set the standby database's LogXptMode property to ASYNC before changing the RedoRoutes of the standby that is to send redo data. Or, specify ASYNC in the sending database's RedoRoutes property to override the value specified in the receiving database's LogXptMode property.
ORA-16696: redo source is disabled
Cause:
An attempt was made to enable a database whose redo source was disabled.
Action:
Enable the redo source first and then retry the command.
ORA-16697: wrong standby type specified for RedoRoutes property modification
Cause:
A logical standby database or snapshot standby database was specified to send redo data.
Action:
Check the setting of the RedoRoutes property and confirm that a primary database, physical standby database, or far sync instance is specified to send the redo data.
ORA-16698: member has a LOG_ARCHIVE_DEST_n parameter with SERVICE attribute set
Cause:
One or more LOG_ARCHIVE_DEST_n initialization parameters that contain a SERVICE attribute for another member in the configuration were set on the new member when attempting to add a standby database or far sync instance to the configuration.
Action:
Clear all LOG_ARCHIVE_DEST_n initialization parameters that contain a SERVICE attribute for another member in the configuration on the new member to be added.
ORA-16699: connect identifier not specified
Cause:
The connect identifier was not specified for the DGMGRL CLI ADD command.
Action:
Retry the ADD command with a connect identifier for the object to be added.
ORA-16700: the standby database has diverged from the primary database
Cause:
The primary database may have been flashed back or restored from a backup set and then reopened with the RESETLOGS option.
Action:
Re-create the standby database from the primary database or flash back the standby database to the same point the primary database had been flashed back to.
ORA-16701: Oracle Data Guard broker command failed
Cause:
The command to modify or query the database failed.
Action:
ORA-16702: Oracle Data Guard broker command warning
Cause:
The command to modify or query the database resulted in a warning.
Action:
Check the Oracle Data Guard broker log file for the warning and, if necessary, reissue the command.
ORA-16703: cannot set property while the database is enabled
Cause:
An attempt was made to change a database property while the database was enabled.
Action:
Disable the database first, update the property and then, reenable the database.
ORA-16704: standby database not valid for primary database
Cause:
The standby database was not added to the Oracle Data Guard broker configuration because it was not a valid standby database for the primary database.
Action:
Add a database to the Oracle Data Guard broker configuration that is a valid standby database to the primary database.
ORA-16706: Oracle Data Guard broker worker process not available
Cause:
The Oracle Data Guard broker worker process was not available to service the request.
Action:
ORA-16707: the value of the property string is invalid, valid values are string
Cause:
An invalid property value was specified while broker management of the database was disabled.
Action:
Reset the property to a valid value.
ORA-16708: the state supplied to broker is invalid
Cause:
The state name specified was invalid for the database.
Action:
Check the state name and reissue the command.
ORA-16709: standby archived log location settings conflict with database recovery area
Cause:
The StandbyArchiveLocation or AlternateLocation property was set to USE_DB_RECOVERY_FILE_DEST, but the initialization parameter DB_RECOVERY_FILE_DEST did not specify a valid destination.
Action:
Use a value other than USE_DB_RECOVERY_FILE_DEST for StandbyArchiveLocation or AlternateLocation, or set up a valid database recovery area by setting DB_RECOVERY_FILE_DEST to a valid destination.
ORA-16710: snapshot standby database should be converted back to a physical standby database as soon as possible
Cause:
A failover causes this snapshot standby database to enter a state that requires it to be re-created if another failover occurs before it is converted back to a physical standby database.
Action:
Reenable the snapshot standby database if it is disabled and convert it back to a physical standby database as soon as possible because the snapshot standby database will have to be re-created if another failover occurs while it is in this state.
ORA-16713: The Oracle Data Guard broker command timed out.
Cause:
The Oracle Data Guard broker timed out the command.
Action:
Verify that the command is valid for the database and then retry the command.
ORA-16714: the value of property string is inconsistent with the database setting
Cause:
The value of the specified configuration property was inconsistent with database in-memory settings or server parameter file settings. This may be caused by changing an initialization parameter that corresponds to a configuration property.
Action:
Query the InconsistentProperties property on the database to determine the which properties are set inconsistently. Reset the properties to make them with the database settings.
ORA-16715: redo transport-related property string of standby database "string" is inconsistent
Cause:
The value of the specified redo transport-related configuration property of the given standby database was inconsistent with the primary database redo transport service setting. This may be caused by changing an initialization parameter that corresponds to a configuration property.
Action:
Query the InconsistentLogXptProps property on the primary database to determine which redo transport properties are set inconsistently Reset the properties on the standby database to make them consistent with the primary database redo transport settings.
ORA-16716: clearing parameter LOG_ARCHIVE_DEST failed
Cause:
An attempt to clear the LOG_ARCHIVE_DEST parameter failed.
Action:
ORA-16717: clearing parameter LOG_ARCHIVE_DUPLEX_DEST failed
Cause:
An attempt to clear the LOG_ARCHIVE_DUPLEX_DEST parameter failed.
Action:
ORA-16718: failed to locate database
Cause:
The Oracle Data Guard broker was unable to locate the database in the broker configuration.
Action:
Add the database to the broker configuration and then reissue the command.
ORA-16719: unable to query V$ARCHIVE_DEST fixed view
Cause:
The broker failed to query the V$ARCHIVE_DEST fixed view."
Action:
Test and clear the problem using SQL*Plus.
ORA-16720: no LOG_ARCHIVE_DEST_n initialization parameters available
Cause:
All LOG_ARCHIVE_DEST_n initialization parameters were in use, or all initialization parameters from LOG_ARCHIVE_DEST_1 through LOG_ARCHIVE_DEST_10 that can support SYNC or ALTERNATE were in use.
Action:
Clear one or more LOG_ARCHIVE_DEST_n initialization parameters so that Data Guard broker can use them to set up the primary database redo transport.
ORA-16721: unable to set LOG_ARCHIVE_DEST_n initialization parameters
Cause:
The broker was unable to set one or more LOG_ARCHIVE_DEST_n initialization parameters.
Action:
Check the Oracle Data Guard broker log file and the Oracle alert log files for more details.
ORA-16722: unable to set LOG_ARCHIVE_DEST_STATE_n initialization parameters
Cause:
The broker was unable to set one or more LOG_ARCHIVE_DEST_STATE_n initialization parameters.
Action:
ORA-16723: setting AlternateLocation property conflicts with the redo transport setting
Cause:
The standby database was not using standby redo logs, and the redo transport service to the standby database is set to a nonzero value for the ReopenSecs property and a value of zero for the MaxFailure property. In this case, the redo transport service will attempt to send redo data to the standby database indefinitely and never switch to the alternate destination.
Action:
Any one of the following actions will solve the problem:
- add standby redo logs to the standby database.
- set ReopenSecs property to zero.
- set MaxFailure property to a nonzero value. After performing one of the above actions, reset the standby database AlternateLocation property.
ORA-16724: cannot resolve gap for one or more standby databases
Cause:
The primary database could not resolve a gap request from one or more standby databases.
Action:
To see which standby database has an unresolvable gap, check the status of the primary database using either Enterprise Manager or the DGMGRL CLI SHOW DATABASE command. Copy the missing archived log files from either backups or from another database in the configuration that has the files to the standby database that is missing the files.
ORA-16727: cannot close database
Cause:
The Oracle Data Guard broker could not close the database.
Action:
Terminate any active sessions connected to the database and then reissue the command.
ORA-16728: consistency check for property string found string error
Cause:
The consistency check for the specified property failed due to the error shown.
Action:
Check the error message and clear the error.
ORA-16729: validation of value for property string found string error
Cause:
The property value validation failed due to the error shown.
Action:
ORA-16730: SQL Apply was not started
Cause:
SQL Apply was not started because there were no pluggable databases opened in read/write mode.
Action:
Open at least one pluggable database in read/write mode. Data Guard will then automatically start SQL Apply.
ORA-16731: No pluggable databases are opened in read/write mode
Cause:
The operation failed because there were no pluggable databases opened in read/write mode.
Action:
Open at least one pluggable database in read/write mode and retry the command.
ORA-16732: Oracle Clusterware is restarting the database instance
Cause:
Action:
If Oracle Clusterware has not already done so, shut down the Oracle instance and then restart it.
ORA-16736: unable to find the destination entry of standby database "string" in V$ARCHIVE_DEST
Cause:
Either the standby destination was manually changed or deleted outside of Oracle Data Guard broker, or no entry was available for the Oracle Data Guard broker to use.
Action:
Clean up the destination setting, remove the unused settings, and reset the redo transport service.
ORA-16737: the redo transport service for standby database "string" has an error
Cause:
A communication problem with the standby database caused the redo transport to fail.
Action:
Query the LogXptStatus property to see the error message. Check the Oracle Data Guard broker log file and the Oracle alert log file for more details.
ORA-16738: redo transport service for database "string" is not running
Cause:
The redo transport service for the specified standby database was not running.
Action:
Check the Oracle Data Guard broker log file or the Oracle alert log file for more details. If necessary, start the redo transport service for the standby database.
ORA-16739: redo transport service for standby database "string" is running
Cause:
The redo transport service for the standby database was running.
Action:
Check the Oracle Data Guard broker log file for more details. If necessary, stop the redo transport service for the standby database.
ORA-16740: redo transport service for standby database "string" incorrectly set to ALTERNATE
Cause:
The redo transport service to the standby database was set to ALTERNATE when no other destination was set to alternate to this destination.
Action:
Reenable the standby database or the entire configuration to allow the configuration property settings to be propagated to the initialization parameters.
ORA-16741: the destination parameter of standby database "string" has incorrect syntax
Cause:
The destination defined in the server parameter file of the primary database had incorrect syntax and Data Guard broker failed to update the destination when redo transport services were enabled.
Action:
Fix the syntax error in the primary database server parameter file or remove the entry from the server parameter file. Also, check the values of the redo transport-related properties for the specified standby database.
ORA-16742: the standby database "string" has exhausted its quota
Cause:
The standby database exhausted its quota for storing archived redo logs.
Action:
Remove some archived redo logs from the standby database or increase its quota.
ORA-16743: cannot determine status of redo transport service for standby database "string"
Cause:
The status of redo transport to the specified standby database could not be determined.
Action:
ORA-16744: The DG_CONFIG list of LOG_ARCHIVE_CONFIG parameter is full.
Cause:
The DG_CONFIG list of the LOG_ARCHIVE_CONFIG attribute was full and the Oracle Data Guard broker was not able to add a new DB_UNIQUE_NAME to the list.
Action:
Remove some unused entries in the DG_CONFIG list, then reenable the database.
ORA-16745: unable to add DB_UNIQUE_NAME "string" into the DG_CONFIG list because it is full
Cause:
The DG_CONFIG list of the LOG_ARCHIVE_CONFIG attribute was full and the Oracle Data Guard broker was not able to add the specified DB_UNIQUE_NAME to the list.
Action:
Remove some unused entries in the DG_CONFIG list then reenable the database.
ORA-16746: Oracle Data Guard broker cannot mount the database
Cause:
The Oracle Data Guard broker failed to mount the database.
Action:
ORA-16747: logical standby database guard could not be turned on
Cause:
The Oracle Data Guard broker could not turn on the logical standby database guard.
Action:
ORA-16748: Oracle Data Guard broker cannot open the primary database
Cause:
The Oracle Data Guard broker failed to open the primary database.
Action:
ORA-16749: switchover to logical standby database failed
Cause:
The Oracle Data Guard broker failed to switch a logical standby database over to a primary database.
Action:
ORA-16750: failed to activate logical standby database
Cause:
The Oracle Data Guard broker failed to activate a logical standby database.
Action:
ORA-16751: failed to switchover to physical standby database
Cause:
The Oracle Data Guard broker failed to switch a physical standby database over to a primary database.
Action:
ORA-16753: Oracle Data Guard broker cannot open standby database
Cause:
The Oracle Data Guard broker failed to open the standby database.
Action:
ORA-16754: failed to activate physical standby database
Cause:
The Oracle Data Guard broker failed to activate the physical standby database.
Action:
ORA-16755: failed to set initialization parameter
Cause:
The Oracle Data Guard broker failed to set an initialization parameter using either the ALTER SYSTEM SET or ALTER SYSTEM RESET command.
Action:
ORA-16757: unable to get the value of this property
Cause:
The Oracle Data Guard broker failed to get the value for the specified property because the value for the specified property is not available for the current database role.
Action:
If the value of the specified property is not available for the current role of the database, specify this property for a database for which the value is available. Otherwise, check the Oracle Data Guard broker log file for more details.
ORA-16758: the specified apply instance is not running
Cause:
The Oracle Data Guard broker could not start apply services on the specified instance because that instance was not running.
Action:
Start the instance and then retry the command.
ORA-16759: cannot start SQL Apply with initial SCN
Cause:
The Oracle Data Guard broker failed to start SQL Apply with an initial system change number (SCN).
Action:
ORA-16760: cannot start SQL Apply
Cause:
The Oracle Data Guard broker failed to start SQL Apply.
Action:
ORA-16761: cannot stop SQL Apply
Cause:
The Oracle Data Guard broker failed to stop SQL Apply.
Action:
ORA-16762: invalid database state
Cause:
Database was not in the intended state.
Action:
Determine the reason why the database is not running in the intended state and reissue the command.
ORA-16763: redo transport service for a member is running
Cause:
The redo transport service for a member was running.
Action:
For more details, check the status of the primary database using either Oracle Enterprise Manager or the DGMGRL CLI SHOW DATABASE command. If necessary, stop the redo transport service to the member.
ORA-16764: redo transport service to a member is not running
Cause:
The redo transport service to a member was not running.
Action:
For more details, check the status of the primary database using either Oracle Enterprise Manager or the DGMGRL CLI SHOW DATABASE command. If necessary, start the redo transport service to the member.
ORA-16765: Redo Apply is running
Cause:
Redo Apply was running when it should have been stopped.
Action:
If necessary, stop Redo Apply.
ORA-16766: Redo Apply is stopped
Cause:
Redo Apply was stopped when it should have been running.
Action:
Check the alert log to see why Redo Apply terminated, correct any problems that may exist, and restart Redo Apply by setting the physical standby database state to APPLY-ON.
ORA-16767: SQL Apply is running
Cause:
SQL Apply was running when it should have been stopped."
Action:
If necessary, stop SQL Apply.
ORA-16768: SQL Apply is stopped
Cause:
SQL Apply was stopped when it should have been running."
Action:
Check the alert log to see why SQL Apply terminated, correct any problems that may exist, and restart SQL Apply by setting the logical standby database state to APPLY-ON.
ORA-16769: the physical standby database is open read-only
Cause:
All instances in the physical standby database were put into a read-only state instead of APPLY-OFF.
Action:
Issue the EDIT DATABASE SET STATE command to set the database to the APPLY-OFF state.
ORA-16770: Redo Apply not started since physical standby database is opening
Cause:
Redo Apply services could not be started on the physical standby database because it was being opened. The Oracle Data Guard broker will start Redo Apply services once the physical standby database has been opened.
Action:
No action required.
ORA-16771: failover to a physical standby database failed
Cause:
The Oracle Data Guard broker encountered errors when converting a physical standby database to a primary database.
Action:
ORA-16772: switchover to a standby database failed
Cause:
The Oracle Data Guard broker encountered errors when switching over to the specified standby database.
Action:
ORA-16773: cannot start Redo Apply
Cause:
The Oracle Data Guard broker failed to start Redo Apply.
Action:
Check the Oracle Data Guard broker log file and the Oracle alert log file for more details. If the database is already open, the broker will not start Redo Apply if the Oracle Active Data Guard option is not enabled.
ORA-16774: cannot stop Redo Apply
Cause:
The Oracle Data Guard broker failed to stop Redo Apply.
Action:
ORA-16775: target standby database in broker operation has potential data loss
Cause:
The target standby database specified for the broker operation did not have all the redo data from the primary database.
Action:
Confirm that the redo transport service on the primary database is functioning correctly by checking its status using either Enterprise Manager or the DGMGRL CLI SHOW DATABASE command. Reissue the broker command once all redo data is available on the target standby database.
ORA-16776: health check of the redo transport service failed
Cause:
The Oracle Data Guard broker could not complete the health check for the redo transport service.
Action:
ORA-16777: unable to find the destination entry of a standby database in V$ARCHIVE_DEST
Cause:
Either a destination was manually deleted or no entry was available for Oracle Data Guard.
Action:
Check the Oracle Data Guard broker log file and the Oracle alert log file for more details. The redo transport service may need to be reset.
ORA-16778: redo transport error for one or more databases
Cause:
The redo transport service was unable to send redo data to one or more standby databases.
Action:
Check the Oracle Data Guard broker log file and the Oracle alert log file for more details. Query the LogXptStatus property to see the errors.
ORA-16779: the destination parameter of a database is set incorrectly
Cause:
The destination was defined in the LOG_ARCHIVE_DEST_n server parameter file with incorrect syntax. The Oracle Data Guard broker failed to update the destination when the redo transport was turned on.
Action:
Check the Oracle Data Guard broker log file to see which database has the problem. Fix the syntax error in the server parameter file or remove the entry from the server parameter file. Check if the syntax of the redo transport-related properties are correct.
ORA-16780: a database has exhausted its archived redo log storage quota
Cause:
A database has exhausted its quota for storing archived redo logs.
Action:
Check the Oracle Data Guard broker log file to see which database has the problem. Remove some archived logs at the standby database or increase its quota.
ORA-16781: cannot determine status of redo transport service for standby database
Cause:
Action:
ORA-16782: instance not open for read and write access
Cause:
The database was mounted on an instance but not opened for read and write access.
Action:
For more details, check the status of the database using either Enterprise Manager or the DGMGRL CLI SHOW DATABASE command. If possible, open the instance manually.
ORA-16783: cannot resolve gap for database string
Cause:
The primary database could not resolve a gap request from the specified standby database(s).
Action:
Copy the missing archived redo log files from either backups or from another database in the configuration that has the files to the standby database(s) missing the files.
ORA-16784: database name specified by Dependency property is incorrect
Cause:
The database name, that should be the value of the DB_UNIQUE_NAME initialization parameter, specified in the Dependency property was incorrect.
Action:
Reset the Dependency property to the correct name of the database.
ORA-16785: the database is in NOARCHIVELOG mode
Cause:
The database was in NOARCHIVELOG mode when it was either a primary database or when it was a standby database that was being switched over to be a primary database.
Action:
Set the database to ARCHIVELOG mode by issuing the ALTER DATABASE ARCHIVELOG command.
ORA-16786: unable to access Oracle Data Guard broker configuration files
Cause:
The Oracle Data Guard broker configuration files did not exist or or could not be accessed.
Action:
ORA-16788: unable to set one or more database configuration property values
Cause:
This situation occurred when the broker attempted to set database configurable property values into the database by issuing ALTER SYSTEM or ALTER DATABASE commands. Typical causes of this error are:
- The values of redo transport-related properties contain syntax syntax errors.
- The value of the LogArchiveTrace property was out of range.
Action:
Check the Oracle Data Guard broker log file to see which property has the problem and set the property to the correct value.
ORA-16789: standby redo logs configured incorrectly
Cause:
Standby redo logs were not configured or were configured incorrectly for the database.
Action:
Standby redo logs are required when the redo transport mode is set to SYNC or ASYNC. Check the Oracle Data Guard documentation to find more information about the correct configuration of standby redo logs.
ORA-16790: the value of the configurable property is invalid
Cause:
An invalid property value was entered, or a RESET was attempted on a property for which no Broker default value exists.
Action:
Set the property to a correct value.
ORA-16791: unable to check the existence of the standby redo logs
Cause:
The database may not be mounted, or the query of the V$STANDBY_LOG fixed view failed.
Action:
Ensure the database is mounted and query the V$STANDBY_LOG fixed view to see if the problem has been corrected, and retry the operation.
ORA-16792: configurable property value is inconsistent with database setting
Cause:
The values of one or more configurable properties were inconsistent with database in-memory settings or server parameter file settings. This may happen by directly altering initialization parameters instead of editing configurable property values using Oracle Data Guard broker.
Action:
Query the InconsistentProperties property on the database or check the Oracle Data Guard broker log file to find which properties are set inconsistently. Reset these properties to make them consistent with the database settings. Alternatively, enable the database or the entire configuration to allow the configurable property settings to be propagated to the initialization parameters.
ORA-16793: logical standby database guard is off
Cause:
The logical standby database guard was turned off.
Action:
Issue the ALTER DATABASE GUARD ALL command to turn the guard on and verify that Data Guard health check error or warning is cleared.
ORA-16794: database guard is on for primary database
Cause:
The database guard was turned on for the primary database.
Action:
Issue the ALTER DATABASE GUARD NONE command to turn off the guard and verify that Data Guard health check error or warning is cleared.
ORA-16795: the standby database needs to be re-created
Cause:
A switchover or failover operation caused this database to require re-creation. The database was marked for re-creation because it was not a viable standby database for the new primary database. Until this error status is resolved for this database, information about this database and the broker configuration to which it belongs is unavailable to a broker client that is connected to this database. Therefore, all commands directed by that client to this database cannot be completed.
Action:
Re-create (or flash back) the standby database. Connect to the primary database in the broker configuration and reenable broker management of that database. Once enabled, it is possible to connect to that standby database and manage it with the broker. Alternatively, many client commands that cannot be completed at the standby database when in this error state can be completed successfully when issued to the primary database. In this case, simply reconnect to the primary database and retry the command.
ORA-16796: one or more properties could not be imported from the member
Cause:
The broker was unable to import property values for the member being added to the broker configuration. This error indicates:
- The Oracle Net service name specified in DGMGRL CREATE CONFIGURATION, ADD DATABASE, ADD FAR_SYNC, or ADD RECOVERY_APPLIANCE command was not one that provides access to the member being added.
- There were no instances running for the member being added.
Action:
Remove the member from the configuration using the REMOVE CONFIGURATION, REMOVE DATABASE, REMOVE FAR_SYNC, or REMOVE RECOVERY_APPLIANCE command. Make sure that the member to be added has at least one instance running and that the Oracle Net service name provides access to the running instance. Also, check the broker log file for additional information. Then, reissue the CREATE CONFIGURATION, ADD DATABASE, ADD FAR_SYNC, or ADD RECOVERY_APPLIANCE command.
ORA-16797: member is not using a server parameter file
Cause:
The member was not using a server parameter file or the broker was unable to access the server parameter file.
Action:
Issue the CREATE SPFILE='..' FROM PFILE='...' command to create a server parameter file and then restart the member to use it.
ORA-16798: unable to complete recovery during failover
Cause:
The physical standby database could not complete recovery during failover.
Action:
Check the Oracle Data Guard broker log file and the Oracle alert log files to see more details on the reason for the failure.
ORA-16799: Redo Apply is not running
Cause:
Either the Oracle Data Guard broker configuration indicated that Redo Apply was turned off, or the MRP0 recovery process was not running. As a result, Redo Apply-related properties could not be set.
Action:
Turn on Redo Apply through Oracle Data Guard broker and reissue the command to set a Redo Apply-related property.
ORA-16800: redo transport service for a standby database incorrectly set to ALTERNATE
Cause:
The redo transport service for a standby database was set to ALTERNATE when no other destination is set to alternate to this destination.
Action:
ORA-16801: redo transport-related property is inconsistent with database setting
Cause:
The values of one or more redo transport-related configuration properties were inconsistent with database in-memory settings or server parameter file settings. This may happen by directly altering initialization parameters instead of editing configurable property values using Oracle Data Guard broker.
Action:
Query the InconsistentLogXptProps property on the primary database or check the Oracle Data Guard broker log file to find which properties are set inconsistently. Reset these properties to make them consistent with the database settings. Alternatively, enable the database or the entire configuration to allow the configurable property settings to be propagated to the initialization parameters.
ORA-16802: downgrading redo transport mode from SYNC disallowed
Cause:
An attempt was made to downgrade the redo transport mode of a standby database from SYNC to ASYNC when the configuration was in Maximum Protection or Maximum Availability mode and the primary database was an Oracle RAC database. This was disallowed even though there may have been other standby databases with redo transport modes set to SYNC to support the protection mode.
Action:
Do one of the following if the redo transport mode of the standby must be downgraded:
- Shut down all instances of the primary database and restart one instance with the initialization parameter CLUSTER_DATABASE set to FALSE. Downgrade the redo transport mode of the standby database of interest. Then, shutdown the instance, set the the CLUSTER_DATABASE initialization parameter to TRUE, and restart all primary database instances.
- Downgrade the protection mode to Maximum Performance mode and then, downgrade the redo transport mode of the standby database of interest. Finally, upgrade the protection mode. This will require a restart of all primary database instances if upgrading to Maximum Protection mode. Note that the above only works when there is at least one standby database in the configuration that has its redo transport mode set to SYNC.
ORA-16803: unable to query a database table or fixed view
Cause:
Querying a database table or fixed view failed. The database may not be opened or mounted.
Action:
ORA-16804: one or more configuration properties have invalid values
Cause:
Oracle Data Guard broker health check detected that one or more configuration properties in the broker configuration had invalid values. The property values were changed while broker management of the database was disabled.
Action:
Check Data Guard broker log file for more details on which properties have invalid values and reset them through the Oracle Data Guard broker.
ORA-16805: change of LogXptMode property violates overall protection mode
Cause:
The broker disallowed the attempt to change the LogXptMode configurable property for the standby database because, if allowed, the overall protection mode for the configuration would have been violated.
Action:
If the LogXptMode configuration property must be changed for the specified standby database, first downgrade the overall protection mode for the broker configuration. After that operation has completed, the LogXptMode configuration property for the standby database can be changed.
ORA-16806: supplemental logging is not turned on
Cause:
Supplemental logging was not turned on while there was a logical standby database in the configuration. This could happen either on the primary database or on the logical standby database that was being switched over to become the primary database.
Action:
Check the Oracle Data Guard broker log file for more details. Issue the ALTER DATABASE ADD SUPPLEMENTAL LOG DATA (PRIMARY KEY, UNIQUE INDEX) COLUMNS to add supplemental logging.
ORA-16807: unable to change database protection mode
Cause:
An attempt to issue the ALTER DATABASE SET STANDBY TO MAXIMIZE {PROTECTION | AVAILABILITY | PERFORMANCE} failed.
Action:
Check the Oracle Data Guard broker log file and the Oracle alert log file for more information.
ORA-16808: primary database is not open
Cause:
A prior attempt to open the primary database was disallowed because the primary had shut itself down earlier after being isolated from both the fast-start failover observer and the target standby database for more than FastStartFailoverThreshold seconds. It was assumed that a fast-start failover was underway. Since that time, re-contact with either the observer or the target standby database indicates that no such failover had actually occurred. The primary database can now be opened.
Action:
Open the database by issuing the SQL*Plus ALTER DATABASE OPEN command.
ORA-16809: multiple warnings detected for the database
Cause:
The broker detected multiple warnings for the database.
Action:
To get a detailed status report, check the status of the database specified using either Enterprise Manager or the DGMGRL CLI SHOW DATABASE command.
ORA-16810: multiple errors or warnings detected for the database
Cause:
The broker detected multiple errors or warnings for the database.
Action:
ORA-16811: apply instance not recorded by the Oracle Data Guard broker
Cause:
The broker did not register an apply instance for a standby database.
Action:
Reenable the standby database to clear the error.
ORA-16812: log apply service not running on apply instance recorded by the broker
Cause:
Log apply services were not running on the instance the Data Guard broker expected them to be running upon.
Action:
ORA-16813: log apply service not running on apply instance string recorded by the broker
Cause:
Action:
ORA-16814: incorrect redo transport setting for AlternateLocation for standby database
Cause:
The Oracle Data Guard broker detected an incorrect redo transport setting for a standby database AlternateLocation property. The incorrect setting could be one of the following:
- The AlternateLocation property was empty, but the redo transport to the standby database had an ALTERNATE setting.
- The AlternateLocation property was not empty and the redo transport to the standby database had no ALTERNATE setting.
- The AlternateLocation property did not match the ALTERNATE setting in the redo transport. The mismatch may include service string, directory specification of the alternate location, or the DB_UNIQUE_NAME attribute.
- The LOG_ARCHIVE_DEST_STATE_n parameter corresponding to the alternate location was not set to ALTERNATE.
- The flash recovery area was being used by the standby database for archived logs, but the redo transport to the standby database still had an ALTERNATE setting for the AlternateLocation property. Data Guard broker log files provide more details on which of the above cases caused the error.
Action:
Reenable the primary database to clear the error.
ORA-16815: incorrect redo transport setting for AlternateLocation for standby database "string"
Cause:
Action:
ORA-16816: incorrect database role
Cause:
The Oracle Data Guard broker detected that the specified database had a different database role than that recorded in the Oracle Data Guard broker configuration. This could be the result of a failed switchover or failover operation, or a switchover or failover operation performed with SQL*Plus.
Action:
Check the Oracle Data Guard broker documentation to see how to recover from failed role change operations, or from role changes that were performed using SQL*Plus for databases managed by Oracle Data Guard broker.
ORA-16817: unsynchronized fast-start failover configuration
Cause:
The fast-start failover target standby database was not synchronized with the primary database. As a result, a fast-start failover could not happen automatically in case of a primary database failure.
Action:
Ensure that the fast-start failover target standby database is running and that the primary database can ship redo data to it. When the standby database has received all of the redo data from the primary database, the primary and standby databases will then be synchronized. The Oracle Data Guard configuration may then fail over automatically to the standby database in the event of loss of the primary database.
ORA-16818: fast-start failover suspended
Cause:
The primary database was intentionally shutdown. As a result, a fast-start failover could not happen automatically.
Action:
Start the primary database. This effectively restores the ability to automatically perform a fast-start failover in the event of a failure of the primary database.
ORA-16819: fast-start failover observer not started
Cause:
The observer for fast-start failover was not started. As a result, fast-start failover could not happen in the case of a primary database failure.
Action:
Start the fast-start failover observer by using, for example, the DGMGRL START OBSERVER command.
ORA-16820: fast-start failover observer is no longer observing this database
Cause:
A previously started observer was no longer actively observing this database. A significant amount of time elapsed since this database last heard from the observer. Possible reasons were:
- The host where the observer was running was not available.
- The network connection between the observer and this database was not available.
- The observer process was terminated unexpectedly.
Action:
Check the reason why the observer cannot contact this database. If the problem cannot be corrected, stop the current observer by connecting to the Oracle Data Guard configuration and issue the DGMGRL STOP OBSERVER command. Then, restart the observer on another host. Finally, use the DGMGRL START OBSERVER command to start the observer on the other host.
ORA-16821: logical standby database dictionary not yet loaded
Cause:
The logical standby database had not loaded the dictionary. This status was detected by the broker health check mechanism. Alternatively, this status may be returned when attempting to switch or fail over to a logical standby database that had not yet loaded its dictionary.
Action:
Start SQL Apply on the logical standby database, if it is not already running, and wait for it to reach the APPLYING state.
ORA-16822: new primary database not yet ready for standby database reinstatement
Cause:
The new primary database, as a result of a logical standby database failover operation, had not fully completed the failover operation. An attempt to reinstate a disabled standby database could not be completed until failover completed on the new primary database.
Action:
Wait until the failover operation has completed on the new primary database. Then retry the reinstate operation.
ORA-16823: redo transport mode is incompatible for current operation
Cause:
The redo transport mode of this database was incompatible for this broker operation.
Action:
Reset the LogXptMode database property for this database and retry the broker operation.
ORA-16824: multiple warnings, including fast-start failover-related warnings, detected for the database
Cause:
The broker detected multiple warnings for the database. At least one of these warnings may have prevented fast-start failover from occurring.
Action:
ORA-16825: multiple errors or warnings, including fast-start failover-related errors or warnings, detected for the database
Cause:
The broker detected multiple errors or warnings for the database. At least one of these errors or warnings may have prevented a fast-start failover from occurring.
Action:
ORA-16826: apply service state is inconsistent with the DelayMins property
Cause:
This warning was caused by one of the following reasons:
- The apply service was started without specifying the real-time apply option or without the NODELAY option when the DelayMins property was set to zero.
- The apply service was started with the real-time apply option or with the NODELAY option when the DelayMins property was set to a value greater than zero.
Action:
Reenable the standby database to allow the broker to restart the apply service with the apply options that are consistent with the specified value of the DelayMins property.
ORA-16827: Flashback Database is disabled
Cause:
The broker detected that the Flashback Database feature was disabled. With Flashback Database disabled, the broker would not be able to:
- reinstate a database that required reinstatement.
- convert a physical standby database to a snapshot standby database.
- convert a snapshot standby database to a physical standby database. Flashback Database may been disabled manually with the ALTER DATABASE FLASHBACK DATABASE OFF command or automatically by the database in the event of an error.
Action:
Check the database alert log to determine whether Flashback Database was disabled due to errors and then correct the problem. If Flashback Database had been manually disabled, reenable Flashback Database with the ALTER DATABASE FLASHBACK DATABASE ON command. If, after enabling Flashback Database, the database still cannot be reinstated or converted, you must re-create the database from a copy of the primary database.
ORA-16828: invalid value specified for REDO_TRANSPORT_USER initialization parameter
Cause:
An invalid value was specified for the REDO_TRANSPORT_USER initialization parameter. The length of the user name exceeded 30 characters.
Action:
Check the documentation and specify a new value for the REDO_TRANSPORT_USER initialization parameter.
ORA-16829: fast-start failover configuration is lagging
Cause:
The fast-start failover target standby database was not within the lag limit specified by the FastStartFailoverLagLimit configuration property. As a result, a fast-start failover could not happen in the event of a primary database failure.
Action:
Ensure that the fast-start failover target standby database is running and applying redo data and that the primary database is successfully transmitting redo data. If this condition persists consider raising the value of the FastStartFailoverLagLimit configuration property.
ORA-16830: primary isolated from fast-start failover partners longer than FastStartFailoverThreshold seconds: shutting down
Cause:
The primary database was isolated from both the observer and target standby database for longer than the seconds specified by the FastStartFailoverThreshold property. A fast-start failover probably occurred. If the FastStartFailoverPmyShutdown configuration property was set to TRUE, the broker will shut down the primary database in this situation.
Action:
Ensure one instance of this database is running and the database is mounted on that instance so that the broker may reinstate the old primary database.
ORA-16831: operation not allowed on this member
Cause:
The Oracle Data Guard broker operation was not allowed for the specified member of the Oracle Data Guard broker configuration.
Action:
Check the documentation for the Oracle Data Guard broker command and then reissue the command with the correct member.
ORA-16832: user-configurable fast-start failover initiated: shutting down
Cause:
The broker initiated a fast-start failover to the target standby database because a user-configurable condition was detected on the primary database. In addition, the broker shut down the primary database.
Action:
Correct the problem on the old primary database that caused the broker to initiate a fast-start failover, then reinstate the old primary database.
ORA-16833: no logging operations detected on database
Cause:
The broker detected that no logging operations were performed on this database. The data modified by these operations may be lost if failover or switchover was performed.
Action:
Use Data Repair Advisor to determine which operations were not logged before attempting a switchover or failover.
ORA-16834: control file corruptions detected on database
Cause:
The broker detected control files corruptions. Many database operations, including switchover and failover, may not be possible.
Action:
Use Data Repair Advisor to determine the extent of the corruptions and how to repair them.
ORA-16835: standby database has one or more unavailable standby redo log groups
Cause:
The broker detected that the standby database had one or more unavailable standby redo log groups.
Action:
Use Data Repair Advisor to determine which standby redo log groups are unavailable and how the log groups can be made available.
ORA-16836: one or more system data files are missing
Cause:
The broker detected that one or more system data files were missing.
Action:
Use Data Repair Advisor to determine which system data files are missing and how the files can be restored.
ORA-16837: one or more system data files are corrupt
Cause:
The broker detected that one or more system data files were corrupt.
Action:
Use Data Repair Advisor to determine which system data files are corrupt and how the files can be restored.
ORA-16838: one or more system data files are offline
Cause:
The broker detected that one or more system data files were offline.
Action:
Use Data Repair Advisor to determine which system data files are offline and how the files can be made online.
ORA-16839: one or more user data files are missing
Cause:
The broker detected that one or more user data files were missing.
Action:
Use Data Repair Advisor to determine which user data files are missing and how the files can be restored.
ORA-16840: one or more user data files are corrupt
Cause:
The broker detected that one or more user data files were corrupt.
Action:
Use Data Repair Advisor to determine which user data files are corrupt and how the files can be restored.
ORA-16841: one or more user data files are offline
Cause:
The broker detected that one or more user data files were offline.
Action:
Use Data Repair Advisor to determine which user data files are offline and how the files can be made online.
ORA-16842: block corruptions detected
Cause:
The broker detected block corruptions on this database.
Action:
Use Data Repair Advisor to determine which files are affected by block corruptions and how the files can be repaired.
ORA-16843: errors discovered in diagnostic repository
Cause:
The broker detected one or more errors in the Automatic Diagnostic Repository.
Action:
Use Data Repair Advisor to see the errors that were discovered and how they can be repaired.
ORA-16844: redo transport mode incompatible with RedoSource property value
Cause:
The standby database could not be set to receive redo data from another standby database or a far sync instance because the standby database LogXptMode property was not set to ASYNC.
Action:
Set the standby database LogXptMode property to ASYNC before setting its RedoSource property to a non-empty value. Or, set the standby database RedoSource property to the empty value before setting its LogXptMode property to a value other than ASYNC.
ORA-16845: database specified by RedoSource property is disabled
Cause:
An attempt was made to either set a database RedoSource property to the name of a database that was disabled or to enable a database whose RedoSource property was set to the name of a database that was disabled.
Action:
Enable the database specified by the RedoSource property and retry the command.
ORA-16846: too many cascading levels
Cause:
The value of the RedoSource property was not set to the name of either a far sync instance or a database that receives redo data directly from the primary database.
Action:
Set the RedoSource property to either a far sync instance or a database that receives redo data directly from the primary database.
ORA-16847: a previous switchover from this database failed with error string
Cause:
A previous switchover operation from this database failed.
Action:
Fix the underlying problem and reissue the switchover command again.
ORA-16848: a previous switchover to this database failed with error string
Cause:
A previous switchover operation to this database failed.
Action:
ORA-16849: a previous switchover from this database was interrupted and aborted
Cause:
A previous switchover operation from this database was interrupted by the user. It may be caused by a hang.
Action:
ORA-16850: a previous switchover to this database was interrupted and aborted
Cause:
A previous switchover operation to this database was interrupted by the user. It may be caused by a hang.
Action:
ORA-16851: a previous failover to this database failed with error string
Cause:
A previous failover operation to this database failed.
Action:
Fix the underlying problem and reissue the failover command again.
ORA-16852: a previous failover to this database was interrupted and aborted
Cause:
A previous failover operation to this database was interrupted by the user. It may be caused by a hang.
Action:
ORA-16853: apply lag has exceeded specified threshold
Cause:
The current apply lag exceeded the value specified by the 'ApplyLagThreshold' database property. It may be caused either by a large transport lag or poor performance of apply services on the standby database.
Action:
Check for gaps on the standby database. If no gap is present, tune the apply services.
ORA-16854: apply lag could not be determined
Cause:
Apply lag could not be determined because either apply services were not running or there was no connectivity between the redo source and standby database.
Action:
Start apply services if they are not running. Also, ensure that there is network connectivity between the redo source and standby databases, and the redo source is sending redo data to the standby.
ORA-16855: transport lag has exceeded specified threshold
Cause:
The current transport lag exceeded the value specified by the 'TransportLagThreshold' database property. It is caused by either poor network performance between the redo source and the standby databases or a network disconnection.
Action:
Check the network connection between the redo source and standby databases. If they are connected, check the network performance between the redo source and the standby databases and tune it if necessary.
ORA-16856: transport lag could not be determined
Cause:
Transport lag could not be determined because there was no connectivity between the redo source and standby databases.
Action:
Ensure that there is network connectivity between the redo source and standby databases, and the redo source is working properly.
ORA-16857: standby disconnected from redo source for longer than specified threshold
Cause:
The amount of time the standby was disconnected from the redo source database exceeded the value specified by the 'TransportDisconnectedThreshold' database property. It is caused by no network connectivity between the redo source and the standby databases.
Action:
ORA-16858: last communication time from redo source could not be determined
Cause:
The standby database had never been contacted by the redo source.
Action:
ORA-16859: request terminated because delete, disable, or failover operation is in progress
Cause:
The broker terminated a request because it was processing a delete, disable, or failover operation.
Action:
Wait for the operation to complete and then retry the request.
ORA-16860: invalid member specified as the fast-start failover target
Cause:
The member specified as the fast-start failover target was either a far sync instance or snapshot standby database, or does not exist in the configuration.
Action:
Only a physical or logical standby database can be specified as a fast-start failover target. Check the database name and retry the command.
ORA-16861: ExternalDestination property requires DB_UNIQUE_NAME attribute
Cause:
The value specified for the ExternalDestination property did not contain the DB_UNIQUE_NAME attribute.
Action:
Ensure that DB_UNIQUE_NAME is specified as the value for the ExternalDestination property.
ORA-16862: unsupported attribute specified for the ExternalDestination property
Cause:
The value specified for the ExternalDestination property contained unsupported attributes.
Action:
Ensure that the value specified for the ExternalDestination property does not contain any of these attributes: LOCATION, ALTERNATE, MAX_FAILURE, SYNC, TEMPLATE, MANDATORY, DELAY, NET_TIMEOUT, and VALID_FOR.
ORA-16863: A member whose MaxFailure property is set to zero cannot have an alternate destination.
Cause:
A member was specified to have an alternate destination when its MaxFailure configurable property was set to zero.
Action:
Set the member's MaxFailure property to a nonzero value and retry the command.
ORA-16864: The MaxFailure property cannot be set to zero for a member that has an alternate destination.
Cause:
An attempt was made to set the MaxFailure configurable property to zero when it had an alternate destination specified.
Action:
Set the member's MaxFailure configurable property to a nonzero value.
ORA-16865: database is closing or is not mounted on the instance
Cause:
Broker health check was unable to complete because the database was closing or was not mounted on the instance.
Action:
No action is required if the database is closing. Mount the database if it is not yet mounted on the instance.
ORA-16900: change of LogXptMode or RedoRoutes property violates overall protection mode
Cause:
The broker did not allow the attempt to change the LogXptMode or RedoRoutes configurable property for the standby database or far sync instance because, if allowed, the overall protection mode for the configuration would have been violated.
Action:
If the LogXptMode or RedoRoutes configuration property must be changed for the specified standby database or far sync instance, first downgrade the overall protection mode for the broker configuration. After that operation has completed, the LogXptMode or RedoRoutes configuration property for the standby database can be changed.
ORA-16901: inconsistent alternate destinations specified with RedoRoutes
Cause:
The specification of alternates for the RedoRoutes property for a member was set inconsistently with respect to another member's RedoRoutes property.
Action:
Check the Oracle Data Guard broker log file for the reason for the failure and reissue the command. Ensure that the member's RedoRoutes alternate setting is set consistently with other member's RedoRoutes property.
ORA-16950: Remote mapped cursors are not supported by this feature.
Cause:
This cursor is a remote mapped cursor which could not be processed locally.
Action:
Try to process this statement directly on the remote site.
ORA-16951: Too many bind variables supplied for this SQL statement.
Cause:
Binding this SQL statement failed because too many bind variables were supplied.
Action:
Pass the correct number of bind variables.
ORA-16952: Failed to bind this SQL statement.
Cause:
Binding this SQL statement failed.
Action:
Check if bind variables for that statement are properly specified.
ORA-16953: Type of SQL statement not supported.
Cause:
This type of SQL statement could not be processed.
Action:
n/a
ORA-16954: SQL parse error.
Cause:
The specified SQL statement failed to be parsed.
Action:
Check if syntax is correct and ensure that this statement can be parsed by the specified user name.
ORA-16955: Unknown error during SQL analyze.
Cause:
The specified SQL statement failed to be analyzed.
Action:
This is an internal error, please contact Oracle support.
ORA-16956: Only SELECT or DML statements are supported for test execute.
Cause:
The specified SQL statement cannot be tested for execute.
Action:
n/a
ORA-16957: SQL Analyze time limit interrupt
Cause:
This is an internal error code used indicate that SQL analyze has reached its time limit.
Action:
n/a
ORA-16958: DML statements running parallel are not supported for test execute.
Cause:
The specified DML statement cannot be tested for execute because part of it is running parallel.
Action:
n/a
ORA-16959: Statement type has been disabled for SQL Analyze
Cause:
The system attempted to analyze a type of statement that was disabled by the current feature.
Action:
Try a different feature capable of analyzing this statement type.
ORA-16960: SQL Analyze could not reproduce the desired plan.
Cause:
SQL Analyze failed to reproduce a particular plan using an outline.
Action:
Check the outline data.
ORA-16961: SQL statement with SQL patch is ignored
Cause:
SQL statements with SQL patches are not supported by SQL tuning advisor.
Action:
Check the SQL patch information. Rerun SQL repair advisor on that SQL statement for a potential better SQL patch.
ORA-16962: SQL statement attempted to begin an autonomous transaction
Cause:
The SQL statement being analyzed attempted to begin an autonomous transaction, which is not supported.
Action:
Analyze another statement or remove the autonomous transaction from the current statement.
ORA-16963: The given user or schema is not supported by this feature.
Cause:
The SQL statement being analyzed had a parsing user or schema which is not currently supported for SQL Analyze.
Action:
Analyze another statement.
ORA-17500: ODM err:string
Cause:
An error returned by ODM library
Action:
Look at error message and take appropriate action or contact Oracle Support Services for further assistance
ORA-17501: logical block size string is invalid
Cause:
logical block size for oracle files must be a multiple of the physical block size, and less than the maximum
Action:
check INIT.ORA file parameters
ORA-17502: ksfdcre:string Failed to create file string
Cause:
file creation failed due to either insufficient OS permission or the file already exists
Action:
check additional error messages
ORA-17503: ksfdopn:string Failed to open file string
Cause:
file open failed due to either insufficient OS permission or the name of file exceeds maximum file name length.
Action:
ORA-17504: ksfddel:Failed to delete file string
Cause:
The file that was being deleted is still in use or the process has insufficient permission to delete file.
Action:
ORA-17505: ksfdrsz:string Failed to resize file to size string blocks
Cause:
There is insufficient space left on the device or the process has insufficient permission to resize file.
Action:
ORA-17506: I/O Error Simulation
Cause:
The i/o request is marked with error because the i/o error simulation event is turned on.
Action:
n/a
ORA-17507: I/O request size string is not a multiple of logical block size
Cause:
i/o's are done in multiple of logical block size
Action:
Check additional error messages
ORA-17508: I/O request buffer ptr is not alligned
Cause:
i/o request buffer should be alligned, check additional information for buffer ptr value
Action:
Call Oracle Support Services
ORA-17509: Attempt to do i/o beyond block1 offset
Cause:
When a file is identified with logical block size of 0, only i/o's to block1 is allowed.
Action:
check additional error messages and call Oracle Support Services
ORA-17510: Attempt to do i/o beyond file size
Cause:
The i/o request points to a block beyond End Of File
Action:
ORA-17512: Block Verification Failed
Cause:
Block Verification after a read operation on a database file failed since the block is media corrupt.
Action:
check additional error messages in the trace file and call Oracle Support Services
ORA-17513: dNFS package call failed
Cause:
An attempt was made to call a dNFS package in a non-dNFS environment
Action:
Make sure dNFS is enabled and the file can be accessed using dNFS.
ORA-17514: Access to clonedb bitmap file failed
Cause:
Accessing the bitmap block file in clonedb environment has encountered an error
Action:
ORA-17515: Creation of clonedb failed using snapshot file string
Cause:
Creating a datafile in a clonedb environment failed.
Action:
Make sure the snapshot file passed to clonedb is not from another clonedb instance and call Oracle Support Services for further assistance
ORA-17516: dNFS asynchronous I/O failure
Cause:
The asynchronous I/O request failed due to storage server reboot.
Action:
Make sure the storage server does not reboot repeatedly during database operations.
ORA-17517: Database cloning using storage snapshot failed on file string:string
Cause:
An invocation of the storage clone command was returned with an error.
Action:
Make sure all necessary steps are performed for storage cloning and check the Oracle trace file for additional information.
ORA-17518: backup file string cannot be found
Cause:
Access to the specified backup file was required for Instant Restore.
Action:
Make sure the path and file name are correct for the backup file and the path to the backup file can be accessed from the node of the instance.
ORA-17519: Reason(string): data file string cannot be prepared
Cause:
The snapshot layer could not prepare the specified data file.
Action:
Make sure the file does not already exist, is already part of a clone setup, or is being repopulated by an Instant Restore background process. Make sure the path specified is accessable and writable by the instance.
ORA-17520: data file string cannot be added to repopulation
Cause:
Instant Restore could not add the file to the repopulation work queue.
Action:
The repopulation process may be working on too many files for the system. Try waiting for some files to complete and try again.
ORA-17521: Instant Restore is not enabled
Cause:
The initialization parameters for Instant Restore were not set.
Action:
Make sure Instant Restore initialization parameter is set as required for this feature.
ORA-17522: file string is already being repopulated
Cause:
The file is currently being repopulated from a previous restore.
Action:
Make sure the file compeletes restore before you start another restore.
ORA-17523: Instance number cannot spawn repopulation (RPOP) process
Cause:
Instance may have too many running processes.
Action:
Make sure maxmimum number of processes initialization parameter is set properly for this feature.
ORA-17524: Repopulation cannot take place - no RPOP processes
Cause:
Maxmimum processes initialization parameter may not be set properly.
Action:
Make sure maxmimum number of processes initialization parameter is set properly for this feature. check alert log for other related errors.
ORA-17525: Database clone using storage snapshot not supported on file string
Cause:
Cloning a database using storage level snapshot is not supported on the underlying storage.
Action:
Use storage product that has snapshot based cloning support for Oracle.
ORA-17526: Block size of file string is too small string. Must be >= string.
Cause:
Files with block sizes smaller than a minimum size cannot be used for clones backed by snapshot file.
Action:
Use files with larger block size.
ORA-17527: Creation of a snapshot failed because the destination string was not a sparse disk group.
Cause:
Creating a snapshot failed because the destination disk group was not sparse.
Action:
Make sure the 'create_file_dest' clause passed to the snapshot copy is in a sparse disk group.
ORA-17528: cannot write to file string opened for read
Cause:
The file is read-only or was opened read-only and an attempt was made to write to the file, or there was an internal error.
Action:
If the file is a parent of a napshot, then you cannot open read/write, drop or unplug the database. Otherwise, look at trace file and contact Oracle Support Services.
ORA-17610: file 'string' does not exist and no size specified
Cause:
An attempt to create a file found neither an existing file nor a size for creating the file.
Action:
Specify a size for the file.
ORA-17611: ksfd: file 'string' cannot be accessed, global open closed
Cause:
An attempt to write to a file which has gone offline/unidentified
Action:
Check for other errno in the stack
ORA-17612: Failed to discover Oracle Disk Manager library, return value string
Cause:
Discovery of the odm library by calling odm_discover() failed
Action:
Contact your storage vendor who has provided the ODM library or call Oracle Support
ORA-17613: Failed to initialize Oracle Disk Manager library: string
Cause:
ODM initialization for the thread failed due to insufficient previlige or memory.
Action:
Make sure there is enough system resources available for the oracle process and it has access to the ODM library
ORA-17618: Unable to update block 0 to version 10 format
Cause:
An attempt was made to update block 0 to version 10 format.
Action:
Check additional error messages and call Oracle Support Services
ORA-17619: max number of processes using I/O slaves in a instance reached
Cause:
An attempt was made to start large number of processes requiring I/O slaves.
Action:
There can be a maximum of 35 processes that can have I/O slaves at any given time in a instance.
ORA-17620: failed to register the network adapter with Oracle Disk Manager library: string
Cause:
The ODM library returned an error while trying to register the network adapter.
Action:
Make sure the network adapter name given in the fileio_network_adapters is a valid name, and that the Oracle user has the correct access privileges.
ORA-17621: failed to register the memory with Oracle Disk Manager library
Cause:
The ODM library returned an error while trying to register the memory.
Action:
Contact the Oracle Disk Manager Library provider.
ORA-17622: failed to deregister the memory with Oracle Disk Manager library
Cause:
The ODM library returned an error while trying to deregister the memory.
Action:
ORA-17624: Failed to delete directory string
Cause:
The directory that was being deleted is still in use or the process had insufficient permission to delete the directory.
Action:
check additional error messages.
ORA-17626: ksfdcre: string file exists
Cause:
trying to create a database file, but file by that name already exists
Action:
verify that name is correct, specify REUSE if necessary
ORA-17627: string
Cause:
An error returned by OCI while sending/receiving message from remote instance
Action:
ORA-17628: Oracle error string returned by remote Oracle server
Cause:
Oracle server on the remote instance has returned an error.
Action:
Look at remote instance alert log/trace file for more information and take appropriate action or contact Oracle Support Services for further assistance
ORA-17629: Cannot connect to the remote database server
Cause:
Connecting to the remote server specified by database connect string for netowrk file transfer failed.
Action:
ORA-17630: Mismatch in the remote file protocol version client string server string
Cause:
Cannot communicate with the remote database server as there is a mismatch in the Oracle file protocol version.
Action:
ORA-17631: dbname 'string' specified by remote server does not match the instance name 'string'
Cause:
The dbname specified by the remote server is not intended for this instance.
Action:
Check the dbname specified in the command of the remote instance and look for further error messages.
ORA-17632: file 'string' is a formatted ASM disk
Cause:
An attempt to create a datafile on a device that was formatted for ASM disk failed.
Action:
Check that the device specified is not an ASM disk. If you would like to use the disk for datafiles, please clear the disk before you retry the operation.
ORA-17633: Operation not supported as one of the servers involved is not capable of performing the requested operation
Cause:
An attempt was made to perform an operation involving two Oracle servers where both servers did not have the capability required for carrying out the operation. It is likely that one of the servers needs a patch or an upgrade to successfully participate in the operation.
Action:
Apply the required fix or update on the lower version server. Contact Oracle Support Services for further assistance.
ORA-17634: network file transfer operation aborted
Cause:
An error occurred during network file transfer operation.
Action:
Check addtional error messages.
ORA-17635: failure in obtaining physical sector size for 'string'
Cause:
An error occurred while determining the physical sector size from the underlying storage (ASM/ODM/OSD).
Action:
Check additional error messages.
ORA-17636: Invalid sparse block format (string). Start block=string. Error=string. File=string
Cause:
An error occurred while reading the block on sparse media.
Action:
Contact Oracle Support Services.
ORA-17676: Failed to mount 'string' with error:'string'
Cause:
Mounting database file system failed with an error.
Action:
Check additional error messages in the trace file.
ORA-17677: failed to unmount 'string' with error:'string'
Cause:
Unmounting database file system failed with an error.
Action:
ORA-18000: invalid outline name
Cause:
The parser detected a missing or invalid outline name
Action:
n/a
ORA-18001: no options specified for ALTER OUTLINE
Cause:
The parser detected that no clause was specified on the command Our performance tests, which are not typical as they exercise all branches of the code, have shown approximately a 30% performance increase line for ALTER OUTLINE.
Action:
Re-issue the command, specifying a valid ALTER OUTLINE clause.
ORA-18002: the specified outline does not exist
Cause:
Either the outline did not exist to begin with, or a timing window allowed for another thread to drop or alter the outline midstream.
Action:
n/a
ORA-18003: an outline already exists with this signature
Cause:
The signature generation algorithm generates signatures that are are 16 bytes in length so it is highly unlikely that any 2 signatures will be identical. This message is raised in such a rare case.
Action:
Either re-issue the statement that led to the outline being created with some whitespace added or force the outline to be created in a different category.
ORA-18004: outline already exists
Cause:
An outline already exists, either with the specified name, or for the specified SQL text.
Action:
n/a
ORA-18005: CREATE ANY OUTLINE privilege is required for this operation
ORA-18006: DROP ANY OUTLINE privilege is required for this operation
ORA-18007: ALTER ANY OUTLINE privilege is required for this operation
ORA-18008: cannot find OUTLN schema
Cause:
The database creation script that creates this schema must not have been executed.
Action:
Review the log files to see what happened when the database was created.
ORA-18009: one or more outline system tables do not exist
Cause:
Either the database creation script that creates these tables was not executed or a user accidently deleted the table
Action:
ORA-18010: command missing mandatory CATEGORY keyword
Cause:
User failed to specify the CATEGORY keyword
Action:
Re-issue the command with the CATEGORY keyword included
ORA-18011: the outline specified in the FROM clause does not exist
ORA-18012: select_catalog_role role is required for this operation
ORA-18013: timed out while waiting for resource string
ORA-18014: deadlock detected while waiting for resource string
ORA-18015: invalid source outline signature
Cause:
User imported an 8i outline into a 9i database without updating signatures
Action:
execute dbms_outln.update_signatures
ORA-18100: XUST0001 - Updating expression in a wrong position
Cause:
An updating expression was used in a position other than one of the following:
- The topmost expression in the body of a query.
- The MODIFY clause of a TRANSFORM expression.
- The RETURN clause of a FLWOR expression.
- The RETURN clauses of a TYPESWITCH expression in which every RETURN clause contains an updating expression, an empty expression ( ), or a call to the fn:error function.
- The THEN and ELSE clauses of a conditional statement in which both the then and else clauses contain either an updating expression, an empty expression ( ), or a call to the fn:error function.
- An operand of a comma expression in which each operand is either an updating expression, an empty expression ( ), or a call to the fn:error function.
- The content of a parenthesized expression.
- The body of a function declaration in which the keyword UPDATING is specified.
Action:
None
ORA-18101: XUST0002 - Non-updating expression in a wrong position
Cause:
A non-updating expression other than an empty expression ( ) or a call to the fn:error function was used in one of the following positions:
- The top-level expression in the body of a function declaration in which the keyword UPDATING is specified.
Action:
None
ORA-18102: XUST0003 - Repeated revalidation declaration
Cause:
Prolog contained more than one revalidation declaration.
Action:
None
ORA-18103: XUTY0004 - Invalid attribute node in the insertion sequence
Cause:
The insertion sequence of an INSERT expression contained an attribute following a node that was not an attribute node.
Action:
None
ORA-18104: XUTY0005 - Invalid target expression for INSERT
Cause:
In an INSERT expression where INTO, AS FIRST INTO, or AS LAST INTO was specified, the target expression returned a nonempty result that did not consist of a single element or document node.
Action:
None
ORA-18105: XUTY0006 - Invalid target expression for INSERT
Cause:
In an INSERT expression where BEFORE or AFTER was specified, the target expression returned a nonempty result that did not consist element, text, comment, or processing instruction node.
Action:
None
ORA-18106: XUTY0007 - Invalid target expression for DELETE
Cause:
The target expression of a DELETE expression did not return a sequence of zero or more nodes.
Action:
None
ORA-18107: XUTY0008 - Invalid target expression for REPLACE
Cause:
In a REPLACE expression, the target expression returned a nonempty result that did not consist of a single element, attribute, text,
Action:
None
ORA-18108: XUDY0009 - Invalid target expression for REPLACE
Cause:
In a REPLACE expression where VALUE OF was not specified, the node returned by the target expression did not have a parent.
Action:
None
ORA-18109: XUTY0010 - Invalid replacement sequence for REPLACE
Cause:
In a REPLACE expression where VALUE OF was not specified and the target was an element, text, comment, or processing instruction node, the replacement sequence did not consist of zero or more element, text, comment, or processing instruction nodes.
Action:
None
ORA-18110: XUTY0011 - Invalid replacement sequence for REPLACE
Cause:
In a REPLACE expression where VALUE OF was not specified and the target is an attribute node, the replacement sequence did not consist of zero or more attribute nodes.
Action:
None
ORA-18111: XUTY0012 - Invalid target expression for RENAME
Cause:
In a RENAME expression, the target expression returned a nonempty result that did not consist of a single element, attribute, or processing instruction node.
Action:
None
ORA-18112: XUTY0013 - Invalid COPY expression for TRANSFORM
Cause:
In a TRANSFORM expression, a source expression in the copy clause did not return a single node.
Action:
None
ORA-18113: XUDY0014 - Modified node was not created by the COPY clause
Cause:
In a TRANSFORM expression, the MODIFY clause modified a node that was not created by the COPY clause.
Action:
None
ORA-18114: XUDY0015 - Duplicate RENAME for the same target node
Cause:
A node was the target of more than one RENAME expression within the same query.
Action:
None
ORA-18115: XUDY0016 - Duplicate REPLACE for the same target node
Cause:
A node was the target of more than one REPLACE expression (without VALUE OF being specified) within the same query.
Action:
None
ORA-18116: XUDY0017 - Duplicate REPLACE for the same target node
Cause:
A node was the target of more than one REPLACE VALUE OF expression within the same query.
Action:
None
ORA-18117: XUDY0018 - External not updating function returns an updated value
Cause:
A function that was declared to be external but not updating returned a nonempty pending update list.
Action:
None
ORA-18118: XUDY0019 - External updating function returns an invalid value
Cause:
A function that was declared to be both external and updating returned a nonempty data model instance.
Action:
None
ORA-18119: XUDY0020 - Deleted node has no parent
Cause:
Node was deleted that had no parent before execution of the query began.
Action:
None
ORA-18120: XUDY0021 - The result XDM instance violates XDM constraints
Cause:
XDM instance resulting from applying all the updates in a query violated constraint specified in [XQuery/XPath Data Model (XDM)]. In this case, none of the updates in the query were made effective.
Action:
None
ORA-18121: XUTY0022 - Invalid attribute insertion into a document node
Cause:
INSERT expression specified the insertion of an attribute node into a document node.
Action:
None
ORA-18122: XUDY0023 - Updating expression introduces a namespace conflict
Cause:
An INSERT, REPLACE, or RENAME expression affected an element node by introducing a new namespace binding that conflicted with one of its existing namespace bindings.
Action:
None
ORA-18123: XUDY0024 - Updating expression introduces a namespace conflict
Cause:
Effect of a set of updating expressions introduced conflicting namespace bindings into an element node.
Action:
None
ORA-18124: XUDY0025 - Invalid QName for processing instruction RENAME
Cause:
Target of a RENAME expression was a processing instruction node, and the new name expression returned a QName with a nonempty namespace prefix.
Action:
None
ORA-18125: XUST0026 Revalidation mode string is not supported
Cause:
Revalidation declaration in a Prolog specified a revalidation mode that is not supported by the current implementation.
Action:
None
ORA-18126: XUDY0027 - Invalid target expression
Cause:
Target expression of an INSERT, REPLACE, or RENAME expression evaluated to an empty sequence.
Action:
None
ORA-18127: XUST0028 - Updating function should not have a return type
Cause:
Function declaration specified both UPDATING and a return type.
Action:
None
ORA-18128: XUDY0029 - INSERT expression target node doesn't have a parent
Cause:
In an INSERT expression where BEFORE or AFTER was specified, a node returned by the target expression did not have a parent.
Action:
None
ORA-18129: XUDY0030 - Invalid insertion of an attribute node
Cause:
INSERT expression specified the insertion of an attribute node before or after a child of a document node.
Action:
None
ORA-18130: FOUP0001 - Invalid 'fn:put' first operand
Cause:
The first operand of fn:put was not a node of a supported kind.
Action:
None
ORA-18131: FOUP0002 - Invalid 'fn:put' second operand
Cause:
The second operand of fn:put was not a valid lexical representation of the xs:anyURI type.
Action:
None
ORA-18150: SQL input value cannot be modified in updating expression
Cause:
Updating expression was specified as top-level XMLQuery expression.
Action:
Use XQuery TRANSFORM expression to copy input value and modify it.
ORA-18160: FTST0001 - FTMildNot operator not supported
Cause:
An attempt was made to use the mild not option when the FTMildNot operator was not supported. An implementation that does not support the FTMildNot operator must raise a static error if a full-text query contains a mild not.
Action:
Do not use the FTMildNot full-text query operator.
ORA-18161: FTST0002 - FTUnaryNot operator not supported
Cause:
An implementation that enforces one of the restrictions on FTUnaryNot must raise a static error if a full-text query does not obey the restriction.
Action:
Do not use the FTUnaryNot full-text query operator.
ORA-18162: FTST0003 - FTUnit and FTBigUnit not supported
Cause:
An implementation that does not support one or more of the choices on FTUnit and FTBigUnit must raise a static error if a full-text query contains one of those choices.
Action:
Do not use the FTUnit or FTBigUnit option.
ORA-18163: FTST0004 - FTScope not supported
Cause:
An implementation that does not support the FTScope operator must raise a static error if a full-text query contains a scope.
Action:
Do not use the FTScope full-text query operator.
ORA-18164: FTST0005 FTTimes not supported
Cause:
An implementation that does not support the FTTimes operator must raise a static error if a full-text query contains a times.
Action:
Do not use the FTTimes full-text query operator.
ORA-18165: FTST0006 FTStopwordOption not supported
Cause:
An implementation that restricts the use of FTStopwordOption must raise a static error if a full-text query contains a stop word option that does not meet the restriction.
Action:
Do not use the FTStopwordOption full-text query operator.
ORA-18166: FTST0007 FTIgnoreOption not supported
Cause:
An implementation that restricts the use of FTIgnoreOption must raise a static error if a full-text query contains an ignore option that does not meet the restriction.
Action:
Do not use the FTIgnoreOption full-text query operator.
ORA-18167: FTST0008 stop word list not found
Cause:
It is a static error if, during the static analysis phase, the query is found to contain a stop word option that refers to a stop word list that is not found in the statically known stop word lists.
Action:
Please make sure the stop word list exist.
ORA-18168: FTST0009 language option not supported
Cause:
It may be a static error if, during the static analysis phase, the query is found to contain a language identifier in a language option that the implementation does not support. The implementation may choose not to raise this error and instead provide some other implementation-defined behavior.
Action:
Do not use the language full-text query option.
ORA-18169: FTST0010 FTOrder not succeeding FTWindow or FTDistance operator
Cause:
It is a static error if, during the static analysis phase, an expression is found to use an FTOrder operator that does not appear directly succeeding an FTWindow or an FTDistance operator and the implementation enforces this restriction.
Action:
Do not use the FTOrder succeeding FTWindow or FTDistance full-text query operator.
ORA-18170: FTST0011 FTWindow and FTDistance restriction
Cause:
An implementation may restrict the use of FTWindow and FTDistance to an FTOr that is either a single FTWords or a combination of FTWords involving only the operators && and ||. If it a static error if, during the static analysis phase, an expression is found that violates this restriction and the implementation enforces this restriction.
Action:
Follow FTWindow and FTDistance restriction.
ORA-18171: FTST0012 FTContent not supported
Cause:
An implementation that does not support the FTContent operator must raise a static error if a full-text query contains one.
Action:
Do not use FTContent full-text query operator.
ORA-18172: FTST0013 more than one language encountered
Cause:
It is a static error if, during the static analysis phase, an implementation that restricts the use of FTLanguageOption to a single language, encounters more than one distinct language option.
Action:
Do not use more than one language in FTLanguag full-text option.
ORA-18173: FTST0014 score computation restriction
Cause:
An implementation may constrain the form of the expression used to compute scores. It is a static error if, during the static analysis phase, such an implementation encounters a scoring expression that does not meet the restriction.
Action:
n/a
ORA-18174: FTST0015 FTCaseOption restriction
Cause:
It is a static error if, during the static analysis phase, an implementation that restricts the choices of FTCaseOption encounters the "lowercase" or "uppercase" option.
Action:
n/a
ORA-18175: FTDY0016 weights invalid
Cause:
It is a dynamic error if an implementation that does not support negative weights encounters a weight expression that does not meet the restriction.
Action:
Do not use invalid weights value.
ORA-18176: FTDY0017 mild not selection containings StringExclude
Cause:
It is a dynamic error if an implementation encounters a mild not selection, one of whose operands evaluates to an AllMatches that contains a StringExclude
Action:
n/a
ORA-18177: XQuery full text expression 'string' cannot be evaluated using XML full-text index
Cause:
There was no XML full-text index to evaluate the XQuery full text expression filtering XML documents that were stored in an XMLType table or column.
Action:
Create an XML full-text index on the XML documents stored in an XMLType table or column and ensure that the XQuery full text expression can be evaluated by an XML full-text index.
ORA-18178: XMLType input to XMLTABLE row expression needs to use PASSING BY REF clause
Cause:
The XMLTABLE column expression used the XMLTYPE(SEQUENCE) BY REF clause which requires XMLType input to the XMLTABLE row expression to use the PASSING BY REF clause.
Action:
Specify the PASSING BY REF clause for XMLType input to the XMLTABLE row expression.
ORA-18179: XMLTABLE column expression needs to be specified using XMLTYPE(SEQUENCE) BY REF clause
Cause:
Output of the XMLTABLE column expression was passed to an XMLTABLE row expression with PASSING BY REF clause.
Action:
Specify the XMLTABLE column expression using XMLTYPE(SEQUENCE) BY REF clause.
ORA-18180: wrong argument is passed to XMLTABLE row expression using PASSING BY REF clause
Cause:
An XML document that was not stored in an XMLTYPE table or column was passed to an XMLTABLE row expression using the PASSING BY REF clause.
Action:
Make sure only XML documents that are stored in an xmltype table or column can be passed in as input to XMLTABLE row expression using the PASSING BY REF clause
ORA-18181: XQuery full text expression option 'string' is not supported
Cause:
An attempt was made to use an XQuery full text expression option that is not supported.
Action:
Avoid using an XQuery full text expression option which is not supported.
ORA-18182: FTST0018 unknown thesaurus is used
Cause:
During the static analysis phase, the query was found to contain a thesaurus option that referred to a thesaurus that was not found in the statically known thesauri. This is a static error.
Action:
Avoid using unknown thesaurus.
ORA-18183: FTST0019 more than one match option of any given match option group is used within a single FTMatchOptions.
Cause:
Within the single FTMatchOptions, there was more than one match option of any given match option group. This is a static error.
Action:
Avoid using more than one match option of any given match option group is used within a single FTMatchOptions.
ORA-18184: FTDY0020 a query string violates wildcard syntax when wildcards is in effect
Cause:
Because wildcards were in effect, the query string violated wildcard syntax. This is a dynamic error.
Action:
Fix wildcard syntax when wildcards is in effect.
ORA-18185: query is not parsed correctly
Cause:
The query string was not parsed correctly.
Action:
Check the syntax of the query string.
ORA-19000: missing RELATIONAL keyword
Cause:
The keyword RELATIONAL in the work OBJECT RELATIONAL is missing in the XMLTYPE storage clause specification.
Action:
Supply the RELATIONAL keyword in the storage clause
ORA-19001: Invalid storage option specified
Cause:
An invalid storage option was specified for the XMLType.
Action:
Supply a valid storage option.
ORA-19002: Missing XMLSchema URL
Cause:
A XML schema URL must be specified in the storage option.
Action:
Specify a URL for the XMLSchema.
ORA-19003: Missing XML root element name
Cause:
A root element in the XMLSchema must be specified if the XML schema is given.
Action:
Specify a root element in the XML schema.
ORA-19004: Duplicate XMLType OBJECT RELATIONAL storage option
Cause:
A duplicate storage option for the XMLType column was specified
Action:
Specify a single storage option for an XMLType column
ORA-19005: Duplicate XMLType LOB storage option
Cause:
Action:
ORA-19006: XMLType TYPE storage option not appropriate for storage type
Cause:
The TYPE option can only be used in case of OBJECT RELATIONAL storage option
Action:
Remove the TYPE option or specify an OBJECT RELATIONAL storage for the XMLType column
ORA-19007: Schema string does not match expected string.
Cause:
The given XML document conformed to a different schema than expected.
Action:
Insert/Update only the XML documents that conform to that particular schema.
ORA-19008: Invalid version of the XMLType
Cause:
An invalid version of the XMLType was found.
Action:
This is possible due to data corruption or an internal error or running an older client against a newer version of the database. Make sure that the version of the client can understand the XMLType in the database.
ORA-19009: Missing XMLSchema keyword
Cause:
The XMLSchema keyword is missing
Action:
Specify the XMLSchema URL and element name.
ORA-19010: Cannot insert XML fragments
Cause:
XML fragments got from extractNode cannot be inserted into the database.
Action:
Convert the fragment into a proper XML document before insertion.
ORA-19011: Character string buffer too small
Cause:
The string result asked for is too big to return back
Action:
Get the result as a lob instead
ORA-19012: Cannot convert XML fragment to the required datatype
Cause:
A conversion to a datatype was requested which cannot be performed
Action:
The XMLType may contain fragments and other elements which cannot be converted to the appropriate datatype.
ORA-19013: Cannot create VARRAY columns containing XMLType
Cause:
An attempt was made to create a VARRAY column which contains a XMLType
Action:
You cannot store VARRAYs containing XMLTypes in tables. Use nested tables instead
ORA-19015: Invalid XML tag identifier (string)
Cause:
An invalid XML identifer was detected during XML generation
Action:
Fix the offending tag to not contain characters or symbols that are not allowed by the XML specification
ORA-19016: attributes cannot occur after element specifications
Cause:
Attributes specified using the "@" identifier can only occur before any other element definition when creating XML
Action:
Change the order of the types so that the attributes occur in the begining
ORA-19017: Attributes can only be simple scalars
Cause:
Attribute values can only be simple scalar values
Action:
Use only simple datatypes for attribute values
ORA-19018: Invalid character in XML tag 'string'
Cause:
A tag name was found to have an invalid XML character during XML generation.
Action:
Rewrite the query so that the generated XML tag, corresponding to a column name or alias, contains only valid characters.
ORA-19019: Invalid context passed to DBMS_XMLGEN.GETXML
Cause:
The value of context passed to GETXML was invalid.
Action:
Rewrite the query so that the value of context passed to GETXML is valid.
ORA-19020: invalid dereference of XMLType columns
Cause:
An attempt was made to dereference the attributes of an XMLType column which is not part of a base table
Action:
You can only dereference the attributes of a base table XMLType column
ORA-19022: Unoptimized XML construct detected.
Cause:
XMLOptimizationCheck is enabled and unrewritten XML construct was detected. This prevents execution of XML construct.
Action:
Make sure that XML construct is being optimized. See trace file for further information. Disable XMLOptimizationCheck if you want the unoptimized XML operation to be executed.
ORA-19023: The first argument to UPDATEXML operator has to be an XMLTYPE
Cause:
The first argument passed to the update value operator was not an XMLTYPE.
Action:
Rewrite the query so that the first argument to the UPDATEXML operator is XMLTYPE.
ORA-19024: Cursor expression must be named
Cause:
Action:
ORA-19025: EXTRACTVALUE returns value of only one node
Cause:
Given XPath points to more than one node.
Action:
Rewrite the query so that exactly one node is returned.
ORA-19026: EXTRACTVALUE can only retrieve value of leaf node
Cause:
Given XPath does not point to a leaf node.
Action:
Rewrite the query so that a leaf node is returned.
ORA-19028: Invalid ADT parameter passed to toObject() function
Cause:
The object passed as ADT parameter to sys.XMLType.toObject() is not the same type, or a super-type, of the mapped type.
Action:
Pass an object of the correct type to toObject().
ORA-19029: Cannot convert the given XMLType to the required type
Cause:
The passed in XMLType could not be convert to the required type
Action:
Binary XMLtype instances or other objects cannot be converted to the required object or collection types.
ORA-19030: Method invalid for non-schema based XML Documents.
Cause:
The method can be invoked on only schema based xmltype objects.
Action:
Don't invoke the method for non schema based xmltype objects.
ORA-19031: XML element or attribute string does not match any in type string.string
Cause:
The passed in XML tag does not match any in the object type
Action:
Pass a valid canonical XML that can map to the given object type
ORA-19032: Expected XML tag string got string
Cause:
When converting XML to object, a wrong tag name was present
Action:
ORA-19033: schema specified in the XML document does not match the schema parameter
Cause:
When creating schema-based XML, the schema specified in the XML document is different from the schema passed in as the 'schema' parameter.
Action:
Change the schema parameter to match the schema specified in the XML document.
ORA-19034: Type not supported during schema generation
Cause:
The object type contained a type that is not supported for schema generation.
Action:
Use a different type or do not generate a schema.
ORA-19035: Invalid select item of the query in newContextFromHierarchy()
Cause:
The query does not have a number select item followed by an XMLType select item only.
Action:
Make sure the result set of the query used in the newContextFromHierarchy() must have only two selected items: the first item must be number type and the second item must be XMLType.
ORA-19036: Invalid query result set in newContextFromHierarchy()
Cause:
The result set of the query used in the newContextFromHierarchy() does not have the same property as the result set generated by a CONNECT BY query.
Action:
Make sure the query used in newContextFromHierarchy() is a CONNECT BY query or the query returns the result set have the same property as the result set generated by a CONNECT BY query.
ORA-19037: XMLType result can not be a fragment
Cause:
The select item of the query in newContextFromHierarchy() is an XML fragment.
Action:
Make sure the select item of the query in newContextFromHierarchy() is NOT an XML fragment
ORA-19038: Invalid opertions on query context
Cause:
SetMaxRows, SetSkipRows, SetRowTagName opertions are applied to a query context created from newContextFromHierarchy().
Action:
SetMaxRows, SetSkipRows, SetRowTagName opertions can not be applied to a query context created from newContextFromHierarchy().
ORA-19039: Keyword string reserved for future use
Cause:
The keyword is reserved for future use as a builtin function.
Action:
Change the name mentioned above to a different one.
ORA-19040: Element string does not match expected string.
Cause:
The given XML document had a different root element than expected.
Action:
Insert/Update only the XML documents that conform to that particular schema and element.
ORA-19041: Comment data cannot contain two consecutive '-'s
Cause:
The given comment string expression has two consecutive '-'s.
Action:
Modify comment string to eliminate one or both of the consevutive '-'s.
ORA-19042: Enclosing tag string cannot be xml in any case combination
Cause:
The given enclosing tag matched 'xml' in some case combination
Action:
Modify the enclosing tag so that it is not xml in any case combination.
ORA-19043: Multiply nested XMLROOT function disallowed
Cause:
An XMLROOT function has an operand that is also an XMLROOT function.
Action:
Modify the query so that there are no multiply nested XMLROOT functions.
ORA-19044: character length specified for XMLSerialize is too small.
Cause:
An XMLSerialize function was called with a type of character type (e.g. VARCHAR2(27)), and the length specified (27 in the example) was too small.
Action:
Modify the query so that the character length specified is larger.
ORA-19045: character set id specified for XMLSerialize not valid
Cause:
An XMLSerialize function was called with an invalid value for the caracter set id.
Action:
Modify the query so that the character set id is valid.
ORA-19046: Out-of-line table cannot be shared by two top-level tables (table 'string.string' and the current table being created).
Cause:
An attempt was made to share an out-of-line table between two top-level tables.
Action:
Use the existing top-level XML table.
ORA-19047: Cannot specify storage for individual VARRAYS
Cause:
An attempt was made to combine storage specification for a particular VARRAY with STORE ALL VARRAYS clause.
Action:
Either specify storage for individual VARRAYs or use the STORE ALL VARRAYS clause.
ORA-19048: Cannot specify VARRAY storage in tableProps
Cause:
An attempt was made to store all varrays as tables or LOBs in tableProps.
Action:
Do not specify varray store as tables or LOBs in tableProps.
ORA-19051: Cannot use fast path insert for this XMLType table
Cause:
Error while trying to insert into an XMLType table using fast path insert.
Action:
Set event 19049 to disable fast path insert and try again.
ORA-19100: PASSING or RETURNING keyword expected
Cause:
The keyword PASSING or RETURNING was missing.
Action:
Specify the PASSING or RETURNING keyword.
ORA-19101: CONTENT keyword expected
Cause:
The keyword CONTENT was missing.
Action:
Specify the CONTENT keyword.
ORA-19102: XQuery string literal expected
Cause:
The string literal containing the XQuery expression was missing.
Action:
Specify the XQuery expression as a string literal.
ORA-19103: VALUE keyword keyword
Cause:
The keyword VALUE was missing.
Action:
Specify the VALUE keyword.
ORA-19104: invalid XQueryX: missing attribute string
Cause:
The XQueryX expression was not assigned the expected attribute.
Action:
Specify a valid XQueryX.
ORA-19105: invalid XQueryX: expected text node - got string
Cause:
The XQueryX expression did not contain a text node as expected.
Action:
ORA-19106: invalid XQueryX: expected string - got string
Cause:
The XQueryX expression did not contain the node as expected.
Action:
ORA-19107: invalid XQueryX - unsupported construct - string
Cause:
The given XQuery expression contains an unsupported construct.
Action:
ORA-19108: WHITESPACE keyword expected
Cause:
The keyword WHITESPACE was missing.
Action:
Specify the WHITESPACE keyword.
ORA-19109: RETURNING keyword expected
Cause:
The keyword RETURNING was missing.
Action:
Specify the RETURNING keyword.
ORA-19110: unsupported XQuery expression
Cause:
The program specified an XQuery expression that is not supported.
Action:
Rewrite the XQuery with a expression that is supported.
ORA-19111: error during evaluation of the XQuery expression
Cause:
An error occurred during the processing of the XQuery expression.
Action:
Check the detailed error message for the possible causes.
ORA-19112: error raised during evaluation: string
Cause:
The error function was called during evaluation of the XQuery expression.
Action:
ORA-19113: trace function called during evaluation: string
Cause:
The trace function was called during evaluation of the XQuery expression.
Action:
Check the log file for the trace message.
ORA-19114: XPST0003 - error during parsing the XQuery expression: string
Cause:
An error occurred during the parsing of the XQuery expression.
Action:
ORA-19115: too many context items specified
Cause:
More than one context item was specified as input to the XMLQuery function.
Action:
Specify a single context item for the XMLQuery function.
ORA-19116: too many xmlspace declarations
Cause:
The query prolog contained multiple xmlspace declarations.
Action:
Remove the duplicate xmlspace declarations.
ORA-19117: XQST0070 - invalid redefinition of predefined namespace prefix 'string'
Cause:
The given predefined namespace was being redefined in a namespace declaration.
Action:
Remove the namespace declaration that redefines the predefined namespace prefix.
ORA-19118: XQST0066 - duplicate default namespace definition - string
Cause:
More than one default namespace declaration used the given namespace URI.
Action:
Remove the duplicate default namespace definition.
ORA-19121: duplicate attribute definition - string
Cause:
More than one attribute with the same name.
Action:
Remove the duplicate attribute definition.
ORA-19122: unsupported XQuery declaration
Cause:
The program specified an XQuery declaration that is not supported.
Action:
Rewrite the XQuery with a declaration that is supported.
ORA-19123: FORG0003: fn:zero-or-one() called with a sequence containing more than one item
Cause:
sequence with more than one item was passed into fn:zero-or-one() function
Action:
correct input argument to fn:zero-or-one() function
ORA-19124: FORG0004: fn:one-or-more() called with a sequence containing no items
Cause:
sequence containing no items was passed into fn:one-or-more() function
Action:
correct input argument to fn:one-or-more() function
ORA-19125: FORG0005: fn:exactly-one() called with a sequence containing zero or more than one item
Cause:
sequence containing zero or more than one item was passed into fn:exactly-one() function
Action:
correct input argument to fn:exactly-one() function
ORA-19126: XQuery extension expression contains neither a pragma that is recognized by the implementation nor an expression enclosed in curly braces
Cause:
No expression was enclosed in curly braces for the extension expression or the pragma content was not recognized.
Action:
Correct inputs to extension expression.
ORA-19127: XQST0067: XQST0067: A static error is raised if a Prolog contains more than one construction declaration
Cause:
Action:
ORA-19128: XQST0068: A static error is raised if a Prolog contains more than one boundary-space declaration
Cause:
Action:
ORA-19129: XQST0069: A static error is raised if a Prolog contains more than one empty order declaration
Cause:
Action:
ORA-19130: XQST0070: A static error is raised if the predefined namespace prefix xml or xmlns is redeclared by a namespace declaration or namespace declaration attribute
Cause:
Action:
ORA-19131: XQST0071: A static error is raised if the namespace declaration attributes of a direct element constructor do not have distinct names
Cause:
Action:
ORA-19132: XQDY0072: It is a dynamic error if the result of the content expression of a computed comment constructor contains two adjacent hyphens or ends with a hyphen
Cause:
Action:
ORA-19133: XQST0073: It is a static error if the graph of module imports contains a cycle (that is, if there exists a sequence of modules M1 ... Mn such that each Mi imports Mi+1 and Mn imports M1), unless all the modules in the cycle share a common namespace
Cause:
Action:
ORA-19134: XQDY0074: It is a dynamic error if the value of the name expression in a computed element constructor cannot be converted to an expanded QName (for example, because it contains a namespace prefix not found in statically known namespaces.)
Cause:
Action:
ORA-19135: XQST0075: An implementation that does not support the Validation Feature must raise a static error if it encounters a validate expression
Cause:
Action:
ORA-19136: XQST0076: It is a static error if a collation subclause in an order by clause of a FLWOR expression does not identify a collation that is present in statically known collations
Cause:
Action:
ORA-19137: XQST0079: It is a static error if an extension expression contains neither a pragma that is recognized by the implementation nor an expression enclosed in curly braces
Cause:
Action:
ORA-19138: The target type of a cast or castable expression must be an atomic type that is in the in-scope schema types and is not xs:NOTATION or xs:anyAtomicType, optionally followed by the occurrence indicator "?"; otherwise a static error is raised
Cause:
Action:
ORA-19139: XPST0081: It is a static error if a QName used in a query contains a namespace prefix that cannot be expanded into a namespace URI by using the statically known namespaces
Cause:
Action:
ORA-19140: XPST0083: It is a static error if the target type of a cast expression or constructor function is xs:QName or a type derived from xs:QName or xs:NOTATION, and the argument of the cast expression or constructor function is not a string literal
Cause:
Action:
ORA-19141: XQDY0084: It is a dynamic error if the element validated by a validate statement does not have a top-level element declaration in the in-scope element declarations, if validation mode is strict
Cause:
Action:
ORA-19142: FONC0001 = FONC0001: undefined context item
Cause:
Action:
ORA-19143: XQTY0086: It is a type error if the typed value of a copied element or attribute node is namespace-sensitive when construction mode is preserve and copy-namespaces mode is no-preserve
Cause:
Action:
ORA-19145: XQST0087: It is a static error if the encoding specified in a Version Declaration does not conform to the definition of EncName specified in [XML 1.0]
Cause:
Action:
ORA-19146: XQST0088: It is a static error if the literal that specifies the target namespace in a module import or a module declaration is of zero length
Cause:
Action:
ORA-19147: XQST0089: It is a static error if a variable bound in a for clause of a FLWOR expression, and its associated positional variable, do not have distinct names (expanded QNames)
Cause:
Action:
ORA-19148: XQST0090: It is a static error if a character reference does not identify a valid character in the version of XML that is in use
Cause:
Action:
ORA-19149: XQDY0091: An implementation may raise a dynamic error if an xml:id error, as defined in [XML ID], is encountered during construction of an attribute named xml:id
Cause:
Action:
ORA-19150: XQDY0092: An implementation may raise a dynamic error if a constructed attribute named xml:space has a value other than preserve or default
Cause:
Action:
ORA-19151: XQST0093: It is a static error to import a module M1 if there exists a sequence of modules M1 ... Mi ... M1 such that each module directly depends on the next module in the sequence (informally, if M1 depends on itself through some chain of module dependencies.)
Cause:
Action:
ORA-19152: FOCH0001 = FOCH0001: codepoint not valid
Cause:
Action:
ORA-19153: FOCH0002: unsupported collation
Cause:
Action:
ORA-19154: FOCH0003: unsupported normalization form
Cause:
Action:
ORA-19155: FOCH0004: collation does not support collation units
Cause:
Action:
ORA-19156: FODC0001: no context document
Cause:
Action:
ORA-19157: FODC0002: error retrieving resource
Cause:
Action:
ORA-19158: FODC0004: invalid argument to fn:collection()
Cause:
Action:
ORA-19159: FODC0005: invalid argument to fn:doc
Cause:
Action:
ORA-19160: XPST0003 - syntax error: invalid variable name string
Cause:
The given XQuery variable does not begin with the '$' sign
Action:
Fix the variable name to start with the "$" sign.
ORA-19161: XPTY0004 - XQuery type mismatch: invalid argument type 'string' for function 'string'
Cause:
The type of the argument that was passed to the given function was not valid.
Action:
Fix the argument to be of a type supported by the given function.
ORA-19162: XPTY0004 - XQuery type mismatch: invalid argument types 'string', 'string' for function 'string'
Cause:
The type of the arguments that were passed to the given function was not valid.
Action:
Fix the arguments to be of a type appropriate for the given function.
ORA-19163: XPTY0004 - XQuery type mismatch: argument type mismatch: expected - 'string' got - 'string' for function 'string'
Cause:
Action:
ORA-19164: XQST0085 - It is a static error if the namespace URI in a namespace declaration attribute is a zero-length string, and the implementation does not support [XML Names 1.1].
Cause:
There was a zero-length URI in namespace declaration.
Action:
Fix the namespace declaration.
ORA-19165: FONS0003: no prefix defined for namespace
Cause:
Action:
ORA-19166: FONS0003: FONS0004: no namespace found for prefix
Cause:
Action:
ORA-19167: FONS0005: base uri not defined in the static context
Cause:
Action:
ORA-19168: FORG0002: invalid argument to fn:resolve-uri()
Cause:
Action:
ORA-19169: FORG0006: invalid argument type in 'string'
Cause:
Action:
ORA-19171: FORG0007: invalid argument to aggregate function
Cause:
Action:
ORA-19172: FORG0008: both arguments to fn:dateTime have a specified timezone
Cause:
Action:
ORA-19173: FORG0009: error in resolving a relative URI against a base URI in fn:resolve-uri
Cause:
Action:
ORA-19174: FORX0001: invalid regular expression flags
Cause:
Action:
ORA-19175: FORX0002: invalid regular expression
Cause:
Action:
ORA-19176: FORX0003: regular expression matches zero-length string
Cause:
Action:
ORA-19177: FORX0004: invalid replacement string
Cause:
Action:
ORA-19178: FOTY0001: type error
Cause:
Action:
ORA-19179: FOTY0011: Type error. Context item is not a node
Cause:
Action:
ORA-19180: FOTY0012: argument node does not have a typed value
Cause:
Action:
ORA-19181: FOTY0014: type exception
Cause:
Action:
ORA-19182: FORT0001: invalid number of parameters
Cause:
Action:
ORA-19183: FOTY0002: type definition not found
Cause:
Action:
ORA-19184: FOTY0021: invalid node type
Cause:
Action:
ORA-19185: FOAR0002: numeric operation overflow/unflow
Cause:
Action:
ORA-19186: FOCA0001: input value too large for decimal
Cause:
Action:
ORA-19187: FOCA0002: invalid lexical value
Cause:
Action:
ORA-19188: FOCA0003: input value too large for integer
Cause:
Action:
ORA-19189: FOCA0005: NaN supplied as float/double value
Cause:
Action:
ORA-19190: FOER0000: Unidentified error
Cause:
Action:
ORA-19191: FOAR0001: division by zero
Cause:
Action:
ORA-19192: XQST0047: It is a static error if multiple module imports in the same Prolog specify the same target namespace
Cause:
Action:
ORA-19193: XQST0045: It is a static error if the function name in a function declaration is in one of the following namespaces: http://www.w3.org/XML/1998/namespace, http://www.w3.org/2001/XMLSchema, http://www.w3.org/2001/XMLSchema-instance, http://www.w3.org/2005/04/xpath-functions, http://www.w3.org/2005/04/xpath-datatypes
Cause:
Action:
ORA-19194: XQDY0026: It is a dynamic error if the result of the content expression of a computed processing instruction constructor contains the string "?>"
Cause:
Action:
ORA-19195: Invalid policy in ora:contains
Cause:
An invalid policy was specified in ora:contains.
Action:
Rename the policy name, policy schema name, or do not specify any policy to pick up default policy.
ORA-19196: XMLType table or view is not allowed with this form of fn:collection
Cause:
The table or view specified in fn:collection was of XMLType.
Action:
XMLType table or view is not allowed in the form of fn:collection('oradb:/schema/table/ROW/column'). It has to be a relational table or view.
ORA-19197: Column not found or invalid column type with this form of fn:collection
Cause:
The column to be retrieved was not found or was not of XMLType.
Action:
The column to be retrieved in the form of fn:collection('oradb:/schema/table/ROW/column') or fn:collection('oradb:/schema/table/ROW[predicate]/column') has to be of XMLType.
ORA-19198: Column not found or invalid column specified in the predicate with this form of fn:collection
Cause:
The column specified in the predicate was not found or was not allowed.
Action:
The column specified in the predicate in the form of fn:collection('oradb:/schema/table/ROW[predicate]/column') cannot be of XMLType.
ORA-19200: Invalid column specification
Cause:
All input arguments must be valid columns
Action:
Specify a valid list of columns
ORA-19201: Datatype not supported
Cause:
The particular datatype is not supported in the XMLGEN operator
Action:
Specify only supported datatypes as arguments to the XMLGEN operator
ORA-19202: Error occurred in XML processingstring
Cause:
An error occurred when processing the XML function
Action:
Check the given error message and fix the appropriate problem
ORA-19203: Error occurred in DBMS_XMLGEN processingstring
Cause:
An error occurred when processing the DBMS_XMLGEN functions
Action:
ORA-19204: Non-scalar value 'string' is marked as XML attribute
Cause:
Only scalar values (i.e. values which are not of object or collection type) can be marked as XML attribute,i.e. is prefixed by '@'. In this case, a non-scalar value was prefixed with '@'
Action:
Remove the '@' sign, or make the value a scalar.
ORA-19205: Attribute 'string' qualifies a non-scalar value in the select list
Cause:
The attribute immediately follows a value of object or collection type in the select list or type definition.
Action:
Remove the '@' sign, or make the previous value a scalar.
ORA-19206: Invalid value for query or REF CURSOR parameter
Cause:
The queryString argument passed to DBMS_XMLGEN.newContext was not a valid query, or REF CURSOR.
Action:
Rewrite the query so that the queryString argument is a valid query or REF CURSOR.
ORA-19207: scalar parameter string of XMLELEMENT cannot have an alias.
Cause:
The scalar parameter to XMLELEMENT has been qualified with an alias.
Action:
Remove the AS clause of the scalar element.
ORA-19208: parameter string of function string must be aliased
Cause:
The indicated parameter of the XML generation function has not been aliased, although it is an expression.
Action:
Specify an alias for the expression using the AS clause.
ORA-19209: invalid or unsupported formatting argument
Cause:
An invalid or unsupported formatting argument was supplied
Action:
Change the formatting argument to legal supported values
ORA-19210: column 'string', specified to be a key or update column for DBMS_XMLSTORE, does not not exist in table 'string'
Cause:
The column specified using setKeyColumn()/setUpdateColumn() did not exist in the table.
Action:
Change the column specified to be a column in the table
ORA-19211: column 'string', specified as key using DBMS_XMLSTORE.setKeyColumn() , must be of scalar type
Cause:
The column specified using setKeyColumn() was a non-scalar type column.
Action:
Change the column specified to be a scalar column in the table
ORA-19212: no key columns specified before call to DBMS_XMLSTORE.updateXML()
Cause:
No columns were specified as key columns before the call to DBMS_XMLSTORE.updateXML.
Action:
Use DBMS_XMLSTORE.setKeyColumn() to specify key columns
ORA-19213: error occurred in XML processing at linesstring
Cause:
An error occurred when processing the given lines in an XML function.
Action:
Check the given error message and fix the appropriate problem.
ORA-19221: XPST0001 - XQuery static context component string not initialized
Cause:
An unitialized static context component was encountered during the static analysis of the expression.
Action:
initialize the given static context.
ORA-19222: XPDY0002 - XQuery dynamic context component string not initialized
Cause:
An unitialized dynamic context component was encountered during the evaluation of the expression.
Action:
Initialize the particular dynamic context component.
ORA-19223: XPST0003 - syntax error in XQuery expression
Cause:
The given XQuery expression contains syntax errors.
Action:
Fix the syntax error in the XQuery expression.
ORA-19224: XPTY0004 - XQuery static type mismatch: expected - string got - string
Cause:
The expression could not be used because it's static type is not appropriate for the context in which it was used.
Action:
Fix the expression to be of the required type or add appropriate cast functions around the expression.
ORA-19225: XPST0005 - XQuery static type error: expected non empty type got empty sequence
Cause:
The static type assigned to an expression other than the () expression must not be the empty type.
Action:
Fix the expression so it does not return empty sequences.
ORA-19226: XPTY0006 - XQuery dynamic type mismatch: expected string got string
Cause:
The expression could not be used because it's dynamic type did not match the required type as specified by XQuery sequencetype matching rules.
Action:
Fix the expression to return the expected type or use appropriate cast functions.
ORA-19227: XPTY0007 - fn:data function is applied to a node (type (string)) whose type annotation denotes a complex type with non-mixed complex content.
Cause:
The input node for atomization contained a type annotation that denoted a complex type with non-mixed complex content.
Action:
Fix the input expression to fn:data to be a node that does not contain non-mixed complex content.
ORA-19228: XPST0008 - undeclared identifier: prefix 'string' local-name 'string'
Cause:
The given identifier refers to either a type name, function name, namespace prefix, or variable name that is not defined in the static context.
Action:
Fix the expression to remove the identifier, or declare the appropriate variable, type, function or namespace.
ORA-19229: XQST0009 - schema import not supported
Cause:
A schema import was encountered in the query.
Action:
remove the schema import.
ORA-19230: XPST0010 - unsupported axis string
Cause:
An unsupported axis was encountered in the given expression.
Action:
Remove the unsupported axis from the expression.
ORA-19231: XPST0011 -
ORA-19232: XQST0012 - imported schemas violate validity rules
Cause:
The imported schemas did not satisfy the conditions for schema validity specified in the XMLSchema specification.
Action:
Fix the imported schemas to satisfy the validity rules.In particular, the definitions must be valid, complete, and unique -- that is, the pool of definitions must not contain two or more schema components with the same name and target namespace.
ORA-19233: XQST0013 - invalid pragma
Cause:
A pragma was specified whose contents are invalid.
Action:
Specify the pragma with the correct contents.
ORA-19234: XQST0014 - invalid or unsupported must-understand extension
Cause:
The must-understand extension specified was either invalid or unsupported.
Action:
remove the unsupported must-understand extension or fix the error.
ORA-19235: XQST0015 - unsupported must-understand extension
Cause:
The XQuery flagger was enabled and the query contained a must-understand extension.
Action:
remove the unsupported must-understand extension.
ORA-19236: XQST0016 - module declaration or import not supported
Cause:
The given query had a module declaration or module import.
Action:
Remove the import module or module declaration.
ORA-19237: XPST0017 - unable to resolve call to function - string:string
Cause:
The name and arity of the function call given could not be matched with any in-scope function in the static context.
Action:
Fix the name of the function or the number of parameters to match the list of in-scope functions.
ORA-19238: XPTY0018 - It is a type error if the result of the last step in a path expression contains both nodes and atomic values
Cause:
Action:
ORA-19239: XPTY0019 - It is a type error if the result of an step (other than the last step) in a path expression contains an atomic value
Cause:
The step expression returned a sequence containing an atomic value.
Action:
Fix the path expression to return only nodes.
ORA-19240: XPTY0020 - context item must be node in an axis expression
Cause:
The context item that was used in the axis epression is not a node.
Action:
Change the context item to be a node.
ORA-19241: XPDY0021 - cast to type string failed
Cause:
The value inside a cast expression could not be cast to the required type.
Action:
Fix the input to the cast expression to be of a castable type.
ORA-19242: XQST0022 - namespace declaration attribute must be a literal
Cause:
The namespace declaration attribute was not a literal string.
Action:
Fix the namespace declaration to be a literal string.
ORA-19243: XQTY0023 - invalid document node content in element constructor
Cause:
The content sequence in an element constructor contained a document node.
Action:
Change the content of the element constructor so that it does not contain a document node.
ORA-19244: XQTY0024 - invalid attribute node in element constructor
Cause:
The content sequence in an element constructor contained an attribute node following a node that was not an attribute node.
Action:
Change the content sequence of the element constructor so that it does not contain the attribute node.
ORA-19245: XQDY0025 - duplicate attribute name string
Cause:
The content sequence of the element constructor contained more than one attribute that had the same name.
Action:
Remove the duplicate attributes.
ORA-19246: validation failed - element string not found in in-scope element declarations
Cause:
The validation mode was strict and the element-constructor contained an element name that was not present in the in-scope element declarations.
Action:
Fix the validation mode to be lax or import the schema definition that contains the required element declaration.
ORA-19247: XQDY0027 - validation error
Cause:
An error was encountered during the validation of the expression.
Action:
Fix the validation error.
ORA-19248: XQTY0028 - invalid node in document constructor
Cause:
The content sequence in a document constructor contained either a document or an attribute node.
Action:
Fix the content so it does not contain any of the above node types.
ORA-19249: XQDY0029 - value does not match facet of the target type
Cause:
The input value to a cast expression did not satisfy the facets of the target type.
Action:
Fix the value to conform to the facets of the target type.
ORA-19250: XQTY0030 - too many values to validate expression
Cause:
The argument of a validate expression returned more than one element or document node.
Action:
Fix the argument of the validate expression to return a single element or document node.
ORA-19251: XQST0031 - unsupported query version
Cause:
The query version specified in the prolog was not supported.
Action:
Supply the version of the query that is supported.
ORA-19252: XQST0032 - too many declarations for base URI
Cause:
The query prolog contained multiple declarations for the base URI.
Action:
Remove the duplicate definitions for the base URI.
ORA-19253: XQST0033 - too many declarations for namespace prefix string
Cause:
The query prolog contained multiple declarations for the same namespace prefix.
Action:
Remove the duplicate definitions for the namespace prefix.
ORA-19254: XQST0034 - too many declarations for function string
Cause:
The query module contained more than one function, either declared or imported, which have the same expanded QName.
Action:
Remove the duplicate function definitions.
ORA-19255: XQST0035 - too many declarations of string in imported schemas
Cause:
Two schemas were imported that defined the same name in the same symbol space and in the same scope.
Action:
Fix the schema imports to remove the name conflict.
ORA-19256: XQST0036 - missing type definitions in imported module
Cause:
A module was imported, which contains references to type names that are not defined in the in-scope type definitions inside the module.
Action:
Fix the module definintion to include the in-scope type definition.
ORA-19257: XQST0037 - function or variable string in module already defined
Cause:
A module being imported contained the function or variable that is already declared in the static context of the importing module.
Action:
Remove the conflicting declarations.
ORA-19258: XQST0038 - unsupported or duplicate default collation specified
Cause:
The query prolog prolog either specified more than one default collation or the collation specified was not supported.
Action:
Remove the duplicate definition or specify a supported collation.
ORA-19259: XQST0039 - duplicate parameter name string in function declaration
Cause:
The function declaration contained more than one parameter with the same name.
Action:
Fix the function declaration to remove the duplicate parameters.
ORA-19260: XQST0040 - invalid namespace node in element constructor
Cause:
The content sequence in an element constructor contained a namespace node node following a node that was not a namespace node.
Action:
Remove the namespace node in the element constructor.
ORA-19261: XQDY0041 - non empty URI in QName
Cause:
The name expression in a computed processing instruction or computed namespace constructor returned a QName whose URI part was not empty.
Action:
Fix the processing instruction or computed namespace constructor to return the QName with an empty URI part.
ORA-19262: XQST0042 - namespace constructor not inside an element constructor
Cause:
The enclosing expression of a computed namespace constructor was not a computed element constructor.
Action:
Fix the namespace constructor to be inside an element constructor.
ORA-19263: XQST0043 - duplicate namespace prefix string
Cause:
Two or more computed namespace constructors within the same computed element constructor attempted to bind the same namespace prefix.
Action:
Remove the duplicate namespace definitions.
ORA-19264: XQDY0044 - invalid namespace in attribute constructors
Cause:
A computed attribute constructor returned a QName that is in the pre-defined XML namespace (corresponding to namespace prefix xmlns).
Action:
Change the namespace for the computed attribute constructor.
ORA-19265: XQST0045 - invalid or unknown prefix string in function declaration
Cause:
The declared function name in a function declaration had no namespace prefix or had one of the predefined namespace prefixes other than local.
Action:
Fix the function declaration to have the correct prefix.
ORA-19266: XQST0046 - invalid URI
Cause:
The given URI contained a lexical form that was not valid according to the definition of xs:anyURI in XML Schema.
Action:
Fix the URI.
ORA-19267: module string not found
Cause:
The module with the given target URI could not be found.
Action:
Fix the prolog to import only available modules.
ORA-19268: XQST0048 - namespace string does not match target namespace string
Cause:
The module contained a function or variable whose namespace did not match the target namespace of the module.
Action:
Fix the namespace of the function or variable to match the target namespace of the module.
ORA-19269: XQST0049 - variable string defined multiple times
Cause:
The module defined or imported the same variable multiple times.
Action:
Fix the import or the module definition to remove duplicate definitions.
ORA-19270: XPDY0050 - treat failed - expected string got string
Cause:
The type of the operand to the treat expression did not match the required type.
Action:
Fix the input operand to be of the correct type.
ORA-19271: XPST0051 - invalid atomic type definition
Cause:
The QName used as an AtomicType in a SequenceType was not defined in the in-scope type definitions as an atomic type.
Action:
Use the correct atomic type name.
ORA-19272: XQDY0052 - invalid atomic value in attribute or element constructor
Cause:
The content of the element or attribute constructor included an atomic value that could not be cast into a string.
Action:
Fix the content to contain atomic values that can be cast to a string.
ORA-19273: XQST0053 - empty string in namespace declaration
Cause:
An empty string was used in a namespace declaration.
Action:
Fix the namespace declaration to have a non-empty string.
ORA-19274: XQST0054 - variable initialization failed due to circularity
Cause:
A circular definition was encountered when the variable was initialized.
Action:
Remove the circularity in the initialization.
ORA-19275: XQST0055 - schema path string not found in list of in-scope schema definitions
Cause:
The ElementTest specified a schema path that could not be found in the list of in-scope schema definitions.
Action:
Include the appropriate schema that can be used to resolve the ElementTest.
ORA-19276: XPST0005 - XPath step specifies an invalid element/attribute name: (string)
Cause:
The XPath step specified invalid element or attribute name that did not match any nodes according to the input XML schema or structure.
Action:
Correct the element or attribute name as the name may be mis-spelled.
ORA-19277: XPST0005 - XPath step specifies an item type matching no node: (string)
Cause:
The XPath step specified an item type that did not match any nodes according to the input XML schema or structure.
Action:
Correct the item type defintion as node of such type does not exit in the input XML schema or structure.
ORA-19278: Invalid value: (string) for type: (string)
Cause:
The value was invalid for the type.
Action:
Correct the value or change the type.
ORA-19279: XPTY0004 - XQuery dynamic type mismatch: expected singleton sequence - got multi-item sequence
Cause:
The XQuery sequence passed in had more than one item.
Action:
Correct the XQuery expression to return a single item sequence.
ORA-19280: XQuery dynamic type mismatch: expected atomic value - got node
Cause:
A node was passed in to the expression where an atomic value was expected.
Action:
Correct the XQuery expression to return an atomic value.
ORA-19281: XQST0055 - It is a static error if a Prolog contains more than one copy-namespaces declaration
Cause:
The query prolog contained multiple copy-namespaces declarations.
Action:
Remove the duplicate copy-namespaces declarations.
ORA-19282: XQST0068 - It is a static error if a Prolog contains more than one xmlspace declaration
Cause:
Action:
ORA-19283: XQST0031 - It is a static error if the version number specified in a version declaration is not supported by the implementation.
Cause:
The query contained a version declaration not supported by this implementation.
Action:
Change the version declaration to 1.0 which is the version supported by this implementation.
ORA-19284: Encoding specification in version declaration not supported
Cause:
The query contained an encoding specification.
Action:
Remove the encoding specification.
ORA-19285: FODC0002 - error retrieving resource
Cause:
The URI provided could not be resolved to a valid resource.
Action:
Provide a valid URI for a resource.
ORA-19286: XPST0017 - unable to resolve call to function - string
Cause:
Action:
ORA-19287: XPST0017 - invalid number of arguments to function - string:string
Cause:
Action:
ORA-19288: XPST0017 - invalid number of arguments to function - string
Cause:
Action:
ORA-19289: XQST0034 - function string:string declared or defined multiple times
Cause:
Multiple functions declared or imported by a module had the same expanded QName and the same number of arguments.
Action:
Fix the function declaraction or definition to remove duplicates.
ORA-19290: XQST0069 - more than one empty order declaration declared in the prolog
Cause:
A prolog had more than one empty order declaration.
Action:
Fix the prolog to have just one empty order declaration.
ORA-19291: XPST0081 - specified QName cannot be expanded into a namespace URI
Cause:
The namespace prefix of the QName could not be expanded into a namespace URI by using the statically known namespaces.
Action:
Use a namespace prefix that can be resolved into a namespace URI from the statically known namespaces.
ORA-19292: XQST0057: It is a static error if a schema import binds a namespace prefix but does not specify a target namespace other than a zero-length string
Cause:
Action:
ORA-19293: XQST0058: It is a static error if multiple schema imports specify the same target namespace
Cause:
Action:
ORA-19294: XQST0059: It is a static error if an implementation is unable to process a schema or module import by finding a schema or module with the specified target namespace
Cause:
Action:
ORA-19295: XQST0060: It is a static error if the name of a function in a function declaration is not in a namespace (expanded QName has a null namespace URI)
Cause:
Action:
ORA-19296: XQDY0061: It is a dynamic error if the operand of a validate expression is a document node whose children do not consist of exactly one element node and zero or more comment and processing instruction nodes, in any order
Cause:
Action:
ORA-19297: XQDY0064: It is a dynamic error if the value of the name expression in a computed processing instruction constructor is equal to "XML" (in any combination of upper and lower case
Cause:
Action:
ORA-19298: XQST0065: A static error is raised if a Prolog contains more than one ordering mode declaration
Cause:
Action:
ORA-19299: XQST0066: A static error is raised if a Prolog contains more than one default element/type namespace declaration, or more than one default function namespace declaration
Cause:
Action:
ORA-19300: Error occurred in uri processingstring
Cause:
An error occurred when processing the URL
Action:
ORA-19320: Host name not specified in HTTP URL
Cause:
A host name was not specified in the HTTP url
Action:
Specify a host name in the HTTP url when creating the URL string
ORA-19321: Could not open HTTP connection to host (string): port (string)
Cause:
A HTTP connection could not be opened to the host
Action:
Specify a valid host name and port to connect to
ORA-19322: An error occurred while reading from host (string): port (string)
Cause:
An error occurred while reading from the HTTP host
Action:
Specify a valid host name and port to read from
ORA-19323: Invalid url string
Cause:
The URL must be a valid URL string
Action:
Specify a valid url string
ORA-19330: Type 'string'.'string' not installed. Please install the type before using the CREATE_DBURI operator
Cause:
The type required for the CREATE_DBURI operator has not been installed correctly.
Action:
Read the installation notes to install the type correctly.
ORA-19331: Last argument to CREATE_DBURI operator must be a column
Cause:
The final argument to the CREATE_DBURI operator must be a column to which the reference is being created.
Action:
Specify a valid column name in the query.
ORA-19332: Invalid column in the CREATE_DBURI operator
Cause:
The argument to the CREATE_DBURI operator can only be a column.
Action:
Specify a valid column name for the operator
ORA-19333: Invalid flags for the CREATE_DBURI operator
Cause:
The flags argument given to the DBURI operator is invalid
Action:
Specify a valid flag value (TEXT) for the DBURI operator
ORA-19334: Invalid column specification for CREATE_DBURI operator
Cause:
All columns must be valid and pointing to the same table or view
Action:
Specify valid list of columns that are from the same table or view.
ORA-19335: Invalid format type object
Cause:
An invalid format type object was specified for the XML function
Action:
Specify a valid format type object
ORA-19336: Missing XML root element
Cause:
The XML being generated does not have an enclosing root element.
Action:
The XML generated must have a root element
ORA-19361: ONLINE option not allowed with this type of index
Cause:
The ONLINE option was specified to validate the structure of a system-generated metadata index
Action:
The ONLINE option can not be used with system-generated metadata indexes such as an LOB index, an IOT Top index, an Index on Clusters etc., Run query without using the ONLINE option.
ORA-19371: invalid update option
Cause:
The user attempted to call load_sqlset with an update option that is different than REPLACE and ACCUMULATE.
Action:
Adjust the update option and retry the operation.
ORA-19372: invalid update condition
Cause:
The user attempted to call load_sqlset with an invalid update condition.
Action:
Check the update condition (e.g., NEW.COL1_NAME >= OLD.COL2_NAME) and retry the operation.
ORA-19373: invalid staging table or tablespace
Cause:
The user attempted to create a staging table and specified an invalid staging table (or one that already exists) or tablespace
Action:
Check the arguments and try again.
ORA-19374: invalid staging table
Cause:
The user specified an invalid staging table to one of the pack, unpack, or remap stgtab routines, or the user does not have the correct privileges on the staging table
Action:
Provide a correct staging table or grant the appropriate privileges
ORA-19375: no CREATE TABLE privilege on schema "string"
Cause:
The user tried to create a staging table when he is missing the CREATE TABLE privilege on the specified schema.
Action:
Grant the privilege to the user and retry
ORA-19376: no privileges on tablespace provided or tablespace is offline
Cause:
The user tried to create a staging table on a tablespace on which he does not have any space allocated, or it is offline
Action:
Allocate space on the tablespace, bring it online, and retry
ORA-19377: no "SQL Tuning Set" with name like "string" exists for owner like "string"
Cause:
The user specified a filter to a pack/unpack function for the SQL Tuning Set that targets no STS in the SYS schema or the staging table, respectively
Action:
Provide a different filter after checking the state of the system
ORA-19378: invalid mode
Cause:
The user specified an invalid mode argument to the capture function.
Action:
Provide a mode argument that was defined in the dbmssqlt file
ORA-19379: invalid time_limit or repeat_interval
Cause:
The user specified a NULL value for either the time_limit or the repeat_interval, or a repeat_interval that is greater than the time_limit
Action:
Provide a non-null value and make sure time_limit >= repeat_interval
ORA-19380: invalid plan filter
Cause:
The user specified an invalid filter for the plan when calling the select_sqlset table function.
Action:
Adjust the the filter to be one of the following values and retry the operation: MAX_ELAPSED_TIME, MAX_CPU_TIME, MAX_DISK_READS, MAX_OPTIMIZER_COST, MAX_BUFFER_GETS, FIRST_LOADED LAST_LOADED, FIRST_GENERATED, or LAST_GENERATED.
ORA-19381: cannot create staging table in SYS schema
Cause:
The user attempted to create a staging table in the sys schema
Action:
Create the table in another schema.
ORA-19384: cannot pack into staging table from previous version
Cause:
An attempt was made to perform a pack operation on a staging table from a previous version.
Action:
Create a staging table in the current version and retry the operation.
ORA-19385: staging table is empty
Cause:
An attempt was made to perform an operation on an empty staging table.
Action:
Check the staging table to make sure that it has rows.
ORA-19386: target object already exists for tuning task "string"
Cause:
An attempt was made to set a target object for a tuning task when one had already been set.
Action:
Create a new task if another target object is needed.
ORA-19387: "SQL Tuning Set" "string" belongs to another tuning task
Cause:
The user attempted to tune a task-managed SQL Tuning Set belonging to one task within the scope of another task.
Action:
Check the SQL Tuning Set and retry the operation.
ORA-19388: operation not supported for "SQL Tuning Set" type
Cause:
The attempted operation was unsupported for the type of the given SQL Tuning Set.
Action:
ORA-19389: LOB types are not supported for SQL binds
Cause:
A LOB type was provided in a SQL bind list.
Action:
Replace the LOB binds with legal bind types or try another SQL.
ORA-19390: The profile type is not valid
Cause:
The profile type is not valid.
Action:
Check the available profile types.
ORA-19400: System type conflict with object SYS.string
Cause:
The user had an object with the same name as one of the system types. The system types were not initialized properly.
Action:
Remove the conflicting object and rerun migration.
