Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
71 ORA-19999 to ORA-24279
ORA-19999: skip_row procedure was called
Cause: The skip_row procedure was called which raises this error
Action: Skip_row should only be called within a trigger or a procedure called by a trigger.
ORA-20000: string
Cause: The stored procedure 'raise_application_error' was called which causes this error to be generated.
Action: Correct the problem as described in the error message or contact the application administrator or DBA for more information.
ORA-21000: error number argument to raise_application_error of stringstring is out of range
ORA-21001: error number argument to raise_system_error of stringstring is out of range
ORA-21300: objects option not installed
Cause: The objects option is not installed at this site. object types and other object features are, therefore, unavailable.
Action: Install the objects option. The objects option is not part of the Oracle Server product and must be purchased separately. Contact an Oracle sales representative if the objects option needs to be purchased.
ORA-21301: not initialized in object mode
Cause: This function requires the OCI process to be initialized in object mode.
Action: Specify OCI_OBJECT mode when calling OCIInitialize().
ORA-21500: internal error code, arguments: [string], [string], [string], [string], [string], [string], [string], [string]
Cause: This is the generic error number for the OCI environment (client-side) internal errors. This indicates that the OCI environment has encountered an exceptional condition.
Action: Report as a bug - the first argument is the internal error number.
ORA-21501: program could not allocate memory
Cause: The operating system has run out of memory.
Action: Take action to make more memory available to the program.
ORA-21503: program terminated by fatal error
Cause: A program is in an unrecoverable error state.
Action: Report as a bug.
ORA-21520: database server driver not installed
Cause: User attempted to access a database server through an object-mode OCI environment but the necessary driver for supporting such access to the database server is not installed or linked in.
Action: Check if the driver corresponding to the database server has been installed/linked in and entered in the server driver table.
ORA-21521: exceeded maximum number of connections in OCI (object mode only)
Cause: User exceeded the maximum number of connections (255) that can be supported by an OCI environment in object mode.
Action: Close some of existing and unused connections before opening more connections.
ORA-21522: attempted to use an invalid connection in OCI (object mode only)
Cause: User attempted to use an invalid connection or a connection that has been terminated in an OCI environment (object mode), or user attempted to dereference a REF obtained from a connection which has been terminated.
Action: Ensure that the connection exists and is still valid.
ORA-21523: functionality not supported by the server (object mode only)
Cause: User attempted to use a functionality that the server does not support.
Action: Upgrade the server
ORA-21524: object type mismatch
Cause: The object type of the object is different from what is specified.
Action: Check the type of the object and correct it.
ORA-21525: attribute number or (collection element at index) string violated its constraints
Cause: Attribute value or collection element value violated its constraint.
Action: Change the value of the attribute or collection element such that it meets its constraints. The constraints are specified as part of the attribute or collection element's schema information.
ORA-21526: initialization failed
Cause: The initialization sequence failed. This can happen, for example, if an environment variable such as NLS_DATE_FORMAT is set to an invalid value.
Action: Check that all NLS environment variables are well-formed.
ORA-21527: internal OMS driver error
Cause: A process has encountered an exceptional condition. This is the generic internal error number for Oracle object management services exceptions.
Action: Report this as a bug to Oracle Support Services.
ORA-21528: internal error, image could not be understood
Cause: The format of the image passed to the pickler is incorrect and cannot be understood.
Action: Contact Oracle Support Services.
ORA-21560: argument string is null, invalid, or out of range
Cause: The argument is expecting a non-null, valid value but the argument value passed in is null, invalid, or out of range. Examples include when the LOB/FILE positional or size argument has a value outside the range 1 through (4GB - 1), or when an invalid open mode is used to open a file, etc.
Action: Check your program and correct the caller of the routine to not pass a null, invalid or out-of-range argument value.
ORA-21561: OID generation failed
Cause: The handles passed in may not be valid
Action: Check the validity of the env, svc handles
ORA-21600: path expression too long
Cause: The path expression that is supplied by the user is too long. The path expression is used to specify the position of an attribute in an object. This error occurs when one of the intermediate elements in the path expression refers to an attribute of a built-in type. Thus, the OCI function cannot proceed on to process the rest of the elements in the path expression.
Action: User should pass in the correct path expression to locate the attribute.
ORA-21601: attribute is not an object
Cause: The user attempts to perform an operation (that is valid only for an object) to an attribute of a built-in type. An example of such an illegal operation is to dynamically set a null structure to an attribute of a built-in type.
Action: User should avoid performing such operation to an attribute of built-in type.
ORA-21602: operation does not support the specified typecode
Cause: The user attempts to perform an operation that does not support the specified typecode.
Action: User should use the range of valid typecodes that are supported by this operation.
ORA-21603: property id [string] is invalid
Cause: The specified property id is invalid.
Action: User should specify a valid property id. Valid property ids are enumerated by OCIObjectPropId.
ORA-21604: property [string] is not a property of transient or value instances
Cause: Trying to get a property which applies only to persistent objects.
Action: User should check the lifetime and only get this property for persistent objects.
ORA-21605: property [string] is not a property of value instances
Cause: Trying to get a property which applies only to persistent and transient objects.
Action: User should check the lifetime and only get this property for persistent and transient objects.
ORA-21606: can not free this object
Cause: Trying to free an object that is persistent and dirty and the OCI_OBJECTFREE_FORCE flag is not specified.
Action: Either flush the persistent object or set the flag to OCI_OBJECTFREE_FORCE
ORA-21607: memory cartridge service handle not initialized
Cause: Attempt to use the handle without initializing it.
Action: Initialize the memory cartridge service handle.
ORA-21608: duration is invalid for this function
Cause: Attempt to use a duration not valid for this function.
Action: Use a valid duration - a previously created user duration or OCI_DURATION_STATEMENT or OCI_DURATION_SESSION. For callout duration or external procedure duration, use OCIExtProcAllocCallMemory.
ORA-21609: memory being resized without being allocated first
Cause: Attempt to resize memory without allocating it first.
Action: Allocate the memory first before resizing it.
ORA-21610: size [string] is invalid
Cause: Attempt to resize memory with invalid size.
Action: Pass in a valid size (must be a positive integer).
ORA-21611: key length [string] is invalid
Cause: Attempt to use an invalid key length.
Action: Key length is invalid and valid range is 0 to 64
ORA-21612: key is already being used
Cause: Attempt to use a key that is already used.
Action: Use a new key that is not yet being used.
ORA-21613: key does not exist
Cause: Attempt to use a non-existent key
Action: Use a key that already exists.
ORA-21614: constraint violation for attribute number [string]
Cause: Constraints on the attribute were violated
Action: Correct the value (of the attribute) so that it satisfies constraints
ORA-21615: copy of an OTS (named or simple) instance failed
Cause: see following message
Action: Check that no attribute value violates constraints.
ORA-21700: object does not exist or is marked for delete
Cause: User attempted to perform an inappropriate operation to an object that is non-existent or marked for delete. Operations such as pinning, deleting and updating cannot be applied to an object that is non-existent or marked for delete.
Action: User needs to re-initialize the reference to reference an existent object or the user needs to unmark the object.
ORA-21701: attempt to flush objects to different servers
Cause: User attempted to flush objects to different servers in one function call. These objects are obtained by calling a callback functions provided by the program.
Action: User should avoid performing such operation.
ORA-21702: object is not instantiated or has been de-instantiated in cache
Cause: User attempted to perform an inappropriate operation to a transient object that is not instantiated in the object cache. Operations that cannot be applied to a not-instantiated transient object include deleting or pinning such an object.
Action: User should check their code to see if they are performing such an operation without instantiating the object first, or performing such an operation after the allocation duration of the object has expired.
ORA-21703: cannot flush an object that is not modified
Cause: See the error message.
Action: The object should not be flushed.
ORA-21704: cannot terminate cache or connection without flushing first
Action: The transaction should be aborted or committed before terminating the cache or connection.
ORA-21705: service context is invalid
Cause: The service context that is supplied by the user is not valid.
Action: User needs to establish the service context.
ORA-21706: duration does not exist or is invalid
Cause: The duration number that is supplied by the user is not valid.
Action: User needs to establish the duration or use a correct predefined duration.
ORA-21707: pin duration is longer than allocation duration
Cause: The pin duration supplied by the user is longer than the allocation duration. This affects operations such as pinning and setting default parameters.
Action: User should use a shorter pin duration or use the null duration.
ORA-21708: inappropriate operation on a transient object
Cause: User attempted to perform an inappropriate operation on a transient object. Operations that cannot be applied to a transient object include flushing and locking.
Action: User should avoid performing such operation on a transient object.
ORA-21709: cannot refresh an object that has been modified
Cause: User attempted to refresh an object that has been marked for delete, update or insert (new).
Action: User should unmark the object before refreshing it.
ORA-21710: argument is expecting a valid memory address of an object
Cause: The object memory address that is supplied by the user is invalid. The user may have passed in a bad memory address to a function that is expecting a valid memory address of an object.
Action: User should pass in a valid memory address of an object to the function.
ORA-21779: duration not active
Cause: User is trying to use a duration that has been terminated.
ORA-21780: Maximum number of object durations exceeded.
Cause: This typically happens if there is infinite recursion in the PL/SQL function that is being executed.
Action: User should alter the recursion condition in order to prevent infinite recursion.
ORA-22053: overflow error
Cause: This operation's result is above the range of Oracle number.
Action: Decrease the input value(s) so that the result is in the range of Oracle number.
ORA-22054: underflow error
Cause: This operation's result is below the range of Oracle number.
Action: Increase the input value(s) so that the result is in the range of Oracle number.
ORA-22055: unknown sign flag value [string]
Cause: Signed flag used is not OCI_NUMBER_SIGNED or OCI_NUMBER_UNSIGNED.
Action: Use either OCI_NUMBER_SIGNED or OCI_NUMBER_UNSIGNED as sign flag.
ORA-22056: value [string] is divided by zero
Cause: Given value is divied by zero.
Action: Modify divisor value to be non-zero.
ORA-22057: bad integer length [string]
Cause: The length of the integer (ie number of bytes) to be converted to or from an Oracle number is invalid.
Action: Use integer length 1, 2, 4 or 8 bytes only.
ORA-22059: buffer size [string] is too small - [string] is needed
Cause: The buffer to hold the resulting text string is too small.
Action: Provide a buffer of the required size.
ORA-22060: argument [string] is an invalid or uninitialized number
Cause: An invalid or uninitialized number is passed in.
Action: Use a valid number. To initialize number call OCINumberSetZero().
ORA-22061: invalid format text [string]
Cause: The numeric format string for converting characters to or from an Oracle number is invalid.
Action: Use valid format string as documented in OCI Programmer's Guide.
ORA-22062: invalid input string [string]
Cause: The text string for converting to numbers is invalid.
Action: Use a valid input string as documented in OCI Programmer's Guide.
ORA-22063: reading negative value [string] as unsigned
Cause: Attempt to convert a negative number to an unsigned integer.
Action: Use the sign flag ORLTSB to convert a signed number.
ORA-22064: invalid NLS parameter string [string]
Cause: The NLS parameter string for converting characters to or from an Oracle number is invalid.
ORA-22065: number to text translation for the given format causes overflow
Cause: Rounding done due to the given string format causes overflow.
Action: Change the string format such that overflow does not occur.
ORA-22130: buffer size [string] is less than the required size [string]
Cause: The size of the buffer into which the hexadecimal REF string is to be written is too small.
ORA-22131: hexadecimal string length is zero
Cause: The given hexadecimal string length must be greater than zero.
Action: Specify a length greater than zero.
ORA-22132: hexadecimal string does not correspond to a valid REF
Cause: The given hexadecimal string is invalid.
Action: Provide a valid hexadecimal string which was previously returned by a call to OCIRefToHex().
ORA-22140: given size [string] must be in the range of 0 to [string]
Cause: The given resize size is invalid.
Action: Ensure that the given size is in the required range.
ORA-22141: given size [string] must be even in UTF-16 environment
Cause: The given resize size is odd. In a UTF-16 environment, all characters are 2 bytes in length.
Action: Ensure that the given size is even.
ORA-22150: variable-length array has not been initialized
Cause: An un-initialized variable-length array is being operated upon.
Action: Initialize the variable-length array prior to calling this function.
ORA-22151: cannot resize non-zero variable-length array to zero elements
Cause: Trying to resize a non-zero variable-length array to 0 elements.
Action: Specify a non-zero size.
ORA-22152: destination variable-length array is not initialized
Cause: The variable-length array on the right-hand-side of an assignment or the destination array of an append is not initialized.
Action: Initialize the destination variable-length array prior to calling this function.
ORA-22153: source variable-length array is not initialized
Cause: The variable-length array on the left-hand-side of an assignment or the source array of an append is not initialized.
ORA-22160: element at index [string] does not exist
Cause: Collection element at the given index does not exist.
Action: Specify the index of an element which exists.
ORA-22161: type code [string] is not valid
Cause: Given type code is not valid.
Action: Use one of the typecodes enumerated in OCITypeCode.
ORA-22162: element at index [string] has been previously deleted
Cause: Trying to delete a non-existent collection element.
Action: Check for the existence of the element prior to calling this function.
ORA-22163: left hand and right hand side collections are not of same type
Cause: Left hand and right side collections are not of same type.
Action: Ensure that the same collection type is passed for both left hand and right hand side of this function.
ORA-22164: delete element operation is not allowed for variable-length array
Cause: Trying to delete an element of a variable-length array.
Action: Ensure that the collection is not a variable-length array prior to calling this function.
ORA-22165: given index [string] must be in the range of [string] to [string]
Cause: Given index is not in the required range.
Action: Ensure that the given index is in the required range.
ORA-22166: collection is empty
Cause: Given collection is empty.
Action: Test if collection is empty prior to invoking this function.
ORA-22167: given trim size [string] must be less than or equal to [string]
Cause: Given trim size is greater than the current collection size.
Action: Ensure that the given size is less than or equal to the collection size prior to calling this function.
ORA-22275: invalid LOB locator specified
Cause: There are several causes: (1) the LOB locator was never initialized; (2) the locator is for a BFILE and the routine expects a BLOB/CLOB/NCLOB locator; (3) the locator is for a BLOB/CLOB/NCLOB and the routine expects a BFILE locator; (4) trying to update the LOB in a trigger body -- LOBs in trigger bodies are read only; (5) the locator is for a BFILE/BLOB and the routine expects a CLOB/NCLOB locator; (6) the locator is for a CLOB/NCLOB and the routine expects a BFILE/BLOB locator;
Action: For (1), initialize the LOB locator by selecting into the locator variable or by setting the LOB locator to empty. For (2),(3), (5) and (6)pass the correct type of locator into the routine. For (4), remove the trigger body code that updates the LOB value.
ORA-22276: invalid locator for LOB buffering
Cause: There are several causes: (1) the locator was never enabled for buffering (2) it is not an updated locator but is being used for a write/flush operation
Action: For (1) enable the locator for buffering; (2) ensure that only an updated locator is used for a LOB update operation
ORA-22277: cannot use two different locators to modify the same LOB
Cause: LOB buffering is enabled and an attempt was made to modify the LOB using two different LOB locators.
Action: When using LOB buffering, modify the LOB through one LOB locator only.
ORA-22278: must update the LOB only through the LOB buffers
Cause: LOB buffering is enabled for this LOB and there are buffers for this LOB in the buffer pool. Thus, updating the LOB through means other than the LOB buffers is not allowed.
Action: Update the LOB through the LOB buffers using the locator that has LOB buffering enabled. If this operation is required, buffers associated with this LOB should either be flushed as necessary or buffering should be disabled. Once this is done, reissue the command.
ORA-22279: cannot perform operation with LOB buffering enabled
Cause: The operation attempted is not allowed when LOB buffering is enabled.
Action: If the operation is required, LOB buffering should not be used. In this case, flush buffers associated with the input LOB locator as necessary, disable buffering on the input LOB locator and reissue the command.
ORA-22280: no more buffers available for operation
Cause: There are two causes: (1) All buffers in the buffer pool have been used up by previous operations (2) Attempt to flush a LOB without any previous buffered update operations.
Action: For (1), flush the LOB(s) through the locator that is being used to update the LOB. For (2), write to the LOB through a locator enabled for buffering before attempting to flush buffers.
ORA-22281: cannot perform operation with an updated locator
Cause: The input locator has buffering enabled and was used to update the LOB value through the LOB buffering subsystem. The modified buffer has not been flushed since the write that was performed by the the input locator; thus, the input locator is considered an updated locator. Updated locators cannot be the source of a copy operation. Only one locator per LOB may be used to modify the LOB value through the LOB buffering subsystem.
Action: Depending on whether the modifications made through the input locator to the LOB buffering subsystem should be written to the server, either flush the buffer to write the modifications, or, disable buffering on the locator to discard the modifications. Then, reissue the command.
ORA-22282: non-contiguous append to a buffering enabled LOB not allowed
Cause: The buffered write operation has an input offset value more than one byte or character past the end of the LOB.
Action: Specify an input offset value which is exactly one character or byte greater than the length of the LOB that you are attempting to update through a buffered write operation.
ORA-22283: filename contains characters that refer to parent directory
Cause: Filename contains a path "../" which references a parent directory
Action: Ensure that the filename does not contain characters which reference a parent directory.
ORA-22284: duplicate LONG binds are not supported
Cause: LOB access layer could not handle duplicate LONG binds.
Action: Provide distinct LONG or VARCHAR binds.
ORA-22285: non-existent directory or file for string operation
Cause: Attempted to access a directory that does not exist, or attempted to access a file in a directory that does not exist.
Action: Ensure that a system object corresponding to the specified directory exists in the database dictionary, or make sure the name is correct.
ORA-22286: insufficient privileges on file or directory to perform string operation
Cause: The user does not have the necessary access privileges on the directory alias and/or the file for the operation.
Action: Ask the database/system administrator to grant the required privileges on the directory alias and/or the file.
ORA-22287: invalid or modified directory occurred during string operation
Cause: The directory alias used for the current operation is not valid if being accessed for the first time, or has been modified by the DBA since the last access.
Action: If you are accessing this directory for the first time, provide a valid directory name. If you have been already successful in opening a file under this directory before this error occured, then close the file and retry the operation with a valid directory alias as modified by your DBA. Oracle recommends that directories should be modified only during quiescent periods.
ORA-22288: file or LOB operation string failed\nstring
Cause: The operation attempted on the file or LOB failed.
Action: See the next error message in the error stack for more detailed information. Also, verify that the file or LOB exists and that the necessary privileges are set for the specified operation. If the error still persists, report the error to the DBA.
ORA-22289: cannot perform string operation on an unopened file or LOB
Cause: The file or LOB is not open for the required operation to be performed.
Action: Precede the current operation with a successful open operation on the file or LOB.
ORA-22290: operation would exceed the maximum number of opened files or LOBs
Cause: The number of open files or LOBs has reached the maximum limit.
Action: Close some of the opened files or LOBs and retry the operation.
ORA-22291: Open LOBs exist at transaction commit time
Cause: An attempt was made to commit a transaction with open LOBs at transaction commit time.
Action: Close the LOBs before committing the transaction.
ORA-22292: Cannot open a LOB in read-write mode without a transaction
Cause: An attempt was made to open a LOB in read-write mode before a transaction was started.
Action: Start a transaction before opening the LOB in read-write mode. Ways to start a transaction include issuing a SQL DML or SELECT FOR UPDATE command. Opening hte LOB in read-only mode does not require a transaction.
ORA-22293: LOB already opened in the same transaction
Cause: An attempt was made to open a LOB that already is open in this transaction.
Action: Close the LOB before attempting to re-open it.
ORA-22294: cannot update a LOB opened in read-only mode
Cause: An attempt was made to write to or update a LOB opened in read-only mode.
Action: Close the LOB and re-open it in read-write mode before attempting to write to or update the LOB.
ORA-22295: cannot bind more than 4000 bytes data to LOB and LONG columns in 1 statement
Cause: An attempt was made to bind data more than 4000 bytes of data to both LOB and LONG columns in the same insert or update statement. You can bind more than 4000 bytes of data to either a LONG column or one or more LOB columns but not both.
Action: Bind more than 4000 bytes of data to either the LONG column or one or more LOB columns but not both.
ORA-22296: invalid ALTER TABLE option for conversion of LONG datatype to LOB
Cause: An attempt was made to specify ALTER TABLE options which are disallowed during conversion of LONG datatype to LOB. The only ALTER TABLE options allowed during conversion of LONG datatype to LOB are the default clause and LOB storage clause for the column being converted to LOB.
Action: Remove the disallowed options.
ORA-22297: warning: Open LOBs exist at transaction commit time
Action: This is just a warning. The transaction was commited successfully, but any domain or functional indexes on the open LOBs were not updated. You may want to rebuild those indexes.
ORA-22298: length of directory alias name or file name too long
Cause: The length of directory alias name or file name given for a BFILE is too long.
Action: Use a shorter alias or file name.
ORA-22303: type "string"."string" not found
Cause: The user is trying to obtain information for a type that cannot be found.
Action: Check that the schema is correct and that the type has been created correctly.
ORA-22304: input type is not an object type
Cause: The user is trying to obtain the supertype information for a non-object type.
Action: Pass in only an object type.
ORA-22305: attribute/method/parameter "string" not found
Cause: Type element with the given name is not found in the type.
Action: Check to make sure that the type element exists.
ORA-22306: type "string"."string" already exists
Cause: The user is trying to create a type that already exists.
Action: Check to make sure that the type has not been created prior to this.
ORA-22307: operation must be on a user-defined type
Cause: attempt to perform an operation that is allowed only on a user-defined type, and the type is not a user-defined type.
Action: Check to make sure that only user-defined types are being operated on.
ORA-22308: operation not allowed on evolved type
Cause: An attempt was made to replace a type whose attribute definition been been altered.
Action: Submit ALTER TYPE ADD/DROP statement instead of ALTER TYPE REPLACE.
ORA-22309: attribute with name "string" already exists
Cause: The user is attempting to create an object type where more than one attributes have the same name.
Action: Check to make sure that all attribute names are unique.
ORA-22310: ALTER TYPE error. Refer to table "string"."string" for errors
Cause: An invalid alter type statement was submitted.
Action: Correct the errors listed in specified table and resubmit statement.
ORA-22311: type for attribute "string" does not exist
Cause: The type of the attribute does not exist.
Action: No types were created/modified for this DDL transaction. Redo the DDL transaction and add the creation of the attribute's type in the DDL transaction.
ORA-22312: must specify either CASCADE or INVALIDATE option
Cause: An attempt was made to alter a type which has a dependent type or table without specifying the CASCADE or INVALIDATE option.
Action: Resubmit the statement with either the CASCADE or INVALIDATE option. Specify CASCADE if you want to cascade the type change to dependent types and tables; otherwise, specify INVALIDATE to invalidate all dependents.
ORA-22313: cannot use two versions of the same type "string"
Cause: The version of this type conflicts with the version of this type used by another library that was linked in with the application. An application may only use one version of a type.
Action: Check that the libraries being linked with this application and use the same versions of the type.
ORA-22314: method information mismatch in ALTER TYPE
Cause: The number of methods or the method signature do not match that of the original type declaration. This is not supported.
Action: Make sure the method signature stay identical for the previously declared method. Do not drop existing methods.
ORA-22315: type "string" does not contain a map or order function
Cause: The input type does not contain a map or order function so one cannot be returned.
Action: Add a map or order function to the type or catch this error.
ORA-22316: input type is not a collection type
Cause: The user is trying to obtain information for collection types on a non-named collection type.
Action: Use a named collection type for the function.
ORA-22317: typecode string is not legal as a number type
Cause: The user is trying to use a number typecode that is not valid.
Action: Use only OCI_TYPECODE_SMALLINT, OCI_TYPECODE_INTEGER, OCI_TYPECODE_REAL, OCI_TYPECODE_DOUBLE, OCI_TYPECODE_FLOAT, OCI_TYPECODE_NUMBER, or OCI_TYPECODE_DECIMAL.
ORA-22318: input type is not an array type
Cause: The user is trying to obtain the number of elements for a non-array type.
Action: Pass in only a named collection type which is an array.
ORA-22319: type attribute information altered in ALTER TYPE
Cause: The type attribute information does not match that of the original type declaration when altering type. Attributes cannot be altered during ALTER TYPE. Only new methods can be added.
Action: Check that all type alterations are legal.
ORA-22320: missing user version string
Cause: The VERSION option is specified without a user version string.
Action: Resubmit the statement with the version string following the VERSION keyword.
ORA-22321: method does not return any result
Cause: OCITypeResult() was called on a method that does not return any results.
Action: Check that you are passing in the correct method descriptor, or that your method creation was done correctly.
ORA-22322: error table "string"."string" has incorrect structure
Cause: The specified error table does not have the expected table structure.
Action: Execute the DBMS_UTILITY.CREATE_ALTER_TYPE_ERROR_TABLE procedure to create an error table, then resubmit the statement using the new error table.
ORA-22323: error table "string"."string" does not exist
Cause: The error table does not exist.
Action: Resubmit the statement with a correct error table name.
ORA-22324: altered type has compilation errors
Cause: The use of the ALTER TYPE statement caused a compilation error.
Action: Correct the error reported and resubmit the statement.
ORA-22325: event for create type with user version string
ORA-22326: cannot change a type to FINAL if it has subtypes
Cause: An attempt was made to change a type with subtypes to FINAL.
Action: Drop all subtypes of the target type before changing it to FINAL.
ORA-22327: cannot change a type to NOT INSTANTIABLE if it has dependent tables
Cause: An attempt was made to change a type with dependent tables to NOT INSTANTIABLE.
Action: Drop all dependent tables of the target type and resubmit the statement.
ORA-22328: object "string"."string" has errors.\nstring
Cause: Altering the target type causes errors in its dependent object.
Action: Correct the problem in the dependent object and resubmit the statement.
ORA-22329: cannot alter a non-object type
Cause: An attempt was made to execute ALTER TYPE on a non-object type.
Action: Drop the non-object type first, then re-create it as an object type.
ORA-22330: cannot alter a type that is not valid
Cause: An attempt was made to perform ALTER TYPE on an invalid type.
Action: Use the CREATE OR REPLACE TYPE command to modify the type.
ORA-22331: cannot alter an incomplete type
Cause: An attempt was made to perform ALTER TYPE on an incomplete type.
Action: Use CREATE TYPE to completely define the original type before executing the ALTER TYPE.
ORA-22332: a dependent object in schema "string" has errors.\nstring
ORA-22333: cannot reset type "string"."string" due to invalid dependent types and tables
Cause: An attempt was made to reset the type version with invalid dependent types and tables.
Action: Use the ALTER TYPE COMPILE statement to compile all invalid dependent types and use the ALTER TABLE UPGRADE INCLUDING DATA to upgrade all the dependent tables then resubmit the statement.
ORA-22334: cannot reset type "string"."string". Dependent tables must be upgraded to latest version
Cause: An attempt was made to reset the type version when the data in the dependent table has not been upgraded to the latest type version.
Action: Use the ALTER TABLE UPGRADE INCLUDING DATA statement to upgrade the data in the dependent tables then resubmit the statement.
ORA-22335: The client cannot work with an altered type
Cause: A pre 8.2 client has requested a type that has been altered on the server.
Action: Only 8.2 or higher clients could access altered types
ORA-22336: table contained 8.0 image format, must specify INCLUDING DATA
Cause: One of the following: 1) An attempt was made to alter a type with a dependent table in 8.0 image format and the NOT INCLUDING TABLE DATA option was specified. 2) An attempt was made to upgrade a table in 8.0 image format with the NOT INCLUDING DATA option specified.
Action: Resubmit the statement with INCLUDING DATA option.
ORA-22337: the type of accessed object has been evolved
Cause: The type of the accessed object has been altered and the client's object is based on an earlier type definition.
Action: The user needs to exit application and modify application to accommodate the type change. From SQL/PLUS, reconnect and resubmit statement.
ORA-22338: must specify CASCADE INCLUDING DATA when altering the final property
Cause: An attempt was made to alter the final property of a type with dependent table(s) without specifying the CASCADE INCLUDING DATA . option.
Action: Resubmit the statement with the CASCADE INCLUDING DATA option.
ORA-22339: cannot alter to not final since its attribute column is substitutable
Cause: An attempt was made to alter a type to not final when its embedded attribute is defined as substitutable in some tables. Note, this is a restriction in 9.0 version because when a type is altered to not final, column of that type is set to not substitutable at all levels; thus, it is an error if one of its embedded attribute column is already marked substitutable.
Action: Recreate the table and specify NOT SUBSTITUTABLE AT ALL LEVELS for all columns of non final type. Then resubmit the ALTER TYPE statement.
ORA-22340: cannot string type "string"."string". Dependent tables must be upgraded to latest version
Cause: An attempt was made to reset the version, drop or alter a type when the data in dependent table has not been upgraded to the latest version.
ORA-22341: cannot assign supertype instance to subtype
Cause: An attempt was made to assign or copy a supertype instance to a container (destination) that can only hold a subtype instance.
Action: Make sure the runtime type of the source of the assignment or copy is the same type as the destination or is a subtype of the destination type
ORA-22342: dependent VARRAY column exceeds the maximum inline column size
Cause: An attempt was made to alter a type (add or modify attribute) which causes the size of its dependent VARRAY column to exceed the maximum inline column size. However, the VARRAY column was not specified to be stored as LOB at the table level when the table was created.
Action: Specify the VARRAY column to be stored as LOB at the table level when the table is created.
ORA-22343: Compilation error for type invalidated by ALTER TYPE
Cause: Compilation failed for a type which was invalidated by ALTER TYPE. We throw this error and rollback the compilation effort so that the user may be able to fix whatever is causing the compilation error and try again. It is important that we do not chnage status here and modify the dependency information as this will affect the creation of versions.
Action: Check what is causing teh compilation error and correct it and try again.
ORA-22344: can not specify CONVERT TO SUBSTITUTABLE option for ALTER TYPE other than NOT FINAL change
Cause: An attempt was made to specify CONVERT TO SUBSTITUTABLE option for ALTER TYPE other than NOT FINAL change.
Action: Specify CONVERT TO SUBSTITUTABLE option only for ALTER TYPE NOT FINAL change.
ORA-22345: recompile type string.string before attempting this operation
Cause: An attempt was made to perform an operation which requires the specified datatype to be valid, but the datatype is invalid
Action: Recompile the specified type and retry the operation
ORA-22346: Type has cyclical dependency. Should use CASCADE option
Cause: An attempt was made to alter a type which has a cyclical dependency, with invalidate option.
Action: Give CASCADE option instead of INVALIDATE
ORA-22347: No changes to type specified for ALTER TYPE
Cause: The ALTER TYPE does not contain any changes to the type.
Action: If any change is required for the type, modify the ALTER TYPE to specify the change. Else no need for the ALTER.
ORA-22348: The object type DDL is not supported in Editioned schema
Cause: The object type DDL was not supported in an Editioned schema.
Action: Do not perform this DDL on an Editioned schema object.
ORA-22349: This version of the Oracle server does not support PL/SQL package type descriptions.
Cause: An attempt was made to get PL/SQL package type description information from a version of the Oracle server that does not support the description of PL/SQL package types.
Action: Do not attempt to describe package types on this Oracle server.
ORA-22350: Incomplete opaque type cannot be used here
Cause: An incomplete SYS.AnyType or SYS.AnyData or SYS.AnyDataSet is being used inappropriately.
Action: Check the documentation for correct usage.
ORA-22351: OCI API is not supported by this version of the Oracle server.
Cause: An attempt was made to call an Oracle Call Interface (OCI) API which is not supported by this version of the Oracle server.
Action: Do not call the unsupported OCI API when connected to this Oracle server.
ORA-22352: Type is unsupported or contains an unsupported attribute or element.
Cause: A PL/SQL package type was not supported on the client or contained an attribute or element that was not supported on the client. Unsupported types include index by VARCHAR2 collections, remote types and MLSLABELs.
Action: Do not attempt to use unsupported PL/SQL package types or types that contain unsupported attributes or elements on the client.
ORA-22369: invalid parameter encountered in method string
Cause: An invalid parameter is being passed to this method of SYS.AnyType ,SYS.AnyData or SYS.AnyDataSet
Action: Check the parameters being passed to this method and make sure that the parameters are allowed.
ORA-22370: incorrect usage of method string
Cause: This method of SYS.AnyType or SYS.AnyData or SYS.AnyDataSet is being used inappropriately.
ORA-22371: Table contains data of type string.string, version string, which does not exist
Cause: Some of the older versions of the type may have got deleted because one or more of the types it were referencing was dropped.
Action: These data could not be read as the whole ADT. Read the data at individual scalar attribute level.
ORA-22372: Event for type dictionary upgrade
Cause: This is an internally used event for type dictionary upgrades from 8.0 to 8.1.
Action: None
ORA-22373: Older version hashcode encountered
Cause: An older version HC is encountered when creating a new version hahscode. Currently this is handled internally.
Action: None
ORA-22374: cannot reset the version of a type with table dependents
Cause: The type for which reset version was requested has table dependents.
Action: None
ORA-22375: Event to check for subtypes in complete type tree
Cause: This event is used to check for subtypes in complete type tree without any restriction on depth in the fix for bug# 12430142.
Action: None
ORA-22376: Event to keep old behavior for type public synonyms
Cause: A public type synonym was qualified with a schema which may lead to incorrect name resolution. This issue has been resolved. However, this event allows you to use the old behavior if desired.
Action: None
ORA-22377: Unpacking of ANYDATA columns is not supported for attribute columns.
Cause: An attribute column has been referenced in the 'modify_opaque_type' clause.
Action: Do not use an attribute column in the 'modify_opaque_type' clause.
ORA-22378: cannot add, drop or modify attributes of a type with synonym dependents defined on FINAL types
Cause: An attempt to ALTER TYPE [ADD | DROP | MODIFY] ATTRIBUTE on a type with synonym dependents defined on a FINAL type, which has table dependents, failed.
Action: None
ORA-22379: event to bypass hashcode in kottyphcequ
Cause: This event is used to bypass the error "ORA-39779" during the import of table data which occurs because of the mismatch in the hashcodes of a user-defined type between the source and the target databases. The event has to be used when the source database has an improper hashcode for the user-defined type.
Action: None
ORA-22380: event to skip updating the dependencies
Cause: This event is used to bypass regenerating dependencies during upgrade while running ALTER TABLE MOVE on type dictionary tables to enable storage in row. This happens on the upgrade path from 10.1.
Action: None
ORA-22600: encountered 8.0.2 (Beta) VARRAY data that cannot be processed
Cause: Production Oracle8 (8.0.3 and beyond) encounters some VARRAY data which was created and stored by Oracle8 8.0.2 (Beta 2). Production Oracle8 cannot understand or process such VARRAY data.
Action: Delete the VARRAY data from the table by dropping the table, deleting the rows, or nulling out the VARRAY columns, and then re-insert the VARRAY data. There is no provided script or tool to help automate this conversion.
ORA-22601: pickler TDS context [string] is not initialized
Cause: Attempt to use the pickler TDS context without initializing it.
Action: Use OCIPicklerTdsCtxInit to initialize the context.
ORA-22602: pickler TDS handle [string] is not well-formed
Cause: Attempt to use the pickler TDS handle without initializing/ constructing it.
Action: Use OCIPicklerTdsInit to initialize the handle before it is constructed. Use OCIPicklerTdsGenerate to generate the TDS before its attributes can be accessed.
ORA-22603: cannot add an attribute to the already generated TDS handle
Cause: Attempt to add an attribute to the already constructed TDS.
Action: Use a TDS handle that is initialized but not yet constructed.
ORA-22604: TDS handle already generated
Cause: Attempt to geneate TDS that is already genearated.
Action: Use a TDS handle that is initialized but not yet generated.
ORA-22605: FDO handle [string] is not initialized
Cause: Attempt to use an uninitialized FDO handle.
Action: Use OCIPicklerFdoInit to initialize FDO handle".
ORA-22606: pickler image handle [string] is not well-formed
Cause: Attempt to use the image handle without initializing/ constructing it.
Action: Use OCIPicklerImageInit to initialize the handle before it is constructed. Use OCIPicklerImageGenerate to generate the image before its attributes can be accessed.
ORA-22607: image handle already generated
Cause: Attempt to geneate image that is already genearated.
Action: Use a image handle that is initialized but not yet generated.
ORA-22608: cannot add an attribute to the already generated image handle
Cause: Attempt to add an attribute to the already constructed image.
Action: Use a image handle that is initialized but not yet constructed.
ORA-22609: error string during initialization of FDO
Cause: Error during FDO initialization.
Action: Take an action based on the specified error.
ORA-22610: error while adding a scalar to the image handle
Cause: Error while adding a scalar attribute to the image handle
Action: Make sure image handle is initialized before adding scalar
ORA-22611: TDS version is not recognized
Cause: Incorrect TDS handle is passed
Action: Make sure image handle is initialized with the correct TDS
ORA-22612: TDS does not describe a collection TDS
Cause: collection construct/access routines are being on an image but the TDS does not describe that a collection TDS
Action: Make sure a collection TDS is used before invoking collection routines on the image handle
ORA-22613: buflen does not match the size of the scalar
Cause: buflen is incorrect
Action: Make sure buflen is correct and matches the size of the scalar
ORA-22614: error while construction the collection in the image
Cause: Error during the construction of collection
Action: Make sure image handle is initialized and OCIPicklerImageCollBegin is called to begin collection
ORA-22615: attribute is not a collection
Cause: collection routine is invoked upon a non-collection attribute
Action: Make sure attribute is a collection
ORA-22616: image is not of Oracle 8.1 format
Cause: The function being invoked is applicable only for 8.1 images
Action: Make sure image is of 8.1 format
ORA-22617: error while accessing the image handle collection
Cause: Error while accessing collection in the image handle
Action: Make sure image is initialized correctly and the collection is constructed properly.
ORA-22618: attribute is a BAD NULL in the image handle
Cause: attribute in question is probably the attribute of a null embedded image
Action: Make sure attribute number is valid or it is NULL or NOT NULL.
ORA-22619: all collection elements have already been accessed
Cause: Accessing a collection element after all the collection elements are already accessed
Action: This function should not be invoked any more.
ORA-22620: buffer size too small to hold the value
Cause: Buffer size is not enough to hold the value. Most likely while doing the character set conversion, a bigger buffer is needed.
Action: Pass in a bigger buffer. If the client character set format differs from that of server, doing the conversion may result in 4X expansion.
ORA-22621: error transfering an object from the agent
Cause: Any error returned from pickler routines on the agent side.
Action: Contact Oracle Support.
ORA-22625: OCIAnyData is not well-formed
Cause: Attempt to use the OCIAnyData without initializing constructing it.
Action: Use OCIAnyDataBeginConstruct to initialize the handle before it is adding attributes. Use OCIAnyDataEndConstruct to complete the construction. Or use OCIAnyDataConvert to do the construction. MAke sure it is properly constructed before accessing attributes.
ORA-22626: Type Mismatch while constructing or accessing OCIAnyData
Cause: Type supplied is not matching the type of the AnyData. If piece wise construction or access is being attempted, the type supplied is not matching the type of the current attribute.
Action: Make sure the type supplied matches the type of object to to be constucted or accessed.
ORA-22627: tc [string] must be that of object/varray/nested table
Cause: Type code is not that of object/varray/nested table
Action: Make sure the type code is OCI_TYPECODE_OBJECT or OCI_TYPECODE_VARRAY or OCI_TYPECODE_TABLE
ORA-22628: OCIAnyData already constructed
Cause: Attempt to add attributes to OCIAnyData that is already constructed.
Action: Use the OCIAnyData that is initialized but not yet constructed.
ORA-22629: OCIAnyData is null
Cause: Attempting an operation that is not valid on null OCIAnyData
Action: Make sure OCIAnyData is not null.
ORA-22630: attribute [string] is null or it is not well-formed
Cause: Passing an attribute that is null or not well-formed
Action: Make sure the attribute is not null or is well-formed.
ORA-22631: attribute [string] is is not well-formed or does not match the type
Cause: Passing an attribute that is not well-formed or does not match the input type.
Action: Make sure the attribute is well-formed and matches the type specified.
ORA-22632: AnyDataSet parameter is not valid for the current operation
Cause: The AnyDataSet parameter is null or it is somehow invalid for the current operation.
Action: Check the documentation for the current operation.
ORA-22633: Error freeing AnyDataSet
Cause: AnyDataSet that is passed in may not be valid.
Action: Check all the AnyDataSet parameters.
ORA-22634: Error adding new instance to AnyDataSet
Cause: Current instance in the AnyDataSet has not been fully constructed.
Action: Make sure that the current instance is fully constructed before adding new instance.
ORA-22635: time stamp with time zone type not supported
Cause: OCIAnyData did not support conversion of time stamp with time zone when the version of time zone files differ.
Action: Use same version of time zone files.
ORA-22800: invalid user-defined type
Cause: An attempt was made to use an incomplete type as a constructor.
Action: Complete the type definition before using it in a query.
ORA-22801: invalid object row variable
Cause: The specified object row variable is not available in the scope of name resolution.
Action: Verify the specified object row variable is correct, or use an object row variable visible in scope.
ORA-22802: remote implementation type not supported
Cause: Remote type reference was not supported with user-defined aggregate function.
Action: Use local implementation type with user-defined aggregate function.
ORA-22803: object type contains zero attributes
Cause: An attempt was made to create or specify a column or constructor of an object type that has no attributes. Only object types that have at least one attribute are allowed in this context.
Action: specify a valid object type
ORA-22804: remote operations not permitted on object tables or user-defined type columns
Cause: An attempt was made to perform queries or DML operations on remote object tables or on remote table columns whose type is one of object, REF, nested table or VARRAY.
Action: n/a
ORA-22805: cannot insert NULL object into object tables or nested tables
Cause: An attempt was made to insert a NULL object into an object table or a Nested Table.
Action: Ensure that a non-NULL object is inserted into the table or insert an object with attributes whose values are NULL.
ORA-22806: not an object or REF
Cause: An attempt was made to extract an attribute from an item that is neither an object nor a REF.
Action: Use an object type or REF type item and retry the operation.
ORA-22807: cannot resolve to a scalar type or a collection type
Cause: Invalid use of a non-scalar (for example, object type) item.
Action: Change the item's data type and retry the operation.
ORA-22808: REF dereferencing not allowed
Cause: An attempt was made to access an object type's attributes by dereferencing a REF item.
Action: Make the item an object type instead of a REF to an object type.
ORA-22809: nonexistent attribute
Cause: An attempt was made to access a non-existent attribute of an object type.
Action: Check the attribute reference to see if it is valid. Then retry the operation.
ORA-22810: cannot modify object attributes with REF dereferencing
Cause: An attempt was made to modify the attributes an object by dereferencing a REF column in an UPDATE statement.
Action: Update the table containing the object that the REF points to, or change the REF column to an object type column.
ORA-22812: cannot reference nested table column's storage table
Cause: An attempt to access the nested table column's storage table is not allowed in the given context.
Action: Issue the statement against the parent table containing the nested table column.
ORA-22813: operand value exceeds system limits
Cause: Object or Collection value was too large. The size of the value might have exceeded 30k in a SORT context, or the size might be too big for available memory.
Action: Choose another value and retry the operation.
ORA-22814: attribute or element value is larger than specified in type
Cause: Value provided for the object type attribute or collection element exceeded the size specified in the type declaration.
ORA-22816: unsupported feature with RETURNING clause
Cause: RETURNING clause is currently not supported for object type columns, LONG columns, remote tables, INSERT with subquery, and INSTEAD OF Triggers.
Action: Use separate select statement to get the values.
ORA-22817: subquery not allowed in the default clause
Cause: An attempt was made to use a subquery in the column default clause expression.
Action: Remove the subquery from the default clause.
ORA-22818: subquery expressions not allowed here
Cause: An attempt was made to use a subquery expression where these are not supported.
Action: Rewrite the statement without the subquery expression.
ORA-22819: scope of input value does not correspond to the scope of the target
Cause: An attempt to operate on a REF value scoped to a different table than the expected one
Action: Use a ref which is scoped to the expected table and retry the operation
ORA-22826: cannot construct an instance of a non instantiable type
Cause: An attempt was made to use a non instantiable type as a constructor.
Action: None
ORA-22828: input pattern or replacement parameters exceed 32K size limit
Cause: Value provided for the pattern or replacement string in the form of VARCHAR2 or CLOB for LOB SQL functions exceeded the 32K size limit.
Action: Use a shorter pattern or process a long pattern string in multiple passes.
ORA-22833: Must cast a transient type to a persistent type
Cause: An attempt was made to use the transient type in the query result.
Action: Cast the transient type to a structurally equivalent persistent type.
ORA-22835: Buffer too small for CLOB to CHAR or BLOB to RAW conversion (actual: string, maximum: string)
Cause: An attempt was made to convert CLOB to CHAR or BLOB to RAW, where the LOB size was bigger than the buffer limit for CHAR and RAW types. Note that widths are reported in characters if character length semantics are in effect for the column, otherwise widths are reported in bytes.
Action: Do one of the following: 1. Make the LOB smaller before performing the conversion, for example, by using SUBSTR on CLOB 2. Use DBMS_LOB.SUBSTR to convert CLOB to CHAR or BLOB to RAW.
ORA-22837: Relational hint or keyword is disallowed for user-level DML
Cause: An attempt was made to use relational hint or keyword in user- level DML.
Action: Avoid using DML with relational hint or keyword.
ORA-22839: Direct updates on SYS_NC columns are disallowed
Cause: An attempt was made to update SYS_NC columns directly.
Action: Avoid direct updates on SYS_NC columns.
ORA-22850: duplicate LOB storage option specificed
Cause: A LOB storage option (CHUNK, PCTVERSION, CACHE, NOCACHE, TABLESPACE, STORAGE, INDEX, SECUREFULE/BASICFILE, [A]SYNC) was specified more than once.
Action: Specify all LOB storage options only once.
ORA-22851: invalid CHUNK LOB storage option value
Cause: The specified CHUNK LOB storage option value must be an integer.
Action: Choose an appropriate integer value and retry the operation.
ORA-22852: invalid PCTVERSION LOB storage option value
Cause: The specified PCTVERSION LOB storage option value must be an integer.
ORA-22853: invalid LOB storage option specification
Cause: A LOB storage option was not specified
Action: Specify one of CHUNK, PCTVERSION, CACHE, NOCACHE, TABLESPACE, STORAGE, INDEX, [A]SYNC or DATA SYNC as part of the LOB storage clause.
ORA-22854: invalid option for LOB storage index
Cause: A valid LOB store index option was not specified.
Action: Specify one of (INITRANS, MAXTRANS, TABLESPACE, STORAGE) as part of the LOB storage index.
ORA-22855: optional name for LOB storage segment incorrectly specified
Cause: The optional name for LOB storage segment was specified with multiple columns in the column list.
Action: Specify each column LOB storage only with optional name(s).
ORA-22856: cannot add columns to object tables
Cause: An attempt was made to add columns to an object table. Object tables cannot be altered to add columns since its definition is based on an object type.
Action: Create a new type with additional attributes, and use the new type to create an object table. The new object table will have the desired columns.
ORA-22857: cannot modify columns of object tables
Cause: An attempt was made to alter the object table by modifing existing columns. An object table cannot be altered to modify existing columns since it is based on an object type. The table definition must be in sync with the corresponding type.
Action: Create a new type with the desired attribute types and use it to create an object table. The new object table will have the desired columns.
ORA-22858: invalid alteration of datatype
Cause: An attempt was made to modify the column type to object, REF, nested table, VARRAY or LOB type.
Action: Create a new column of the desired type and copy the current column data to the new type using the appropriate type constructor.
ORA-22859: invalid modification of columns
Cause: An attempt was made to modify an object, REF, VARRAY, nested table, or LOB column type.
ORA-22860: object type expected
Cause: An attempt was made to create an object table using a non- object type, or to create a column that is a REF to a non-object type.
Action: Use a valid object type in the table or column definition.
ORA-22861: invalid user-defined type
Cause: An attempt was made to create a column or object table of a non- existent type.
Action: Specify a valid type in the table or column definition.
ORA-22862: specified object identifier doesn't match existing object identifier
Cause: An attempt was made to specify an object identifier for the type that does not match the existing identifier of the incomplete type of the same name.
Action: Specify the correct object identifier or leave it out of the statement.
ORA-22863: synonym for datatype string.string not allowed
Cause: A synonym specification for a datatype is not supported
Action: do not use the synonym for the datatype
ORA-22864: cannot ALTER or DROP LOB indexes
Cause: An attempt was made to ALTER or DROP a LOB index.
Action: Do not operate directly on the system-defined LOB index. Perform operations on the corresponding LOB column.
ORA-22865: more than one column specified
Cause: An attempt was made to specify multiple columns where only one is allowed.
Action: Specify a single column and retry the operation.
ORA-22866: cannot replace a type with table dependents
Cause: An attempt was made to replace a type that has table dependents.
Action: Drop all table(s) depending on the type, then retry the operation.
ORA-22868: table with LOBs contains segments in different tablespaces
Cause: An attempt was made to drop a tablespace which contains the segment(s) for the LOB columns of a table but does not contain the table segment.
Action: Find table(s) with LOB columns which have non-table segments in this tablespace. Drop these tables and reissue drop tablespace.
ORA-22869: depth of type dependency hierarchy exceeds maximum limit
Cause: The type dependency hierarchy was structured to have depth greater than 1024.
Action: Re-structure the type dependency hierarchy to a shorter depth.
ORA-22870: ALTER TYPE with REPLACE option a non-object type
Cause: attempt to perform ALTER TYPE with REPLACE option a non-object type
Action: drop the non-object type first, then re-create it as an object type
ORA-22871: ALTER TYPE with REPLACE is not allowed for pure incomplete types
Cause: An attempt to perform ALTER TYPE with REPLACE option for a pure incomplete type
Action: Completely define the original type, before using the ALTER TYPE with REPLACE option.
ORA-22872: OID INDEX clause not allowed on tables with primary key based object identifiers
Cause: An attempt to create an OID INDEX on a table with primary key based object identifiers.
Action: Remove the OID INDEX clause
ORA-22873: primary key not specified for primary key based object table
Cause: An attempt to create a primary key based object table without specifying a primary key
Action: Specify a primary key and retry the operation
ORA-22874: attribute "string" is not part of the type "string"
Cause: Attribute specified in the user_defined clause is not an attribute of the REF type
Action: Ensure that the name specified in the user_defined clause is the name of a valid attribute of the REF type
ORA-22875: cannot drop primary key of an object table whose object identifier is primary key based
Cause: An attempt to drop the primary key of an object table which has a primary key based object identifier
Action: Remove the drop primary key clause
ORA-22876: this user-defined type is not allowed or it cannot be used in this context
Cause: An attempt to create a kind of user-defined type which is not allowed, or an attempt to create table columns or use default constructor with a type on which these are not supported.
Action: Ensure that the type is permitted in this context.
ORA-22877: invalid option specified for a HASH partition or subpartition of a LOB column
Cause: One or more invalid options were encountered while parsing the physical attributes of a LOB partition or subpartition. Either the LOB partition is in a table partitioned using the HASH method, or the LOB subpartition is in a table subpartitioned using the HASH method. TABLESPACE is the only valid option for a HASH partition or subpartition.
Action: Remove the invalid option(s).
ORA-22878: duplicate LOB partition or subpartition specified
Cause: An attempt was made to specify a partition or subpartition that has already been specified for the LOB column.
Action: Remove the duplicate specification.
ORA-22879: cannot use the LOB INDEX clause for partitioned tables
Cause: An attempt was made to specify a LOB INDEX clause in a CREATE TABLE or ALTER TABLE statement for a partitioned table.
Action: Remove the LOB INDEX clause.
ORA-22880: invalid REF
Cause: An invalid REF was accessed.
Action: Modify the REF and retry the operation.
ORA-22881: dangling REF
Cause: The object corresponding to the REF that was accessed does not exist.
Action: Ensure that the REF value is pointing to an existing object.
ORA-22882: object creation failed
Cause: The object cannot be created in the database.
Action: Check to see if the object table exists and the object size is not too big. Then retry the operation.
ORA-22883: object deletion failed
Cause: The object could not be deleted from the database.
Action: Check to see if the object table exists.Then retry the operation.
ORA-22884: object modification failed
Cause: The object could not be modified in the database.
ORA-22885: cannot get REF to a non-persistent object
Cause: An attempt was made to get a REF for something other than an object in an object table. REFs can only be taken for objects in object tables.
Action: Rewrite the query to obtain REF values from object tables.
ORA-22886: scoped table "string" in schema "string" is not an object table
Cause: The scoped table specified for a REF column is not an object table.
Action: Ensure that the scoped table is an object table.Then retry the operation.
ORA-22887: type of REF column is not the same as that of its scoped table
Cause: The type specified for the REF column and the type specified for the scope table are different.
Action: Ensure that the types of a REF column and its scoped table are the same.
ORA-22888: duplicate SCOPE clauses for a REF column
Cause: Multiple SCOPE clauses were specified for a single REF column.
Action: Remove the duplicate SCOPE clauses and retry the operation.
ORA-22889: REF value does not point to scoped table
Cause: An attempt was made to insert a REF value that does not point to the scoped table.
Action: Ensure that the REF values point to the scoped table.
ORA-22890: cannot specify name for REF column constraint
Cause: An attempt was made to specify a constraint name for a constraint on a REF column.
Action: Remove the constraint name and retry the operation.
ORA-22891: cannot have multiple columns in REF constraint
Cause: An attempt was made to specify multiple columns in a single REF constraint.
Action: Specify separate constraints for each column and retry the operation.
ORA-22892: scoped table "string" does not exist in schema "string"
Cause: The scoped table specified for a REF column does not exist.
Action: Ensure that the scoped table exists and retry the operation.
ORA-22893: constraint can be specified only for REF columns
Cause: The constraint specified does not apply to non-REF columns.
Action: Remove the constraint and retry the operation.
ORA-22894: cannot add constraint on existing unscoped REF columns of non-empty tables
Cause: An attempt was made to add a constraint to existing unscoped REF columns of a table which contains one or more rows.
Action: Remove the constraint specification or add the constraint after emptying the table.
ORA-22895: referenced table "string" in schema "string" is not an object table
Cause: The referenced table specified for a REF column is not an object table.
Action: Ensure that the referenced table is an object table.Then retry the operation.
ORA-22896: cannot have both scope and referential constraint on REF column "string"
Cause: REF column has both a referential and a scope constraint. A referential constraint implies a scope constraint.
Action: Remove either the referential or scope constraint and then retry the operation.
ORA-22897: no scope clause specified for user-defined REF column "string"
Cause: User-defined REF column does not have a scope constraint.
Action: Specify a scope constraint for the user-defined REF column and retry the operation.
ORA-22898: existing scope clause on "string" points to a table other than the one mentioned in the referential constraint
Cause: Table mentioned in the referential integrity constraint is different from the scope table of the REF column.
Action: Specify the scope table of the REF column in the referential integrity constraint and then retry the operation.
ORA-22899: cannot specify both scope and rowid constraint on ref column
Cause: An attempt was made to specify both a scope and a rowid constraint on a REF column.
Action: Remove either the rowid or scope constraint and then retry the operation.
ORA-22900: the SELECT list item of THE subquery is not a collection type
Cause: The THE subquery must SELECT a nested table or VARRAY item.
Action: change the subquery to SELECT a nested table or VARRAY item.
ORA-22901: cannot compare VARRAY or LOB attributes of an object type
Cause: Comparison of VARRAY or LOB attributes of an object type was attempted in the absence of a MAP or ORDER method.
Action: Define a MAP or ORDER method for the object type.
ORA-22902: CURSOR expression not allowed
Cause: CURSOR on a subquery is allowed only in the top-level SELECT list of a query.
Action: n/a
ORA-22903: MULTISET expression not allowed
Cause: MULTISET expressions are allowed only inside a CAST to a nested table or VARRAY type.
Action: put the MULTISET(subquery) expression inside a CAST to a nested table or VARRAY type.
ORA-22904: invalid reference to a nested table column
Cause: invalid use of a nested table column
Action: remove invalid reference to the nested table column
ORA-22905: cannot access rows from a non-nested table item
Cause: attempt to access rows of an item whose type is not known at parse time or that is not of a nested table type
Action: use CAST to cast the item to a nested table type
ORA-22906: cannot perform DML on expression or on nested table view column
Cause: Attempted to perform a DML on an expression or on a nested table view column where a nested table column of a base table is expected.
Action: Only nested table column of a base table is allowed in the DML.
ORA-22907: invalid CAST to a type that is not a nested table or VARRAY
Cause: Attempted to CAST to a type that is not a nested table or VARRAY
Action: Re-specify CAST to a nested table or VARRAY type.
ORA-22908: reference to NULL table value
Cause: The evaluation of the THE subquery or nested table column resulted in a NULL value implying a NULL table instance. The THE subquery or nested table column must identify a single non-NULL table instance.
Action: Ensure that the evaluation of the THE subquery or nested table column results in a single non-null table instance. If happening in the context of an insert statement where the THE subquery is the target of an insert, then ensure that an empty nested table instance is created by updating the nested table column of the parent table's row specifying an empty nested table constructor.
ORA-22909: exceeded maximum VARRAY limit
Cause: The total number of elements used in VARRAY construction exceeds the specified VARRAY limit.
Action: Don't use the more than the specified limit of elements for VARRAY construction.
ORA-22910: cannot specify schema name for nested tables
Cause: Table name was qualified with schema name in the nested table column's (or attribute's) storage clause.
Action: Re-specify the nested table item's storage clause without the schema name qualification. By default, the storage table for the nested table item is created in the same schema as the containing table.
ORA-22911: duplicate storage specification for the nested table item
Cause: The storage clause is specified more than once for the NESTED TABLE column.
Action: Remove the duplicate storage specification.
ORA-22912: specified column or attribute is not a nested table type
Cause: The storage clause is specified for a column or attribute that is not a nested table column or attribute.
Action: Specify a valid nested table column or attribute.
ORA-22913: must specify table name for nested table column or attribute
Cause: The storage clause is not specified for a nested table column or attribute.
Action: Specify the nested table storage clause for the nested table column or attribute.
ORA-22914: DROP of nested tables not supported
Cause: Attempted to DROP a nested table.
Action: nested tables cannot be explicitly dropped. nested tables can only be dropped by dropping their containing parent table.
ORA-22915: cannot ALTER a nested table's storage table to ADD/MODIFY columns
Cause: An attempt was made to ADD or MODIFY columns of a nested table's storage table.
Action: Columns cannot be added or modified for a nested table's storage table. You must alter the parent table's nested table column to cause any such change.
ORA-22916: cannot do an exact FETCH on a query with Nested cursors
Cause: Exact FETCH on a query was specified which is not allowed if the query returns any cursors.
Action: Do not use an exact FETCH.
ORA-22917: use VARRAY to define the storage clause for this column or attribute
Cause: Not using VARRAY to define storage clause for VARRAY column or attribute.
Action: Specify VARRAY before the column storage clause and resubmit statement.
ORA-22918: specified column or attribute is not a VARRAY type
Cause: Attemp to define a VARRAY storage clause for a column or attribute which is not VARRAY type.
Action: Specify VARRAY storage clause for a VARRAY column or attribute.
ORA-22919: dangling REF error or lock object failed for no wait request
Cause: The error could be one of the following. The object corresponding to the REF does not exist or the object was locked by another user and the lock with nowait request failed.
Action: Ensure that the REF value is pointing to an existing object or issue a lock request without the nowait option.
ORA-22920: row containing the LOB value is not locked
Cause: The row containing the LOB value must be locked before updating the LOB value.
Action: Lock the row containing the LOB value before updating the LOB value.
ORA-22921: length of input buffer is smaller than amount requested
Cause: The buffer length is not big enough to hold the amount of data requested.
Action: Verify that the number of bytes/characters specified in the input amount parameter is not bigger than the number of bytes specified in the input buffer length parameter. Allocate more space for the input buffer if necessary.
ORA-22922: nonexistent LOB value
Cause: The LOB value associated with the input locator does not exist. The information in the locator does not refer to an existing LOB.
Action: Repopulate the locator by issuing a select statement and retry the operation.
ORA-22923: amount of data specified in streaming LOB write is 0
Cause: Trying to write LOB value via the streaming mechanism (i.e. unlimited write) but the input amount of data to stream was specified as 0. Thus, the user is trying to write 0 bytes to the LOB value.
Action: Write more than 0 bytes to the LOB value.
ORA-22924: snapshot too old
Cause: The version of the LOB value needed for the consistent read was already overwritten by another writer.
Action: Use a larger version pool.
ORA-22925: operation would exceed maximum size allowed for a LOB value
Cause: Trying to write too much data to the LOB value. LOB size is limited to 4 gigabytes.
Action: Either start writing at a smaller LOB offset or write less data to the LOB value.
ORA-22926: specified trim length is greater than current LOB value's length
Cause: The input length for which to trim the LOB value to is greater than the current length of the LOB value.
Action: May not need to trim the LOB value because it's already smaller than the trim length specified. Or, if trimming the LOB value really is required, use a smaller trim length.
ORA-22927: invalid LOB locator specified
Cause: There are several causes: (1) the LOB locator was never initialized; (2) the locator is for a BFILE and the routine expects a BLOB/CLOB/NCLOB locator; (3) the locator is for a BLOB/CLOB/NCLOB and the routine expects a BFILE locator; (4) trying to update the LOB in a trigger body -- LOBs in trigger bodies are read only.
Action: For (1), initialize the LOB locator by selecting into the locator variable or by setting the LOB locator to empty. For (2) and (3), pass the correct type of locator into the routine. For (4), remove the trigger body code that updates the LOB value.
ORA-22928: invalid privilege on directories
Cause: An attempt was made to grant or revoke an invalid privilege on a directory.
Action: Only CREATE, DELETE, READ, WRITE and EXECUTE privileges can be granted or revoked on directories. Do not grant or revoke other privileges.
ORA-22929: invalid or missing directory name
Cause: The required directory name is invalid or missing.
Action: Specify a valid name.
ORA-22930: directory does not exist
Cause: Attempt to access a directory that does not exist.
Action: Make sure the name is correct.
ORA-22933: cannot change object with type or table dependents
Cause: Attempt to replace, drop or rename an object with type or table dependents.
Action: Drop depending objects or use FORCE option if available.
ORA-22936: cannot replace a system predefined type
Cause: An attempt was made to replace a system predefined type.
Action: Use other names for newly created system types.
ORA-22950: cannot ORDER objects without MAP or ORDER method
Cause: an object type must have a MAP or ORDER method defined for all comparisons other than equality and inequality comparisons.
ORA-22951: NULL returned by ORDER method
Cause: ORDER method used to compare two object values returned NULL which is not allowed.
Action: Redefine the ORDER method to not return a NULL.
ORA-22952: Nested Table equality requires a map method on the element ADT
Cause: Nested Table equality was tried where the element ADT did not have a map method defined on it.
Action: Define a map method on the element ADT..
ORA-22953: Cardinality of the input to powermultiset exceeds maximum allowed
Cause: The cardinality of the input nested table to the powermultiset should not exceed 32 elements
Action: Reduce the number of elements to the input.
ORA-22954: This multiset operation is not supported for this element type.
Cause: The multiset operation attempted was not supported for the nested table element type.
Action: Use a supported element type.
ORA-22955: The cardinality parameter is not within the allowed limits
Cause: The cardinality parameter has to be greater than 1 and less than or equal to the cardinality of the input.
Action: Give a valid cardinality value.
ORA-22956: The set contains no elements
Cause: An empty set was given as input to the powermultiset function.
Action: Give a non-empty set as input
ORA-22957: NULL is an invalid input to powermultiset and COLLECT functions
Cause: NULL was given as input to the powermultiset or COLLECT function.
Action: Give a non-null value as input
ORA-22958: This operation is not allowed in check constraints or triggers
Cause: An invalid operation is used in a check constraint or trigger
Action: Do not use the operation
ORA-22970: name does not correspond to an object view
Cause: Either the expression is not a view name or the name specified does not correspond to an object view.
Action: Replace the expression with the name of an object view.
ORA-22971: invalid datatype for PRIMARY KEY-based object identifier
Cause: When creating an object view, the datatype of an expression in the WITH OBJECT OID clause is not allowed for PRIMARY KEY-based OID.
Action: Replace the expression with one of appropriate scalar datatype.
ORA-22972: NULL value not allowed in PRIMARY KEY-based object identifier
Cause: A value constituting the PRIMARY KEY-based object identifier is NULL.
Action: Ensure the expressions in MAKE_REF system function or attributes in the WITH OBJECT OID clause of an object view do not evaluate to NULL.
ORA-22973: size of object identifier exceeds maximum size allowed
Cause: Size of the PRIMARY KEY-based object identifier of an object view exceeds the maximum size of 4000 bytes.
Action: Specify fewer or smaller PRIMARY KEY attributes in the WITH object OID clause when creating the object view.
ORA-22974: missing WITH OBJECT OID clause
Cause: WITH OBJECT OID clause is not specified when creating an object view.
Action: Specify the WITH OBJECT OID clause.
ORA-22975: cannot create a PRIMARY KEY-based REF to this object view
Cause: The object view specified in the MAKE_REF function does not have a PRIMARY KEY-based object identifier. A PRIMARY KEY-based REF cannot be created for such a view.
Action: Specify an object view that has a PRIMARY KEY-based object identifier in the MAKE_REF function.
ORA-22976: incorrect number of arguments to MAKE_REF
Cause: Number of arguments for MAKE_REF is different from the number of PRIMARY KEY attributes of the object view.
Action: Specify all the necessary arguments for MAKE_REF.
ORA-22977: missing or invalid attribute
Cause: Either the attribute name is missing in the WITH OBJECT OID clause or it is invalid.
Action: Specify a valid attribute of the object type of the object view.
ORA-22978: only simple attribute name is allowed in the WITH OBJECT OID clause
Cause: Attempted to specify a Nested attribute in the WITH OBJECT OID clause.
Action: Specify a top-level attribute of the object type of the object view.
ORA-22979: cannot INSERT object view REF or user-defined REF
Cause: Attempt to insert an object view REF or user-defined REF in a REF column created to store system generated REF values"
Action: Make sure the REF to be inserted is not from an object view or from a user-defined REF column
ORA-22980: must specify a set of attributes for the WITH OBJECT OID clause
Cause: The WITH OBJECT OID DEFAULT clause was used, but the underlying view or table does not have a OID.
Action: Specify attributes for the WITH OBJECT OID clause to create a primary key based object identifier for the object view.
ORA-22981: must specify a table/view having system generated OID
Cause: The super-view is based on a table/view having the system generated OID and the sub-view must also be based on a similar table/view.
Action: Specify table/view having system generated OID and retry the the operation.
ORA-22982: cannot create sub-view under this view
Cause: The view derives its OID from a table/view having primary key based OID and sub-views cannot be created under such views.
Action: Specify view having system generated OID or a view created with the specification of attributes in the WITH OBJECT ID clause and retry the operation.
ORA-22983: not a user-defined REF
Cause: Attempt to use a system generated REF value where a user-defined REF value should be used.
Action: Make sure the REF value is user-defined.
ORA-22984: view query cannot contain references to a super view
Cause: The query defining the view contains references to a super-view of the view being created.
Action: Make sure that the view query does not reference a super-view.
ORA-22990: LOB locators cannot span transactions
Cause: A LOB locator selected in one transaction cannot be used in a different transaction.
Action: Re-select the LOB locator and retry the operation.
ORA-22991: insufficient space allocated for argument string
Cause: The data to be returned in the argument is greater than the amount of space allocated for the argument.
Action: Allocate more space for the argument.
ORA-22992: cannot use LOB locators selected from remote tables
Cause: A remote LOB column cannot be referenced.
Action: Remove references to LOBs in remote tables.
ORA-22993: specified input amount is greater than actual source amount
Cause: (1) For LOB write, the amount of data received is different from the amount that was indicated would be sent. (2) For LOB copy and loadfromfile, the end of the source LOB/FILE value was reached before the specified input amount was copied/loaded.
Action: (1) will happen when using OCI's piecewise mechanism with polling or with a callback function. Modify the code either to send the amount specified or to pass 0 as the input amount so that any amount of data can be sent. (2) will happen if the specified input amount is too large for the source LOB/FILE given the starting source offset. Either decrease the starting source offset, or decrease the amount to copy/load.
ORA-22994: source offset is beyond the end of the source LOB
Cause: The source offset for a LOB COPY or LOB LOADFROMFILE is beyond the end of the source LOB.
Action: Check the length of the LOB and then adjust the source offset.
ORA-22995: TABLESPACE DEFAULT option is invalid in this context
Cause: TABLESPACE DEFAULT option can be specified for LOB columns only in the following contexts: - at the table level for a partitioned table - at the partition level for a composite partition. An attempt was made to use the TABLESPACE DEFAULT option in a different context.
Action: Remove the TABLESPACE DEFAULT option.
ORA-22996: NEXT extent size is smaller than LOB chunksize
Cause: An attempt was made to create or alter a LOB segment so that its NEXT extent size was less than the LOB chunksize
Action: Specify a NEXT extent size that is greater than or equal to the LOB chunksize
ORA-22997: VARRAY | OPAQUE stored as LOB is not specified at the table level
Cause: An attempt was made to specify a VARRAY|OPAQUE column to be stored as LOB at the partition/subpartition/template level. However the VARRAY|OPAQUE column was not specified to be stored as LOB at the table level when the table was created.
Action: Specify the VARRAY | OPAQUE column to be stored as LOB at the table level when the table is created. Alternatively, do not specify the VARRAY | OPAQUE column to be stored as LOB at the partition/subpartition/template level if it is not specified at the table level when the table is created.
ORA-22998: CLOB or NCLOB in multibyte character set not supported
Cause: A CLOB or NCLOB in a fixed-width or varying-width multibyte character set was passed to a SQL character function which does not support multibyte LOB data.
Action: Use DBMS_LOB functions such as DBMS_LOB.INSTR() and DBMS_LOB.SUBSTR() or use PLSQL DBMS_LOB.READ/WRITE to access LOB data.
ORA-22999: CLOB or NCLOB data may have been corrupted
Cause: CLOB or NCLOB contains invalid character data. One possible cause is that the wrong csid was specified for the external file when calling DBMS_LOB.LOADCLOBFROMFILE or DBMS_XSLPROCESSOR.READ2CLOB to load CLOB or NCLOB data from external files.
Action: Reload the CLOB/NCLOB data with the correct csid specified for the external file.
ORA-23290: This operation may not be combined with any other operation
Cause: ALTER TABLE RENAME COLUMN/CONSTRAINT operation was given in conjunction with another ALTER TBALE Operation. This is not allowed.
Action: Ensure that RENAME COLUMN/CONSTRAINT is the only operation specified in the ALTER TABLE.
ORA-23291: Only base table columns may be renamed
Cause: Tried to rename a column of a non-base table, like object table/ nested table/ materialized view table.
Action: None. This is not allowed.
ORA-23292: The constraint does not exist
Cause: The given constraint name does not exist.
Action: Give an existing constraint's name.
ORA-23293: Cannot rename a column which is part of a join index
Cause: The column participates in a join index.
Action: If you need to rename the column, you need to drop the join index.
ORA-23300: string
Cause: The stored procedure 'raise_system_error' was called which causes this error to be generated.
Action: Correct the problem as described in the error message or contact the application administrator or DBA for more information.
ORA-23301: mixed use of deferred rpc destination modes
Cause: Replication catalog determined deferred RPC destinations were mixed with destination determined by other mechanisms in the same transaction.
Action: Do not mix destination types in the same transaction.
ORA-23302: application raised communication failure during deferred RPC
Cause: An application declared a communication failure during a defered RPC.
Action: Retry the application when communication is restored.
ORA-23303: application raised generic exception during deferred RPC
Cause: An application declared a generic failure during a defered RPC.
Action: Determined by the application
ORA-23304: malformed deferred rpc at arg string of string in call string, in tid string
Cause: A deferred RPC call was issued without the correct number of arguments as determined by the count parameter to dbms_defer.call
Action: Be sure the number of actuals matches the count.
ORA-23305: internal deferred RPC error: string
Cause: An internal error occurred in deferred rpc.
Action: Report the error and other information to support.
ORA-23306: schema string does not exist
Cause: The schema name was null or misspelled, or the schema does not exist locally.
Action: Specify the schema correctly, or create it with CREATE USER.
ORA-23307: replicated schema string already exists
Cause: The given database already replicates the given schema.
Action: Choose a different schema or a different database.
ORA-23308: object string.string does not exist or is invalid
Cause: The given name was null or misspelled, the given type was wrong, the object does not exist as a valid database object, or the object does not exist as a replicated object with the appropriate status.
Action: Ensure the object is valid in the database, is visible to the user, and, if appropriate, is a valid object in all_repobject.
ORA-23309: object string.string of type string exists
Cause: An object in the same namespace exists, perhaps with a different type or shape, or the same object has already been registered as an repobject in another object group.
Action: Remove the offending object with the SQL DROP command, unregister the offending object with dbms_repcat.drop_master_repobject(), or reinvoke the request using TRUE for a boolean parameter such as retry or use_existing_object.
ORA-23310: object group "string"."string" is not quiesced
Cause: The requested operation requires the object group to be suspended.
Action: Invoke suspend_master_activity at the repgroup's masterdef, wait until the status has changed to quiesced, and then retry the original request.
ORA-23312: not the masterdef according to string
Cause: The group name is null, the group name is misspelled, the invocation or given database is not the masterdef, or one of the masters does not believe the invocation database is the masterdef.
Action: If the given group name and masterdef were both correct, connect to the masterdef and retry the request, or relocate the masterdef at the (errant) databases using relocate_masterdef.
ORA-23313: object group "string"."string" is not mastered at string
Cause: The group name is null, the group name is misspelled, the invocation database is not a master, or the invocation database does not believe the given database is a master.
Action: If the given group name was correct, connect to a current master and retry the request, make the invocation database a master with add_master_database, or use switch_mview_master if the invocation database is a materialized view site.
ORA-23314: database is not a materialized view site for "string"."string"
Cause: The invocation database is not a materialized view database for the given object group.
Action: Connect to the desired materialized view database and retry the request, or make the invocation database a materialized view site with create_mview_repschema or create_mview_repgroup.
ORA-23315: repcatlog version or request string is not supported by version string
Cause: Either incompatible repcat versions are used, or a repcatlog record has been corrupted.
Action: Convert the master to a compatible version of repcat or retry the request.
ORA-23316: the masterdef is string
Cause: The requested operation is not permitted on a masterdef site.
Action: Relocate the masterdef to another master and retry the operation.
ORA-23317: a communication failure has occurred
Cause: The remote database is inaccessible.
Action: Ensure the remote database is running, the communications network is functioning, and the appropriate database links are present.
ORA-23318: a ddl failure has occurred
Cause: User-supplied or system-generated ddl did not execute successfully.
Action: Examine ddl, database state, repcatlog, and all_errors to determine why the failure occurred.
ORA-23319: parameter value string is not appropriate
Cause: The given value of a parameter is either null, misspelled, or not supported.
Action: Refer to the documentation and use parameter values that are appropriate for the given situation.
ORA-23320: the request failed because of values string and string
Cause: A missing ddl record for a repcatlog record, or inconsistency in repcat views.
Action: Retry the request, or make the views consistent.
ORA-23321: Pipename may not be null
Cause: You called dbms_pipe with a null pipe name.
Action: Find out the name of the pipe and call function with non-null pipename.
ORA-23322: Privilege error accessing pipe
Cause: You either tried to create a pipe that already existed and belonged to someone else, or remove a pipe that you were not authorized to use, or put a message into a pipe that you were not authorized for, or get a message from a pipe that you were not authorized for.
Action: You may have to use a different pipename.
ORA-23323: parameter length exceeds deferred RPC limits
Cause: A deferred rpc parameter was longer than the deferred rpc limits of 4000 bytes for char/varchar2 parameters and 2000 bytes for raw parameters.
Action: Use smaller parameters.
ORA-23324: error string, while creating deferror entry at "string" with error string
Cause: The given error was encountered while attempting to create a deferor entry for the give error code and the give database.
Action: Correct the cause of the given error.
ORA-23325: parameter type is not string
Cause: A conflict resolution priority function was given a type different than the type assigned to the priority group; or the priority group has no type assigned or a function; or dbms_defer_sys_query was called to retrieve a deferred rpc parameter from the deferred rpc queue, but the type of the parameter does not match the return type of the function.
Action: Use the function corresponding to the parameter type.
ORA-23326: object group "string"."string" is quiesced
Cause: Either suspend_master_activity has been called before the object group has resumed normal operation or a (deferred) rpc operation was attempted while the object group was quiesced.
Action: If suspend_master_activity has been called and a resume_master_activity request is pending, wait until it completes, and then reinvoke suspend_master_activity. Otherwise, resume database activity with the resume_master_activity call.
ORA-23327: imported deferred rpc data does not match string of importing db
Cause: Deferred rpc queues were imported from a database with a different global name or operating system than importing database.
Action: Deferred rpc data should only be imported into a database with the same global name and hardware and operating system.
ORA-23328: mview base table "string"."string" differs from master table "string"."string"
Cause: When creating a materialized view through repcat, the materialized view base table name did not match a replicated table name at the master.
Action: Change the materialized view ddl to use the same base table as the replicated table name at the master.
ORA-23329: successful user-provided ddl but no materialized view "string"."string"
Cause: The DDL provided by the user to create a materialized view was executed without error, but materialized view does not exist.
Action: Manually back-out the DDL, and reregister with matching ddl and materialized view.
ORA-23330: column group string already exists
Cause: The column group was already registered in the object group.
Action: Use a column group name not yet registered in the replicated object group.
ORA-23331: column group string does not exist
Cause: The given column group is either null, misspelled or not registered.
Action: Use a registered column group.
ORA-23332: group string is in use; cannot drop
Cause: The given column group or priority group is being used to resolve conflicts.
Action: Call dbms_repcat procedures drop_update_resolution, drop_delete_resolution, drop_unique_resolution so that the column group or priority group is no longer in use before dropping.
ORA-23333: column string is already part of a column group
Cause: Attempted to add a column to a column group when the column was already a member of a column group.
Action: Drop the column from its existing column group before trying to add it to another.
ORA-23334: column string does not exist in table or column group
Cause: The given column is either null, misspelled or is not part of the given table or column group.
Action: Use a column that is a member of the table or column group.
ORA-23335: priority group string already exists
Cause: The priority group was already registered in the object group.
Action: Use a column group name not yet registered in the object group.
ORA-23336: priority group string does not exist
Action: Use a priority group name not yet registered in the object group.
ORA-23337: priority or value not in priority group string
Cause: The specified value or priority has not been registered as part of the priority group.
Action: Either specify a different value or priority that is already part of the priority group, or add the value to the priority group.
ORA-23338: priority or value already in priority group string
Cause: The specified value or priority has already been registered as part of the priority group.
Action: Either specify a different value or priority that not already part of the priority group, or drop the value to the priority group.
ORA-23339: duplicate conflict resolution information
Cause: The specified combination of column group, sequence, conflict type and/or parameter table name, parameter column name, and parameter sequence number has already been registered.
Action: Verify that additional conflict resolution information needs to be added and provide a new sequence number. If modifying existing information, the existing information must be dropped first.
ORA-23340: incorrect resolution method string
Cause: User function is specified when conflict resolution method was not "USER FUNCTION" or specified resolution method is not one of the predefined methods.
Action: If user function is specified when conflict resolution method was not "USER FUNCTION", either reregister function with method as "USER FUNCTION" or specify a NULL user function. Otherwise Specify one of the documented supported conflict resolution methods.
ORA-23341: user function required
Cause: A NULL user function was specified for the "USER FUNCTION" method.
Action: Provide user function name (e.g., "schema"."package"."function") that conforms to the documented user function specifications or specify one of the documented supported conflict resolution methods.
ORA-23342: invalid parameter column string
Cause: The parameter column name is null or misspelled, the invocation database is not a master, or is of the wrong type for the specified conflict resolution method.
Action: Specify a parameter column from the specified column group that has a correct type for the conflict resolution method.
ORA-23343: no match for specified conflict resolution information
Cause: The specified combination of column group, sequence, conflict type has not been registered (e.g., for adding a comment).
Action: Specify a combination of column group, sequence, conflict type has been registered.
ORA-23344: constraint (string.string) does not exist
Cause: A null, misspelled or nonexistent constraint was specified when registering a uniqueness conflict.
Action: Register a named constraint for the specified table.
ORA-23345: table "string"."string" not registered to collect statistics
Cause: A procedure that deals with conflict resolution statistics-gathering was called for a table that was not registered to collect statistics.
Action: Call dbms_repcat.register_statistics to register the table.
ORA-23346: primary key or object ID is undefined for table or materialized view string
Cause: Trying to generate replication support for a table or materialized view without a primary key (as defined by a constraint or dbms_repcat.set_columns) or an object ID.
Action: For a table, add a primary key constraint or define a primary key using dbms_repcat.set_columns or use object tables. For a ROWID materialized view, set min_communication to false or use primary key or object ID materialized views.
ORA-23347: datatype string for column string table string not supported
Cause: The table has a column whose datatype is not supported by repcat.
Action: Remove the column from the table, or alter the column to have one of the supported datatypes.
ORA-23348: cannot replicate procedure string; only IN parameters supported
Cause: Trying to generate replication support for a package that has a procedure with OUT or IN OUT parameters.
Action: Remove the procedure from the package, or remove the OUT or IN OUT parameters from the procedure.
ORA-23349: cannot generate replication support for functions
Cause: Trying to generate replication support for a package that has a public function, or for a stand-alone function.
Action: Remove the public function from the package, or alter the function to be a procedure.
ORA-23350: maximum number of recursive calls exceeded
Cause: This usually occurs when trying to resolve conflicts in a table while concurrent updates to the same row create more conflicts.
Action: Re-execute the deferred transaction from DefError using dbms_defer_sys.execute_error
ORA-23351: parameter datatype string for procedure string not supported
Cause: The procedure has a parameter whose datatype is not supported by repcat.
Action: Remove the parameter from the procedure, or alter the parameter to have one of the supported datatypes.
ORA-23352: duplicate destination for deferred transaction
Cause: A duplicate destination was specified for a deferred transaction either in a dbms_defer.call call or an earlier dbms_defer.transaction call or a dbms_defer_sys.add_default_dest call.
Action: Remove the duplicate entry
ORA-23353: deferred RPC queue has entries for object group "string"."string"
Cause: The requested action cannot be performed until the queue is empty for the given object group
Action: Use dbms_defer_sys.execute or dbms_defer_sys.delete_tran to empty the queue.
ORA-23354: deferred RPC execution disabled for "string" with "string"
Cause: Deferred RPC can not be executed at the destination with the specified catchup value because their propogation has been disabled.
Action: Enable deferred RPC execution with the dbms_defer_sys.set_disabled call.
ORA-23355: object string.string does not exist or is invalid at master site
Cause: The given name was null or misspelled, the given type was wrong, the object does not exist as a valid database object at the master site, or the object does not exist as a replicated object with the appropriate status.
Action: Ensure the object is valid in the master database, and is visible to the user, and, if appropriate, is a valid object in all_repobject.
ORA-23356: masterdef recognizes a master which does not recognize the masterdef
Cause: Possibly drop_master_repgroup was run at a master site but remove_master_databases was not run at master definition site for that master.
Action: Run remove_master_databases from master definition site to remove the appropriate master (see associated error messages).
ORA-23357: the propagator does not exist
Cause: The propagator does not exist.
Action: Register a new propagator.
ORA-23358: invalid remote user
Cause: The local user does not match the remote user connected via a database link.
Action: Drop and recreate the identified database link with the connect-to user identical to the owner of the database link.
ORA-23359: error on creating a ddl record for a repcatlog record
Cause: The userid in the repcatlog record does not match the userid of the connected user.
Action: Retry the operation with a different user.
ORA-23360: only one materialized view for master table "string" can be created
Cause: Trying to create more than one materialized view on a given master table in the same rep group.
Action: Create these other materialized views in a different rep group at another site.
ORA-23361: materialized view "string" does not exist at master site
Cause: The materialized view does not exist at the master site for offline instantiation of the materialized view.
Action: The correct procedure is to create the materialized view in a different schema at the master site, and then follow the instructions for offline instantiation of materialized views.
ORA-23362: invalid user
Cause: The given user does not exist.
Action: n/a
ORA-23363: mismatch of mview base table "string" at master and mview site
Cause: The name of the base table of the materialized view at the master site is different from the base table at the materialized view site. This error may arise during offline instantiation of materialized views.
Action: Retry offline instantiation with a materialized view name less than 24 bytes
ORA-23364: Feature not enabled: Advanced replication
Cause: The Advanced Replication feature is not enabled at this site. Updatable materialized views, deferred RPCs, and other replication features are, therefore, unavailable.
Action: Do not attempt to use this feature. Contact an Oracle Customer Support representative if the Advanced Replication feature has been purchased but not enabled.
ORA-23365: site string does not exist
Cause: site specified in argument "reference_site" or argument "comparison_site" in call to "differences()" routine or "rectify()" routine does not name an existing site.
Action: Make sure that database sites specified really do exist, and re-run the routine.
ORA-23366: integer value string is less than 1
Cause: Value of argument "max_missing" to routine "differences()" cannot be less than 1. Value of argument "commit_rows" to routines "differences()" and "rectify()" cannot be less than 1.
Action: Choose an integer value for those arguments to be 1 or greater.
ORA-23367: table string is missing the primary key
Cause: Table specified in argument "oname1" or "oname2" in call to "differences()" routine does not contain either a primary key or a virtual primary key (defined through dbms_repcat package under symmetric replication).
Action: Make sure the tables specified have a primary key defined.
ORA-23368: name string cannot be null or the empty string
Cause: Argument "sname1," "sname2," "oname1," "oname2," "missing_rows_sname," "missing_rows_oname1," "missing_rows_oname2" to "differences()" or "rectify()" cannot be NULL or '' (empty string).
Action: Change argument to non-null or non-empty string.
ORA-23369: value of "string" argument cannot be null
Cause: Argument "max_missing" to "differences()" routine cannot be NULL.
Action: Legal values for "max_missing" are integers 1 or greater.
ORA-23370: table string and table string are not shape equivalent (string)
Cause: The tables specified are not shape equivalent, which means intuitively that the number of columns, the names, their datatypes and lengths are not the same. Specifically, problem is in the parentheses and is one of the following: the number of columns are not equal, datatypes of columns with same name in different tables are different, lengths of varchar2 and char columns are not equal, precision and scale of number datatypes are not equal.
Action: Make sure the two tables being compared have the same number of columns, same column names, and same datatypes.
ORA-23371: column string unknown in table string
Cause: Some column in "array_columns" argument (or "column_list" argument) to "differences()" routine does not correspond to a column in the specified table.
Action: Make sure that all the columns in either "array_columns" or "column_list" are present in the specified table.
ORA-23372: type string in table string is unsupported
Cause: Certain types in the table comparison utility are not supported.
Action: Make sure that the types of columns in the tables to be compared are the ones supported by symmetric replication.
ORA-23373: object group "string"."string" does not exist
Cause: The group name was null or misspelled, or the group does not exist locally.
Action: Specify the group correctly, or create it with dbms_repcat.create_master_repgroup().
ORA-23374: object group "string"."string" already exists
Cause: The given database already replicates the given object group. A materialized view repgroup cannot be created at a given site where a master repgroup with the same name already exists.
Action: Choose a different group or a different database.
ORA-23375: feature is incompatible with database version at string
Cause: A feature not compatible with the specified database was used
Action: Set or raise the value of the "compatible" INIT.ORA parameter to match the necessary compatibility level.
ORA-23376: node string is not compatible with replication version "string"
Cause: A feature not compatible with the remote database was used
Action: Upgrade the remote database and retry the operation
ORA-23377: bad name string for missing_rows_oname1 argument
Cause: An attempt was made to use the name of the reference site table as the name of the missing_rows_oname1 argument.
Action: Provide a separately created table with a different name for missing_rows_oname1 argument. The separately created table will contain the differences between the tables being compared.
ORA-23378: connection qualifier "string" is not valid for object group "string"."string"
Cause: The connection qualifier used in the database link for the specified object group does not match the qualifier specified for the group in create_master_repgroup.
Action: Use or create a database link which contains the correct connection qualifier.
ORA-23379: connection qualifier "string" is too long
Cause: The maximum length of a database link, including the connection qualifier, is 128 bytes.
Action: Use a shorter connection qualifier, or shorten the name of the database link
ORA-23380: propagation mode "string" is not valid
Cause: The specified propagation may be misspelled, or is not supported. For materialized view sites, all materialized view object groups at the same materialized view site with the same master object group must all have the same propagation method.
Action: Refer to the manual on replicated data for valid propagation modes. For materialized view sites, also ensure that the propagation modes of all materialized view object groups with the same master object group are the same.
ORA-23381: generated object for base object string.string@string does not exist
Cause: The system generated object(s) for the specified base object do not exist at the specified site. The current operation requires the base object to have generated replication support.
Action: Ensure that the generated replication object(s) for the base object exist and are valid at the specified site. If the generated object(s) do not exist, then the procedure dbms_repcat.generate_replication_support() needs to be called from the master definition site for the base object. missing_rows_oname1 argument. The separately created table will contain the differences between the tables being compared.
ORA-23382: materialized view repgroup "string"."string" is not registered at site string
Cause: The materialized view repgroup is not currently registered at the master and so cannot be unregistered.
Action: None
ORA-23383: registration for materialized view repgroup "string"."string" failed at site string
Cause: Insertion into local repschema table failed.
Action: None
ORA-23384: replication parallel push string argument out of range
Cause: Specified numeric argument to dbms_defer_sys.push is invalid.
Action: Fix the argument value and try again.
ORA-23385: replication parallel push string argument not valid
Cause: Specified string argument to dbms_defer_sys.push is invalid.
ORA-23386: replication parallel push cannot create slave processes
Cause: An error was occurred while creating slave processes for parallel push.
Action: n/a
ORA-23387: replication parallel push dequeue error
Cause: An attempt to dequeue a deferred transaction failed while trying to assign a new queue batch number.
Action: n/a
ORA-23388: replication parallel push watermark error
Cause: An error occurred during parallel push while trying to update the high-water-mark information in system.def$_destination.
Action: n/a
ORA-23389: obsolete procedure; drop objects and recreate using new master
Cause: dbms_repcat.switch_mview_master is no longer supported.
Action: Drop the objects in the object group and recreate them using the new master.
ORA-23392: could not find materialized view to be associated with "string"."string"
Cause: Could not find materialized view associated with a trigger or index that is being pulled from the master site.
Action: Ensure that materialized view, master, and master index or trigger is registered as replicated objects.
ORA-23393: the user is already the propagator
Cause: The given user is already the current propagator.
Action: n/a
ORA-23394: duplicate propagator
Cause: More than one valid propagator exist.
Action: Unregister any duplicate propagator.
ORA-23395: object "string"."string" of type "string" does not exist or is invalid
ORA-23396: database link "string" does not exist or has not been scheduled
Cause: the database link does not exist in the schema of the replication propagator or has not been scheduled.
Action: Ensure that the database link exists in the database, is accessible and is scheduled for execution.
ORA-23397: global name "string" does not match database link name "string"
Cause: the database link name at the local node does not match the global name of the database that the link accesses.
Action: Ensure that global names is set to true and the link name matches the global name.
ORA-23398: user name "string" at database link "string" does not match local user name "string"
Cause: the user name of the replication administration user at the local node and the user name at the node corresponding to the database link are not the same. Symmetric replication expects the two users to be the same.
Action: Ensure that the user ID of the replication administration user at the local node and the user ID at the node corresponding to the database link are the same.
ORA-23399: generation of replication support for "string"."string" is not complete
Cause: Replication support for the specified object has not been generated or the generation process is not yet complete.
Action: Ensure that replication support has been generated for the object. Use DBMS_REPCAT.GENERATE_REPLICATION_SUPPORT() to generate replication support for the object.
ORA-23400: invalid materialized view name "string"
Cause: A null, misspelled, or badly formed materialized view name was given to dbms_mview.refresh.
Action: Provide a valid materialized view name to dbms_mview.refresh.
ORA-23401: materialized view "string"."string" does not exist
Cause: A materialized view name was given to dbms_mview.refresh that is not in sys.snap$ or its associated views.
Action: Provide a materialized view name that is in sys.snap$, all_mviews or user_mviews.
ORA-23402: refresh was aborted because of conflicts caused by deferred txns
Cause: There are outstanding conflicts logged in the DefError table at the materialized view's master.
Action: Resolve the conflicts in the master DefError table and refresh again after the table is empty. Alternatively, refresh with refresh_after_errors set to TRUE, which will proceed with the refresh even if there are conflicts in the master's DefError table. Proceeding despite conflicts can result with an updatable materialized view's changes appearing to be temporarily lost (until a refresh succeeds after the conflicts are resolved).
ORA-23403: refresh group "string"."string" already exists
Cause: Making a new refresh group when there is already a group of the same name in sys.rgroup$.
Action: Choose a diifferent refresh group name.
ORA-23404: refresh group "string"."string" does not exist
Cause: A refresh group name was given that is not in sys.rgroup$.
Action: Provide a refresh group name that is in sys.rgroup$ or dbs_rgroup.
ORA-23405: refresh group number string does not exist
Cause: A refresh group number was given that is not in sys.rgroup$.
Action: Provide a refresh group number that is in sys.rgroup$ or dbs_rgroup.
ORA-23406: insufficient privileges on user "string"
Cause: The caller is not the owner of the materialized view and does not have ALTER ANY MATERIALIZED VIEW privileges.
Action: Perform the operation as the owner of the materialized view or as a user with ALTER ANY MATERIALIZED VIEW privileges.
ORA-23407: object name string must be shaped like "schema"."object" or "object"
Cause: The object name (e.g., the rollback segment, the materialized view name, the refresh group) was incorrectly specified.
Action: Retry the operation with the object name properly specified (like "schema"."object" or "object")
ORA-23408: this replication operation is not supported in a mixed configuration
Cause: operation is not supported if the object group is replicated at a pre-V8 node.
Action: Ensure that all nodes of the replicated object group are V8.
ORA-23409: could not find an unused refresh group number
Cause: 1000 consecutive refresh group numbers, as defined by the rgroupseq number, were already used by rows in sys.rgroup$.
Action: Alter the sequence number to be within a legal unused range and destroy unneeded refresh groups.
ORA-23410: materialized view "string"."string" is already in a refresh group
Cause: A materialized view of the same name is already in a refresh group.
Action: Subtract the materialized view from the current refresh group and add it to its new refresh group, or combine the two refresh groups into a single refresh group.
ORA-23411: materialized view "string"."string" is not in refresh group "string"."string"
Cause: The specified materialized view is not in the specified refresh group.
Action: Try again with the proper materialized view and refresh group names.
ORA-23412: master table's primary key columns have changed
Cause: The master table's primary key constraint was modified after the primary key materialized view was created.
Action: Drop and recreate the primary key materialized view
ORA-23413: table "string"."string" does not have a materialized view log
Cause: The fast refresh can not be performed because the master table does not contain a materialized view log.
Action: Use the CREATE MATERIALIZED VIEW LOG command to create a materialized view log on the master table.
ORA-23414: materialized view log for "string"."string" does not record rowid values
Cause: A rowid materialized view is being fast refreshed, but the materialized view log does not record rowid information.
Action: Use the CREATE MATERIALIZED VIEW LOG...ADD ROWID command to begin recording rowid information in the materialized view log.
ORA-23415: materialized view log for "string"."string" does not record the primary key
Cause: A primary key materialized view is being fast refreshed, but the materialized view log does not record primary key information.
Action: Use the CREATE MATERIALIZED VIEW LOG...ADD PRIMARY KEY command to begin recording primary key information in the materialized view log.
ORA-23416: table "string"."string" does not contain a primary key constraint
Cause: The master table does not constaint a primary key constraint or the primary key constraint has been disabled.
Action: Create a primary key constraint on the master table or enable the existing constraint.
ORA-23417: unknown materialized view type: string
Cause: A fast refresh is being performed on a materialized view of an unknown or unsupported type.
Action: Check all_mviews and ensure that the materialized view being refreshed a valid materialized view.
ORA-23418: cannot unregister the propagator who is currently in use
Cause: The propagator is currently used in propagating replication RPCs.
Action: Try again later when there is no transaction active in propagating replication RPCs.
ORA-23419: regenerate replication support before resuming master activity
Cause: There are tables in the object group that require regeneration of replication support.
Action: Check the generation_status column in the all_repobjects view. Regenerate replication support for any table in the object group with a 'NEEDSGEN' status. Resume master activity.
ORA-23420: interval must evaluate to a time in the future
Cause: The parameter "interval" evaluates to a time earlier than SYSDATE.
Action: Choose an expression that evaluates to a time later than SYSDATE.
ORA-23421: job number string is not a job in the job queue
Cause: There is no job visible to the caller with the given job number.
Action: Choose the number of a job visible to the caller.
ORA-23422: Oracle Server could not generate an unused job number
Cause: Oracle Server could not generate a job number that was not used to identify another job.
Action: Retry the operation.
ORA-23423: job number string is not positive
Cause: The given job number is less than 1.
Action: Choose a positive integer.
ORA-23424: materialized view "string"."string" at string not registered
Cause: The specified materialized view has not be successfully registered at this site.
Action: Register the materialized view manually at either the master site or the materialized view site.
ORA-23425: invalid materialized view identifier string
Cause: The argument provided to dbms_mview.purge_mview_from_log is an invalid materialized view identifer or it does not identify an Oracle 8 fast refreshable materialized view or the materialized view has been already purged.
Action: If the materialized view is an Oracle 8 fast refreshable materialized view then provide purge_mview_from_log with its valid materialized view identifier.
ORA-23426: deferred RPC queue has entries for string
Cause: The requested action cannot be performed until the queue is empty for the given site/dblink
Action: Use dbms_defer_sys.push, dbms_defer_sys.purge_queue or dbms_defer_sys.delete_tran to empty the queue.
ORA-23427: deferred purge queue argument string out of range
Cause: Specified numeric argument to dbms_defer_sys.purge_queue is invalid.
ORA-23428: job associated instance number string is not valid
Cause: A job is associated with an instance that is not running.
Action: Choose a running instance for job affinity, or set force parameter to TRUE.
ORA-23430: argument "string" cannot be NULL or empty string
Cause: The caller has provided an argument whose value cannot be NULL or the empty string.
Action: Check that the varchar2 value provided is not NULL or the empty string, and retry the call.
ORA-23431: wrong state: string
Cause: The routine was executed against a replicated object group that was in the wrong state.
Action: Make sure that the replicated object group is in the state given in the error message.
ORA-23432: master site string already exists
Cause: An attempt was made to instantiate a replicated object group at a master site that was already a part of the object group.
Action: If you were trying to add this site, do nothing because it already exists; otherwise, pick the name of another site, and re-run the routine.
ORA-23433: executing against wrong master site string
Cause: An attempt was made to execute the routine at a site that is different from the site specified in the argument of the routine.
Action: Provide an argument to the routine that correctly indicates the site against which the routine should be executing.
ORA-23434: master site string not known for object group
Cause: The site name given as an argument to a routine was not already known to the replicated object group.
Action: Execute the dbms_offline_og.begin_instantiation() routine to add a new site to the replicated object group.
ORA-23435: cannot create an updatable ROWID materialized view with LOB columns
Cause: The propagation of LOB data from materialized view sites to the master site requires a primary key on the replicated table. Thus updatable ROWID materialized views that contain LOB columns are not supported.
Action: Create a primary key materialized view instead of a ROWID materialized view. If the materialized view already exists, it can be converted to a primary key materialized view using the ALTER MATERIALIZED VIEW DDL command.
ORA-23436: missing template authorization for user
Cause: The specified template authorization does not exist.
Action: Check the values for user name and refresh template name to ensure a valid row exists in the DBA_REPCAT_USER_AUTHORIZATIONS view.
ORA-23437: template authorization already exists for user
Cause: The specified user already has been authorized to use the specified refresh group template.
Action: Check the values for user name and refresh template name or query the DBA_REPCAT_USER_AUTHORIZATIONS view to ensure that the correct values were passed as parameters.
ORA-23438: missing refresh group template
Cause: The specified refresh group template does not exist.
Action: Verify that the refresh group template does not exist by querying the DBA_REPCAT_REFRESH_TEMPLATES view.
ORA-23439: refresh group template already exists
Cause: The specified refresh group template already exists.
Action: Verify that the refresh group template exists by querying the DBA_REPCAT_REFRESH_TEMPLATES view.
ORA-23440: incorrect public template value
Cause: The public template parameter is not 'Y', 'N' or NULL.
Action: Correct the value of the public template parameter. It must be 'Y','N' or NULL.
ORA-23441: object does not exist for refresh group template
Cause: The specified object does not exist in the refresh group template.
Action: Correct the object name and object type parameters. Check the DBA_REPCAT_TEMPLATE_OBJECTS view to verify the correct name and type of the object.
ORA-23442: object already exists for the refresh group template
Cause: The specified object already exists in the refresh group template.
Action: Change the object name and object type parameters. Query the DBA_REPCAT_REMPLATE_OBJECTS view to verify the correct name and type of the object.
ORA-23443: missing template parameter
Cause: The specified template parameter does not exist.
Action: Correct the template parameter value and execute the procedure again. Use the DBA_REPCAT_TEMPLATE_PARMS view to verify the name of the refresh group template and parameter name.
ORA-23444: duplicate template parameter
Cause: The template parameter already exists for the specified refresh group template.
ORA-23445: missing template site
Cause: The template site specified by the site name, user name and refresh group template name does not exist.
Action: Correct the invalid parameter and execute the procedure again. Use the DBA_REPCAT_TEMPLATE_SITES view to query the existing template sites.
ORA-23446: duplicate template site
Cause: The template site specified by the site name, user name and refresh group template name already exists.
ORA-23447: missing user parameter value
Cause: The user parameter value specified by the user name, parameter name and refresh group template name does not exist.
Action: Correct the invalid parameter and execute the procedure again. Use the DBA_REPCAT_USER_PARMS view to query the existing user parameters.
ORA-23448: duplicate user parameter value
Cause: The user parameter value specified by the user name, parameter name and refresh group template name already exists.
ORA-23449: missing user name
Cause: The user specified by the user name parameter does not exist in the database.
Action: Correct an invalid user name or create the user in the master database. Use the DBA_USERS view to select the valid database users.
ORA-23450: flavor already contains object "string"."string"
Cause: The flavor already contains the specified object.
Action: Check that the specified object is correct. To add all columns of a table object, delete the object from the flavor and then add it again.
ORA-23451: flavor string already defined for object group "string"."string"
Cause: The given object group already contains a (possibly unpublished) definition of the specified flavor.
Action: Check the spelling of the flavor name. Check for an unpublished flavor of the desired name.
ORA-23452: flavor string of object group "string"."string" is already published
Cause: The given object group already contains a (published) definition of the specified flavor.
ORA-23453: requested operation is not supported on top flavor
Cause: The TOP flavor has a NULL name and may not be directly defined or deleted.
Action: Supply the name of a flavor other than the TOP flavor or use dbms_repcat routines to implicitly change the TOP flavor.
ORA-23454: flavor string not defined for object group "string"."string"
Cause: The given object group does not contain a (published) definition of the specified flavor.
Action: Check the spelling of the flavor name. Ensure the flavor has been defined (and published) for the object group.
ORA-23455: flavor string contains object "string"
Cause: The given flavor contains the object to be dropped.
Action: Purge the flavor or choose another object to drop.
ORA-23456: flavor string does not contain "string"
Cause: The flavor does not contain the given object, column, or attribute.
Action: Either drop the flavor or choose a different object, column, or attribute.
ORA-23457: invalid flavor ID string
Cause: The given flavor ID is invalid.
Action: Make sure this flavor has been instantiated. If the flavor ID is outside the range (-2147483647, 2147483647), contact customer support.
ORA-23458: inappropriate flavor string at string
Cause: The given flavor at the given database prevents the operation from succeeding.
Action: Either change the database flavor or choose a different operation.
ORA-23459: flavor string must contain "string"
Cause: The flavor must contain the given object, column, or attribute.
Action: Either choose a different database flavor or ensure the object, column, or attribute is available.
ORA-23460: missing value for column string in resolution method "string" for "string"."string"."string"
Cause: before resolving conflicts, some values necessary resolving conflicts are not available, or after resolving conflicts, some values necessary for re-trying of the SQL are not available
Action: define appropriate flavors, provide necessary values through availability vector in USER FLAVOR FUNCTION for conflict resolution
ORA-23461: fail to resolve conflict for "string"."string"."string"
ORA-23462: flavor string in use at site string
Cause: The given flavor cannot be deleted because it is being used at the given site.
Action: Change the flavor of the site, or unregister it if it is a materialized view site.
ORA-23463: flavor incompatible with object "string"."string"
Cause: An existing flavor includes the specified object with an incompatible type.
Action: Change the type of the object, or delete the flavor if it is not in use.
ORA-23464: flavor lacks column string of "string"."string"
Cause: The flavor includes some columns of an object group but not all the required columns.
Action: Change the flavor definition to include all required columns.
ORA-23465: flavor already includes column string of "string"."string"
Cause: The flavor includes the specified column which is being added.
Action: Check that the specified column is correct.
ORA-23466: flavor requires missing object "string"."string"
Cause: The flavor includes the specified object which does not exist
Action: Check that the specified object name is correct, and create the object if appropriate.
ORA-23467: flavor lacks object "string"."string"
Cause: The flavor does not include the specified object which is being dropped.
ORA-23468: missing string string
Cause: The template is missing the object with the specified key.
Action: Add the object to the template.
ORA-23469: string is different between templates
Cause: The values for the specified columns are different in each template for the same key values.
Action: Correct the column values to make the templates the same.
ORA-23470: invalid status
Cause: The status should be DELETED, INSTALLING or INSTALLED. Any other status is invalid.
Action: Check that the specified status value is correct.
ORA-23471: template not authorized for user
Cause: The refresh template is private and the user has not been authorized to instantiate the template.
Action: Authorize the user to use the template.
ORA-23472: materialized view "string"."string" must be atomically refreshed
Cause: Non-atomic refresh is not supported for the specified materialized view.
Action: Set the value of the ATOMIC parameter to FALSE in the refresh procedure being used or remove the specified materialized view from the set of materialized views being refreshed.
ORA-23473: replication RPC processing for "string"."string" is disabled
Cause: The processing of replication RPCs for the object group that contains this object is disabled. This includes RPCs in the error queue.
Action: Processing of replication RPCs is disabled when the object group is being offline instantiated. Wait until offline instantiation is finished.
ORA-23474: definition of "string"."string" has changed since generation of replication support
Cause: The current columns in the specified table and their column types do not match the columns and column types when replication support was last generated.
Action: Regenerate replication support for the affected table. All flavors that include the specified table should be checked for validity. Types for any UDT columns should also be checked for validity.
ORA-23475: key column string must be sent and compared
Cause: The specified column is a key column and must be sent and compared during replication propagation.
Action: Make sure every key column is sent and compared.
ORA-23476: cannot import from string to string
Cause: This object was imported from a database with a different global name than the importing database.
Action: Only import this object into a database with the same global name.
ORA-23477: unable to alter propagation mode for object group "string"."string"
Cause: The propagation method of a materialized view object group can only be altered when no other object groups with the same master object group are sharing the materialized view site.
Action: Ensure that there are no other materialized view object groups at the local site with the same master object group.
ORA-23478: object group "string" is already mastered at string
Cause: There is at least one other materialized view repgroup at the local site with the same group name but a different master site.
Action: Ensure that all materialized view repgroups at the local site with the same group name have the same master.
ORA-23480: Column string is not a top-level column of "string"."string".
Cause: The column is either not a top-level column or is not present in the table or materialized view.
Action: Ensure only valid top-level columns are used.
ORA-23481: unexpected name string "string"
ORA-23482: column string of "string"."string": object types not allowed.
Cause: The column is of Object Type.
Action: Ensure that all the columns are not of Object Type.
ORA-23483: object "string"."string" not allowed in this operation.
Cause: The specified operation does not support the given object.
Action: Do not invoke the operation for this object.
ORA-23484: internal internet Application Server error: string
Cause: An internal error occurred in internet Application Server.
ORA-23485: Column group "string" must consist of a single numeric column only
Cause: The column group doesn't contain only one numeric column.
Action: Use a column group containing a single numeric column.
ORA-23487: object groups "string"."string" and "string"."string" do not have the same connection qualifier
Cause: The specified two object groups do not have the same connection qualifier.
Action: Do not invoke the operation on the above object groups, or ensure they have the same connection qualifier.
ORA-23488: propagation mode "string" for "string" is not allowed for this operation
Cause: This operation does not support the specified dblink in the above propagation mode.
Action: Do not invoke the operation for this dblink, or change the propagation mode for this dblink.
ORA-23489: duplicate entry "string"
Cause: The specified value is duplicated in the parameter list.
Action: Remove duplicated entries in the parameter list.
ORA-23490: extension request "string" with status "string" not allowed in this operation
Cause: The specified operation is not allowed for the extension request with the specified status.
Action: Ensure the extension request has the appropriate status before retrying this operation.
ORA-23491: no valid extension request at "string"
Cause: The specified database does not have a valid extension request.
Action: Ensure there is a valid extension request in DBA_REPEXTENSIONS view before retrying this operation.
ORA-23492: no new sites for extension request "string"
Cause: There is no new site with the specified extension request.
Action: Ensure there is at least one new site in DBA_REPSITES_NEW view for this request before retrying this operation.
ORA-23493: "string" is not a new site for extension request "string"
Cause: The specified extension request does not include the specified site as a new site.
Action: Ensure the specified site is a new site for this extension request before retrying this operation.
ORA-23494: too many rows for destination "string"
Cause: The specified destination has too many rows in system.def$_destination table.
Action: Ensure the specified destination has at most two valid rows before retrying this operation.
ORA-23495: serial propagation can not be used for "string"
Cause: The sites involved may be in the process of adding a new site without quiescing.
Action: Check the def$_destination table for this destination and try parallel propagation.
ORA-23496: can not change disabled status for "string" and "string"
Cause: The disabled status for this site is set internally for synchronization during adding a new master without quiescing.
Action: Ensure adding a new master without quiescing finished before invoking this procedure.
ORA-23497: repgroup name cannot be null
Cause: The array of Repgroup names contains a null value.
Action: Ensure that the array of Repgroup names is dense and is not null terminated.
ORA-23498: repgroups specified must have the same masters
Cause: The Repgroup names specified do not have the same masters.
Action: Ensure that the Repgroup names specified have the same masters.
ORA-23500: cannot switch master for a multi-tier materialized view repgroup "string"."string"
Cause: An attempt was made to switch master for a materialized view repgroup when its parent repgroup is also a materialized view repgroup. This is not allowed.
Action: Drop and recreate the materialized view repgroup based on a proper parent repgroup.
ORA-23501: refresh template cannot be instantiated for database with compatibilty equal to or less than 8.0
Cause: Instantiation of a refresh template is not supported for database compatibility 8.0 or less.
Action: Be sure the database compatibility is 8.1 or above.
ORA-23502: valid directory for offline instatiation is not specified
Cause: An attempt was made to offline instantiate to a directory which is not specified or null.
Action: There are two ways to specify the directory: o As a parm offline_dirpath to the API o As an init.ora parm named utl_file_dir Make sure you have specified an appropriate directory in which the offline file can be created.
ORA-23503: error occurred during IAS instantiation
Cause: An attempt was made to instantiate a IAS site. Error occurred during IAS instantiation.
Action: See other errors on the error stack to look for the source of the problem. If the error still persists, contact Oracle Support.
ORA-23504: columns added to table do not match list of columns to be added
Cause: The list of columns passed as a parameter does not match the columns to be added to the table.
Action: Correct the DDL string or list of columns and rexecute.
ORA-23505: Object "string"."string" is missing.
Cause: The specified object does not exist.
ORA-23514: invalid or incorrect number of arguments
Cause: The arguments passed to the online redefinition API were invalid or missing.
Action: Call the online redefinition API with the right number of valid arguments.
ORA-23515: materialized views and/or their indices exist in the tablespace
Cause: An attempt was made to drop a tablespace which contains materialized views and/or their indices.
Action: Drop the materialized views in this tablespace. Also, find indices belonging to materialized views in this tablespace and drop then. Then try dropping the tablespace.
ORA-23531: site owner already exists in the template.
Cause: Site owner for the template already exists.
Action: Do not create multiple siteowners for this template.
ORA-23532: tables with different synchronization mechanisms are in the same group
Cause: Tables belonging to the same replication group were specified to be cached with different synchronization mechanisms.
Action: Do not specify different synchronization mechanisms while caching tables belonging to the same replication group.
ORA-23533: object "string"."string" can not be cached
Cause: An attempt was made to cache an object which is not supported.
Action: Do not cache an object which is not supported.
ORA-23534: missing column in materialized view container table "string"."string"
Cause: After import, the materialized view container table has missing columns.
Action: Check if materialized view container table was imported correctly.
ORA-23535: instantiating templates from multiple back ends is not allowed.
Cause: An attempt was made to set a new non-null back end database for an iAS site.
Action: Call dbms_ias_configure.set_back_end_db procedure with null dblink. Then, call the same procedure with the new non-null dblink.
ORA-23536: the object "string"."string" is not cached at the middle tier as expected.
Cause: The object may have been dropped or renamed at the back end after dbms_ias_inst.start_ias_inst was executed.
Action: Check the validity of the object at the back end and retry the instantiation.
ORA-23537: function or procedure string is not allowed to be invoked from this site.
Cause: This function or procedure is restricted to the backend or middle tier site
Action: Connect to the proper site before calling this function or procedure.
ORA-23538: cannot explicitly refresh a NEVER REFRESH materialized view ("string")
Cause: An attempt was made to explicitly refresh a NEVER REFRESH MV.
Action: Do not perform this refresh operation or remove the MV(s) from the list.
ORA-23539: table "string"."string" currently being redefined
Cause: An attempt was made to redefine a table which is currently involved in an ongoing redefinition.
Action: Do not perform this redefinition operation on this table or wait till the ongoing redefinition of the table is completed.
ORA-23540: Redefinition not defined or initiated
Cause: An attempt was made to continue or complete a redefinition which was not defined or initiated.
Action: Define or initiate the redefinition before performing this operation.
ORA-23541: tables do not match tables used while defining the redefinition
Cause: An attempt was made to continue or complete a redefinition by providing different tables than those used while defining or initiating the redefinition.
Action: Repeat this operation and specify the same tables as those that were specified while defining or initiating the redefinition.
ORA-23542: dependent object "string"."string" already registered
Cause: An attempt was made to register an already registered dependent object to an ongoing redefinition.
Action: Do not attempt to register an already registered dependent object to an ongoing redefinition.
ORA-23543: materialized view log on "string"."string" is in an inconsistent state
Cause: There was an error while creating the materialized view log and the log is currently in an inconsistent state. A possible cause could be that schema redefinition has occurred on the master table while the log was being created. Another possible cause could be that there were DMLs being applied on the master table concurrently in another session at the time the materialized view log creation started and those DML transactions haven't committed even after a very long period of time.
Action: Drop the materialized view log and recreate it.
ORA-23546: cannot create rowid mapping table string.string
Cause: The online partition mover could not create a rowid mappping table.
Action: Rename the conflicting table or rerun the SQL statement. * There may be a concurrent online operation on the same object.
ORA-23547: dml_lock_timeout value is out of the permitted range
Cause: The value for dml_lock_timeout was out of the permitted range of 0 to 1,000,000.
Action: Use a value within the range of 0 to 1,000,000 and reexecute the procedure
ORA-23600: cannot create PROPAGATION, string already exists
Cause: The propagate_name already exists.
Action: Drop the propagate_name usign DROP_PROPAGATEcommand or specify propagate_name.
ORA-23601: PROPAGATION_NAME string does not exist
Cause: Propagation does not exist.
Action: Query DBA_PROPAGATION view to find existing propagation_name
ORA-23602: Invalid string process type string
Cause: Specified GoldenGate, XStream or Streams process type is not valid.
Action: Specify either capture or apply.
ORA-23603: string enqueue aborted due to low SGA
Cause: An attempt to enqueue a GoldenGate, XStream or Streams message was aborted because ORACLE is running low on memory allotted.
Action: Either start consuming messages by enabling any GoldenGate, XStream or Streams propagation or apply which might be disabled. An alternative is to allot more memory to STREAMS, which can be done by increasing the streams_pool_size initialization parameter if one was defined or by increasing the shared_pool_size.
ORA-23605: invalid value "string" for string parameter string
Cause: An attempt was made to specify an invalid parameter value.
Action: Specify a valid value for the parameter. Check the documentation for valid parameter values.
ORA-23606: invalid object string
Cause: An attempt was made to specify an invalid object.
Action: Specify a valid object.
ORA-23607: invalid column "string"
Cause: An invalid column was specified in the column list.
Action: Check the columns in the object and specify the right column name.
ORA-23608: invalid resolution column "string"
Cause: An invalid column was specified as the resolution column. The resolution column must belong to the list of columns specified in the 'column_list' parameter.
Action: Check the columns in the column_list and specify the right resolution column name.
ORA-23609: unable to find directory object for directory string
Cause: There was no entry in ALL_DIRECTORIES corresponding to the specified directory.
Action: Grant to the current user appropriate privileges on either a new directory object or an existing directory object.
ORA-23610: internal dbms_streams_tablespaces error: [string] [string] [string] [string]
Cause: Streams detected an erroneous result.
Action: Look for information in the session trace file and contact customer support.
ORA-23611: tablespace "string" has more than one data file
Cause: The specified tablespace had more than one data file and hence did not qualify as a simple tablespace.
Action: Choose a self-contained tablespace with a single data file, or use a procedure that supports any tablespace.
ORA-23612: unable to find tablespace "string"
Cause: Either the tablespace did not exist, or the current user did not have sufficient privileges on the tablespace.
Action: Grant appropriate privileges on the tablespace to the current user or choose a different tablespace.
ORA-23613: Script string already exists
Cause: A script for the specified invoking package already existed.
Action: Complete the previous invocation or drop the previous invocation before proceeding with the current invocation.
ORA-23614: Script string does not exist
Cause: The named script did not exist.
Action: Create the script.
ORA-23615: Block number string does not exist for script string
Cause: The specified block number did not exist for the script.
Action: Add the block or check the block number and reexecute.
ORA-23616: Failure in executing block string for script string with \nstring
Cause: The execution of specified block failed.
Action: Check the error. Query DBA_RECOVERABLE_SCRIPT_BLOCKS to view the failed block. Rectify and rerun the block or script.
ORA-23617: Block string for script string has already been executed
Cause: The specified block was already executed.
Action: Check the block number and reissue the command.
ORA-23618: Generation of script string is not complete.
Cause: Script generation for the specified script was not completed in a prior invocation.
Action: Purge the specified script by calling the RECOVER_OPERATION API in the package DBMS_STREAMS_ADM and reattempt the entire operation.
ORA-23619: non-Oracle system error: string
Cause: A non-Oracle database has returned an error message to STREAMS when attempting to apply a DML statement. The non-Oracle system error message is a parameter to this Oracle error.
Action: Corrective action may or may not be possible (depending on the non-Oracle system error). If corrective action is possible, correct the problem and try applying the transaction again.
ORA-23620: bind value size too large for PL/SQL CALL operation
Cause: In a PL/SQL CALL to a stored procedure, the bind string size exceeded 4K.
Action: Either make the bind string size shorter (less than 4K) or use BEGIN-END to call the procedure instead of CALL.
ORA-23621: Operation corresponding to script string is in progress.
Cause: The script was already being run in a different session or was terminated before status for the script was updated to ERROR or EXECUTED.
Action: Make sure the script is not being run in a parallel session. Then call the RECOVER_OPERATION API in the DBMS_STREAMS_ADM package with the appropriate OPERATION_MODE argument.
ORA-23622: Operation string.string.string is in progress.
Cause: An attempt was made to execute a procedure which was being executed in a parallel session or failed execution.
Action: Query the DBA_RECOVERABLE_SCRIPT view to identify the operation that is currently in progress for the specified invoking procedure. Complete the operation before proceeding.
ORA-23623: internal DBMS_COMPARISON error: [string] [string] [string] [string]
Cause: DBMS_COMPARISON detected an erroneous result.
Action: Look for information in the session trace file and contact Oracle Support Services.
ORA-23624: A comparison operation is currently in progress for string.
Cause: Another session was already performing an operation on this object.
Action: Retry the operation once other sessions are done with the specific comparison object.
ORA-23625: Table shapes of string.string and string.string@string did not match.
Cause: Table shapes of local and remote tables to compare did not match.
Action: Retry by explicitly specifying columns that match in column_list or create views on the tables as appropriate.
ORA-23626: No eligible index on table string.string
Cause: Table did not have an eligible index to use for comparison.
Action: For a table to be compared using DBMS_COMPARISON, the table must have an appropriate index on a column of certain data types. Check the documentation for supported data types.
ORA-23627: Comparison object string already existed.
Cause: A comparison object by the specified name already exists.
Action: Retry with a different name.
ORA-23628: Comparison query too long (actual string, allowed string).
Cause: A generated query for comparison was too long.
Action: Comparison is unsupported for very large tables with long column names. Retry with a subset of columns or with shorter column names.
ORA-23629: string.string is not an eligible index on table string.string for comparison
Cause: The specified index was not an eligible index to use for comparison.
Action: For a table to be compared using DBMS_COMPARISON, the table must have an appropriate index. Please specify an eligible index for the table to be compared.
ORA-23630: Cannot switch to apply-state checkpoint mode (value "string", string parameter string), due to the following reason:
Cause: Could not switch to apply-state checkpoint mode, or already in apply-state checkpoint mode.
Action: Can switch to apply-state checkpoint mode only if the capture is new (it never ran), the capture wasn't cloned from a capture with checkpoints, the capture doesn't include any extra attributes, and combined capture and apply is enabled.
ORA-23631: apply-state checkpoint mode cannot change (value "string", string parameter string)
Cause: Could not switch to checkpoints because apply-state checkpoint mode was set.
Action: Drop the apply-state checkpoint capture and create a new one that will / take checkpoints.
ORA-23632: Cannot force checkpoints in apply-state checkpoint mode (value "string", string parameter string)
Cause: The capture process was in apply-state checkpoint mode.
Action: Cannot take checkpoints in apply-state checkpoint mode.
ORA-23633: Cannot turn off combined capture and apply mode in apply-state checkpoint mode (value "string", string parameter string)
Cause: The capture was running in apply-state checkpoint mode and had to run in combined capture and apply mode also.
Action: Ensure that this capture runs in combined capture and apply by dropping additional propagation or apply processes for the same queue.
ORA-23634: Cannot include extra attributes in apply-state checkpoint mode
Action: Extra attributes are not supported in apply-state checkpoint mode.
ORA-23635: MAINTAIN_TTS: tablespace(s) already exist(s) in target database.
Cause: The tablespaces were already in existence in the target database when the streams MAINTAIN_TTS APIs were called."
Action: Check whether you can drop the tablespaces to be maintained in the target database. If not, don't use streams MAINTAIN_TTS APIs to setup streams. Check the Oracle documentation on how to setup streams.
ORA-23636: MAINTAIN_TTS: Invalid tablespace name, reason: string.
Cause: The tablespace name was either NULL or too long when the streams MAINTAIN_TTS APIs were called.
Action: Check that the specified tablespace names are not NULL and are spelled correctly. If there are too many tablespaces, group them together and call the streams MAINTAIN_TTS APIs for the group.
ORA-23637: Capture started in checkpoint mode
ORA-23638: Capture cloned from a capture with checkpoints
ORA-23639: Extra Attribute included
ORA-23640: Combined capture and apply disabled
ORA-23641: Capture started in apply-state checkpoint mode already
ORA-23642: Cannot switch to checkpoint mode (value "string", string parameter string)
Cause: Capture was cloned from a capture in apply-state checkpoint mode.
Action: Clone from a capture with checkpoints.
ORA-23643: Capture cloned from a capture in apply-state checkpoint mode
ORA-23644: Cannot switch to apply-state checkpoint mode (Capture string)
Cause: Switch to apply-state checkpoint mode was prevented by a previous error.
Action: See the previous error for the appropriate action.
ORA-23645: Cannot switch to checkpoints (Capture string)
Cause: Switch to checkpoints was prevented by a previous error.
ORA-23646: string string process string does not exist
Cause: Capture or Apply did not exist.
Action: Create a Capture or Apply process, then try again.
ORA-23647: string string process string is not running
Cause: Capture or Apply were not running.
Action: Start Capture or Apply process, then try again
ORA-23648: Capture string is for Change Data Capture
Cause: Capture was for Change Data Capture, and checkpoints were required.
Action: None
ORA-23649: Capture string is for Audit Vault
Cause: Capture was for Audit Vault, and checkpoints were required.
Action: None
ORA-23650: No progress Capture string
Cause: Capture was not capturing changes.
Action: Make sure Capture is running and capturing changes.
ORA-23651: Capture string is already in string mode
Cause: Capture was already in the desired mode.
Action: None
ORA-23652: The oldest SCN could not be updated at Apply string
Cause: The oldest SCN was not updated before the switch was performed.
Action: Make sure Apply is running and the switch package version is the same at both databases.
ORA-23653: LogMiner session does not exist
Cause: LogMiner session did not exist.
Action: Make sure the Capture process exists.
ORA-23654: Attempting to set the oldest SCN to a greater value (string) than the current one (string) at Apply string
Cause: The new value for the oldest SCN was not computed correctly.
Action: Make sure Capture and Apply are running, and Capture is making progress.
ORA-23655: The SCN range cannot be smaller than 0, (SCN range = string)
Cause: The function was invoked with a negative SCN range.
Action: Use a positive SCN range.
ORA-23656: Timeout occurred while string string process string
Cause: The GoldenGate, XStream or Streams process could not be stopped or started.
Action: Call the switch procedure again.
ORA-23657: the converted file string already exists
Cause: The converted file was already in existence. CONVERT FILE call does not overwrite the existing file.
Action: Check whether the existing file can be deleted. If the existing file can be deleted, delete it. Otherwise, specify a different directory or file extension.
ORA-23658: Invalid character set specified when converting column 'string' in 'string.string'
Cause: The conversion between two character sets for the column in the given table is not supported.
Action: Check if the implicit conversion between source and destination column is supported.
ORA-23659: Destination buffer is not large enough when converting column 'string' in 'string.string' (actual length: string; maximum length: string)
Cause: The conversion between two character sets failed because a source column value is too large for the destination column.
Action: Check if size of the source and destination column matches.
ORA-23660: Unable to load NLS data object when converting column 'string' in 'string.string'
Cause: It may be caused by invalid NLS environment setting.
Action: Check your NLS environment setting.
ORA-23661: Canon capture name "string" not found
Cause: There's no such capture process
Action: Pass the right parameter to the function
ORA-23662: subset rule length exceeds maximum allowed value
Cause: The length of an insert, update, or delete subset rule computed from the DML condition input exceeded the maximum allowed length.
Action: Make the DML condition shorter.
ORA-23663: local object string.string is not a single table view
Cause: The view was based either on another view or multiple tables or views.
Action: For comparison, specify a view based on a single table.
ORA-23664: remote object string.string is not a single table view
ORA-23665: DML conflict handler "string" not found
Cause: The DML conflict handler was not found for modification or removal.
Action: Make sure the name of the conflict handler is correct and that it exists.
ORA-23666: Default column group in use by DML conflict handler "string"
Cause: A default column group was found for the specified Apply name, operation name, and conflict type.
Action: Remove the existing default column group and retry.
ORA-23667: Column "string" already used by conflict handler "string"
Cause: The column was already in the column group of another conflict handler for the specified Apply name, operation name, and conflict type.
Action: Remove the column from the other conflict handler or specify a different column.
ORA-23668: Column "string" does not have a numeric data type.
Cause: The specified column did not have a numeric data type. Delta conflict resolution requires numeric columns.
Action: Check the data type of the column and specify only numeric columns.
ORA-23669: Duplicate conflict handler name
Cause: A DML conflict handler with the specified name was found.
Action: Remove the current DML conflict handler or specify a different name.
ORA-23670: Duplicate column name "string"
Cause: The specified value was duplicated in the column group list.
Action: Remove duplicated entries from the column group list.
ORA-23671: Default column group required
Cause: A default column group was not specified. The specified Apply name, operation name, and conflict type is only supported on default column groups.
Action: Specify a default column group.
ORA-23672: Column not specified in column group for DML conflict handling for table "string"."string"
Cause: The specified table contained a column that was not specified as part of a column group.
Action: Add the column to a column group.
ORA-23673: Invalid resolution column "string" for table "string"."string"
Cause: The specified resolution column was not valid.
Action: Set the resolution column to a valid column.
ORA-23674: Unable to handle delta conflict resolution for table "string"."string"
Cause: The specified table or the LCR contained a null value in one of the columns belonging to a delta conflict group.
Action: Correct each delta column in the table or the error LCR if it currently has a null value.
ORA-23675: Unsupported OPERATION_NAME, CONFLICT_TYPE, and METHOD_NAME
Cause: The specified OPERATION_NAME, CONFLICT_TYPE, and METHOD_NAME was not a valid set of parameters.
Action: Retry with a valid set of parameters.
ORA-23676: no eligible index on local table "string"."string"
Cause: The local table did not have an eligible index to use for comparison.
ORA-23677: no eligible index on remote table "string"."string"
Cause: The remote table did not have an eligible index to use for comparison.
ORA-23678: index "string"."string" on local table "string"."string" is not eligible for comparison
Cause: The specified index was not eligible for comparison.
Action: For a table to be compared using DBMS_COMPARISON, the table must have an appropriate index. Specify an eligible index for the table to be compared.
ORA-23679: index "string"."string" on remote table "string"."string" is not eligible for comparison
ORA-24000: invalid value string, string should be of the form [SCHEMA.]NAME
Cause: An invalid value was specified for the paramerter.
Action: Specify a string of the form [SCHEMA.]NAME .
ORA-24001: cannot create QUEUE_TABLE, string already exists
Cause: The queue table already exists in the queueing system.
Action: Drop the table first using the DROP_QUEUE_TABLE() command or specify another table.
ORA-24002: QUEUE_TABLE string does not exist
Cause: Queue_table not exist.
Action: Query on the user view USER_QUEUE_TABLES to find out existing queue tables.
ORA-24003: Queue table index string inconsistent with queue table string
Cause: The queue table index has not yet been successfully imported.
Action: Import the queue table index before attempting to use the queue table. If the import failed, correct the problem and try to import the queue table index again.
ORA-24004: invalid column name string in SORT_LIST, should be ENQ_TIME or PRIORITY
Cause: Invalid column name was specified in the SORT_LIST.
Action: The valid column names are ENQ_TIME and PRIORITY.
ORA-24005: Inappropriate utilities used to perform DDL on AQ table string.string
Cause: An attempt was made to use the SQL command DROP TABLE or TRUNCATE TABLE or ALTER TABLE on queue metadata or tables.
Action: Use the DBMS_AQADM.DROP_QUEUE_TABLE to DROP TABLE, DBMS_AQADM.PURGE_QUEUE_TABLE to TRUNCATE TABLE. ALTER TABLE redefinition based on only ALTER_TABLE_PROPERTIES and ALTER_TABLE_PARTITIONING clauses are allowed.
ORA-24006: cannot create QUEUE, string already exists
Cause: The queue requested to be created already exists.
Action: Specify another queue name. Query USER_QUEUES for all the exisiting queues in the users's schema.
ORA-24007: invalid value string, MAX_RETRIES should be non-negative integer
Cause: An invalid value was specified for MAX_RETRIES.
Action: Specify a non-negative integer.
ORA-24008: queue table string.string must be dropped first
Cause: An error was detected when dropping a queue table in a cluster, tablespace, or schema.
Action: Use the DBMS_AQADM.DROP_QUEUE_TABLE procedure to drop the specified queue table first; then, retry the operation.
ORA-24009: invalid value string, QUEUE_TYPE should be NORMAL_QUEUE or EXCEPTION_QUEUE
Cause: Invalid queue type parameter
Action: Valid values are NORMAL_QUEUE for normal queue and EXCEPTION_QUEUE for exception queue.
ORA-24010: QUEUE string does not exist
Cause: The specified queue does not exist.
Action: Specify a valid queue. Query USER_QUEUES for all the valid queues.
ORA-24011: cannot drop QUEUE, string should be stopped first
Cause: The queue has not been stopped i.e. either enqueue or dequeue is still enabled.
Action: Stop the queue first using the STOP_QUEUE command and disable it from both enqueueing and dequeueing.
ORA-24012: cannot drop QUEUE_TABLE, some queues in string have not been dropped
Cause: A queue exists in the queue table which has not been dropped. All queues need to be dropped first.
Action: Drop all queues belonging to this queue table using the drop_queue() command. Be sure to stop the queues appropriately before dropping them. Alternately, use the force option in drop_queuetable.
ORA-24013: invalid value string, RETRY_DELAY should be non-negative
Cause: A negative value was specified for RETRY_DELAY.
Action: Specify a non-negative value for RETRY_DELAY.
ORA-24014: invalid value string, RETENTION_TIME should be FOREVER or non-negative
Cause: Queue retention was specified, but the retention time was specified to be less than zero.
Action: Specify the retention time to be non-negative or FOREVER. Alternately don't specify retention.
ORA-24015: cannot create QUEUE_TABLE, QUEUE_PAYLOAD_TYPE string.string does not exist
Cause: An invalid QUEUE_PAYLOAD_TYPE specified during create_queue_table.
Action: The QUEUE_PAYLOAD_TYPE should be RAW or an object type that already exists in the database.
ORA-24016: cannot create QUEUE_TABLE, user string does not have execute privileges on QUEUE_PAYLOAD_TYPE string.string
Cause: An invalid object type specified for QUEUE_PAYLOAD_TYPE during create_queue_table.
Action: The user should have execute priviliges on the object type specified for the queue.
ORA-24017: cannot enable enqueue on QUEUE, string is an exception queue
Cause: User tried to enable enqueueing to an exception queue.
Action: None
ORA-24018: STOP_QUEUE on string failed, outstanding transactions found
Cause: There were outstanding transactions on the queue, and WAIT was set to false, so STOP_QUEUE was unsucessful in stopping the queue.
Action: Set WAIT to TRUE and try STOP_QUEUE again. It will hang till all outstanding transactions are completed.
ORA-24019: identifier for string too long, should not be greater than string characters
Cause: The identifier specified is too long.
Action: Try again with a shorter identifier.
ORA-24020: Internal error in DBMS_AQ_IMPORT_INTERNAL, string
Cause: Internal Error occured in the package DBMS_AQ_IMPORT_INTERNAL.
Action: Internal error, call Oracle Support.
ORA-24021: queue table definition not imported for string.string
Cause: The queue definition is not updated because the queue table was not imported properly
Action: Import the queue table again.
ORA-24022: the specified parameters has no effect on the queue
Cause: The parameter combination will not cause the queue to be started or stoped.
Action: None. This is just a warning.
ORA-24023: Internal error in DBMS_AQ_EXP_INTERNAL.string [string] [string]
Cause: Internal Error occured in the package DBMS_AQ_EXP_INTERNAL.
ORA-24024: Internal error in DBMS_AQ_IMP_INTERNAL.string [string] [string]
Cause: Internal Error occured in the package DBMS_AQ_IMP_INTERNAL.
ORA-24025: invalid value string, QUEUE_PAYLOAD_TYPE should be RAW or an object type
Cause: Parameter queue_payload_type has invalid value.
Action: Specify a valid object type or RAW.
ORA-24026: operation failed, queue string.string has errors
Cause: An attempt was made to enqueue, dequeue or administer a queue which has errors.
Action: Drop the queue table setting the force option to true.
ORA-24027: AQ HTTP propagation encountered error, status-code string, string
Cause: AQ propagation's HTTP request to the propagation servlet at the specified address encountered an error
Action: Specify a valid address in the connect string of the propagation destination dblink, the dblink user has the correct permissions, check if the AQ propagation servlet was properly installed.
ORA-24028: cannot create a reciever non-repudiable single consumer queue
Cause: Tried to create a reciever non-repudiable single consumer queue
Action: This feature is not supported
ORA-24029: operation not allowed on a single-consumer queue
Cause: Tried an operation not allowed on a single-consumer queue.
Action: Specify the operation on a multi-consumer queue.
ORA-24030: Only one of rule or rule-set must be specified
Cause: Specified both a rule and rule-set for the operation.
Action: Specify only one of rule or rule-set.
ORA-24031: invalid value, string should be non-NULL
Cause: Parameter is NULL.
Action: Specify a non NULL value for the parameter.
ORA-24032: object string exists, index could not be created for queue table string
Cause: Oracle AQ tried to create an index with the name specified in the error message. The index could not be created for the specified queue table because a object exists with the same name.
Action: Drop the object specified in the error message and retry the command. You can also choose a different name for the queue table.
ORA-24033: no recipients for message
Cause: An enqueue was performed on a queue that has been set up for multiple dequeuers but there were neither explicit recipients specified in the call nor were any queue subscribers determined to be recipients for this message.
Action: Either pass a list of recipients in the enqueue call or add subscribers to the queue for receiving this message.
ORA-24034: application string is already a subscriber for queue string
Cause: An application name that was already a subscriber for the queue was specified in the dbms_aq.subscribe call.
Action: n/a
ORA-24035: AQ agent string is not a subscriber for queue string
Cause: An AQ agent that was not a subscriber for the queue was specified.
Action: Check the name and/or address of the agent and retry the call.
ORA-24036: invalid SORT_ORDER column string specified for queue table
Cause: The create queue table command was issued with message_grouping set to TRANSACTIONAL and a sort order column other than priority. Only the priority column can be specified in the sort order for queue tables with transactional grouping.
Action: Change the sort order list in the create queue table command and retry the call.
ORA-24037: schema string in QUEUE_NAME is not same as schema string in QUEUE_TABLE
Cause: The schema specified in the QUEUE_NAME parameter of CREATE_QUEUE is not the same as the schema specified in the QUEUE_TABLE parameter.
Action: Use the same schema name for both the QUEUE_NAME and QUEUE_TABLE parameters and retry the command.
ORA-24038: RETRY_DELAY and MAX_RETRIES cannot be used for a 8.0 compatible multiple consumer queue
Cause: The CREATE_QUEUE or ALTER_QUEUE command was issued with a non-zero RETRY_DELAY and a QUEUE_TABLE that was created for multiple consumers and with COMPATIBLE parameter set to '8.0'.
Action: Either set the RETRY_DELAY to zero or upgrade the queue table to 8.1 compatible using the DBMS_AQADM.MIGRATE_QUEUE_TABLE procedure.
ORA-24039: Queue string not created in queue table for multiple consumers
Cause: Either an ADD_SUBSCRIBER, ALTER_SUBSCRIBER, or REMOVE_SUBSCRIBER procedure, or an ENQUEUE with a non-empty recipient list, was issued on a queue that was not created for multiple consumers.
Action: Create the queue in a queue table that was created for multiple consumers and retry the call.
ORA-24041: propagation schedule exists for QUEUE string and DESTINATION string
Cause: A SCHEDULE_PROPAGATION was issued for a queue and destination pair which has an existing propagation schedule.
Action: Issue UNSCHEDULE_PROPAGATION to remove the existing schedule and then reissue the SCHEDULE_PROPAGATION call.
ORA-24042: no propagation schedule exists for QUEUE string and DESTINATION string
Cause: AN UNSCHEDULE_PROPAGATION was issued for a queue and destination pair which has no existing propagation schedule.
Action: Verify the spelling of the specified QUEUE and DESTINATION and then reissue the call with the correct spelling.
ORA-24043: destination string uses a reserved name, names with AQ$_ prefix are not valid
Cause: An attempt was made to specify a reserved name for a destination.
Action: Enter a different value or NULL for the local destination. Then retry the operation.
ORA-24044: source string and destination string object types do not match
Cause: A message recipient's queue has a different object structure than the sender's queue. The message cannot be propagated.
Action: Either remove the recipient from the subscriber's list for the sender's queue or create the destination queue with an object type that matches the source queue's object type.
ORA-24045: invalid agent address string, agent address should be of the form [SCHEMA.]NAME[@DATABASE LINK]
Cause: An invalid value was specified for the agent address parameter.
Action: Specify a string of the form [SCHEMA.]NAME[@DATABASE LINK].
ORA-24046: protocol attribute reserved for future use
Cause: The protocol attribute of the AQ agent object type is reserved for future use.
Action: Do not specify the protocol attribute in the agent object type.
ORA-24047: invalid agent name string, agent name should be of the form NAME
Cause: An invalid value was specified for the agent name parameter.
Action: Specify a string of the form NAME. Then retry the operation.
ORA-24048: cannot create QUEUE_TABLE, user does not have access to AQ object types
Cause: An attempt was made to issue the CREATE_QUEUE_TABLE command, but the user who issued the command does not have access to internal AQ object types.
Action: Use the DBMS_AQADM.GRANT_TYPE_ACCESS procedure to grant the user access to the AQ object types.
ORA-24049: invalid agent name string, names with AQ$_ prefix are not valid
Cause: An attempt was made to use a reserved prefix in the agent name.
Action: Enter a different value for the agent name. Then, retry the operation.
ORA-24050: subscribers are not supported for exception queue string
Cause: An ADD_SUBSCRIBER, ALTER_SUBSCRIBER, or REMOVE_SUBSCRIBER procedure was issued on a queue that was created as an EXCEPTION_QUEUE.
Action: Specify a NORMAL_QUEUE in the procedure.
ORA-24051: cannot propagate object type payloads that have a REF attribute
Cause: An ADD_SUBSCRIBER or ENQUEUE procedure with a non-NULL address field in the agent type was issued on a queue whose payload has a REF attribute. Propagation of object type payloads that have a REF attribute currently is not supported.
Action: Specify an agent with a NULL address field so that the agent can dequeue from the same queue. Or, change the object type definition to one that does not use REF attributes.
ORA-24052: cannot propagate object type payloads with LOB attributes to an 8.0 release
Cause: The recipient of a message with LOB attributes was using an Oracle 8.0 release. Propagation of LOB attributes is supported only in Oracle 8.1 and higher releases.
Action: Upgrade the target release to Oracle 8.1 and retry. Or, change the object type definition to one that does not use LOBs.
ORA-24053: PRIMARY_INSTANCE and SECONDARY_INSTANCE must be non-negative
Cause: One of PRIMARY_INSTANCE or SECONDARY_INSTANCE was negative.
Action: Specify non-negative integers for PRIMARY_INSTANCE and SECONDARY_INSTANCE.
ORA-24054: cannot propagate to an Oracle 8.0.3 release or lower release
Cause: The recipient of a message was using an Oracle 8.0.3 release or lower release. Propagation is supported only in Oracle 8.0.4 and higher releases.
Action: Upgrade the target release to Oracle 8.0.4 or higher and retry.
ORA-24055: cannot delete propagation status rows that are in prepared state
Cause: An attempt was made to use the internal administration procedure to delete status rows from the SYS.AQ$_PROPAGATION_STATUS table that were in the prepared state.
Action: Wait for the propagation to complete successfully before retrying the operation.
ORA-24056: internal inconsistency for QUEUE string and destination string
Cause: The sequence numbers used in the SYS.AQ$_PROPAGATION_STATUS table were inconsistent for the given queue and destination.
Action: Contact Oracle Worldwide Support.
ORA-24057: cannot define subscriber with rule for queue string
Cause: An ADD_SUBSCRIBER or ALTER_SUBSCRIBER procedure with a rule was issued on a queue for which rule based subscribers are not supported. Rule based subscribers currently are supported only for NORMAL (persistent) multi-consumer queues created using an Oracle release 8.1.0 or higher compatible queue table.
Action: Create a NORMAL multi-consumer queue in an Oracle release 8.1.0 or higher compatible queue table, and retry the call. Or, if the queue is a normal (persistent) multi-consumer queue, convert the queue table to Oracle 8.1.0 or higher compatibility and retry.
ORA-24058: cannot downgrade QUEUE_TABLE that has propagation in a prepared state
Cause: An attempt was made to downgrade the queue table when there were messages being propagated that were in the prepared state.
Action: Wait for the propagation to complete before retrying the operation.
ORA-24059: invalid COMPATIBLE parameter setting string specified in DBMS_AQADM.string
Cause: An invalid compatible parameter was specified in the DBMS_AQADM procedure. The parameter setting must be of the form '8.x.y' where x is the release number and y is the update number.
Action: Specify a valid COMPATIBLE parameter setting, and retry the operation.
ORA-24060: cannot convert QUEUE_TABLE, string already is compatible with release string
Cause: The source queue table in the DBMS_AQADM procedure is compatible with the specified COMPATIBLE parameter setting.
Action: Choose a different COMPATIBLE parameter setting to convert the queue table to the desired compatibility.
ORA-24061: cannot specify non-zero SECONDARY_INSTANCE if PRIMARY_INSTANCE was zero
Cause: A non-zero value was specified for SECONDARY_INSTANCE when PRIMARY_INSTANCE was zero.
Action: Specify a non-zero primary instance before you specify a non-zero secondary instance.
ORA-24062: Subscriber table string inconsistent with queue table string
Cause: The subscriber table has not yet been successfully imported.
Action: Import the subscriber table before attempting to use the queue table. If the import failed, correct the problem and try to import the subscriber table again.
ORA-24063: cannot downgrade QUEUE_TABLE that has queues with rule-based subscribers
Cause: An attempt was made to downgrade the queue table when there were queues on which rule based subscribers are defined.
Action: Remove the rule based subscribers for all queues in this queue table and retry.
ORA-24064: propagation for QUEUE string and DESTINATION string already enabled
Cause: An ENABLE_SCHEDULE_PROPAGATION command was issued for a queue and destination pair whose propagation schedule already was enabled.
Action: Make sure the QUEUE and DESTINATION are correct when you issue the ENABLE_SCHEDULE_PROPAGATION command.
ORA-24065: propagation for QUEUE string and DESTINATION string already disabled
Cause: A DISABLE_SCHEDULE_PROPAGATION command was issued for a queue and destination pair whose propagation schedule already was disabled.
Action: Make sure the QUEUE and DESTINATION are correct when you issue the DISABLE_SCHEDULE_PROPAGATION command.
ORA-24066: invalid privilege specified
Cause: An invalid privilege is specified for granting or revoking privilege
Action: Specify a valid privilege.
ORA-24067: exceeded maximum number of subscribers for queue string
Cause: An attempt was made to add new subscribers to the specified, but the number of subscribers for this queue has exceeded the maximum number (1024) of subscribers allowed per queue.
Action: Remove existing subscribers before trying to add new subscribers.
ORA-24068: cannot start queue string, queue table string is being migrated
Cause: An attempt was made to start a queue in a queue table that is being migrated.
Action: Complete the queue table migration, and retry the operation.
ORA-24069: cannot downgrade queue table string while it is being upgraded
Cause: An attempt was made to downgrade a queue table, but a previous command to upgrade the queue table has not yet completed successfully.
Action: Complete the upragde of the queue table by re-executing the DBMS_AQADM.MIGRATE_QUEUE_TABLE procedure. Then, downgrade the queue table.
ORA-24070: cannot upgrade queue table string while it is being downgraded
Cause: An attempt was made to upgrade a queue table, but a previous command to downgrade the queue table has not yet completed succesfully.
Action: Complete the downgrade of the queue table by re-executing the DBMS_AQADM.MIGRATE_QUEUE_TABLE procedure. Then, upgrade the queue table.
ORA-24071: cannot perform operation string, queue table string is being migrated
Cause: An attempt was made to perform an operation on a queue in a queue table that is being migrated.
ORA-24072: cannot execute MIGRATE_QUEUE_TABLE procedure; must own queue table
Cause: An attempt was made to upgrade or downgrade a queue table using the DBMS_AQADM.MIGRATE_QUEUE_TABLE procedure, but the user who executed the procedure does not own the queue.
Action: Reconnect as the owner of the queue table, and then execute the DBMS_AQADM.MIGRATE_QUEUE_TABLE procedure.
ORA-24073: cannot specify RETENTION_TIME on exception queue string.string
Cause: An attempt was made to create or alter an exception queue by specifying a non-zero RETENTION_TIME.
Action: Use the default RETENTION_TIME parameter value for exception queues.
ORA-24074: RETRY_DELAY and MAX_RETRIES cannot be used for exception queue %.string
Cause: The CREATE_QUEUE or ALTER_QUEUE command was issued with a non-zero RETRY_DELAY and an exception queue.
Action: Do not specify RETRY_DELAY or MAX_RETRIES for exception queues.
ORA-24075: cannot specify agent with NULL address and non-NULL protocol
Cause: An ADD_SUBSCRIBER or enqueue was attemoted with an agent that had a NULL address and a non-NULL protocol.
Action: Either specify a non-NULL address or set the protocol to NULL.
ORA-24076: cannot perform operation string for NON_PERSISTENT queue string.string
Cause: One of the operations, SCHEDULE_PROPAGATION, ALTER_QUEUE, LISTEN, DEQUEUE was issued for a NON_PERSISTENT queue.
Action: Do not specify a NON_PERSISTENT queue for these operations.
ORA-24077: cannot create propagation schedule for EXCEPTION queue string.string
Cause: A SCHEDULE_PROPAGATION was issued for an EXCEPTION queue. Propagation schedules can be created only for NORMAL queues.
Action: To propagate messages from a queue specify the queue type as NORMAL.
ORA-24078: cannot specify a non-NULL SECONDARY_INSTANCE if PRIMARY_INSTANCE was NULL
Cause: A non-NULL value was specified for SECONDARY_INSTANCE when PRIMARY_INSTANCE was NULL.
Action: Specify a non-NULL primary instance before you specify a non-NULL secondary instance.
ORA-24079: invalid name string, names with AQ$_ prefix are not valid for string
Cause: An attempt was made to use a reserved prefix for the object name.
Action: Enter a different name for this object. Then, retry the operation.
ORA-24080: unschedule_propagation pending for QUEUE string and DESTINATION string
Cause: A propagation administration command was issued for a queue and destination pair whose propagation is being unscheduled.
Action: Do not issue propagation administration commands for a propagation schedule on which there is a pending unschedule request.
ORA-24081: compatible parameter needs to be string or greater
Cause: The compatible parameter was not high enough to allow the operation.
Action: Shutdown and restart with a higher compatibility setting.
ORA-24082: propagation may still be happening for the schedule for QUEUE string and DESTINATION string
Cause: The snapshot process executing the propagation schedule did not respond to the disable propagation command.
Action: Make sure that the job for the propagation schedule has been ended.
ORA-24083: cannot specify remote subscribers for string QUEUE string
Cause: An add_subscriber call with a non-null address field was issued on a queue which does not support remote subscribers. Remote subscribers are not supported for NON_PERSISTENT QUEUES.
Action: Specify a null address field and retry the call.
ORA-24084: DBLINK name in address field of agent string is not unique within the first 24 bytes
Cause: Advanced Queuing requires that the agent's dblink name should be unique within the first 24 bytes (for 8.0 compatible queuetables)
Action: Specify a dblink name that is unique within the first 24 bytes or migrate to 8.1 compatible queuetables where this restriction is not there.
ORA-24085: operation failed, queue string is invalid
Cause: An attempt was made to enqueue, dequeue or administer a queue which is invalid. This could have occured because the payload type of the queue's queue table was dropped or rules associated with queue subscribers got altered or dropped.
ORA-24086: cannot create a 8.0 compatible string queue
Cause: An attempt was made to create a 8.0 compatible queue table and enable a feature that is supported only on 8.1 style queue tables
ORA-24087: Invalid database user string
Cause: An invalid database username was specified
Action: Specify a valid database user
ORA-24088: AQ Agent string does not exist
Cause: This AQ Agent does not exist
Action: Specify a valid AQ agent. Check the DBA_AQ_AGENTS view for a list of valid aq agents
ORA-24089: AQ Agent string already exists
Cause: This AQ agent has already been created
Action: Specify another agent name or use the ALTER api to modify the agent information.
ORA-24090: at least one protocol must be enabled
Cause: No protocol was enabled for aq agent
Action: Enable one of the protocols by setting one of the enable parameters to true.
ORA-24091: Destination queue string is the same as the source queue
Cause: Propagation cannot be scheduled when the destination queue is the same as the source queue.
Action: Specify a different destination queue.
ORA-24092: invalid value string specified
Cause: A queue, queue table, rule, or ruleset name that requires double quotes was specifed when the database compatibility was less than 10.0.
Action: Specify a value that does not require double quotes and retry the operation.
ORA-24093: AQ agent string not granted privileges of database user string
Cause: The specified AQ agent does not have privileges of the specified database user
Action: Specify a valid combination of AQ agent and database user. Check the DBA_AQ_AGENT_PRIVS or USER_AQ_AGENT_PRIVS view for user/agent mappings
ORA-24094: invalid transformation, target type does not match that of the queue
Cause: The target type of the transformation specified was different from the type of the queue.
Action: Provide a valid transformation whose target type is the same as the queue type.
ORA-24095: invalid transformation, source type does not match that of the queue
Cause: The source type of the transformation specified was different from the type of the queue.
Action: Provide valid transformation whose source type is the same as the queue type.
ORA-24096: invalid message state specified
Cause: Invalid value is specified for message state
Action: Provide a valid message state as specified in the documentation
ORA-24097: Invalid value string, string should be non-negative
Cause: A negative value or NULL was specified for the parameter.
Action: Specify a non negative integer.
ORA-24098: invalid value string for string
Cause: An Invalid value or NULL was specified for the parameter.
Action: Check the documentation for valid values.
ORA-24099: operation not allowed for 8.0 compatible queues
Cause: The specified operation is only supported for queues with compatibility 8.1 or greater
Action: Upgrade the 8.0 compatible queue to release 8.1 using DBMS_AQADM.MIGRATE_QUEUE_TABLE or specify a queue with compatibility 8.1
ORA-24100: error in ktz testing layer
Cause: There is an error in the Transaction layer test ICDs
Action: n/a
ORA-24101: stopped processing the argument list at: string
Cause: One of the arguments of the requested operation contained a list of scheduler objects. While processing this list an error was encountered with the specified item.
Action: Resolve the error for this element of the list and then re-issue the command with the remainder of the argument list. See the rest of the error stack to find out what the exact error is.
ORA-24102: invalid prefix for generate_job_name
Cause: generate_job_name was called with a prefix longer than 18 characters or a prefix ending in a digit.
Action: Re-issue the command using a prefix no longer than 18 characters and not ending in a digit.
ORA-24103: job "string"."string" failed to be enabled after creation
Cause: The job failed to be enabled after creation.
Action: Review the reason for the failure, correct it if possible and re-create the job.
ORA-24120: invalid string parameter passed to DBMS_REPAIR.string procedure
Cause: An invalid parameter was passed to the specified DBMS_REPAIR procedure.
Action: Specify a valid parameter value or use the parameter's default.
ORA-24121: both cascade and a block range passed to DBMS_REPAIR.CHECK_OBJECT procedure
Cause: Both cascade and a block range were specified in a call to DBMS_REPAIR.CHECK_OBJECT.
Action: Use either cascade or a block range, or do not use either one.
ORA-24122: invalid block range specification
Cause: An incorrect block range was specified.
Action: Specify correct values for the BLOCK_START and BLOCK_END parameters.
ORA-24123: feature string is not yet implemented
Cause: An attempt was made to use the specified feature, but the feature is not yet implemented.
Action: Do not attempt to use the feature.
ORA-24124: invalid ACTION parameter passed to DBMS_REPAIR.string procedure
Cause: An invalid ACTION parameter was specified.
Action: Specify CREATE_ACTION, PURGE_ACTION or DROP_ACTION for the ACTION parameter.
ORA-24125: Object string.string has changed
Cause: An attempt was made to fix corrupt blocks on an object that has been dropped or truncated since DBMS_REPAIR.CHECK_OBJECT was run.
Action: Use DBMS_REPAIR.ADMIN_TABLES to purge the repair table and run DBMS_REPAIR.CHECK_OBJECT to determine whether there are any corrupt blocks to be fixed.
ORA-24126: invalid CASCADE_FLAG passed to DBMS_REPAIR.string procedure
Cause: CASCADE_FLAG was specified for an object that is not a table.
Action: Use CASCADE_FLAG only for tables.
ORA-24127: TABLESPACE parameter specified with an ACTION other than CREATE_ACTION
Cause: The TABLESPACE parameter can only be used with CREATE_ACTION.
Action: Do not specify TABLESPACE when performing actions other than CREATE_ACTION.
ORA-24128: partition name specified for a non-partitioned object
Cause: A partition name was specified for an object that is not partitioned.
Action: Specify a partition name only if the object is partitioned.
ORA-24129: table name string does not start with string prefix
Cause: An attempt was made to pass a table name parameter without the specified prefix.
Action: Pass a valid table name parameter.
ORA-24130: table string does not exist
Cause: An attempt was made to specify a map, repair, or sync table that does not exist.
Action: Specify a valid table name parameter.
ORA-24131: table string has incorrect columns
Cause: An attempt was made to specify a map, repair, or sync table that does not have a correct definition.
Action: Specify a table name that refers to a properly created table.
ORA-24132: table name string is too long
Cause: An attempt was made to specify a table name is greater than 30 characters long"
ORA-24141: rule set string.string does not exist
Cause: An attempt to access or modify a ruleset was made, which failed because the ruleset does not exist.
Action: Only access or modify existing rulesets.
ORA-24142: invalid ruleset name
Cause: An attempt to create a ruleset with an invalid name was made. The ruleset name can not be NULL, and can not be more than 26 characters, unless a rules_table_name is also specified, in which case the ruleset name may be up to 30 characters.
Action: Retry the create with a valid ruleset name.
ORA-24143: invalid evaluation context name
Cause: An attempt to create a rule/ruleset on an invalid evaluation name was made. The evaluation_context can not be more than 30 characters. The evaluation context with the name specified must exist.
Action: Retry the create with a valid evaluation context name.
ORA-24144: rules engine internal error, arguments: [string], [string]
Cause: An internal error occurred in the rules engine. This indicates that the rules engine has encountered an exception condition.
Action: Please report this error as a bug. The first argument is the error and the second argument is the package.
ORA-24145: evaluation context string.string already exists
Cause: An evaluation context of the given name already exists
Action: Specify another name for the evaluation context being created
ORA-24146: rule string.string already exists
Cause: A rule of the given name already exists
Action: Specify another name for the rule being created.
ORA-24147: rule string.string does not exist
Cause: The rule of the given name does not exist
Action: create the rule or specify one that exists
ORA-24148: cannot drop rule string.string with dependents
Cause: The rule still belongs to some rulesets, cannot be dropped
Action: do not drop a rule that belongs to rulesets without force option
ORA-24149: invalid rule name
Cause: An attempt to create a rule with an invalid name was made. The rule name can not be NULL, and can not be more than 30 characters
Action: n/a
ORA-24150: evaluation context string.string does not exist
Cause: The evaluation context of the given name does not exist
Action: create the evaluation context or specify one that exists
ORA-24151: no evaluation context is associated with rule string.string or rule set string.string
Cause: Whening adding a rule to a rule set, either the rule or the rule set must have an evaluation context associated with it
Action: do not add a rule without an evaluation context to a ruleset that does not have a default evaluation context
ORA-24152: cannot drop evaluation context string.string with dependents
Cause: The evaluation context still belongs to some rules or rule sets, cannot be dropped
Action: do not drop an evaluation context with dependents without force option
ORA-24153: rule set string.string already exists
Cause: A rule set of the given name already exists
Action: Specify another name for the rule set being created.
ORA-24154: rule string.string already in rule set string.string
Cause: a rule can be added to a rule set only once
Action: do not add a rule to a rule set that already contains this rule
ORA-24155: rule string.string not in rule set string.string
Cause: the rule to be removed from the rule set is not in the rule set
Action: do not remove a rule from a rule set that does not contain the rule
ORA-24156: duplicate table alias string
Cause: there is a table alias of the same name in the evaluation context
Action: do not add two table aliases of the same name to an evaluation context
ORA-24157: duplicate variable name string
Cause: there is a variable of the same name in the evaluation context
Action: do not add two variables of the same name to an evaluation context
ORA-24158: invalid table alias
Cause: table alias name or base table name is not specified in the table alias definiton
Action: specify both alias name and alias base table in the table alias structure
ORA-24159: invalid variable definiton
Cause: variable name or variable type is not specified in the variable definiton
Action: specify both variable name and variable type in the variable definition structure
ORA-24160: name string already exists in the name value pair list
Cause: there is already a name-value pair with the same name in the NVlist
Action: try another name.
ORA-24161: name string does not exist in the name value pair list
Cause: there is not such a name-value pair in the NVlist
Action: check the name-value pair exists in the NVList.
ORA-24162: name value pair list is full, cannot add another entry
Cause: The NVList is full (1024 elements) and cannot hold more elements
Action: do not add elements to a full list.
ORA-24163: dblink is not supported in rules engine DDLs
Cause: the object name has a database link in it, which is not supported
Action: Do not specify remote objects in rules engine DDLs.
ORA-24164: invalid rule engine system privilege: string
Cause: no such system privilege number for rule engine objects
Action: check specfication of dbms_rule_adm for valid system privilege numbers
ORA-24165: invalid rule engine object privilege: string
Cause: no such object privilege number for rule engine objects
Action: check specfication of dbms_rule_adm for valid object privilege numbers
ORA-24166: evaluation context string.string has errors
Cause: The table aliases and the variable types specified in the evaluation context could not be resolved.
Action: Make sure that all base tables exist and that all variable types are correct. Also, make sure that tables are not composite partitioned or clustered partitioned.
ORA-24167: incompatible rule engine objects, cannot downgrade
Cause: there are rule engine objects in the database that cannot be downgraded.
Action: check utlincmp.sql and remove all incompatible rules engine objects before downgrade.
ORA-24168: rule string.string cannot have default evaluation context
Cause: If a rule is added to a rule set with more than one evaluation contexts, it must not have an evaluation context itself.
Action: Do not set the evaluation context of such rules to a not-null value
ORA-24169: rule condition has unrecognized variables
Cause: The rule references variables not in the evaluation context.
Action: Modify the rule condition to remove illegal reference.
ORA-24170: string.string is created by AQ, cannot be dropped directly
Cause: This object is created by AQ, thus cannot be dropped directly
Action: use dbms_aqadm.drop_subscriber to drop the object
ORA-24171: creation properties are only for internal use
Cause: user specified not null creation properties when creating rules engine objects, which are not for external use
Action: do not set creation properties when creating rules engine objects
ORA-24172: rule set string.string has errors
ORA-24173: nested query not supported for rule condition
Cause: user specified nested query in rule condition.
Action: do not use nested query in rule condition.
ORA-24174: The number of string per evaluation context is more than string
Cause: Number of tables or variables were more than the defined upper limit.
Action: Reduce the number of tables or variables per evaluation context.
ORA-24175: The number of string exceeds limit string as there exists at least one nonsimple rule condition
Cause: Upper limit of tables or variable per evaluation context exceeded as there exists at least one nonsimple rule condition.
ORA-24180: invalid transformation expression, the transformation expression does not evaluate to the target type/attribute
Cause: The transformation expression does not evaluate to the target type or the target type's specified attribute.
Action: Provide valid transformation expression which evaluates to the target type or the target type's specified attribute.
ORA-24181: The type string does not exist
Cause: The source or destination type for the transformation does not exist
Action: Create the type or specify one that exists
ORA-24182: attribute number specified does not exist
Cause: The target type of the transformation does not have the attribute number specified in the ADD_ATTRIBUTE_TRANSFORMATION command
Action: check the target type definition and specify a valid attribute number
ORA-24183: invalid transformation
Cause: The transformation specified is invalid because the source or the target type have been dropped/modified.
Action: Drop and recreate the transformation
ORA-24184: transformation string.string already exists
Cause: The named transformation already exists.
Action: Specify another name for the transformation being created.
ORA-24185: transformation string.string does not exist
Cause: The specified transformation does not exist.
Action: Create the transformation before using it or specify an existing transformation.
ORA-24186: wrong object type, could not transform message
Cause: The object type of the message to be transformed does not match the source type of the specified transfomation.
Action: Specify another transformation, or specify a message of the correct type.
ORA-24190: length of payload exceeds string
Cause: the length of payload being taken exceeds the limit of varchar2 or raw.
Action: use clob type or blob type to call get_text or get_bytes.
ORA-24191: the property name string has existed
Cause: the property name being set has existed.
Action: use another property name.
ORA-24192: the property name cannot be null
Cause: the property name cannot be null.
Action: make sure the property name not null.
ORA-24193: the property value exceeds the valid range string
Cause: the property valus being set exceeds the valid range.
Action: make sure the property value is within the valid range.
ORA-24194: attempt to read data in a message as the wrong type
Cause: According to JMS specification, some type conversions were not allowed.
Action: Make sure to use the correct READ function to retrieve message data.
ORA-24195: attemp to retrieve the name list of a map message with size exceeding 1024
Cause: The GET_NAMES function returns the names in a varray with a size limit of 1024.
Action: Retrieve in several smaller steps using the GET_NAMES function with OFFSET and LENGTH parameters.
ORA-24196: access the message in a wrong access mode
Cause: StreamMessage and BytesMessage could not be read when they were in write only mode and vice versa.
Action: Change the access mode using PREPARE, CLEAR_BODY and RESET procedures.
ORA-24197: JAVA stored procedure throws JAVA exceptions
Cause: The JAVA stored procedure threw some exceptions that could not be catergorized.
Action: Use GET_EXCEPTION procedure to see what the exception is about.
ORA-24198: attempt to use an invalid operation ID
Cause: An attempt was made to use an invalid operation ID to access messages.
Action: Use the correct operation ID returned by PREPARE or CLEAR_BODY procedure.
ORA-24199: message store is overflow
Cause: An attemp was made to access too many messages at the same time.
Action: Use the CLEAN procedure to clean up some of the messages.
ORA-24201: duplicate publisher, publisher already added to the queue
Cause: Attempted to add a publisher to the queue again.
Action: Specify another publisher or user DBMS_AQADM.ALTER_PUBLISHER to alter the publisher's properties.
ORA-24202: publisher does not exist for the queue
Cause: Attempted to alter or drop a non existent publisher from a queue.
Action: Specify another publisher.
ORA-24203: operation failed, queue table string.string has errors
Cause: An operation attempt was made to a queue table which has errors.
ORA-24204: existing string propagation schedules
Cause: A propagation administrative interface was called when the existing propagation schedules were running in different mode (10.2/11g).
Action: Set appropriate internal parameter and unschedule existing schedules if required.
ORA-24205: feature string not supported for sharded queues
Cause: An attempt was made to use a feature that is not supported for sharded queues.
Action: Specify only supported features and try again.
ORA-24206: maximum limit of string nondurable subscribers reached for queue string.string
Cause: An attempt to add a new nondurable subscriber to the queue failed because the number of nondurable subscribers has exceeded the maximum limit.
Action: Remove existing subscribers and then attempt to add a new subscriber.
ORA-24207: addition of a nondurable subscriber for queue string.string aborted due to low SGA
Cause: An attempt to add a new nondurable subscriber on the specified queue was aborted because of memory constraints.
Action: Increase the shared pool size by increasing the value of the SHARED_POOL_SIZE parameter.
ORA-24208: API not supported for non-sharded queues
Cause: An attempt was made to use a sharded queue API on a non-sharded queue.
Action: Use non-sharded queue APIs.
ORA-24209: nondurable subscriber rule has errors for queue string
Cause: An attempt was made to create a nondurable subscriber with a rule condition, but the condition had compilation errors.
Action: Correct the condition statement based on the error stack.
ORA-24210: attempt to string string on queue string.string, string already string
Cause: An attempt was made to start or stop a queue operation on a queue which is already enabled or disabled for that operation.
Action: Make only one attempt to start or stop the queue operation.
ORA-24230: input to DBMS_DDL.WRAP is not a legal PL/SQL unit
Cause: The input supplied to DBMS_DDL.WRAP or DBMS_DDL.CREATE_WRAPPED did not specify a legal PL/SQL package specification, package body, type specification, type body, function or procedure. This error can occur if you used incorrect syntax in the CREATE OR REPLACE statement or specified a unit that cannot be wrapped (e.g., a trigger or anonymous block).
Action: Provide a legal PL/SQL unit as input.
ORA-24231: database access descriptor (DAD) string not found
Cause: The specified Database Access Descriptor (DAD) did not exist.
Action: Make sure the name of the Database Access Descriptor (DAD) is correct and the DAD exists.
ORA-24232: unknown Embedded PL/SQL Gateway attribute string
Cause: The specified Embedded PL/SQL Gateway attribute was not known.
Action: Make sure the name of the Embedded PL/SQL Gateway attribute is correct.
ORA-24233: argument passed to DBMS_UTILITY.VALIDATE is not legal
Cause: One or more input arguments to the DBMS_UTILITY.VALIDATE routine was not legal. This error occurred because the object name or owner or namespace arguments (if specified) were NULL or illegal.
Action: Identify and correct the illegal argument.
ORA-24234: unable to get source of string "string"."string", insufficient privileges or does not exist
Cause: The specified PL/SQL object in a DBMS_PREPROCESSOR subprogram did not exist or you did not have the privileges necessary to view its source.
Action: Make sure the specified object exists and you have the privileges necessary to view its source.
ORA-24235: bad value for object type: string
Cause: The specified object type was not appropriate.
Action: Make sure the specified object type is one of the following: package, package body, procedure, function, trigger, type, and type body.
ORA-24236: source text is empty
Cause: The input source text supplied to a DBMS_PREPROCESSOR subprogram was empty.
Action: Pass a non-empty input source text as the input.
ORA-24237: object id argument passed to DBMS_UTILITY.INVALIDATE is not legal
Cause: This error occurred because the p_object_id argument passed to the DBMS_UTILITY.INVALIDATE routine was NULL, there was no object with the specified object id, or the user calling the routine did not have sufficient privileges to invalidate the object.
Action: Correct the illegal argument.
ORA-24238: object settings argument passed to DBMS_UTILITY.INVALIDATE is not legal
Cause: This error occurred because the p_plsql_object_settings argument passed to the DBMS_UTILITY.INVALIDATE routine was NULL or malformed.
ORA-24239: object could not be invalidated
Cause: A call to the DBMS_UTILITY.INVALIDATE routine failed. This error occurred because the object type of the object specified by the p_object_id argument is not one of the types that can be handled by this routine. Alternately, the object was an object type specification with table dependents, or the object was the specification of the STANDARD, DBMS_STANDARD, DBMS_UTILITY package, or the body of the DBMS_UTILITY package.
Action: Call DBMS_UTILITY.INVALIDATE only on supported object types.
ORA-24240: invalid database access descriptor (DAD) name
Cause: The specified Database Access Descriptor (DAD) name was invalid.
Action: Make sure the name of the Database Access Descriptor (DAD) is valid and its length does not exceed its limit.
ORA-24241: source text is in wrapped format
Cause: The input source text supplied to a DBMS_PREPROCESSOR subprogram was in wrapped format.
Action: Pass a nonwrapped source text as the input.
ORA-24242: anonymous access through a dynamically authenticated Database Access Descriptor (DAD) prohibited
Cause: An attempt to allow anonymous access through a dynamically authenticated Database Access Descriptor (DAD) was prohibited.
Action: Make sure the Database Access Descriptor (DAD) is not dynamically authenticated before allowing anonymous access through it.
ORA-24243: access control entry (ACE) already exists
Cause: An access control entry (ACE) for the principal with the same grant or deny attribute in the IS_GRANT argument already existed.
Action: Add the privilege to the existing access control entry (ACE) instead.
ORA-24244: invalid host or port for access control list (ACL) assignment
Cause: The host or port to which the access control list (ACL) was assigned was invalid.
Action: Ensure the host and port to which you are assigning the access control list (ACL) are valid.
ORA-24245: invalid network privilege
Cause: The network privilege being added to the access control list (ACL) was invalid.
Action: Ensure the network privilege that you are adding to the access control list (ACL) is valid.
ORA-24246: empty access control list (ACL) not allowed
Cause: An attempt was made to store an empty access control list (ACL).
Action: Ensure that the access control list (ACL) has at least one
ORA-24247: network access denied by access control list (ACL)
Cause: No access control list (ACL) has been assigned to the target host or the privilege necessary to access the target host has not been granted to the user in the access control list.
Action: Ensure that an access control list (ACL) has been assigned to the target host and the privilege necessary to access the target host has been granted to the user.
ORA-24248: XML DB extensible security not installed
Cause: XML DB extensible security necessary for this operation has not been installed.
Action: Ensure that XML DB has been installed.
ORA-24249: Authentication scheme "string" not supported
Cause: An unsupported authentication scheme was used.
Action: Retry with a supported authentication scheme.
ORA-24250: No supported authentication scheme found
Cause: A supported authentication scheme was not found.
ORA-24251: This statement is not supported by EXPAND_SQL_TEXT.
Cause: EXPAND_SQL_TEXT supports only SELECT statements.
Action: Submit only a SELECT statement.
ORA-24252: SQL translation profile does not exist
Cause: An attempt was made to access a SQL translation profile that either did not exist or for which the current user did not have privileges on.
Action: Check the SQL translation profile name and verify that the current user has appropriate privileges on the SQL translation profile.
ORA-24253: translation of SQL statement or error code not found
Cause: An attempt to translate a SQL statement or error code or to change a SQL or error code translation failed because the translation was not found.
Action: Verify that the SQL statement or error code is valid and either a custom translation is registered or the translator package in the SQL translation profile can translate it.
ORA-24254: appropriate SQL translation profile not set
Cause: An attempt to translate a SQL statement or error code failed because either a SQL translation profile was not set or the profile could not translate the given SQL syntax.
Action: Set an appropriate SQL translation profile before attempting to translate a SQL statement or error code.
ORA-24255: Implementation restriction: bind variables cannot change in the translated SQL statement
Cause: An attempt to register or use a translated SQL statement failed because the number or the order of bind variables were changed in the statement.
Action: Do not change the number or the order of bind variables in the translated SQL statement.
ORA-24256: EXPAND_SQL_TEXT failed with string
Cause: See the string parameter at the end of the message.
Action: See the string parameter at the end of the message and take corrective action.
ORA-24265: Insufficient privileges for SQL profile operation
Cause: A DDL operation was attempted on a SQL profile by a session without the proper privileges.
Action: Grant the user the appropriate privilege.
ORA-24270: a row already exists in the string table for these parameters
Cause: A call was made to create a new row in the specified table. A row already exists in the table with the specified values.
Action: Delete the existing row using the appropriate API or check the parameters used to create the row.
ORA-24271: translation type must be either T, S or M
Cause: The translation type parameter is not a T, S or an M. A value other than T, S or M was specified.
Action: Correct the translation type and reexecute the API call.
ORA-24272: initialization value must be either F or T
Cause: The initialization value must be either F or T. A value other than F or T was specified.
Action: Correct the initialization value and reexecute the API call.
ORA-24273: translation text is required if translation type is T or S
Cause: If a translation type of T or S is specified, translation text must be supplied.
Action: Provide translation text and reexecute the API call.
ORA-24274: no row exists in the string table for these parameters
Cause: A call was made to update a row that does not exist or a foreign key value supplied to create a table does not exist.
Action: Create the row using the appropriate API or check the parameters used to create the new row to ensure that all specified values exist.
ORA-24275: function 'string' parameter 'string' missing or invalid
Cause: The function <pkgname.funcname> was called with a parameter parmname that was null, 0 length, or had an invalid value.
Action: Correct the parameter to supply values that comply with its datatype and limits as specified in the documentation.
ORA-24276: function 'string' output 'string' maximum value exceeded
Cause: The function <pkgname.funcname> computed a value for the output parmname that exceeded the maximum allowed. This can occur when multiple input parameters, each valid separately, combine to specify an invalid result. For example, when a length parameter multiplied by a copies parameter yields a total length exceeding the maximum for the output datatype.
Action: Correct the input values to produce a result that will comply with the limits as specified in the documentation.
ORA-24277: invalid database link string
Cause: The database link did not exist.
Action: Make sure the database link name is correct.
ORA-24278: remote table string not found
Cause: The table did not exist in the remote database.
Action: Make sure the remote table name is correct.
ORA-24279: view string is not a parallel access view
Cause: The view was not created by CREATE_OR_REPLACE_VIEW API.
Action: Provide the correct view name that was created by CREATE_OR_REPLACE_VIEW API.
