Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
74 ORA-32800 to ORA-32857
ORA-32800: internal error string
Cause: An unexpected error occurred.
Action: Contact Oracle Support Services.
ORA-32801: invalid value string for string
Cause: An invalid value was specified for a parameter.
Action: Specify a valid value for the parameter.
ORA-32802: value for string must be string
Action: Specify the value as indicated by the message.
ORA-32803: value for string cannot be altered
Cause: An attempt was made to alter a value that cannot be altered.
Action: Retry the operation without altering the indicated value.
ORA-32804: invalid value string, string should have form string
Cause: A value specified for a parameter has the incorrect form.
Action: Specify a string of the correct form.
ORA-32805: identifier for string too long, maximum length is string characters
Cause: An identifier string exceeded the maximum allowed length.
Action: Specify a string whose length is less than the maximum allowed length.
ORA-32806: value for string is too long, maximum length is string
Cause: A value exceeded it's maximum allowed length.
Action: Specify a value whose length is less than the maximum allowed length.
ORA-32807: message system link string already exists
Cause: A message system link of the specified name already exists.
Action: Specify a different name.
ORA-32808: message system link string does not exist
Cause: A message system link of the specified name does not exist.
Action: Specify a message system link name that already exists.
ORA-32809: foreign queue string is already registered
Cause: The foreign queue has already been registered for this message system link (NAME@MSGLINK).
Action: Specify a different name that is not being used for this message system link.
ORA-32810: foreign queue string is not registered
Cause: The foreign queue (NAME@MSGLINK) has not been registered for this message system link.
Action: Specify the name of a registered foreign queue.
ORA-32811: subscriber string already exists
Cause: The specified subscriber identifier already exists.
Action: Specify a different identifier.
ORA-32812: subscriber string does not exist
Cause: The specified subscriber identifier does not exist.
Action: Specify an existing subscriber identifier.
ORA-32813: propagation schedule string already exists
Cause: The specified propagation schedule identifer already exists.
ORA-32814: propagation schedule string does not exist
Cause: The specified propagation schedule identifier does not exist.
Action: Specify a schedule identifier that already exists.
ORA-32815: message system link string is referenced by a foreign queue
Cause: An attempt was made to remove a message system link currently referenced by one or more registered foreign queues.
Action: Unregister all foreign queues using this message system link and retry the operation.
ORA-32816: foreign queue string is referenced by a subscriber or schedule
Cause: An attempt was made to unregister a foreign queue currently referenced by one or more subscribers or propagation schedules.
Action: Remove all subscribers and propagation schedules using this foreign queue and retry the operation.
ORA-32817: message system link string is not configured with a log queue for string
Cause: An attempt was made to add a propagation subscriber but the message system link was not configured with a log queue for the indicated propagation type.
Action: Alter the message system link to configure the link with a log queue for this propagation type.
ORA-32818: AQ queue string does not exist
Cause: An operation was attempted where the specified AQ queue does not exist.
Action: Specify the name of an existing AQ queue.
ORA-32819: AQ queue string must be a normal queue
Cause: An operation was attempted where the specified AQ queue exists but is not a normal queue.
Action: Specify the name of an AQ queue which was created as a normal queue (NORMAL_QUEUE).
ORA-32820: subscriber queue and exception queue must use same message system link
Cause: An operation was attempted for INBOUND propagation where the specified subscriber queue and exception queue reference different message system links.
Action: Specify an exception queue that is a registered foreign queue of the same message system link as the subscriber queue.
ORA-32821: subscriber queue and exception queue must have same payload type
Cause: An operation was attempted for OUTBOUND propagation where the AQ queues used for the subscriber queue and exception queue have different payload types.
Action: Specify an exception queue that has the same payload type as the subscriber queue.
ORA-32822: subscriber string is marked for removal
Cause: An administration operation was attempted for a subscriber which is marked for removal. If attempting to remove a subscriber, the Messaging Gateway agent is not running or is running but unable to remove the subscriber at this time.
Action: Do not issue propagation administration commands for a subscriber for which removal is pending. Wait for the subscriber to be removed by the agent or issue REMOVE_SUBSCRIBER with the FORCE option to force the subscriber to be removed.
ORA-32823: subscriber exists for queue string and destination string
Cause: An attempt was made to create a propagation subscriber when one already exists for the specified queue and destination pair.
Action: Specify a different queue and destination pair, or remove the subscriber using that pair and retry the operation.
ORA-32824: schedule exists for source string and destination string
Cause: An attempt was made to create a propagation schedule when one already exists for the specified source and destination pair.
Action: Specify a different source and destination pair, or remove the schedule using that pair and retry the operation.
ORA-32825: Messaging Gateway agent has not been started
Cause: An attempt was made to shut down the Messaging Gateway agent when it is not started.
Action: No action required.
ORA-32826: Messaging Gateway agent has already been started
Cause: An attempt was made to start the Messaging Gateway agent when it is already started.
ORA-32827: Messaging Gateway agent must be shut down
Cause: An operation was attempted that requires the Messaging Gateway agent to be shut down.
Action: Issue SHUTDOWN, wait for MGW_GATEWAY view to show a NOT_STARTED status, and retry the operation. CLEANUP_GATEWAY may need to be issued to reset the gateway state if the agent fails to shut down after a reasonable time period.
ORA-32828: Messaging Gateway agent must be running
Cause: An operation was attempted that requires the Messaging Gateway agent to be started and responsive.
Action: Issue STARTUP, wait for MGW_GATEWAY view to show a RUNNING status, and retry the operation.
ORA-32829: Messaging Gateway agent cannot be shut down while it is starting
Cause: An attempt was made to shut down the Messaging Gateway agent when it is in the process of starting and initializing.
Action: Wait for MGW_GATEWAY view to show a RUNNING status and retry the operation. CLEANUP_GATEWAY may need to be issued to reset the gateway state if the agent fails to start after a reasonable time period.
ORA-32830: result code string returned by Messaging Gateway agent
Cause: The Messaging Gateway agent terminated abnormally due to an unexpected error.
Action: Review the Messaging Gateway log file for further information regarding the problem. Resolve the problem and start the Messaging Gateway agent. Contact Oracle Support Services if the problem cannot be resolved.
ORA-32831: timed out trying to acquire administration lock
Cause: A timeout occurred when attempting an administration operation. Either an administration operation was attempted while the Messaging Gateway agent was starting and initializing, or two administration operations were attempted at the same time.
Action: Retry the operation. If the Messaging Gateway agent is starting, wait for MGW_GATEWAY view to show a RUNNING status and retry the operation.
ORA-32832: failure string trying to acquire administration lock
Cause: An unexpected error occurred trying to acquire administration lock.
Action: Retry the operation. Contact Oracle Support Services if the error persists.
ORA-32833: failure string trying to release administration lock
Cause: An unexpected error occurred trying to release administration lock.
Action: Contact Oracle Support Services if the error persists.
ORA-32834: Messaging Gateway agent user has not been set
Cause: A Messaging Gateway agent user has not been configured.
Action: Create a database user having role MGW_AGENT_ROLE and issue DB_CONNECT_INFO to configure an agent user.
ORA-32835: database user string does not exist
Cause: The specified database user does not currently exist.
Action: Create the user and grant all necessary privileges and roles.
ORA-32836: database user string must be granted role string
Cause: The specified database user does not have a required role.
Action: Grant the user the indicated role.
ORA-32837: invalid configuration state string
Cause: The specified configuration state is invalid.
Action: Remove and re-create the configured entities. Contact Oracle Support Services if the problem cannot be identified or resolved.
ORA-32838: exceeded maximum number of properties
Cause: An attempt was made to alter a property list where the number of properties in the resulting list exceeds the maximum allowed.
Action: Order the elements of the alter list differently so the number of elements in the resulting list is less than the maximum.
ORA-32839: property string is reserved, names with MGWPROP$_ prefix are not valid
Cause: An attempt was made to specify a reserved name for a property name.
Action: Use a non-reserved name.
ORA-32840: property name cannot be NULL
Cause: An attempt was made to use NULL for a property name.
Action: Specify a non-NULL name.
ORA-32841: invalid value for property string
Cause: An attempt was made to specify an invalid value for a property.
Action: Specify a valid property value.
ORA-32842: value for property string cannot be altered
Cause: An attempt was made to alter a property that cannot be altered.
Action: Retry the operation without altering the indicated property.
ORA-32843: value for string is outside the valid range of string to string
Cause: A value was specified that is not in the valid range.
Action: Specify a value within the indicated range.
ORA-32844: exceeded maximum number of string values
Cause: An attempt was made to add a value of the specified type but the maximum number of such values has been reached.
ORA-32845: Messaging Gateway agent is already running
Cause: An attempt was made to start the Messaging Gateway agent when an agent instance is already running.
Action: Shut down the Messaging Gateway agent currently running, verify the agent process has been terminated, and start the Messaging Gateway agent.
ORA-32846: Messaging Gateway agent cannot be started; status is string
Cause: An attempt to start the Messaging Gateway agent failed due to the indicated agent status. A BROKEN status indicates a problem that requires user intervention before the agent can be started.
Action: Review the MGW_GATEWAY view and the Messaging Gateway log file for further information. Resolve the problem and start the Messaging Gateway agent. Contact Oracle Support Services if the problem cannot be resolved.
ORA-32847: operation is not supported on this platform
Cause: An attempt was made to perform an operation that is not supported on this platform.
Action: Switch to a platform on which the operation is supported.
ORA-32848: foreign queue DOMAIN required for JMS unified connections
Cause: A DOMAIN was not specified when registering a foreign queue for a messaging system link that is configured to use the JMS unified messaging model.
Action: Specify a non-NULL value for the DOMAIN parameter.
ORA-32849: string cannot be set unless string is set
Cause: An attempt was made to specify a value for a parameter that cannot be set unless an associated parameter is also set.
Action: Specify a valid value for both parameters, or, do not specify a value for either parameter.
ORA-32850: agent string does not exist
Cause: The specified Messaging Gateway agent name did not exist.
Action: Specify an existing agent name.
ORA-32851: agent string already exists
Cause: The specified Messaging Gateway agent name already existed.
Action: Specify a different agent name.
ORA-32852: agent string is referenced by a message system link
Cause: An attempt was made to remove a Messaging Gateway agent currently referenced by one or more message system links.
Action: Remove all message system links associated with this agent and retry the operation.
ORA-32853: propagation job string does not exist
Cause: The specified propagation job identifier did not exist.
Action: Specify an existing identifier.
ORA-32854: propagation job string already exists
Cause: The specified propagation job identifier already existed.
ORA-32855: propagation job string is marked for removal
Cause: An administration operation was attempted for a propagation job which is marked for removal. If attempting to remove a job, the Messaging Gateway agent is not running or is running but unable to remove the job at this time.
Action: Do not issue propagation administration commands for a job for which removal is pending. Wait for the job to be removed by the agent, or, issue REMOVE_JOB with the FORCE option to force the job to be removed.
ORA-32856: operation not supported for propagation job
Cause: An attempt was made to perform an operation that was not supported for a propagation job.
Action: Perform the operation using a propagation job procedure.
ORA-32857: propagation job exists for source string and destination string
Cause: An attempt was made to create a propagation job, subscriber, or schedule when a propagation job already existed for the specified source and destination pair.
Action: Specify a different source and destination pair, or remove the propagation job using that pair and retry the operation.
