Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
81 ORA-47000 to ORA-47999
ORA-47000: Factor Type string already defined
Cause: The object with this name exists already
Action: Choose a unique object name and retry the operation
ORA-47001: Factor Type string not found
Cause: The object being requested does not exist
Action: Choose an object name that exists and retry the operation
ORA-47002: error creating Factor Type string, string
Cause: An unexpected error occurred creating the factor type
Action: Please review the definition and retry the operation
ORA-47003: error deleting Factor Type string, string
Cause: An unexpected error occurred deleting the factor type
ORA-47004: error updating Factor Type string, string
Cause: An unexpected error occurred updating the factor type
ORA-47005: error renaming Factor Type string, string
Cause: An unexpected error occurred renaming the factor type
ORA-47020: Factor string already defined
ORA-47021: Factor string not found
ORA-47022: error creating Factor string, string
Action: Please review the definition for accuracy and retry the operation
ORA-47023: error deleting Factor string, string
ORA-47024: error updating Factor string, string
ORA-47025: Factor Link already exists for string and string
ORA-47026: error creating Factor Link for string and string, string
Cause: An unexpected error occurred creating the factor link
ORA-47027: Factor Link does not exist for string and string
Cause: The factor link referenced does not exist
ORA-47028: error deleting Factor Link for string and string, string
Cause: An unexpected error occurred deleting the factor link
ORA-47029: Factor type string is used by one or more factors.
Cause: The specified factor type was used by existing factor(s).
Action: Remove the dependent factors and retry the operation.
ORA-47030: Factor string is referred by one or more factor links.
Cause: The specified factor was referred by existing factor link(s).
Action: Remove the dependent factor links and retry the operation.
ORA-47031: Factor string is used by one or more policy factors.
Cause: The specified factor was used by existing policy factor(s).
Action: Remove the dependent policy factors and retry the operation.
ORA-47032: Factor string is referred by one or more identities.
Cause: The specified factor was referred by existing identities.
Action: Remove the dependent identities and retry the operation.
ORA-47033: Factor link for string and string is referred by one or more identity maps.
Cause: The specified factor link was referred by existing identity maps.
Action: Remove the dependent identity maps and retry the operation.
ORA-47040: Identity string for Factor string already defined
ORA-47041: Identity string for Factor string not found
ORA-47042: error creating Identity string for Factor string, string
Cause: An unexpected error occurred creating the identity
ORA-47043: error deleting Identity string for Factor string, string
Cause: An unexpected error occurred deleting the identity
ORA-47044: error updating Identity string for Factor string, string
Cause: An unexpected error occurred updating the identity
ORA-47045: Identity string for Factor string is used by one or more identity maps.
Cause: The specified identity was used by exiting identity map(s).
ORA-47046: Identity string for Factor string is referred by one or more policy labels.
Cause: The specified identity was used by exiting policy label(s).
Action: Remove the dependent policy labels and retry the operation.
ORA-47060: Identity map for Identity string.string, Factor Link string, string already defined for operation string on string
ORA-47061: Identity map for Identity string.string, Factor Link string, string not found for operation string on string
ORA-47062: error creating Identity map for Identity string.string, Factor Link string, string already defined for operation string on string
ORA-47063: error deleting Identity map for Identity string.string, Factor Link string, string already defined for operation string on string
ORA-47080: code string already defined in group string
ORA-47081: code string not found in group string
ORA-47100: Command Rule string already defined for string.string
ORA-47101: Command Rule string not found for string.string
ORA-47102: error creating Command Rule string for string.string, string
Cause: An unexpected error occurred creating the command rule
ORA-47103: error deleting Command Rule string for string.string, string
Cause: An unexpected error occurred deleting the command rule
ORA-47104: error updating Command Rule string for string.string, string
Cause: An unexpected error occurred updating the command rule
ORA-47105: invalid object owner string for command string
Cause: The object owner is invalid for this command
Action: Choose an object owner other than SYS or a wildcard for this command
ORA-47120: Document string already defined
ORA-47121: Document string not found
ORA-47140: Factor expression string already defined
ORA-47141: Factor expression string not found
Cause: The object being requested does not exists
ORA-47160: Factor link string already defined
ORA-47161: Factor link string not found
ORA-47180: Integration Policy for OLS Policy string is already defined
ORA-47181: Integration Policy for OLS Policy string not found
ORA-47182: Label algorithm string not found
ORA-47183: error creating Integration Policy for OLS Policy string, string
Cause: An unexpected error occurred creating the integration policy
ORA-47184: error updating Integration Policy for OLS Policy string, string
Cause: An unexpected error occurred updating the integration policy
ORA-47185: error deleting Integration Policy for OLS Policy string, string
Cause: An unexpected error occurred deleting the integration policy
ORA-47200: Integration Policy Factor already defined for Factor string and Policy string
ORA-47201: Integration Policy Factor not found for Factor string and Policy string
ORA-47202: error creating Integration Policy Factor for factor string and policy string, string
Cause: An unexpected error occurred creating the integration policy factor
ORA-47203: error deleting Integration Policy Factor for factor string and policy string, string
Cause: An unexpected error occurred deleting the integration policy factor
ORA-47220: Label string for Identity string.string under OLS Policy string already defined
ORA-47221: Label string for Identity string.string under OLS Policy string not found
ORA-47222: error creating Label string for Identity string.string under OLS Policy string, string
Cause: An unexpected error occurred creating the identity label
ORA-47223: error deleting Label string for Identity string.string under OLS Policy string, string
Cause: An unexpected error occurred deleting the identity label
ORA-47240: Realm string already defined
ORA-47241: Realm string not found
ORA-47242: error creating Realm string, string
Cause: An unexpected error occurred creating the realm
ORA-47243: error deleting Realm string, string
Cause: An unexpected error occurred deleting the realm
ORA-47244: error updating Realm string, string
Cause: An unexpected error occurred updating the realm
ORA-47245: error renaming Realm string, string
Cause: An unexpected error occurred renaming the realm
ORA-47246: cannot change default realm string to mandatory realm
Cause: An attempt was made to change the realm type of this default realm to mandatory realm.
Action: No action required.
ORA-47260: Realm Authorization to string for Realm string already defined
ORA-47261: Realm Authorization to string for Realm string not found
ORA-47262: error creating Realm Authorization to string for Realm string, string
Cause: An unexpected error occurred creating the realm authorization
ORA-47263: error deleting Realm Authorization to string for Realm string, string
Cause: An unexpected error occurred deleting the realm authorization
ORA-47264: error updating Realm Authorization to string for Realm string, string
Cause: An unexpected error occurred updating the realm authorization
ORA-47280: Realm Object string,string.string already defined in Realm string
ORA-47281: Realm Object string,string.string not found in Realm string
ORA-47282: error adding Realm Object string,string.string to Realm string, string
Cause: An unexpected error occurred creating the realm object
ORA-47283: error deleting Realm Object string,string.string from Realm string, string
Cause: An unexpected error occurred deleting the realm object
ORA-47284: error adding Realm Object string.string. string is not a valid object type
Cause: The specified object type is not valid.
Action: Enter a valid object type for the specified object name, or enter "%" and all objects with the specified name and the specified owner will be added to the realm.
ORA-47290: error creating VPD policy for Realm string, string
Cause: An unexpected error occurred creating the VPD policy
ORA-47300: Role already string defined
ORA-47301: Role string not found
ORA-47302: error creating Role string, string
Cause: An unexpected error occurred creating the role
ORA-47303: error deleting Role string, string
Cause: An unexpected error occurred deleting the role
ORA-47304: error updating Role string, string
Cause: An unexpected error occurred updating the role
ORA-47305: Rule Set violation on string (string)
Cause: An operation that was attempted failed due to a rule set violation
Action: Ensure you have sufficient privileges for this operation retry the operation
ORA-47320: Rule string already defined
ORA-47321: Rule string not found
ORA-47322: error creating Rule string, string
Cause: An unexpected error occurred creating the rule
ORA-47323: error deleting Rule string, string
Cause: An unexpected error occurred deleting the rule
ORA-47324: error updating Rule string, string
Cause: An unexpected error occurred updating the rule
ORA-47325: Rule string is used by one or more rule sets.
Cause: The specified rule was used by existing rule set(s).
Action: Remove the dependent rule sets and retry the operation.
ORA-47340: Rule Set string already defined
ORA-47341: Rule Set string not found
ORA-47342: error creating Rule Set string, string
Cause: An unexpected error occurred creating the rule set
ORA-47343: error deleting Rule Set string, string
Cause: An unexpected error occurred deleting the rule set
ORA-47344: error updating Rule Set string, string
Cause: An unexpected error occurred updating the rule set
ORA-47345: Rule set string is used by one or more realm authorizations.
Cause: The specified rule set was used by existing realm authorization(s).
Action: Remove the dependent realm authorizations and retry the operation.
ORA-47346: Rule set string is used by one or more command rules.
Cause: The specified rule set was used by existing command rule(s).
Action: Remove the dependent command rules and retry the operation.
ORA-47347: Rule set string is used by one or more secure application roles.
Cause: The specified rule set was used by existing secure application role(s).
Action: Remove the dependent secure application roles and retry the operation.
ORA-47348: Rule set string is used by one or more factors.
Cause: The specified rule set was used by existing factor(s).
ORA-47349: error occurred when executing the rule set handler
Cause: Either there was a syntax error on the rule set handler or DVSYS did not have sufficient privilege to execute the rule set handler.
Action: Fix the syntax error on the rule set handler or grant execute privilege on the rule set handler to DVSYS.
ORA-47360: rule string already added to rule set string
Cause: The object with this name existed already.
Action: Choose a unique object name and retry the operation.
ORA-47361: rule string not associated to rule set string
Cause: The rule specified was not associated to the rule set.
Action: Review the definition for accuracy and retry the operation.
ORA-47362: error adding rule string to rule set string, string
Cause: An unexpected error occurred while adding the rule to the rule set.
ORA-47363: error deleting rule string from rule set string, string
Cause: An unexpected error occurred while deleting the rule from the rule set.
ORA-47381: Oracle Label Security (OLS) Policy string not found
Cause: The object being requested did not exist.
Action: Choose an object name that exists and retry the operation.
ORA-47382: Oracle Label Security (OLS) Policy Label string not found for policy string
ORA-47383: error capturing the session state information
Cause: An internal error occurred capture the session state
Action: Please retry the operation if possible
ORA-47390: failed to audit event, string
Cause: An internal error auditing the operation
ORA-47391: attempt to set Factor string violates Rule Set string
Cause: An attempt to set the factor violated the associated rule set
Action: Please check to ensure you have the ability to set the factor
ORA-47392: Factor string cannot be set
Cause: The attempt to set the factor is not allowed
Action: This factor cannot be set so there is no corrective action
ORA-47393: Factor string value not allowed
Cause: The value being assigned to the factor is not allowed
Action: This factor cannot be set to this value so there is no corrective action
ORA-47394: Factor assignment rule set not defined
Cause: The rule set being associated to the factor does not exist
ORA-47395: error returned by Factor string evaluation expression string
Cause: The factor retrieval method resulted in an error
Action: Please review the retrieval method definition for accuracy and correct it as required
ORA-47396: error returned by Factor string validation expression string
Cause: The factor retrieval method resulted in an invalid value based on its validation method
Action: Please review the factor definition and correct it as required
ORA-47397: incorrect identified by value for Factor string
Cause: The factor identified by value is incorrect
ORA-47398: multiple identities defined for Factor string
Cause: The factor has duplicate identities defined
ORA-47399: incorrect labeled by value for Factor string
Cause: The factor labeled by value is incorrect
ORA-47400: Command Rule violation for string on string
Cause: An operation that was attempted failed due to a command rule violation
ORA-47401: Realm violation for string on string.string
Cause: An operation that was attempted failed due to a realm protection
ORA-47402: incorrect evaluation options value for Factor string
Cause: The factor evaluations options value is incorrect
ORA-47403: NULL returned by Factor string evaluation expression string
Cause: The factor evaluated to a NULL value
ORA-47404: NULL trust level for Factor string
Cause: The factor has a NULL trust level
ORA-47405: negative trust level for Factor string
Cause: The factor has a negative trust level
ORA-47406: ALWAYS AUDIT option set for Factor string
Cause: The factor audit option is set to always audit
ORA-47407: ALWAYS AUDIT option set for Rule Set string
Cause: The rule set audit option is set to always audit
ORA-47408: Realm violation for the EXECUTE command
Cause: A realm violation has occurred for a realm-protected stored procedure.
Action: In order to invoke the realm-protected procedure, you must have GRANT privileges to execute the procedure, or you must be authorized to operate in the procedure's realm.
ORA-47409: Command Rule violation for the EXECUTE command
Cause: A command rule violation occurred when trying to perform the EXECUTE command for a stored procedure protected by a command rule.
Action: Ask the Database Vault administrator to perform the operation or remove the command rule for the protected stored procedure.
ORA-47410: Realm violation for string on string
Cause: An operation that was attempted failed with insufficient privileges due to an attempt to violate a Database Vault Realm security policy which is currently enabled and enforced.
Action: Ensure you have sufficient privileges for this operation and retry the operation.
ORA-47411: Cannot use string due to Oracle Database Vault policy.
Cause: An operation that was attempted failed because Database Vault policy currently prevents the related feature from being used.
Action: Ask the Database Vault administrator to allow the feature to be used.
ORA-47412: The DVSYS and DVF users are not allowed to switch containers.
Cause: An attempt was made to switch containers while connecting as DVSYS or DVF, which is not allowed.
Action: Connect as a different user and try again.
ORA-47413: Cannot connect due to Oracle Database Vault policy.
Cause: An attempt to connect to DVSYS or DVF accounts failed because the Database Vault administrator had disabled the account.
Action: Ask the Database Vault administrator to enable the account.
ORA-47500: Database Vault cannot be configured.
Cause: The Database Vault configuration failed because some Database Vault objects were missing.
Action: Run the dvremov.sql script to remove Database Vault and then reinstall Database Vault.
ORA-47501: Database Vault has already been configured.
Cause: An attempt was made to run this procedure more than once. This procedure can be run successfully only once.
Action: If you are attempting to grant the DV_OWNER or DV_ACCTMGR roles, do so manually.
ORA-47502: Database Vault is not yet configured.
Cause: The Database Vault configuration procedure dvsys.configure_dv() had not been run.
Action: Run dvsys.configure_dv() before attempting to enable or disable Database Vault enforcement.
ORA-47503: Database Vault is not enabled on CDB$ROOT.
Cause: Database Vault is required to be enabled on CDB$ROOT for this operation.
Action: Enable Database Vault on CDB$ROOT and retry the operation.
ORA-47504: Common audit policies for component Oracle Database Vault not supported.
Cause: Audit policies for Oracle Database Vault realms, factors and rule sets could not be common audit policies.
Action: If creating audit policies for Oracle Database Vault objects on CDB$ROOT, include the clause 'container=current'.
ORA-47901: OLS policy not specified
Cause: An OLS policy name is required for this operation
Action: Specify a policy name and retry the operation
ORA-47902: OLS policy label not specified
Cause: An OLS policy label is required for this operation
Action: Specify a policy label and retry the operation
ORA-47903: OLS policy label string not found for policy string
Cause: The policy label being requested does not exist
ORA-47904: OLS session label does not exist
Cause: The policy label specified does not exist
Action: Choose a valid policy label and retry the operation
ORA-47905: OLS policy label string is not allowed for policy string
Cause: The policy label specified is not valid for this policy
Action: Choose a valid policy label for this policy and retry the operation
ORA-47906: OLS policy label not specified for identity string.string under policy string
Cause: The policy label is required for this operation
ORA-47907: Database Vault associated OLS policy string not fully configured
Cause: The Oracle Label Security (OLS) policy was associated with Database Vault. But either the policy was not configured with a factor or the current factor identity was not assigned a label.
Action: Based on the cause, either configure a factor with the OLS policy using DVSYS.DBMS_MACADM.ADD_POLICY_FACTOR procedure and assign labels to factor identities using DVSYS.DBMS_MACADM.CREATE_POLICY_LABEL procedure or remove Database Vault association using DVSYS.DBMS_MACADM.DELETE_MAC_POLICY_CASCADE procedure.
ORA-47920: Authorization failed for user string to perform this operation
Cause: The operation attempted is not allowed for this user
Action: Please ensure you have privileges to perform this operation
ORA-47921: error adding host string to domain string, string
Cause: An error occurred adding the host specified to the domain specified
Action: Please review the host and domain definition and correct it as required
ORA-47922: error removing host string to domain string, string
Cause: An error occurred removing the host specified to the domain specified
ORA-47930: Privilege capture string already exists.
Cause: A privilege capture with the given name was already in existence.
Action: Choose another capture name or drop the existing privilege capture.
ORA-47931: Privilege capture string does not exist.
Cause: The given privilege capture did not exist.
Action: Choose another privilege capture.
ORA-47932: Privilege capture string is still enabled.
Cause: The given privilege capture was still enabled.
Action: Choose another capture or disable the given privilege capture.
ORA-47933: Privilege capture string is already enabled.
Cause: The given privilege capture was already enabled.
ORA-47934: Two privilege captures are already enabled.
Cause: The maximum number of two privilege captures were enabled."
Action: Disable one of the enabled privilege captures.
ORA-47935: Another privilege capture is enabled.
Cause: Another capture of the same type or another nondatabase-wide capture was enabled.
Action: Disable the enabled privilege capture.
ORA-47936: Privilege capture string is already disabled.
Cause: The given privilege capture was already disabled.
Action: Choose another capture.
ORA-47937: Input string does not match the given privilege capture type.
Cause: The given input did not match the given privilege capture type.
Action: Change the input or the privilege capture type.
ORA-47938: GENERATE_RESULT is already running for privilege capture string.
Cause: DBMS_PRIVILEGE_CAPTURE.GENERATE_RESULT was already running for the given privilege capture.
Action: Wait and retry later or choose another privilege capture.
ORA-47939: Capture context namespace or attribute does not exist or is invalid.
Cause: Context namespace or attribute used in the capture condition did not exist or was invalid.
Action: Create the namespace or set the attribute or recreate a privilege capture with a valid namespace and attribute.
ORA-47950: no value defined for required parameter string
Cause: The operation requires a value for this parameter
Action: Please specify the missing parameter and retry the operation
ORA-47951: invalid input value or length for parameter 'string'
Cause: The value specified for this parameter is invalid or too large
Action: Please specify the a valid parameter and retry the operation
ORA-47952: Oracle Data Pump authorization for Oracle Database Vault to string already exists
Cause: Oracle Data Pump authorization for Oracle Database Vault was already granted to the given grantee.
Action: Choose a different grantee and retry the operation.
ORA-47953: Oracle Data Pump authorization for Oracle Database Vault to string on schema string already exists
Cause: Oracle Data Pump authorization for Oracle Database Vault on the given schema was already granted to the given grantee.
Action: Choose a different grantee or schema and retry the operation.
ORA-47954: Oracle Data Pump authorization for Oracle Database Vault to string on object string.string already exists
Cause: Oracle Data Pump authorization for Oracle Database Vault on the given object was already granted to the given grantee.
Action: Choose a different grantee or a different object and retry the operation.
ORA-47955: Oracle Data Pump authorization for Oracle Database Vault to string is not found
Cause: Oracle Data Pump authorization for Oracle Database Vault was not granted to the given user.
Action: Choose a user who has Oracle Data Pump authorization for Oracle Database Vault and retry the operation.
ORA-47956: Oracle Data Pump authorization for Oracle Database Vault to string on schema string is not found
Cause: Oracle Data Pump authorization for Oracle Database Vault was not granted to the given user on the given schema.
Action: Choose a different user or schema and retry the operation.
ORA-47957: Oracle Data Pump authorization for Oracle Database Vault to string on object string.string is not found
Cause: Oracle Data Pump authorization for Oracle Database Vault was not granted to the given user on the given object.
Action: Choose a different user or object and retry the operation.
ORA-47958: Running EXP with direct path option is disallowed when Oracle Database Vault is enabled.
Cause: While Oracle Database Vault was enabled, an attempt was made to run EXP with the 'direct=y' option.
Action: Change the option to 'direct=n' or disable Oracle Database Vault and retry the operation.
ORA-47959: Oracle transportable tablespace authorization for Oracle Database Vault to string on tablespace string already exists.
Cause: Oracle transportable tablespace authorization for Oracle Database Vault on the given tablespace was already granted to the given grantee.
Action: Choose a different grantee or tablespace and retry the operation.
ORA-47960: Oracle transportable tablespace authorization for Oracle Database Vault to string on tablespace string is not found.
Cause: Oracle transportable tablespace authorization for Oracle Database Vault was not granted to the given user on the given tablespace.
Action: Choose a different user or tablespace and retry the operation.
ORA-47961: Oracle Scheduler Job authorization for Oracle Database Vault to string already exists
Cause: Oracle Scheduler Job authorization for Oracle Database Vault was already granted to the given grantee.
ORA-47962: Oracle Scheduler Job authorization for Oracle Database Vault to string on schema string already exists
Cause: Oracle Scheduler Job authorization for Oracle Database Vault on the given schema was already granted to the given grantee.
ORA-47963: Oracle Scheduler Job authorization for Oracle Database Vault to string is not found
Cause: Oracle Scheduler Job authorization for Oracle Database Vault was not granted to the given user.
Action: Choose a user who has Oracle Scheduler Job authorization for Oracle Database Vault and retry the operation.
ORA-47964: Oracle Scheduler job authorization for Oracle Database Vault to string on schema string is not found
Cause: Oracle Scheduler job authorization for Oracle Database Vault was not granted to the given user on the given schema.
ORA-47971: Oracle proxy authorization for Oracle Database Vault to string on schema string already exists
Cause: Oracle proxy authorization for Oracle Database Vault on the given schema was already granted to the given grantee.
ORA-47972: Oracle proxy authorization for Oracle Database Vault to string on schema string is not found.
Cause: Oracle proxy authorization for Oracle Database Vault was not granted to the given user on the given schema.
ORA-47973: Oracle DDL authorization for Oracle Database Vault to string on schema string already exists.
Cause: Oracle DDL authorization for Oracle Database Vault on the given schema was already granted to the given grantee.
ORA-47974: Oracle DDL authorization for Oracle Database Vault to string on schema string is not found.
Cause: Oracle DDL authorization for Oracle Database Vault was not granted to the given user on the given schema.
ORA-47985: password same as or similar to user
Cause: The password specified similar to the user account name and therefore insecure
Action: Please specify the more complex password and retry the operation
ORA-47986: password length must be 8 characters or more
Cause: The password specified is too short and therefore insecure
Action: Please specify a password with more characters and retry the operation
ORA-47987: password is too simple
Cause: The password specified can be guessed based on dictionary terms and therefore insecure
Action: Please specify a password that is not based on dictionary terms and retry the operation
ORA-47988: password should contain at least one numeric and one alphabetic character
Cause: The password does not contain at least one numeric and one alphabetic character
Action: Please specify a password with at least one numeric and one alphabetic character and retry the operation
ORA-47989: password should differ by at least 3 characters
Cause: The password specified does not differ from the previous one by more than 3 characters
Action: Please specify a password that differs from the previous one by more than 3 characters and retry the operation
ORA-47994: Database Vault removal script must be run as SYS
Cause: The Database Vault removal script was not run as SYS.
Action: Run the Database Vault removal script as SYS.
ORA-47995: Database Vault must be linked off and disabled before removal
Cause: Database Vault was not linked off and disabled.
Action: Link Database Vault off and execute DBMS_MACADM.DISABLE_DV_CHECK as DV_OWNER.
ORA-47996: The RECYCLEBIN is turned on
Cause: The RECYCLEBIN was turned on.
Action: Turn off the RECYCLEBIN and then execute Database Vault Removal script.
ORA-47997: Database Vault protected schema does not exist
Cause: The Database Vault DVSYS protected schema did not exist.
Action: Contact Oracle Support Services for instructions.
ORA-47999: internal Database Vault error: string\n Error: string
Cause: An internal Database Vault framework error occurred.
Action: Contact Oracle Customer Support.
