PRKA-02001: GSD already exists
Cause:
An attempt was made to create the Global Services Daemon (GSD) application while there was a running GSD application.
Action:
Stop and remove the GSD and create the GSD application again using 'srvctl add nodeapps'.
PRKA-02002: Listener already exists
Cause:
An attempt was made to create a Listener application while there was a running Listener application.
Action:
Stop and remove the running Listener and create the Listener application again using 'srvctl add nodeapps'.
PRKA-02003: EM Agent already exists
Cause:
An attempt was made to create an Agent application while there was a running Agent application.
Action:
Stop the running Agent and create the Agent application again using 'srvctl add nodeapps'.
PRKA-02005: Netmasks are different for starting and ending IP addresses
Cause:
An invalid range of VIP addresses was specified for the cluster
Action:
Check if the starting and ending addresses in the VIP range belong to the same netmask.
