PRKH-01014: Current user "{0}" is not the oracle owner user "{1}" of oracle home "{2}"
Cause:
The command was run as a different user than the owner user of the oracle home path.
Action:
Retry the command as the user who owns the specified oracle home.
PRKH-01016: Failed to get CSS mode
Cause:
An error occurred on a Cluster Synchronization Services request. This message may be accompanied by others identifying the specific problem.
Action:
Correct the problem indicated by the accompanying messages, if possible. Otherwise. contact Oracle Support Services.
PRKH-01050: Buffer is too small
Cause:
An internal error occurred.
Action:
Contact Oracle Support Services.
PRKH-01051: Cluster software (skgxn) error
Cause:
An error occurred when Cluster Synchronization Services attempted to use non-Oracle vendor clusterware. This message may be accompanied by others identifying the specific problem.
Action:
Correct the problem indicated by the accompanying messages, if possible. Otherwise, contact Oracle Support Services.
PRKH-01052: Invalid arguments
Cause:
Action:
PRKH-01053: Cluster synchronization services are not active
Cause:
CSS daemon is not running or unable to authenticate with CSS daemon
Action:
Use 'crsctl check css' to ensure that CSS daemon is running. If CSS daemon is not running, execute 'crsctl start crs' command.
PRKH-01054: Communications error
Cause:
CSS daemon is not running on the local node or unable to authenticate with CSS daemon
Action:
PRKH-01055: Oracle Cluster Registry error
Cause:
OCR returned an error while processing a CSS request
Action:
Ensure that CRSD daemon is running e.g. with crsctl check clusterware
PRKH-01056: Unexpected CSS error
Cause:
Action:
PRKH-01057: Check for node with node number 0 failed.
Cause:
CSS daemon is not running on local node or unable to authenticate with CSS daemon.
Action:
PRKH-01058: Node number specified for the node name lookup is beyond the allowed node number range
Cause:
Action:
PRKH-01059: Failed to get ASM mode
Cause:
An error occurred on an Oracle Clusterware request. This message may be accompanied by others identifying the specific problem.
Action:
PRKH-03002: Vendor cluster software error occurred in Cluster Synchronization Services
Cause:
Action:
PRKH-03003: An attempt to communicate with the CSS daemon failed
Cause:
CSS daemon is not running.
Action:
Ensure that CSS daemon is running.
PRKH-03004: Failed due to insufficient memory for Cluster Synchronization Services
Cause:
Action:
PRKH-03005: Entity {0} was not registered with CSS
Cause:
The given entity (e.g. instance) was not registered with CSS.
Action:
Start the entity before retrying the operation.
PRKH-03009: An attempt was made by Cluster Synchronization Services to release a lock that was not held
Cause:
Action:
PRKH-03011: Cluster Synchronization Services was started but has not completed startup
Cause:
An attempt to connect to CSS failed because initialization is still in progress.
Action:
None
PRKH-03013: An improper buffer argument was supplied to Cluster Synchronization Services
Cause:
This is an internal error.
Action:
PRKH-03016: Invalid arguments
Cause:
Action:
PRKH-03050: Unexpected error ({0}) returned from Cluster Synchronization Services
Cause:
Action:
PRKH-03101: GIPC Error returned from DHCP module
Cause:
A communication error occurred on a DHCP operation. This message may be accompanied by others identifying the specific problem.
Action:
PRKH-03150: Unexpected error ({0}) returned from DHCP module
Cause:
Action:
PRKH-03202: An error occurred in Oracle Clusterware during an Operating System function call or request
Cause:
An error occurred in Oracle Clusterware. This message may be accompanied by others identifying the specific problem.
Action:
PRKH-03203: Required password not supplied
Cause:
A requested operation requires a password but none was supplied. This message may be accompanied by others identifying the specific problem.
Action:
PRKH-03204: An improper buffer argument was supplied to Oracle Clusterware
Cause:
Action:
PRKH-03205: Internal error in Oracle Clusterware
Cause:
Action:
PRKH-03250: Unexpected error ({0}) returned from Oracle Clusterware
Cause:
Action:
PRKH-03301: Invalid arguments
Cause:
Action:
PRKH-03302: Oracle Clusterware database support layer returned OCR error
Cause:
Action:
PRKH-03303: Oracle Clusterware database support layer returned OSD error
Cause:
Action:
PRKH-03304: Internal error returned from Oracle Clusterware database support layer
Cause:
Action:
PRKH-03306: Internal error returned from Oracle Clusterware database support layer
Cause:
Action:
PRKH-03307: Internal error returned from Oracle Clusterware database support layer
Cause:
Action:
PRKH-03340: Following VIP error occurred from Oracle Clusterware database support layer
Cause:
An error occurred while processing a VIP request. This message may be accompanied by others identifying the specific problem.
Action:
PRKH-03350: Unexpected error returned from Oracle Clusterware database support layer
Cause:
Action:
PRKH-03401: An improper buffer argument was supplied to an internal interface
Cause:
Action:
PRKH-03402: OCR error returned from an internal interface
Cause:
An internal interface encountered an error in OCR processing. This message may be accompanied by others identifying the specific problem.
Action:
PRKH-03450: Unexpected error ({0}) returned from an internal interface
Cause:
Action:
