PROC-00001: Oracle Cluster Registry cannot be initialized.
Cause:
An invalid init level was passed to initialize Oracle Cluster Registry.
Action:
Initialize Oracle Cluster Registry with a valid init level.
PROC-00002: Cannot perform cluster registry operation at the current init level.
Cause:
Program tried a cluster registry operation which is not permitted at the init level.
Action:
Initialize Oracle Cluster Registry with an appropriate init level.
PROC-00003: Cannot perform cluster registry operation because context is invalid.
Cause:
The Oracle Cluster Registry context passed was invalid.
Action:
This is an internal error. Contact Oracle Support Services.
PROC-00004: The cluster registry key to be operated on does not exist.
Cause:
Program tried a cluster registry operation on a key which does not exist.
Action:
Check to see if the key exists and try the operation again.
PROC-00005: User does not have permission to perform a cluster registry operation on this key.
Cause:
Program tried an operation on a cluster registry key for which it does not have permission.
Action:
Check to see if program is run as the correct user.
PROC-00006: User does not have permission to perform a cluster registry operation on this key.
Cause:
Program tried a cluster registry operation on a key for which it does not have permission.
Action:
PROC-00007: Cannot perform cluster registry operation because key or batch handle is invalid.
Cause:
The cluster registry key or batch handle passed was invalid.
Action:
PROC-00008: Cannot perform cluster registry operation because one of the parameters is invalid.
Cause:
Program tried a cluster registry operation using an invalid parameter.
Action:
PROC-00009: Cannot perform cluster registry operation because the buffer passed is too small.
Cause:
The amount of memory allocated for the buffer was insufficient.
Action:
PROC-00010: Cannot delete the cluster registry key as subkeys exist.
Cause:
The program tried to delete a key for which subkeys exist.
Action:
PROC-00011: Cannot perform cluster registry operation because key is NULL.
Cause:
The cluster registry key passed was NULL.
Action:
PROC-00012: Out of heap memory.
Cause:
The program ran out of heap memory.
Action:
PROC-00013: Cannot perform cluster registry operation because one of the parameters is NULL.
Cause:
Program tried a cluster registry operation using an NULL parameter.
Action:
PROC-00014: Unknown error occurred
Cause:
This is generic internal error for Oracle Cluster Registry.
Action:
PROC-00015: Failed to initialize the cluster registry
Cause:
The Oracle Cluster Registry could not be accessed. The possible causes are:
1. The cluster registry has not been formatted.
2. The cluster registry location is not accessible.
3. The cluster registry location has incorrect permissions.
4. Oracle Clusterware is not running.
Action:
1. Run the 'ocrcheck' command to confirm that the OCR is formatted and usable.
2. Run 'ocrcheck -config' command to retrieve the configured locations, and verify that each location is accessible and has the correct permissions via native platform or OS methods. If a location is an ASM disk group, verify that the disk group exists and is mounted.
3. Run 'crsctl check crs' command to verify that Oracle Clusterware is running.
PROC-00016: Cannot retrieve any more subkeys for the given keyhandle
Cause:
The key has no more subkeys to enumerate.
Action:
PROC-00017: Unimplemented feature
Cause:
Requested feature has not been implemented in the current release.
Action:
Try the feature again in the upcoming Oracle release.
PROC-00018: The value size passed is too large
Cause:
Cannot set a value of the given size.
Action:
PROC-00019: Cannot create more subkeys for the key
Cause:
An attempt was made to create more subkeys under a key that is not permitted by the cluster registry.
Action:
PROC-00020: ORACLE_HOME environment not set
Cause:
ORACLE_HOME environment not set.
Action:
Make sure that the ORACLE_HOME environment variable has been properly set and exported.
PROC-00021: Maximum permitted depth of the OCR tree is reached
Cause:
An attempt was made to create subkeys under a key which is already at depth PROCR_MAX_KEY_DEPTH
Action:
PROC-00022: The OCR backend has an invalid format
Cause:
An attempt was made to use OCR before initializing it.
Action:
Use the root.sh script. The 'ocrconfig -upgrade' command will initialize OCR.
PROC-00023: Error in cluster services layer
Cause:
An error occurred in the cluster services layer while performing a cluster registry operation.
Action:
PROC-00024: Error in the messaging layer
Cause:
An error occurred in the messaging layer while performing a cluster registry operation.
Action:
PROC-00025: Error in the NLS services
Cause:
An error occurred in the NLS services while performing a cluster registry operation.
Action:
PROC-00026: Error while accessing the physical storage
Cause:
Action:
PROC-00027: Error in authentication layer
Cause:
An error occurred in the authentication layer while performing a cluster registry operation.
Action:
PROC-00028: Oracle Cluster Registry already in current version
Cause:
An attempt to upgrade the cluster registry which has already been upgraded.
Action:
No action required.
PROC-00029: Error in logging layer
Cause:
An error occurred in the logging layer while performing a cluster registry operation.
Action:
PROC-00030: Oracle Cluster Registry IDs do not match
Cause:
The cluster registry storage seen by the client was not the same as the one seen by the server. This may be caused by a misconfiguration.
Action:
PROC-00031: Storage device for the cluster registry is too small
Cause:
The configured storage device or the storage device to be newly added to the cluster registry was too small.
Action:
Refer to the documentation and configure a storage device that is large enough for use by cluster registry. In case the cluster registry is already configured, execute the 'ocrcheck' command to retrieve the total size, and ensure that the size of the device to be added is large enough for use by cluster registry.
PROC-00032: Cluster Ready Services on the local node is not running
Cause:
The Cluster Ready Services on the local node was not running.
Action:
Use the 'crsctl start crs' command to start the Cluster Ready Services on the local node.
PROC-00033: Oracle Cluster Registry is not configured
Cause:
Oracle Cluster Registry configuration was not present on the node.
Action:
Install and configure Oracle Clusterware.
PROC-00034: Oracle Cluster Registry configurations are not compatible
Cause:
Cluster registry configuration on this node did not match with another node in the cluster.
Action:
Retrieve the cluster registry configuration using 'ocrcheck -config' command on all nodes in the cluster. Fix the configuration on this node and make it consistent using 'ocrconfig -repair' command.
PROC-00035: Cannot perform cluster registry operation due to invalid version
Cause:
The operation cannot be performed for this cluster active version
Action:
Complete the upgrade before retrying the operation
PROC-00036: No free space to perform this operation
Cause:
There is no free space left to perform the requested operation.
Action:
Free up space and retry the operation.
PROC-00037: Oracle Cluster Registry does not support the storage type configured
Cause:
The configured storage type for cluster registry is not supported
Action:
Change the configuration of the cluster registry to a supported storage type. Refer to Oracle documentation for an exhaustive list for each platform.
PROC-00038: Requested block number is not allocated from Oracle Cluster Registry
Cause:
The requested block number is not allocated from Oracle Cluster Registry.
Action:
Retry the operation with another block number.
PROC-00039: Requested block has an invalid header
Cause:
The requested block has an invalid header.
Action:
PROC-00040: Cannot add more operations to the batch
Cause:
An attempt was made to add an operation to a batch that already has the maximum allowed operations.
Action:
PROC-00041: Oracle Cluster Registry is incorrectly configured
Cause:
The cluster registry is incorrectly configured.
Action:
Correct the cluster registry configuration.
PROC-00042: User cannot access Oracle Cluster Registry configuration
Cause:
Program encountered an error accessing the cluster registry configuration.
Action:
Check to see if program is run as the correct user. Check that the cluster registry configuration has the correct permissions.
PROC-00043: Error in the ASM access layer
Cause:
An error occurred in the layer used to access OCR when configured on ASM managed storage.
Action:
PROC-00044: Error in network address and interface operations
Cause:
An error occurred in the network address and interface operations layer while performing a cluster registry operation.
Action:
PROC-00045: Error in the Oracle Clusterware API layer
Cause:
An error occurred in the Oracle Clusterware API layer.
Action:
PROC-00046: Cannot perform cluster registry operation because the batch is empty.
Cause:
An attempt was made to execute the batch without any operations in it.
Action:
PROC-00047: Cannot proceed while the Oracle Cluster Registry format upgrade is in progress.
Cause:
An Oracle Cluster Registry operation was requested, but found that an Oracle Cluster Registry format upgrade was in progress.
Action:
Retry the operation after the format upgrade completes.
PROC-00048: Cannot perform the Oracle Cluster Registry operation due to a transient error.
Cause:
A transient error occurred while performing the requested Oracle Cluster Registry operation. The operation was aborted without retrying, as requested by the client.
Action:
Retry the operation.
PROC-00049: The specified Oracle Cluster Registry backup location is inaccessible on nodes string.
Cause:
The Oracle Cluster Registry backup location did not exist, was not mounted correctly or did not have the required permissions on the above listed nodes.
Action:
Ensure that the backup location exists with appropriate permissions on the above listed nodes. If the backup location is an ASM disk group, the disk group must be mounted correctly; also check the entries in the ASM alert log file for more details.
PROC-00050: The Oracle Cluster Registry location to be added is inaccessible on nodes string.
Cause:
The Oracle Cluster Registry location to be added did not exist, was not mounted correctly or did not have the required permissions on the above listed nodes.
Action:
Ensure that the location exists with appropriate permissions on the above listed nodes. If the location is an ASM disk group, the disk group must be mounted correctly; also check the entries in the ASM alert log file for more details.
PROC-00051: Error in patch management layer
Cause:
An error occurred in the patch management layer while performing a cluster registry operation.
Action:
PROC-00052: Failed to update the Oracle High Availability Service (OHASD) resource dependencies on nodes string.
Cause:
An error occurred while updating the OHASD resource dependencies on the above listed nodes.
Action:
PROC-00053: The configured patch level does not match the release patch level
Cause:
1. Oracle Clusterware was started before the patch application had completed.
2. Oracle Clusterware was started from a location other than the Grid Infrastructure home that was most recently patched.
Action:
Check the Cluster Ready Services (CRSD) log file for details.
1. Complete applying the patch on this node.
2. Ensure the Oracle Clusterware is started from the Grid Infrastructure home that was most recently patched. Verify the patch level matches using the 'crsctl query crs releasepatch' and the 'crsctl query crs softwarepatch' commands. If the problem persists, contact Oracle Support Services.
PROC-00054: The requested OCR operation is not supported.
Cause:
An attempt was made to use an operation that is not supported.
Action:
Verify the operation is valid before resubmitting it.
PROC-00055: cannot create and set the cluster registry key because the key already exists
Cause:
The program tried to create and set the cluster registry key when the key already exists.
Action:
PROC-00056: user does not have privilege to access the Oracle Cluster Registry
Cause:
An operation that accesses the Oracle Cluster Registry was requested by a user with insufficient privileges.
Action:
Run the command as root or administrator user.
PROC-00057: Oracle Cluster Registry contains inconsistent data.
Cause:
Inconsistent data was detected in the Oracle Cluster Registry.
Action:
Check the availability of Oracle Cluster Registry backups using the 'ocrconfig -showbackup' command and restore a compatible backup. If you are not able to resolve the problem, contact Oracle Support Services.
PROC-00101: Operating System error [string]
Cause:
An error occurred in the operating system layer while performing a cluster registry operation
Action:
PROC-00102: Cluster services error [string]
Cause:
Action:
PROC-00103: Messaging error [string]
Cause:
Action:
PROC-00104: Authentication error [string]
Cause:
Action:
PROC-00105: Logging error
Cause:
An error occurred in the logging layer while while performing a cluster registry operation.
Action:
PROC-00106: Unidentified component error
Cause:
An error occurred in an unidentified layer while performing a cluster registry operation.
Action:
PROC-00107: Storage layer error [string]
Cause:
An error occurred in the storage layer while performing a cluster registry operation.
Action:
PROC-00108: ASM error [string]
Cause:
An error occurred in the asm layer while performing a cluster registry operation.
Action:
PROC-00109: Network address and interface operations error
Cause:
Action:
PROC-00110: Patch and upgrade error [string]
Cause:
An error occurred in the patch and upgrade management layer while performing a cluster registry operation.
Action:
