Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
128 PRVP-01041 to PRVP-03563
PRVP-01041: value specified "{0}" for command line option '-port' is not a number
Cause: A non-numeric value was specified for command line option '-port'.
Action: Specify a numeric value for the command line option '-port'.
PRVP-01044: Error occurred while opening configuration file "{0}"
Cause: Configuration file could not be opened. It either does not exist or you are not allowed read access.
Action: Provide a usable configuration file.
PRVP-01049: Failed to read the root user password from standard input
Cause: An attempt to read the password for the root user from standard input failed.
Action: Look at the accompanying messages for details on the cause of failure.
PRVP-01050: Failed to read the password for 'sudo' user "{1}" from standard input
Cause: An attempt to read the password for specified 'sudo' user from standard input failed.
PRVP-01051: Failed to read the password for 'pbrun' user "{1}" from standard input
Cause: An attempt to read the password for specified 'pbrun' user for from standard input failed.
PRVP-01052: Command line option -method required when -dhcpport is less than 1024. The DHCP port value used is "{0}".
Cause: An attempt to check DHCP was rejected because the user did not have sufficient authority to listen on the specified DHCP port.
Action: DHCP checks when command line option -dhcpport is less than 1024 can be run only as root user. When command line option -dhcpport is not specified the default value of DHCP port used is 67. Make sure that required credentials are supplied using the command line option -method.
PRVP-01055: -d <oracle_home> cannot be specified in combination with -collect cluster.
Cause: -d <oracle_home> cannot be combined with -collect cluster.
Action: Remove the -d <oracle_home> specification.
PRVP-01061: Ignoring domains for the following node names specified with domain "{0}". Verification will proceed with nodes "{1}"
Cause: Node names were specified with domain names, and the domain names were ignored.
Action: Make sure that node names are specified without domain names.
PRVP-03514: -savedir flag not specified.
Cause: The -savedir flag was not specified while running the baseline collection command through 'runcluvfy'.
Action: Specify a valid value for -savedir flag.
PRVP-03563: Invalid command line option specified. The option '-serviceuser' is not valid with version "{0}".
Cause: Command line option -serviceuser was specified with release version earlier than 12g.
Action: Use -serviceuser option with 12g or later release.
