You use the Form Designer to set the Point of View, and specify form details, row, column, and header options.
After you create a data form, you can scan it to check the validity. The system generates the form script and validates it. If there are errors, they are displayed in the Script view. See Using Data Form Scripts.
For information on setting form details:
To create a data form:
Click New, and then Data Form, or select Actions, then New, and then Data Form.
The Forms Designer is displayed by default.
Tip: | If the Designer page is not automatically displayed, click Designer, or select Actions, and then Designer. |
Optional: To add rows or columns, click Add New Row, Add New Column, or select Actions, and then Add New Row or Add New Column.
Tip: | To delete a row or column, click Delete Column/Row, or select Actions, and then Delete Column/Row. |
Tip: | To reset the form to the default values or the last saved definition, click Reset. |
Click Save to save the form, enter the information for the form, and then click Save.
