Deleting Applications
Caution!
This information is provided for use with Financial Management application Administration only. For information on application administration using Performance Management Architect, see the Oracle Hyperion Enterprise Performance Management Architect Administrator's Guide.
Before you delete an application, ensure that no other user is currently using the application.
To delete an application, you must have these security roles:
  To delete an application:
  1. Select Navigate, then Administer, and then Consolidation Administration.
  2. Select Administration, and then Applications.
  3. Select the application to delete.
  4. Click Delete, or select Actions, and then Delete.
  5. If the application is open, a warning message displays. Select an option:
    • To delete the application forcefully, click Force Delete.
      Users who are logged in receive error messages after the application is deleted.
    • To view the application users, click See Users. From the System Users page, you can log out users.
    • To cancel application deletion, click Cancel.
  6. If the application is not open by you or other users, a confirmation prompt displays. Click Yes to delete the application.
