You can use the Clear Invalid Records feature to scan an application for invalid records and to remove them. You must have Administrator security access to clear invalid records.
Running the Clear Invalid Records process impacts the database, network, and Financial Management environment and can cause performance issues. This process must be run in a maintenance window where users are not accessing the Financial Management environment.
