You can extract member lists from an application. Extracted member lists are saved as ASCII files. By default, member list files use the LST file extension. After you extract member lists, you can view and modify the member list information in a text editor.
To extract member lists:
Select Consolidation, then Extract, and then Application Elements.
Follow the download instructions displayed in the browser to download the extracted file.
The instructions vary depending on the Web browser that you are using. Make sure to save the file in the Web directory that you set up.
Optional: To download the log file, click Download Log. Click Open to display the log file, or Save and select a location to save the file locally.
