When you extract rules, they are saved to an ASCII file that supports multibyte character sets (MBCS). By default, rules files use the RLE file extension. After you extract rules, you can view and modify them in a text editor.
To extract rules:
Select Consolidation, then Extract, and then Application Elements.
Follow the download instructions displayed in the browser to download the extracted file.
The instructions vary depending on the Web browser that you are using. Make sure to save the file in the Web directory that you set up.
Optional: To download the log file, click Download Log. Click Open to display the log file, or Save and select a location to save the file locally.
