You can extract application security to view or modify it in a text editor. When you extract application security from an application, save the file in a format that supports multibyte character sets (MBCS). By default, application security files use the SEC file extension.
You can extract these types of security information:
To extract application security:
Select Consolidation, then Extract, and then Application Elements.
In the Security section, from Delimiter, select the character used to separate information in the file.
From Filters, select the types of security to extract.
Tip: | To reset the selections, click Reset. |
Follow the download instructions displayed in the browser to download the extracted file.
The instructions vary depending on the Web browser that you are using. Make sure to save the file in the Web directory that you set up.
Optional: To download the log file, click Download Log. Click Open to display the log file, or Save and select a location to save the file locally.
