Viewing the Intercompany Transactions Summary
You can view a summary of the status for all intercompany transactions, and if necessary, filter entities to display specific entity
To view the intercompany transactions summary:
Select Consolidation, then Intercompany, and then Monitor.
Select a Scenario, Year, and Period for the entity.
Using the Entity filter, select one or more entities for which to view a summary of transactions.
Click Summary, or select Summary from the context menu, or select Actions, and then Summary.
When you finish viewing the summary, click OK.
