Opening Applications
In Financial Management, all data is processed within applications. You can open and work with multiple applications at one time.
To access an application, you must be assigned as a user of the application.
  To open an application:
  1. Select Navigate, then Applications, then Consolidation.
  2. Select an application.
    If the application is not listed, click Refresh.
