Defining Reports
In This Section:
Defining Journal Report Scripts
Defining Intercompany Matching Report Scripts
Defining Intercompany Transaction Report Scripts
You can define these report types in Financial Management:
You can create a new report definition for each report, or you can open and modify a report definition.
You define a report using one of these methods:
The date, time, and user fields are automatically displayed as header information on all reports. The Point of View definitions differ for each report. For detailed examples of reports, see Defining Journal Report Scripts, and Defining Intercompany Matching Report Scripts.
Sample Intercompany Partner Matching report scripts are included when you install Sample Applications for Financial Management. The files are located in the Sample Applications folder in the directory to which you installed Financial Management.
