During the installation process, you configure and register server clusters. After you create an application, you can register the application against the preferred server cluster.
To register applications:
Select Navigate, then Administer, and then Consolidation Administration.
Select Administration, and then Applications.
From the application list, select an application.
Click Register, or select Actions, and then Register.
From the Cluster list, select a server cluster.
From the User Management Project list, select the Oracle Hyperion Shared Services project.
Click Register.
