After you complete all the steps in the Application Creation Wizard and click Create Application, the system generates a binary application Profile (.PER) file using the options that you selected during the wizard navigation. The application is then created using the Profile file. Metadata is updated and loaded with your selected settings.
After a Profile file is created for an application, you can create a new application using the Profile file. See Creating an Application from a Profile File.
