Running Security Reports
You can run security reports on the information that you selected while setting up security for the application. You can run reports for classes by user, roles by user, classes and roles by user, and users by group. You can view the report online or you can export it to a file.
  To create a security report:
  1. From the Oracle Hyperion Shared Services Console, expand Application Groups, right-click the application name, and select Assign Access Control.
  2. Select Security Reports, or select Actions, and then Security Reports.
  3. Select a report option:
    • Access Rights and select options:
      • Classes by User
      • Roles by User
    • Users by Group
  4. Select a Report Format: PDF, RTF, HTML, XLS, XLSX.
  5. Optional: Select a Template.
  6. Select an option:
    • Launch Report to open the report in a new page.
    • Export to File to save the report in the selected report file format.
