Security classes determine user and group access rights to application elements.
Caution! | The information in this section is provided for use with Classic Financial Management applications only. For information on setting up security using Performance Management Architect, see the Oracle Hyperion Enterprise Performance Management Architect Administrator's Guide. |
You can perform these procedures:
Note: | Only users assigned to the Provisioning Manager role can define security classes for applications. |
After you define security classes for an application, you can assign the security classes to application elements such as accounts and entities.
A user's or group's ability to access application elements depends on the security classes to which the user or group belongs and on the security class associated with the application elements.
A system-generated security class called [Default] is created as part of an application. It cannot be deleted or modified by users. Access rights can be assigned to the [Default] security class. Any member that is not assigned a security class is treated as if it has the Default security class.
