In This Section:
Available Configuration Settings
Changing Configuration Settings
The Settings module enables you to view and modify Financial Management configuration settings. By default, the Settings table is populated with the recommended settings at the time of installation.
You can change setting values if required. For example, you might need to change values based on memory usage or to improve performance. For considerations on updating these values, see Optimizing Performance.
You can override settings for a specific application. To change a system-level value, you must have the Financial Management Administrator security role. To change an application level value, you must have both the Financial Management Administrator and the Application Administrator security roles.
You can sort the settings list, search for settings, and export them to an Excel worksheet. You can delete setting overrides, but you cannot delete settings created by the system.
You can also view runtime values for specific application settings. See Viewing Effective Settings.
See these topics:
