Auditing Tasks
You can use the Task Audit feature to view the tasks performed by users. You can filter audited tasks by date range, application server, user, and task performed.
If you are assigned the Application Administrator role, you can view, export, and delete task audit information. If you are not an administrator, but have the View Task Audit role, you can view and export task audit information.
These user activities are logged in the task audit:
The task audit log includes this information:
The task audit log information is stored in the (APPNAME_TASK_AUDIT) table. You can back up or extract the information in the table to a file, then clear the table. You should monitor the size of the log and clear it on a regular basis.
  To perform a task audit:
  1. Select Navigate, then Administer, and then Consolidation Administration.
  2. Select Administration, then Audit, and then Tasks.
  3. Optional: From the Filters panel, select filter criteria:
    • Application
    • Server
    • Date Range
      • To view all dates, select Include All.
      • To specify a date range, select Range, and then specify Minutes, Hours, Days, or Months.
      • To specify specific dates, select Custom, and then enter a Start and End date, or click the calendar icon to select dates.
    • Users
    • Tasks
  4. Optional: To export the audit information to a CSV file, click Export, or select Actions, and then Export and follow the download instructions.
  5. Optional: To delete entries based on the current filter settings, click Delete based on the current filter settings, or select Actions, and then Delete Filtered.
  6. Optional: To delete all entries from the log, click Delete All, or select Actions, and then Delete All.
    When you clear the log, a record of the clear process remains in the log and cannot be erased.
