The Checksum Support and Content Verification program introduces additional levels of data verification into the Oracle DIVArchive Suite. This feature brings checksum generation and verification for each file and object managed by DIVArchive.
Oracle Linux 7 (x86_64, 64-bit) is now supported for all core DIVArchive components. If you require a Linux environment in a language other than English, simply create a user and identify the desired language in the user profile. Oracle Linux has support for a variety of languages (other than English) and the language can be selected during Linux installation. Windows installations must use the English language and Oracle only supports English-based Windows environments.
All Windows batch files (.bat) have corresponding shell scripts (.sh) in Linux. You must substitute Windows paths with Linux paths when operating on Linux. For example, the Windows path C:\DIVA\Program will be /home/diva/DIVA/Program when running under Linux.
Note: Linux commands, paths and file names are case-sensitive. |
See the Oracle DIVArchive Supported Environments Guide in the Oracle DIVArchive 7.4 Core Documentation Library for information about certain limitations when running in the Linux environment.
The available checksum algorithms for Oracle DIVArchive are as follows:
Message Digest 2 (MD2) Algorithm: A cryptographic hash function developed in 1989. The algorithm is optimized for 8-bit computers. Although other algorithms have been proposed since, MD2 remains in use in public key infrastructures as part of certificates generated with MD2 and RSA.
Modification Detection Code 2: In cryptography MDC2 (sometimes called Meyer-Schilling) is a cryptographic hash function with a 128-bit hash value. MDC2 is based on a block cipher with a proof of security in the ideal-cipher model.
Message Digest 5 Algorithm: In cryptography, MD5 is a widely used cryptographic hash function with a 128-bit hash value. As an Internet standard (RFC 1321), MD5 has been employed in a wide variety of security applications and is commonly used to check the integrity of files. MD5 is the default DIVArchive Checksum Type.
Secure Hash Algorithm: One of several cryptographic hash functions published by the National Institute of Standards and Technology as a US Federal Information Processing Standard.
Secure Hash Algorithm-1: A 160-bit hash function which resembles the MD5 algorithm. This was designed by the National Security Agency (NSA) to be part of the Digital Signature Algorithm. SHA-1 is the default SAMMAsolo Checksum Type.
RACE Integrity Primitives Evaluation Message Digest: A 160-bit message digest algorithm (cryptographic hash function) developed in Leuven (Belgium) at the COSIC Research Group at the Katholieke Universiteit Leuven, and first published in 1996. It is an improved version of RIPEMD, which was based upon the design principles used in MD4, and is similar in performance to the more popular SHA-1.
When an object contains multiple files (components), a checksum will be generated and later verified for each of the component elements. There are three types of checksums that are distinguishable:
This checksum is provided through the API in the Archive request, or retrieved by the Oracle DIVArchive Actor from the Source/Destination. It ensures maximum security because it allows DIVArchive to verify all transfers to and within the archive system.
The GC is obtained before the archive starts. It is either passed in the archiveObject API function, or obtained from the Source/Destination by the Oracle DIVArchive Actor using an API provided by the Source/Destination manufacturer.
This checksum is generated during the transfer phase into DIVArchive and based on the data that is received from the network (for networked sources), calculated during the actual transfer, or read from the device (for disk type sources). This type of checksum does not allow detecting corruptions occurring during the transfer from the Source/Destination to the Actor. However, all other subsequent corruptions can be detected.
The AC is calculated real-time before it writing to disk or other storage medium (within DIVArchive) during data transfer.
This checksum is generated during the read of an object already stored in the archive system which has no checksum previously associated with it - either because the previous DIVArchive version did not support it, or the option was not activated.
This type of checksum does not allow corruption detection that occurred during an earlier stage (for example, during the archive or further data movement within a copy or repack process). However, it enables corruption detection in all further data processing.
This checksum is generated during requests on existing objects. (for example, Copy, Restore, and so on).
Checksum verification occurs when transferring data from a Source/Destination or when reading data from a source or a storage medium. The latter occurs during the retrieval of an object from a storage medium during routine functions (Restore, Copy, Repack, and Transcode, but not Oracle DIVArchive Partial File Restore), during a read-back from storage (Verify Following Write feature), or from the source (Verify Following Restore feature). MD5 is the default DIVArchive Checksum Type which applies to the entire system.
There are four major workflows used for Checksum Support Verification. Each of these workflows are described as follows:
Verify Read is the default workflow. It calculates a real-time checksum for content as it is being read from a storage medium (for example, a disk or a tape - including cache disks configured for VR) inside DIVArchive, and performs checksum verification. The operation is only considered successful after this full read operation is complete and the calculated checksum matches the checksum attached to the stored data.
Verify Write reads back data that was just written to a storage medium, for example a disk or a tape inside DIVArchive, and performs checksum verification. This read-back data will be used to calculate a real-time checksum and then discarded. The write operation is successful when the full read operation is complete and the calculated checksum matches the checksum of the incoming data.
Verify Following Archive re-transfers the data from the source device after an initial archive operation, and then compares it against the AC checksum calculated. The archive operation is successful when the second transfer is fully complete and the checksums are identical. This verification mode is not compatible with GC enabled sources or complex objects.
Verify Following Restore re-transfers the data from the source device after an initial restore operation, and then compares it with the checksum attached to the stored data. This restore operation is considered successful when the second transfer is fully complete and the checksums are identical.
WARNING: This verification mode is not compatible with complex objects. |
Each workflow can be used with one or several requests. The following list describes the DIVArchive requests and the appropriate corresponding checksum workflows. The operation is listed and then the supported checksum workflows for that operation.
Notes: Verify Following Archive and Genuine Checksum are mutually exclusive.Verify Write does not apply to cache disk writes. |
Verify Read (default), Genuine Checksum, Verify Following Archive, Verify Write, SAMMAsolo integration
Verify Read (default), Verify Following Restore
Checksums are not supported for Partial File Restore.
Verify Read (default), Verify Write
Export content with checksum (default)
Import content with checksum (default)
Verify Read, Genuine Checksum - both workflows are supported with a change in the object format.
DIVArchive 7.4 supports all checksum workflows for non-complex objects. However, only Verify Write (VW) is supported for complex objects.
Complex object checksums are stored in the Metadata database rather than the Oracle database, and therefore will not be displayed in any database queries. The getObjectInfo API call will return a phony checksum, and not all files and folders will be displayed (only a single file representing the entire complex object).
If checksum support is disabled when a complex object is archived, and then subsequently enabled, there will be no checksum comparison during operations on the complex object. In other words, whatever checksum is used when the complex object is archived will be the checksum used throughout the life of the object.
