| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The Service Processor Configuration tab in the main window displays information about the firmware, host policy configuration, power on self test configuration, SP alert configuration, and DNS and NTP settings. You can select one of these tabs to view detailed information about it.
The Firmware Information tab shows a table with the component identifier for all installed firmware, the type, the version, and the release date.
The Host Policy Configuration tab shows a table with a list of the host policy names and their current values.
The Power On Self Test Configuration tab shows a table with a list of the power on self test setting names and their current values.
The SP Alert Configuration tab shows a table with the service processor alert names. For each alert, the table provides the alert type, alert level, destination address, destination port, SNMP version, and community.
The DNS & NTP tab shows information about the DNS and NTP settings. The following fields are displayed:
Auto DNS/DHCP: Indicates whether DNS or DHCP is being used.
DNS Servers: Lists the DNS servers in use.
Search Path: Lists the search path for the DNS servers.
Time: Lists the current time and time zone for the hardware.
Use NTP Server: Indicates whether an NTP server is being used.
NTP Server 1: The IP address of the first NTP server.
NTP Server 2: The IP address of the second NTP server.
