| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
With Host Services, you can see which services are managed by the operating system and the state of the services. This is useful when you want to quickly identify which services are in need of attention and the state of services that are important to you.
Host Services monitors and displays the services running on a host. You can view the current state of a service. However, you cannot create, delete, or modify the properties of a service. Fault Management Resource Identifier (FMRI) identifies each service on the system.
The following are the service states:
Running: The service is running.
Stopped. The service is either disabled or offline and the service is not running.
The Host Services page displays the service state, the number of spawned process identifiers, and the spawned process identifiers (PIDs).
