| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The Hardware View tab in the main window displays a photorealistic view of compatible hardware, including the front, top, and rear, and a table view of the hardware's components.
Select Photorealistic View to display the photorealistic view of the hardware. Components with incidents are outlined in red.
You can click any component displayed in the photorealistic view to view additional information about that component. The following information is displayed if it is available and relevant to the component:
Component Name
Manufacturer
Serial Number
Part Number
Total Cores: The number of cores for a CPU
Enabled Cores: The number of enabled cores for a CPU
Size: The size of memory components in GB
Select Table to display a table of the hardware components. The following information is displayed for each component:
Slot Number
Component Name
Component Type
