| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
When you first install the app, there is no default Enterprise Manager connection, so you must supply a Cloud Control URL. There are two ways to do this:
Use the iDevice Settings app
Launch the Cloud Control Mobile app
In either case, first log in to VPN if required before proceeding with the instructions below. Without the VPN connection, the login screen will not appear.
iDevice Settings
Define a default Cloud Control URL as follows:
Tap the Settings icon on the Home screen.
Tap Cloud Control in the apps list.
On the Cloud Control screen, enter a name to identify the site and type the Cloud Control URL to which to connect. The URL should be of the form:
https://www.yoursite.com/em
Tap Settings to store the information and return to the list of apps.
Initial App Launch
Proceed with the login.
