Go to primary content
Oracle® Enterprise Manager Cloud Control Administrator's Guide
13c Release 2
E74458-09
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
39.10 Viewing Host Storage
Host Storage contains links to detailed storage information, including the disks, filesystems, volume group and SAN configuration. You can view all storage, or filter by volume name, or select to view only local or remote storage.
  1. From the Targets menu, select Hosts.
    The Hosts page appears with a list of all managed hosts. You can sort the list.
  2. Click the host name from the list of managed hosts.
  3. Click the Host Storage tab.
  4. Select Local or Remote to view a subset of storage. Enter a name in the Volume Name field to filter your results.
  5. Click the icon for the storage details you want to view. For example, for Linux the options are Disks, Filesystems, Linux LVM Volume Group(s), and SAN Configuration.
