| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The focal point of Information Publisher is the report definition. A report definition tells the reporting framework how to generate a specific report by defining report properties such as report content, user access, and scheduling of report generation.
Information Publisher comes with a comprehensive library of predefined report definitions, allowing you to generate fully formatted HTML reports presenting critical operations and business information without any additional configuration or setup. .
Generating this HTML report involved three simple steps:
Step 1: Click Availability History (Group) in the report definition list.
Step 2: Select the group for which you want to run the report.
Step 3: Click Continue to generate the fully-formed report.
Supplied report definitions are organized by functional category with each category covering key areas.
To access the Information Publisher home page, from the Enterprise menu, choose Reports and then Information Publisher.
