Go to primary content
Oracle® Enterprise Manager Cloud Control Administrator's Guide
13c Release 2
E74458-09
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
35.6 Changing PDU Monitoring Credentials
In case the HTTP and SNMP PDU credentials are changed on the PDU, you can change the credentials in the Enterprise Manager using the PDU's Management Interface.
35.6.1 Change the HTTP Credentials
Perform the following steps to change the http credentials:
  1. Under Setup, click Security, then click Monitoring Credentials.
  2. In the Target Type column, select Systems Infrastructure PDU, then click Manage Monitoring Credentials.
  3. In the Systems Infrastructure PDU Monitoring Credentials screen, select the HTTP Monitoring Credentials (in the Credential Set column), then click Set Credentials.
  4. In the Enter Monitoring Credentials screen, enter new credentials for the PDU HTTP, then click Test and Save.
35.6.2 Changing the SNMP Credentials
Perform the following steps to change the SNMP credentials:
  3. In the Systems Infrastructure PDU Monitoring Credentials screen, select the SNMP Monitoring Credentials (in the Credential Set column), then click Set Credentials.
    Figure 35-7 Set SNMP Credentials
  4. In the Enter Monitoring Credentials screen, enter new credentials for the PDU SNMP, then click Save.
