| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The Energy tab in the main window displays information about the hardware's energy consumption.
The summary section displays three graphs showing basic temperature, fan speed, and power information. You can use the Time Range dropdown to select a different time interval to display.
The first graph shows the inlet and exhaust temperatures in degrees Celsius.
The second graph shows the fan speed as a percentage of the maximum.
The third graph shows the power consumption and utilization in watts.
You can click the Table View link to view a table of the data points used to create the graph.
