| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Cloud Control Mobile has its own settings interface apart from the iDevice Settings app that you use to manage all apps.
In managing Cloud Control Mobile app settings, you perform the following actions:
Add a site
Edit a site
Delete a site
Change the default site
Each action starts with the same basic steps:
Tap the actions icon on the right of the navigation bar.
Tap Settings in the action sheet.
Tap the Edit Sites table row.
Tap Edit. The Sites management screen appears:
Then proceed as described below for each individual action.
Add a Site
Tap the + sign on the left of the Sites navigation bar.
Type a name and a URL for the site to be added.
Tap Done on the Add Site navigation bar to close the screen.
Tap Done on the Sites navigation bar to exit edit mode.
Tap Settings on the Sites navigation bar to close the Sites list screen.
Tap Save on the Settings navigation bar to complete the action.
Edit a Site
Tap the blue arrow to the right of the URL to be edited.
Change the values as appropriate.
Tap Done on the Edit Site navigation bar to close the screen.
Tap Save on the Sites navigation bar to complete the action.
Delete a Site
Tap the red circle to the left of the URL to be deleted.
Tap Delete that appears on the right in the table row.
Tap Done on the Sites navigation bar to close the screen.
Change the Default Site
Note that you also can change the default site in iDevice Settings for Cloud Control.
